path: root/sound/mips
2013-05-06ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Vivien Chappelier <vivien.chappelier@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-06ALSA: mips/hal2: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Thomas Bogendoerfer <tsbogend@alpha.fanken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-12-07ALSA: mips: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-24ALSA: Convert mips directory to module_platform_driverAxel Lin
Factor out some boilerplate code. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-11-03Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (37 commits) MIPS: O32: Provide definition of registers ta0 .. ta3. MIPS: perf: Add Octeon support for hardware perf. MIPS: perf: Add support for 64-bit perf counters. MIPS: perf: Reorganize contents of perf support files. MIPS: perf: Cleanup formatting in arch/mips/kernel/perf_event.c MIPS: Add accessor macros for 64-bit performance counter registers. MIPS: Add probes for more Octeon II CPUs. MIPS: Add more CPU identifiers for Octeon II CPUs. MIPS: XLR, XLS: Add comment for smp setup MIPS: JZ4740: GPIO: Check correct IRQ in demux handler MIPS: JZ4740: GPIO: Simplify IRQ demuxer MIPS: JZ4740: Use generic irq chip MIPS: Alchemy: remove all CONFIG_SOC_AU1??? defines MIPS: Alchemy: kill au1xxx.h header MIPS: Alchemy: clean DMA code of CONFIG_SOC_AU1??? defines MIPS, IDE: Alchem, au1xxx-ide: Remove pb1200/db1200 header dep MIPS: Alchemy: Redo PCI as platform driver MIPS: Alchemy: more base address cleanup MIPS: Alchemy: rewrite USB platform setup. MIPS: Alchemy: abstract USB block control register access ... Fix up trivial conflicts in: arch/mips/alchemy/devboards/db1x00/platform.c drivers/ide/Kconfig drivers/mmc/host/au1xmmc.c drivers/video/Kconfig sound/mips/Kconfig
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-24MIPS: Alchemy: remove all CONFIG_SOC_AU1??? definesManuel Lauss
Now that no driver any longer depends on the CONFIG_SOC_AU1??? symbols, it's time to get rid of them: Move some of the platform devices to the boards which can use them, Rename a few (unused) constants in the header, Replace them with MIPS_ALCHEMY in the various Kconfig files. Finally delete them altogether from the Alchemy Kconfig file. Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> To: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/2707/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-09-22sound: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27ALSA: deprecate MIPS AU1X00 AC97 driverManuel Lauss
Now that an ASoC variant is available, tell users that this driver is now living on borrowed time... Signed-off-by: Manuel Lauss <manuel.lauss@googlemail.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2010-05-27sound: Add missing spin_unlockJulia Lawall
Add a spin_unlock missing on the error path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * spin_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * spin_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-18ALSA: pcm - Call pgprot_noncached() for vmalloc'ed buffersTakashi Iwai
pgprot_noncached() can be set for vmalloc'ed buffers safely, and we'd need non-cached behavior more or less, even for the intermediate ring- buffers. Now snd_pcm_lib_mmap_vmalloc() is added as the common PCM mmap callback that is coupled with snd_pcm_lib_alloc_vmalloc_buffer() & co. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: sgio2audio: use vmalloc buffer helper functionsClemens Ladisch
Remove this duplicate of snd_pcm_alloc_vmalloc_buffer and use the equivalent core functions instead. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-18sound: sgio2audio/pdaudiocf/usb-audio: initialize PCM bufferClemens Ladisch
When allocating the PCM buffer, use vmalloc_user() instead of vmalloc(). Otherwise, it would be possible for applications to play the previous contents of the kernel memory to the speakers, or to read it directly if the buffer is exported to userspace. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-10-02ALSA: Fix invalid __exit in sound/mips/*.cTakashi Iwai
The remove callback has to be marked as __devexit, as the dynamic unbind is possible. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-06-07ALSA: sgio2audio.c: clean up checkingFigo.zhang
vfree() does it's own 'NULL' check,so no need for check before calling it. Signed-off-by: Figo.zhang <figo1802@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/misc' into for-linusTakashi Iwai
2009-02-05ALSA: Add missing KERN_* prefix to printk in other sound/*Takashi Iwai
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-13ALSA: Kill snd_assert() in other placesTakashi Iwai
Kill snd_assert() in other places, either removed or replaced with if () with snd_BUG_ON(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-23removed unused #include <linux/version.h>'sAdrian Bunk
This patch lets the files using linux/version.h match the files that #include it. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14ALSA: ALSA driver for SGI O2 audio boardThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside most of the SGI O2 workstation. The hardware uses a SGI custom chip, which feeds a AD codec chip. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-07-14ALSA: ALSA driver for SGI HAL2 audio deviceThomas Bogendoerfer
This patch adds a new ALSA driver for the audio device found inside many older SGI workstation (Indy, Indigo2). The hardware uses a SGI custom chip, which feeds two codec chips, an IEC chip and a synth chip. Currently only one of the codecs is supported. This driver already has the same functionality as the HAL2 OSS driver and will replace it. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-29[PATCH] sound/mips/au1x00: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-02[PATCH] irq-flags: sound: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[ALSA] AMD Au1x00: AC'97 controller is memory mappedSergei Shtylyov
Modules: MIPS AU1x00 driver AMD Au1x00 ALSA driver erroneously calls request_region() for AC'97 controller registers -- the controller is actually memory mapped at addresses 0x10000000 thru 0x100FFFFF. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] AMD Au1x00: fix DMA init/cleanupSergei Shtylyov
Modules: MIPS AU1x00 driver AMD Au1x00 ALSA driver causes kernel oops in au1000_init() by trying to set DMA channel to -1 in yet unallocated audio streams. Here's the patch that staightens up DMA init/cleanup code. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] AMD Au1x00: make driver build after cleanupSergei Shtylylov
Modules: MIPS AU1x00 driver AMD Au1x00 ALSA driver doesn't build after the recent code cleanup: sound/mips/au1x00.c: In function 'au1000_setup_dma_link': sound/mips/au1x00.c:173: error: 'pointer' undeclared (first use in this function) sound/mips/au1x00.c:173: error: (Each undeclared identifier is reported only once sound/mips/au1x00.c:173: error: for each function it appears in.) sound/mips/au1x00.c: In function 'snd_au1000_hw_params': sound/mips/au1x00.c:339: warning: implicit declaration of function 'snd_mask_min' Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove snd_card_generic_dev()Takashi Iwai
Remove the obsolete snd_card_generic_dev(). CONFIG_SND_GENERIC_DRIVER is also removed from Kconfig. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: MIPS AU1x00Takashi Iwai
Modules: MIPS AU1x00 driver Remove xxx_t typedefs from the MIPS AU1x00 driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] au1x00 - Code clean upTakashi Iwai
Modules: MIPS AU1x00 driver Clean up snd-au1x00 driver code: - Remove global variables - Remove old compatibility codes - Fix DMA-link allocation/release functions in hw_params and hw_free callbacks (they may be called multiple times) - Fix spinlocks Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] AMD Au1x00 driver: buggy spinlocksKonstantin Baydarov
Modules: MIPS AU1x00 driver AMD Au1x00 ALSA driver fails compilation with the alternate spinlock implementation because it doesn't do locking/unlocking correctly in some places (passes spinlock by value). Signed-off-by: Konstantin Baydarov <kbaidarov@ru.mvista.com> Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove obsolete chip_tTakashi Iwai
Modules: Documentation,MIPS AU1x00 driver,PPC Beep,SPARC DBRI driver Removed the use of chip_t, which was obsoleted. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] Remove vmalloc wrapper, kfree_nocheck()Takashi Iwai
- Remove vmalloc wrapper - Add release_and_free_resource() to remove kfree_nocheck() from each driver and simplify the code Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-09-12[ALSA] Add snd_card_set_generic_dev() callTakashi Iwai
ARM,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,MIPS MIPS AU1x00 driver,PPC,PPC PowerMac driver,SPARC,SPARC AMD7930 driver SPARC cs4231 driver,SPARC DBRI driver - Added snd_card_set_generic_dev() call. - Added SND_GENERIC_DRIVER to Kconfig. - Clean up the error path in probe if necessary. Signed-off-by: Takashi Iwai <tiwai@suse.de>
