- define the SMALL_POP as a 1-bit mask, not value;
- properly set the SMALL_POP on device probing.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
- ldo_regulator_remove() doesn't reset sgtl5000->ldo so it is
possible to dereference members of previously freed struct ldo.
- Name headphone mux related data objects correctly.
- the code to fallback to internal ldo regulator instead of external
vddd is completely wrong. According to TDM and Errata of sgtl5000
chips revision < 0x11 strongly need to use external vddd due to ER1.
For chips revision >= 0x11 there is no limitation to use either
external vddd or internal ldo regulator.
- fix logical error in cleanup sequence.
commit c251ea7bd7a04f1f2575467e0de76e803cf59149 upstream
On a mx28evk with a sgtl5000 codec we notice a loud 'click' sound to happen
5 seconds after the end of a playback.
The SMALL_POP bit should fix this, but its definition is incorrect:
according to the sgtl5000 manual it is bit 0 of CHIP_REF_CTRL register, not
bit 1.
Fix the definition accordingly and enable the bit as intended per the code
comment.
After applying this change, no loud 'click' sound is heard after playback
Signed-off-by: Mark Brown <broonie@kernel.org>
Cc: stable@vger.kernel.org
commit f091f3f07328f75d20a2a5970d1f8b58d95fc990 upstream
When a sound capture/playback is terminated while a playback/capture
is running, power_vag_event() will clear SGTL5000_CHIP_ANA_POWER in
the SND_SOC_DAPM_PRE_PMD event, thus muting the respective other
channel.
Don't clear SGTL5000_CHIP_ANA_POWER when both DAC and ADC are active
to prevent this.
Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de>
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit dd4d2d6dfb49e8916064f2cb07f0ad7b32a82fb7 upstream
The VAG_POWER must be enabled after all other bits in CHIP_ANA_POWER
and disabled before any other bit in CHIP_ANA_POWER. See the SGTL5000
datasheet (Table 31, BIT 7, page 42-43). Failing to follow this order
will result in ugly loud "POP" noise at the end of playback.
To achieve such order, use the _PRE and _POST DAPM widgets to trigger
the power_vag_event, where the event type check has to be fixed
accordingly as well.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
snd_usb_add_audio_stream() call
create_fixed_stream_quirk(), snd_usb_parse_audio_interface() and
create_uaxx_quirk() functions allocate the audioformat object by themselves
and free it upon error before returning. However, once the object is linked
to a stream, it's freed again in snd_usb_audio_pcm_free(), thus it'll be
double-freed, eventually resulting in a memory corruption.
This patch fixes these failures in the error paths by unlinking the audioformat
object before freeing it.
Based on a patch by Takashi Iwai <tiwai@suse.de>
[Note for stable backports:
this patch requires the commit 902eb7fd1e4a ('ALSA: usb-audio: Minor
code cleanup in create_fixed_stream_quirk()')]
Bug 1823317
Bug 1935735
Change-Id: I4f65a902a19e7b21e8bc0fa21efd833c8360a3cf
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1283358
Reported-by: Ralf Spenneberg <ralf@spenneberg.net>
Cc: <stable@vger.kernel.org> # see the note above
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Reviewed-on: http://git-master/r/1259999
(cherry picked from commit 14e09c3233fb7578c778b70ec3933ba5cadfccb6)
Reviewed-on: https://git-master.nvidia.com/r/1690292
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Check ucode size for upper limit.
Bug 1901435
Bug 1954563
Bug 1917589
Signed-off-by: Ravindra Lokhande <rlokhande@nvidia.com>
Signed-off-by: Xia Yang <xiay@nvidia.com>
Change-Id: I2f455771147bb4466d154878d2461e472647c4fb
Reviewed-on: https://git-master.nvidia.com/r/1575925
Reviewed-on: https://git-master.nvidia.com/r/1674399
Tested-by: James Huang <jamehuang@nvidia.com>
Reviewed-by: James Huang <jamehuang@nvidia.com>
This patch adds support for the Toradex Apalis TK1 acomputer on module
which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality which is not yet
supported.
This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto
or L4T/JetPack Ubuntu based image.
The following things are known to work to a certain extend:
- analogue/digital audio
- debug UART1
- DVFS power management incl. low power core migration
- eMMC
- gigabit Ethernet
- GPIOs
- HDMI (incl. HDA audio)
- I2C
- LVDS
- PCIe
- SATA
- SD/MMC cards
- temperature sensor
- USB host ports
The rest is untested.
Hack HDA driver to make it the 2nd rather than the first sound card as
the first one should be the SGTL5000 which is always present on our T30
and TK1 modules. Especially on Ixora where there is no HDA codec on the
carrier board HDA being the first sound card does not make much sense
even more though as there was no primary device (e.g. device=hw:0,0).
(cherry picked from commit fff75b252e0aed1d8be2b62234624f726c153776)
If firmware is not found in case of error, set audio_engine
to NULL so that kernel does not panic while further
processing
Bug 200067781
Change-Id: Ia854c978bd33a2615ab27715e83b4d78a1dbab3a
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/670625
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Some info prints are wrongly processed as err print
Bug 200042283
Change-Id: I490b4782e5d26d06c0f3c7104ab8c68b94f31888
Reviewed-on: http://git-master/r/668854
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
- avp module remove should not try to release client
if avp pcm open was never called and client was
never allocated
- avp module remove should deregister offload ops
Bug 200043253
Change-Id: I11a6d65afab4d88aa5669553809e99fd69cfd000
Signed-off-by: Shreshtha SAHU <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/554153
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Reviewed-by: Zheng Liu <zhliu@nvidia.com>
Bug 1550880
Change-Id: I54697780893c17a1c117483fd9bf271ba31209d4
Reviewed-on: http://git-master/r/551902
- Remove switch_dev_unregister and call tegra_asoc_switch_unregister
instead in error return path corresponding to tegra_asoc_switch_register.
- Skip max97236 registration for laguna erss platorm.
Issues surfaced out on making max98090 as removable KO module.
Bug 1550880
Change-Id: I6a6c0185a3980efab3592f0733bda214aac4fc81
Reviewed-on: http://git-master/r/551901
without regmap_exit in remove, next modprobe of
modprobe used to complain of
"Failed to create debugfs directory"
due to stale debugfs directory.
Bug 200038898
Change-Id: Ie6373f40b50c1307ee7d114dc0f44164c4b426eb
Reviewed-on: http://git-master/r/542646
added missing device_remove_file during device remove
this resulted failure in modprobe of module
Bug 200038187
Bug 200037087
Change-Id: Ibbe8cf92162144d438f5b563bf6d2b9787acc04e
Reviewed-on: http://git-master/r/499745
digital_reg was disabled second time instead of codec_reg
Bug 200036995
Change-Id: I8e9b3aeafa613a5a58063b88ee81bf3d0aaf4e43
Reviewed-on: http://git-master/r/498837
Reviewed-by: Vinayak Pane <vpane@nvidia.com>
Export symbols so the sound driver can be built as a module.
Bug 1536426
Change-Id: I86fa8800df1988f630b4e45d4cbf1733c039c837
Signed-off-by: Zheng Liu <zhliu@nvidia.com>
Reviewed-on: http://git-master/r/494120
Reviewed-by: Allen Martin <amartin@nvidia.com>
This makes controls HDA Decode Capability, HDA Maximum PCM Channels
for HDA and AVP DMA channel id for Tegra Soc read only.
Bug 200023797
Change-Id: I3271470354b02f3d1b3aab8fa3963ad19d281f41
Signed-off-by: Rahool Paliwal <rpaliwal@nvidia.com>
Reviewed-on: http://git-master/r/441855
Several additional audio clocks need to be initialized before
accessing any audio register, otherwise system will just hard hang.
Probably fastboot bootloader initialize these clocks, which actually
should be handled in driver. We found this issue for U-Boot bringup.
Bug 1482099
Change-Id: Ia7a7c0115bc92a4e98e6f337cf8efc7b2f7a72a0
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Signed-off-by: Prabhu Kuttiyam <pkuttiyam@nvidia.com>
Reviewed-on: http://git-master/r/408429
(cherry picked from commit 2929886db14e9d2ac0e75b282126397970fbf9c9)
Reviewed-on: http://git-master/r/427929
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
- Add dai link for effects capture
Bug 1399923
Change-Id: Ie361aad3cedb1c47b8800fc9eac221e4fcaccc97
Signed-off-by: Deepa Madiregama <dmadiregama@nvidia.com>
Reviewed-on: http://git-master/r/433496
Reviewed-by: Ravindra Lokhande <rlokhande@nvidia.com>
Add capture node to get the effects data from AVP
Bug 1399923
Change-Id: I854de0966a40fe7867001a25058626da63b87b92
Reviewed-on: http://git-master/r/414091
Reviewed-by: Emad Mir <emir@nvidia.com>
Tested-by: Emad Mir <emir@nvidia.com>
raw aac support is added for compress decoding on avp.
Bug 200013486
Change-Id: I355bc8b1636811fb51abb4c4c6ca23f207ec5064
Signed-off-by: Sayak Ghosh Choudhury <sayakc@nvidia.com>
Reviewed-on: http://git-master/r/427720
- Added virtual mixer and switch to support multiple BE
- One FE can be connected to multiple BE, mixer control can be used
to select the path
- Fix crash if no path is selected
Change-Id: Ibbf03ef1e1826acd92402b8275d72a580e643e66
Reviewed-on: http://git-master/r/428950
Bug 200008134
Change-Id: I3f39c15a91fb76958b739636eddb6d8480898d21
Reviewed-on: http://git-master/r/422171
Tested-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
hp_amp_power is called multiple times during widget
power on and power on/off info is helpful in debugging.
so moving print from info to debug.
Bug 200010480
Change-Id: Id8db60f1617cd7a5d939ffcf8192201658d6fe96
Signed-off-by: Shreshtha Sahu <ssahu@nvidia.com>
Reviewed-on: http://git-master/r/422579
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
-Update from vendor to fix/improve Headset detection.
Bug 1514488
Bug 200004866
Change-Id: I7b8ca45b7f30c964013a34c8cdd5734efb544c81
Signed-off-by: Vinod Subbarayalu <vsubbarayalu@nvidia.com>
Reviewed-on: http://git-master/r/419207
into promotion_build
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Bug 200006476
Change-Id: I8269a39840a4e887f8c0405457f9484fd2956e9b
Signed-off-by: Rene Houle <rhoule@nvidia.com>
Reviewed-on: http://git-master/r/418512
Reviewed-by: Pierre Gervais <pgervais@nvidia.com>
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
This patch clears previous interrupt and installs interrupt
handler at the end of device probe. Also it enables jack
detection only after handler is installed. This prevents,
false/stale interrupt generation and hence device access
by interrupt handler even before device probe has completed.
Bug 1464724
Change-Id: I5988b500bb5e197c095eb64e254829635115994c
Reviewed-on: http://git-master/r/398891
(cherry picked from commit 9368b1bb2d85286b8ef890d63e6f3d41c63b0bdc)
Reviewed-on: http://git-master/r/411451
- Add dai link for pcm and compress offload
- Enable offload for norrin
Change-Id: Ib938673fdd14faf7548dc8048bd6bfa6fab58baf
Reviewed-on: http://git-master/r/411554
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
- Add 192Khz sample rate
- Update clock rate for i2s clock
- Update ahub clock
Bug 1502003
Change-Id: I0013957e22a864670e67e3c808df270a8ca16fa1
Signed-off-by: Vijay Mali <vmali@nvidia.com>
Reviewed-on: http://git-master/r/398989
(cherry picked from commit 6f3ec1ce0b301ebf2eb3533a3fd985f25132e4f2)
Reviewed-on: http://git-master/r/411871
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Bug 1502003
Change-Id: Ic90cf2781578adefdf108358ccff94676e6df146
Reviewed-on: http://git-master/r/402848
(cherry picked from commit d90f64b19f2b8ef4f2e77134bc3d538e0c938b97)
Reviewed-on: http://git-master/r/411870
In case of seek, pause <-> stop <-> resume is the general
sequence, so allow pause state to come before stop.
Bug 1405523
Change-Id: Ib90d5c6cb780bdb5c9cedd33ae114f78603b2649
Signed-off-by: Chandrakanth Gorantla <cgorantla@nvidia.com>
Reviewed-on: http://git-master/r/401556
Reviewed-by: Deepa Madiregama <dmadiregama@nvidia.com>
- Added path between BE and codec stream
- use atomic reference count
Bug 1495249
Change-Id: I895d22e1854c53f41362ed2a1cff63d88feb397b
Reviewed-on: http://git-master/r/405859
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: I06582980f2e9e88ab0e34bc5febc5d939fb77cc4
Reviewed-on: http://git-master/r/404934
(cherry picked from commit d1095251dadc17cb2c4f885f0d5d23359536f02b)
Reviewed-on: http://git-master/r/405472
Add alsa control for volume changes during compress
offload playback.
Bug 1498475
Change-Id: I5572338648a2fefdcf3095702bcbade35f1b0565
Reviewed-on: http://git-master/r/399682
commit 7c66593286bcd153e4868383e675673a27071bd5 upstream.
Signed-off-by: Kailang Yang <kailang@realtek.com>
commit 415d555e6b398b00fc1733f0113065a54df9106a upstream.
The recent fixups for HP laptops to support the mute LED made the
speaker output silent on some machines. It turned out that they use
the NID 0x18 for the speaker while it's also used for controlling the
LED via VREF bits although the current driver code blindly assumes
that such a node is a mic pin (where 0x18 is usually so).
This patch fixes the problem by only changing the VREF bits and
keeping the other pin ctl bits.
Reported-and-tested-by: Hui Wang <hui.wang@canonical.com>
commit 4f8e940095536bc002a81666a4107a581c84e9b9 upstream.
PCM pointer callbacks in ice1712 driver check the buffer size boundary
wrongly between bytes and frames. This leads to PCM core warnings
like:
snd_pcm_update_hw_ptr0: 105 callbacks suppressed
ALSA pcm_lib.c:352 BUG: pcmC3D0c:0, pos = 5461, buffer size = 5461, period size = 2730
This patch fixes these checks to be placed after the proper unit
conversions.
commit a4b7f21d7b42b33609df3f86992a8deff80abfaf upstream.
The `lspci -nnvv` output contains (wrapped for line length):
00:1b.0 Audio device [0403]:
Intel Corporation 7 Series/C210 Series Chipset Family
High Definition Audio Controller [8086:1e20] (rev 04)
Subsystem: ASUSTeK Computer Inc. Device [1043:115d]
Signed-off-by: W. Trevor King <wking@tremily.us>
commit 1555b652970e541fa1cb80c61ffc696bbfb92bb7 upstream.
The mask bits values were wrong for the SOC_VALUE_ENUM_SINGLE for the mono mix controls.
Reported-by: Takashi Iwai <tiwai@suse.de>
Signed-off-by: Brian Austin <brian.austin@cirrus.com>
commit d31a33dd7792c7d6c11fda226a3b9e4fb7f86f95 upstream.
The mask bits values were wrong for the SOC_VALUE_ENUM_SINGLE for the PCM/ADC Swap controls
kcontrols
commit 7272e051157ccd5871b5d939548d0ba5a94a2965 upstream.
The shift values for the ADC,PCM, and Analog kcontrols were wrong causing wrong values for the SOC_DOUBLE_R_SX_TLV macros
Fixed the TLV for aout_tlv to show -102dB correctly
Fixes: 1d99f2436d (ASoC: core: Rework SOC_DOUBLE_R_SX_TLV add SOC_SINGLE_SX_TLV)
Reported-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
When the device enters to LP0, resetting of the audio codec makes the
HP detection GPIO pin high and causes a false interrupt. If the codec
gets reset before the interrupt is disabled by the machine driver,
device never goes to LP0 or wakes up from LP0. Added fix to avoid
this condition.
Bug 1499603
Reviewed-on: http://git-master/r/400786
(cherry picked from commit cb430a1dcc1eab8dc993c5042a4683d81edb1b8d)
Change-Id: I5fd498c13a384b501243b13a7faef6aa069aa7ab
Signed-off-by: Sharad Gupta <sharadg@nvidia.com>
Reviewed-on: http://git-master/r/402750
