path: root/sound/aoa
2013-05-16ALSA: snd-aoa: Add a layout entry for PowerBook6,5Michael Ellerman
Either one or a combination of commits 81e5d86 "Register i2c devices from device-tree" and 3a3dd01 "Improve detection of devices from device-tree" broke sound on PowerBook6,5 machines. Fix it by adding an entry to the new driver to match PowerBook6,5 machines. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: pcm_format_to_bits strong-typed conversionEldad Zack
Add a function to handle conversion from snd_pcm_format_t to bitwise with proper typing. Change such conversions to use this function and silence sparse warnings. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-07-11sound/aoa: Adapt to new i2c probing schemeAndreas Schwab
The i2c-powermac driver now creates the i2c devices properly from the device-tree, including workarounds for broken or missing device-tree bits, so let's just use the normal probe methods and get rid of the hand made device creation code. Signed-off-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-01-27ALSA: aoa: Convert onyx and tas codec drivers to module_i2c_driverAxel Lin
This patch converts onyx and tas codec drivers to use the module_i2c_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-10-31sound: Add module.h to the previously silent sound usersPaul Gortmaker
Lots of sound drivers were getting module.h via the implicit presence of it in <linux/device.h> but we are going to clean that up. So fix up those users now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-29snd-aoa: remove commented out Kconfig entryPaul Bolle
config SND_AOA_TOPAZ has been commented out since it was added five years ago with commit f3d9478b ("[...] add snd-aoa"). There's no indication why it's commented out. It might as well be removed. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-09-16Merge branch 'fix/misc' into topic/miscTakashi Iwai
2011-09-12ALSA: aoa: Remove obsolete cleanup for clientdataAxel Lin
The i2c core will clear the clientdata pointer automatically. We don't have to set the `data' field to NULL in remove() or if probe() failed anymore. Also remove a unneeded NULL checking for kfree. Signed-off-by: Axel Lin <axel.lin@gmail.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-20ALSA: sound/aoa/fabrics/layout.c: remove unneeded kfreeJulia Lawall
The label outnodev is only used when kzalloc has not yet taken place or has failed, so there is no need for the call for kfree under this label. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier x; expression E1!=0,E2,E3,E4; statement S; iterator I; @@ ( if (...) { ... when != kfree(x) when != x = E3 when != E3 = x * return ...; } ... when != x = E2 when != I(...,x,...) S if (...) { ... when != x = E4 kfree(x); ... return ...; } ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2010-12-13Merge branch 'topic/workq-update' into topic/miscTakashi Iwai
2010-12-13sound: don't use flush_scheduled_work()Tejun Heo
flush_scheduled_work() is deprecated and scheduled to be removed. * cancel[_delayed]_work() + flush_scheduled_work() -> cancel[_delayed]_work_sync(). * wm8350, wm8753 and soc-core use custom code to cancel a delayed work, execute it immediately if it was pending and wait for its completion. This is equivalent to flush_delayed_work_sync(). Use it instead. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-12-10ALSA: aoa: Remove wrong i2c_set_clientdata in onyx_i2c_remove()Axel Lin
It does not make sense to set clientdata to onyx in onyx_i2c_remove() as we are going to kfree onyx. What we really want here is i2c_set_clientdata(client, NULL); Since the i2c core will take care of it now, so this patch just removes it. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-02powerpc/macio: Fix probing of macio devices by using the right of match tableBenjamin Herrenschmidt
Grant patches added an of mach table to struct device_driver. However, while he changed the macio device code to use that, he left the match table pointer in struct macio_driver and didn't update drivers to use the "new" one, thus breaking the probing. This completes the change by moving all drivers to setup the "new" one, removing all traces of the old one, and while at it (since it changes the exact same locations), I also remove two other duplicates from struct driver which are the name and owner fields. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-05-22Merge remote branch 'origin' into secretlab/next-devicetreeGrant Likely
Merging in current state of Linus' tree to deal with merge conflicts and build failures in vio.c after merge. Conflicts: drivers/i2c/busses/i2c-cpm.c drivers/i2c/busses/i2c-mpc.c drivers/net/gianfar.c Also fixed up one line in arch/powerpc/kernel/vio.c to use the correct node pointer. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-22arch/powerpc: Move dma_mask from of_device into pdev_archdataGrant Likely
By moving dma_mask into pdev_archdata, and adding archdata to struct of_device, it makes it possible to substitute of_device with struct platform_device, which is a stepping stone to removing the of_platform bus entirely. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-18of: Always use 'struct device.of_node' to get device node pointer.Grant Likely
The following structure elements duplicate the information in 'struct device.of_node' and so are being eliminated. This patch makes all readers of these elements use device.of_node instead. (struct of_device *)->node (struct dev_archdata *)->prom_node (sparc) (struct dev_archdata *)->of_node (powerpc & microblaze) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-07powerpc/aoa: gpio-pmf.c: 3 * redundant coded binderman
Signed-off-by: David Binderman <dcb314@hotmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-28of: unify phandle name in struct device_nodeGrant Likely
In struct device_node, the phandle is named 'linux_phandle' for PowerPC and MicroBlaze, and 'node' for SPARC. There is no good reason for the difference, it is just an artifact of the code diverging over a couple of years. This patch renames both to simply .phandle. Note: the .node also existed in PowerPC/MicroBlaze, but the only user seems to be arch/powerpc/platforms/powermac/pfunc_core.c. It doesn't look like the assignment between .linux_phandle and .node is significantly different enough to warrant the separate code paths unless ibm,phandle properties actually appear in Apple device trees. I think it is safe to eliminate the old .node property and use phandle everywhere. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Tested-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-10-01ALSA: Don't assume i2c device probing always succeedsTakashi Iwai
The client->driver pointer can be NULL when i2c-device probing fails in i2c_new_device(). This patch adds the NULL checks for client->driver and return the error instead of blind assumption of driver availability. Reported-by: Tim Shepard <shep@alum.mit.edu> Cc: Jean Delvare <khali@linux-fr.org> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-07-31ALSA: sound/aoa: Add kmalloc NULL testsJulia Lawall
Check that the result of kzalloc is not NULL before a dereference. The semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ expression *x; identifier f; constant char *C; @@ x = \(kmalloc\|kcalloc\|kzalloc\)(...); ... when != x == NULL when != x != NULL when != (x || ...) ( kfree(x) | f(...,C,...,x,...) | *f(...,x,...) | *x->f ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-12sound: remove driver_data direct access of struct deviceGreg Kroah-Hartman
In the near future, the driver core is going to not allow direct access to the driver_data pointer in struct device. Instead, the functions dev_get_drvdata() and dev_set_drvdata() should be used. These functions have been around since the beginning, so are backwards compatible with all older kernel versions. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-04-21ALSA: AOA: Convert onyx and tas codecs to new-style i2c driversJean Delvare
The legacy i2c binding model is going away soon, so convert the AOA codec drivers to the new model or they'll break. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Johannes Berg <johannes@sipsolutions.net> Tested-by: Andreas Schwab <schwab@linux-m68k.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-24Merge branch 'topic/aoa' into for-linusTakashi Iwai
2009-01-15ALSA: snd-aoa: handle master-amp if presentJohannes Berg
Some machines have a master amp GPIO that needs to be toggled to get sound output, in addition to speaker/headphone/line-out amps. This makes snd-aoa handle it, if present in the device tree, thus making snd-aoa be able to output sound on PowerMac3,6, which was previously handled by snd-powermac which also doesn't use the master amp GPIO. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-15ALSA: snd-aoa: handle older machinesJohannes Berg
This patch changes snd-aoa to handle some older machines that are currently handled by snd-powermac. snd-aoa has a number of advantages though, notably it can autoload better and is generally a more modern driver. By hardcoding the accepted device-ids (last hunk of the patch) I'm trying to avoid regressions because this driver will otherwise load automatically and not let snd-powermac load. People who are unhappy with snd-powermac and have a device-id property in the device tree are encouraged to read this patch and make a patch to amend this as appropriate. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-01-12ALSA: Convert to snd_card_create() in other sound/*Takashi Iwai
Convert from snd_card_new() to the new snd_card_create() function in other sound subdirectories. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-12-25Merge branch 'topic/aoa' into to-pushTakashi Iwai
2008-11-03Merge branches 'topic/fix/misc' and 'topic/fix/hda' into for-linusTakashi Iwai
2008-11-03sound: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
[stripped sound/isa/* changes, replaced with the next patch -- tiwai] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-23Merge branches 'topic/asoc', 'topic/misc-fixes' and 'topic/hda' into for-linusTakashi Iwai
2008-10-23ALSA: aoa: clean up file namesJohannes Berg
This cleans up the apple onboard audio driver filenames. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-23ALSA: aoa i2sbus: don't overwrite module parameterJohannes Berg
We shouldn't modify a global variable here. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-15Merge commit 'origin'Benjamin Herrenschmidt
Manual fixup of conflicts on: arch/powerpc/include/asm/dcr-regs.h drivers/net/ibm_newemac/core.h
2008-08-25ALSA: aoa - Remove duplicate assignment of SNDRV_PCM_FMTBIT_S{16,24}_BE bitsRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-20powerpc/drivers: Use linux/of_device.h instead of asm/of_device.hStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-05-27sound: Convert to menuconfigTakashi Iwai
Convert menu in sound Kconfig files to menuconfig and if. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] aoa - fix compile warningTakashi Iwai
Set a proper error code in the error path of i2sbus_attach_codec(). Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] add number of periods constraint to snd-aoaHeikki Lindholm
The aoa driver is not specifying constraints on number of periods, and, it seems, it might end with a non-integer number, which it cannot deal with. Fix by adding a proper constraint. Signed-off-by: Heikki Lindholm <holindho@cs.helsinki.fi> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] aoa - Check value range in ctl callbacksTakashi Iwai
Check the value ranges in ctl put callbacks properly in aoa drivers. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] Clean up with common snd_ctl_boolean_*_info callbacksTakashi Iwai
Clean up codes using the new common snd_ctl_boolean_*_info() callbacks. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] Fix tas_suspend/resume build warningStephen Rothwell
sound/aoa/codecs/snd-aoa-codec-tas.c:750: warning: 'tas_suspend' defined but not used sound/aoa/codecs/snd-aoa-codec-tas.c:760: warning: 'tas_resume' defined but not used Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-20[ALSA] snd-aoa-codec-onyx: fix typoYoann Padioleau
Parse error in ifdef or bad use of macro. Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
