Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
Plug a group_info refcount leak in ping_init.
group_info is only needed during initialization and
the code failed to release the reference on exit.
While here move grabbing the reference to a place
where it is actually needed.
Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com>
Signed-off-by: Zhang Dongxing <dongxing.zhang@intel.com>
Signed-off-by: xiaoming wang <xiaoming.wang@intel.com>
[ Upstream commit 65886f439ab0fdc2dff20d1fa87afb98c6717472 ]
Commit 8cd3ac9f9b7b ("ipmr: advertise new mfc entries via rtnl") reuses the
function ipmr_fill_mroute() to notify mfc events.
But this function was used only for dump and thus was always setting the
flag NLM_F_MULTI, which is wrong in case of a single notification.
Libraries like libnl will wait forever for NLMSG_DONE.
CC: Thomas Graf <tgraf@suug.ch>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
[ Upstream commit c3f9b01849ef3bc69024990092b9f42e20df7797 ]
Lars Persson reported following deadlock :
-000 |M:0x0:0x802B6AF8(asm) <-- arch_spin_lock
-001 |tcp_v4_rcv(skb = 0x8BD527A0) <-- sk = 0x8BE6B2A0
-002 |ip_local_deliver_finish(skb = 0x8BD527A0)
-003 |__netif_receive_skb_core(skb = 0x8BD527A0, ?)
-004 |netif_receive_skb(skb = 0x8BD527A0)
-005 |elk_poll(napi = 0x8C770500, budget = 64)
-006 |net_rx_action(?)
-007 |__do_softirq()
-008 |do_softirq()
-009 |local_bh_enable()
-010 |tcp_rcv_established(sk = 0x8BE6B2A0, skb = 0x87D3A9E0, th = 0x814EBE14, ?)
-011 |tcp_v4_do_rcv(sk = 0x8BE6B2A0, skb = 0x87D3A9E0)
-012 |tcp_delack_timer_handler(sk = 0x8BE6B2A0)
-013 |tcp_release_cb(sk = 0x8BE6B2A0)
-014 |release_sock(sk = 0x8BE6B2A0)
-015 |tcp_sendmsg(?, sk = 0x8BE6B2A0, ?, ?)
-016 |sock_sendmsg(sock = 0x8518C4C0, msg = 0x87D8DAA8, size = 4096)
-017 |kernel_sendmsg(?, ?, ?, ?, size = 4096)
-018 |smb_send_kvec()
-019 |smb_send_rqst(server = 0x87C4D400, rqst = 0x87D8DBA0)
-020 |cifs_call_async()
-021 |cifs_async_writev(wdata = 0x87FD6580)
-022 |cifs_writepages(mapping = 0x852096E4, wbc = 0x87D8DC88)
-023 |__writeback_single_inode(inode = 0x852095D0, wbc = 0x87D8DC88)
-024 |writeback_sb_inodes(sb = 0x87D6D800, wb = 0x87E4A9C0, work = 0x87D8DD88)
-025 |__writeback_inodes_wb(wb = 0x87E4A9C0, work = 0x87D8DD88)
-026 |wb_writeback(wb = 0x87E4A9C0, work = 0x87D8DD88)
-027 |wb_do_writeback(wb = 0x87E4A9C0, force_wait = 0)
-028 |bdi_writeback_workfn(work = 0x87E4A9CC)
-029 |process_one_work(worker = 0x8B045880, work = 0x87E4A9CC)
-030 |worker_thread(__worker = 0x8B045880)
-031 |kthread(_create = 0x87CADD90)
-032 |ret_from_kernel_thread(asm)
Bug occurs because __tcp_checksum_complete_user() enables BH, assuming
it is running from softirq context.
Lars trace involved a NIC without RX checksum support but other points
are problematic as well, like the prequeue stuff.
Problem is triggered by a timer, that found socket being owned by user.
tcp_release_cb() should call tcp_write_timer_handler() or
tcp_delack_timer_handler() in the appropriate context :
BH disabled and socket lock held, but 'owned' field cleared,
as if they were running from timer handlers.
Fixes: 6f458dfb4092 ("tcp: improve latencies of timer triggered events")
Reported-by: Lars Persson <lars.persson@axis.com>
Tested-by: Lars Persson <lars.persson@axis.com>
[ Upstream commit e588e2f286ed7da011ed357c24c5b9a554e26595 ]
Quoting Alexander Aring:
While fragmentation and unloading of 6lowpan module I got this kernel Oops
after few seconds:
BUG: unable to handle kernel paging request at f88bbc30
Modules linked in: ipv6 [last unloaded: 6lowpan]
Call Trace:
[<c012af4c>] ? call_timer_fn+0x54/0xb3
[<c012aef8>] ? process_timeout+0xa/0xa
[<c012b66b>] run_timer_softirq+0x140/0x15f
Problem is that incomplete frags are still around after unload; when
their frag expire timer fires, we get crash.
When a netns is removed (also done when unloading module), inet_frag
calls the evictor with 'force' argument to purge remaining frags.
The evictor loop terminates when accounted memory ('work') drops to 0
or the lru-list becomes empty. However, the mem accounting is done
via percpu counters and may not be accurate, i.e. loop may terminate
prematurely.
Alter evictor to only stop once the lru list is empty when force is
requested.
Reported-by: Phoebe Buckheister <phoebe.buckheister@itwm.fraunhofer.de>
Reported-by: Alexander Aring <alex.aring@gmail.com>
Tested-by: Alexander Aring <alex.aring@gmail.com>
[ Upstream commit 24b9bf43e93e0edd89072da51cf1fab95fc69dec ]
I stumbled upon this very serious bug while hunting for another one,
it's a very subtle race condition between inet_frag_evictor,
inet_frag_intern and the IPv4/6 frag_queue and expire functions
(basically the users of inet_frag_kill/inet_frag_put).
What happens is that after a fragment has been added to the hash chain
but before it's been added to the lru_list (inet_frag_lru_add) in
inet_frag_intern, it may get deleted (either by an expired timer if
the system load is high or the timer sufficiently low, or by the
fraq_queue function for different reasons) before it's added to the
lru_list, then after it gets added it's a matter of time for the
evictor to get to a piece of memory which has been freed leading to a
number of different bugs depending on what's left there.
I've been able to trigger this on both IPv4 and IPv6 (which is normal
as the frag code is the same), but it's been much more difficult to
trigger on IPv4 due to the protocol differences about how fragments
are treated.
The setup I used to reproduce this is: 2 machines with 4 x 10G bonded
in a RR bond, so the same flow can be seen on multiple cards at the
same time. Then I used multiple instances of ping/ping6 to generate
fragmented packets and flood the machines with them while running
other processes to load the attacked machine.
*It is very important to have the _same flow_ coming in on multiple CPUs
concurrently. Usually the attacked machine would die in less than 30
minutes, if configured properly to have many evictor calls and timeouts
it could happen in 10 minutes or so.
An important point to make is that any caller (frag_queue or timer) of
inet_frag_kill will remove both the timer refcount and the
original/guarding refcount thus removing everything that's keeping the
frag from being freed at the next inet_frag_put. All of this could
happen before the frag was ever added to the LRU list, then it gets
added and the evictor uses a freed fragment.
An example for IPv6 would be if a fragment is being added and is at
the stage of being inserted in the hash after the hash lock is
released, but before inet_frag_lru_add executes (or is able to obtain
the lru lock) another overlapping fragment for the same flow arrives
at a different CPU which finds it in the hash, but since it's
overlapping it drops it invoking inet_frag_kill and thus removing all
guarding refcounts, and afterwards freeing it by invoking
inet_frag_put which removes the last refcount added previously by
inet_frag_find, then inet_frag_lru_add gets executed by
inet_frag_intern and we have a freed fragment in the lru_list.
The fix is simple, just move the lru_add under the hash chain locked
region so when a removing function is called it'll have to wait for
the fragment to be added to the lru_list, and then it'll remove it (it
works because the hash chain removal is done before the lru_list one
and there's no window between the two list adds when the frag can get
dropped). With this fix applied I couldn't kill the same machine in 24
hours with the same setup.
Fixes: 3ef0eb0db4bf ("net: frag, move LRU list maintenance outside of
rwlock")
CC: Florian Westphal <fw@strlen.de>
CC: Jesper Dangaard Brouer <brouer@redhat.com>
CC: David S. Miller <davem@davemloft.net>
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
[ Upstream commit f5ddcbbb40aa0ba7fbfe22355d287603dbeeaaac ]
This patch fixes two bugs in fastopen :
1) The tcp_sendmsg(..., @size) argument was ignored.
Code was relying on user not fooling the kernel with iovec mismatches
2) When MTU is about 64KB, tcp_send_syn_data() attempts order-5
allocations, which are likely to fail when memory gets fragmented.
Fixes: 783237e8daf13 ("net-tcp: Fast Open client - sending SYN-data")
Cc: Yuchung Cheng <ycheng@google.com>
Acked-by: Yuchung Cheng <ycheng@google.com>
Tested-by: Yuchung Cheng <ycheng@google.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Bug 1456092
Change-Id: I87b6b883c382000fc0dfee7c8d8f36269f504e46
commit fe6cc55f3a9a053482a76f5a6b2257cee51b4663 upstream.
Marcelo Ricardo Leitner reported problems when the forwarding link path
has a lower mtu than the incoming one if the inbound interface supports GRO.
Given:
Host <mtu1500> R1 <mtu1200> R2
Host sends tcp stream which is routed via R1 and R2. R1 performs GRO.
In this case, the kernel will fail to send ICMP fragmentation needed
messages (or pkt too big for ipv6), as GSO packets currently bypass dstmtu
checks in forward path. Instead, Linux tries to send out packets exceeding
the mtu.
When locking route MTU on Host (i.e., no ipv4 DF bit set), R1 does
not fragment the packets when forwarding, and again tries to send out
packets exceeding R1-R2 link mtu.
This alters the forwarding dstmtu checks to take the individual gso
segment lengths into account.
For ipv6, we send out pkt too big error for gso if the individual
segments are too big.
For ipv4, we either send icmp fragmentation needed, or, if the DF bit
is not set, perform software segmentation and let the output path
create fragments when the packet is leaving the machine.
It is not 100% correct as the error message will contain the headers of
the GRO skb instead of the original/segmented one, but it seems to
work fine in my (limited) tests.
Eric Dumazet suggested to simply shrink mss via ->gso_size to avoid
sofware segmentation.
However it turns out that skb_segment() assumes skb nr_frags is related
to mss size so we would BUG there. I don't want to mess with it considering
Herbert and Eric disagree on what the correct behavior should be.
Hannes Frederic Sowa notes that when we would shrink gso_size
skb_segment would then also need to deal with the case where
SKB_MAX_FRAGS would be exceeded.
This uses sofware segmentation in the forward path when we hit ipv4
non-DF packets and the outgoing link mtu is too small. Its not perfect,
but given the lack of bug reports wrt. GRO fwd being broken this is a
rare case anyway. Also its not like this could not be improved later
once the dust settles.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Reported-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
[ Upstream commit a6254864c08109c66a194612585afc0439005286 ]
since commit 89aef8921bf("ipv4: Delete routing cache."), the counter
in_slow_tot can't work correctly.
The counter in_slow_tot increase by one when fib_lookup() return successfully
in ip_route_input_slow(), but actually the dst struct maybe not be created and
cached, so we can increase in_slow_tot after the dst struct is created.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
[ Upstream commit bf06200e732de613a1277984bf34d1a21c2de03d ]
Commit 46d3ceabd8d9 ("tcp: TCP Small Queues") introduced a possible
regression for applications using TCP_NODELAY.
If TCP session is throttled because of tsq, we should consult
tp->nonagle when TX completion is done and allow us to send additional
segment, especially if this segment is not a full MSS.
Otherwise this segment is sent after an RTO.
[edumazet] : Cooked the changelog, added another fix about testing
sk_wmem_alloc twice because TX completion can happen right before
setting TSQ_THROTTLED bit.
This problem is particularly visible with recent auto corking,
but might also be triggered with low tcp_limit_output_bytes
values or NIC drivers delaying TX completion by hundred of usec,
and very low rtt.
Thomas Glanzmann for example reported an iscsi regression, caused
by tcp auto corking making this bug quite visible.
Fixes: 46d3ceabd8d9 ("tcp: TCP Small Queues")
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Reported-by: Thomas Glanzmann <thomas@glanzmann.de>
[ Upstream commit 63b5f152eb4a5bb79b9caf7ec37b4201d12f6e66 ]
On m68k/ARAnyM:
WARNING: CPU: 0 PID: 407 at net/ipv4/devinet.c:1599 0x316a99()
Modules linked in:
CPU: 0 PID: 407 Comm: ifconfig Not tainted
3.13.0-atari-09263-g0c71d68014d1 #1378
Stack from 10c4fdf0:
10c4fdf0 002ffabb 000243e8 00000000 008ced6c 00024416 00316a99 0000063f
00316a99 00000009 00000000 002501b4 00316a99 0000063f c0a86117 00000080
c0a86117 00ad0c90 00250a5a 00000014 00ad0c90 00000000 00000000 00000001
00b02dd0 00356594 00000000 00356594 c0a86117 eff6c9e4 008ced6c 00000002
008ced60 0024f9b4 00250b52 00ad0c90 00000000 00000000 00252390 00ad0c90
eff6c9e4 0000004f 00000000 00000000 eff6c9e4 8000e25c eff6c9e4 80001020
Call Trace: [<000243e8>] warn_slowpath_common+0x52/0x6c
[<00024416>] warn_slowpath_null+0x14/0x1a
[<002501b4>] rtmsg_ifa+0xdc/0xf0
[<00250a5a>] __inet_insert_ifa+0xd6/0x1c2
[<0024f9b4>] inet_abc_len+0x0/0x42
[<00250b52>] inet_insert_ifa+0xc/0x12
[<00252390>] devinet_ioctl+0x2ae/0x5d6
Adding some debugging code reveals that net_fill_ifaddr() fails in
put_cacheinfo(skb, ifa->ifa_cstamp, ifa->ifa_tstamp,
preferred, valid))
nla_put complains:
lib/nlattr.c:454: skb_tailroom(skb) = 12, nla_total_size(attrlen) = 20
Apparently commit 5c766d642bcaffd0c2a5b354db2068515b3846cf ("ipv4:
introduce address lifetime") forgot to take into account the addition of
struct ifa_cacheinfo in inet_nlmsg_size(). Hence add it, like is already
done for ipv6.
Suggested-by: Cong Wang <cwang@twopensource.com>
Signed-off-by: Cong Wang <cwang@twopensource.com>
The default initial rwnd is hardcoded to 10.
Now we allow it to be controlled via
/proc/sys/net/ipv4/tcp_default_init_rwnd
which limits the values from 3 to 100
This is somewhat needed because ipv6 routes are
autoconfigured by the kernel.
See "An Argument for Increasing TCP's Initial Congestion Window"
in https://developers.google.com/speed/articles/tcp_initcwnd_paper.pdf
Change-Id: I386b2a9d62de0ebe05c1ebe1b4bd91b314af5c54
Signed-off-by: JP Abgrall <jpa@google.com>
net/ipv4/sysctl_net_ipv4.c
net/ipv4/tcp_input.c
[ Upstream commit a452ce345d63ddf92cd101e4196569f8718ad319 ]
I see a memory leak when using a transparent HTTP proxy using TPROXY
together with TCP early demux and Kernel v3.8.13.15 (Ubuntu stable):
unreferenced object 0xffff88008cba4a40 (size 1696):
comm "softirq", pid 0, jiffies 4294944115 (age 8907.520s)
hex dump (first 32 bytes):
0a e0 20 6a 40 04 1b 37 92 be 32 e2 e8 b4 00 00 .. j@..7..2.....
02 00 07 01 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff810b710a>] kmem_cache_alloc+0xad/0xb9
[<ffffffff81270185>] sk_prot_alloc+0x29/0xc5
[<ffffffff812702cf>] sk_clone_lock+0x14/0x283
[<ffffffff812aaf3a>] inet_csk_clone_lock+0xf/0x7b
[<ffffffff8129a893>] netlink_broadcast+0x14/0x16
[<ffffffff812c1573>] tcp_create_openreq_child+0x1b/0x4c3
[<ffffffff812c033e>] tcp_v4_syn_recv_sock+0x38/0x25d
[<ffffffff812c13e4>] tcp_check_req+0x25c/0x3d0
[<ffffffff812bf87a>] tcp_v4_do_rcv+0x287/0x40e
[<ffffffff812a08a7>] ip_route_input_noref+0x843/0xa55
[<ffffffff812bfeca>] tcp_v4_rcv+0x4c9/0x725
[<ffffffff812a26f4>] ip_local_deliver_finish+0xe9/0x154
[<ffffffff8127a927>] __netif_receive_skb+0x4b2/0x514
[<ffffffff8127aa77>] process_backlog+0xee/0x1c5
[<ffffffff8127c949>] net_rx_action+0xa7/0x200
[<ffffffff81209d86>] add_interrupt_randomness+0x39/0x157
But there are many more, resulting in the machine going OOM after some
days.
From looking at the TPROXY code, and with help from Florian, I see
that the memory leak is introduced in tcp_v4_early_demux():
void tcp_v4_early_demux(struct sk_buff *skb)
iph = ip_hdr(skb);
th = tcp_hdr(skb);
if (th->doff < sizeof(struct tcphdr) / 4)
return;
sk = __inet_lookup_established(dev_net(skb->dev), &tcp_hashinfo,
iph->saddr, th->source,
iph->daddr, ntohs(th->dest),
skb->skb_iif);
if (sk) {
skb->sk = sk;
where the socket is assigned unconditionally to skb->sk, also bumping
the refcnt on it. This is problematic, because in our case the skb
has already a socket assigned in the TPROXY target. This then results
in the leak I see.
The very same issue seems to be with IPv6, but haven't tested.
Reviewed-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
[ Upstream commit a0065f266a9b5d51575535a25c15ccbeed9a9966 ]
The two commits 0115e8e30d (net: remove delay at device dismantle) and
748e2d9396a (net: reinstate rtnl in call_netdevice_notifiers()) silently
removed a NULL pointer check for in_dev since Linux 3.7.
This patch re-introduces this check as it causes crashing the kernel when
setting small mtu values on non-ip capable netdevices.
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
[ Upstream commit 11c21a307d79ea5f6b6fc0d3dfdeda271e5e65f6 ]
commit a622260254ee48("ip_tunnel: fix kernel panic with icmp_dest_unreach")
clear IPCB in ip_tunnel_xmit() , or else skb->cb[] may contain garbage from
GSO segmentation layer.
But commit 0e6fbc5b6c621("ip_tunnels: extend iptunnel_xmit()") refactor codes,
and it clear IPCB behind the dst_link_failure().
So clear IPCB in ip_tunnel_xmit() just like commti a622260254ee48("ip_tunnel:
fix kernel panic with icmp_dest_unreach").
[ Upstream commit 77f99ad16a07aa062c2d30fae57b1fee456f6ef6 ]
Because the tcp-metrics is an RCU-list, it may be that two
soft-interrupts are inside __tcp_get_metrics() for the same
destination-IP at the same time. If this destination-IP is not yet part of
the tcp-metrics, both soft-interrupts will end up in tcpm_new and create
a new entry for this IP.
So, we will have two tcp-metrics with the same destination-IP in the list.
This patch checks twice __tcp_get_metrics(). First without holding the
lock, then while holding the lock. The second one is there to confirm
that the entry has not been added by another soft-irq while waiting for
the spin-lock.
Fixes: 51c5d0c4b169b (tcp: Maintain dynamic metrics in local cache.)
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 95f4a45de1a0f172b35451fc52283290adb21f6e ]
Bob Falken reported that after 4G packets, multicast forwarding stopped
working. This was because of a rule reference counter overflow which
freed the rule as soon as the overflow happend.
This patch solves this by adding the FIB_LOOKUP_NOREF flag to
fib_rules_lookup calls. This is safe even from non-rcu locked sections
as in this case the flag only implies not taking a reference to the rule,
which we don't need at all.
Rules only hold references to the namespace, which are guaranteed to be
available during the call of the non-rcu protected function reg_vif_xmit
because of the interface reference which itself holds a reference to
the net namespace.
Fixes: f0ad0860d01e47 ("ipv4: ipmr: support multiple tables")
Fixes: d1db275dd3f6e4 ("ipv6: ip6mr: support multiple tables")
Reported-by: Bob Falken <NetFestivalHaveFun@gmx.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Julian Anastasov <ja@ssi.bg>
[ Based upon upstream commit 70315d22d3c7383f9a508d0aab21e2eb35b2303a ]
Fix inet_diag_dump_icsk() to reflect the fact that both TIME_WAIT and
FIN_WAIT2 connections are represented by inet_timewait_sock (not just
TIME_WAIT). Thus:
(a) We need to iterate through the time_wait buckets if the user wants
either TIME_WAIT or FIN_WAIT2. (Before fixing this, "ss -nemoi state
fin-wait-2" would not return any sockets, even if there were some in
FIN_WAIT2.)
(b) We need to check tw_substate to see if the user wants to dump
sockets in the particular substate (TIME_WAIT or FIN_WAIT2) that a
given connection is in. (Before fixing this, "ss -nemoi state
time-wait" would actually return sockets in state FIN_WAIT2.)
An analogous fix is in v3.13: 70315d22d3c7383f9a508d0aab21e2eb35b2303a
("inet_diag: fix inet_diag_dump_icsk() to use correct state for
timewait sockets") but that patch is quite different because 3.13 code
is very different in this area due to the unification of TCP hash
tables in 05dbc7b ("tcp/dccp: remove twchain") in v3.13-rc1.
I tested that this applies cleanly between v3.3 and v3.12, and tested
that it works in both 3.3 and 3.12. It does not apply cleanly to 3.2
and earlier (though it makes semantic sense), and semantically is not
the right fix for 3.13 and beyond (as mentioned above).
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Eric Dumazet <edumazet@google.com>
A plain read() on a socket does set msg->msg_name to NULL. So check for
NULL pointer first.
[Backport of net-next cf970c002d270c36202bd5b9c2804d3097a52da0]
Bug: 12780426
Change-Id: I3df76aca2fa56478b9a33c404f7b1f0940475ef7
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
[net-next commit c26d6b46da3ee86fa8a864347331e5513ca84c2b]
If we don't need scope id, we should initialize it to zero.
Same for ->sin6_flowinfo.
Bug: 12800827
Change-Id: Ic19792cee3f5dc30237562cf48e6bdf49817c96e
Cc: Lorenzo Colitti <lorenzo@google.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
Acked-by: Lorenzo Colitti <lorenzo@google.com>
[net-next commit 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67]
This adds the ability to send ICMPv6 echo requests without a
raw socket. The equivalent ability for ICMPv4 was added in
2011.
Instead of having separate code paths for IPv4 and IPv6, make
most of the code in net/ipv4/ping.c dual-stack and only add a
few IPv6-specific bits (like the protocol definition) to a new
net/ipv6/ping.c. Hopefully this will reduce divergence and/or
duplication of bugs in the future.
Caveats:
- Setting options via ancillary data (e.g., using IPV6_PKTINFO
to specify the outgoing interface) is not yet supported.
- There are no separate security settings for IPv4 and IPv6;
everything is controlled by /proc/net/ipv4/ping_group_range.
- The proc interface does not yet display IPv6 ping sockets
properly.
Tested with a patched copy of ping6 and using raw socket calls.
Compiles and works with all of CONFIG_IPV6={n,m,y}.
Bug: 12800827
Change-Id: I718cd9931823873ab44df22e8a66e12d6a0a6eb1
[ Upstream commit b1aac815c0891fe4a55a6b0b715910142227700f ]
Jakub reported while working with nlmon netlink sniffer that parts of
the inet_diag_sockid are not initialized when r->idiag_family != AF_INET6.
That is, fields of r->id.idiag_src[1 ... 3], r->id.idiag_dst[1 ... 3].
In fact, it seems that we can leak 6 * sizeof(u32) byte of kernel [slab]
memory through this. At least, in udp_dump_one(), we allocate a skb in ...
rep = nlmsg_new(sizeof(struct inet_diag_msg) + ..., GFP_KERNEL);
... and then pass that to inet_sk_diag_fill() that puts the whole struct
inet_diag_msg into the skb, where we only fill out r->id.idiag_src[0],
r->id.idiag_dst[0] and leave the rest untouched:
r->id.idiag_src[0] = inet->inet_rcv_saddr;
r->id.idiag_dst[0] = inet->inet_daddr;
struct inet_diag_msg embeds struct inet_diag_sockid that is correctly /
fully filled out in IPv6 case, but for IPv4 not.
So just zero them out by using plain memset (for this little amount of
bytes it's probably not worth the extra check for idiag_family == AF_INET).
Similarly, fix also other places where we fill that out.
Reported-by: Jakub Zawadzki <darkjames-ws@darkjames.pl>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
[ Upstream commit 0e3da5bb8da45890b1dc413404e0f978ab71173e ]
ipgre_header_parse() needs to parse the tunnel's ip header and it
uses mac_header to locate the iphdr. This got broken when gre tunneling
was refactored as mac_header is no longer updated to point to iphdr.
Introduce skb_pop_mac_header() helper to do the mac_header assignment
and use it in ipgre_rcv() to fix msg_name parsing.
Bug introduced in commit c54419321455 (GRE: Refactor GRE tunneling code.)
Cc: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
It turns out that commit: d3f7d56a7a4671d395e8af87071068a195257bf6 was
applied to the tree twice, which didn't hurt anything, but it's good to
fix this up.
Reported-by: Veaceslav Falico <veaceslav@falico.eu>
Cc: Richard Weinberger <richard@nod.at>
Cc: Shawn Landden <shawnlandden@gmail.com>
Cc: Tom Herbert <therbert@google.com>
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit d3f7d56a7a4671d395e8af87071068a195257bf6 upstream.
Commit 35f9c09fe (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag MSG_SENDPAGE_NOTLAST, similar to
MSG_MORE.
algif_hash, algif_skcipher, and udp used MSG_MORE from tcp_sendpages()
and need to see the new flag as identical to MSG_MORE.
This fixes sendfile() on AF_ALG.
v3: also fix udp
Reported-and-tested-by: Shawn Landden <shawnlandden@gmail.com>
Original-patch: Richard Weinberger <richard@nod.at>
Signed-off-by: Shawn Landden <shawn@churchofgit.com>
[ Upstream commit 0d08c42cf9a71530fef5ebcfe368f38f2dd0476f ]
commit 6ff50cd55545 ("tcp: gso: do not generate out of order packets")
had an heuristic that can trigger a warning in skb_try_coalesce(),
because skb->truesize of the gso segments were exactly set to mss.
This breaks the requirement that
skb->truesize >= skb->len + truesizeof(struct sk_buff);
It can trivially be reproduced by :
ifconfig lo mtu 1500
ethtool -K lo tso off
netperf
As the skbs are looped into the TCP networking stack, skb_try_coalesce()
warns us of these skb under-estimating their truesize.
Reported-by: Alexei Starovoitov <ast@plumgrid.com>
[ Upstream commit f1d8cba61c3c4b1eb88e507249c4cb8d635d9a76 ]
In commit c9e9042994d3 ("ipv4: fix possible seqlock deadlock") I left
another places where IP_INC_STATS_BH() were improperly used.
udp_sendmsg(), ping_v4_sendmsg() and tcp_v4_connect() are called from
process context, not from softirq context.
This was detected by lockdep seqlock support.
Reported-by: jongman heo <jongman.heo@samsung.com>
Fixes: 584bdf8cbdf6 ("[IPV4]: Fix "ipOutNoRoutes" counter error for TCP and UDP")
Fixes: c319b4d76b9e ("net: ipv4: add IPPROTO_ICMP socket kind")
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
[ Upstream commit d3f7d56a7a4671d395e8af87071068a195257bf6 ]
MSG_MORE.
v3: also fix udp
[ Upstream commit dcdfdf56b4a6c9437fc37dbc9cee94a788f9b0c4 ]
CPUs can ask for local route via ip_route_input_noref() concurrently.
if nh_rth_input is not cached yet, CPUs will proceed to allocate
equivalent DSTs on 'lo' and then will try to cache them in nh_rth_input
via rt_cache_route()
Most of the time they succeed, but on occasion the following two lines:
orig = *p;
prev = cmpxchg(p, orig, rt);
in rt_cache_route() do race and one of the cpus fails to complete cmpxchg.
But ip_route_input_slow() doesn't check the return code of rt_cache_route(),
so dst is leaking. dst_destroy() is never called and 'lo' device
refcnt doesn't go to zero, which can be seen in the logs as:
unregister_netdevice: waiting for lo to become free. Usage count = 1
Adding mdelay() between above two lines makes it easily reproducible.
Fix it similar to nh_pcpu_rth_output case.
Fixes: d2d68ba9fe8b ("ipv4: Cache input routes in fib_info nexthops.")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
[ Upstream commit dbde497966804e63a38fdedc1e3815e77097efc2 ]
snd_nxt must be updated synchronously with sk_send_head. Otherwise
tp->packets_out may be updated incorrectly, what may bring a kernel panic.
Here is a kernel panic from my host.
[ 103.043194] BUG: unable to handle kernel NULL pointer dereference at 0000000000000048
[ 103.044025] IP: [<ffffffff815aaaaf>] tcp_rearm_rto+0xcf/0x150
[ 146.301158] Call Trace:
[ 146.301158] [<ffffffff815ab7f0>] tcp_ack+0xcc0/0x12c0
Before this panic a tcp socket was restored. This socket had sent and
unsent data in the write queue. Sent data was restored in repair mode,
then the socket was switched from reapair mode and unsent data was
restored. After that the socket was switched back into repair mode.
In that moment we had a socket where write queue looks like this:
snd_una snd_nxt write_seq
|_________|________|
sk_send_head
After a second switching from repair mode the state of socket was
changed:
snd_una snd_nxt, write_seq
|_________ ________|
sk_send_head
This state is inconsistent, because snd_nxt and sk_send_head are not
synchronized.
Bellow you can find a call trace, how packets_out can be incremented
twice for one skb, if snd_nxt and sk_send_head are not synchronized.
In this case packets_out will be always positive, even when
sk_write_queue is empty.
tcp_write_wakeup
skb = tcp_send_head(sk);
tcp_fragment
if (!before(tp->snd_nxt, TCP_SKB_CB(buff)->end_seq))
tcp_adjust_pcount(sk, skb, diff);
tcp_event_new_data_sent
tp->packets_out += tcp_skb_pcount(skb);
I think update of snd_nxt isn't required, when a socket is switched from
repair mode. Because it's initialized in tcp_connect_init. Then when a
write queue is restored, snd_nxt is incremented in tcp_event_new_data_sent,
so it's always is in consistent state.
I have checked, that the bug is not reproduced with this patch and
all tests about restoring tcp connections work fine.
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
[ Upstream commit 236c9f84868534c718b6889aa624de64763281f9 ]
After searching rt by the vti tunnel dst/src parameter,
if this rt has neither attached to any transformation
nor the transformation is not tunnel oriented, this rt
should be released back to ip layer.
otherwise causing dst memory leakage.
Signed-off-by: Fan Du <fan.du@windriver.com>
functions
[ Upstream commit 85fbaa75037d0b6b786ff18658ddf0b4014ce2a4 ]
Commit bceaa90240b6019ed73b49965eac7d167610be69 ("inet: prevent leakage
of uninitialized memory to user in recv syscalls") conditionally updated
addr_len if the msg_name is written to. The recv_error and rxpmtu
functions relied on the recvmsg functions to set up addr_len before.
As this does not happen any more we have to pass addr_len to those
functions as well and set it to the size of the corresponding sockaddr
length.
This broke traceroute and such.
Fixes: bceaa90240b6 ("inet: prevent leakage of uninitialized memory to user in recv syscalls")
Reported-by: Brad Spengler <spender@grsecurity.net>
Reported-by: Tom Labanowski
Cc: mpb <mpb.mail@gmail.com>
[ Upstream commit bceaa90240b6019ed73b49965eac7d167610be69 ]
Only update *addr_len when we actually fill in sockaddr, otherwise we
can return uninitialized memory from the stack to the caller in the
recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL)
checks because we only get called with a valid addr_len pointer either
from sock_common_recvmsg or inet_recvmsg.
If a blocking read waits on a socket which is concurrently shut down we
now return zero and set msg_msgnamelen to 0.
Reported-by: mpb <mpb.mail@gmail.com>
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit c9e9042994d37cbc1ee538c500e9da1bb9d1bcdf ]
ip4_datagram_connect() being called from process context,
it should use IP_INC_STATS() instead of IP_INC_STATS_BH()
otherwise we can deadlock on 32bit arches, or get corruptions of
SNMP counters.
Reported-by: Dave Jones <davej@redhat.com>
[ Upstream commit dccf76ca6b626c0c4a4e09bb221adee3270ab0ef ]
We had some reports of crashes using TCP fastopen, and Dave Jones
gave a nice stack trace pointing to the error.
Issue is that tcp_get_metrics() should not be called with a NULL dst
Fixes: 1fe4c481ba637 ("net-tcp: Fast Open client - cookie cache")
Tested-by: Dave Jones <davej@fedoraproject.org>
[ Upstream commit 98e09386c0ef4dfd48af7ba60ff908f0d525cdee ]
After commit c9eeec26e32e ("tcp: TSQ can use a dynamic limit"), several
users reported throughput regressions, notably on mvneta and wifi
adapters.
802.11 AMPDU requires a fair amount of queueing to be effective.
This patch partially reverts the change done in tcp_write_xmit()
so that the minimal amount is sysctl_tcp_limit_output_bytes.
It also remove the use of this sysctl while building skb stored
in write queue, as TSO autosizing does the right thing anyway.
Users with well behaving NICS and correct qdisc (like sch_fq),
can then lower the default sysctl_tcp_limit_output_bytes value from
128KB to 8KB.
This new usage of sysctl_tcp_limit_output_bytes permits each driver
authors to check how their driver performs when/if the value is set
to a minimum of 4KB.
Normally, line rate for a single TCP flow should be possible,
but some drivers rely on timers to perform TX completion and
too long TX completion delays prevent reaching full throughput.
Fixes: c9eeec26e32e ("tcp: TSQ can use a dynamic limit")
Reported-by: Sujith Manoharan <sujith@msujith.org>
Reported-by: Arnaud Ebalard <arno@natisbad.org>
Tested-by: Sujith Manoharan <sujith@msujith.org>
Cc: Felix Fietkau <nbd@openwrt.org>
Bug 1412141
Change-Id: I74764edf3d0567f5ae094b2e83484cdfe05f6098
(cherry picked from commit 14e41a18688ec8d52ea3163f7898455b52365854)
Reviewed-on: http://git-master/r/336270
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Reviewed-on: http://git-master/r/337765
Reviewed-by: Om Prakash Singh <omp@nvidia.com>
Tested-by: Om Prakash Singh <omp@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
[backport of net-next 6d0bfe22611602f36617bc7aa2ffa1bbb2f54c67]
2011.
Caveats:
properly.
Bug 1412141
Change-Id: I0081b4654dd54b12c8f233e00e18943582aa2142
[lorenzo@google.com: backported to 3.4]
(cherry picked from commit 1f0675844e3b63a765e5bd32bc5af051ccd951c0)
Reviewed-on: http://git-master/r/336269
include/net/ipv6.h
net/ipv4/af_inet.c
net/ipv4/icmp.c
net/ipv4/ping.c
net/ipv6/Makefile
net/ipv6/af_inet6.c
net/ipv6/icmp.c
Change-Id: I6300756942bcf23f4745400c53fdb33301e9815f
Reviewed-on: http://git-master/r/337764
[ No applicable upstream commit, the upstream implementation is
now completely different and doesn't have this bug. ]
In case of WCCPv2 GRE header has extra four bytes. Following
patch pull those extra four bytes so that skb offsets are set
correctly.
CC: Eric Dumazet <eric.dumazet@gmail.com>
Reported-by: Peter Schmitt <peter.schmitt82@yahoo.de>
Tested-by: Peter Schmitt <peter.schmitt82@yahoo.de>
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
[ This is a simplified -stable version of a set of upstream commits. ]
This is a replacement patch only for stable which does fix the problems
handled by the following two commits in -net:
"ip_output: do skb ufo init for peeked non ufo skb as well" (e93b7d748be887cd7639b113ba7d7ef792a7efb9)
"ip6_output: do skb ufo init for peeked non ufo skb as well" (c547dbf55d5f8cf615ccc0e7265e98db27d3fb8b)
Three frames are written on a corked udp socket for which the output
netdevice has UFO enabled. If the first and third frame are smaller than
the mtu and the second one is bigger, we enqueue the second frame with
skb_append_datato_frags without initializing the gso fields. This leads
to the third frame appended regulary and thus constructing an invalid skb.
This fixes the problem by always using skb_append_datato_frags as soon
as the first frag got enqueued to the skb without marking the packet
as SKB_GSO_UDP.
The problem with only two frames for ipv6 was fixed by "ipv6: udp
packets following an UFO enqueued packet need also be handled by UFO"
(2811ebac2521ceac84f2bdae402455baa6a7fb47).
Cc: Jiri Pirko <jiri@resnulli.us>
[ Upstream commit 7263a5187f9e9de45fcb51349cf0e031142c19a1 ]
This patch fixes and improves the use of vti interfaces (while
lightly changing the way of configuring them).
Currently:
- it is necessary to identify and mark inbound IPsec
packets destined to each vti interface, via netfilter rules in
the mangle table at prerouting hook.
- the vti module cannot retrieve the right tunnel in input since
commit b9959fd3: vti tunnels all have an i_key, but the tunnel lookup
is done with flag TUNNEL_NO_KEY, so there no chance to retrieve them.
- the i_key is used by the outbound processing as a mark to lookup
for the right SP and SA bundle.
This patch uses the o_key to store the vti mark (instead of i_key) and
enables:
- to avoid the need for previously marking the inbound skbuffs via a
netfilter rule.
- to properly retrieve the right tunnel in input, only based on the IPsec
packet outer addresses.
- to properly perform an inbound policy check (using the tunnel o_key
as a mark).
- to properly perform an outbound SPD and SAD lookup (using the tunnel
o_key as a mark).
- to keep the current mark of the skbuff. The skbuff mark is neither
used nor changed by the vti interface. Only the vti interface o_key
is used.
SAs have a wildcard mark.
SPs have a mark equal to the vti interface o_key.
The vti interface must be created as follows (i_key = 0, o_key = mark):
ip link add vti1 mode vti local 1.1.1.1 remote 2.2.2.2 okey 1
The SPs attached to vti1 must be created as follows (mark = vti1 o_key):
ip xfrm policy add dir out mark 1 tmpl src 1.1.1.1 dst 2.2.2.2 \
proto esp mode tunnel
ip xfrm policy add dir in mark 1 tmpl src 2.2.2.2 dst 1.1.1.1 \
The SAs are created with the default wildcard mark. There is no
distinction between global vs. vti SAs. Just their addresses will
possibly link them to a vti interface:
ip xfrm state add src 1.1.1.1 dst 2.2.2.2 proto esp spi 1000 mode tunnel \
enc "cbc(aes)" "azertyuiopqsdfgh"
ip xfrm state add src 2.2.2.2 dst 1.1.1.1 proto esp spi 2000 mode tunnel \
enc "cbc(aes)" "sqbdhgqsdjqjsdfh"
To avoid matching "global" (not vti) SPs in vti interfaces, global SPs
should no use the default wildcard mark, but explicitly match mark 0.
To avoid a double SPD lookup in input and output (in global and vti SPDs),
the NOPOLICY and NOXFRM options should be set on the vti interfaces:
echo 1 > /proc/sys/net/ipv4/conf/vti1/disable_policy
echo 1 > /proc/sys/net/ipv4/conf/vti1/disable_xfrm
The outgoing traffic is steered to vti1 by a route via the vti interface:
ip route add 192.168.0.0/16 dev vti1
The incoming IPsec traffic is steered to vti1 because its outer addresses
match the vti1 tunnel configuration.
Signed-off-by: Christophe Gouault <christophe.gouault@6wind.com>
[ Upstream commit 0a7e22609067ff524fc7bbd45c6951dd08561667 ]
When sending out multicast messages, the source address in inet->mc_addr is
ignored and rewritten by an autoselected one. This is caused by a typo in
commit 813b3b5db831 ("ipv4: Use caller's on-stack flowi as-is in output
route lookups").
Signed-off-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 80ad1d61e72d626e30ebe8529a0455e660ca4693 ]
commit 3ab5aee7fe84 ("net: Convert TCP & DCCP hash tables to use RCU /
hlist_nulls") incorrectly used sock_put() on TIMEWAIT sockets.
We should instead use inet_twsk_put()
[ Upstream commit 031afe4990a7c9dbff41a3a742c44d3e740ea0a1 ]
On receiving an ACK that covers the loss probe sequence, TLP
immediately sets the congestion state to Open, even though some packets
are not recovered and retransmisssion are on the way. The later ACks
may trigger a WARN_ON check in step D of tcp_fastretrans_alert(), e.g.,
https://bugzilla.redhat.com/show_bug.cgi?id=989251
The fix is to follow the similar procedure in recovery by calling
tcp_try_keep_open(). The sender switches to Open state if no packets
are retransmissted. Otherwise it goes to Disorder and let subsequent
ACKs move the state to Recovery or Open.
Reported-By: Michael Sterrett <michael@sterretts.net>
Tested-By: Dormando <dormando@rydia.net>
Signed-off-by: Yuchung Cheng <ycheng@google.com>
Acked-by: Neal Cardwell <ncardwell@google.com>
[ Upstream commit 5e8a402f831dbe7ee831340a91439e46f0d38acd ]
Yuchung found following problem :
There are bugs in the SACK processing code, merging part in
tcp_shift_skb_data(), that incorrectly resets or ignores the sacked
skbs FIN flag. When a receiver first SACK the FIN sequence, and later
throw away ofo queue (e.g., sack-reneging), the sender will stop
retransmitting the FIN flag, and hangs forever.
Following packetdrill test can be used to reproduce the bug.
$ cat sack-merge-bug.pkt
`sysctl -q net.ipv4.tcp_fack=0`
// Establish a connection and send 10 MSS.
0.000 socket(..., SOCK_STREAM, IPPROTO_TCP) = 3
+.000 setsockopt(3, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
+.000 bind(3, ..., ...) = 0
+.000 listen(3, 1) = 0
+.050 < S 0:0(0) win 32792 <mss 1000,sackOK,nop,nop,nop,wscale 7>
+.000 > S. 0:0(0) ack 1 <mss 1460,nop,nop,sackOK,nop,wscale 6>
+.001 < . 1:1(0) ack 1 win 1024
+.000 accept(3, ..., ...) = 4
+.100 write(4, ..., 12000) = 12000
+.000 shutdown(4, SHUT_WR) = 0
+.000 > . 1:10001(10000) ack 1
+.050 < . 1:1(0) ack 2001 win 257
+.000 > FP. 10001:12001(2000) ack 1
+.050 < . 1:1(0) ack 2001 win 257 <sack 10001:11001,nop,nop>
+.050 < . 1:1(0) ack 2001 win 257 <sack 10001:12002,nop,nop>
// SACK reneg
+.050 < . 1:1(0) ack 12001 win 257
+0 %{ print "unacked: ",tcpi_unacked }%
+5 %{ print "" }%
First, a typo inverted left/right of one OR operation, then
code forgot to advance end_seq if the merged skb carried FIN.
Bug was added in 2.6.29 by commit 832d11c5cd076ab
("tcp: Try to restore large SKBs while SACK processing")
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Acked-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
[ Upstream commit c52e2421f7368fd36cbe330d2cf41b10452e39a9 ]
TCP stack should make sure it owns skbs before mangling them.
We had various crashes using bnx2x, and it turned out gso_size
was cleared right before bnx2x driver was populating TC descriptor
of the _previous_ packet send. TCP stack can sometime retransmit
packets that are still in Qdisc.
Of course we could make bnx2x driver more robust (using
ACCESS_ONCE(shinfo->gso_size) for example), but the bug is TCP stack.
We have identified two points where skb_unclone() was needed.
This patch adds a WARN_ON_ONCE() to warn us if we missed another
fix of this kind.
Kudos to Neal for finding the root cause of this bug. Its visible
using small MSS.
