ALSA: Fix initiailization of user-space controls
Fix an assertion when accessing a user-defined control due to lack of
initialization (appears only when CONFIG_SND_DEBUg is enabled).
ALSA sound/core/control.c:660: BUG? (info->access == 0)
Revert the mixer element names of some Mic controls to the state of
2.6.17. This should fix the name mismatch in alsactl.
Cc: Jaroslav Kysela <perex@suse.cz>
This patch schedules obsolete OSS drivers (with ALSA drivers that support
the same hardware) for removal.
A rationale of the patch is in
http://lkml.org/lkml/2006/7/11/186
TVMixer and FM801 Tea5757 are still using V4L1 API.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Accept O_RDWR at opening a PCM OSS device that is read- or write-only,
just for the compatibility with the behavior of older versions.
Signed-off-by: Jaroslav Kysela <perex@suse.cz>
Fixes ALSA bug#1365.
Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
exist
Sometimes we simply want to turn off or on everything, and when recently a
warning was added when a certain platform function can't be called, this
triggered all the time in those cases. This patch shows the warning only if
the error was different from the function not existing.
The alternative would be to not even try calling the function when it
doesn't exist by first checking which exist and then only calling those that
do, but that adds complexity that isn't necessary.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
This patch makes snd-powermac load when it can't bind the device right
away. That's the expected behaviour for hotplugging, but fixes an
important problem I was seeing with doing a modprobe snd-powermac with
a version that refuses loading on machines with layout-id: snd-powermac
would create a bunch of uevents and then refuse to load, the uevents
causing udev to reload it again, ad eternum.
This patch fixes the toonie codec to be actually usable.
The IRQ rework caused some hiccups here, in some cases we call
get_irq without a device node. This patch makes it catch that
case and return NO_IRQ when it happens, along with changing the
place where the irq is checked to check for NO_IRQ instead of -1.
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
sound: Conversions from kmalloc+memset to k(c|z)alloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Fixes ALSA bug#2190 System hangs on unplugging Audigy 2 ZS
Notebook CardBus card.
WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/sound/isa/opti9xx/snd-miro.ko
needs unknown symbol snd_cs4231_create
needs unknown symbol snd_cs4231_pcm
needs unknown symbol snd_cs4231_timer
needs unknown symbol snd_cs4231_mixer
WARNING: /lib/modules/2.6.18-rc1-mm1/kernel/fs/reiser4/reiser4.ko needs
unknown symbol generic_file_read
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
'devices' is not a good name for a global variable.
Thankfully, it can become static.
Fixed the missing array terminators in AD1988 codec support code.
Fix a occasional deadlock occuring with snd-rtctimer driver,
added irqsave to the lock in tasklet (ALSA bug#952).
Fixed 'section mismatch' errors in ALSA PCI drivers:
- removed invalid __devinitdata from pci id tables
- fix/remove __devinit of functions called in suspend/resume
Drop the snd_minor structure's name field that was just a helper for
devfs device deregistration.
Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
This patch fixes the remaining instances in our tree where a non-
existent mpu401 interface can cause a hard freeze when i/o is issued.
This commit closes Malone #34831.
Bug: https://launchpad.net/distros/ubuntu/+source/linux-source-2.6.15/+bug/34831
patch location:
http://www.kernel.org/git/?p=linux/kernel/git/bcollins/ubuntu-dapper.git;a=commitdiff;h=b422309cdd980cfefe99379796c04e961d3c1544
The wavefront driver used __init in some places referenced by __devinit
functions.
Fix the workaround for AD1988A rev2 codec not to apply to AD1988B codec
chips.
- Fix spaces, wrap lines in 80 columns.
- Move EXPORT_SYMBOL() adjacent to each function.
Static functions shouldn't be exported.
Added the default ac97 quirk (hp_only) for Tyan Thunder K8WE board.
Fix the driver string name for Terratec Aureon 7.1 Universe
to fit in 15 letters to avoid the overflow.
CONFIG_SND_FM801=y, CONFIG_SND_FM801_TEA575X=m resulted in the following
compile error:
<-- snip -->
LD vmlinux
sound/built-in.o: In function 'snd_fm801_free':
fm801.c:(.text+0x3c15b): undefined reference to 'snd_tea575x_exit'
sound/built-in.o: In function 'snd_card_fm801_probe':
fm801.c:(.text+0x3cfde): undefined reference to 'snd_tea575x_init'
make: *** [vmlinux] Error 1
<-- snip -->
This patch fixes kernel Bugzilla #6458.
if one of the first three CS_CHECKS fails, we goto cs_failed:
In this case parse we donr kfree() parse. Since the the last three
CS_CHECKS might also fail, i moved the kfree() below all the CS_CHECKs
and added one in the error path. This fixes coverity bug id #1099
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
The MacMini board table seems to largely look like any bog-standard
Intel 945 board.
This patch adds the bass/treble controls to snd-aoa that snd-powermac always
had for tas3004 based machines.
The layout fabric gained support for all IDs when I extracted those from the
OSX description file. But apparently I had forgotten to add them all as
module aliases so the module will also load. This patch adds them.
This patch makes the DRC control visible again for TAS chips.
This patch fixes the initialisation and reset of the tas codec. The tas will
often reset if the i2s clocks go away so it needs to be completely
re-initialised when clocks come back.
Also, this patch adds some code for DRC that will be exploited later to add a
DRC control again, fixing a regression over snd-powermac.
This patch changes the PCM1 control name to PCM to make it play nice with the
softvol plugin (which will then go away if it sees a proper PCM slider)
This patch cleans up the printk's in the layout fabric and also makes it
display which type of GPIO access it is going to use.
This patch makes the pmf GPIO layer in aoa report if calling a platform
function failed.
This patch revamps the i2sbus control layer by using the macio/keylargo
functions instead of directly mapping.
This patch fixes initialisation issues when all of aoa is built into the
kernel by re-ordering the link order in the Makefile and making the soundbus
use subsys_initcall so it is initialised earlier.
This patch cleans up the resource handling in i2sbus and adds workarounds for
the broken device trees on the PowerMac7,2 and 7,3. Some of this code will
later move again when macio_asic is going to export all the sub-nodes too.
This patch moves the i2sbus 'force' module parameter declaration to the top of
the file.
Use proper irq mapping interface for snd-aoa-i2sbus.
Signed-off-by: Andreas Schwab <schwab@suse.de>
Cc: Takashi Iwai <tiwai@suse.de>
There is a code sequence where the locking is substream->self_group.lock
-> ins->scbs[index].lock
substream->self_group.lock is interrupt safe, and taken from irq context
as well (trace is snipped for brevity)
so what can happen is
cpu 0 cpu 1
user context user context
take ins->scbs[index].lock without disabling interrupts
get substream->self_group.lock (irqsafe)
try to get ins->scbs[index].lock (spins)
interrupt happens
try to get substream->self_group.lock (spins)
which is an obvious AB-BA deadlock
fix is to just take the lock with _irqsafe
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Acked-by: Takashi Iwai <tiwai@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc:
powerpc: add defconfig for Freescale MPC8349E-mITX board
powerpc: Add base support for the Freescale MPC8349E-mITX eval board
Documentation: correct values in MPC8548E SEC example node
[POWERPC] Actually copy over i8259.c to arch/ppc/syslib this time
[POWERPC] Add new interrupt mapping core and change platforms to use it
[POWERPC] Copy i8259 code back to arch/ppc
[POWERPC] New device-tree interrupt parsing code
[POWERPC] Use the genirq framework
[PATCH] genirq: Allow fasteoi handler to retrigger disabled interrupts
[POWERPC] Update the SWIM3 (powermac) floppy driver
[POWERPC] Fix error handling in detecting legacy serial ports
[POWERPC] Fix booting on Momentum "Apache" board (a Maple derivative)
[POWERPC] Fix various offb and BootX-related issues
[POWERPC] Add a default config for 32-bit CHRP machines
[POWERPC] fix implicit declaration on cell.
[POWERPC] change get_property to return void *
The ops structure has complex locking rules, where not all ops are equal, some
are subordinate on others for some complex sound cards. This requires for
lockdep checking that each individual reg_mutex is considered in separation
for its locking rules.
Has no effect on non-lockdep kernels.
Teach special (recursive) locking code to the lock validator. Has no effect
sound/sparc/amd7930.c: In function 'amd7930_attach_common':
sound/sparc/amd7930.c:1040: warning: format '%08lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t'
sound/sparc/cs4231.c:2043: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t'
sound/sparc/dbri.c: In function 'dbri_attach':
sound/sparc/dbri.c:2650: warning: format '%016lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t'
This adds the new irq remapper core and removes the old one. Because
there are some fundamental conflicts with the old code, like the value
of NO_IRQ which I'm now setting to 0 (as per discussions with Linus),
etc..., this commit also changes the relevant platform and driver code
over to use the new remapper (so as not to cause difficulties later
in bisecting).
This patch removes the old pre-parsing of the open firmware interrupt
tree along with all the bogus assumptions it made to try to renumber
interrupts according to the platform. This is all to be handled by the
new code now.
For the pSeries XICS interrupt controller, a single remapper host is
created for the whole machine regardless of how many interrupt
presentation and source controllers are found, and it's set to match
any device node that isn't a 8259. That works fine on pSeries and
avoids having to deal with some of the complexities of split source
controllers vs. presentation controllers in the pSeries device trees.
The powerpc i8259 PIC driver now always requests the legacy interrupt
range. It also has the feature of being able to match any device node
(including NULL) if passed no device node as an input. That will help
porting over platforms with broken device-trees like Pegasos who don't
have a proper interrupt tree.
The 64 bits resource patches did a bit of damage on PowerMac causing a
buffer overflow in macio_asic and a warning in a sound driver. The
former is fixed by reverting the sprintf of the bus_id to %08x as it was
before. The bus_id used for macio devices is always a 32 bits value
(macio always sits in 32 bits space) and since it's exposed to userland,
the format of the string shouldn't be changed like that anyway. The
second by using the proper type for printk.
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
