[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
commit b4011239a08e7e6c2c6e970dfa9e8ecb73139261 upstream.
Without the new LLCP_CONNECTING state, non blocking sockets will be
woken up with a POLLHUP right after calling connect() because their
state is stuck at LLCP_CLOSED.
That prevents userspace from implementing any proper non blocking
socket based NFC p2p client.
The Kconfig symbol NFC_LLCP was removed in commit 30cc458765 ("NFC: Move
LLCP code to the NFC top level diirectory"). But the reference to its
macro in this Makefile was only commented out. Remove it now.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
drivers/net/ethernet/broadcom/bnx2x/bnx2x_main.c
drivers/net/ethernet/emulex/benet/be.h
include/net/tcp.h
net/mac802154/mac802154.h
Most conflicts were minor overlapping stuff.
The be2net driver brought in some fixes that added __vlan_put_tag
calls, which in net-next take an additional argument.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
Since the NFC subsystem gained RFKILL support, it needs to be able
to build properly with whatever option for RFKILL has been selected.
on i386:
net/built-in.o: In function `nfc_unregister_device':
(.text+0x6a36d): undefined reference to `rfkill_unregister'
(.text+0x6a378): undefined reference to `rfkill_destroy'
net/built-in.o: In function `nfc_register_device':
(.text+0x6a493): undefined reference to `rfkill_alloc'
(.text+0x6a4a4): undefined reference to `rfkill_register'
(.text+0x6a4b3): undefined reference to `rfkill_destroy'
net/built-in.o: In function `nfc_dev_up':
(.text+0x6a8e8): undefined reference to `rfkill_blocked'
when CONFIG_RFKILL=m but NFC is builtin.
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
And stop making it optional. LLCP is a fundamental part of the NFC
specifications and making it optional does not make much sense.
The sockaddr_nfc_llcp struct has as hole between ->sa_family and
->dev_idx so I've added a memset() to clear it and prevent an
information leak.
Also the ->nfc_protocol element wasn't set so I've added that.
"uaddr->sa_family" and "llcp_addr->sa_family" are the same thing but
it's less confusing to use llcp_addr consistently throughout.
All NFC devices will now get proper RFKILL support as long as they provide
some dev_up and dev_down hooks. Rfkilling an NFC device will bring it down
while it is left to userspace to bring it back up when being rfkill unblocked.
This is very similar to what Bluetooth does.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Some devices turn radio on whenever they're asked to start a poll.
To prevent that from happening, we just don't call into the driver
start_poll hook when the NFC device is down.
According to the LLCP specs, we must terminate the LLCP link when receiving
a DISC with both ssap and dsap set to 0.
local_cleanup is always called with device set to false as it means the
local LLCP is going away. So no need to pass this switch as an argument.
When the MAC goes down, connected and connection less sockets should be
notified, but raw sockets should be kept alive.
They will get notified only when the physical devices goes away.
Useful for LLCP validation tests.
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
This resets remote parameters in both local and socket llcp structures when the
link goes down. That way, nfc_llcp_getsockopt won't return values corresponding
to the previous link parameters.
If remote_miu value is not set in the socket (i.e. connection-less socket) the
value stored in the local is used.
This adds support for AGF PDUs. For each PDU contained in the AGF, a new sk_buff
is allocated and dispatched to its corresponding handler.
LLCP Validation test #2 (Connection-less information transfer) send a
service data unit of zero octets length. This is now handled correctly.
Signed-off-by: Olivier Guiter <olivier.guiter@linux.intel.com>
If a socket option has not been set by the user, fall back to the LLCP
local ones.
The MIUX must be transmitted in big endian and as such we have to convert
it properly.
drivers/net/wireless/rt2x00/rt2x00pci.c
drivers/nfc/microread/mei.c
net/netfilter/nfnetlink_queue_core.c
Pull in 'net' to get Eric Biederman's AF_UNIX fix, upon which
some cleanups are going to go on-top.
The code in llcp_sock_recvmsg() does not initialize all the members of
struct sockaddr_nfc_llcp when filling the sockaddr info. Nor does it
initialize the padding bytes of the structure inserted by the compiler
for alignment.
Also, if the socket is in state LLCP_CLOSED or is shutting down during
receive the msg_namelen member is not updated to 0 while otherwise
returning with 0, i.e. "success". The msg_namelen update is also
missing for stream and seqpacket sockets which don't fill the sockaddr
info.
Both issues lead to the fact that the code will leak uninitialized
kernel stack bytes in net/socket.c.
Fix the first issue by initializing the memory used for sockaddr info
with memset(0). Fix the second one by setting msg_namelen to 0 early.
It will be updated later if we're going to fill the msg_name member.
Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org>
Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Commit 7d4c04fc170087119727119074e72445f2bb192b ("net: add option to enable
error queue packets waking select") has an issue due to operator precedence
causing the bit-wise OR to bind to the sock_flags call instead of the result of
the terniary conditional. This fixes the *_poll functions to work properly. The
old code results in "mask |= POLLPRI" instead of what was intended, which is to
only include POLLPRI when the socket option is enabled.
Signed-off-by: Jacob Keller <jacob.e.keller@intel.com>
Currently, when a socket receives something on the error queue it only wakes up
the socket on select if it is in the "read" list, that is the socket has
something to read. It is useful also to wake the socket if it is in the error
list, which would enable software to wait on error queue packets without waking
up for regular data on the socket. The main use case is for receiving
timestamped transmit packets which return the timestamp to the socket via the
error queue. This enables an application to select on the socket for the error
queue only instead of for the regular traffic.
-v2-
* Added the SO_SELECT_ERR_QUEUE socket option to every architechture specific file
* Modified every socket poll function that checks error queue
Cc: Jeffrey Kirsher <jeffrey.t.kirsher@intel.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Matthew Vick <matthew.vick@intel.com>
And avoid decreasing the ack log twice when dequeueing connected LLCP
sockets.
kfree_skb was called twice when the socket receive queue is full
Calling sock_orphan when e.g. the NFC adapter is removed can lead to
kernel crashes when e.g. a connection less client is sleeping on the
Rx workqueue, waiting for data to show up.
net/nfc/llcp/llcp.c
If the remote LLC doesn't reply in time to our SNL requests we remove
them from the list of pending requests. The timeout is fixed to an
arbitrary value of 3 times remote_lto.
When not replied, the local LLC broadcasts NFC_EVENT_LLC_SDRES nl events for
the concerned uris with sap values set to LLCP_SDP_UNBOUND (which is 65).
This adds a netlink interface for service name lookup support.
Multiple URIs can be passed nested into the NFC_ATTR_LLC_SDP attribute
using the NFC_CMD_LLC_SDREQ netlink command.
When the SNL reply is received, a NFC_EVENT_LLC_SDRES event is sent to
the user space. URI and SAP tuples are passed back, nested into
NFC_ATTR_LLC_SDP attribute.
This modifies the way SDRES PDUs are sent back. If multiple SDREQs are
received within a single SNL PDU, all SDRES replies are sent packed in
one SNL PDU too.
We already have a pr_debug for that.
If the socket link options are set, use them before the local one.
Some LLCP services (e.g. the validation ones) require some control over
the LLCP link parameters like the receive window (RW) or the MIU extension
(MIUX). This can only be done through socket options.
They really are remote peer parameters, and we need to distinguish them
from the local ones as we'll modify the latter with socket options.
Whenever an adapter is removed we must clean all the local structures,
especially the timers and scheduled work. Otherwise those asynchronous
threads will eventually try to access the freed nfc_dev pointer if an LLCP
link is up.
This is really difficult to test with real NFC devices, but without
this fix an LLCP server will eventually refuse new connections.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core patches from Greg Kroah-Hartman:
"Here is the big driver core merge for 3.9-rc1
There are two major series here, both of which touch lots of drivers
all over the kernel, and will cause you some merge conflicts:
- add a new function called devm_ioremap_resource() to properly be
able to check return values.
- remove CONFIG_EXPERIMENTAL
Other than those patches, there's not much here, some minor fixes and
updates"
Fix up trivial conflicts
* tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits)
base: memory: fix soft/hard_offline_page permissions
drivercore: Fix ordering between deferred_probe and exiting initcalls
backlight: fix class_find_device() arguments
TTY: mark tty_get_device call with the proper const values
driver-core: constify data for class_find_device()
firmware: Ignore abort check when no user-helper is used
firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER
firmware: Make user-mode helper optional
firmware: Refactoring for splitting user-mode helper code
Driver core: treat unregistered bus_types as having no devices
watchdog: Convert to devm_ioremap_resource()
thermal: Convert to devm_ioremap_resource()
spi: Convert to devm_ioremap_resource()
power: Convert to devm_ioremap_resource()
mtd: Convert to devm_ioremap_resource()
mmc: Convert to devm_ioremap_resource()
mfd: Convert to devm_ioremap_resource()
media: Convert to devm_ioremap_resource()
iommu: Convert to devm_ioremap_resource()
drm: Convert to devm_ioremap_resource()
If gb_len is less than 3 it would cause an integer underflow and
possibly memory corruption in nfc_llcp_parse_gb_tlv().
I removed the old test for gb_len == 0. I also removed the test for
->remote_gb == NULL. It's not possible for ->remote_gb to be NULL and
we have already dereferenced ->remote_gb_len so it's too late to test.
The old test return -ENODEV but my test returns -EINVAL.
All in-kernel users of class_find_device() don't really need mutable
data for match callback.
In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c)
this patch changes match callbacks to use const search data.
The const is propagated to rtc_class_open() and power_supply_get_by_name()
parameters.
Note that there's a dev reference leak in suspend_test.c that's not
touched in this patch.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Safer and more robust than than memcpy_toiovec.
We can cast msg_name to a sockaddr_nfc_llcp pointer directly.
Each NFC adapter can have several links to different secure elements and
that property needs to be exported by the drivers.
A secure element link can be enabled and disabled, and card emulation will
be handled by the currently active one. Otherwise card emulation will be
host implemented.
Some chips diverge from the HCI spec in their implementation of standard
features. This adds a new quirks parameter to
nfc_hci_allocate_device() to let the driver indicate its divergence.
Signed-off-by: Eric Lapuyade <eric.lapuyade@intel.com>
