[ Upstream commit 7c8a61d9ee1df0fb4747879fa67a99614eb62fec ]
Alexandar Potapenko while testing the kernel with KMSAN and syzkaller
discovered that in some configurations sctp would leak 4 bytes of
kernel stack.
Working with his reproducer I discovered that those 4 bytes that
are leaked is the scope id of an ipv6 address returned by recvmsg.
With a little code inspection and a shrewd guess I discovered that
sctp_inet6_skb_msgname only initializes the scope_id field for link
local ipv6 addresses to the interface index the link local address
pertains to instead of initializing the scope_id field for all ipv6
addresses.
That is almost reasonable as scope_id's are meaniningful only for link
local addresses. Set the scope_id in all other cases to 0 which is
not a valid interface index to make it clear there is nothing useful
in the scope_id field.
There should be no danger of breaking userspace as the stack leak
guaranteed that previously meaningless random data was being returned.
Fixes: 372f525b495c ("SCTP: Resync with LKSCTP tree.")
History-tree: https://git.kernel.org/pub/scm/linux/kernel/git/tglx/history.git
Reported-by: Alexander Potapenko <glider@google.com>
Tested-by: Alexander Potapenko <glider@google.com>
[ Upstream commit df80cd9b28b9ebaa284a41df611dbf3a2d05ca74 ]
Now when peeling off an association to the sock in another netns, all
transports in this assoc are not to be rehashed and keep use the old
key in hashtable.
As a transport uses sk->net as the hash key to insert into hashtable,
it would miss removing these transports from hashtable due to the new
netns when closing the sock and all transports are being freeed, then
later an use-after-free issue could be caused when looking up an asoc
and dereferencing those transports.
This is a very old issue since very beginning, ChunYu found it with
syzkaller fuzz testing with this series:
socket$inet6_sctp()
bind$inet6()
sendto$inet6()
unshare(0x40000000)
getsockopt$inet_sctp6_SCTP_GET_ASSOC_ID_LIST()
getsockopt$inet_sctp6_SCTP_SOCKOPT_PEELOFF()
This patch is to block this call when peeling one assoc off from one
netns to another one, so that the netns of all transport would not
go out-sync with the key in hashtable.
Note that this patch didn't fix it by rehashing transports, as it's
difficult to handle the situation when the tuple is already in use
in the new netns. Besides, no one would like to peel off one assoc
to another netns, considering ipaddrs, ifaces, etc. are usually
different.
Reported-by: ChunYu Wang <chunwang@redhat.com>
Signed-off-by: Xin Long <lucien.xin@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
[ Upstream commit 0642840b8bb008528dbdf929cec9f65ac4231ad0 ]
The way people generally use netlink_dump is that they fill in the skb
as much as possible, breaking when nla_put returns an error. Then, they
get called again and start filling out the next skb, and again, and so
forth. The mechanism at work here is the ability for the iterative
dumping function to detect when the skb is filled up and not fill it
past the brim, waiting for a fresh skb for the rest of the data.
However, if the attributes are small and nicely packed, it is possible
that a dump callback function successfully fills in attributes until the
skb is of size 4080 (libmnl's default page-sized receive buffer size).
The dump function completes, satisfied, and then, if it happens to be
that this is actually the last skb, and no further ones are to be sent,
then netlink_dump will add on the NLMSG_DONE part:
nlh = nlmsg_put_answer(skb, cb, NLMSG_DONE, sizeof(len), NLM_F_MULTI);
It is very important that netlink_dump does this, of course. However, in
this example, that call to nlmsg_put_answer will fail, because the
previous filling by the dump function did not leave it enough room. And
how could it possibly have done so? All of the nla_put variety of
functions simply check to see if the skb has enough tailroom,
independent of the context it is in.
In order to keep the important assumptions of all netlink dump users, it
is therefore important to give them an skb that has this end part of the
tail already reserved, so that the call to nlmsg_put_answer does not
fail. Otherwise, library authors are forced to find some bizarre sized
receive buffer that has a large modulo relative to the common sizes of
messages received, which is ugly and buggy.
This patch thus saves the NLMSG_DONE for an additional message, for the
case that things are dangerously close to the brim. This requires
keeping track of the errno from ->dump() across calls.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
[ Upstream commit 052d41c01b3a2e3371d66de569717353af489d63 ]
After refcnt reaches zero, vlan_vid_del() could free
dev->vlan_info via RCU:
RCU_INIT_POINTER(dev->vlan_info, NULL);
call_rcu(&vlan_info->rcu, vlan_info_rcu_free);
However, the pointer 'grp' still points to that memory
since it is set before vlan_vid_del():
vlan_info = rtnl_dereference(dev->vlan_info);
if (!vlan_info)
goto out;
grp = &vlan_info->grp;
Depends on when that RCU callback is scheduled, we could
trigger a use-after-free in vlan_group_for_each_dev()
right following this vlan_vid_del().
Fix it by moving vlan_vid_del() before setting grp. This
is also symmetric to the vlan_vid_add() we call in
vlan_device_event().
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Fixes: efc73f4bbc23 ("net: Fix memory leak - vlan_info struct")
Cc: Alexander Duyck <alexander.duyck@gmail.com>
Cc: Girish Moodalbail <girish.moodalbail@oracle.com>
Reviewed-by: Girish Moodalbail <girish.moodalbail@oracle.com>
Tested-by: Fengguang Wu <fengguang.wu@intel.com>
[ Upstream commit 2b5ec1a5f9738ee7bf8f5ec0526e75e00362c48f ]
When run ipvs in two different network namespace at the same host, and one
ipvs transport network traffic to the other network namespace ipvs.
'ipvs_property' flag will make the second ipvs take no effect. So we should
clear 'ipvs_property' when SKB network namespace changed.
Fixes: 621e84d6f373 ("dev: introduce skb_scrub_packet()")
Signed-off-by: Ye Yin <hustcat@gmail.com>
Signed-off-by: Wei Zhou <chouryzhou@gmail.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
[ Upstream commit 3b11775033dc87c3d161996c54507b15ba26414a ]
Christoph Paasch sent a patch to address the following issue :
tcp_make_synack() is leaving some TCP private info in skb->cb[],
then send the packet by other means than tcp_transmit_skb()
tcp_transmit_skb() makes sure to clear skb->cb[] to not confuse
IPv4/IPV6 stacks, but we have no such cleanup for SYNACK.
tcp_make_synack() should not use tcp_init_nondata_skb() :
tcp_init_nondata_skb() really should be limited to skbs put in write/rtx
queues (the ones that are only sent via tcp_transmit_skb())
This patch fixes the issue and should even save few cpu cycles ;)
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Reported-by: Christoph Paasch <cpaasch@apple.com>
Reviewed-by: Christoph Paasch <cpaasch@apple.com>
commit df80cd9b28b9ebaa284a41df611dbf3a2d05ca74 upstream.
key in hashtable.
socket$inet6_sctp()
bind$inet6()
sendto$inet6()
unshare(0x40000000)
different.
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d01332f1acacc0cb43a61f4244dd2b846d4cd585 upstream.
Changing certain link attributes (link tolerance and link priority)
from the TIPC management tool is supposed to automatically take
effect at both endpoints of the affected link.
Currently the media address is not instantiated for the link and is
used uninstantiated when crafting protocol messages designated for the
peer endpoint. This means that changing a link property currently
results in the property being changed on the local machine but the
protocol message designated for the peer gets lost. Resulting in
property discrepancy between the endpoints.
In this patch we resolve this by using the media address from the
link entry and using the bearer transmit function to send it. Hence,
we can now eliminate the redundant function tipc_link_prot_xmit() and
the redundant field tipc_link::media_addr.
Fixes: 2af5ae372a4b (tipc: clean up unused code and structures)
Reviewed-by: Jon Maloy <jon.maloy@ericsson.com>
Reported-by: Jason Hu <huzhijiang@gmail.com>
Signed-off-by: Richard Alpe <richard.alpe@ericsson.com>
[backported to 4.4 by Tommi Rantala]
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
[ Upstream commit 06f877d613be3621604c2520ec0351d9fbdca15f ]
In my first attempt to fix the lockdep splat, I forgot we could
enter inet_csk_route_req() with a freshly allocated request socket,
for which refcount has not yet been elevated, due to complex
SLAB_TYPESAFE_BY_RCU rules.
We either are in rcu_read_lock() section _or_ we own a refcount on the
request.
Correct RCU verb to use here is rcu_dereference_check(), although it is
not possible to prove we actually own a reference on a shared
refcount :/
In v2, I added ireq_opt_deref() helper and use in three places, to fix other
possible splats.
[ 49.844590] lockdep_rcu_suspicious+0xea/0xf3
[ 49.846487] inet_csk_route_req+0x53/0x14d
[ 49.848334] tcp_v4_route_req+0xe/0x10
[ 49.850174] tcp_conn_request+0x31c/0x6a0
[ 49.851992] ? __lock_acquire+0x614/0x822
[ 49.854015] tcp_v4_conn_request+0x5a/0x79
[ 49.855957] ? tcp_v4_conn_request+0x5a/0x79
[ 49.858052] tcp_rcv_state_process+0x98/0xdcc
[ 49.859990] ? sk_filter_trim_cap+0x2f6/0x307
[ 49.862085] tcp_v4_do_rcv+0xfc/0x145
[ 49.864055] ? tcp_v4_do_rcv+0xfc/0x145
[ 49.866173] tcp_v4_rcv+0x5ab/0xaf9
[ 49.868029] ip_local_deliver_finish+0x1af/0x2e7
[ 49.870064] ip_local_deliver+0x1b2/0x1c5
[ 49.871775] ? inet_del_offload+0x45/0x45
[ 49.873916] ip_rcv_finish+0x3f7/0x471
[ 49.875476] ip_rcv+0x3f1/0x42f
[ 49.876991] ? ip_local_deliver_finish+0x2e7/0x2e7
[ 49.878791] __netif_receive_skb_core+0x6d3/0x950
[ 49.880701] ? process_backlog+0x7e/0x216
[ 49.882589] __netif_receive_skb+0x1d/0x5e
[ 49.884122] process_backlog+0x10c/0x216
[ 49.885812] net_rx_action+0x147/0x3df
Fixes: a6ca7abe53633 ("tcp/dccp: fix lockdep splat in inet_csk_route_req()")
Fixes: c92e8c02fe66 ("tcp/dccp: fix ireq->opt races")
Reported-by: kernel test robot <fengguang.wu@intel.com>
Reported-by: Maciej Żenczykowski <maze@google.com>
[ Upstream commit a6ca7abe53633d08eea1c6756cb49c9b2d4c90bf ]
This patch fixes the following lockdep splat in inet_csk_route_req()
inet_csk_route_req
tcp_v4_send_synack
tcp_rtx_synack
inet_rtx_syn_ack
tcp_fastopen_synack_time
tcp_retransmit_timer
tcp_write_timer_handler
tcp_write_timer
call_timer_fn
Thread running inet_csk_route_req() owns a reference on the request
socket, so we have the guarantee ireq->ireq_opt wont be changed or
freed.
lockdep can enforce this invariant for us.
[ Upstream commit c92e8c02fe664155ac4234516e32544bec0f113d ]
syzkaller found another bug in DCCP/TCP stacks [1]
For the reasons explained in commit ce1050089c96 ("tcp/dccp: fix
ireq->pktopts race"), we need to make sure we do not access
ireq->opt unless we own the request sock.
Note the opt field is renamed to ireq_opt to ease grep games.
[1]
BUG: KASAN: use-after-free in ip_queue_xmit+0x1687/0x18e0 net/ipv4/ip_output.c:474
Read of size 1 at addr ffff8801c951039c by task syz-executor5/3295
CPU: 1 PID: 3295 Comm: syz-executor5 Not tainted 4.14.0-rc4+ #80
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:16 [inline]
dump_stack+0x194/0x257 lib/dump_stack.c:52
print_address_description+0x73/0x250 mm/kasan/report.c:252
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x25b/0x340 mm/kasan/report.c:409
__asan_report_load1_noabort+0x14/0x20 mm/kasan/report.c:427
tcp_transmit_skb+0x1ab7/0x3840 net/ipv4/tcp_output.c:1135
tcp_send_ack.part.37+0x3bb/0x650 net/ipv4/tcp_output.c:3587
tcp_send_ack+0x49/0x60 net/ipv4/tcp_output.c:3557
__tcp_ack_snd_check+0x2c6/0x4b0 net/ipv4/tcp_input.c:5072
tcp_ack_snd_check net/ipv4/tcp_input.c:5085 [inline]
tcp_rcv_state_process+0x2eff/0x4850 net/ipv4/tcp_input.c:6071
tcp_child_process+0x342/0x990 net/ipv4/tcp_minisocks.c:816
tcp_v4_rcv+0x1827/0x2f80 net/ipv4/tcp_ipv4.c:1682
ip_local_deliver_finish+0x2e2/0xba0 net/ipv4/ip_input.c:216
NF_HOOK include/linux/netfilter.h:249 [inline]
ip_local_deliver+0x1ce/0x6e0 net/ipv4/ip_input.c:257
dst_input include/net/dst.h:464 [inline]
ip_rcv_finish+0x887/0x19a0 net/ipv4/ip_input.c:397
ip_rcv+0xc3f/0x1820 net/ipv4/ip_input.c:493
__netif_receive_skb_core+0x1a3e/0x34b0 net/core/dev.c:4476
__netif_receive_skb+0x2c/0x1b0 net/core/dev.c:4514
netif_receive_skb_internal+0x10b/0x670 net/core/dev.c:4587
netif_receive_skb+0xae/0x390 net/core/dev.c:4611
tun_rx_batched.isra.50+0x5ed/0x860 drivers/net/tun.c:1372
tun_get_user+0x249c/0x36d0 drivers/net/tun.c:1766
tun_chr_write_iter+0xbf/0x160 drivers/net/tun.c:1792
call_write_iter include/linux/fs.h:1770 [inline]
new_sync_write fs/read_write.c:468 [inline]
__vfs_write+0x68a/0x970 fs/read_write.c:481
vfs_write+0x18f/0x510 fs/read_write.c:543
SYSC_write fs/read_write.c:588 [inline]
SyS_write+0xef/0x220 fs/read_write.c:580
entry_SYSCALL_64_fastpath+0x1f/0xbe
RIP: 0033:0x40c341
RSP: 002b:00007f469523ec10 EFLAGS: 00000293 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 000000000040c341
RDX: 0000000000000037 RSI: 0000000020004000 RDI: 0000000000000015
RBP: 0000000000000086 R08: 0000000000000000 R09: 0000000000000000
R10: 00000000000f4240 R11: 0000000000000293 R12: 00000000004b7fd1
R13: 00000000ffffffff R14: 0000000020000000 R15: 0000000000025000
Allocated by task 3295:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:59
save_stack+0x43/0xd0 mm/kasan/kasan.c:447
set_track mm/kasan/kasan.c:459 [inline]
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:551
__do_kmalloc mm/slab.c:3725 [inline]
__kmalloc+0x162/0x760 mm/slab.c:3734
kmalloc include/linux/slab.h:498 [inline]
tcp_v4_save_options include/net/tcp.h:1962 [inline]
tcp_v4_init_req+0x2d3/0x3e0 net/ipv4/tcp_ipv4.c:1271
tcp_conn_request+0xf6d/0x3410 net/ipv4/tcp_input.c:6283
tcp_v4_conn_request+0x157/0x210 net/ipv4/tcp_ipv4.c:1313
tcp_rcv_state_process+0x8ea/0x4850 net/ipv4/tcp_input.c:5857
tcp_v4_do_rcv+0x55c/0x7d0 net/ipv4/tcp_ipv4.c:1482
tcp_v4_rcv+0x2d10/0x2f80 net/ipv4/tcp_ipv4.c:1711
Freed by task 3306:
kasan_slab_free+0x71/0xc0 mm/kasan/kasan.c:524
__cache_free mm/slab.c:3503 [inline]
kfree+0xca/0x250 mm/slab.c:3820
inet_sock_destruct+0x59d/0x950 net/ipv4/af_inet.c:157
__sk_destruct+0xfd/0x910 net/core/sock.c:1560
sk_destruct+0x47/0x80 net/core/sock.c:1595
__sk_free+0x57/0x230 net/core/sock.c:1603
sk_free+0x2a/0x40 net/core/sock.c:1614
sock_put include/net/sock.h:1652 [inline]
inet_csk_complete_hashdance+0xd5/0xf0 net/ipv4/inet_connection_sock.c:959
tcp_check_req+0xf4d/0x1620 net/ipv4/tcp_minisocks.c:765
tcp_v4_rcv+0x17f6/0x2f80 net/ipv4/tcp_ipv4.c:1675
Fixes: e994b2f0fb92 ("tcp: do not lock listener to process SYN packets")
Fixes: 079096f103fa ("tcp/dccp: install syn_recv requests into ehash table")
[ Upstream commit f3594f0a7ea36661d7fd942facd7f31a64245f1a ]
t->err_count is used to count the link failure on tunnel and an err
will be reported to user socket in tx path if t->err_count is not 0.
udp socket could even return EHOSTUNREACH to users.
Since commit fd58156e456d ("IPIP: Use ip-tunneling code.") removed
the 'switch check' for icmp type in ipip_err(), err_count would be
increased by the icmp packet with ICMP_EXC_FRAGTIME code. an link
failure would be reported out due to this.
In Jianlin's case, when receiving ICMP_EXC_FRAGTIME a icmp packet,
udp netperf failed with the err:
send_data: data send error: No route to host (errno 113)
We expect this error reported from tunnel to socket when receiving
some certain type icmp, but not ICMP_EXC_FRAGTIME, ICMP_SR_FAILED
or ICMP_PARAMETERPROB ones.
This patch is to bring 'switch check' for icmp type back to ipip_err
so that it only reports link failure for the right type icmp, just as
in ipgre_err() and ipip6_err().
Fixes: fd58156e456d ("IPIP: Use ip-tunneling code.")
Reported-by: Jianlin Shi <jishi@redhat.com>
[ Upstream commit d04adf1b355181e737b6b1e23d801b07f0b7c4c0 ]
Now when migrating sock to another one in sctp_sock_migrate(), it only
resets owner sk for the data in receive queues, not the chunks on out
queues.
It would cause that data chunks length on the sock is not consistent
with sk sk_wmem_alloc. When closing the sock or freeing these chunks,
the old sk would never be freed, and the new sock may crash due to
the overflow sk_wmem_alloc.
syzbot found this issue with this series:
r0 = socket$inet_sctp()
sendto$inet(r0)
listen(r0)
accept4(r0)
close(r0)
Although listen() should have returned error when one TCP-style socket
is in connecting (I may fix this one in another patch), it could also
be reproduced by peeling off an assoc.
This issue is there since very beginning.
This patch is to reset owner sk for the chunks on out queues so that
sk sk_wmem_alloc has correct value after accept one sock or peeloff
an assoc to one sock.
Note that when resetting owner sk for chunks on outqueue, it has to
sctp_clear_owner_w/skb_orphan chunks before changing assoc->base.sk
first and then sctp_set_owner_w them after changing assoc->base.sk,
due to that sctp_wfree and it's callees are using assoc->base.sk.
[ Upstream commit f8d20b46ce55cf40afb30dcef6d9288f7ef46d9b ]
The similar fix in patch 'ipip: only increase err_count for some
certain type icmp in ipip_err' is needed for ip6gre_err.
In Jianlin's case, udp netperf broke even when receiving a TooBig
icmpv6 packet.
Fixes: c12b395a4664 ("gre: Support GRE over IPv6")
[ Upstream commit 0f5da659d8f1810f44de14acf2c80cd6499623a0 ]
socket_diag shows information only about sockets from a namespace where
a diag socket lives.
But if we request information about one unix socket, the kernel don't
check that its netns is matched with a diag socket namespace, so any
user can get information about any unix socket in a system. This looks
like a bug.
v2: add a Fixes tag
Fixes: 51d7cccf0723 ("net: make sock diag per-namespace")
Signed-off-by: Andrei Vagin <avagin@openvz.org>
[ Upstream commit 864e2a1f8aac05effac6063ce316b480facb46ff ]
When syzkaller team brought us a C repro for the crash [1] that
had been reported many times in the past, I finally could find
the root cause.
If FlowLabel info is merged by fl6_merge_options(), we leave
part of the opt_space storage provided by udp/raw/l2tp with random value
in opt_space.tot_len, unless a control message was provided at sendmsg()
time.
Then ip6_setup_cork() would use this random value to perform a kzalloc()
call. Undefined behavior and crashes.
Fix is to properly set tot_len in fl6_merge_options()
At the same time, we can also avoid consuming memory and cpu cycles
to clear it, if every option is copied via a kmemdup(). This is the
change in ip6_setup_cork().
[1]
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 0 PID: 6613 Comm: syz-executor0 Not tainted 4.14.0-rc4+ #127
task: ffff8801cb64a100 task.stack: ffff8801cc350000
RIP: 0010:ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168
RSP: 0018:ffff8801cc357550 EFLAGS: 00010203
RAX: dffffc0000000000 RBX: ffff8801cc357748 RCX: 0000000000000010
RDX: 0000000000000002 RSI: ffffffff842bd1d9 RDI: 0000000000000014
RBP: ffff8801cc357620 R08: ffff8801cb17f380 R09: ffff8801cc357b10
R10: ffff8801cb64a100 R11: 0000000000000000 R12: ffff8801cc357ab0
R13: ffff8801cc357b10 R14: 0000000000000000 R15: ffff8801c3bbf0c0
FS: 00007f9c5c459700(0000) GS:ffff8801db200000(0000) knlGS:0000000000000000
CR2: 0000000020324000 CR3: 00000001d1cf2000 CR4: 00000000001406f0
DR0: 0000000020001010 DR1: 0000000000000000 DR2: 0000000000000000
DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000600
Call Trace:
ip6_make_skb+0x282/0x530 net/ipv6/ip6_output.c:1729
udpv6_sendmsg+0x2769/0x3380 net/ipv6/udp.c:1340
inet_sendmsg+0x11f/0x5e0 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633 [inline]
sock_sendmsg+0xca/0x110 net/socket.c:643
SYSC_sendto+0x358/0x5a0 net/socket.c:1750
SyS_sendto+0x40/0x50 net/socket.c:1718
RIP: 0033:0x4520a9
RSP: 002b:00007f9c5c458c08 EFLAGS: 00000216 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 0000000000718000 RCX: 00000000004520a9
RDX: 0000000000000001 RSI: 0000000020fd1000 RDI: 0000000000000016
RBP: 0000000000000086 R08: 0000000020e0afe4 R09: 000000000000001c
R10: 0000000000000000 R11: 0000000000000216 R12: 00000000004bb1ee
R13: 00000000ffffffff R14: 0000000000000016 R15: 0000000000000029
Code: e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85 ea 0f 00 00 48 8d 79 04 48 b8 00 00 00 00 00 fc ff df 45 8b 74 24 04 48 89 fa 48 c1 ea 03 <0f> b6 14 02 48 89 f8 83 e0 07 83 c0 03 38 d0 7c 08 84 d2 0f 85
RIP: ip6_setup_cork+0x274/0x15c0 net/ipv6/ip6_output.c:1168 RSP: ffff8801cc357550
[ Upstream commit 509c7a1ecc8601f94ffba8a00889fefb239c00c6 ]
syzkaller got crashes in packet_getsockopt() processing
PACKET_ROLLOVER_STATS command while another thread was managing
to change po->rollover
Using RCU will fix this bug. We might later add proper RCU annotations
for sparse sake.
In v2: I replaced kfree(rollover) in fanout_add() to kfree_rcu()
variant, as spotted by John.
Fixes: a9b6391814d5 ("packet: rollover statistics")
Cc: Willem de Bruijn <willemb@google.com>
Cc: John Sperbeck <jsperbeck@google.com>
[ Upstream commit 1cc276cec9ec574d41cf47dfc0f51406b6f26ab4 ]
Now sctp processes icmp redirect packet in sctp_icmp_redirect where
it calls sctp_transport_dst_check in which tp->dst can be released.
The problem is before calling sctp_transport_dst_check, it doesn't
check sock_owned_by_user, which means tp->dst could be freed while
a process is accessing it with owning the socket.
An use-after-free issue could be triggered by this.
This patch is to fix it by checking sock_owned_by_user before calling
sctp_transport_dst_check in sctp_icmp_redirect, so that it would not
release tp->dst if users still hold sock lock.
Besides, the same issue fixed in commit 45caeaa5ac0b ("dccp/tcp: fix
routing redirect race") on sctp also needs this check.
Fixes: 55be7a9c6074 ("ipv4: Add redirect support to all protocol icmp error handlers")
Reported-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 0ad646c81b2182f7fa67ec0c8c825e0ee165696d ]
register_netdevice() could fail early when we have an invalid
dev name, in which case ->ndo_uninit() is not called. For tun
device, this is a problem because a timer etc. are already
initialized and it expects ->ndo_uninit() to clean them up.
We could move these initializations into a ->ndo_init() so
that register_netdevice() knows better, however this is still
complicated due to the logic in tun_detach().
Therefore, I choose to just call dev_get_valid_name() before
register_netdevice(), which is quicker and much easier to audit.
And for this specific case, it is already enough.
Fixes: 96442e42429e ("tuntap: choose the txq based on rxq")
Reported-by: Dmitry Alexeev <avekceeb@gmail.com>
Cc: Jason Wang <jasowang@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
[ Upstream commit 5903f594935a3841137c86b9d5b75143a5b7121c ]
When pppol2tp_session_ioctl() is called by pppol2tp_tunnel_ioctl(),
the session may be unconnected. That is, it was created by
pppol2tp_session_create() and hasn't been connected with
pppol2tp_connect(). In this case, ps->sock is NULL, so we need to check
for this case in order to avoid dereferencing a NULL pointer.
Fixes: 309795f4bec2 ("l2tp: Add netlink control API for L2TP")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 2b7cda9c35d3b940eb9ce74b30bbd5eb30db493d ]
Based on SNMP values provided by Roman, Yuchung made the observation
that some crashes in tcp_sacktag_walk() might be caused by MTU probing.
Looking at tcp_mtu_probe(), I found that when a new skb was placed
in front of the write queue, we were not updating tcp highest sack.
If one skb is freed because all its content was copied to the new skb
(for MTU probing), then tp->highest_sack could point to a now freed skb.
Bad things would then happen, including infinite loops.
This patch renames tcp_highest_sack_combine() and uses it
from tcp_mtu_probe() to fix the bug.
Note that I also removed one test against tp->sacked_out,
since we want to replace tp->highest_sack regardless of whatever
condition, since keeping a stale pointer to freed skb is a recipe
for disaster.
Fixes: a47e5a988a57 ("[TCP]: Convert highest_sack to sk_buff to allow direct access")
Reported-by: Alexei Starovoitov <alexei.starovoitov@gmail.com>
Reported-by: Roman Gushchin <guro@fb.com>
Reported-by: Oleksandr Natalenko <oleksandr@natalenko.name>
Acked-by: Alexei Starovoitov <ast@kernel.org>
Acked-by: Neal Cardwell <ncardwell@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
commit cfbb0d90a7abb289edc91833d0905931f8805f12 upstream.
For the reinstall prevention, the code I had added compares the
whole key. It turns out though that iwlwifi firmware doesn't
provide the TKIP TX MIC key as it's not needed in client mode,
and thus the comparison will always return false.
For client mode, thus always zero out the TX MIC key part before
doing the comparison in order to avoid accepting the reinstall
of the key with identical encryption and RX MIC key, but not the
same TX MIC key (since the supplicant provides the real one.)
Fixes: fdf7cb4185b6 ("mac80211: accept key reinstall without changing anything")
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2bdd713b92a9cade239d3c7d15205a09f556624d upstream.
Otherwise we risk leaking information via timing side channel.
commit fdf7cb4185b60c68e1a75e61691c4afdc15dea0e upstream.
When a key is reinstalled we can reset the replay counters
etc. which can lead to nonce reuse and/or replay detection
being impossible, breaking security properties, as described
in the "KRACK attacks".
In particular, CVE-2017-13080 applies to GTK rekeying that
happened in firmware while the host is in D3, with the second
part of the attack being done after the host wakes up. In
this case, the wpa_supplicant mitigation isn't sufficient
since wpa_supplicant doesn't know the GTK material.
In case this happens, simply silently accept the new key
coming from userspace but don't take any action on it since
it's the same key; this keeps the PN replay counters intact.
[ Upstream commit 3a89eaa65db68bf53bf92dedc60084f810e1779a ]
The support for DSA Ethernet switch chips depends on TCP/IP networking,
thus explicit that HAVE_NET_DSA depends on INET.
DSA uses SWITCHDEV, thus select it instead of depending on it.
Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
[ Upstream commit ebd89a2d0675f1325c2be5b7576fd8cb7e8defd0 ]
ah4 input processing uses the asynchronous hash crypto API which
supplies an error code as part of the operation completion but
the error code was being ignored.
Treat a crypto API error indication as a verification failure.
While a crypto API reported error would almost certainly result
in a memcpy of the digest failing anyway and thus the security
risk seems minor, performing a memory compare on what might be
uninitialized memory is wrong.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
[ Upstream commit f169fd695b192dd7b23aff8e69d25a1bc881bbfa ]
After adding the following nft rule, then ping 224.0.0.1:
# nft add rule netdev t c pkttype host counter
The warning complain message will be printed out again and again:
WARNING: CPU: 0 PID: 10182 at net/netfilter/nft_meta.c:163 \
nft_meta_get_eval+0x3fe/0x460 [nft_meta]
Call Trace:
<IRQ>
dump_stack+0x85/0xc2
__warn+0xcb/0xf0
warn_slowpath_null+0x1d/0x20
nft_do_chain+0xff/0x5e0 [nf_tables]
So we should deal with PACKET_LOOPBACK in netdev family too. For ipv4,
convert it to PACKET_BROADCAST/MULTICAST according to the destination
address's type; For ipv6, convert it to PACKET_MULTICAST directly.
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream.
Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection
error into one field such that:
(1) The instantiation state can be modified/read atomically.
(2) The error can be accessed atomically with the state.
(3) The error isn't stored unioned with the payload pointers.
This deals with the problem that the state is spread over three different
objects (two bits and a separate variable) and reading or updating them
atomically isn't practical, given that not only can uninstantiated keys
change into instantiated or rejected keys, but rejected keys can also turn
into instantiated keys - and someone accessing the key might not be using
any locking.
The main side effect of this problem is that what was held in the payload
may change, depending on the state. For instance, you might observe the
key to be in the rejected state. You then read the cached error, but if
the key semaphore wasn't locked, the key might've become instantiated
between the two reads - and you might now have something in hand that isn't
actually an error code.
The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error
code if the key is negatively instantiated. The key_is_instantiated()
function is replaced with key_is_positive() to avoid confusion as negative
keys are also 'instantiated'.
Additionally, barriering is included:
(1) Order payload-set before state-set during instantiation.
(2) Order state-read before payload-read when using the key.
Further separate barriering is necessary if RCU is being used to access the
payload content after reading the payload pointers.
Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data")
Reported-by: Eric Biggers <ebiggers@google.com>
Reviewed-by: Eric Biggers <ebiggers@google.com>
[ Upstream commit 4b86c459c7bee3acaf92f0e2b4c6ac803eaa1a58 ]
Commit 4dee62b1b9b4 ("netfilter: nf_ct_expect: nf_ct_expect_insert()
returns void") inadvertently changed the successful return value of
nf_ct_expect_related_report() from 0 to 1 due to
__nf_ct_expect_check() returning 1 on success. Prevent this
regression in the future by changing the return value of
__nf_ct_expect_check() to 0 on success.
Signed-off-by: Jarno Rajahalme <jarno@ovn.org>
Acked-by: Joe Stringer <joe@ovn.org>
[ Upstream commit d98937f4ea713d21e0fcc345919f86c877dd8d6f ]
iwlwifi now supports RSS and can't let mac80211 track the
PS state based on the Rx frames since they can come out of
order. iwlwifi is now advertising AP_LINK_PS, and uses
explicit notifications to teach mac80211 about the PS state
of the stations and the PS poll / uAPSD trigger frames
coming our way from the peers.
Because of that, the TIM stopped being maintained in
mac80211. I tried to fix this in commit c68df2e7be0c
("mac80211: allow using AP_LINK_PS with mac80211-generated TIM IE")
but that was later reverted by Felix in commit 6c18a6b4e799
("Revert "mac80211: allow using AP_LINK_PS with mac80211-generated TIM IE")
since it broke drivers that do not implement set_tim.
Since none of the drivers that set AP_LINK_PS have the
set_tim() handler set besides iwlwifi, I can bail out in
__sta_info_recalc_tim if AP_LINK_PS AND .set_tim is not
implemented.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
[ Upstream commit aad06212d36cf34859428a0a279e5c14ee5c9e26 ]
In commit e3a77561e7d32 ("tipc: split up function tipc_msg_eval()"),
we have updated the function tipc_msg_lookup_dest() to set the error
codes to negative values at destination lookup failures. Thus when
the function sets the error code to -TIPC_ERR_NO_NAME, its inserted
into the 4 bit error field of the message header as 0xf instead of
TIPC_ERR_NO_NAME (1). The value 0xf is an unknown error code.
In this commit, we set only positive error code.
Fixes: e3a77561e7d32 ("tipc: split up function tipc_msg_eval()")
Signed-off-by: Parthasarathy Bhuvaragan <parthasarathy.bhuvaragan@ericsson.com>
[ Upstream commit 9d538fa60bad4f7b23193c89e843797a1cf71ef3 ]
sk->sk_prot and sk->sk_prot_creator can differ when the app uses
IPV6_ADDRFORM (transforming an IPv6-socket to an IPv4-one).
Which is why sk_prot_creator is there to make sure that sk_prot_free()
does the kmem_cache_free() on the right kmem_cache slab.
Now, if such a socket gets transformed back to a listening socket (using
connect() with AF_UNSPEC) we will allocate an IPv4 tcp_sock through
sk_clone_lock() when a new connection comes in. But sk_prot_creator will
still point to the IPv6 kmem_cache (as everything got copied in
sk_clone_lock()). When freeing, we will thus put this
memory back into the IPv6 kmem_cache although it was allocated in the
IPv4 cache. I have seen memory corruption happening because of this.
With slub-debugging and MEMCG_KMEM enabled this gives the warning
"cache_from_obj: Wrong slab cache. TCPv6 but object is from TCP"
A C-program to trigger this:
void main(void)
int fd = socket(AF_INET6, SOCK_STREAM, IPPROTO_TCP);
int new_fd, newest_fd, client_fd;
struct sockaddr_in6 bind_addr;
struct sockaddr_in bind_addr4, client_addr1, client_addr2;
struct sockaddr unsp;
int val;
memset(&bind_addr, 0, sizeof(bind_addr));
bind_addr.sin6_family = AF_INET6;
bind_addr.sin6_port = ntohs(42424);
memset(&client_addr1, 0, sizeof(client_addr1));
client_addr1.sin_family = AF_INET;
client_addr1.sin_port = ntohs(42424);
client_addr1.sin_addr.s_addr = inet_addr("127.0.0.1");
memset(&client_addr2, 0, sizeof(client_addr2));
client_addr2.sin_family = AF_INET;
client_addr2.sin_port = ntohs(42421);
client_addr2.sin_addr.s_addr = inet_addr("127.0.0.1");
memset(&unsp, 0, sizeof(unsp));
unsp.sa_family = AF_UNSPEC;
bind(fd, (struct sockaddr *)&bind_addr, sizeof(bind_addr));
listen(fd, 5);
client_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
connect(client_fd, (struct sockaddr *)&client_addr1, sizeof(client_addr1));
new_fd = accept(fd, NULL, NULL);
close(fd);
val = AF_INET;
setsockopt(new_fd, SOL_IPV6, IPV6_ADDRFORM, &val, sizeof(val));
connect(new_fd, &unsp, sizeof(unsp));
memset(&bind_addr4, 0, sizeof(bind_addr4));
bind_addr4.sin_family = AF_INET;
bind_addr4.sin_port = ntohs(42421);
bind(new_fd, (struct sockaddr *)&bind_addr4, sizeof(bind_addr4));
listen(new_fd, 5);
connect(client_fd, (struct sockaddr *)&client_addr2, sizeof(client_addr2));
newest_fd = accept(new_fd, NULL, NULL);
close(new_fd);
close(client_fd);
close(new_fd);
As far as I can see, this bug has been there since the beginning of the
git-days.
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit da7c9561015e93d10fe6aab73e9288e0d09d65a6 ]
Packet socket option po->has_vnet_hdr can be updated concurrently with
other operations if no ring is attached.
Do not test the option twice in packet_snd, as the value may change in
between calls. A race on setsockopt disable may cause a packet > mtu
to be sent without having GSO options set.
Fixes: bfd5f4a3d605 ("packet: Add GSO/csum offload support.")
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 4971613c1639d8e5f102c4e797c3bf8f83a5a69e ]
Once a socket has po->fanout set, it remains a member of the group
until it is destroyed. The prot_hook must be constant and identical
across sockets in the group.
If fanout_add races with packet_do_bind between the test of po->fanout
and taking the lock, the bind call may make type or dev inconsistent
with that of the fanout group.
Hold po->bind_lock when testing po->fanout to avoid this race.
I had to introduce artificial delay (local_bh_enable) to actually
observe the race.
Fixes: dc99f600698d ("packet: Add fanout support.")
[ Upstream commit 62b982eeb4589b2e6d7c01a90590e3a4c2b2ca19 ]
If we try to delete the same tunnel twice, the first delete operation
does a lookup (l2tp_tunnel_get), finds the tunnel, calls
l2tp_tunnel_delete, which queues it for deletion by
l2tp_tunnel_del_work.
The second delete operation also finds the tunnel and calls
l2tp_tunnel_delete. If the workqueue has already fired and started
running l2tp_tunnel_del_work, then l2tp_tunnel_delete will queue the
same tunnel a second time, and try to free the socket again.
Add a dead flag to prevent firing the workqueue twice. Then we can
remove the check of queue_work's result that was meant to prevent that
race but doesn't.
Reproducer:
ip l2tp add tunnel tunnel_id 3000 peer_tunnel_id 4000 local 192.168.0.2 remote 192.168.0.1 encap udp udp_sport 5000 udp_dport 6000
ip l2tp add session name l2tp1 tunnel_id 3000 session_id 1000 peer_session_id 2000
ip link set l2tp1 up
ip l2tp del tunnel tunnel_id 3000
Fixes: f8ccac0e4493 ("l2tp: put tunnel socket release on a workqueue")
Signed-off-by: Sabrina Dubroca <sd@queasysnail.net>
Acked-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit 12d656af4e3d2781b9b9f52538593e1717e7c979 ]
While destroying a network namespace that contains a L2TP tunnel a
"BUG: scheduling while atomic" can be observed.
Enabling lockdep shows that this is happening because l2tp_exit_net()
is calling l2tp_tunnel_closeall() (via l2tp_tunnel_delete()) from
within an RCU critical section.
l2tp_exit_net() takes rcu_read_lock_bh()
<< list_for_each_entry_rcu() >>
__l2tp_session_unhash()
synchronize_rcu() << Illegal inside RCU critical section >>
BUG: sleeping function called from invalid context
in_atomic(): 1, irqs_disabled(): 0, pid: 86, name: kworker/u16:2
INFO: lockdep is turned off.
CPU: 2 PID: 86 Comm: kworker/u16:2 Tainted: G W O 4.4.6-at1 #2
Hardware name: Xen HVM domU, BIOS 4.6.1-xs125300 05/09/2016
Workqueue: netns cleanup_net
0000000000000000 ffff880202417b90 ffffffff812b0013 ffff880202410ac0
ffffffff81870de8 ffff880202417bb8 ffffffff8107aee8 ffffffff81870de8
0000000000000c51 0000000000000000 ffff880202417be0 ffffffff8107b024
Call Trace:
[<ffffffff812b0013>] dump_stack+0x85/0xc2
[<ffffffff8107aee8>] ___might_sleep+0x148/0x240
[<ffffffff8107b024>] __might_sleep+0x44/0x80
[<ffffffff810b21bd>] synchronize_sched+0x2d/0xe0
[<ffffffff8109be6d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff8105c7bb>] ? __local_bh_enable_ip+0x6b/0xc0
[<ffffffff816a1b00>] ? _raw_spin_unlock_bh+0x30/0x40
[<ffffffff81667482>] __l2tp_session_unhash+0x172/0x220
[<ffffffff81667397>] ? __l2tp_session_unhash+0x87/0x220
[<ffffffff8166888b>] l2tp_tunnel_closeall+0x9b/0x140
[<ffffffff81668c74>] l2tp_tunnel_delete+0x14/0x60
[<ffffffff81668dd0>] l2tp_exit_net+0x110/0x270
[<ffffffff81668d5c>] ? l2tp_exit_net+0x9c/0x270
[<ffffffff815001c3>] ops_exit_list.isra.6+0x33/0x60
[<ffffffff81501166>] cleanup_net+0x1b6/0x280
This bug can easily be reproduced with a few steps:
$ sudo unshare -n bash # Create a shell in a new namespace
# ip link set lo up
# ip addr add 127.0.0.1 dev lo
# ip l2tp add tunnel remote 127.0.0.1 local 127.0.0.1 tunnel_id 1 \
peer_tunnel_id 1 udp_sport 50000 udp_dport 50000
# ip l2tp add session name foo tunnel_id 1 session_id 1 \
peer_session_id 1
# ip link set foo up
# exit # Exit the shell, in turn exiting the namespace
$ dmesg
[942121.089216] BUG: scheduling while atomic: kworker/u16:3/13872/0x00000200
To fix this, move the call to l2tp_tunnel_closeall() out of the RCU
critical section, and instead call it from l2tp_tunnel_del_work(), which
is running from the l2tp_wq workqueue.
Fixes: 2b551c6e7d5b ("l2tp: close sessions before initiating tunnel delete")
Signed-off-by: Ridge Kennedy <ridge.kennedy@alliedtelesis.co.nz>
[ Upstream commit 36f6ee22d2d66046e369757ec6bbe1c482957ba6 ]
When running LTP IPsec tests, KASan might report:
BUG: KASAN: use-after-free in vti_tunnel_xmit+0xeee/0xff0 [ip_vti]
Read of size 4 at addr ffff880dc6ad1980 by task swapper/0/0
Call Trace:
<IRQ>
dump_stack+0x63/0x89
print_address_description+0x7c/0x290
kasan_report+0x28d/0x370
? vti_tunnel_xmit+0xeee/0xff0 [ip_vti]
__asan_report_load4_noabort+0x19/0x20
? vti_init_net+0x190/0x190 [ip_vti]
? save_stack_trace+0x1b/0x20
? save_stack+0x46/0xd0
dev_hard_start_xmit+0x147/0x510
? icmp_echo.part.24+0x1f0/0x210
__dev_queue_xmit+0x1394/0x1c60
Freed by task 0:
kasan_slab_free+0x70/0xc0
kmem_cache_free+0x81/0x1e0
kfree_skbmem+0xb1/0xe0
kfree_skb+0x75/0x170
kfree_skb_list+0x3e/0x60
__dev_queue_xmit+0x1298/0x1c60
dev_queue_xmit+0x10/0x20
neigh_resolve_output+0x3a8/0x740
ip_finish_output2+0x5c0/0xe70
ip_finish_output+0x4ba/0x680
ip_output+0x1c1/0x3a0
xfrm_output_resume+0xc65/0x13d0
xfrm_output+0x1e4/0x380
xfrm4_output_finish+0x5c/0x70
Can be fixed if we get skb->len before dst_output().
Fixes: b9959fd3b0fa ("vti: switch to new ip tunnel code")
Fixes: 22e1b23dafa8 ("vti6: Support inter address family tunneling.")
Signed-off-by: Alexey Kodanev <alexey.kodanev@oracle.com>
[ Upstream commit 008ba2a13f2d04c947adc536d19debb8fe66f110 ]
Packet socket bind operations must hold the po->bind_lock. This keeps
po->running consistent with whether the socket is actually on a ptype
list to receive packets.
fanout_add unbinds a socket and its packet_rcv/tpacket_rcv call, then
binds the fanout object to receive through packet_rcv_fanout.
Make it hold the po->bind_lock when testing po->running and rebinding.
Else, it can race with other rebind operations, such as that in
packet_set_ring from packet_rcv to tpacket_rcv. Concurrent updates
can result in a socket being added to a fanout group twice, causing
use-after-free KASAN bug reports, among others.
Reported independently by both trinity and syzkaller.
Verified that the syzkaller reproducer passes after this patch.
Reported-by: nixioaming <nixiaoming@huawei.com>
[ Upstream commit 76cc0d3282d4b933fa144fa41fbc5318e0fdca24 ]
Now in ip6gre_header before packing the ipv6 header, it skb_push t->hlen
which only includes encap_hlen + tun_hlen. It means greh and inner header
would be over written by ipv6 stuff and ipv6h might have no chance to set
up.
Jianlin found this issue when using remote any on ip6_gre, the packets he
captured on gre dev are truncated:
22:50:26.210866 Out ethertype IPv6 (0x86dd), length 120: truncated-ip6 -\
8128 bytes missing!(flowlabel 0x92f40, hlim 0, next-header Options (0) \
payload length: 8192) ::1:2000:0 > ::1:0:86dd: HBH [trunc] ip-proto-128 \
8184
It should also skb_push ipv6hdr so that ipv6h points to the right position
to set ipv6 stuff up.
This patch is to skb_push hlen + sizeof(*ipv6h) and also fix some indents
in ip6gre_header.
[ Upstream commit 63ecc3d9436f8012e49dc846d6cb0a85a3433517 ]
While trying an ESP transport mode encryption for UDPv6 packets of
datagram size 1436 with MTU 1500, checksum error was observed in
the secondary fragment.
This error occurs due to the UDP payload checksum being missed out
when computing the full checksum for these packets in
udp6_hwcsum_outgoing().
Fixes: d39d938c8228 ("ipv6: Introduce udpv6_send_skb()")
Signed-off-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
commit ad670233c9e1d5feb365d870e30083ef1b889177 upstream.
Define a policy for packet pattern attributes in order to fix a
potential read over the end of the buffer during nla_get_u32()
of the NL80211_PKTPAT_OFFSET attribute.
Note that the data there can always be read due to SKB allocation
(with alignment and struct skb_shared_info at the end), but the
data might be uninitialized. This could be used to leak some data
from uninitialized vmalloc() memory, but most drivers don't allow
an offset (so you'd just get -EINVAL if the data is non-zero) or
just allow it with a fixed value - 100 or 128 bytes, so anything
above that would get -EINVAL. With brcmfmac the limit is 1500 so
(at least) one byte could be obtained.
Cc: stable@kernel.org
Signed-off-by: Peng Xu <pxu@qti.qualcomm.com>
Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com>
[rewrite description based on SKB allocation knowledge]
[ Upstream commit 3b12f73a5c2977153f28a224392fd4729b50d1dc ]
In the function rds_ib_setup_qp, the error handle is missing. When some
error occurs, it is possible that memory leak occurs. As such, error
handle is added.
Cc: Joe Jin <joe.jin@oracle.com>
Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com>
Reviewed-by: Guanglei Li <guanglei.li@oracle.com>
Signed-off-by: Zhu Yanjun <yanjun.zhu@oracle.com>
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
[ Upstream commit ae5c682113f9f94cc5e76f92cf041ee624c173ee ]
The helper->expect_class_max must be set to the total number of
expect_policy minus 1, since we will use the statement "if (class >
helper->expect_class_max)" to validate the CTA_EXPECT_CLASS attr in
ctnetlink_alloc_expect.
So for compatibility, set the helper->expect_class_max to the
NFCTH_POLICY_SET_NUM attr's value minus 1.
Also: it's invalid when the NFCTH_POLICY_SET_NUM attr's value is zero.
1. this will result "expect_policy = kzalloc(0, GFP_KERNEL);";
2. we cannot set the helper->expect_class_max to a proper value.
So if nla_get_be32(tb[NFCTH_POLICY_SET_NUM]) is zero, report -EINVAL to
the userspace.
[ Upstream commit 3b7dabf029478bb80507a6c4500ca94132a2bc0b ]
Otherwise, another CPU may access the invalid pointer. For example:
CPU0 CPU1
- rcu_read_lock();
- pfunc = _hook_;
_hook_ = NULL; -
mod unload -
- pfunc(); // invalid, panic
- rcu_read_unlock();
So we must call synchronize_rcu() to wait the rcu reader to finish.
Also note, in nf_nat_snmp_basic_fini, synchronize_rcu() will be invoked
by later nf_conntrack_helper_unregister, but I'm inclined to add a
explicit synchronize_rcu after set the nf_nat_snmp_hook to NULL. Depend
on such obscure assumptions is not a good idea.
Last, in nfnetlink_cttimeout, we use kfree_rcu to free the time object,
so in cttimeout_exit, invoking rcu_barrier() is not necessary at all,
remove it too.
[ Upstream commit 5b8d5429daa05bebef6ffd3297df3b502cc6f184 ]
Peter reported a kernel oops when executing the following command:
$ ip link add name test type bridge vlan_default_pvid 1
[13634.939408] BUG: unable to handle kernel NULL pointer dereference at
0000000000000190
[13634.939436] IP: __vlan_add+0x73/0x5f0
[13634.939783] Call Trace:
[13634.939791] ? pcpu_next_unpop+0x3b/0x50
[13634.939801] ? pcpu_alloc+0x3d2/0x680
[13634.939810] ? br_vlan_add+0x135/0x1b0
[13634.939820] ? __br_vlan_set_default_pvid.part.28+0x204/0x2b0
[13634.939834] ? br_changelink+0x120/0x4e0
[13634.939844] ? br_dev_newlink+0x50/0x70
[13634.939854] ? rtnl_newlink+0x5f5/0x8a0
[13634.939864] ? rtnl_newlink+0x176/0x8a0
[13634.939874] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.939886] ? rtnetlink_rcv_msg+0xe1/0x220
[13634.939896] ? lookup_fast+0x52/0x370
[13634.939905] ? rtnl_newlink+0x8a0/0x8a0
[13634.939915] ? netlink_rcv_skb+0xa1/0xc0
[13634.939925] ? rtnetlink_rcv+0x24/0x30
[13634.939934] ? netlink_unicast+0x177/0x220
[13634.939944] ? netlink_sendmsg+0x2fe/0x3b0
[13634.939954] ? _copy_from_user+0x39/0x40
[13634.939964] ? sock_sendmsg+0x30/0x40
[13634.940159] ? ___sys_sendmsg+0x29d/0x2b0
[13634.940326] ? __alloc_pages_nodemask+0xdf/0x230
[13634.940478] ? mem_cgroup_commit_charge+0x7c/0x4e0
[13634.940592] ? mem_cgroup_try_charge+0x76/0x1a0
[13634.940701] ? __handle_mm_fault+0xdb9/0x10b0
[13634.940809] ? __sys_sendmsg+0x51/0x90
[13634.940917] ? entry_SYSCALL_64_fastpath+0x1e/0xad
The problem is that the bridge's VLAN group is created after setting the
default PVID, when registering the netdevice and executing its
ndo_init().
Fix this by changing the order of both operations, so that
br_changelink() is only processed after the netdevice is registered,
when the VLAN group is already initialized.
Fixes: b6677449dff6 ("bridge: netlink: call br_changelink() during br_dev_newlink()")
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
Signed-off-by: Ido Schimmel <idosch@mellanox.com>
Reported-by: Peter V. Saveliev <peter@svinota.eu>
Tested-by: Peter V. Saveliev <peter@svinota.eu>
[ Upstream commit fd2c83b35752f0a8236b976978ad4658df14a59f ]
In the case getsockopt() is called with PACKET_HDRLEN and optlen < 4
|val| remains uninitialized and the syscall may behave differently
depending on its value, and even copy garbage to userspace on certain
architectures. To fix this we now return -EINVAL if optlen is too small.
This bug has been detected with KMSAN.
Signed-off-by: Alexander Potapenko <glider@google.com>
[ Upstream commit 9899886d5e8ec5b343b1efe44f185a0e68dc6454 ]
Added NULL check to make __dev_kfree_skb_irq consistent with kfree
family of functions.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=195289
Signed-off-by: Myungho Jung <mhjungk@gmail.com>
[ Upstream commit 62bc306e2083436675e33b5bdeb6a77907d35971 ]
32-bit socketcalls were not being logged by audit on x86_64 systems.
Log them. This is basically a duplicate of the call from
net/socket.c:sys_socketcall(), but it addresses the impedance mismatch
between 32-bit userspace process and 64-bit kernel audit.
See: https://github.com/linux-audit/audit-kernel/issues/14
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
[ Upstream commit 941f8d55f6d613a460a5e080d25a38509f45eb75 ]
When application sends an RDS RDMA composite message consist of
RDMA transfer to be followed up by non RDMA payload, it expect to
be notified *only* when the full message gets delivered. RDS RDMA
notification doesn't behave this way though.
Thanks to Venkat for debug and root casuing the issue
where only first part of the message(RDMA) was
successfully delivered but remainder payload delivery failed.
In that case, application should not be notified with
a false positive of message delivery success.
Fix this case by making sure the user gets notified only after
the full message delivery.
Reviewed-by: Venkat Venkatsubra <venkat.x.venkatsubra@oracle.com>
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
commit e785fa0a164aa11001cba931367c7f94ffaff888 upstream.
nl80211_set_rekey_data() does not check if the required attributes
NL80211_REKEY_DATA_{REPLAY_CTR,KEK,KCK} are present when processing
NL80211_CMD_SET_REKEY_OFFLOAD request. This request can be issued by
users with CAP_NET_ADMIN privilege and may result in NULL dereference
and a system crash. Add a check for the required attributes presence.
This patch is based on the patch by bo Zhang.
This fixes CVE-2017-12153.
References: https://bugzilla.redhat.com/show_bug.cgi?id=1491046
Fixes: e5497d766ad ("cfg80211/nl80211: support GTK rekey offload")
Reported-by: bo Zhang <zhangbo5891001@gmail.com>
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
