Not all wifi modules support the AP mode in the 5GHz band. However, most
do support the 2.4GHz band. Therefore, we change the channel
configuration to channel 9 which is in the 2.4GHz band and should work
for most wifi modules.
Related-to: ELB-4815
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit b020ecb69f425e14ab1c2daccc074d1f89ae071e)
Use bluealsa recipe from meta-openembedded layer.
Related-to: ELB-4505
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Disable background scan in config to avoid a significant increase in
bandwidth.
Related-to: ELB-4148
Disable BackgroundScan in main.conf.
(cherry picked from commit 097df183d8e70cfcf4267425c195a6dcfcdbc9ed)
- Drop 0001-connman.service.in-don-t-start-if-nfs-boot.patch, since
commit "ef0d26e6: rootnfs: Working rootnfs using connman", connman
can handle nfs rootfs on NICs.
- Change "+=" to "_append", this could avoid some cases "+=" being
overridden by overrides variables.
(cherry picked from commit fd7a7b83175368f809b237979e3f20304a5571de)
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
NTP client should not update time and timezone by default unless
otherwise stated in the settings.
Related-to: ELB-2753
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
(cherry picked from commit 16961c4f190d23d640286b5df73107cbdf27b727)
GCC 10 by default compiles with -fno-common which results in linker erros.
| ld: bluez-a2dp.o:...git/src/bluez-a2dp.h:20: multiple definition of `bluez_a2dp_sbc'; .../git/src/bluez-a2dp.h:20: first defined here
| ld: bluez-iface.o:...git/src/bluez-iface.h:17: multiple definition of `bluez_iface_profile'; .../git/src/bluez-iface.h:17: first defined here
| ld: bluez-iface.o:...git/src/bluez-iface.h:16: multiple definition of `bluez_iface_endpoint'; .../git/src/bluez-iface.h:16: first defined here
Declare with 'extern' fixes the linkage.
This will add an example hostapd package that will contain all necessary
files to just "enable" an acces-point on a demo image.
Relates-to: ELB-1303
(cherry picked from commit 7873d287300c204c594bc46429bca066cbd68bea)
This dependency is not needed anymore and without further changes now
makes do_configure even fail. So we drop this.
Do configure samba with quota installed the following additional entry
to meta-networking/files/waf-cross-answers/cross-answers-arm.txt would
be needed:
checking for clnt_create(): OK
This reverts commit 1ea8042efa053e94c011d4b2e8835cf4e2e05ad6.
(cherry picked from commit 03aa13b6a709470ba7c9367293f979e6f0bb939b)
(cherry picked from commit 73b17417033314baf809522e87ccf794c0d16680)
The changes have been added upstream.
This reverts commit d568bc40cabdb27fb1948206b8d2f3f911f6e252.
wireless-regdb version 2018.05.31 was failing when
populating the SDK.
Use wireless-regdb version 2018.05.31.
Revert once 8382cdc0888ca645a44aacaac1155afb8dcde979 and
77c353cc9bdfbf1b6453b2579b72726db05eb69c are backported to rocko.
This reverts commit 4ade18dd772a72a4ca8d58df8ef82d67948a65c7.
bbappend does no longer apply as OE-core updated the version and with it also
pulled in the needed fix to allow using thumb2.
This allows to play audio over Bluetooth without pulseaudio sound
server, just using alsa. The recipe has been adopted from meta-agl.
Basic usage instructions can be found on Github:
https://github.com/Arkq/bluez-alsa
Due to an issue with OpenSSL and binutils 2.29 avoid using Thumb2
for now. See:
http://lists.openembedded.org/pipermail/openembedded-core/2017-November/144652.html
Version update in oe-core requires patch rebase.
This reverts commit f06f9b397b0db891d902eefa54761b37e7d00ec6.
The fix is now applied in meta-openembedded.
The connman sources provide main.conf with all settings set to default.
Patch that file rather than providing the file in full from a maybe
outdated connman version.
Previously my morty build failed as follows:
| arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mfpu=neon -mfloat-abi
=hard --sysroot=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/apalis-tk1-mai
nline -Wall -DVER=1.6 -D_GNU_SOURCE -DHAVE_CLOCK_ADJTIME -DHAVE_POSIX_SPAWN -I/
lib/modules/4.8.13/build/usr/include -DHAVE_ONESTEP_SYNC -D_GNU_SOURCE -DHAVE_C
LOCK_ADJTIME -DHAVE_ONESTEP_SYNC -O2 -pipe -g -feliminate-unused-debug-types -fd
ebug-prefix-map=/data/build/oe_core-V2.7/build/tmp-glibc/work/armv7at2hf-neon-an
gstrom-linux-gnueabi/linuxptp/1.6-r0=/usr/src/debug/linuxptp/1.6-r0 -fdebug-pref
ix-map=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/x86_64-linux= -fdebug-p
refix-map=/data/build/oe_core-V2.7/build/tmp-glibc/sysroots/apalis-tk1-mainline=
-c -o msg.o msg.c
| {standard input}: Assembler messages:
| {standard input}:39: Error: bad instruction `bswapq r0'
| <builtin>: recipe for target 'msg.o' failed
| make: *** [msg.o] Error 1
As it tried using the kernel headers from my Fedora 23 build server
located at /lib/modules/4.8.13/build/usr/include.
Fix this by no longer calling the incdefs.sh shell script from the
makefile.
Remove the locally backported 6.8 version since bitbake anyway
use the newer 7.1 version from OpenEmbedded core.
This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2.
midori_*bb has been removed.
We've seen newer distros which incorrectly negotiate used cypher with the on
target openssh. Using 6.8 fixes that.
Connman gained support for USB gadget. The typical usecase is to use
USB gadget for tethering. In this use case the module would be the
device sharing the connection to the USB host connected to the module.
However, our typical use case in mind for RNDIS is a simple ethernet
connection between a development host and the module, hence no need
for tethering/routing. This however is not easily doable with connman,
since connman tries to have one connection online only. When enabling
USB gadget as a normal ethernet device, this typically leads to classic
ethernet not being configured since the USB RNDIS connection is already
up and running.
By blacklisting USB gadget, connman won't touch the device and we can
use other means of bringing up the network interface.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
This gets rid of a long timeout when connecting in a network
which does not provide reverse DNS.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
with the move from meta-openembedded to oe-core some things have
changed, e.g. the config files have to explicitly installed
- is already installed
