commit e6c9366b2adb52cba64b359b3050200743c7568c upstream.
Commit 778dd893ae78 ("tmpfs: fix race between umount and swapoff")
forgot the new rules for strict atomic kmap nesting, causing
WARNING: at arch/x86/mm/highmem_32.c:81
from __kunmap_atomic(), then
BUG: unable to handle kernel paging request at fffb9000
from shmem_swp_set() when shmem_unuse_inode() is handling swapoff with
highmem in use. My disgrace again.
See
https://bugzilla.kernel.org/show_bug.cgi?id=35352
Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl>
commit 59a16ead572330deb38e5848151d30ed1af754bc upstream.
Testing the shmem_swaplist replacements for igrab() revealed another bug:
writes to /dev/loop0 on a tmpfs file which fills its filesystem were
sometimes failing with "Buffer I/O error"s.
These came from ENOSPC failures of shmem_getpage(), when racing with
swapoff: the same could happen when racing with another shmem_getpage(),
pulling the page in from swap in between our find_lock_page() and our
taking the info->lock (though not in the single-threaded loop case).
This is unacceptable, and surprising that I've not noticed it before:
it dates back many years, but (presumably) was made a lot easier to
reproduce in 2.6.36, which sited a page preallocation in the race window.
Fix it by rechecking the page cache before settling on an ENOSPC error.
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit fc5da22ae35d4720be59af8787a8a6d5e4da9517 upstream.
If you fill up a tmpfs, df was showing
tmpfs 460800 - - - /tmp
because of an off-by-one in the max_blocks checks. Fix it so df shows
tmpfs 460800 460800 0 100% /tmp
Cc: Tim Chen <tim.c.chen@linux.intel.com>
commit 05bf86b4ccfd0f197da61c67bd372111d15a6620 upstream.
Shame on me! Commit b1dea800ac39 "tmpfs: fix race between umount and
writepage" fixed the advertized race, but introduced another: as even
its comment makes clear, we cannot safely rely on a peek at list_empty()
while holding no lock - until info->swapped is set, shmem_unuse_inode()
may delete any formerly-swapped inode from the shmem_swaplist, which
in this case would leave a swap area impossible to swapoff.
Although I don't relish taking the mutex every time, I don't care much
for the alternatives either; and at least the peek at list_empty() in
shmem_evict_inode() (a hotter path since most inodes would never have
been swapped) remains safe, because we already truncated the whole file.
commit b1dea800ac39599301d4bb8dcf2b1d29c2558211 upstream.
Konstanin Khlebnikov reports that a dangerous race between umount and
shmem_writepage can be reproduced by this script:
for i in {1..300} ; do
mkdir $i
while true ; do
mount -t tmpfs none $i
dd if=/dev/zero of=$i/test bs=1M count=$(($RANDOM % 100))
umount $i
done &
done
on a 6xCPU node with 8Gb RAM: kernel very unstable after this accident. =)
Kernel log:
VFS: Busy inodes after unmount of tmpfs.
Self-destruct in 5 seconds. Have a nice day...
WARNING: at lib/list_debug.c:53 __list_del_entry+0x8d/0x98()
list_del corruption. prev->next should be ffff880222fdaac8, but was (null)
Pid: 11222, comm: mount.tmpfs Not tainted 2.6.39-rc2+ #4
Call Trace:
warn_slowpath_common+0x80/0x98
warn_slowpath_fmt+0x41/0x43
evict+0x50/0x113
iput+0x138/0x141
BUG: unable to handle kernel paging request at ffffffffffffffff
IP: shmem_free_blocks+0x18/0x4c
Pid: 10422, comm: dd Tainted: G W 2.6.39-rc2+ #4
Call Trace:
shmem_recalc_inode+0x61/0x66
shmem_writepage+0xba/0x1dc
pageout+0x13c/0x24c
shrink_page_list+0x28e/0x4be
shrink_inactive_list+0x21f/0x382
shmem_writepage() calls igrab() on the inode for the page which came from
page reclaim, to add it later into shmem_swaplist for swapoff operation.
This igrab() can race with super-block deactivating process:
shrink_inactive_list() deactivate_super()
pageout() tmpfs_fs_type->kill_sb()
shmem_writepage() kill_litter_super()
generic_shutdown_super()
evict_inodes()
igrab()
atomic_read(&inode->i_count)
skip-inode
iput()
if (!list_empty(&sb->s_inodes))
printk("VFS: Busy inodes after...
This igrap-iput pair was added in commit 1b1b32f2c6f6 "tmpfs: fix
shmem_swaplist races" based on incorrect assumptions: igrab() protects the
inode from concurrent eviction by deletion, but it does nothing to protect
it from concurrent unmounting, which goes ahead despite the raised
i_count.
So this use of igrab() was wrong all along, but the race made much worse
in 2.6.37 when commit 63997e98a3be "split invalidate_inodes()" replaced
two attempts at invalidate_inodes() by a single evict_inodes().
Konstantin posted a plausible patch, raising sb->s_active too: I'm unsure
whether it was correct or not; but burnt once by igrab(), I am sure that
we don't want to rely more deeply upon externals here.
Fix it by adding the inode to shmem_swaplist earlier, while the page lock
on page in page cache still secures the inode against eviction, without
artifically raising i_count. It was originally added later because
shmem_unuse_inode() is liable to remove an inode from the list while it's
unswapped; but we can guard against that by taking spinlock before
dropping mutex.
Reported-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Tested-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
commit 778dd893ae785c5fd505dac30b5fc40aae188bf1 upstream.
The use of igrab() in swapoff's shmem_unuse_inode() is just as vulnerable
to umount as that in shmem_writepage().
Fix this instance by extending the protection of shmem_swaplist_mutex
right across shmem_unuse_inode(): while it's on the list, the inode cannot
be evicted (and the filesystem cannot be unmounted) without
shmem_evict_inode() taking that mutex to remove it from the list.
But since shmem_writepage() might take that mutex, we should avoid making
memory allocations or memcg charges while holding it: prepare them at the
outer level in shmem_unuse(). When mem_cgroup_cache_charge() was
originally placed, we didn't know until that point that the page from swap
was actually a shmem page; but nowadays it's noted in the swap_map, so
we're safe to charge upfront. For the radix_tree, do as is done in
shmem_getpage(): preload upfront, but don't pin to the cpu; so we make a
habit of refreshing the node pool, but might dip into GFP_NOWAIT reserves
on occasion if subsequently preempted.
With the allocation and charge moved out from shmem_unuse_inode(),
we can also hold index map and info->lock over from finding the entry.
commit 8f389a99b652aab5b42297280bd94d95933ad12f upstream.
Stefan found nobootmem does not work on his system that has only 8M of
RAM. This causes an early panic:
BIOS-provided physical RAM map:
BIOS-88: 0000000000000000 - 000000000009f000 (usable)
BIOS-88: 0000000000100000 - 0000000000840000 (usable)
bootconsole [earlyser0] enabled
Notice: NX (Execute Disable) protection missing in CPU or disabled in BIOS!
DMI not present or invalid.
last_pfn = 0x840 max_arch_pfn = 0x100000
init_memory_mapping: 0000000000000000-0000000000840000
8MB LOWMEM available.
mapped low ram: 0 - 00840000
Zone PFN ranges:
DMA 0x00000001 -> 0x00001000
Normal empty
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
0: 0x00000001 -> 0x0000009f
0: 0x00000100 -> 0x00000840
BUG: Int 6: CR2 (null)
EDI c034663c ESI (null) EBP c0329f38 ESP c0329ef4
EBX c0346380 EDX 00000006 ECX ffffffff EAX fffffff4
err (null) EIP c0353191 CS c0320060 flg 00010082
Stack: (null) c030c533 000007cd (null) c030c533 00000001 (null) (null)
00000003 0000083f 00000018 00000002 00000002 c0329f6c c03534d6 (null)
(null) 00000100 00000840 (null) c0329f64 00000001 00001000 (null)
Pid: 0, comm: swapper Not tainted 2.6.36 #5
Call Trace:
[<c02e3707>] ? 0xc02e3707
[<c035e6e5>] 0xc035e6e5
[<c0353191>] ? 0xc0353191
[<c03534d6>] 0xc03534d6
[<c034f1cd>] 0xc034f1cd
[<c034a824>] 0xc034a824
[<c03513cb>] ? 0xc03513cb
[<c0349432>] 0xc0349432
[<c0349066>] 0xc0349066
It turns out that we should ignore the low limit of 16M.
Use alloc_bootmem_node_nopanic() in this case.
[akpm@linux-foundation.org: less mess]
Signed-off-by: Yinghai LU <yinghai@kernel.org>
Reported-by: Stefan Hellermann <stefan@the2masters.de>
Tested-by: Stefan Hellermann <stefan@the2masters.de>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
commit a09a79f66874c905af35d5bb5e5f2fdc7b6b894d upstream.
Linux kernel excludes guard page when performing mlock on a VMA with
down-growing stack. However, some architectures have up-growing stack
and locking the guard page should be excluded in this case too.
This patch fixes lvm2 on PA-RISC (and possibly other architectures with
up-growing stack). lvm2 calculates number of used pages when locking and
when unlocking and reports an internal error if the numbers mismatch.
[ Patch changed fairly extensively to also fix /proc/<pid>/maps for the
grows-up case, and to move things around a bit to clean it all up and
share the infrstructure with the /proc bits.
Tested on ia64 that has both grow-up and grow-down segments - Linus ]
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Tested-by: Tony Luck <tony.luck@gmail.com>
commit 42c36f63ac1366ab0ecc2d5717821362c259f517 upstream.
Commit a626ca6a6564 ("vm: fix vm_pgoff wrap in stack expansion") fixed
the case of an expanding mapping causing vm_pgoff wrapping when you had
downward stack expansion. But there was another case where IA64 and
PA-RISC expand mappings: upward expansion.
This fixes that case too.
commit a1fde08c74e90accd62d4cfdbf580d2ede938fe7 upstream.
The logic in __get_user_pages() used to skip the stack guard page lookup
whenever the caller wasn't interested in seeing what the actual page
was. But Michel Lespinasse points out that there are cases where we
don't care about the physical page itself (so 'pages' may be NULL), but
do want to make sure a page is mapped into the virtual address space.
So using the existence of the "pages" array as an indication of whether
to look up the guard page or not isn't actually so great, and we really
should just use the FOLL_MLOCK bit. But because that bit was only set
for the VM_LOCKED case (and not all vma's necessarily have it, even for
mlock()), we couldn't do that originally.
Fix that by moving the VM_LOCKED check deeper into the call-chain, which
actually simplifies many things. Now mlock() gets simpler, and we can
also check for FOLL_MLOCK in __get_user_pages() and the code ends up
much more straightforward.
Reported-and-reviewed-by: Michel Lespinasse <walken@google.com>
commit 78f11a255749d09025f54d4e2df4fbcb031530e2 upstream.
The huge_memory.c THP page fault was allowed to run if vm_ops was null
(which would succeed for /dev/zero MAP_PRIVATE, as the f_op->mmap wouldn't
setup a special vma->vm_ops and it would fallback to regular anonymous
memory) but other THP logics weren't fully activated for vmas with vm_file
not NULL (/dev/zero has a not NULL vma->vm_file).
So this removes the vm_file checks so that /dev/zero also can safely use
THP (the other albeit safer approach to fix this bug would have been to
prevent the THP initial page fault to run if vm_file was set).
After removing the vm_file checks, this also makes huge_memory.c stricter
in khugepaged for the DEBUG_VM=y case. It doesn't replace the vm_file
check with a is_pfn_mapping check (but it keeps checking for VM_PFNMAP
under VM_BUG_ON) because for a is_cow_mapping() mapping VM_PFNMAP should
only be allowed to exist before the first page fault, and in turn when
vma->anon_vma is null (so preventing khugepaged registration). So I tend
to think the previous comment saying if vm_file was set, VM_PFNMAP might
have been set and we could still be registered in khugepaged (despite
anon_vma was not NULL to be registered in khugepaged) was too paranoid.
The is_linear_pfn_mapping check is also I think superfluous (as described
by comment) but under DEBUG_VM it is safe to stay.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=33682
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Reported-by: Caspar Zhang <bugs@casparzhang.com>
Acked-by: Mel Gorman <mel@csn.ul.ie>
commit cc03638df20acbec5d0d0d9e07234aadde9e698d upstream.
With transparent hugepage support, handle_mm_fault() has to be careful
that a normal PMD has been established before handling a PTE fault. To
achieve this, it used __pte_alloc() directly instead of pte_alloc_map as
pte_alloc_map is unsafe to run against a huge PMD. pte_offset_map() is
called once it is known the PMD is safe.
pte_alloc_map() is smart enough to check if a PTE is already present
before calling __pte_alloc but this check was lost. As a consequence,
PTEs may be allocated unnecessarily and the page table lock taken. Thi
useless PTE does get cleaned up but it's a performance hit which is
visible in page_test from aim9.
This patch simply re-adds the check normally done by pte_alloc_map to
check if the PTE needs to be allocated before taking the page table lock.
The effect is noticable in page_test from aim9.
AIM9
2.6.38-vanilla 2.6.38-checkptenone
creat-clo 446.10 ( 0.00%) 424.47 (-5.10%)
page_test 38.10 ( 0.00%) 42.04 ( 9.37%)
brk_test 52.45 ( 0.00%) 51.57 (-1.71%)
exec_test 382.00 ( 0.00%) 456.90 (16.39%)
fork_test 60.11 ( 0.00%) 67.79 (11.34%)
MMTests Statistics: duration
Total Elapsed Time (seconds) 611.90 612.22
(While this affects 2.6.38, it is a performance rather than a functional
bug and normally outside the rules -stable. While the big performance
differences are to a microbench, the difference in fork and exec
performance may be significant enough that -stable wants to consider the
patch)
Reported-by: Raz Ben Yehuda <raziebe@gmail.com>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
commit f755a042d82b51b54f3bdd0890e5ea56c0fb6807 upstream.
PTE pages eat up memory just like anything else, but we do not account for
them in any way in the OOM scores. They are also _guaranteed_ to get
freed up when a process is OOM killed, while RSS is not.
Reported-by: Dave Hansen <dave@linux.vnet.ibm.com>
Acked-by: David Rientjes <rientjes@google.com>
commit 4471a675dfc7ca676c165079e91c712b09dc9ce4 upstream.
5520e89 ("brk: fix min_brk lower bound computation for COMPAT_BRK")
tried to get the whole logic of brk randomization for legacy
(libc5-based) applications finally right.
It turns out that the way to detect whether brk has actually been
randomized in the end or not introduced by that patch still doesn't work
for those binaries, as reported by Geert:
: /sbin/init from my old m68k ramdisk exists prematurely.
: Before the patch:
: | brk(0x80005c8e) = 0x80006000
: After the patch:
: | brk(0x80005c8e) = 0x80005c8e
: Old libc5 considers brk() to have failed if the return value is not
: identical to the requested value.
I don't like it, but currently see no better option than a bit flag in
task_struct to catch the CONFIG_COMPAT_BRK && randomize_va_space == 2
case.
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
commit 929bea7c714220fc76ce3f75bef9056477c28e74 upstream.
all_unreclaimable check in direct reclaim has been introduced at 2.6.19
by following commit.
2006 Sep 25; commit 408d8544; oom: use unreclaimable info
And it went through strange history. firstly, following commit broke
the logic unintentionally.
2008 Apr 29; commit a41f24ea; page allocator: smarter retry of
costly-order allocations
Two years later, I've found obvious meaningless code fragment and
restored original intention by following commit.
2010 Jun 04; commit bb21c7ce; vmscan: fix do_try_to_free_pages()
return value when priority==0
But, the logic didn't works when 32bit highmem system goes hibernation
and Minchan slightly changed the algorithm and fixed it .
2010 Sep 22: commit d1908362: vmscan: check all_unreclaimable
in direct reclaim path
But, recently, Andrey Vagin found the new corner case. Look,
struct zone {
int all_unreclaimable;
unsigned long pages_scanned;
zone->all_unreclaimable and zone->pages_scanned are neigher atomic
variables nor protected by lock. Therefore zones can become a state of
zone->page_scanned=0 and zone->all_unreclaimable=1. In this case, current
all_unreclaimable() return false even though zone->all_unreclaimabe=1.
This resulted in the kernel hanging up when executing a loop of the form
1. fork
2. mmap
3. touch memory
4. read memory
5. munmmap
as described in
http://www.gossamer-threads.com/lists/linux/kernel/1348725#1348725
Is this ignorable minor issue? No. Unfortunately, x86 has very small dma
zone and it become zone->all_unreclamble=1 easily. and if it become
all_unreclaimable=1, it never restore all_unreclaimable=0. Why? if
all_unreclaimable=1, vmscan only try DEF_PRIORITY reclaim and
a-few-lru-pages>>DEF_PRIORITY always makes 0. that mean no page scan at
all!
Eventually, oom-killer never works on such systems. That said, we can't
use zone->pages_scanned for this purpose. This patch restore
all_unreclaimable() use zone->all_unreclaimable as old. and in addition,
to add oom_killer_disabled check to avoid reintroduce the issue of commit
d1908362 ("vmscan: check all_unreclaimable in direct reclaim path").
Reported-by: Andrey Vagin <avagin@openvz.org>
Cc: Nick Piggin <npiggin@kernel.dk>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit 341aea2bc48bf652777fb015cc2b3dfa9a451817 upstream.
This is an almost-revert of commit 93b43fa ("oom: give the dying task a
higher priority").
That commit dramatically improved oom killer logic when a fork-bomb
occurs. But I've found that it has nasty corner case. Now cpu cgroup has
strange default RT runtime. It's 0! That said, if a process under cpu
cgroup promote RT scheduling class, the process never run at all.
If an admin inserts a !RT process into a cpu cgroup by setting
rtruntime=0, usually it runs perfectly because a !RT task isn't affected
by the rtruntime knob. But if it promotes an RT task via an explicit
setscheduler() syscall or an OOM, the task can't run at all. In short,
the oom killer doesn't work at all if admins are using cpu cgroup and don't
touch the rtruntime knob.
Eventually, kernel may hang up when oom kill occur. I and the original
author Luis agreed to disable this logic.
Acked-by: Luis Claudio R. Goncalves <lclaudio@uudg.org>
Acked-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
commit e27e6151b154ff6e5e8162efa291bc60196d29ea upstream.
The conventional format for boolean attributes in sysfs is numeric ("0" or
"1" followed by new-line). Any boolean attribute can then be read and
written using a generic function. Using the strings "yes [no]", "[yes]
no" (read), "yes" and "no" (write) will frustrate this.
[akpm@linux-foundation.org: use kstrtoul()]
[akpm@linux-foundation.org: test_bit() doesn't return 1/0, per Neil]
Cc: Johannes Weiner <jweiner@redhat.com>
Tested-by: David Rientjes <rientjes@google.com>
Cc: NeilBrown <neilb@suse.de>
commit 95042f9eb78a8d9a17455e2ef263f2f310ecef15 upstream.
Commit 53a7706d5ed8 ("mlock: do not hold mmap_sem for extended periods
of time") changed mlock() to care about the exact number of pages that
__get_user_pages() had brought it. Before, it would only care about
errors.
And that doesn't work, because we also handled one page specially in
__mlock_vma_pages_range(), namely the stack guard page. So when that
case was handled, the number of pages that the function returned was off
by one. In particular, it could be zero, and then the caller would end
up not making any progress at all.
Rather than try to fix up that off-by-one error for the mlock case
specially, this just moves the logic to handle the stack guard page
into__get_user_pages() itself, thus making all the counts come out
right automatically.
Reported-by: Robert Święcki <robert@swiecki.net>
commit a626ca6a656450e9f4df91d0dda238fff23285f4 upstream.
Commit 982134ba6261 ("mm: avoid wrapping vm_pgoff in mremap()") fixed
the case of a expanding mapping causing vm_pgoff wrapping when you used
mremap. But there was another case where we expand mappings hiding in
plain sight: the automatic stack expansion.
This one also found by Robert Święcki, using his nasty system call
fuzzer tool. Good job.
Reported-and-tested-by: Robert Święcki <robert@swiecki.net>
commit 982134ba62618c2d69fbbbd166d0a11ee3b7e3d8 upstream.
The normal mmap paths all avoid creating a mapping where the pgoff
inside the mapping could wrap around due to overflow. However, an
expanding mremap() can take such a non-wrapping mapping and make it
bigger and cause a wrapping condition.
Noticed by Robert Swiecki when running a system call fuzzer, where it
caused a BUG_ON() due to terminally confusing the vma_prio_tree code. A
vma dumping patch by Hugh then pinpointed the crazy wrapped case.
Reported-and-tested-by: Robert Swiecki <robert@swiecki.net>
commit 95f28604a65b1c40b6c6cd95e58439cd7ded3add upstream.
We don't have proper reference counting for this yet, so we run into
cases where the device is pulled and we OOPS on flushing the fs data.
This happens even though the dirty inodes have already been
migrated to the default_backing_dev_info.
Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit ef2b4b95a63a1d23958dcb99eb2c6898eddc87d0 upstream.
Change the _mapcount value indicating PageBuddy from -2 to -128 for
more robusteness against page_mapcount() undeflows.
Use reset_page_mapcount instead of __ClearPageBuddy in bad_page to
ignore the previous retval of PageBuddy().
Reported-by: Hugh Dickins <hughd@google.com>
commit edd45544c6f09550df0a5491aa8a07af24767e73 upstream.
The oom killer naturally defers killing anything if it finds an eligible
task that is already exiting and has yet to detach its ->mm. This avoids
unnecessarily killing tasks when one is already in the exit path and may
free enough memory that the oom killer is no longer needed. This is
detected by PF_EXITING since threads that have already detached its ->mm
are no longer considered at all.
The problem with always deferring when a thread is PF_EXITING, however, is
that it may never actually exit when being traced, specifically if another
task is tracing it with PTRACE_O_TRACEEXIT. The oom killer does not want
to defer in this case since there is no guarantee that thread will ever
exit without intervention.
This patch will now only defer the oom killer when a thread is PF_EXITING
and no ptracer has stopped its progress in the exit path. It also ensures
that a child is sacrificed for the chosen parent only if it has a
different ->mm as the comment implies: this ensures that the thread group
leader is always targeted appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
Reported-by: Oleg Nesterov <oleg@redhat.com>
Cc: Andrey Vagin <avagin@openvz.org>
commit 30e2b41f20b6238f51e7cffb879c7a0f0073f5fe upstream.
We shouldn't defer oom killing if a thread has already detached its ->mm
and still has TIF_MEMDIE set. Memory needs to be freed, so find kill
other threads that pin the same ->mm or find another task to kill.
Signed-off-by: Andrey Vagin <avagin@openvz.org>
commit 3a5dda7a17cf3706f79b86293f29db02d61e0d48 upstream.
This patch prevents unnecessary oom kills or kernel panics by reverting
two commits:
495789a5 (oom: make oom_score to per-process value)
cef1d352 (oom: multi threaded process coredump don't make deadlock)
First, 495789a5 (oom: make oom_score to per-process value) ignores the
fact that all threads in a thread group do not necessarily exit at the
same time.
It is imperative that select_bad_process() detect threads that are in the
exit path, specifically those with PF_EXITING set, to prevent needlessly
killing additional tasks. If a process is oom killed and the thread group
leader exits, select_bad_process() cannot detect the other threads that
are PF_EXITING by iterating over only processes. Thus, it currently
chooses another task unnecessarily for oom kill or panics the machine when
nothing else is eligible.
By iterating over threads instead, it is possible to detect threads that
are exiting and nominate them for oom kill so they get access to memory
reserves.
Second, cef1d352 (oom: multi threaded process coredump don't make
deadlock) erroneously avoids making the oom killer a no-op when an
eligible thread other than current isfound to be exiting. We want to
detect this situation so that we may allow that exiting thread time to
exit and free its memory; if it is able to exit on its own, that should
free memory so current is no loner oom. If it is not able to exit on its
own, the oom killer will nominate it for oom kill which, in this case,
only means it will get access to memory reserves.
Without this change, it is easy for the oom killer to unnecessarily target
tasks when all threads of a victim don't exit before the thread group
leader or, in the worst case, panic the machine.
commit d527caf22e48480b102c7c6ee5b9ba12170148f7 upstream.
This patch reverts 5a03b051 ("thp: use compaction in kswapd for GFP_ATOMIC
order > 0") due to reports stating that kswapd CPU usage was higher and
IRQs were being disabled more frequently. This was reported at
http://www.spinics.net/linux/fedora/alsa-user/msg09885.html.
Without this patch applied, CPU usage by kswapd hovers around the 20% mark
according to the tester (Arthur Marsh:
http://www.spinics.net/linux/fedora/alsa-user/msg09899.html). With this
patch applied, it's around 2%.
The problem is not related to THP which specifies __GFP_NO_KSWAPD but is
triggered by high-order allocations hitting the low watermark for their
order and waking kswapd on kernels with CONFIG_COMPACTION set. The most
common trigger for this is network cards configured for jumbo frames but
it's also possible it'll be triggered by fork-heavy workloads (order-1)
and some wireless cards which depend on order-1 allocations.
The symptoms for the user will be high CPU usage by kswapd in low-memory
situations which could be confused with another writeback problem. While
a patch like 5a03b051 may be reintroduced in the future, this patch plays
it safe for now and reverts it.
[mel@csn.ul.ie: Beefed up the changelog]
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reported-by: Arthur Marsh <arthur.marsh@internode.on.net>
Tested-by: Arthur Marsh <arthur.marsh@internode.on.net>
commit 52c50567d8ab0a0a87f12cceaa4194967854f0bd upstream.
If an administrator tries to swapon a file backed by NFS, the inode mutex is
taken (as it is for any swapfile) but later identified to be a bad swapfile
due to the lack of bmap and tries to cleanup. During cleanup, an attempt is
made to close the file but with inode->i_mutex still held. Closing an NFS
file syncs it which tries to acquire the inode mutex leading to deadlock. If
lockdep is enabled the following appears on the console;
[ INFO: possible recursive locking detected ]
2.6.38-rc8-autobuild #1
swapon/2192 is trying to acquire lock:
(&sb->s_type->i_mutex_key#13){+.+.+.}, at: vfs_fsync_range+0x47/0x7c
but task is already holding lock:
(&sb->s_type->i_mutex_key#13){+.+.+.}, at: sys_swapon+0x28d/0xae7
1 lock held by swapon/2192:
#0: (&sb->s_type->i_mutex_key#13){+.+.+.}, at: sys_swapon+0x28d/0xae7
stack backtrace:
Pid: 2192, comm: swapon Not tainted 2.6.38-rc8-autobuild #1
Call Trace:
__lock_acquire+0x2eb/0x1623
find_get_pages_tag+0x14a/0x174
pagevec_lookup_tag+0x25/0x2e
lock_acquire+0xd3/0x100
nfs_flush_one+0x0/0xdf [nfs]
mutex_lock_nested+0x40/0x2b1
vfs_fsync+0x1c/0x1e
nfs_file_flush+0x64/0x69 [nfs]
filp_close+0x43/0x72
sys_swapon+0xa39/0xae7
sysret_check+0x2e/0x69
system_call_fastpath+0x16/0x1b
This patch releases the mutex if its held before calling filep_close()
so swapon fails as expected without deadlock when the swapfile is backed
by NFS. If accepted for 2.6.39, it should also be considered a -stable
candidate for 2.6.38 and 2.6.37.
commit bee4c36a5cf5c9f63ce1d7372aa62045fbd16d47 upstream.
Up to 2.6.22, you could use remap_file_pages(2) on a tmpfs file or a
shared mapping of /dev/zero or a shared anonymous mapping. In 2.6.23 we
disabled it by default, but set VM_CAN_NONLINEAR to enable it on safe
mappings. We made sure to set it in shmem_mmap() for tmpfs files, but
missed it in shmem_zero_setup() for the others. Fix that at last.
Reported-by: Kenny Simpson <theonetruekenny@yahoo.com>
commit 3ff84a7f36554b257cd57325b1a7c1fa4b49fbe3 upstream.
This reverts commit 5c5e3b33b7cb959a401f823707bee006caadd76e.
The commit breaks ARM thusly:
| Mount-cache hash table entries: 512
| slab error in verify_redzone_free(): cache `idr_layer_cache': memory outside object was overwritten
| Backtrace:
| [<c0227088>] (dump_backtrace+0x0/0x110) from [<c0431afc>] (dump_stack+0x18/0x1c)
| [<c0431ae4>] (dump_stack+0x0/0x1c) from [<c0293304>] (__slab_error+0x28/0x30)
| [<c02932dc>] (__slab_error+0x0/0x30) from [<c0293a74>] (cache_free_debugcheck+0x1c0/0x2b8)
| [<c02938b4>] (cache_free_debugcheck+0x0/0x2b8) from [<c0293f78>] (kmem_cache_free+0x3c/0xc0)
| [<c0293f3c>] (kmem_cache_free+0x0/0xc0) from [<c032b1c8>] (ida_get_new_above+0x19c/0x1c0)
| [<c032b02c>] (ida_get_new_above+0x0/0x1c0) from [<c02af7ec>] (alloc_vfsmnt+0x54/0x144)
| [<c02af798>] (alloc_vfsmnt+0x0/0x144) from [<c0299830>] (vfs_kern_mount+0x30/0xec)
| [<c0299800>] (vfs_kern_mount+0x0/0xec) from [<c0299908>] (kern_mount_data+0x1c/0x20)
| [<c02998ec>] (kern_mount_data+0x0/0x20) from [<c02146c4>] (sysfs_init+0x68/0xc8)
| [<c021465c>] (sysfs_init+0x0/0xc8) from [<c02137d4>] (mnt_init+0x90/0x1b0)
| [<c0213744>] (mnt_init+0x0/0x1b0) from [<c0213388>] (vfs_caches_init+0x100/0x140)
| [<c0213288>] (vfs_caches_init+0x0/0x140) from [<c0208c0c>] (start_kernel+0x2e8/0x368)
| [<c0208924>] (start_kernel+0x0/0x368) from [<c0208034>] (__enable_mmu+0x0/0x2c)
| c0113268: redzone 1:0xd84156c5c032b3ac, redzone 2:0xd84156c5635688c0.
| slab error in cache_alloc_debugcheck_after(): cache `idr_layer_cache': double free, or memory outside object was overwritten
| c011307c: redzone 1:0x9f91102ffffffff, redzone 2:0x9f911029d74e35b
| slab: Internal list corruption detected in cache 'idr_layer_cache'(24), slabp c0113000(16). Hexdump:
| 000: 20 4f 10 c0 20 4f 10 c0 7c 00 00 00 7c 30 11 c0
| 010: 10 00 00 00 10 00 00 00 00 00 c9 17 fe ff ff ff
| 020: fe ff ff ff fe ff ff ff fe ff ff ff fe ff ff ff
| 030: fe ff ff ff fe ff ff ff fe ff ff ff fe ff ff ff
| 040: fe ff ff ff fe ff ff ff fe ff ff ff fe ff ff ff
| 050: fe ff ff ff fe ff ff ff fe ff ff ff 11 00 00 00
| 060: 12 00 00 00 13 00 00 00 14 00 00 00 15 00 00 00
| 070: 16 00 00 00 17 00 00 00 c0 88 56 63
| kernel BUG at /home/rmk/git/linux-2.6-rmk/mm/slab.c:2928!
Reference: https://lkml.org/lkml/2011/2/7/238
Reported-and-analyzed-by: Russell King <rmk@arm.linux.org.uk>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
This reverts the parent commit. I hate doing that, but it's generating
some discussion ("half of it is right"), and since I am planning on
doing the 2.6.38 release later today we can punt it to stable if
required. Let's not rock the boat right now.
oom_kill_process() starts with victim_points == 0. This means that
(most likely) any child has more points and can be killed erroneously.
Also, "children has a different mm" doesn't match the reality, we should
check child->mm != t->mm. This check is not exactly correct if t->mm ==
NULL but this doesn't really matter, oom_kill_task() will kill them
anyway.
Note: "Kill all processes sharing p->mm" in oom_kill_task() is wrong
too.
THP's collapse_huge_page() has an understandable but ugly difference
in when its huge page is allocated: inside if NUMA but outside if not.
It's hardly surprising that the memcg failure path forgot that, freeing
the page in the non-NUMA case, then hitting a VM_BUG_ON in get_page()
(or even worse, using the freed page).
When vmscan.c calls page_referenced(), if an anon page was created
before a process forked, rmap will search for it in both of the
processes, even though one of them might have since broken COW.
If the child process mlocks the vma where the COWed page belongs to,
page_referenced() running on the page mapped by the parent would lead to
*vm_flags getting VM_LOCKED set erroneously (leading to the references
on the parent page being ignored and evicting the parent page too
early).
*mapcount would also be decremented by page_referenced_one even if the
page wasn't found by page_check_address.
This also lets pmdp_clear_flush_young_notify() go ahead on a
pmd_trans_splitting() pmd.
We hold the page_table_lock so __split_huge_page_map() must wait the
pmdp_clear_flush_young_notify() to complete before it can modify the
pmd. The pmd is also still mapped in userland so the young bit may
materialize through a tlb miss before split_huge_page_map runs.
This will provide a more accurate page_referenced() behavior during
split_huge_page().
Reported-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Michel Lespinasse <walken@google.com>
Reviewed-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Rik van Riel<riel@redhat.com>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Pass down the correct node for a transparent hugepage allocation. Most
callers continue to use the current node, however the hugepaged daemon
now uses the previous node of the first to be collapsed page instead.
This ensures that khugepaged does not mess up local memory for an
existing process which uses local policy.
The choice of node is somewhat primitive currently: it just uses the
node of the first page in the pmd range. An alternative would be to
look at multiple pages and use the most popular node. I used the
simplest variant for now which should work well enough for the case of
all pages being on the same node.
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
This makes a difference for LOCAL policy, where the node cannot be
determined from the policy itself, but has to be gotten from the original
page.
Currently alloc_pages_vma() always uses the local node as policy node for
the LOCAL policy. Pass this node down as an argument instead.
No behaviour change from this patch, but will be needed for followons.
It seems odd that truncate_inode_pages_range(), called not only when
truncating but also when evicting inodes, has mem_cgroup_uncharge_start
and _end() batching in its second loop to clear up a few leftovers, but
not in its first loop that does almost all the work: add them there too.
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Acked-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
The THP code didn't pass the correct interleaving shift to the memory
policy code. Fix this here by adjusting for the order.
Reviewed-by: Christoph Lameter <cl@linux.com>
When pfn_valid_within() failed 'iter' was incremented twice.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: <stable@kernel.org>
!__GFP_REPEAT
should_continue_reclaim() for reclaim/compaction allows scanning to
continue even if pages are not being reclaimed until the full list is
scanned. In terms of allocation success, this makes sense but potentially
it introduces unwanted latency for high-order allocations such as
transparent hugepages and network jumbo frames that would prefer to fail
the allocation attempt and fallback to order-0 pages. Worse, there is a
potential that the full LRU scan will clear all the young bits, distort
page aging information and potentially push pages into swap that would
have otherwise remained resident.
This patch will stop reclaim/compaction if no pages were reclaimed in the
last SWAP_CLUSTER_MAX pages that were considered. For allocations such as
hugetlbfs that use __GFP_REPEAT and have fewer fallback options, the full
LRU list may still be scanned.
Order-0 allocation should not be affected because RECLAIM_MODE_COMPACTION
is not set so the following avoids the gfp_mask being examined:
if (!(sc->reclaim_mode & RECLAIM_MODE_COMPACTION))
return false;
A tool was developed based on ftrace that tracked the latency of
high-order allocations while transparent hugepage support was enabled and
three benchmarks were run. The "fix-infinite" figures are 2.6.38-rc4 with
Johannes's patch "vmscan: fix zone shrinking exit when scan work is done"
applied.
STREAM Highorder Allocation Latency Statistics
fix-infinite break-early
1 :: Count 10298 10229
1 :: Min 0.4560 0.4640
1 :: Mean 1.0589 1.0183
1 :: Max 14.5990 11.7510
1 :: Stddev 0.5208 0.4719
2 :: Count 2 1
2 :: Min 1.8610 3.7240
2 :: Mean 3.4325 3.7240
2 :: Max 5.0040 3.7240
2 :: Stddev 1.5715 0.0000
9 :: Count 111696 111694
9 :: Min 0.5230 0.4110
9 :: Mean 10.5831 10.5718
9 :: Max 38.4480 43.2900
9 :: Stddev 1.1147 1.1325
Mean time for order-1 allocations is reduced. order-2 looks increased but
with so few allocations, it's not particularly significant. THP mean
allocation latency is also reduced. That said, allocation time varies so
significantly that the reductions are within noise.
Max allocation time is reduced by a significant amount for low-order
allocations but reduced for THP allocations which presumably are now
breaking before reclaim has done enough work.
SysBench Highorder Allocation Latency Statistics
1 :: Count 15745 15677
1 :: Min 0.4250 0.4550
1 :: Mean 1.1023 1.0810
1 :: Max 14.4590 10.8220
1 :: Stddev 0.5117 0.5100
2 :: Count 1 1
2 :: Min 3.0040 2.1530
2 :: Mean 3.0040 2.1530
2 :: Max 3.0040 2.1530
2 :: Stddev 0.0000 0.0000
9 :: Count 2017 1931
9 :: Min 0.4980 0.7480
9 :: Mean 10.4717 10.3840
9 :: Max 24.9460 26.2500
9 :: Stddev 1.1726 1.1966
Again, mean time for order-1 allocations is reduced while order-2
allocations are too few to draw conclusions from. The mean time for THP
allocations is also slightly reduced albeit the reductions are within
varianes.
Once again, our maximum allocation time is significantly reduced for
low-order allocations and slightly increased for THP allocations.
Anon stream mmap reference Highorder Allocation Latency Statistics
1 :: Count 1376 1790
1 :: Min 0.4940 0.5010
1 :: Mean 1.0289 0.9732
1 :: Max 6.2670 4.2540
1 :: Stddev 0.4142 0.2785
2 :: Count 1 -
2 :: Min 1.9060 -
2 :: Mean 1.9060 -
2 :: Max 1.9060 -
2 :: Stddev 0.0000 -
9 :: Count 11266 11257
9 :: Min 0.4990 0.4940
9 :: Mean 27250.4669 24256.1919
9 :: Max 11439211.0000 6008885.0000
9 :: Stddev 226427.4624 186298.1430
This benchmark creates one thread per CPU which references an amount of
anonymous memory 1.5 times the size of physical RAM. This pounds swap
quite heavily and is intended to exercise THP a bit.
Mean allocation time for order-1 is reduced as before. It's also reduced
for THP allocations but the variations here are pretty massive due to
swap. As before, maximum allocation times are significantly reduced.
Overall, the patch reduces the mean and maximum allocation latencies for
the smaller high-order allocations. This was with Slab configured so it
would be expected to be more significant with Slub which uses these size
allocations more aggressively.
The mean allocation times for THP allocations are also slightly reduced.
The maximum latency was slightly increased as predicted by the comments
due to reclaim/compaction breaking early. However, workloads care more
about the latency of lower-order allocations than THP so it's an
acceptable trade-off.
Cc: Kent Overstreet <kent.overstreet@gmail.com>
The move_pages() usage of find_task_by_vpid() requires rcu_read_lock() to
prevent free_pid() from reclaiming the pid.
Without this patch, RCU warnings are printed in v2.6.38-rc4 move_pages()
with:
CONFIG_LOCKUP_DETECTOR=y
CONFIG_PREEMPT=y
CONFIG_LOCKDEP=y
CONFIG_PROVE_LOCKING=y
CONFIG_PROVE_RCU=y
Previously, migrate_pages() went through a similar transformation
replacing usage of tasklist_lock with rcu read lock:
commit 55cfaa3cbdd29c4919ecb5fb8965c310f357e48c
Author: Zeng Zhaoming <zengzm.kernel@gmail.com>
Date: Thu Dec 2 14:31:13 2010 -0800
mm/mempolicy.c: add rcu read lock to protect pid structure
commit 1e50df39f6e2c3a4a3394df62baa8a213df16c54
Author: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Date: Thu Jan 13 15:46:14 2011 -0800
mempolicy: remove tasklist_lock from migrate_pages
Signed-off-by: Greg Thelen <gthelen@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Zeng Zhaoming <zengzm.kernel@gmail.com>
Grab a reference to bdev before calling blkdev_get(), which expects
the refcount to be already incremented and either returns success or
decrements the refcount and returns an error.
The bug was introduced by e525fd89 (block: make blkdev_get/put()
handle exclusive access), which didn't take into account this behavior
of blkdev_get().
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Robert Swiecki reported a BUG_ON(page_mapped) from a fuzzer, punching
a hole with madvise(,, MADV_REMOVE). That path is under mutex, and
cannot be explained by lack of serialization in unmap_mapping_range().
Reviewing the code, I found one place where vm_truncate_count handling
should have been updated, when I switched at the last minute from one
way of managing the restart_addr to another: mremap move changes the
virtual addresses, so it ought to adjust the restart_addr.
But rather than exporting the notion of restart_addr from memory.c, or
converting to restart_pgoff throughout, simply reset vm_truncate_count
to 0 to force a rescan if mremap move races with preempted truncation.
We have no confirmation that this fixes Robert's BUG,
but it is a fix that's worth making anyway.
Michael Leun reported that running parallel opens on a fuse filesystem
can trigger a "kernel BUG at mm/truncate.c:475"
Gurudas Pai reported the same bug on NFS.
The reason is, unmap_mapping_range() is not prepared for more than
one concurrent invocation per inode. For example:
thread1: going through a big range, stops in the middle of a vma and
stores the restart address in vm_truncate_count.
thread2: comes in with a small (e.g. single page) unmap request on
the same vma, somewhere before restart_address, finds that the
vma was already unmapped up to the restart address and happily
returns without doing anything.
Another scenario would be two big unmap requests, both having to
restart the unmapping and each one setting vm_truncate_count to its
own value. This could go on forever without any of them being able to
finish.
Truncate and hole punching already serialize with i_mutex. Other
callers of unmap_mapping_range() do not, and it's difficult to get
i_mutex protection for all callers. In particular ->d_revalidate(),
which calls invalidate_inode_pages2_range() in fuse, may be called
with or without i_mutex.
This patch adds a new mutex to 'struct address_space' to prevent
running multiple concurrent unmap_mapping_range() on the same mapping.
[ We'll hopefully get rid of all this with the upcoming mm
preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex
lockbreak" patch in particular. But that is for 2.6.39 ]
Reported-by: Michael Leun <lkml20101129@newton.leun.net>
Reported-by: Gurudas Pai <gurudas.pai@oracle.com>
Tested-by: Gurudas Pai <gurudas.pai@oracle.com>
Cc: stable@kernel.org
Transparent hugepages can only be created if rmap is fully
functional. So we must prevent hugepages to be created while
is_vma_temporary_stack() is true.
This also optmizes away some harmless but unnecessary setting of
khugepaged_scan.address and it switches some BUG_ON to VM_BUG_ON.
mem_cgroup_uncharge_page() should be called in all failure cases after
mem_cgroup_charge_newpage() is called in huge_memory.c::collapse_huge_page()
[ 4209.076861] BUG: Bad page state in process khugepaged pfn:1e9800
[ 4209.077601] page:ffffea0006b14000 count:0 mapcount:0 mapping: (null) index:0x2800
[ 4209.078674] page flags: 0x40000000004000(head)
[ 4209.079294] pc:ffff880214a30000 pc->flags:2146246697418756 pc->mem_cgroup:ffffc9000177a000
[ 4209.082177] (/A)
[ 4209.082500] Pid: 31, comm: khugepaged Not tainted 2.6.38-rc3-mm1 #1
[ 4209.083412] Call Trace:
[ 4209.083678] [<ffffffff810f4454>] ? bad_page+0xe4/0x140
[ 4209.084240] [<ffffffff810f53e6>] ? free_pages_prepare+0xd6/0x120
[ 4209.084837] [<ffffffff8155621d>] ? rwsem_down_failed_common+0xbd/0x150
[ 4209.085509] [<ffffffff810f5462>] ? __free_pages_ok+0x32/0xe0
[ 4209.086110] [<ffffffff810f552b>] ? free_compound_page+0x1b/0x20
[ 4209.086699] [<ffffffff810fad6c>] ? __put_compound_page+0x1c/0x30
[ 4209.087333] [<ffffffff810fae1d>] ? put_compound_page+0x4d/0x200
[ 4209.087935] [<ffffffff810fb015>] ? put_page+0x45/0x50
[ 4209.097361] [<ffffffff8113f779>] ? khugepaged+0x9e9/0x1430
[ 4209.098364] [<ffffffff8107c870>] ? autoremove_wake_function+0x0/0x40
[ 4209.099121] [<ffffffff8113ed90>] ? khugepaged+0x0/0x1430
[ 4209.099780] [<ffffffff8107c236>] ? kthread+0x96/0xa0
[ 4209.100452] [<ffffffff8100dda4>] ? kernel_thread_helper+0x4/0x10
[ 4209.101214] [<ffffffff8107c1a0>] ? kthread+0x0/0xa0
[ 4209.101842] [<ffffffff8100dda0>] ? kernel_thread_helper+0x0/0x10
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Commit 3e7d34497067 ("mm: vmscan: reclaim order-0 and use compaction
instead of lumpy reclaim") introduced an indefinite loop in
shrink_zone().
It meant to break out of this loop when no pages had been reclaimed and
not a single page was even scanned. The way it would detect the latter
is by taking a snapshot of sc->nr_scanned at the beginning of the
function and comparing it against the new sc->nr_scanned after the scan
loop. But it would re-iterate without updating that snapshot, looping
forever if sc->nr_scanned changed at least once since shrink_zone() was
invoked.
This is not the sole condition that would exit that loop, but it
requires other processes to change the zone state, as the reclaimer that
is stuck obviously can not anymore.
This is only happening for higher-order allocations, where reclaim is
run back to back with compaction.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reported-by: Michal Hocko <mhocko@suse.cz>
Tested-by: Kent Overstreet<kent.overstreet@gmail.com>
Reported-by: Kent Overstreet <kent.overstreet@gmail.com>
If the page is going to be written to, __do_page needs to break COW.
However, the old page (before breaking COW) was never mapped mapped into
the current pte (__do_fault is only called when the pte is not present),
so vmscan can't have marked the old page as PageMlocked due to being
mapped in __do_fault's VMA. Therefore, __do_fault() does not need to
worry about clearing PageMlocked() on the old page.
Signed-off-by: Michel Lespinasse <walken@google.com>
vmscan can lazily find pages that are mapped within VM_LOCKED vmas, and
set the PageMlocked bit on these pages, transfering them onto the
unevictable list. When do_wp_page() breaks COW within a VM_LOCKED vma,
it may need to clear PageMlocked on the old page and set it on the new
page instead.
This change fixes an issue where do_wp_page() was clearing PageMlocked
on the old page while the pte was still pointing to it (as well as
rmap). Therefore, we were not protected against vmscan immediately
transfering the old page back onto the unevictable list. This could
cause pages to get stranded there forever.
I propose to move the corresponding code to the end of do_wp_page(),
after the pte (and rmap) have been pointed to the new page.
Additionally, we can use munlock_vma_page() instead of
clear_page_mlock(), so that the old page stays mlocked if there are
still other VM_LOCKED vmas mapping it.
While applying patch to use memblock to find aperture for 64bit x86.
Ingo found system with 1g + force_iommu
> No AGP bridge found
> Node 0: aperture @ 38000000 size 32 MB
> Aperture pointing to e820 RAM. Ignoring.
> Your BIOS doesn't leave a aperture memory hole
> Please enable the IOMMU option in the BIOS setup
> This costs you 64 MB of RAM
> Cannot allocate aperture memory hole (0,65536K)
the corresponding code:
addr = memblock_find_in_range(0, 1ULL<<32, aper_size, 512ULL<<20);
if (addr == MEMBLOCK_ERROR || addr + aper_size > 0xffffffff) {
printk(KERN_ERR
"Cannot allocate aperture memory hole (%lx,%uK)\n",
addr, aper_size>>10);
return 0;
memblock_x86_reserve_range(addr, addr + aper_size, "aperture64")
fails because memblock core code align the size with 512M. That could
make size way too big.
So don't align the size in that case.
actually __memblock_alloc_base, the another caller already align that
before calling that function.
BTW. x86 does not use __memblock_alloc_base...
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Dave Airlie <airlied@linux.ie>
