Related-to: ELB-5482
Update imx-firmware to commit 2afa15e77f0b58eade42b4f59c9215339efcca66
on branch lf-6.6.3_1.0.0. This updates the IW416 Bluetooth and Wi-Fi
Firmware to 16.92.21.p119.2.
Bump SRCREV hashes as used in build of Mon 29 Apr 2024 11:51:04 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 590
Matrix Build Status: SUCCESS
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/590
Signed-off-by: ci.toradex <cicd@toradex.com>
Enable user-space I/O driver support for HID subsystem (CONFIG_UHID=m)
as e.g. required for Bluetooth keyboards.
Related-to: ELB-5738
The sethostname script has issues when the root filesystem is mounted
as read-only, making not possible to create or modify the /etc/hostname
file.
Therefore, this change updates the sethostname script and adds the
@@HOSTNAMECTL_OPT@@ that can further be replaced with the "--transient"
flag for hostnamectl if the system uses a read-only root FS. This flag
will change the hostname without creating the /etc/hostname file.
With this change, update recipe version from 1.0 to 1.1.
Related-to: ELB-5713
Signed-off-by: Hiago De Franco <hiago.franco@toradex.com>
Previously, the network configuration file only supported mwifiex_pcie
driver, but WiFi/BT interface of the Verdin modules uses the SDIO
interface, which caused 10-toradex-wifi-ifnames.link was not being applied
to this hardware family. Therefore, fix this issue by extending support to
the SDIO driver.
Related-to: ELB-5696
Add alsa-ucm-conf-tdx (ALSA Use Case Manager with Toradex hardware
configurations) recipe and dahlia/dev configuration files for Alsa UCM.
The ALSA UCM is used to set different audio input/output configurations
based on the audio card name used by the board. With UCM, a
configuration file for codec WM8904 (Dahlia board) or codec NAU8822
(Development board) will be automatically selected during boot.
This recipe is dependent on the OE upstream recipe alsa-ucm-conf.
Related-to: ELB-4916
The setting of localversion has been changed in openembedded-core
to accomodate changes in the kernel sources around v6.3.
This changed that the kernel and external kernel modules with our
way of setting localversion didn't use the same module magic.
One used what we want for LOCALVERSION twice while the other uses
it only once.
Compare with OE-Commits:
commit b378eec156 ("kernel: make LOCALVERSION consistent between recipes")
commit 765b13b730 ("kernel: fix localversion in v6.3+")
Related-to: ELB-5330
(cherry picked from commit 0ffa2b2b3aec8b4456acebec33a09b9dd88f7f49)
Backport to kirkstone after the above OE-Commits were backported to
kirkstone.
Change the class to keep using CONFIG_LOCALVERSION in the kernel
configuration as the Torizon TCB tool relies on the information
from this config variable.
If a kernel based on version 6.3+ would be built the git version
will no longer be included in the reported kernel version.
Related-to: ELB-5704
Patches were applied 6.1 stable kernel, remove it from the patches list
since it's not required anymore and to fix a build failure.
Recipe version is also updated to v6.1.84 that includes this patch.
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Bump SRCREV hashes as used in build of Thu 28 Mar 2024 11:19:09 PM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 285
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/285
CPU ops
On colibri-imx7 (nand) linux kernel fails to initialize the CAAM Job Rings,
with this error:
`caam_jr 30901000.jr: failed to flush job ring`
On colibri-imx7-emmc linux kernel fails to initialize CPUidle with this error:
`CPUidle arm: CPU 0 failed to init idle CPU ops`
CAAM Job Rings linux driver needs that U-Boot allow access to JR registers
when running in HYP mode (aka U-Boot non secure-mode)
CPUIdle needs PSCI it is active only when HYP mode.
Moreover, mainline kernel should be run in HYP mode.
So, enable non secure mode on colibri-imx7-emmc and give access
at CAAM Job Rings to Non Trusted Zone when running in HYP mode.
Related-to: ELB-4940 ELB-5611
Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
Add patches to fix MMC extcsd ioctl regression.
Related-to: ELB-5679
Add Verdin I2C_3_HDMI symlink rule to match upstream kernel naming.
Related-to: ELB-5638
Signed-off-by: Vitor Soares <vitor.soares@toradex.com>
The removed patch is relevant to the downstream colibri-imx7 kernel
which is no longer supported.
Related-to: ELB-5611
Add support for rootfs image files in the raw format. This might be
useful when the rootfs image has formats like squashfs or verity.
Signed-off-by: Sergio Prado <sergio.prado@e-labworks.com>
Bump SRCREV hashes as used in build of Sat 02 Mar 2024 12:49:27 AM UTC
Matrix Build: image-tezi-kirkstone-6.x.y-nightly-matrix 264
Triggered by: https://jenkins.int.toradex.com/job/image-tezi-kirkstone-6.x.y-nightly-matrix/264
Introduce systemd link files to incorporate alternative names for CAN
interfaces, adding compatibility with names provided in datasheets and
device tree comments.
With this modification, the alternative name for can0 will be 'verdin-can1',
and for can1, 'verdin-can2' on i.MX processors. For the AM62, can1 will
become 'verdin-can1', and can0 will become 'verdin-can2'. The alternative
names will be displayed as follows:
4: can0: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
altname verdin-can1
5: can1: <NOARP,ECHO> mtu 16 qdisc noop state DOWN group default qlen 10
link/can
altname verdin-can2
Related-to: ELB-5600
Patch was applied to 6.1 stable kernel, remove it from the patches list
Recipe version is also updated to v6.1.79 that includes this patch.
Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
Add support for ExFAT filesystem.
Related-to: ELB-5583
Signed-off-by: Parth Pancholi <parth.pancholi@toradex.com>
Bump SRCREV hashes as used in build of Tue 30 Jan 2024 09:52:32 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 510
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/510
Recipe version is also updated to v6.1.75 that includes this patch.
Backport patches to add device tree support for the new Apalis Evaluation
Board v1.2.
Related-to: ELB-5532
Add patch to add the new nonwince pid4 of colibri imx6/imx7 and apalis
imx6 on bsp6 u-boot.
Related-to: ELB-5558
This fixes NXP having renamed and updated the license (again).
Fixes: a7100f0ca20b ("linux-firmware: update imx-firmware to lf-6.1.55-2.2.0")
Update imx-firmware to commit 7be5a936ce8677962dd7b41c6c9f41dd14350bec
on branch lf-6.1.55_2.2.0. This updates the IW416 Bluetooth and Wi-Fi
Firmware to 16.92.21.p84.128.
openembedded-core bumped to the 20231030 release which includes the
updated firmware files we need. Drop the recipe.
Apalis Evaluation Board v1.2 added some new on-board chips (compared to
v1.1) that are not yet enabled in the mainline Linux kernel defconfig
file:
- Audio codec NAU88C22YG
- Current/Voltage measurement INA219
- Temperature Sensor TMP75CIDGKR
So add the necessary drivers as modules to support these new devices.
This makes it easier to reference a custom produced image in a deploy or
customization (e.g. with torizoncore-builder) workflow.
Variable names and the link command are modeled after
/meta-toradex-torizon/recipes-bsp/u-boot/u-boot-ota.inc
Signed-off-by: Rafael Beims <rafael.beims@toradex.com>
Signed-off-by: Matthijs Kooijman <matthijs@stdin.nl>
Bump SRCREV hashes as used in build of Fri 05 Jan 2024 09:02:58 PM UTC
Matrix Build: image-tdxref-kirkstone-6.x.y-nightly-matrix 488
Triggered by: https://jenkins.int.toradex.com/job/image-tdxref-kirkstone-6.x.y-nightly-matrix/488
This patch addresses an issue related to NCM and the transmission of small
packets, as when using VNC, for example.
The ongoing discussion about this problem can be checked on the Linux
kernel mailing list at [1]. Until the matter is resolved in the mainline,
we should keep this patch here as it has demonstrated it solves the issue
for now. Future updates can be made once the mainline fix is implemented.
[1] https://lore.kernel.org/all/20231204183751.64202-1-hiagofranco@gmail.com/
Related-to: TEI-1078
When restart hostapd the AP is no longer functional. This patch
addresses the issue by configuring AP BSSID before starting the AP.
Related-to: ELB-5484
The "filelist" property allows extra files to be copied into the target
filesystem at image installation time. With this implementation we let
users fill in that property at build-time; this is done by settting the
value of the OE variable TEZI_ROOT_FILELIST. The files referenced by
that variable will also become part of the Toradex Easy Installer
image.
Relate-to: TOR-2915
Signed-off-by: Rogerio Guerra Borin <rogerio.borin@toradex.com>
On Colibri iMX7D 1GB v1.1B, a "new" SoC fusing is being used. This
caused an issue where the GPIO(6,11), used to detect if a board uses
NAND or eMMC, only worked while the module was in recovery mode. Once it
booted from the eMMC, the GPIO was set to output, therefore always
returning 0.
The default behavior should be GPIO return 1 for eMMC device and 0 for a
NAND device, which allows U-Boot to behave correctly.
This also addresses an issue where Tezi 6 was failing to boot because of
wrong variant detection.
Related-to: ELB-5496
Bump SRCREV hashes as used in build of Tue 05 Dec 2023 06:28:53 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 450
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/450
Backport mallow carrier board device tree files for verdin imx8mm/mp
already sent to mainline linux enabling mallow support on toradex
mainline version.
Related-to: ELB-5215 and ELB-5216
Recipe version is also updated to v6.1.64 that includes this patch.
We dropped having common device tree overlays, i.e. all dtbo are now
machine specific and start with the machine name.
Drop searching and deploying dtbos which do not start with a machine
name.
This fixes deploying verdin-am62*dtbo for non verdin-am62 machines.
Related-to: ELB-5479
The following error was spotted during the boot of Colibri iMX7S on Tezi
6:
U-Boot 2022.07-6.4.0-devel+git.e092e3250270 (Jul 11 2022 - 13:42:58 +0000)
CPU: Freescale i.MX7S rev1.2 800 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 29C
Reset cause: POR
DRAM: initcall sequence 8786b820 failed at call 87818e09 (err=-3)
\### ERROR ### Please RESET the board ###
This patch solves this issue by calling fdt_increase_size() on
colibri_imx7.c file.
Related-to: TEI-1138
add /dev/verdin-uart2 symlink on Verdin AM62
Related-to: ELB-5122
With the kernel moving 32 bit device trees in subdirectories starting
with kernel 6.5 the toradex machine configuration files provide the
variable KERNEL_DTB_PREFIX.
The fit image configuration name is constructed from KERNEL_DTB_PREFIX
plus the dtb file name. Make use of the KERNEL_DTB_PREFIX variable to
construct the configuration used for booting.
As we now also set KERNEL_DTB_PREFIX for the 64 bit machines the inline
python works for all machines, thus drop the DTB_PREFIX overrides.
Related-to: ELB-5262
Micron MTFC4GACAJCN eMMC supports cache but requires that flush cache
operation be allowed only after a write has occurred. Otherwise, the
cache flush command or subsequent commands will time out.
This patch has been merged in mainline with commit ed9009ad300c.
Related-to: ELB-5386
Signed-off-by: Bean Huo <beanhuo@micron.com>
This commit introduces patches to the defconfig of Apalis/Colibri iMX6,
Colibri iMX7 and Colibri iMX6ULL to enable fastboot support and adds a
logic to the bootcmd to select SDP or Fastboot based on the configs
enabled.
Related-to: TEI-1136
Bump SRCREV hashes as used in build of Thu 26 Oct 2023 05:20:06 AM UTC
Matrix Build: image-torizoncore-kirkstone-6.x.y-nightly-matrix 420
Triggered by: https://jenkins.int.toradex.com/job/image-torizoncore-kirkstone-6.x.y-nightly-matrix/420
With oe-core bumping linux-firmware we now get the following error:
| ERROR: ParseError at ...meta-toradex-bsp-common/recipes-kernel/linux-firmware/linux-firmware_20230928.bb:1: Could not include required file recipes-kernel/linux-firmware/linux-firmware_20230625.bb
board
Newer variants of Ixora boards require a power-up delay when powering up
the CAN transceiver of up to 1ms.
This patch adds mentioned delay for iMX6 Apalis SoM variants.
The series has been submitted upstream [1].
[1] https://lore.kernel.org/all/20231020153022.57858-3-andrejs.cainikovs@gmail.com/
Related-to: ELB-5224
Signed-off-by: Andrejs Cainikovs <andrejs.cainikovs@toradex.com>
Add a patch to fix device tree build errors from other boards that are
not related to Colibri.
The last commit [0cdb7f9e] removed the need of the 'nand_padding' function
within our recipes, so remove it.
This commit backports two patches submitted to the U-Boot mainline, both of
which relocate the 'nand_padding' function to the Makefile of 'mach-imx.'
The first patch introduces the 'u-boot-nand.imx' target to the Makefile,
producing a binary file with 1024 leading zeros. The second patch adds a 'dd'
command to the Makefile, appending 10k zeros to the end of the binary.
These changes will eliminate the need of the 'nand_padding' function.
Change to the most "open" MIT license. While at it also update the
summary, description, drop the bogus inherit systemd and update the
SRC_URI to be fully in-line with btnxpuartconf.
