path: root/scripts/coccicheck
2013-04-08Coccinelle: Fix patch output when coccicheck is used with M= and C=Nicolas Palix
When the M variable is used, the -patch option should be given to spatch. This patch fixes the case where C is used. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08Coccinelle: Add support to the SPFLAGS variableNicolas Palix
The SPFLAGS variable allows to pass additional options to spatch, e.g. -use_glimpse. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08Coccinelle: Cleanup the setting of the FLAGS and OPTIONS variablesNicolas Palix
The FLAGS variable is factorized independently of the ONLINE mode. The OPTIONS variable is now based on LINUXINCLUDE and explicit includes are thus removed. The format of the -I option differs between gcc and spatch. The COCCIINCLUDE is used to adapt the format. This rewritting needs bash. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-04-08Coccinelle: Restore coccicheck verbosity in ONLINE mode (C=1 or C=2)Nicolas Palix
A recent patch have introduce the VERBOSE variable and comments now depend on it. However, the message printed for each cocci file such not be printed when the ONLINE mode is active, whatever is the value of VERBOSE. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22coccicheck: Allow to show the executed command lineBernd Schubert
On my system one of the tests failed with "Fatal error: exception Failure("No OCaml compiler found! Install either ocamlopt or ocamlopt.opt")". Investigating such issues is easier if the executed command line is being shown. Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> CC: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2013-02-22coccicheck: Allow the user to give a V= (verbose) argumentBernd Schubert
Do not run with verbosity on/off depending on the ONLINE variable, which gets set with C=1 or C=2, but allow the user to set the verbosity using kernel default make V= paramemter. Verbosity is off by default now. Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> CC: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-10-11coccicheck: Add the rep+ctxt modeNicolas Palix
This adds a 'rep+ctxt' mode which prints the warning message followed by the context. Signed-off-by: Nicolas Palix <nicolas.palix@imag.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-02-24coccicheck: change handling of C={1,2} when M= is setGreg Dietsche
This patch reverts a portion of d0bc1fb4 so that coccicheck will work properly when C=1 or C=2. Reported-and-tested-by: Brice Goglin <Brice.Goglin@inria.fr> Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2012-01-14coccicheck: add M= option to control which dir is processedGreg Dietsche
Examples: make coccicheck M=drivers/net/wireless/ make coccicheck SUBDIRS=drivers/net/wireless/ Version 2: fix patch file names when using M= tell coccinelle where the include files are Version 3: Add second include option to support out of tree development Fix error message Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-28Coccinelle: Add contextual messageNicolas Palix
Change the message displayed to the user according to the current mode used. Fix trailing white-space and spelling Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Use the -no_show_diff option for org and report modeNicolas Palix
This allows to write the semantic patches with code sharing for the matching parts. Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Add a new mode named 'chain'Nicolas Palix
spatch now returns -1 when a virtual rule (given with -D on the command line) is not defined in the semantic patch. Using this spatch feature, coccicheck is now tries several modes by default, in the order: patch, report, context, org Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-10-13Coccinelle: Improve user information with a new kind of commentNicolas Palix
Improve user information with a new kind of comment about semantic patch output. Fix spelling. Signed-off-by: Nicolas Palix <npalix.work@gmail.com> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-28Add support for the C variable in the coccicheck scriptNicolas Palix
This patch makes it possible to use the Coccinelle checker with the C variable of the build system. To check only newly edited code, the following command may be used: 'make C={1,2} CHECK="scripts/coccicheck"' This runs every semantic patch in scripts/coccinelle by default. The COCCI variable may additionally be used to only apply a single semantic patch. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Michal Marek <mmarek@suse.cz>
2010-06-12Add a target to use the Coccinelle checkerNicolas Palix
A 'coccicheck' target is added. It can be called with four different modes. Each one generates a different kind of output, i.e. context, patch, org, report, according to the corresponding mode to be activated. The new target calls the 'coccicheck' front-end in the 'scripts' directory with the MODE argument. Every SmPL file in the subdirectories of 'scripts/coccinelle' is then given to the front-end and applied to the entire source tree. The four modes behave as follows: 'report' generates a list in the following format: file:line:column-column: message 'patch' proposes a fix, when possible. 'context' highlights lines of interest and their context in a diff-like style. Lines of interest are indicated with '-'. 'org' generates a report in the Org mode format of Emacs. Signed-off-by: Nicolas Palix <npalix@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
