add exfat-utils for ExFAT filesystem support to
"packagegroup-base-tdx-cli"
Related-to: ELB-5583
Signed-off-by: Parth Pancholi <parth.pancholi@toradex.com>
(cherry picked from commit fede816e0e6d8f92084998f6e63b302b5f218c11)
Add tpm packagegroup to the multimedia reference image.
Related-to: ELB-5500
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
(cherry picked from commit 242b266f3bfebf8a1f2698ca1de3022729e6355e)
Create a new packagegroup with the tools and libraries needed to
use/develop for the TPM. This is only basic functionalities but is also
possible to develop applications using the SDK. For now, the tpm software
stack is added only for the Verdin SoM.
(cherry picked from commit 248ada4d4288a7d9ceb1e81b1b3e75cebcfe810d)
add jq cli for JSON data processing to "packagegroup-devel-tdx-cli"
Related-to: ELB-5433
(cherry picked from commit 3a8301c17aeabaf32c7674b6da3224694086cfaf)
Remove mwifiexap as mwifiexconf is now provided via
MACHINE_EXTRA_RRECOMMENDS.
(cherry picked from commit 655ddc7a45b883d705407b6a002aac8191b58c7d)
Add linux-firmware-iw416 package to the wifi firmware package group.
Related-to: ELB-5247
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
(cherry picked from commit ac087af8ca07b847e48e9f321a1e606b61b156c1)
Add mwifiexap package, simplify using mwifiex driver in AP mode.
Related-to: ELB-5192
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
(cherry picked from commit 4860e75022c791cc7157a8ebf7e30befe5c0cc75)
Verdin AM62 is expected to have SKUs without a GPU too. So start a demo
application which works resonably well without a GPU.
Note that currently the X11 distros do not build for the verdin-am62
machine. Even so, do the change also if one would build for X11.
Related-to: ELB-5184
(cherry picked from commit cd885de817405c00298500f90af689612757aebb)
Now libusbgx-config contains all the start scripts and schema files.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
A Powerful Diagnostic Tool for Texas Instruments K3 based Processors.
Add it to the packagegroup-devel-tdx-cli packagegroup if building for
a AM62xx processor.
Related-to: ELB-5130
(cherry picked from commit a4c3f41c2a522b5f4818a794834c6e0649abcf66)
Do not install btuart on verdin-imx8mp anymore. We can remove this
because we use serdev to load the bluetooth driver from now on.
Related-to: ELB-5030
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit 388954e3541a0fbd4a4e3fb11f53235536bb5b09)
Related-to: ELB-4978
(cherry picked from commit ef7368d235a2c08ec72b040fdadaa994b62d3f38)
squash missing append:
(cherry picked from commit 3ed48330988647960161aec76eb5c789cdff1d41)
The tdx-info shell script is a helper tool intended to simplify getting
information (software and hardware related) on Toradex modules (and
potentially on any machine).
For more details on tdx-info, see https://github.com/toradex/tdx-info/blob/master/README.md
Related-to: ELB-4860
Signed-off-by: Henrique Garcia <henrique.garcia@toradex.com>
(cherry picked from commit a38e08181f08a6b2d50e7b30b39db45ed47fda39)
Turns out that somehow we still have some old override syntax stuff
laying around!
This prevented the btuart stuff being installed on the Verdin iMX8M
Plus which would be responsible for out-of-the-box Bluetooth operation.
(cherry picked from commit cdf85aa03e9f0d9c8a9bc880fa58fe2f978019ef)
The vulkan packages were splitted, however that wasn't updated in the
removal for mx8mm-nxp-bsp.
Otherwise it would not be installed to tdx-reference-minimal-image
image.
Related-to: ELB-4727
We dont support the following machines any more:
colibri-t20/colibri-t30/apalis-t30/apalis-tk1/colibri-vf, let's drop
their references.
The recipe spidev-test is only used by colibri-vf, also drop it.
Related-to: ELB-4471
canfdtest binary has been splitted to can-utils-cantest subpackage in
meta-openembedded layer and we want that to be in our image, let's add
it to RRECOMMENDS.
Related-to: ELB-4627
mwifiexap is required to create the uap0 device to be used for Wi-Fi AP
mode, this used to be included because of the `mx8`
RRECOMMENDS_packagegroup-machine-tdx-cli,
however after the addition of a new `verdin-imx8mp` it is no longer
there.
Add mwifiexap explicitly to verdin-imx8mp packagegroup to solve the
issue.
Related-to: ELB-4535
Fixes: 7df50f3ff17a ("packagegroup-tdx-cli: verdin-imx8mp: add btuart")
(cherry picked from commit ce3c1925df34b4d299b2dd1003ced41b9485ce41)
Related-to: ELB-4451
(cherry picked from commit 190f3ee1e3005997fe331345c13724ea2d58e1af)
To get gst-play and gst-launcher tools.
Related-to: ELB-2913
We dont need it, it's deprecated.
Related-to: ELB-4553
It's deprecated and not being used by Toradex.
Related-to: ELB-4539
Use bluealsa recipe from meta-openembedded layer.
Related-to: ELB-4505
This adds the Bluetooth UART initialisation as required for the Verdin
iMX8M Plus 4GB WB IT V1.1A.
(cherry picked from commit 7df50f3ff17aa4ce839dee8a38f14844460ac819)
This adds the Wi-Fi/Bluetooth firmware as required for the Verdin iMX8M
(cherry picked from commit c67b830a4f768d6507949bfcdff2f8c7b60a8f5e)
There is now a 'weston' image feature introduced in OE, we can use it
to install weston related packages and choose SYSTEMD_DEFAULT_TARGET.
Also change to use "x11-base" image feature instead of "x11", this
ensures x11 init scripts would be installed to image.
Related-to: ELB-3477
Follow meta-freescale commit 30f5ce1d ("Generalize overrides subsystem for
NXP and Mainline support").
TEZI_SHOW_EULA_LICENSE shall be a machine global variable but not image
specific, move it to tdx-base.inc in meta-toradex-distro layer.
Torizoncore/Tezi/BSP now use the same setting of
TEZI_SHOW_EULA_LICENSE.
Related-to: TOR-2102
(cherry picked from commit 95a04d675063b714504ccc9d38f6ea71244f64e4)
Add fio, Flexible I/O tester [*], to devel-tdx-cli package group, the
tool is useful for benchmark and hardware verification of I/O subsystem
and hardware devices.
tdx-reference-multimedia-image rootfs size increase is 1124k after the
inclusion.
[*] https://fio.readthedocs.io/
Related-to: ELB-4213
(cherry picked from commit c369af47314e1b1e1776dcfa0cee1befc73fd044)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
(cherry picked from commit f99619b2135ff939b6370be8116d66a10bc84836)
NXP provides proprietary VPU libraries with media codecs for i.MX6
Toradex Easy Installer customer has to accept EULA for i.MX6 builds
Related-to: ELB-3945
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
(cherry picked from commit edb69bd5c57c0bc65558eca01553df6c433bd194)
The service "set-hostname" adds a serial number of a module to a
machine hostname. It allows a customer to identify a module he
is working with simply.
Add it to the "packagegroup-base-tdx-cli", so that all Reference
Multimedia and Minimal images have hostnames like Torizon in the
style of "colibri-imx8x-06748675". Also, customers using the
"packagegroup-base-tdx-cli" inherit that and it lands in their
production image.
Related-to: ELB-1322
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit c00e37b6324b16361ddc08abfdf39acd54d60ce6)
Tezi will not show EULA License for Apalis TK1 and upstream builds
(cherry picked from commit 49d49b87cb98e061731e38985b425147e22dcfcb)
With the 4.4 kernel perf no longer builds. Don't add it to the
packagegroup for colibri-vf machine with use-nxp-bsp.
(cherry picked from commit bf5691c4651ece15e6b08e9fc347b657dd9af38b)
(cherry picked from commit 9c277f8bf4fa3c6a0b2c10c93b66b28f440d9723)
This adds packages related to the i.MX 8M Plus ISP (Image signal processor).
For all other machines this packegroup does currently doesn't add anything.
Related-to: ELB-3957
(cherry picked from commit b7ed660510e95eb50c707153a5c3713c0338135c)
Related-to: ELB-3478
(cherry picked from commit bda9e7f561b50cda6881d0300f9c0d4f93fd9549)
Tezi will show EULA License for Toradex reference targets.
Related-to: ELB-3485
(cherry picked from commit db7776dd7e6eae80811568b85bbf478e35f27045)
Provide a higher ranking video sink plugin than the not working
imxeglvivsink and thus fixes automatic (playbin) pipeline construction
and audio mpeg codec warning (AAC codec).
Additionaly include a NXP userspace cli tool to play or record with
gstreamer.
Related-to: ELB-3013
Related-to: ELB-3010
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 62a138575743b9780aff969c041432194680d4c3)
Without qtwayland deployed QT is not working on wayland.
Related-to: ELB-3153
(cherry picked from commit 02e7cbe9ec44be6ea36095914c19a02a0ca925b4)
For low-end modules without GPU only show the QT analogclock. For TK1
also choose a different QT-demo.
(cherry picked from commit c79cc904871adae96d1c0d0743c5a2605cb25e20)
libdrm-tests contains the useful binary modetest to check the different
kernel mode setting parameters. This doesn't make sense to deploy for
downstream images so only deploy this to mx8 and upstream images.
Related-to: ELB-3048
(cherry picked from commit b962519c754bd918e99ff08e583f63ffb10757b0)
We dropped our own package split rtl8188eu in favour of the
openembedded-core provided rtl8188 which contains the firmware for
both rtl8188 and rtl8188eu.
After moving the images to the kernel toradex_5.4-2.1.x-imx,
backport-5.4 got obsolete. Exclude backports from images.
Related-to: ELB-2891
Two more tools we use in testing of module features.
Related-to: ELB-2874
Related-to: ELB-2838
