path: root/tools
2011-09-29perf tools: Fix raw sample readingJiri Olsa
Wrong pointer is being passed for raw data sanity checking, when parsing sample event. This ends up with invalid event and perf record being stuck in __perf_session__process_events function during processing build IDs (process_buildids function). Following command hangs up in my setup: ./perf record -e raw_syscalls:sys_enter ls The fix is to use proper pointer to the raw data instead of the 'u' union. Reviewed-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1317308709-9474-2-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf python: Add missing perf_event__parse_sample 'swapped' parmArnaldo Carvalho de Melo
Problem introduced in 936be50, that missed one perf_event__parse_sample user, the python binding. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ja4phms9618ggi657plyuch2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf tools: Add support for disabling -Werror via WERROR=0Darren Hart
GCC often introduces new warnings with lots of false positives - breaking -Werror builds. WERROR=0 allows one to build perf without much fuss - while still encouraging people to send patches to avoid the fuss of having to type WERROR=0. Bisecting back to commits that produce a (mostly harmless) warning on some compilers is more difficult. With WERROR=0 one could bisect without worrying about harmless warnings. Cc: Ingo Molnar <mingo@elte.hu> Link: http://lkml.kernel.org/r/eac06c7cc4920e5d4830417d466161fb26c7359c.1315514559.git.dvhart@linux.intel.com Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf top: Fix userspace sample addr map offsetArnaldo Carvalho de Melo
The 'perf top' tool came from the kernel where we had each DSO (vmlinux, modules) loaded just once at a time. But userspace may have DSOs loaded in multiple addresses (shared libraries), requiring that we use the just resolved map instead of the first one found. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-ag53wz0yllpgers0n2w7hchp@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Fix issue with binaries using 16-bytes buildids (v2)Stephane Eranian
Buildid can vary in size. According to the man page of ld, buildid can be 160 bits (sha1) or 128 bits (md5, uuid). Perf assumes buildid size of 20 bytes (160 bits) regardless. When dealing with md5 buildids, it would thus read more than needed and that would cause mismatches and samples without symbols. This patch fixes this by taking into account the actual buildid size as encoded int he section header. The leftover bytes are also cleared. This second version fixes a minor issue with the memset() base position. Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@gmail.com> Link: http://lkml.kernel.org/r/4cc1af3c.8ee7d80a.5a28.ffff868e@mx.google.com Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf tool: Fix endianness handling of u32 data in samplesDavid Ahern
Currently, analyzing PPC data files on x86 the cpu field is always 0 and the tid and pid are backwards. For example, analyzing a PPC file on PPC the pid/tid fields show: rsyslogd 1210/1212 and analyzing the same PPC file using an x86 perf binary shows: rsyslogd 1212/1210 The problem is that the swap_op method for samples is perf_event__all64_swap which assumes all elements in the sample_data struct are u64s. cpu, tid and pid are u32s and need to be handled individually. Given that the swap is done before the sample is parsed, the simplest solution is to undo the 64-bit swap of those elements when the sample is parsed and do the proper swap. The RAW data field is generic and perf cannot have programmatic knowledge of how to treat that data. Instead a warning is given to the user. Thanks to Anton Blanchard for providing a data file for a mult-CPU PPC system so I could verify the fix for the CPU fields. v3 -> v4: - fixed use of WARN_ONCE v2 -> v3: - used WARN_ONCE for message regarding raw data - removed struct wrapper around union - fixed whitespace issues v1 -> v2: - added a union for undoing the byte-swap on u64 and redoing swap on u32's to address compiler errors (see git commit 65014ab3) Cc: Anton Blanchard <anton@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1315321946-16993-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf sort: Fix symbol sort output by separating unresolved samples by typeAnton Blanchard
I took a profile that suggested 60% of total CPU time was in the hypervisor: ... 60.20% [H] 0x33d43c 4.43% [k] ._spin_lock_irqsave 1.07% [k] ._spin_lock Using perf stat to get the user/kernel/hypervisor breakdown contradicted this. The problem is we merge all unresolved samples into the one unknown bucket. If add a comparison by sample type to sort__sym_cmp we get the real picture: ... 57.11% [.] 0x80fbf63c 4.43% [k] ._spin_lock_irqsave 1.07% [k] ._spin_lock 0.65% [H] 0x33d43c So it was almost all userspace, not hypervisor as the initial profile suggested. I found another issue while adding this. Symbol sorting sometimes shows multiple entries for the unknown bucket: ... 16.65% [.] 0x6cd3a8 7.25% [.] 0x422460 5.37% [.] yylex 4.79% [.] malloc 4.78% [.] _int_malloc 4.03% [.] _int_free 3.95% [.] hash_source_code_string 2.82% [.] 0x532908 2.64% [.] 0x36b538 0.94% [H] 0x8000000000e132a4 0.82% [H] 0x800000000000e8b0 This happens because we aren't consistent with our sorting. On one hand we check to see if both symbols match and for two unresolved samples sym is NULL so we match: if (left->ms.sym == right->ms.sym) return 0; On the other hand we use sample IP for unresolved samples when comparing against a symbol: ip_l = left->ms.sym ? left->ms.sym->start : left->ip; ip_r = right->ms.sym ? right->ms.sym->start : right->ip; This means unresolved samples end up spread across the rbtree and we can't merge them all. If we use cmp_null all unresolved samples will end up in the one bucket and the output makes more sense: ... 39.12% [.] 0x36b538 5.37% [.] yylex 4.79% [.] malloc 4.78% [.] _int_malloc 4.03% [.] _int_free 3.95% [.] hash_source_code_string 2.26% [H] 0x800000000000e8b0 Acked-by: Eric B Munson <emunson@mgebm.net> Cc: Eric B Munson <emunson@mgebm.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ian Munsie <imunsie@au1.ibm.com> Link: http://lkml.kernel.org/r/20110831115145.4f598ab2@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Synthesize anonymous mmap eventsAnton Blanchard
perf_event__synthesize_mmap_events does not create anonymous mmap events even though the kernel does. As a result an already running application with dynamically created code will not get profiled - all samples end up in the unknown bucket. This patch skips any entries with '[' in the name to avoid adding events for special regions (eg the vsyscall page). All other executable mmaps are assumed to be anonymous and an event is synthesized. Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Link: http://lkml.kernel.org/r/20110830091506.60b51fe8@kryten Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf record: Create events initially disabled and enable after initDavid Ahern
perf-record currently creates events enabled. When doing a system wide collection (-a arg) this causes data collection for perf's initialization activities -- eg., perf_event__synthesize_threads(). For some events (e.g., context switch S/W event or tracepoints like syscalls) perf's initialization causes a lot of events to be captured frequently generating "Check IO/CPU overload!" warnings on larger systems (e.g., 2 socket, quad core, hyperthreading). perf's initialization phase can be skipped by creating events disabled and then enabling them once the initialization is done. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1314289075-14706-1-git-send-email-dsahern@gmail.com Signed-off-by: David Ahern <dsahern@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Add some heuristics for choosing the best duplicate symbolAnton Blanchard
Try and pick the best symbol based on a few heuristics: - Prefer a non weak symbol over a weak one - Prefer a global symbol over a non global one - Prefer a symbol with less underscores (idea taken from kallsyms.c) - If all else fails, choose the symbol with the longest name Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065243.161953371@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Preserve symbol scope when parsing /proc/kallsymsAnton Blanchard
kallsyms__parse capitalises the symbol type, so every symbol is marked global. Remove this and fix symbol_type__is_a to handle both local and global symbols. Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065243.077125989@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: /proc/kallsyms does not sort module symbolsAnton Blanchard
kallsyms__parse assumes that /proc/kallsyms is sorted and sets the end of the previous symbol to the start of the current one. Unfortunately module symbols are not sorted, eg: ffffffffa0081f30 t e1000_clean_rx_irq [e1000e] ffffffffa00817a0 t e1000_alloc_rx_buffers [e1000e] Some symbols end up with a negative length and others have a length larger than they should. This results in confusing perf output. We already have a function to fixup the end of zero length symbols so use that instead. Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065242.969681349@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Fix ppc64 SEGV in dso__load_sym with debuginfo filesAnton Blanchard
64bit PowerPC debuginfo files have an empty function descriptor section. I hit a SEGV when perf tried to use this section for symbol resolution. To fix this we need to check the section is valid and we can do this by checking for type SHT_PROGBITS. Cc: <stable@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric B Munson <emunson@mgebm.net> Link: http://lkml.kernel.org/r/20110824065242.895239970@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf probe: Fix regression of variable finderMasami Hiramatsu
Fix to call convert_variable() if previous call does not fail. To call convert_variable, it ensures "ret" is 0. However, since "ret" has the return value of synthesize_perf_probe_arg() which always returns positive value if it succeeded, perf probe doesn't call convert_variable(). This will cause a SEGV when we add an event with arguments. This has to be fixed as it ensures "ret" is greater than 0 (or not negative). This regression has been introduced by my previous patch, f182e3e1. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110820053922.3286.65805.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-29Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: avoid writing the auxillary control register for ARMv7 ARM: pm: some ARMv7 requires a dsb in resume to ensure correctness ARM: pm: arm920/926: fix number of registers saved ARM: pm: CPU specific code should not overwrite r1 (v:p offset) ARM: 7066/1: proc-v7: disable SCTLR.TE when disabling MMU ARM: 7065/1: kexec: ensure new kernel is entered in ARM state ARM: 7003/1: vexpress: Add clock definition for the SP805. ARM: 7051/1: cpuimx* boards: fix mach-types errors ARM: 7019/1: Footbridge: select CLKEVT_I8253 for ARCH_NETWINDER ARM: 7015/1: ARM errata: Possible cache data corruption with hit-under-miss enabled ARM: 7014/1: cache-l2x0: Fix L2 Cache size calculation. ARM: 6967/1: ep93xx: ts72xx: fix board model detection ARM: 6965/1: ep93xx: add model detection for ts-7300 and ts-7400 boards ARM: cache: detect VIPT aliasing I-cache on ARMv6 ARM: twd: register clockevents device before enabling PPI ARM: realview: ensure visibility of writes during reset ARM: perf: make name of arm_pmu_type consistent ARM: perf: fix prototype of release_pmu ARM: fix perf build with uclibc toolchains
2011-08-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutilsLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/cpupowerutils: cpupower: use man(1) when calling "cpupower help subcommand" cpupower: make NLS truly optional cpupower: fix Makefile typo cpupower: Make monitor command -c/--cpu aware cpupower: Better detect offlined CPUs cpupower: Do not show an empty Idle_Stats monitor if no idle driver is available cpupower: mperf monitor - Use TSC to calculate max frequency if possible cpupower: avoid using symlinks
2011-08-19cpupower: use man(1) when calling "cpupower help subcommand"Dominik Brodowski
Instead of printing something non-formatted to stdout, call man(1) to show the man page for the proper subcommand. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-19cpupower: make NLS truly optionalDominik Brodowski
Loosely based on a patch for cpufrequtils, submittted by Sergey Dryabzhinsky <sergey.dryabzhinsky@gmail.com> and signed-off-by: Matt Turner <mattst88@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-19cpupower: fix Makefile typoDave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-18perf tools: Add group event scheduling option to perf record/statLin Ming
Group event scheduling command line option is missing in perf record/stat. Add it to perf record/stat, which is same as in perf top. Reported-by: Andi Kleen <andi@firstfloor.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1313577727.2754.5.camel@hp6530s Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-18perf tools: Fix build against newer glibcJosh Boyer
Upstream glibc commit 295e904 added a definition for __attribute_const__ to cdefs.h. This causes the following error when building perf: util/include/linux/compiler.h:8:0: error: "__attribute_const__" redefined [-Werror] /usr/include/sys/cdefs.h:226:0: note: this is the location of the previous definition Wrap __attribute_const__ in #ifndef as we do for __always_inline. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110818113720.GL2227@zod.bos.redhat.com Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-18perf tools: Fix error handling of unknown eventsStephane Eranian
There was a problem with the parse_events() code not printing the correct event name when an event was unknown and starting with an 'r'. The source of the problem was the way raw notation was parsed. Without the patch: $ perf stat -e retired_foo invalid event modifier: 'tired_foo' With the patch: $ perf stat -e retired_foo invalid or unsupported event: 'retired_foo' This also covers the case where the name of the event was not printed at all when perf was linked with libpfm4. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110723021043.GA20178@quad Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-18perf evlist: Fix missing event name init for default eventStephane Eranian
When no event is given to perf record, perf top, a default event is initialized (cycles). However, perf_evlist__add_default() was not setting the symbolic name for the event. Perf top worked simply because it was reconstructing the name from the event code. But it should not have to do this. This patch initializes the evsel->name field properly. This second version improves the code flow on the non error path. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110607161936.GA8163@quad Signed-off-by: Stephane Eranian <eranian@google.com> [committer note: Use perf_evsel__delete() instead of plain free()] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-18perf list: Fix exit valueStephane Eranian
This patch fixes an issue with the exit value of perf list: $ perf list; echo $? 129 perf list returns an error exit code even though there is no error. There was a stray exit(129) in print_events(). This patch removes this exit(). $ perf list; echo $? 0 $ perf list hw sw cpu-cycles OR cycles [Hardware event] stalled-cycles-frontend OR idle-cycles-frontend [Hardware event] stalled-cycles-backend OR idle-cycles-backend [Hardware event] instructions [Hardware event] cache-references [Hardware event] cache-misses [Hardware event] branch-instructions OR branches [Hardware event] branch-misses [Hardware event] bus-cycles [Hardware event] cpu-clock [Software event] task-clock [Software event] page-faults OR faults [Software event] minor-faults [Software event] major-faults [Software event] context-switches OR cs [Software event] cpu-migrations OR migrations [Software event] alignment-faults [Software event] emulation-faults [Software event] $ echo $? 0 Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110523123917.GA31060@quad Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-15cpupower: Make monitor command -c/--cpu awareThomas Renninger
This allows for example: cpupower -c 2-4,6 monitor -m Mperf |Mperf PKG |CORE|CPU | C0 | Cx | Freq 0| 8| 4| 2.42| 97.58| 1353 0| 16| 2| 14.38| 85.62| 1928 0| 24| 6| 1.76| 98.24| 1442 1| 16| 3| 15.53| 84.47| 1650 CPUs always get resorted for package, core then cpu id if it could get read out (or however you name these topology levels...). Still this is a nice way to keep the overview if a test binary is bound to a specific CPU or if one wants to show all CPUs inside a package or similar. Still missing: Do not measure not available cores to reduce the overhead and achieve better results. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-15cpupower: Better detect offlined CPUsThomas Renninger
Before, checking for offlined CPUs was done dirty and it was checked whether topology parsing returned -1 values. But this is a valid case on a Xen (and possibly other) kernels. Do proper online/offline checking, also take CONFIG_HOTPLUG_CPU option into account (no /sys/devices/../cpuX/online file). Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-15cpupower: Do not show an empty Idle_Stats monitor if no idle driver is availableThomas Renninger
By taking error values of: sysfs_get_idlestate_count(..); into account. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-15cpupower: mperf monitor - Use TSC to calculate max frequency if possibleThomas Renninger
Which makes the implementation independent from cpufreq drivers. Therefore this would also work on a Xen kernel where the hypervisor is doing frequency switching and idle entering. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-15cpupower: avoid using symlinksAmerigo Wang
Reference the source directly, don't create symlinks. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2011-08-14Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
2011-08-13Merge branch '3.1-fixes-for-rmk' of git://linux-arm.org/linux-2.6-wd into fixesRussell King
2011-08-12ARM: fix perf build with uclibc toolchainsFlorian Fainelli
libio.h is not provided by uClibc, in order to be able to test the definition of __UCLIBC__ we need to include stdlib.h, which also includes stddef.h, providing the definition of 'NULL'. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2011-08-12perf probe: Filter out redundant inline-instancesMasami Hiramatsu
With gcc4.6, some instances of concrete inlined function looks redundant and broken, because it appears inside of a concrete instance and its call_file and call_line are same as the original abstruct's decl_file and decl_line respectively. e.g. [ d1aa] subprogram external (flag) Yes name (strp) "add_timer" decl_file (data1) 2 ;here is original decl_line (data2) 847 ;line and file prototyped (flag) Yes inline (data1) inlined (1) sibling (ref4) [ d1c6] ... [ 11d84] subprogram abstract_origin (ref4) [ d1aa] ; concrete instance low_pc (addr) .text+0x000000000000246f <add_timer> high_pc (addr) .text+0x000000000000248b <mod_timer_pending> frame_base (block1) [ 0] call_frame_cfa sibling (ref4) [ 11dd9] [ 11d9f] formal_parameter abstract_origin (ref4) [ d1b9] location (data4) location list [ 701b] [ 11da8] inlined_subroutine abstract_origin (ref4) [ d1aa] ; redundant instance low_pc (addr) .text+0x000000000000247e <add_timer+0xf> high_pc (addr) .text+0x0000000000002480 <add_timer+0x11> call_file (data1) 2 ; call line and file call_line (data2) 847 ; are same as above Those redundant instances leads unwilling results; e.g. find probe points inside of functions even if we specify a function entry as below; $ perf probe -V add_timer Available variables at add_timer @<add_timer+0> struct timer_list* timer @<add_timer+15> (No matched variables) So, this filters out those redundant instances based on call-site and decl-site information. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110317.19900.59525.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Search concrete out-of-line instancesMasami Hiramatsu
gcc 4.6 generates a concrete out-of-line instance when there is a function which is implicitly inlined somewhere but also has its own instance. The concrete out-of-line instance means that it has an abstract origin of the function which is referred by not only inlined-subroutines but also a concrete subprogram. Since current dwarf_func_inline_instances() can find only instances of inlined-subroutines, this introduces new die_walk_instances() to find both of subprogram and inlined-subroutines. e.g. without this, Available variables at sched_group_rt_period @<cpu_rt_period_read_uint+9> struct task_group* tg perf probe failed to find actual subprogram instance of sched_group_rt_period(). With this, Available variables at sched_group_rt_period @<cpu_rt_period_read_uint+9> struct task_group* tg @<sched_group_rt_period+0> struct task_group* tg Now it found the sched_group_rt_period() itself. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110311.19900.63997.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Avoid searching variables in intermediate scopesMasami Hiramatsu
Fix variable searching logic to search one in inner than local scope or global(CU) scope. In the other words, skip searching in intermediate scopes. e.g., in the following code, int var1; void inline infunc(int i) { i++; <--- [A] } void func(void) { int var1, var2; infunc(var2); } At [A], "var1" should point the global variable "var1", however, if user mis-typed as "var2", variable search should be failed. However, current logic searches variable infunc() scope, global scope, and then func() scope. Thus, it can find "var2" variable in func() scope. This may not be what user expects. So, it would better not search outer scopes except outermost (compile unit) scope which contains only global variables, when it failed to find given variable in local scope. E.g. Without this: $ perf probe -V pre_schedule --externs > without.vars With this: $ perf probe -V pre_schedule --externs > with.vars Check the diff: $ diff without.vars with.vars 88d87 < int cpu 133d131 < long unsigned int* switch_count These vars are actually in the scope of schedule(), the caller of pre_schedule(). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110305.19900.94374.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Fix to search local variables in appropriate scopeMasami Hiramatsu
Fix perf probe to search local variables in appropriate local inlined function scope. For example, pre_schedule() has only 2 local variables, as below; $ perf probe -L pre_schedule <pre_schedule@/home/mhiramat/ksrc/linux-2.6/kernel/sched.c:0> 0 static inline void pre_schedule(struct rq *rq, struct task_struct *prev) { 2 if (prev->sched_class->pre_schedule) 3 prev->sched_class->pre_schedule(rq, prev); } However, current perf probe shows 4 local variables on pre_schedule(), because it searches variables in the caller(schedule()) scope. $ perf probe -V pre_schedule Available variables at pre_schedule @<schedule+445> int cpu long unsigned int* switch_count struct rq* rq struct task_struct* prev This patch fixes this issue by searching variables in the local scope of the instance of inlined function. Here is the result. $ perf probe -V pre_schedule Available variables at pre_schedule @<schedule+445> struct rq* rq struct task_struct* prev Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110259.19900.85664.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Warn when more than one line are givenMasami Hiramatsu
Check multiple --lines option and print warning informing that only the first specified --line option is valid. Changes from the 1st post: - Accept only the first option instead of the last. - Fix warning message according to David's comment. - Mark as a bugfix. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110253.19900.96192.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Fix to walk all inline instancesMasami Hiramatsu
Fix line-range collector to walk all instances of inlined function, because some execution paths can be optimized out depending on the function argument of instances. E.g.) inline_func (arg) { if (arg) do_something; else do_another; } func_A() { inline_func(1) } func_B() { inline_func(0) } In this case, func_A may have only do_something code and func_B may have only do_another. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110247.19900.93702.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Fix to search nested inlined functions in CUMasami Hiramatsu
Fix perf probe to walk through the lines of all nested inlined function call sites and declared lines when a whole CU is passed to the line walker. The die_walk_lines() can have two different type of DIEs, subprogram (or inlined-subroutine) DIE and CU DIE. If a caller passes a subprogram DIE, this means that the walker walk on lines of given subprogram. In this case, it just needs to search on direct children of DIE tree for finding call-site information of inlined function which directly called from given subprogram. On the other hand, if a caller passes a CU DIE to the walker, this means that the walker have to walk on all lines in the source files included in given CU DIE. In this case, it has to search whole DIE trees of all subprograms to find the call-site information of all nested inlined functions. Without this patch: $ perf probe --line kernel/cpu.c:151-157 </home/mhiramat/ksrc/linux-2.6/kernel/cpu.c:151> static int cpu_notify(unsigned long val, void *v) { 154 return __cpu_notify(val, v, -1, NULL); } With this: $ perf probe --line kernel/cpu.c:151-157 </home/mhiramat/ksrc/linux-2.6/kernel/cpu.c:151> 152 static int cpu_notify(unsigned long val, void *v) { 154 return __cpu_notify(val, v, -1, NULL); } As you can see, --line option with source line range shows the declared lines as probe-able. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110241.19900.34994.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Fix line walker to check CU correctlyMasami Hiramatsu
Fix line walker to check whether a given DIE is CU or not. Actually this function accepts CU, subprogram and inlined_subroutine DIEs. Without this fix, perf probe always fails to analyze lines on inlined functions; $ perf probe -L pre_schedule Debuginfo analysis failed. (-2) Error: Failed to show lines. (-2) This fixes that bug, as below. $ perf probe -L pre_schedule <pre_schedule@/home/mhiramat/ksrc/linux-2.6/kernel/sched.c:0> 0 static inline void pre_schedule(struct rq *rq, struct task_struct *prev { 2 if (prev->sched_class->pre_schedule) 3 prev->sched_class->pre_schedule(rq, prev); } /* rq->lock is NOT held, but preemption is disabled */ Changes from v1: - Update against current tip tree.(Fix dwarf-aux.c) Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110235.19900.20614.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf probe: Fix a memory leak for scopes arrayMasami Hiramatsu
Fix a memory leak for scopes array when it finds a variable in the global scope. Reviewed-by: Pekka Enberg <penberg@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20110811110229.19900.63019.stgit@fedora15 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf: fix temporary file ownership checkVasiliy Kulikov
A file in /tmp/ might be a symlink, so lstat() should be used instead of stat(). Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110811205537.GA22864@albatros Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-11perf report: Use properly build_id kernel binariesJiri Olsa
If we bring the recorded perf data together with kernel binary from another machine using: on server A: perf archive on server B: tar xjvf perf.data.tar.bz2 -C ~/.debug the build_id kernel dso is not properly recognized during the "perf report" command on server B. The reason is, that build_id dsos are added during the session initialization, while the kernel maps are created during the sample event processing. The machine__create_kernel_maps functions ends up creating new dso object for kernel, but it does not check if we already have one added by build_id processing. Also the build_id reading ABI quirk added in commit: - commit b25114817a73bbd2b84ce9dba02ee1ef8989a947 perf build-id: Add quirk to deal with perf.data file format breakage populates the "struct build_id_event::pid" with 0, which is later interpreted as DEFAULT_GUEST_KERNEL_ID. This is not always correct, so it's better to guess the pid value based on the "struct build_id_event::header::misc" value. - Tested with data generated on x86 kernel version v2.6.34 and reported back on x86_64 current kernel. - Not tested for guest kernel case. Note the problem stays for PERF_RECORD_MMAP events recorded by perf that does not use proper pid (HOST_KERNEL_ID/DEFAULT_GUEST_KERNEL_ID). They are misinterpreted within the current perf code. Probably there's not much we can do about that. Cc: Avi Kivity <avi@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20110601194346.GB1934@jolsa.brq.redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-10perf top browser: Remove spurious helpline updateArnaldo Carvalho de Melo
It will be immediately replaced in perf_top_browser__run. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-q7e2jzb44elqpkvdllk94x0i@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-10Merge branch 'perf/core' of ↵Ingo Molnar
2011-08-09perf symbols: Check '/tmp/perf-' symbol file ownershipPekka Enberg
The external symbol files are generated by JIT compilers, for example, but we need to make sure they're ours before injecting them to 'perf report'. Requested-by: Ingo Molnar <mingo@elte.hu> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1312919658-17158-1-git-send-email-penberg@kernel.org Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09perf sched: Usage leftover from trace -> script renameJiri Olsa
The 'perf sched' command usage still showing 'trace' command instead of the 'script' command. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110809124651.GD2056@jolsa.brq.redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09perf sched: Do not delete session object prematurelyJiri Olsa
The session object is released prematurely when processing events for latency command. The session's thread objects are used within the output_lat_thread function. Runnning following commands: # perf sched record # perf sched latency the latter displays incorrect data and might cause access violation. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1312837414-3819-1-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09perf tools: Check $HOME/.perfconfig ownershipArnaldo Carvalho de Melo
Just like we do already for perf.data files. Requested-by: Ingo Molnar <mingo@elte.hu> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: Christian Ohm <chr.ohm@gmx.net> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jonathan Nieder <jrnieder@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qgokmxsmvppwpc5404qhyk7e@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09Merge branch 'perf/core' of ↵Ingo Molnar
