As Xiao pointed out, there are a few problems with it:
- kvm_arch_commit_memory_region() write protects the memory slot only
for GET_DIRTY_LOG when modifying the flags.
- FNAME(sync_page) uses the old spte value to set a new one without
checking KVM_MEM_READONLY flag.
Since we flush all shadow pages when creating a new slot, the simplest
fix is to disallow such problematic flag changes: this is safe because
no one is doing such things.
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
KVM_SET_USER_MEMORY_REGION forces __kvm_set_memory_region() to identify
what kind of change is being requested by checking the arguments. The
current code does this checking at various points in code and each
condition being used there is not easy to understand at first glance.
This patch consolidates these checks and introduces an enum to name the
possible changes to clean up the code.
Although this does not introduce any functional changes, there is one
change which optimizes the code a bit: if we have nothing to change, the
new code returns 0 immediately.
Note that the return value for this case cannot be changed since QEMU
relies on it: we noticed this when we changed it to -EINVAL and got a
section mismatch error at the final stage of live migration.
yield_to returns -ESRCH, When source and target of yield_to
run queue length is one. When we see three successive failures of
yield_to we assume we are in potential undercommit case and abort
from PLE handler.
The assumption is backed by low probability of wrong decision
for even worst case scenarios such as average runqueue length
between 1 and 2.
More detail on rationale behind using three tries:
if p is the probability of finding rq length one on a particular cpu,
and if we do n tries, then probability of exiting ple handler is:
p^(n+1) [ because we would have come across one source with rq length
1 and n target cpu rqs with length 1 ]
so
num tries: probability of aborting ple handler (1.5x overcommit)
1 1/4
2 1/8
3 1/16
We can increase this probability with more tries, but the problem is
the overhead.
Also, If we have tried three times that means we would have iterated
over 3 good eligible vcpus along with many non-eligible candidates. In
worst case if we iterate all the vcpus, we reduce 1x performance and
overcommit performance get hit.
note that we do not update last boosted vcpu in failure cases.
Thank Avi for raising question on aborting after first fail from yield_to.
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Tested-by: Chegu Vinod <chegu_vinod@hp.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Virtual interrupt delivery avoids KVM to inject vAPIC interrupts
manually, which is fully taken care of by the hardware. This needs
some special awareness into existing interrupr injection path:
- for pending interrupt, instead of direct injection, we may need
update architecture specific indicators before resuming to guest.
- A pending interrupt, which is masked by ISR, should be also
considered in above update action, since hardware will decide
when to inject it at right time. Current has_interrupt and
get_interrupt only returns a valid vector from injection p.o.v.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
We've been ignoring read-only mappings and programming everything
into the iommu as read-write. Fix this to only include the write
access flag when read-only is not set.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Memory slot flags can be altered without changing other parameters of
the slot. The read-only attribute is the only one the IOMMU cares
about, so generate an un-map, re-map when this occurs. This also
avoid unnecessarily re-mapping the slot when no IOMMU visible changes
are made.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
One such variable, slot, is enough for holding a pointer temporarily.
We also remove another local variable named slot, which is limited in
a block, since it is confusing to have the same name in this function.
Don't need the check for deleting an existing slot or just modifiying
the flags.
This makes the separation between the sanity checks and the rest of the
code a bit clearer.
Calling kvm_mmu_slot_remove_write_access() for a deleted slot does
nothing but search for non-existent mmu pages which have mappings to
that deleted memory; this is safe but a waste of time.
Since we want to make the function rmap based in a later patch, in a
manner which makes it unsafe to be called for a deleted slot, we makes
the caller see if the slot is non-zero and being dirty logged.
Move repetitive code sequence to a separate function.
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
Previous patch "kvm: Minor memory slot optimization" (b7f69c555ca43)
overlooked the generation field of the memory slots. Re-using the
original memory slots left us with with two slightly different memory
slots with the same generation. To fix this, make update_memslots()
take a new parameter to specify the last generation. This also makes
generation management more explicit to avoid such problems in the future.
Reported-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
This hack is wrong. The pin number of PIT is connected to
2 not 0. This means this hack never takes effect. So it is ok
to remove it.
We're currently offering a whopping 32 memory slots to user space, an
int is a bit excessive for storing this. We would like to increase
our memslots, but SHRT_MAX should be more than enough.
There's no need for this to be an int, it holds a boolean.
Move to the end of the struct for alignment.
It's easy to confuse KVM_MEMORY_SLOTS and KVM_MEM_SLOTS_NUM. One is
the user accessible slots and the other is user + private. Make this
more obvious.
If a slot is removed or moved in the guest physical address space, we
first allocate and install a new slot array with the invalidated
entry. The old array is then freed. We then proceed to allocate yet
another slot array to install the permanent replacement. Re-use the
original array when this occurs and avoid the extra kfree/kmalloc.
The iommu integration into memory slots expects memory slots to be
added or removed and doesn't handle the move case. We can unmap
slots from the iommu after we mark them invalid and map them before
installing the final memslot array. Also re-order the kmemdup vs
map so we don't leave iommu mappings if we get ENOMEM.
The API documents that only flags and guest physical memory space can
be modified on an existing slot, but we don't enforce that the
userspace address cannot be modified. Instead we just ignore it.
This means that a user may think they've successfully moved both the
guest and user addresses, when in fact only the guest address changed.
Check and error instead.
The API documentation states:
When changing an existing slot, it may be moved in the guest
physical memory space, or its flags may be modified.
An "existing slot" requires a non-zero npages (memory_size). The only
transition we should therefore allow for a non-existing slot should be
to create the slot, which includes setting a non-zero memory_size. We
currently allow calls to modify non-existing slots, which is pointless,
confusing, and possibly wrong.
With this we know that the invalidation path of __kvm_set_memory_region
is always for a delete or move and never for adding a zero size slot.
Typo for the next pointer means we're walking random data here.
* 'for-upstream' of https://github.com/agraf/linux-2.6: (28 commits)
KVM: PPC: booke: Get/set guest EPCR register using ONE_REG interface
KVM: PPC: bookehv: Add EPCR support in mtspr/mfspr emulation
KVM: PPC: bookehv: Add guest computation mode for irq delivery
KVM: PPC: Make EPCR a valid field for booke64 and bookehv
KVM: PPC: booke: Extend MAS2 EPN mask for 64-bit
KVM: PPC: e500: Mask MAS2 EPN high 32-bits in 32/64 tlbwe emulation
KVM: PPC: Mask ea's high 32-bits in 32/64 instr emulation
KVM: PPC: e500: Add emulation helper for getting instruction ea
KVM: PPC: bookehv64: Add support for interrupt handling
KVM: PPC: bookehv: Remove GET_VCPU macro from exception handler
KVM: PPC: booke: Fix get_tb() compile error on 64-bit
KVM: PPC: e500: Silence bogus GCC warning in tlb code
KVM: PPC: Book3S HV: Handle guest-caused machine checks on POWER7 without panicking
KVM: PPC: Book3S HV: Improve handling of local vs. global TLB invalidations
MAINTAINERS: Add git tree link for PPC KVM
KVM: PPC: Book3S PR: MSR_DE doesn't exist on Book 3S
KVM: PPC: Book3S PR: Fix VSX handling
KVM: PPC: Book3S PR: Emulate PURR, SPURR and DSCR registers
KVM: PPC: Book3S HV: Don't give the guest RW access to RO pages
KVM: PPC: Book3S HV: Report correct HPT entry index when reading HPT
The current eventfd code assumes that when we have eventfd, we also have
irqfd for in-kernel interrupt delivery. This is not necessarily true. On
PPC we don't have an in-kernel irqchip yet, but we can still support easily
support eventfd.
We can deliver certain interrupts, notably MSI,
from atomic context. Use kvm_set_irq_inatomic,
to implement an irq handler for msi.
This reduces the pressure on scheduler in case
where host and guest irq share a host cpu.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Add an API to inject IRQ from atomic context.
Return EWOULDBLOCK if impossible (e.g. for multicast).
Only MSI is supported ATM.
Prior to memory slot sorting this loop compared all of the user memory
slots for overlap with new entries. With memory slot sorting, we're
just checking some number of entries in the array that may or may not
be user slots. Instead, walk all the slots with kvm_for_each_memslot,
which has the added benefit of terminating early when we hit the first
empty slot, and skip comparison to private slots.
Cc: stable@vger.kernel.org
TSC initialization will soon make use of online_vcpus.
KVM added a global variable to guarantee monotonicity in the guest.
One of the reasons for that is that the time between
1. ktime_get_ts(×pec);
2. rdtscll(tsc);
Is variable. That is, given a host with stable TSC, suppose that
two VCPUs read the same time via ktime_get_ts() above.
The time required to execute 2. is not the same on those two instances
executing in different VCPUS (cache misses, interrupts...).
If the TSC value that is used by the host to interpolate when
calculating the monotonic time is the same value used to calculate
the tsc_timestamp value stored in the pvclock data structure, and
a single <system_timestamp, tsc_timestamp> tuple is visible to all
vcpus simultaneously, this problem disappears. See comment on top
of pvclock_update_vm_gtod_copy for details.
Monotonicity is then guaranteed by synchronicity of the host TSCs
and guest TSCs.
Set TSC stable pvclock flag in that case, allowing the guest to read
clock from userspace.
No need to check return value before breaking switch.
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
We should avoid kfree()ing error pointer in kvm_vcpu_ioctl() and
kvm_arch_vcpu_ioctl().
This patch filters noslot pfn out from error pfns based on Marcelo comment:
noslot pfn is not a error pfn
After this patch,
- is_noslot_pfn indicates that the gfn is not in slot
- is_error_pfn indicates that the gfn is in slot but the error is occurred
when translate the gfn to pfn
- is_error_noslot_pfn indicates that the pfn either it is error pfns or it
is noslot pfn
And is_invalid_pfn can be removed, it makes the code more clean
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Merge reason: development work has dependency on kvm patches merged
upstream.
arch/powerpc/include/asm/Kbuild
arch/powerpc/include/asm/kvm_para.h
Pull kvm fixes from Avi Kivity:
"KVM updates for 3.7-rc2"
* tag 'kvm-3.7-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM guest: exit idleness when handling KVM_PV_REASON_PAGE_NOT_PRESENT
KVM: apic: fix LDR calculation in x2apic mode
KVM: MMU: fix release noslot pfn
We can not directly call kvm_release_pfn_clean to release the pfn
since we can meet noslot pfn which is used to cache mmio info into
spte
Signed-off-by: Avi Kivity <avi@redhat.com>
iommu_attach_device() fails
Change existing kernel error message to include return value from
iommu_attach_device() when it fails. This will help debug device
assignment failures more effectively.
Signed-off-by: Shuah Khan <shuah.khan@hp.com>
set_bit_le()
Now that we have defined generic set_bit_le() we do not need to use
test_and_set_bit_le() for atomically setting a bit.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Pull KVM updates from Avi Kivity:
"Highlights of the changes for this release include support for vfio
level triggered interrupts, improved big real mode support on older
Intels, a streamlines guest page table walker, guest APIC speedups,
PIO optimizations, better overcommit handling, and read-only memory."
* tag 'kvm-3.7-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (138 commits)
KVM: s390: Fix vcpu_load handling in interrupt code
KVM: x86: Fix guest debug across vcpu INIT reset
KVM: Add resampling irqfds for level triggered interrupts
KVM: optimize apic interrupt delivery
KVM: MMU: Eliminate pointless temporary 'ac'
KVM: MMU: Avoid access/dirty update loop if all is well
KVM: MMU: Eliminate eperm temporary
KVM: MMU: Optimize is_last_gpte()
KVM: MMU: Simplify walk_addr_generic() loop
KVM: MMU: Optimize pte permission checks
KVM: MMU: Update accessed and dirty bits after guest pagetable walk
KVM: MMU: Move gpte_access() out of paging_tmpl.h
KVM: MMU: Optimize gpte_access() slightly
KVM: MMU: Push clean gpte write protection out of gpte_access()
KVM: clarify kvmclock documentation
KVM: make processes waiting on vcpu mutex killable
KVM: SVM: Make use of asm.h
KVM: VMX: Make use of asm.h
KVM: VMX: Make lto-friendly
KVM: x86: lapic: Clean up find_highest_vector() and count_vectors()
arch/s390/include/asm/processor.h
arch/x86/kvm/i8259.c
Pull workqueue changes from Tejun Heo:
"This is workqueue updates for v3.7-rc1. A lot of activities this
round including considerable API and behavior cleanups.
* delayed_work combines a timer and a work item. The handling of the
timer part has always been a bit clunky leading to confusing
cancelation API with weird corner-case behaviors. delayed_work is
updated to use new IRQ safe timer and cancelation now works as
expected.
* Another deficiency of delayed_work was lack of the counterpart of
mod_timer() which led to cancel+queue combinations or open-coded
timer+work usages. mod_delayed_work[_on]() are added.
These two delayed_work changes make delayed_work provide interface
and behave like timer which is executed with process context.
* A work item could be executed concurrently on multiple CPUs, which
is rather unintuitive and made flush_work() behavior confusing and
half-broken under certain circumstances. This problem doesn't
exist for non-reentrant workqueues. While non-reentrancy check
isn't free, the overhead is incurred only when a work item bounces
across different CPUs and even in simulated pathological scenario
the overhead isn't too high.
All workqueues are made non-reentrant. This removes the
distinction between flush_[delayed_]work() and
flush_[delayed_]_work_sync(). The former is now as strong as the
latter and the specified work item is guaranteed to have finished
execution of any previous queueing on return.
* In addition to the various bug fixes, Lai redid and simplified CPU
hotplug handling significantly.
* Joonsoo introduced system_highpri_wq and used it during CPU
hotplug.
There are two merge commits - one to pull in IRQ safe timer from
tip/timers/core and the other to pull in CPU hotplug fixes from
wq/for-3.6-fixes as Lai's hotplug restructuring depended on them."
Fixed a number of trivial conflicts, but the more interesting conflicts
were silent ones where the deprecated interfaces had been used by new
code in the merge window, and thus didn't cause any real data conflicts.
Tejun pointed out a few of them, I fixed a couple more.
* 'for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (46 commits)
workqueue: remove spurious WARN_ON_ONCE(in_irq()) from try_to_grab_pending()
workqueue: use cwq_set_max_active() helper for workqueue_set_max_active()
workqueue: introduce cwq_set_max_active() helper for thaw_workqueues()
workqueue: remove @delayed from cwq_dec_nr_in_flight()
workqueue: fix possible stall on try_to_grab_pending() of a delayed work item
workqueue: use hotcpu_notifier() for workqueue_cpu_down_callback()
workqueue: use __cpuinit instead of __devinit for cpu callbacks
workqueue: rename manager_mutex to assoc_mutex
workqueue: WORKER_REBIND is no longer necessary for idle rebinding
workqueue: WORKER_REBIND is no longer necessary for busy rebinding
workqueue: reimplement idle worker rebinding
workqueue: deprecate __cancel_delayed_work()
workqueue: reimplement cancel_delayed_work() using try_to_grab_pending()
workqueue: use mod_delayed_work() instead of __cancel + queue
workqueue: use irqsafe timer for delayed_work
workqueue: clean up delayed_work initializers and add missing one
workqueue: make deferrable delayed_work initializer names consistent
workqueue: cosmetic whitespace updates for macro definitions
workqueue: deprecate system_nrt[_freezable]_wq
workqueue: deprecate flush[_delayed]_work_sync()
To emulate level triggered interrupts, add a resample option to
KVM_IRQFD. When specified, a new resamplefd is provided that notifies
the user when the irqchip has been resampled by the VM. This may, for
instance, indicate an EOI. Also in this mode, posting of an interrupt
through an irqfd only asserts the interrupt. On resampling, the
interrupt is automatically de-asserted prior to user notification.
This enables level triggered interrupts to be posted and re-enabled
from vfio with no userspace intervention.
All resampling irqfds can make use of a single irq source ID, so we
reserve a new one for this interface.
Most interrupt are delivered to only one vcpu. Use pre-build tables to
find interrupt destination instead of looping through all vcpus. In case
of logical mode loop only through vcpus in a logical cluster irq is sent
to.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
vcpu mutex can be held for unlimited time so
taking it with mutex_lock on an ioctl is wrong:
one process could be passed a vcpu fd and
call this ioctl on the vcpu used by another process,
it will then be unkillable until the owner exits.
Call mutex_lock_killable instead and return status.
Note: mutex_lock_interruptible would be even nicer,
but I am not sure all users are prepared to handle EINTR
from these ioctls. They might misinterpret it as an error.
Cleanup paths expect a vcpu that can't be used by
any userspace so this will always succeed - catch bugs
by calling BUG_ON.
Catch callers that don't check return state by adding
__must_check.
Other arches do not need this.
v2: fix incorrect deletion of mmio sptes on gpa move (noticed by Takuya)
PPC must flush all translations before the new memory slot
is visible.
Introducing kvm_arch_flush_shadow_memslot, to invalidate the
translations of a single memory slot.
The build error was caused by that builtin functions are calling
the functions implemented in modules. This error was introduced by
commit 4d8b81abc4 ("KVM: introduce readonly memslot").
The patch fixes the build error by moving function __gfn_to_hva_memslot()
from kvm_main.c to kvm_host.h and making that "inline" so that the
builtin function (kvmppc_h_enter) can use that.
Acked-by: Paul Mackerras <paulus@samba.org>
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
KVM_SET_SIGNAL_MASK passed a NULL argument leaves the on stack signal
sets uninitialized. It then passes them through to
kvm_vcpu_ioctl_set_sigmask.
We should be passing a NULL in this case not translated garbage.
Signed-off-by: Alan Cox <alan@linux.intel.com>
In current code, if we map a readonly memory space from host to guest
and the page is not currently mapped in the host, we will get a fault
pfn and async is not allowed, then the vm will crash
We introduce readonly memory region to map ROM/ROMD to the guest, read access
is happy for readonly memslot, write access on readonly memslot will cause
KVM_EXIT_MMIO exit
Then, remove bad_hva and inline kvm_is_error_hva
In current code, we always map writable pfn for the read fault, in order
to support readonly memslot, we map writable pfn only if 'writable'
is not NULL
We do too many things in hva_to_pfn, this patch reorganize the code,
let it be better readable
