path: root/net/openvswitch
2013-04-30openvswitch: Remove unneeded ovs_netdev_get_ifindex()Thomas Graf
The only user is get_dpifindex(), no need to redirect via the port operations. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-25openvswitch: Use parallel_ops genl.Pravin B Shelar
OVS locking was recently changed to have private OVS lock which simplified overall locking. Therefore there is no need to have another global genl lock to protect OVS data structures. Following patch uses of parallel_ops genl family for OVS. This also allows more granual OVS locking using ovs_mutex for protecting OVS data structures, which gives more concurrencey. E.g multiple genl operations OVS_PACKET_CMD_EXECUTE can run in parallel, etc. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: add protocol argument to packet tagging functionsPatrick McHardy
Add a protocol argument to the VLAN packet tagging functions. In case of HW tagging, we need that protocol available in the ndo_start_xmit functions, so it is stored in a new field in the skb. The new field fits into a hole (on 64 bit) and doesn't increase the sks's size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*Patrick McHardy
Rename the hardware VLAN acceleration features to include "CTAG" to indicate that they only support CTAGs. Follow up patches will introduce 802.1ad server provider tagging (STAGs) and require the distinction for hardware not supporting acclerating both. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-15openvswitch: Use generic struct pcpu_tstats.Pravin B Shelar
Rather than defining ovs specific stats struct (vport_percpu_stats), we can use existing pcpu_tstats to achieve exactly same functionality. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-04-15openvswitch: Simplify datapath locking.Pravin B Shelar
Currently OVS uses combination of genl and rtnl lock to protect datapath state. This was done due to networking stack locking. But this has complicated locking and there are few lock ordering issues with new tunneling protocols. Following patch simplifies locking by introducing new ovs mutex and now this lock is used to protect entire ovs state. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-04-10openvswitch: datapath.h: Fix a stale comment.Andy Zhou
Signed-off-by: Andy Zhou <azhou@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-04-02openvswitch: Don't insert empty OVS_VPORT_ATTR_OPTIONS attributeThomas Graf
The port specific options are currently unused resulting in an empty OVS_VPORT_ATTR_OPTIONS nested attribute being inserted into every OVS_VPORT_CMD_GET message. Don't insert OVS_VPORT_ATTR_OPTIONS if no options are present. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-29openvswitch: Move common genl notify code into ovs_notify()Thomas Graf
2013-03-29openvswitch: Refine Netlink message size calculation and kill FLOW_BUFSIZEThomas Graf
Kills the FLOW_BUFSIZE constant which needs to be calculated manually and replaces it with key_attr_size() based on nla_total_size(). Calculates the size of datapath messages instead of relying on NLMSG_DEFAULT_SIZE and moves the existing message size calculations into own functions for clarity. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-29openvswitch: Use nla_memcpy() to memcpy() data from attributesThomas Graf
Less error prone as it takes into account the length of both the destination buffer and the source attribute and documents when data is copied from an attribute. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-29openvswitch: Specify the minimal length of OVS_PACKET_ATTR_PACKET in the policyThomas Graf
Specifying the minimal length in the policy makes it reuseable and documents the interface. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-28net: add ETH_P_802_3_MINSimon Horman
Add a new constant ETH_P_802_3_MIN, the minimum ethernet type for an 802.3 frame. Frames with a lower value in the ethernet type field are Ethernet II. Also update all the users of this value that David Miller and I could find to use the new constant. Also correct a bug in util.c. The comparison with ETH_P_802_3_MIN should be >= not >. As suggested by Jesse Gross. Compile tested only. Cc: David Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: Bart De Schuymer <bart.de.schuymer@pandora.be> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Marcel Holtmann <marcel@holtmann.org> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: Johan Hedberg <johan.hedberg@gmail.com> Cc: linux-bluetooth@vger.kernel.org Cc: netfilter-devel@vger.kernel.org Cc: bridge@lists.linux-foundation.org Cc: linux-wireless@vger.kernel.org Cc: linux1394-devel@lists.sourceforge.net Cc: linux-media@vger.kernel.org Cc: netdev@vger.kernel.org Cc: dev@openvswitch.org Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-27openvswitch: correct an invalid BUG_ONHong Zhiguo
table->count is uint32_t Signed-off-by: Hong Zhiguo <honkiko@gmail.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-27openvswitch: Preallocate reply skb in ovs_vport_cmd_set().Jesse Gross
Allocation of the Netlink notification skb can potentially fail after changing vport configuration. In general, we try to avoid this by undoing any change we made but that is difficult for existing objects. This avoids the problem by preallocating the buffer (which is fixed size). Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Pull in the 'net' tree to get Daniel Borkmann's flow dissector infrastructure change. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-17Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Conflicts: net/openvswitch/vport-internal_dev.c Jesse Gross says: ==================== A couple of minor enhancements for net-next/3.10. The largest is an extension to allow variable length metadata to be passed to userspace with packets. There is a merge conflict in net/openvswitch/vport-internal_dev.c: A existing commit modifies internal_dev_mac_addr() and a new commit deletes it. The new one is correct, so you can just remove that function. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-03-15Merge branch 'fixes' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/jesse/openvswitch Jesse Gross says: ==================== A few different bug fixes, including several for issues with userspace communication that have gone unnoticed up until now. These are intended for net/3.9. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22openvswitch: remove some useless commentsCong Wang
These comments are useless in upstream kernel. Cc: David S. Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: fix the calculation of checksum for vlan headerCong Wang
In vlan_insert_tag(), we insert a 4-byte VLAN header _after_ mac header: memmove(skb->data, skb->data + VLAN_HLEN, 2 * ETH_ALEN); ... veth->h_vlan_proto = htons(ETH_P_8021Q); ... veth->h_vlan_TCI = htons(vlan_tci); so after it, we should recompute the checksum to include these 4 bytes. skb->data still points to the mac header, therefore VLAN header is at (2 * ETH_ALEN = 12) bytes after it, not (ETH_HLEN = 14) bytes. This can also be observed via tcpdump: 0x0000: ffff ffff ffff 5254 005d 6f6e 8100 000a 0x0010: 0806 0001 0800 0604 0001 5254 005d 6f6e 0x0020: c0a8 026e 0000 0000 0000 c0a8 0282 Similar for __pop_vlan_tci(), the vlan header we remove is the one overwritten in: memmove(skb->data + VLAN_HLEN, skb->data, 2 * ETH_ALEN); Therefore the VLAN_HLEN = 4 bytes after 2 * ETH_ALEN is the part we want to sub from checksum. Cc: David S. Miller <davem@davemloft.net> Cc: Jesse Gross <jesse@nicira.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: Fix parsing invalid LLC/SNAP ethertypesRich Lane
Before this patch, if an LLC/SNAP packet with OUI 00:00:00 had an ethertype less than 1536 the flow key given to userspace in the upcall would contain the invalid ethertype (for example, 3). If userspace attempted to insert a kernel flow for this key it would be rejected by ovs_flow_from_nlattrs. This patch allows OVS to pass the OFTest pktact.DirectBadLlcPackets. Signed-off-by: Rich Lane <rlane@bigswitch.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: Call genlmsg_end in queue_userspace_packetRich Lane
Without genlmsg_end the upcall message ends (according to nlmsg_len) after the struct ovs_header. Signed-off-by: Rich Lane <rlane@bigswitch.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: Fix ovs_vport_cmd_new return value on successRich Lane
If the pointer does not represent an error then the PTR_ERR macro may still return a nonzero value. Signed-off-by: Rich Lane <rlane@bigswitch.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: Fix ovs_vport_cmd_del return value on successRich Lane
If the pointer does not represent an error then the PTR_ERR macro may still return a nonzero value. The fix is the same as in ovs_vport_cmd_set. Signed-off-by: Rich Lane <rlane@bigswitch.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-22openvswitch: Allow OVS_USERSPACE_ATTR_USERDATA to be variable length.Ben Pfaff
Until now, the optional OVS_USERSPACE_ATTR_USERDATA attribute had to be exactly 64 bits long, if it was present. However, 64 bits is not enough space to associate as much information with a flow as would be convenient for some userspace features now under development. This commit generalizes the attribute, allowing it to be any length. This generalization is backward-compatible: if userspace only uses 64-bit attributes, then it will not see any change in behavior. CC: Romain Lenglet <rlenglet@vmware.com> Signed-off-by: Ben Pfaff <blp@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-02-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Synchronize with 'net' in order to sort out some l2tp, wireless, and ipv6 GRE fixes that will be built on top of in 'net-next'. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-06net: adjust skb_gso_segment() for calling in rx pathCong Wang
skb_gso_segment() is almost always called in tx path, except for openvswitch. It calls this function when it receives the packet and tries to queue it to user-space. In this special case, the ->ip_summed check inside skb_gso_segment() is no longer true, as ->ip_summed value has different meanings on rx path. This patch adjusts skb_gso_segment() so that we can at least avoid such warnings on checksum. Cc: Jesse Gross <jesse@nicira.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21openvswitch: Move LRO check from transmit to receive.Jesse Gross
The check for LRO packets was incorrectly put in the transmit path instead of on receive. Since this check is supposed to protect OVS (and other parts of the system) from packets that it cannot handle it is obviously not useful on egress. Therefore, this commit moves it back to the receive side. The primary problem that this caused is upcalls to userspace tried to segment the packet even though no segmentation information is available. This would later cause NULL pointer dereferences when skb_gso_segment() did nothing. Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-01-09openvswitch: Use FIELD_SIZEOF() in dp_init().YOSHIFUJI Hideaki / 吉藤英明
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-09openvswitch: Change ENOENT return value to ENODEV in lookup_vport().Jarno Rajahalme
This reduces the number of valid "no such device" error values that need special attention by the caller. Userspace code will need to keep on checking for both ENODEV and ENOENT as long as older kernel modules are around. Signed-off-by: Jarno Rajahalme <jarno.rajahalme@nsn.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2013-01-06ethtool: fix drvinfo strings set in driversJiri Pirko
Use strlcpy where possible to ensure the string is \0 terminated. Use always sizeof(string) instead of 32, ETHTOOL_BUSINFO_LEN and custom defines. Use snprintf instead of sprint. Remove unnecessary inits of ->fw_version Remove unnecessary inits of drvinfo struct. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-03net: remove unnecessary NET_ADDR_RANDOM "bitclean"Jiri Pirko
NET_ADDR_SET is set in dev_set_mac_address() no need to alter dev->addr_assign_type value in drivers. Signed-off-by: Jiri Pirko <jiri@resnulli.us> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-04openvswitch: Avoid useless holes in struct vportThomas Graf
Having the 16bit port_no in between a set of pointers creates an unwanted and useless hole in the struct. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-12-04openvswitch: Use eth_mac_addr() instead of duplicating itThomas Graf
bonus: if we ever are to use IFF_LIVE_ADDR_CHANGE for anything further than to check availability in eth_mac_addr(), Open vSwitch will be ready for that. Signed-off-by: Thomas Graf <tgraf@redhat.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-11-28openvswitch: Use RCU callback when detaching netdevices.Jesse Gross
Currently, each time a device is detached from an OVS datapath we call synchronize RCU before freeing associated data structures. However, if a bridge is deleted (which detaches all ports) when many devices are connected then there can be a long delay. This switches to use call_rcu() to group the cost together. Reported-by: Justin Pettit <jpettit@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-11-26openvswitch: add skb mark matching and set actionAnsis Atteka
This patch adds support for skb mark matching and set action. Signed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-11-16net: openvswitch: use this_cpu_ptr per-cpu helperShan Wei
just use more faster this_cpu_ptr instead of per_cpu_ptr(p, smp_processor_id()); Signed-off-by: Shan Wei <davidshan@tencent.com> Reviewed-by: Christoph Lameter <cl@linux.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-11-13openvswitch: add ipv6 'set' actionAnsis Atteka
This patch adds ipv6 set action functionality. It allows to change traffic class, flow label, hop-limit, ipv6 source and destination address fields. Signed-off-by: Ansis Atteka <aatteka@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-11-02openvswitch: Process RARP packets with ethertype 0x8035 similar to ARP packets.Mehak Mahajan
With this commit, OVS will match the data in the RARP packets having ethertype 0x8035, in the same way as the data in the ARP packets. Signed-off-by: Mehak Mahajan <mmahajan@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-10-30openvswitch: Store flow key len if ARP opcode is not request or reply.Mehak Mahajan
We currently only extract the ARP payload if the opcode indicates that it is a request or reply. However, we also only set the key length in these situations even though it should still be possible to match on the opcode. There's no real reason to restrict the ARP opcode since all have the same format so this simply removes the check. Signed-off-by: Mehak Mahajan <mmahajan@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-10-30openvswitch: Print device when warning about over MTU packets.Jesse Gross
If an attempt is made to transmit a packet that is over the device's MTU then we log it using the datapath's name. However, it is much more helpful to use the device name instead. Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-09-18net/openvswitch/vport.c: Remove unecessary semicolonPeter Senna Tschudin
Found by http://coccinelle.lip6.fr/ Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/netfilter/nfnetlink_log.c net/netfilter/xt_LOG.c Rather easy conflict resolution, the 'net' tree had bug fixes to make sure we checked if a socket is a time-wait one or not and elide the logging code if so. Whereas on the 'net-next' side we are calculating the UID and GID from the creds using different interfaces due to the user namespace changes from Eric Biederman. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-04Merge branch 'master' of ↵David S. Miller
2012-09-03openvswitch: Increase maximum number of datapath ports.Pravin B Shelar
Use hash table to store ports of datapath. Allow 64K ports per switch. Signed-off-by: Pravin B Shelar <pshelar@nicira.com> Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-09-03openvswitch: Fix FLOW_BUFSIZE definition.Jesse Gross
The vlan encapsulation fields in the maximum flow defintion were never updated when the representation changed before upstreaming. In theory this could cause a kernel panic when a maximum length flow is used. In practice this has never happened (to my knowledge) because skb allocations are padded out to a cache line so you would need the right combination of flow and packet being sent to userspace. Signed-off-by: Jesse Gross <jesse@nicira.com>
2012-09-02openvswitch: Fix typoJoe Stringer
Signed-off-by: Joe Stringer <joe@wand.net.nz> Signed-off-by: Jesse Gross <jesse@nicira.com>
