According to the manual [1], SYS_MCLK should base on SYS_FS, not on sample rate.
Calculating SYS_MCLK using sample rate only prevents playing/recording
samples with rate < 16 kHz:
root@apalis-tk1:~# aplay test-8k-sample.wav
Playing WAVE 'test-8k-sample.wav' : Signed 16 bit
[...] tegra-snd-apalis-tk1-sgtl5000 tegra-snd-apalis-tk1-sgtl5000.0: ASoC: machine hw_params failed: -22
Little Endian, Rate 8000 Hz, Stereo
aplay: set_params:1403: Unable to install hw params:
Using the helper from sgtl5000.h fixes this issue.
To keep determination of sys_fs solid, use a helper in device driver.
[1] https://www.nxp.com/docs/en/data-sheet/SGTL5000.pdf
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
This patch adds support for the Toradex Apalis TK1 acomputer on module
which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality which is not yet
supported.
This is known to boot into either a basic Angstrom/OpenEmbedded/Yocto
or L4T/JetPack Ubuntu based image.
The following things are known to work to a certain extend:
- analogue/digital audio
- debug UART1
- DVFS power management incl. low power core migration
- eMMC
- gigabit Ethernet
- GPIOs
- HDMI (incl. HDA audio)
- I2C
- LVDS
- PCIe
- SATA
- SD/MMC cards
- temperature sensor
- USB host ports
The rest is untested.
