For the Toradex Easy Installer update to the last git hash before the
device tree resp. overlay re-work of late.
Lock use-head-next to the last git hash before the device tree resp.
NAND support may help (;-p).
Both colibri-imx7 use the same defconfig, however we do not have a
common mx7 override so provide it for each machine.
Add a apalis-tk1-mainline defconfig using the 4.19.59 tegra_defconfig
with enabled CONFIG_PREEMPT_RT_FULL.
Add a default defconfig, use the 4.19.59 arm64 defconfig with enabled
(cherry picked from commit 60f4dbc77be23abfe2995f9f2bd448694157d020)
Both colibri-imx7 use the same defconfig, only provide it once.
Add a apalis-tk1-mainline defconfig using the 5.4.6 tegra_defconfig.
Add a default defconfig, use the 5.4.6 arm64 defconfig.
(cherry picked from commit f9d7fe8962838dbb8a166f8ec991b397fde28a5f)
(cherry picked from commit 47bba89a6a09dc0e353cabb343b04f9322f7e3c2)
Using the only backported versions of mwifiex, cfg80211 and lib80211
allows to avoid several sporadical bugs about wrong dependencies
from built-in modules to backports modules and vice versa.
Related-to: ELB-2687
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
With common depmod config file, the backported rtl8188eu driver
tries to load for Realtek 8188EU USB devices. On the other hand,
on-module Wi-Fi chip loads built-in mwifiex_pcie driver. This driver
uses cfg80211 built-in module. Backported rtl8188eu driver can't use
built-in cfg80211 module, so, to allow using Realtek 8188EU USB device
with Colibri iMX8QXP module, the built-in rtl8188eu driver should be
used.
With this patch the specific depmod config file deploys on the image
for Apalis iMX8QM.
built-in cfg80211 module, so to allow using Realtek 8188EU USB device
used.
for Colibri iMX8QXP.
Backports recipe deploys the custom config file for depmod.
Use it in depmodwrapper to generate modules dependencies properly.
Deploying depmod.conf file makes almost all manipulations
in postinst and postrm scripts useless. Clean up these scripts.
Only backported drivers should depend on backported common modules.
Deploying the 99-backports.conf file allows depmod to build modules.dep
dependancies file properly.
Generic and RT-kernels use diffierent package names.
Add dependancy on virtual name kernel package fixes
build issue for RT-kernels.
Related-to: ELB-2388
backports-5.4 provides latter drivers.
The main issue that fixes with these backports: the earlier mwifiex
drivers for Marvel 8997 WiFi module stucks on firmware crash (ELB-2596).
While at it, add the use-head-next override which builds head instead
of the pinned version. This is useful for integration work.
Fix Linux version to really represent 5.4.6.
Update to latest which includes the following two commits:
e87dbbae2576:
ARM: dts: imx7: Fix Toradex Colibri iMX7S 256MB NAND flash support
575bd2d69a82:
arm64: dts: freescale: add initial support for colibri imx8x
Bump to latest LTS release Linux 5.4.6 plus Apalis T30/TK1 patches.
Bump to latest LTS release Linux 5.4.5.
(cherry picked from commit 2d635349eff45166feb4340c3008fd2a12f354cf)
Bump to latest LTS release Linux 5.4.2.
(cherry picked from commit 6e96e4c828b853edefbc9107680efa38c143c7f6)
Set the package version to reflect the complete Linux kernel version
plus the git hash it has been built from.
This could be done in the inc file only once, however, the Yocto
kernel recipes set PV in the individual recipies as well. The close
proximity to LINUX_VERSION also makes it obvious what PV will be.
Add initial version of a recipe to build the mainline based PREEMPT_RT
kernel for Toradex modules. This kernel has been maintained for
TorizonCore and is now moving to the official BSP. At this point the
kernel is working well for the platforms supported by TorizonCore,
but the hardware support hasn't been completed or verified.
The defconfig files are the same configurations as generated by the
TorizonCore kernel-cache (kernel configuration metadata) commit
fd3d3be08c05 ("features/usb-net: enable some LTE/GSM modems").
Add initial version of a recipe to build the mainline based kernel for
Toradex modules. This kernel has been maintained for TorizonCore and
is now moving to the official BSP. At this point the kernel is working
well for the platforms supported by TorizonCore, but the hardware
(cherry picked from commit 8109e0a87240489e6bc698e79f2cc748cbe40b17)
(cherry picked from commit d02ed084d1c4a13e77898affc1b48beabef956f4)
Backports based on 4.19 kernel.
(cherry picked from commit 78e1cdabe0baeb794945bd4926c28058f9f12aa9)
(cherry picked from commit 56829b6d643fa5dfdac42c0adddf5d41e7fb982e)
When building with usrmerge, the firmware directory is in /usr/lib.
Make sure we pickup firmwares from nonarch_base_libdir.
This fixes a build warning when building Torizon:
* Problem 1/1:
* - nothing provides linux-firmware-rtl8188eu needed by linux-firmware-1:0.0+git0+d114732723-r0.all
Add missing space in front of DEPENDS_append in order to avoid issues
caused by further appending.
Since kernel module packages are generated dynamically, the dependency
resolution fails when one requests a specific package which is
generated at build time. Use PACKAGES_DYNAMIC to tell the build system
that backport-kernel-module-* packages can be considered available.
This reverts commit e6641b0a6f93ebf752534b283d0dfb0c2c656ec2.
add coreutils native to depends
in do_configure:
| /bin/bash: line 28: seq: command not found
resulting in do_compile failing:
| In file included from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/ieee80211_i.h:35:0,
| from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/status.c:17:
| /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/sta_info.h:460:21: error: field 'hash_node' has incom
| struct rhlist_head hash_node;
Don't use HEAD of branch for every build.
That way we get more reproduciable builds and the git fetcher will not access
the network on every build to check what the current HEAD actually is.
Use KERNEL_VERSION variable instad of running
make kernelversion
Introducing Backports.
