path: root/qt5-layer
2022-12-07qt5: examples: cinematicexperience: Fix a crash with no screenStefan Eichenberger
When there is no screen attached the Qt application fails to start. The message when the application crashes is: xdg_wm_base@17: error 4: xdg_surface geometry (500 x 500) is larger than the configured fullscreen state (0 x 0) The Wayland connection experienced a fatal error: Protocol error This leads to a kernel messages each time the application tries to start. With BSP5 the application just tries to restart every time the applications exits but doesn't spam the kernel log. The reason why this changed is this new feature: https://code.qt.io/cgit/qt/qtwayland.git/commit/?h=5.15&id=d58008c4310f99d0faebcfb2fd9aa9296b813ecf The change of this commit fixes the application so that it properly works with no screen attached and doesn't crash at all. Related-to: ELB-4884 Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com> (cherry picked from commit 2ca50c7c93e69cd02028ec5a204b84632d996703) Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-03-06layer: Update LICENSE variable to use SPDX license identifiersMax Krummenacher
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for obsolete license usage"), LICENSE field not containing SPDX identifiers are treated with WARNING. An automated conversion using scripts/contrib/convert-spdx-licenses.py to convert to use the standard SPDX license identifiers has been done on the entire layer. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-08-14layer: convert to new override syntaxMax Krummenacher
This is the result of automated script (0.9.3) conversion: +# meta-toradex-distro +vars = vars + ["preempt-rt","tdx","upstream"] +# meta-toradex-* machines +vars = vars + ["apalis-","colibri-","verdin-","tegra124"] +# meta-freescale +vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"] ../openembedded-core/scripts/contrib/convert-overrides.py . converting the metadata to use ":" as the override character instead of "_". Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-07-22qt5: set qt backend according to installed graphical backendPhilippe Schenker
Related-to: ELB-2838 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2020-07-22falkon: move recipe so it does not interfere with meta-qt5Philippe Schenker
2020-06-17qt5-x11-free-systemd: drop deprecated NATIVE_SYSTEMD_SUPPORTMing Liu
Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit 72adf20fd19877f245c523b65da8a923b64f6492)
2020-01-09qt5: do not require meta-qt5Max Krummenacher
Move all qt5 relevant stuff where it only gets parsed if meta-qt5 is available. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03qt5 toolchain: include python json module in the native sdkMax Krummenacher
As several customers reported qtcreator imports that python module when debugging. https://www.toradex.com/community/questions/11201/qt-creator-debugging-python-issue-colibri-imx7d.html Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
