path: root/lib/random32.c
2013-12-08random32: fix off-by-one in seeding requirementDaniel Borkmann
[ Upstream commit 51c37a70aaa3f95773af560e6db3073520513912 ] For properly initialising the Tausworthe generator [1], we have a strict seeding requirement, that is, s1 > 1, s2 > 7, s3 > 15. Commit 697f8d0348 ("random32: seeding improvement") introduced a __seed() function that imposes boundary checks proposed by the errata paper [2] to properly ensure above conditions. However, we're off by one, as the function is implemented as: "return (x < m) ? x + m : x;", and called with __seed(X, 1), __seed(X, 7), __seed(X, 15). Thus, an unwanted seed of 1, 7, 15 would be possible, whereas the lower boundary should actually be of at least 2, 8, 16, just as GSL does. Fix this, as otherwise an initialization with an unwanted seed could have the effect that Tausworthe's PRNG properties cannot not be ensured. Note that this PRNG is *not* used for cryptography in the kernel. [1] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme.ps [2] http://www.iro.umontreal.ca/~lecuyer/myftp/papers/tausme2.ps Joint work with Hannes Frederic Sowa. Fixes: 697f8d0348a6 ("random32: seeding improvement") Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Florian Weimer <fweimer@redhat.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17prandom: introduce prandom_bytes() and prandom_bytes_state()Akinobu Mita
Add functions to get the requested number of pseudo-random bytes. The difference from get_random_bytes() is that it generates pseudo-random numbers by prandom_u32(). It doesn't consume the entropy pool, and the sequence is reproducible if the same rnd_state is used. So it is suitable for generating random bytes for testing. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: David Laight <david.laight@aculab.com> Cc: Michel Lespinasse <walken@google.com> Cc: Robert Love <robert.w.love@intel.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17random32: rename random32 to prandomAkinobu Mita
This renames all random32 functions to have 'prandom_' prefix as follows: void prandom_seed(u32 seed); /* rename from srandom32() */ u32 prandom_u32(void); /* rename from random32() */ void prandom_seed_state(struct rnd_state *state, u64 seed); /* rename from prandom32_seed() */ u32 prandom_u32_state(struct rnd_state *state); /* rename from prandom32() */ The purpose of this renaming is to prevent some kernel developers from assuming that prandom32() and random32() might imply that only prandom32() was the one using a pseudo-random number generator by prandom32's "p", and the result may be a very embarassing security exposure. This concern was expressed by Theodore Ts'o. And furthermore, I'm going to introduce new functions for getting the requested number of pseudo-random bytes. If I continue to use both prandom32 and random32 prefixes for these functions, the confusion is getting worse. As a result of this renaming, "prandom_" is the common prefix for pseudo-random number library. Currently, srandom32() and random32() are preserved because it is difficult to rename too many users at once. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Robert Love <robert.w.love@intel.com> Cc: Michel Lespinasse <walken@google.com> Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu> Cc: David Laight <david.laight@aculab.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-07lib: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27lib/random32: export pseudo-random number generator for modulesJoe Eykholt
This patch moves the definition of struct rnd_state and the inline __seed() function to linux/random.h. It renames the static __random32() function to prandom32() and exports it for use in modules. prandom32() is useful as a privately-seeded pseudo random number generator that can give the same result every time it is initialized. For FCoE FC-BB-6 VN2VN mode self-selected unique FC address generation, we need an pseudo-random number generator seeded with the 64-bit world-wide port name. A truly random generator or one seeded with randomness won't do because the same sequence of numbers should be generated each time we boot or the link comes up. A prandom32_seed() inline function is added to the header file. It is inlined not for speed, but so the function won't be expanded in the base kernel, but only in the module that uses it. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-30random32: seeding improvementStephen Hemminger
The rationale is: * use u32 consistently * no need to do LCG on values from (better) get_random_bytes * use more data from get_random_bytes for secondary seeding * don't reduce state space on srandom32() * enforce state variable initialization restrictions Note: the second paper has a version of random32() with even longer period and a version of random64() if needed. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2008-04-03[NET]: srandom32 fixes for networking v2Andi Kleen
- Let it update the state of all CPUs. The network stack goes into pains to feed the current IP addresses in, but it is not very effective if that is only done for some random CPU instead of all. So change it to feed bits into all CPUs. I decided to do that lockless because well somewhat random results are ok. v2: Drop rename so that this patch doesn't depend on x86 maintainers Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] severing module.h->sched.hAl Viro
2006-10-17[PATCH] rename net_random to random32Stephen Hemminger
Make net_random() more widely available by calling it random32 akpm: hopefully this will permit the removal of carta_random32. That needs confirmation from Stephane - this code looks somewhat more computationally expensive, and has a different (ie: callee-stateful) interface. [akpm@osdl.org: lots of build fixes, cleanups] Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
