[ Upstream commit b836c4d29f2744200b2af41e14bf50758dddc818 ]
Commit 18b44bc5a672 ("ovl: Always reevaluate the file signature for
IMA") forced signature re-evaulation on every file access.
Instead of always re-evaluating the file's integrity, detect a change
to the backing file, by comparing the cached file metadata with the
backing file's metadata. Verifying just the i_version has not changed
is insufficient. In addition save and compare the i_ino and s_dev
as well.
Reviewed-by: Amir Goldstein <amir73il@gmail.com>
Tested-by: Eric Snowberg <eric.snowberg@oracle.com>
Tested-by: Raul E Rangel <rrangel@chromium.org>
Cc: stable@vger.kernel.org
Signed-off-by: Mimi Zohar <zohar@linux.ibm.com>
[ Upstream commit e044374a8a0a99e46f4e6d6751d3042b6d9cc12e ]
It is not clear that IMA should be nested at all, but as long is it
measures files both on overlayfs and on underlying fs, we need to
annotate the iint mutex to avoid lockdep false positives related to
IMA + overlayfs, same as overlayfs annotates the inode mutex.
Reported-and-tested-by: syzbot+b42fe626038981fb7bfa@syzkaller.appspotmail.com
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
commit 91e326563ee34509c35267808a4b1b3ea3db62a8 upstream.
Changing the direct dependencies of IMA_BLACKLIST_KEYRING and
IMA_LOAD_X509 caused them to no longer depend on IMA, but a
a configuration without IMA results in link failures:
arm-linux-gnueabi-ld: security/integrity/iint.o: in function `integrity_load_keys':
iint.c:(.init.text+0xd8): undefined reference to `ima_load_x509'
aarch64-linux-ld: security/integrity/digsig_asymmetric.o: in function `asymmetric_verify':
digsig_asymmetric.c:(.text+0x104): undefined reference to `ima_blacklist_keyring'
Adding explicit dependencies on IMA would fix this, but a more reliable
way to do this is to enclose the entire Kconfig file in an 'if IMA' block.
This also allows removing the existing direct dependencies.
Fixes: be210c6d3597f ("ima: Finish deprecation of IMA_TRUSTED_KEYRING Kconfig")
[ Upstream commit be210c6d3597faf330cb9af33b9f1591d7b2a983 ]
The removal of IMA_TRUSTED_KEYRING made IMA_LOAD_X509
and IMA_BLACKLIST_KEYRING unavailable because the latter
two depend on the former. Since IMA_TRUSTED_KEYRING was
deprecated in favor of INTEGRITY_TRUSTED_KEYRING use it
as a dependency for the two Kconfigs affected by the
deprecation.
Fixes: 5087fd9e80e5 ("ima: Remove deprecated IMA_TRUSTED_KEYRING Kconfig")
Signed-off-by: Oleksandr Tymoshenko <ovt@google.com>
Reviewed-by: Nayna Jain <nayna@linux.ibm.com>
[ Upstream commit 387ef964460f14fe1c1ea29aba70e22731ea7cf7 ]
Currently in "smack_inode_copy_up()" function, process label is
changed with the label on parent inode. Due to which,
process is assigned directory label and whatever file or directory
created by the process are also getting directory label
which is wrong label.
Changes has been done to use label of overlay inode instead
of parent inode.
Signed-off-by: Vishal Goel <vishal.goel@samsung.com>
Signed-off-by: Casey Schaufler <casey@schaufler-ca.com>
[ Upstream commit 3a3d8fce31a49363cc31880dce5e3b0617c9c38b ]
Enhance smack_inode_getsecurity() to retrieve the value for
SMACK64TRANSMUTE from the inode security blob, similarly to SMACK64.
This helps to display accurate values in the situation where the security
labels come from mount options and not from xattrs.
Signed-off-by: Roberto Sassu <roberto.sassu@huawei.com>
[ Upstream commit 2c085f3a8f23c9b444e8b99d93c15d7ce870fc4e ]
smack_dentry_create_files_as() determines whether transmuting should occur
based on the label of the parent directory the new inode will be added to,
and not the label of the directory where it is created.
This helps for example to do transmuting on overlayfs, since the latter
first creates the inode in the working directory, and then moves it to the
correct destination.
However, despite smack_dentry_create_files_as() provides the correct label,
smack_inode_init_security() does not know from passed information whether
or not transmuting occurred. Without this information,
smack_inode_init_security() cannot set SMK_INODE_CHANGED in smk_flags,
which will result in the SMACK64TRANSMUTE xattr not being set in
smack_d_instantiate().
Thus, add the smk_transmuted field to the task_smack structure, and set it
in smack_dentry_create_files_as() to smk_task if transmuting occurred. If
smk_task is equal to smk_transmuted in smack_inode_init_security(), act as
if transmuting was successful but without taking the label from the parent
directory (the inode label was already set correctly from the current
credentials in smack_inode_alloc_security()).
[ Upstream commit 3ad49d37cf5759c3b8b68d02e3563f633d9c1aee ]
There is a upper bound to "catlen" but no lower bound to prevent
negatives. I don't see that this necessarily causes a problem but we
may as well be safe.
Fixes: e114e473771c ("Smack: Simplified Mandatory Access Control Kernel")
Signed-off-by: Dan Carpenter <dan.carpenter@linaro.org>
[ Upstream commit 5087fd9e80e539d2163accd045b73da64de7de95 ]
Time to remove "IMA_TRUSTED_KEYRING".
Fixes: f4dc37785e9b ("integrity: define '.evm' as a builtin 'trusted' keyring") # v4.5+
Signed-off-by: Nayna Jain <nayna@linux.ibm.com>
[ Upstream commit 2d7f105edbb3b2be5ffa4d833abbf9b6965e9ce7 ]
If the current task fails the check for the queried capability via
`capable(CAP_SYS_ADMIN)` LSMs like SELinux generate a denial message.
Issuing such denial messages unnecessarily can lead to a policy author
granting more privileges to a subject than needed to silence them.
Reorder CAP_SYS_ADMIN checks after the check whether the operation is
actually privileged.
Signed-off-by: Christian Göttsche <cgzones@googlemail.com>
Reviewed-by: Jarkko Sakkinen <jarkko@kernel.org>
Signed-off-by: Jarkko Sakkinen <jarkko@kernel.org>
[ Upstream commit 644f17412f5acf01a19af9d04a921937a2bc86c6 ]
UML supports HAS_IOMEM since 0bbadafdc49d (um: allow disabling
NO_IOMEM).
Current IMA build on UML fails on allmodconfig (with TCG_TPM=m):
ld: security/integrity/ima/ima_queue.o: in function `ima_add_template_entry':
ima_queue.c:(.text+0x2d9): undefined reference to `tpm_pcr_extend'
ld: security/integrity/ima/ima_init.o: in function `ima_init':
ima_init.c:(.init.text+0x43f): undefined reference to `tpm_default_chip'
ld: security/integrity/ima/ima_crypto.o: in function `ima_calc_boot_aggregate_tfm':
ima_crypto.c:(.text+0x1044): undefined reference to `tpm_pcr_read'
ld: ima_crypto.c:(.text+0x10d8): undefined reference to `tpm_pcr_read'
Modify the IMA Kconfig entry so that it selects TCG_TPM if HAS_IOMEM
is set, regardless of the UML Kconfig setting.
This updates TCG_TPM from =m to =y and fixes the linker errors.
Fixes: f4a0391dfa91 ("ima: fix Kconfig dependencies")
Cc: Stable <stable@vger.kernel.org> # v5.14+
Cc: Fabio Estevam <festevam@gmail.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Anton Ivanov <anton.ivanov@cambridgegreys.com>
Cc: Johannes Berg <johannes@sipsolutions.net>
Cc: linux-um@lists.infradead.org
[ Upstream commit d55901522f96082a43b9842d34867363c0cdbac5 ]
When making a DNS query inside the kernel using dns_query(), the request
code can in rare cases end up creating a duplicate index key in the
assoc_array of the destination keyring. It is eventually found by
a BUG_ON() check in the assoc_array implementation and results in
a crash.
Example report:
[2158499.700025] kernel BUG at ../lib/assoc_array.c:652!
[2158499.700039] invalid opcode: 0000 [#1] SMP PTI
[2158499.700065] CPU: 3 PID: 31985 Comm: kworker/3:1 Kdump: loaded Not tainted 5.3.18-150300.59.90-default #1 SLE15-SP3
[2158499.700096] Hardware name: VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform, BIOS 6.00 11/12/2020
[2158499.700351] Workqueue: cifsiod cifs_resolve_server [cifs]
[2158499.700380] RIP: 0010:assoc_array_insert+0x85f/0xa40
[2158499.700401] Code: ff 74 2b 48 8b 3b 49 8b 45 18 4c 89 e6 48 83 e7 fe e8 95 ec 74 00 3b 45 88 7d db 85 c0 79 d4 0f 0b 0f 0b 0f 0b e8 41 f2 be ff <0f> 0b 0f 0b 81 7d 88 ff ff ff 7f 4c 89 eb 4c 8b ad 58 ff ff ff 0f
[2158499.700448] RSP: 0018:ffffc0bd6187faf0 EFLAGS: 00010282
[2158499.700470] RAX: ffff9f1ea7da2fe8 RBX: ffff9f1ea7da2fc1 RCX: 0000000000000005
[2158499.700492] RDX: 0000000000000000 RSI: 0000000000000005 RDI: 0000000000000000
[2158499.700515] RBP: ffffc0bd6187fbb0 R08: ffff9f185faf1100 R09: 0000000000000000
[2158499.700538] R10: ffff9f1ea7da2cc0 R11: 000000005ed8cec8 R12: ffffc0bd6187fc28
[2158499.700561] R13: ffff9f15feb8d000 R14: ffff9f1ea7da2fc0 R15: ffff9f168dc0d740
[2158499.700585] FS: 0000000000000000(0000) GS:ffff9f185fac0000(0000) knlGS:0000000000000000
[2158499.700610] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[2158499.700630] CR2: 00007fdd94fca238 CR3: 0000000809d8c006 CR4: 00000000003706e0
[2158499.700702] Call Trace:
[2158499.700741] ? key_alloc+0x447/0x4b0
[2158499.700768] ? __key_link_begin+0x43/0xa0
[2158499.700790] __key_link_begin+0x43/0xa0
[2158499.700814] request_key_and_link+0x2c7/0x730
[2158499.700847] ? dns_resolver_read+0x20/0x20 [dns_resolver]
[2158499.700873] ? key_default_cmp+0x20/0x20
[2158499.700898] request_key_tag+0x43/0xa0
[2158499.700926] dns_query+0x114/0x2ca [dns_resolver]
[2158499.701127] dns_resolve_server_name_to_ip+0x194/0x310 [cifs]
[2158499.701164] ? scnprintf+0x49/0x90
[2158499.701190] ? __switch_to_asm+0x40/0x70
[2158499.701211] ? __switch_to_asm+0x34/0x70
[2158499.701405] reconn_set_ipaddr_from_hostname+0x81/0x2a0 [cifs]
[2158499.701603] cifs_resolve_server+0x4b/0xd0 [cifs]
[2158499.701632] process_one_work+0x1f8/0x3e0
[2158499.701658] worker_thread+0x2d/0x3f0
[2158499.701682] ? process_one_work+0x3e0/0x3e0
[2158499.701703] kthread+0x10d/0x130
[2158499.701723] ? kthread_park+0xb0/0xb0
[2158499.701746] ret_from_fork+0x1f/0x40
The situation occurs as follows:
* Some kernel facility invokes dns_query() to resolve a hostname, for
example, "abcdef". The function registers its global DNS resolver
cache as current->cred.thread_keyring and passes the query to
request_key_net() -> request_key_tag() -> request_key_and_link().
* Function request_key_and_link() creates a keyring_search_context
object. Its match_data.cmp method gets set via a call to
type->match_preparse() (resolves to dns_resolver_match_preparse()) to
dns_resolver_cmp().
* Function request_key_and_link() continues and invokes
search_process_keyrings_rcu() which returns that a given key was not
found. The control is then passed to request_key_and_link() ->
construct_alloc_key().
* Concurrently to that, a second task similarly makes a DNS query for
"abcdef." and its result gets inserted into the DNS resolver cache.
* Back on the first task, function construct_alloc_key() first runs
__key_link_begin() to determine an assoc_array_edit operation to
insert a new key. Index keys in the array are compared exactly as-is,
using keyring_compare_object(). The operation finds that "abcdef" is
not yet present in the destination keyring.
* Function construct_alloc_key() continues and checks if a given key is
already present on some keyring by again calling
search_process_keyrings_rcu(). This search is done using
dns_resolver_cmp() and "abcdef" gets matched with now present key
"abcdef.".
* The found key is linked on the destination keyring by calling
__key_link() and using the previously calculated assoc_array_edit
operation. This inserts the "abcdef." key in the array but creates
a duplicity because the same index key is already present.
Fix the problem by postponing __key_link_begin() in
construct_alloc_key() until an actual key which should be linked into
the destination keyring is determined.
[jarkko@kernel.org: added a fixes tag and cc to stable]
Cc: stable@vger.kernel.org # v5.3+
Fixes: df593ee23e05 ("keys: Hoist locking out of __key_link_begin()")
Signed-off-by: Petr Pavlu <petr.pavlu@suse.com>
Reviewed-by: Joey Lee <jlee@suse.com>
commit 9df6a4870dc371136e90330cfbbc51464ee66993 upstream.
When integrity_inode_get() is querying and inserting the cache, there
is a conditional race in the concurrent environment.
The race condition is the result of not properly implementing
"double-checked locking". In this case, it first checks to see if the
iint cache record exists before taking the lock, but doesn't check
again after taking the integrity_iint_lock.
Fixes: bf2276d10ce5 ("ima: allocating iint improvements")
Signed-off-by: Tianjia Zhang <tianjia.zhang@linux.alibaba.com>
Cc: Dmitry Kasatkin <dmitry.kasatkin@gmail.com>
Cc: <stable@vger.kernel.org> # v3.10+
[ Upstream commit 95526d13038c2bbddd567a4d8e39fac42484e182 ]
Fix build warnings (function parameters description) for
ima_collect_modsig(), ima_match_policy() and ima_parse_add_rule().
Fixes: 15588227e086 ("ima: Collect modsig") # v5.4+
Fixes: 2fe5d6def167 ("ima: integrity appraisal extension") # v5.14+
Fixes: 4af4662fa4a9 ("integrity: IMA policy") # v3.2+
[ Upstream commit b1de86d4248b273cb12c4cd7d20c08d459519f7d ]
Add the description for missing parameters of evm_inode_setattr() to
avoid the warning arising with W=n compile option.
Fixes: 817b54aa45db ("evm: add evm_inode_setattr to prevent updating an invalid security.evm") # v3.2+
Fixes: c1632a0f1120 ("fs: port ->setattr() to pass mnt_idmap") # v6.3+
Reviewed-by: Stefan Berger <stefanb@linux.ibm.com>
commit 42c4e97e06a839b07d834f640a10911ad84ec8b3 upstream.
The Linux Kernel currently only requires make v3.82 while the grouped
target functionality requires make v4.3. Removed the grouped target
introduced in 4ce1f694eb5d ("selinux: ensure av_permissions.h is
built when needed") as well as the multiple header file targets in
the make rule. This effectively reverts the problem commit.
We will revisit this change when make >= 4.3 is required by the rest
of the kernel.
Fixes: 4ce1f694eb5d ("selinux: ensure av_permissions.h is built when needed")
Reported-by: Erwan Velu <e.velu@criteo.com>
Reported-by: Luiz Capitulino <luizcap@amazon.com>
Tested-by: Luiz Capitulino <luizcap@amazon.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 4ce1f694eb5d8ca607fed8542d32a33b4f1217a5 ]
The Makefile rule responsible for building flask.h and
av_permissions.h only lists flask.h as a target which means that
av_permissions.h is only generated when flask.h needs to be
generated. This patch fixes this by adding av_permissions.h as a
target to the rule.
Fixes: 8753f6bec352 ("selinux: generate flask headers during kernel build")
[ Upstream commit bcab1adeaad4b39a1e04cb98979a367d08253f03 ]
Make the flask.h target depend on the genheaders binary instead of
classmap.h to ensure that it is rebuilt if any of the dependencies of
genheaders are changed.
Notably this fixes flask.h not being rebuilt when
initial_sid_to_string.h is modified.
Signed-off-by: Ondrej Mosnacek <omosnace@redhat.com>
Acked-by: Stephen Smalley <stephen.smalley.work@gmail.com>
[ Upstream commit 47f9e4c924025c5be87959d3335e66fcbb7f6b5c ]
The key which gets cached in task structure from a kernel thread does not
get invalidated even after expiry. Due to which, a new key request from
kernel thread will be served with the cached key if it's present in task
struct irrespective of the key validity. The change is to not cache key in
task_struct when key requested from kernel thread so that kernel thread
gets a valid key on every key request.
The problem has been seen with the cifs module doing DNS lookups from a
kernel thread and the results getting pinned by being attached to that
kernel thread's cache - and thus not something that can be easily got rid
of. The cache would ordinarily be cleared by notify-resume, but kernel
threads don't do that.
This isn't seen with AFS because AFS is doing request_key() within the
kernel half of a user thread - which will do notify-resume.
Fixes: 7743c48e54ee ("keys: Cache result of request_key*() temporarily in task_struct")
Signed-off-by: Bharath SM <bharathsm@microsoft.com>
cc: Shyam Prasad N <nspmangalore@gmail.com>
cc: Steve French <smfrench@gmail.com>
cc: keyrings@vger.kernel.org
cc: linux-cifs@vger.kernel.org
cc: linux-fsdevel@vger.kernel.org
Link: https://lore.kernel.org/r/CAGypqWw951d=zYRbdgNR4snUDvJhWL=q3=WOyh7HhSJupjz2vA@mail.gmail.com/
commit 4971c268b85e1c7a734a61622fc0813c86e2362e upstream.
Commit 98de59bfe4b2f ("take calculation of final prot in
security_mmap_file() into a helper") moved the code to update prot, to be
the actual protections applied to the kernel, to a new helper called
mmap_prot().
However, while without the helper ima_file_mmap() was getting the updated
prot, with the helper ima_file_mmap() gets the original prot, which
contains the protections requested by the application.
A possible consequence of this change is that, if an application calls
mmap() with only PROT_READ, and the kernel applies PROT_EXEC in addition,
that application would have access to executable memory without having this
event recorded in the IMA measurement list. This situation would occur for
example if the application, before mmap(), calls the personality() system
call with READ_IMPLIES_EXEC as the first argument.
Align ima_file_mmap() parameters with those of the mmap_file LSM hook, so
that IMA can receive both the requested prot and the final prot. Since the
requested protections are stored in a new variable, and the final
protections are stored in the existing variable, this effectively restores
the original behavior of the MMAP_CHECK hook.
Fixes: 98de59bfe4b2 ("take calculation of final prot in security_mmap_file() into a helper")
[ Upstream commit eaf2213ba563b2d74a1f2c13a6b258273f689802 ]
If *.conf.default is updated, builtin-policy.h should be rebuilt,
but this does not work when compiled with O= option.
[Without this commit]
$ touch security/tomoyo/policy/exception_policy.conf.default
$ make O=/tmp security/tomoyo/
make[1]: Entering directory '/tmp'
GEN Makefile
CALL /home/masahiro/ref/linux/scripts/checksyscalls.sh
DESCEND objtool
make[1]: Leaving directory '/tmp'
[With this commit]
GEN Makefile
DESCEND objtool
POLICY security/tomoyo/builtin-policy.h
CC security/tomoyo/common.o
AR security/tomoyo/built-in.a
$(srctree)/ is essential because $(wildcard ) does not follow VPATH.
Fixes: f02dee2d148b ("tomoyo: Do not generate empty policy files")
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
commit e68bfbd3b3c3a0ec3cf8c230996ad8cabe90322f upstream.
When add the 'a *:* rwm' entry to devcgroup A's whitelist, at first A's
exceptions will be cleaned and A's behavior is changed to
DEVCG_DEFAULT_ALLOW. Then parent's exceptions will be copyed to A's
whitelist. If copy failure occurs, just return leaving A to grant
permissions to all devices. And A may grant more permissions than
parent.
Backup A's whitelist and recover original exceptions after copy
failure.
Fixes: 4cef7299b478 ("device_cgroup: add proper checking when changing default behavior")
Signed-off-by: Wang Weiyang <wangweiyang2@huawei.com>
Reviewed-by: Aristeu Rozanski <aris@redhat.com>
commit 11220db412edae8dba58853238f53258268bdb88 upstream.
In restore_template_fmt, when kstrdup fails, a non-NULL value will still be
returned, which causes a NULL pointer access in template_desc_init_fields.
Fixes: c7d09367702e ("ima: support restoring multiple template formats")
Cc: stable@kernel.org
Co-developed-by: Jiaming Li <lijiaming30@huawei.com>
Signed-off-by: Jiaming Li <lijiaming30@huawei.com>
Signed-off-by: Huaxin Lu <luhuaxin1@huawei.com>
commit 0be56a116220f9e5731a6609e66a11accfe8d8e2 upstream.
The iMac Pro 2017 is also a T2 Mac. Thus add it to the list of uefi skip
cert.
Fixes: 155ca952c7ca ("efi: Do not import certificates from UEFI Secure Boot for T2 Macs")
Link: https://lore.kernel.org/linux-integrity/9D46D92F-1381-4F10-989C-1A12CD2FFDD8@live.com/
Signed-off-by: Aditya Garg <gargaditya08@live.com>
[ Upstream commit 37923d4321b1e38170086da2c117f78f2b0f49c6 ]
According to the implementations of cred_label() and set_cred_label(),
we should use pointer to struct aa_label for lbs_cred instead of struct
aa_task_ctx, this patch fixes it.
Fixes: bbd3662a8348 ("Infrastructure management of the cred security blob")
Signed-off-by: Xiu Jianfeng <xiujianfeng@huawei.com>
Signed-off-by: John Johansen <john.johansen@canonical.com>
[ Upstream commit 1b5a6198f5a9d0aa5497da0dc4bcd4fc166ee516 ]
The v8 abi is supported by the kernel but the userspace supported
version check does not allow for it. This was missed when v8 was added
due to a bug in the userspace compiler which was setting an older abi
version for v8 encoding (which is forward compatible except on the
network encoding). However it is possible to detect the network
encoding by checking the policydb network support which the code
does. The end result was that missing the abi flag worked until
userspace was fixed and began correctly checking for the v8 abi
version.
Fixes: 56974a6fcfef ("apparmor: add base infastructure for socket mediation")
[ Upstream commit 9c4557efc558a68e4cd973490fd936d6e3414db8 ]
Fix the following lockdep warning
[ 1119.158984] ============================================
[ 1119.158988] WARNING: possible recursive locking detected
[ 1119.158996] 6.0.0-rc1+ #257 Tainted: G E N
[ 1119.158999] --------------------------------------------
[ 1119.159001] bash/80100 is trying to acquire lock:
[ 1119.159007] ffff88803e79b4a0 (&ns->lock/1){+.+.}-{4:4}, at: destroy_ns.part.0+0x43/0x140
[ 1119.159028]
but task is already holding lock:
[ 1119.159030] ffff8881009764a0 (&ns->lock/1){+.+.}-{4:4}, at: aa_remove_profiles+0x3f0/0x640
[ 1119.159040]
[ 1119.159042] Possible unsafe locking scenario:
[ 1119.159043] CPU0
[ 1119.159045] ----
[ 1119.159047] lock(&ns->lock/1);
[ 1119.159051] lock(&ns->lock/1);
[ 1119.159055]
*** DEADLOCK ***
Which is caused by an incorrect lockdep nesting notation
Fixes: feb3c766a3ab ("apparmor: fix possible recursive lock warning in __aa_create_ns")
[ Upstream commit c73275cf6834787ca090317f1d20dbfa3b7f05aa ]
In multi_transaction_new(), the variable t is not freed or passed out
on the failure of copy_from_user(t->data, buf, size), which could lead
to a memleak.
Fix this bug by adding a put_multi_transaction(t) in the error path.
Fixes: 1dea3b41e84c5 ("apparmor: speed up transactional queries")
Signed-off-by: Gaosheng Cui <cuigaosheng1@huawei.com>
[ Upstream commit 25369175ce84813dd99d6604e710dc2491f68523 ]
The input parameter @fields is type of struct ima_template_field ***, so
when allocates array memory for @fields, the size of element should be
sizeof(**field) instead of sizeof(*field).
Actually the original code would not cause any runtime error, but it's
better to make it logically right.
Fixes: adf53a778a0a ("ima: new templates management mechanism")
Reviewed-by: Roberto Sassu <roberto.sassu@huawei.com>
[ Upstream commit 39419ef7af0916cc3620ecf1ed42d29659109bf3 ]
Key restriction is allocated in integrity_init_keyring(). However, if
keyring allocation failed, it is not freed, causing memory leaks.
Fixes: 2b6aa412ff23 ("KEYS: Use structure to capture key restriction function and data")
Signed-off-by: GUO Zihua <guozihua@huawei.com>
[ Upstream commit c7423dbdbc9ecef7fff5239d144cad4b9887f4de ]
IMA relies on the blocking LSM policy notifier callback to update the
LSM based IMA policy rules.
When SELinux update its policies, IMA would be notified and starts
updating all its lsm rules one-by-one. During this time, -ESTALE would
be returned by ima_filter_rule_match() if it is called with a LSM rule
that has not yet been updated. In ima_match_rules(), -ESTALE is not
handled, and the LSM rule is considered a match, causing extra files
to be measured by IMA.
Fix it by re-initializing a temporary rule if -ESTALE is returned by
ima_filter_rule_match(). The origin rule in the rule list would be
updated by the LSM policy notifier callback.
Fixes: b16942455193 ("ima: use the lsm policy update notifier")
[ Upstream commit 28073eb09c5aa29e879490edb88cfd3e7073821e ]
In preparation to enable -Wimplicit-fallthrough for Clang, fix multiple
warnings by explicitly adding multiple break statements instead of just
letting the code fall through to the next case.
Link: https://github.com/KSPP/linux/issues/115
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
Stable-dep-of: c7423dbdbc9e ("ima: Handle -ESTALE returned by ima_filter_rule_match()")
[ Upstream commit b8867eedcf76caef8ae6412da97cd9abfd092ff8 ]
Rename IMA's internal filter rule functions from security_filter_rule_*()
to ima_filter_rule_*(). This avoids polluting the security_* namespace,
which is typically reserved for general security subsystem
infrastructure.
Signed-off-by: Tyler Hicks <tyhicks@linux.microsoft.com>
Suggested-by: Casey Schaufler <casey@schaufler-ca.com>
[zohar@linux.ibm.com: reword using the term "filter", not "audit"]
commit 8cf0a1bc12870d148ae830a4ba88cfdf0e879cee upstream.
In cap_inode_getsecurity(), we will use vfs_getxattr_alloc() to
complete the memory allocation of tmpbuf, if we have completed
the memory allocation of tmpbuf, but failed to call handler->get(...),
there will be a memleak in below logic:
|-- ret = (int)vfs_getxattr_alloc(mnt_userns, ...)
| /* ^^^ alloc for tmpbuf */
|-- value = krealloc(*xattr_value, error + 1, flags)
| /* ^^^ alloc memory */
|-- error = handler->get(handler, ...)
| /* error! */
|-- *xattr_value = value
| /* xattr_value is &tmpbuf (memory leak!) */
So we will try to free(tmpbuf) after vfs_getxattr_alloc() fails to fix it.
Fixes: 8db6c34f1dbc ("Introduce v3 namespaced file capabilities")
Acked-by: Serge Hallyn <serge@hallyn.com>
[PM: subject line and backtrace tweaks]
commit bab715bdaa9ebf28d99a6d1efb2704a30125e96d upstream.
It turns out Apple doesn't capitalise the "mini" in "Macmini" in DMI, which
is inconsistent with other model line names.
Correct the capitalisation of Macmini in the quirk for skipping loading
platform certs on T2 Macs.
Currently users get:
[Firmware Bug]: Page fault caused by firmware at PA: 0xffffa30640054000
WARNING: CPU: 1 PID: 8 at arch/x86/platform/efi/quirks.c:735 efi_crash_gracefully_on_page_fault+0x55/0xe0
Modules linked in:
CPU: 1 PID: 8 Comm: kworker/u12:0 Not tainted 5.18.14-arch1-2-t2 #1 4535eb3fc40fd08edab32a509fbf4c9bc52d111e
Hardware name: Apple Inc. Macmini8,1/Mac-7BA5B2DFE22DDD8C, BIOS 1731.120.10.0.0 (iBridge: 19.16.15071.0.0,0) 04/24/2022
Workqueue: efi_rts_wq efi_call_rts
---[ end trace 0000000000000000 ]---
efi: Froze efi_rts_wq and disabled EFI Runtime Services
integrity: Couldn't get size: 0x8000000000000015
integrity: MODSIGN: Couldn't get UEFI db list
efi: EFI Runtime Services are disabled!
integrity: Couldn't get UEFI dbx list
Cc: Aditya Garg <gargaditya08@live.com>
Tested-by: Samuel Jiang <chyishian.jiang@gmail.com>
Signed-off-by: Orlando Chamberlain <redecorating@protonmail.com>
commit 417ea9fe972d2654a268ad66e89c8fcae67017c3 upstream.
When copy_from_user failed, the memory is freed by kvfree. however the
management struct and data blob are allocated independently, so only
kvfree(data) cause a memleak issue here. Use aa_put_loaddata(data) to
fix this issue.
Fixes: a6a52579e52b5 ("apparmor: split load data into management struct and data blob")
commit 11c3627ec6b56c1525013f336f41b79a983b4d46 upstream.
The aa_pivotroot() function has a reference counting bug in a specific
path. When aa_replace_current_label() returns on success, the function
forgets to decrement the reference count of “target”, which is
increased earlier by build_pivotroot(), causing a reference leak.
Fix it by decreasing the refcount of “target” in that path.
Fixes: 2ea3ffb7782a ("apparmor: add mount mediation")
Co-developed-by: Xiyu Yang <xiyuyang19@fudan.edu.cn>
Signed-off-by: Xiyu Yang <xiyuyang19@fudan.edu.cn>
Co-developed-by: Xin Tan <tanxin.ctf@gmail.com>
Signed-off-by: Xin Tan <tanxin.ctf@gmail.com>
Signed-off-by: Xin Xiong <xiongx18@fudan.edu.cn>
commit 2504db207146543736e877241f3b3de005cbe056 upstream.
When finding the profile via patterned attachments, the longest left
match is being set to the static compile time value and not using the
runtime computed value.
Fix this by setting the candidate value to the greater of the
precomputed value or runtime computed value.
Fixes: 21f606610502 ("apparmor: improve overlapping domain attachment resolution")
commit 3e2a3a0830a2090e766d0d887d52c67de2a6f323 upstream.
Clang static analysis reports this issue
label.c:1802:3: warning: 2nd function call argument
is an uninitialized value
pr_info("%s", str);
str is set from a successful call to aa_label_asxprint(&str, ...)
On failure a negative value is returned, not a -1. So change
the check.
Fixes: f1bd904175e8 ("apparmor: add the base fns() for domain labels")
Signed-off-by: Tom Rix <trix@redhat.com>
commit ec240b5905bbb09a03dccffee03062cf39e38dc2 upstream.
When the mount check fails due to a permission check failure instead
of explicitly at one of the subcomponent checks, AppArmor is reporting
a failure in the flags match. However this is not true and AppArmor
can not attribute the error at this point to any particular component,
and should only indicate the mount failed due to missing permissions.
commit 511f7b5b835726e844a5fc7444c18e4b8672edfd upstream.
AppArmor is prefixing secids that are converted to secctx with the =
to indicate the secctx should only be parsed from an absolute root
POV. This allows catching errors where secctx are reparsed back into
internal labels.
Unfortunately because audit is using secid to secctx conversion this
means that subject and object labels can result in a very unfortunate
== that can break audit parsing.
eg. the subj==unconfined term in the below audit message
type=USER_LOGIN msg=audit(1639443365.233:160): pid=1633 uid=0 auid=1000
ses=3 subj==unconfined msg='op=login id=1000 exe="/usr/sbin/sshd"
hostname=192.168.122.1 addr=192.168.122.1 terminal=/dev/pts/1 res=success'
Fix this by switch the prepending of = to a _. This still works as a
special character to flag this case without breaking audit. Also move
this check behind debug as it should not be needed during normal
operqation.
Fixes: 26b7899510ae ("apparmor: add support for absolute root view based labels")
Reported-by: Casey Schaufler <casey@schaufler-ca.com>
commit 68ff8540cc9e4ab557065b3f635c1ff4c96e1f1c upstream.
Global quieting of denied AppArmor generated file events is not
handled correctly. Unfortunately the is checking if quieting of all
audit events is set instead of just denied events.
Fixes: 67012e8209df ("AppArmor: basic auditing infrastructure.")
[ Upstream commit 15ec76fb29be31df2bccb30fc09875274cba2776 ]
Just like next_entry(), boundary check is necessary to prevent memory
out-of-bound access.
[ Upstream commit 891163adf180bc369b2f11c9dfce6d2758d2a5bd ]
The original 'ima' measurement list template contains a hash, defined
as 20 bytes, and a null terminated pathname, limited to 255
characters. Other measurement list templates permit both larger hashes
and longer pathnames. When the "ima" template is configured as the
default, a new measurement list template (ima_template=) must be
specified before specifying a larger hash algorithm (ima_hash=) on the
boot command line.
To avoid this boot command line ordering issue, remove the legacy "ima"
template configuration option, allowing it to still be specified on the
boot command line.
The root cause of this issue is that during the processing of ima_hash,
we would try to check whether the hash algorithm is compatible with the
template. If the template is not set at the moment we do the check, we
check the algorithm against the configured default template. If the
default template is "ima", then we reject any hash algorithm other than
sha1 and md5.
For example, if the compiled default template is "ima", and the default
algorithm is sha1 (which is the current default). In the cmdline, we put
in "ima_hash=sha256 ima_template=ima-ng". The expected behavior would be
that ima starts with ima-ng as the template and sha256 as the hash
algorithm. However, during the processing of "ima_hash=",
"ima_template=" has not been processed yet, and hash_setup would check
the configured hash algorithm against the compiled default: ima, and
reject sha256. So at the end, the hash algorithm that is actually used
will be sha1.
With template "ima" removed from the configured default, we ensure that
the default tempalte would at least be "ima-ng" which allows for
basically any hash algorithm.
This change would not break the algorithm compatibility checks for IMA.
Fixes: 4286587dccd43 ("ima: add Kconfig default measurement list template")
Cc: <Stable@vger.kernel.org>
commit 543ce63b664e2c2f9533d089a4664b559c3e6b5b upstream.
The lockdown LSM is primarily used in conjunction with UEFI Secure Boot.
This LSM may also be used on machines without UEFI. It can also be
enabled when UEFI Secure Boot is disabled. One of lockdown's features
is to prevent kexec from loading untrusted kernels. Lockdown can be
enabled through a bootparam or after the kernel has booted through
securityfs.
If IMA appraisal is used with the "ima_appraise=log" boot param,
lockdown can be defeated with kexec on any machine when Secure Boot is
disabled or unavailable. IMA prevents setting "ima_appraise=log" from
the boot param when Secure Boot is enabled, but this does not cover
cases where lockdown is used without Secure Boot.
To defeat lockdown, boot without Secure Boot and add ima_appraise=log to
the kernel command line; then:
$ echo "integrity" > /sys/kernel/security/lockdown
$ echo "appraise func=KEXEC_KERNEL_CHECK appraise_type=imasig" > \
/sys/kernel/security/ima/policy
$ kexec -ls unsigned-kernel
Add a call to verify ima appraisal is set to "enforce" whenever lockdown
is enabled. This fixes CVE-2022-21505.
Fixes: 29d3c1c8dfe7 ("kexec: Allow kexec_file() with appropriate IMA policy when locked down")
Signed-off-by: Eric Snowberg <eric.snowberg@oracle.com>
Acked-by: Mimi Zohar <zohar@linux.ibm.com>
Reviewed-by: John Haxby <john.haxby@oracle.com>
[ Upstream commit d2ee2cfc4aa85ff6a2a3b198a3a524ec54e3d999 ]
When the ima-modsig is enabled, the rc passed to evm_verifyxattr() may be
negative, which may cause the integer overflow problem.
Fixes: 39b07096364a ("ima: Implement support for module-style appended signatures")
commit 51dd64bb99e4478fc5280171acd8e1b529eadaf7 upstream.
This reverts commit ccf11dbaa07b328fa469415c362d33459c140a37.
Commit ccf11dbaa07b ("evm: Fix memleak in init_desc") said there is
memleak in init_desc. That may be incorrect, as we can see, tmp_tfm is
saved in one of the two global variables hmac_tfm or evm_tfm[hash_algo],
then if init_desc is called next time, there is no need to alloc tfm
again, so in the error path of kmalloc desc or crypto_shash_init(desc),
It is not a problem without freeing tmp_tfm.
And also that commit did not reset the global variable to NULL after
freeing tmp_tfm and this makes *tfm a dangling pointer which may cause a
UAF issue.
Reported-by: Guozihua (Scott) <guozihua@huawei.com>
commit 155ca952c7ca19aa32ecfb7373a32bbc2e1ec6eb upstream.
On Apple T2 Macs, when Linux attempts to read the db and dbx efi variables
at early boot to load UEFI Secure Boot certificates, a page fault occurs
in Apple firmware code and EFI runtime services are disabled with the
following logs:
[Firmware Bug]: Page fault caused by firmware at PA: 0xffffb1edc0068000
WARNING: CPU: 3 PID: 104 at arch/x86/platform/efi/quirks.c:735 efi_crash_gracefully_on_page_fault+0x50/0xf0
(Removed some logs from here)
Call Trace:
<TASK>
page_fault_oops+0x4f/0x2c0
? search_bpf_extables+0x6b/0x80
? search_module_extables+0x50/0x80
? search_exception_tables+0x5b/0x60
kernelmode_fixup_or_oops+0x9e/0x110
__bad_area_nosemaphore+0x155/0x190
bad_area_nosemaphore+0x16/0x20
do_kern_addr_fault+0x8c/0xa0
exc_page_fault+0xd8/0x180
asm_exc_page_fault+0x1e/0x30
? __efi_call+0x28/0x30
? switch_mm+0x20/0x30
? efi_call_rts+0x19a/0x8e0
? process_one_work+0x222/0x3f0
? worker_thread+0x4a/0x3d0
? kthread+0x17a/0x1a0
? process_one_work+0x3f0/0x3f0
? set_kthread_struct+0x40/0x40
? ret_from_fork+0x22/0x30
</TASK>
---[ end trace 1f82023595a5927f ]---
integrity: Couldn't get mokx list
So we avoid reading these UEFI variables and thus prevent the crash.
Reviewed-by: Mimi Zohar <zohar@linux.ibm.com>
commit eadb2f47a3ced5c64b23b90fd2a3463f63726066 upstream.
KGDB and KDB allow read and write access to kernel memory, and thus
should be restricted during lockdown. An attacker with access to a
serial port (for example, via a hypervisor console, which some cloud
vendors provide over the network) could trigger the debugger so it is
important that the debugger respect the lockdown mode when/if it is
triggered.
Fix this by integrating lockdown into kdb's existing permissions
mechanism. Unfortunately kgdb does not have any permissions mechanism
(although it certainly could be added later) so, for now, kgdb is simply
and brutally disabled by immediately exiting the gdb stub without taking
any action.
For lockdowns established early in the boot (e.g. the normal case) then
this should be fine but on systems where kgdb has set breakpoints before
the lockdown is enacted than "bad things" will happen.
CVE: CVE-2022-21499
Co-developed-by: Stephen Brennan <stephen.s.brennan@oracle.com>
Signed-off-by: Stephen Brennan <stephen.s.brennan@oracle.com>
Reviewed-by: Douglas Anderson <dianders@chromium.org>
Signed-off-by: Daniel Thompson <daniel.thompson@linaro.org>
[ Upstream commit a5cd1ab7ab679d252a6d2f483eee7d45ebf2040c ]
Remove inappropriate use of ntohs() and assign the
port value directly.
Reported-by: kernel test robot <lkp@intel.com>
