path: root/kernel
2013-07-13futex: Take hugepages into account when generating futex_keyZhang Yi
commit 13d60f4b6ab5b702dc8d2ee20999f98a93728aec upstream. The futex_keys of process shared futexes are generated from the page offset, the mapping host and the mapping index of the futex user space address. This should result in an unique identifier for each futex. Though this is not true when futexes are located in different subpages of an hugepage. The reason is, that the mapping index for all those futexes evaluates to the index of the base page of the hugetlbfs mapping. So a futex at offset 0 of the hugepage mapping and another one at offset PAGE_SIZE of the same hugepage mapping have identical futex_keys. This happens because the futex code blindly uses page->index. Steps to reproduce the bug: 1. Map a file from hugetlbfs. Initialize pthread_mutex1 at offset 0 and pthread_mutex2 at offset PAGE_SIZE of the hugetlbfs mapping. The mutexes must be initialized as PTHREAD_PROCESS_SHARED because PTHREAD_PROCESS_PRIVATE mutexes are not affected by this issue as their keys solely depend on the user space address. 2. Lock mutex1 and mutex2 3. Create thread1 and in the thread function lock mutex1, which results in thread1 blocking on the locked mutex1. 4. Create thread2 and in the thread function lock mutex2, which results in thread2 blocking on the locked mutex2. 5. Unlock mutex2. Despite the fact that mutex2 got unlocked, thread2 still blocks on mutex2 because the futex_key points to mutex1. To solve this issue we need to take the normal page index of the page which contains the futex into account, if the futex is in an hugetlbfs mapping. In other words, we calculate the normal page mapping index of the subpage in the hugetlbfs mapping. Mappings which are not based on hugetlbfs are not affected and still use page->index. Thanks to Mel Gorman who provided a patch for adding proper evaluation functions to the hugetlbfs code to avoid exposing hugetlbfs specific details to the futex code. [ tglx: Massaged changelog ] Signed-off-by: Zhang Yi <zhang.yi20@zte.com.cn> Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn> Tested-by: Ma Chenggong <ma.chenggong@zte.com.cn> Reviewed-by: 'Mel Gorman' <mgorman@suse.de> Acked-by: 'Darren Hart' <dvhart@linux.intel.com> Cc: 'Peter Zijlstra' <peterz@infradead.org> Link: http://lkml.kernel.org/r/000101ce71a6%24a83c5880%24f8b50980%24@com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-13module: do percpu allocation after uniqueness check. No, really!Rusty Russell
commit 8d8022e8aba85192e937f1f0f7450e256d66ae5c upstream. v3.8-rc1-5-g1fb9341 was supposed to stop parallel kvm loads exhausting percpu memory on large machines: Now we have a new state MODULE_STATE_UNFORMED, we can insert the module into the list (and thus guarantee its uniqueness) before we allocate the per-cpu region. In my defence, it didn't actually say the patch did this. Just that we "can". This patch actually *does* it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Jim Hull <jim.hull@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-29Fix: kernel/ptrace.c: ptrace_peek_siginfo() missing __put_user() validationMathieu Desnoyers
This __put_user() could be used by unprivileged processes to write into kernel memory. The issue here is that even if copy_siginfo_to_user() fails, the error code is not checked before __put_user() is executed. Luckily, ptrace_peek_siginfo() has been added within the 3.10-rc cycle, so it has not hit a stable release yet. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Oleg Nesterov <oleg@redhat.com> Cc: Andrey Vagin <avagin@openvz.org> Cc: Roland McGrath <roland@redhat.com> Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Pedro Alves <palves@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "Correct an ordering issue in the tick broadcast code. I really wish we'd get compensation for pain and suffering for each line of code we write to work around dysfunctional timer hardware." * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Fix tick_broadcast_pending_mask not cleared
2013-06-26Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Three small fixlets" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: hw_breakpoint: Use cpu_possible_mask in {reserve,release}_bp_slot() hw_breakpoint: Fix cpu check in task_bp_pinned(cpu) kprobes: Fix arch_prepare_kprobe to handle copy insn failures
2013-06-21Merge branch 'x86/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: "This series fixes a couple of build failures, and fixes MTRR cleanup and memory setup on very specific memory maps. Finally, it fixes triggering backtraces on all CPUs, which was inadvertently disabled on x86." * 'x86/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/efi: Fix dummy variable buffer allocation x86: Fix trigger_all_cpu_backtrace() implementation x86: Fix section mismatch on load_ucode_ap x86: fix build error and kconfig for ia32_emulation and binfmt range: Do not add new blank slot with add_range_with_merge x86, mtrr: Fix original mtrr range get for mtrr_cleanup
2013-06-21tick: Fix tick_broadcast_pending_mask not clearedDaniel Lezcano
The recent modification in the cpuidle framework consolidated the timer broadcast code across the different drivers by setting a new flag in the idle state. It tells the cpuidle core code to enter/exit the broadcast mode for the cpu when entering a deep idle state. The broadcast timer enter/exit is no longer handled by the back-end driver. This change made the local interrupt to be enabled *before* calling CLOCK_EVENT_NOTIFY_EXIT. On a tegra114, a four cores system, when the flag has been introduced in the driver, the following warning appeared: WARNING: at kernel/time/tick-broadcast.c:578 tick_broadcast_oneshot_control CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.0-rc3-next-20130529+ #15 [<c00667f8>] (tick_broadcast_oneshot_control+0x1a4/0x1d0) from [<c0065cd0>] (tick_notify+0x240/0x40c) [<c0065cd0>] (tick_notify+0x240/0x40c) from [<c0044724>] (notifier_call_chain+0x44/0x84) [<c0044724>] (notifier_call_chain+0x44/0x84) from [<c0044828>] (raw_notifier_call_chain+0x18/0x20) [<c0044828>] (raw_notifier_call_chain+0x18/0x20) from [<c00650cc>] (clockevents_notify+0x28/0x170) [<c00650cc>] (clockevents_notify+0x28/0x170) from [<c033f1f0>] (cpuidle_idle_call+0x11c/0x168) [<c033f1f0>] (cpuidle_idle_call+0x11c/0x168) from [<c000ea94>] (arch_cpu_idle+0x8/0x38) [<c000ea94>] (arch_cpu_idle+0x8/0x38) from [<c005ea80>] (cpu_startup_entry+0x60/0x134) [<c005ea80>] (cpu_startup_entry+0x60/0x134) from [<804fe9a4>] (0x804fe9a4) I don't have the hardware, so I wasn't able to reproduce the warning but after looking a while at the code, I deduced the following: 1. the CPU2 enters a deep idle state and sets the broadcast timer 2. the timer expires, the tick_handle_oneshot_broadcast function is called, setting the tick_broadcast_pending_mask and waking up the idle cpu CPU2 3. the CPU2 exits idle handles the interrupt and then invokes tick_broadcast_oneshot_control with CLOCK_EVENT_NOTIFY_EXIT which runs the following code: [...] if (dev->next_event.tv64 == KTIME_MAX) goto out; if (cpumask_test_and_clear_cpu(cpu, tick_broadcast_pending_mask)) goto out; [...] So if there is no next event scheduled for CPU2, we fulfil the first condition and jump out without clearing the tick_broadcast_pending_mask. 4. CPU2 goes to deep idle again and calls tick_broadcast_oneshot_control with CLOCK_NOTIFY_EVENT_ENTER but with the tick_broadcast_pending_mask set for CPU2, triggering the warning. The issue only surfaced due to the modifications of the cpuidle framework, which resulted in interrupts being enabled before the call to the clockevents code. If the call happens before interrupts have been enabled, the warning cannot trigger, because there is still the event pending which caused the broadcast timer expiry. Move the check for the next event below the check for the pending bit, so the pending bit gets cleared whether an event is scheduled on the cpu or not. [ tglx: Massaged changelog ] Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org> Reported-and-tested-by: Joseph Lo <josephl@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: linux-arm-kernel@lists.infradead.org Cc: linaro-kernel@lists.linaro.org Link: http://lkml.kernel.org/r/1371485735-31249-1-git-send-email-daniel.lezcano@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-20Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Two smaller fixes - plus a context tracking tracing fix that is a bit bigger" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tracing/context-tracking: Add preempt_schedule_context() for tracing sched: Fix clear NOHZ_BALANCE_KICK sched/x86: Construct all sibling maps if smt
2013-06-20Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Four fixes. The mmap ones are unfortunately larger than desired - fuzzing uncovered bugs that needed perf context life time management changes to fix properly" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86: Fix broken PEBS-LL support on SNB-EP/IVB-EP perf: Fix mmap() accounting hole perf: Fix perf mmap bugs kprobes: Fix to free gone and unused optprobes
2013-06-20Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull cpu idle fixes from Thomas Gleixner: - Add a missing irq enable. Fallout of the idle conversion - Fix stackprotector wreckage caused by the idle conversion * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: idle: Enable interrupts in the weak arch_cpu_idle() implementation idle: Add the stack canary init to cpu_startup_entry()
2013-06-20Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: - Fix inconstinant clock usage in virtual time accounting - Fix a build error in KVM caused by the NOHZ work - Remove a pointless timekeeping duty assignment which breaks NOHZ - Use a proper notifier return value to avoid random behaviour * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Remove useless timekeeping duty attribution to broadcast source nohz: Fix notifier return val that enforce timekeeping kvm: Move guest entry/exit APIs to context_tracking vtime: Use consistent clocks among nohz accounting
2013-06-20hw_breakpoint: Use cpu_possible_mask in {reserve,release}_bp_slot()Oleg Nesterov
fetch_bp_busy_slots() and toggle_bp_slot() use for_each_online_cpu(), this is obviously wrong wrt cpu_up() or cpu_down(), we can over/under account the per-cpu numbers. For example: # echo 0 >> /sys/devices/system/cpu/cpu1/online # perf record -e mem:0x10 -p 1 & # echo 1 >> /sys/devices/system/cpu/cpu1/online # perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a & # taskset -p 0x2 1 triggers the same WARN_ONCE("Can't find any breakpoint slot") in arch_install_hw_breakpoint(). Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-20hw_breakpoint: Fix cpu check in task_bp_pinned(cpu)Oleg Nesterov
trinity fuzzer triggered WARN_ONCE("Can't find any breakpoint slot") in arch_install_hw_breakpoint() but the problem is not arch-specific. The problem is, task_bp_pinned(cpu) checks "cpu == iter->cpu" but this doesn't account the "all cpus" events with iter->cpu < 0. This means that, say, register_user_hw_breakpoint(tsk) can happily create the arbitrary number > HBP_NUM of breakpoints which can not be activated. toggle_bp_task_slot() is equally wrong by the same reason and nr_task_bp_pinned[] can have negative entries. Simple test: # perl -e 'sleep 1 while 1' & # perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10,mem:0x10 -p `pidof perl` Before this patch this triggers the same problem/WARN_ON(), after the patch it correctly fails with -ENOSPC. Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20130620155006.GA6324@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-19tracing/context-tracking: Add preempt_schedule_context() for tracingSteven Rostedt
Dave Jones hit the following bug report: =============================== [ INFO: suspicious RCU usage. ] 3.10.0-rc2+ #1 Not tainted ------------------------------- include/linux/rcupdate.h:771 rcu_read_lock() used illegally while idle! other info that might help us debug this: RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 0 RCU used illegally from extended quiescent state! 2 locks held by cc1/63645: #0: (&rq->lock){-.-.-.}, at: [<ffffffff816b39fd>] __schedule+0xed/0x9b0 #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8109d645>] cpuacct_charge+0x5/0x1f0 CPU: 1 PID: 63645 Comm: cc1 Not tainted 3.10.0-rc2+ #1 [loadavg: 40.57 27.55 13.39 25/277 64369] Hardware name: Gigabyte Technology Co., Ltd. GA-MA78GM-S2H/GA-MA78GM-S2H, BIOS F12a 04/23/2010 0000000000000000 ffff88010f78fcf8 ffffffff816ae383 ffff88010f78fd28 ffffffff810b698d ffff88011c092548 000000000023d073 ffff88011c092500 0000000000000001 ffff88010f78fd60 ffffffff8109d7c5 ffffffff8109d645 Call Trace: [<ffffffff816ae383>] dump_stack+0x19/0x1b [<ffffffff810b698d>] lockdep_rcu_suspicious+0xfd/0x130 [<ffffffff8109d7c5>] cpuacct_charge+0x185/0x1f0 [<ffffffff8109d645>] ? cpuacct_charge+0x5/0x1f0 [<ffffffff8108dffc>] update_curr+0xec/0x240 [<ffffffff8108f528>] put_prev_task_fair+0x228/0x480 [<ffffffff816b3a71>] __schedule+0x161/0x9b0 [<ffffffff816b4721>] preempt_schedule+0x51/0x80 [<ffffffff816b4800>] ? __cond_resched_softirq+0x60/0x60 [<ffffffff816b6824>] ? retint_careful+0x12/0x2e [<ffffffff810ff3cc>] ftrace_ops_control_func+0x1dc/0x210 [<ffffffff816be280>] ftrace_call+0x5/0x2f [<ffffffff816b681d>] ? retint_careful+0xb/0x2e [<ffffffff816b4805>] ? schedule_user+0x5/0x70 [<ffffffff816b4805>] ? schedule_user+0x5/0x70 [<ffffffff816b6824>] ? retint_careful+0x12/0x2e ------------[ cut here ]------------ What happened was that the function tracer traced the schedule_user() code that tells RCU that the system is coming back from userspace, and to add the CPU back to the RCU monitoring. Because the function tracer does a preempt_disable/enable_notrace() calls the preempt_enable_notrace() checks the NEED_RESCHED flag. If it is set, then preempt_schedule() is called. But this is called before the user_exit() function can inform the kernel that the CPU is no longer in user mode and needs to be accounted for by RCU. The fix is to create a new preempt_schedule_context() that checks if the kernel is still in user mode and if so to switch it to kernel mode before calling schedule. It also switches back to user mode coming back from schedule in need be. The only user of this currently is the preempt_enable_notrace(), which is only used by the tracing subsystem. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1369423420.6828.226.camel@gandalf.local.home Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-19sched: Fix clear NOHZ_BALANCE_KICKVincent Guittot
I have faced a sequence where the Idle Load Balance was sometime not triggered for a while on my platform, in the following scenario: CPU 0 and CPU 1 are running tasks and CPU 2 is idle CPU 1 kicks the Idle Load Balance CPU 1 selects CPU 2 as the new Idle Load Balancer CPU 2 sets NOHZ_BALANCE_KICK for CPU 2 CPU 2 sends a reschedule IPI to CPU 2 While CPU 3 wakes up, CPU 0 or CPU 1 migrates a waking up task A on CPU 2 CPU 2 finally wakes up, runs task A and discards the Idle Load Balance task A quickly goes back to sleep (before a tick occurs on CPU 2) CPU 2 goes back to idle with NOHZ_BALANCE_KICK set Whenever CPU 2 will be selected as the ILB, no reschedule IPI will be sent because NOHZ_BALANCE_KICK is already set and no Idle Load Balance will be performed. We must wait for the sched softirq to be raised on CPU 2 thanks to another part the kernel to come back to clear NOHZ_BALANCE_KICK. The proposed solution clears NOHZ_BALANCE_KICK in schedule_ipi if we can't raise the sched_softirq for the Idle Load Balance. Change since V1: - move the clear of NOHZ_BALANCE_KICK in got_nohz_idle_kick if the ILB can't run on this CPU (as suggested by Peter) Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1370419991-13870-1-git-send-email-vincent.guittot@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-19perf: Fix mmap() accounting holePeter Zijlstra
Vince's fuzzer once again found holes. This time it spotted a leak in the locked page accounting. When an event had redirected output and its close() was the last reference to the buffer we didn't have a vm context to undo accounting. Change the code to destroy the buffer on the last munmap() and detach all redirected events at that time. This provides us the right context to undo the vm accounting. Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-18range: Do not add new blank slot with add_range_with_mergeYinghai Lu
Joshua reported: Commit cd7b304dfaf1 (x86, range: fix missing merge during add range) broke mtrr cleanup on his setup in 3.9.5. corresponding commit in upstream is fbe06b7bae7c. The reason is add_range_with_merge could generate blank spot. We could avoid that by searching new expanded start/end, that new range should include all connected ranges in range array. At last add the new expanded start/end to the range array. Also move up left array so do not add new blank slot in the range array. -v2: move left array to avoid enhance add_range() -v3: include fix from Joshua about memmove declaring when DYN_DEBUG is used. Reported-by: Joshua Covington <joshuacov@googlemail.com> Tested-by: Joshua Covington <joshuacov@googlemail.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Link: http://lkml.kernel.org/r/1371154622-8929-3-git-send-email-yinghai@kernel.org Cc: <stable@vger.kernel.org> v3.9 Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS fixes from Al Viro: "Several fixes + obvious cleanup (you've missed a couple of open-coded can_lookup() back then)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: snd_pcm_link(): fix a leak... use can_lookup() instead of direct checks of ->i_op->lookup move exit_task_namespaces() outside of exit_notify() fput: task_work_add() can fail if the caller has passed exit_task_work() ncpfs: fix rmdir returns Device or resource busy
2013-06-15move exit_task_namespaces() outside of exit_notify()Oleg Nesterov
exit_notify() does exit_task_namespaces() after forget_original_parent(). This was needed to ensure that ->nsproxy can't be cleared prematurely, an exiting child we are going to reparent can do do_notify_parent() and use the parent's (ours) pid_ns. However, after 32084504 "pidns: use task_active_pid_ns in do_notify_parent" ->nsproxy != NULL is no longer needed, we rely on task_active_pid_ns(). Move exit_task_namespaces() from exit_notify() to do_exit(), after exit_fs() and before exit_task_work(). This solves the problem reported by Andrey, free_ipc_ns()->shm_destroy() does fput() which needs task_work_add(). Note: this particular problem can be fixed if we change fput(), and that change makes sense anyway. But there is another reason to move the callsite. The original reason for exit_task_namespaces() from the middle of exit_notify() was subtle and it has already gone away, now this looks confusing. And this allows us do simplify exit_notify(), we can avoid unlock/lock(tasklist) and we can use ->exit_state instead of PF_EXITING in forget_original_parent(). Reported-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Andrey Vagin <avagin@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-14idle: Enable interrupts in the weak arch_cpu_idle() implementationJames Bottomley
PARISC bootup triggers the warning at kernel/cpu/idle.c:96. That's caused by the weak arch_cpu_idle() implementation, which is provided to avoid that architectures implement idle_poll over and over. The switchover to polling mode happens in the first call of the weak arch_cpu_idle() implementation, but that code fails to reenable interrupts and therefor triggers the warning. Fix this by enabling interrupts in the weak arch_cpu_idle() code. [ tglx: Made the changelog match the patch ] Signed-off-by: James Bottomley <JBottomley@Parallels.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1371236142.2726.43.camel@dabdike Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-13Merge branch 'rcu/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu Pull RCU fixes from Paul McKenney: "I must confess that this past merge window was not RCU's best showing. This series contains three more fixes for RCU regressions: 1. A fix to __DECLARE_TRACE_RCU() that causes it to act as an interrupt from idle rather than as a task switch from idle. This change is needed due to the recent use of _rcuidle() tracepoints that can be invoked from interrupt handlers as well as from idle. Without this fix, invoking _rcuidle() tracepoints from interrupt handlers results in splats and (more seriously) confusion on RCU's part as to whether a given CPU is idle or not. This confusion can in turn result in too-short grace periods and therefore random memory corruption. 2. A fix to a subtle deadlock that could result due to RCU doing a wakeup while holding one of its rcu_node structure's locks. Although the probability of occurrence is low, it really does happen. The fix, courtesy of Steven Rostedt, uses irq_work_queue() to avoid the deadlock. 3. A fix to a silent deadlock (invisible to lockdep) due to the interaction of timeouts posted by RCU debug code enabled by CONFIG_PROVE_RCU_DELAY=y, grace-period initialization, and CPU hotplug operations. This will not occur in production kernels, but really does occur in randconfig testing. Diagnosis courtesy of Steven Rostedt" * 'rcu/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu: rcu: Fix deadlock with CPU hotplug, RCU GP init, and timer migration rcu: Don't call wakeup() with rcu_node structure ->lock held trace: Allow idle-safe tracepoints to be called from irq
2013-06-12Merge branch 'akpm' (updates from Andrew Morton)Linus Torvalds
Merge misc fixes from Andrew Morton: "Bunch of fixes and one little addition to math64.h" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (27 commits) include/linux/math64.h: add div64_ul() mm: memcontrol: fix lockless reclaim hierarchy iterator frontswap: fix incorrect zeroing and allocation size for frontswap_map kernel/audit_tree.c:audit_add_tree_rule(): protect `rule' from kill_rules() mm: migration: add migrate_entry_wait_huge() ocfs2: add missing lockres put in dlm_mig_lockres_handler mm/page_alloc.c: fix watermark check in __zone_watermark_ok() drivers/misc/sgi-gru/grufile.c: fix info leak in gru_get_config_info() aio: fix io_destroy() regression by using call_rcu() rtc-at91rm9200: use shadow IMR on at91sam9x5 rtc-at91rm9200: add shadow interrupt mask rtc-at91rm9200: refactor interrupt-register handling rtc-at91rm9200: add configuration support rtc-at91rm9200: add match-table compile guard fs/ocfs2/namei.c: remove unecessary ERROR when removing non-empty directory swap: avoid read_swap_cache_async() race to deadlock while waiting on discard I/O completion drivers/rtc/rtc-twl.c: fix missing device_init_wakeup() when booted with device tree cciss: fix broken mutex usage in ioctl audit: wait_for_auditd() should use TASK_UNINTERRUPTIBLE drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channel ...
2013-06-12kernel/audit_tree.c:audit_add_tree_rule(): protect `rule' from kill_rules()Chen Gang
audit_add_tree_rule() must set 'rule->tree = NULL;' firstly, to protect the rule itself freed in kill_rules(). The reason is when it is killed, the 'rule' itself may have already released, we should not access it. one example: we add a rule to an inode, just at the same time the other task is deleting this inode. The work flow for adding a rule: audit_receive() -> (need audit_cmd_mutex lock) audit_receive_skb() -> audit_receive_msg() -> audit_receive_filter() -> audit_add_rule() -> audit_add_tree_rule() -> (need audit_filter_mutex lock) ... unlock audit_filter_mutex get_tree() ... iterate_mounts() -> (iterate all related inodes) tag_mount() -> tag_trunk() -> create_trunk() -> (assume it is 1st rule) fsnotify_add_mark() -> fsnotify_add_inode_mark() -> (add mark to inode->i_fsnotify_marks) ... get_tree(); (each inode will get one) ... lock audit_filter_mutex The work flow for deleting an inode: __destroy_inode() -> fsnotify_inode_delete() -> __fsnotify_inode_delete() -> fsnotify_clear_marks_by_inode() -> (get mark from inode->i_fsnotify_marks) fsnotify_destroy_mark() -> fsnotify_destroy_mark_locked() -> audit_tree_freeing_mark() -> evict_chunk() -> ... tree->goner = 1 ... kill_rules() -> (assume current->audit_context == NULL) call_rcu() -> (rule->tree != NULL) audit_free_rule_rcu() -> audit_free_rule() ... audit_schedule_prune() -> (assume current->audit_context == NULL) kthread_run() -> (need audit_cmd_mutex and audit_filter_mutex lock) prune_one() -> (delete it from prue_list) put_tree(); (match the original get_tree above) Signed-off-by: Chen Gang <gang.chen@asianux.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12audit: wait_for_auditd() should use TASK_UNINTERRUPTIBLEOleg Nesterov
audit_log_start() does wait_for_auditd() in a loop until audit_backlog_wait_time passes or audit_skb_queue has a room. If signal_pending() is true this becomes a busy-wait loop, schedule() in TASK_INTERRUPTIBLE won't block. Thanks to Guy for fully investigating and explaining the problem. (akpm: that'll cause the system to lock up on a non-preemptible uniprocessor kernel) (Guy: "Our customer was in fact running a uniprocessor machine, and they reported a system hang.") Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Guy Streeter <streeter@redhat.com> Cc: Eric Paris <eparis@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12kmsg: honor dmesg_restrict sysctl on /dev/kmsgKees Cook
The dmesg_restrict sysctl currently covers the syslog method for access dmesg, however /dev/kmsg isn't covered by the same protections. Most people haven't noticed because util-linux dmesg(1) defaults to using the syslog method for access in older versions. With util-linux dmesg(1) defaults to reading directly from /dev/kmsg. To fix /dev/kmsg, let's compare the existing interfaces and what they allow: - /proc/kmsg allows: - open (SYSLOG_ACTION_OPEN) if CAP_SYSLOG since it uses a destructive single-reader interface (SYSLOG_ACTION_READ). - everything, after an open. - syslog syscall allows: - anything, if CAP_SYSLOG. - SYSLOG_ACTION_READ_ALL and SYSLOG_ACTION_SIZE_BUFFER, if dmesg_restrict==0. - nothing else (EPERM). The use-cases were: - dmesg(1) needs to do non-destructive SYSLOG_ACTION_READ_ALLs. - sysklog(1) needs to open /proc/kmsg, drop privs, and still issue the destructive SYSLOG_ACTION_READs. AIUI, dmesg(1) is moving to /dev/kmsg, and systemd-journald doesn't clear the ring buffer. Based on the comments in devkmsg_llseek, it sounds like actions besides reading aren't going to be supported by /dev/kmsg (i.e. SYSLOG_ACTION_CLEAR), so we have a strict subset of the non-destructive syslog syscall actions. To this end, move the check as Josh had done, but also rename the constants to reflect their new uses (SYSLOG_FROM_CALL becomes SYSLOG_FROM_READER, and SYSLOG_FROM_FILE becomes SYSLOG_FROM_PROC). SYSLOG_FROM_READER allows non-destructive actions, and SYSLOG_FROM_PROC allows destructive actions after a capabilities-constrained SYSLOG_ACTION_OPEN check. - /dev/kmsg allows: - open if CAP_SYSLOG or dmesg_restrict==0 - reading/polling, after open Addresses https://bugzilla.redhat.com/show_bug.cgi?id=903192 [akpm@linux-foundation.org: use pr_warn_once()] Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Christian Kujau <lists@nerdbynature.de> Tested-by: Josh Boyer <jwboyer@redhat.com> Cc: Kay Sievers <kay@vrfy.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12reboot: rigrate shutdown/reboot to boot cpuRobin Holt
We recently noticed that reboot of a 1024 cpu machine takes approx 16 minutes of just stopping the cpus. The slowdown was tracked to commit f96972f2dc63 ("kernel/sys.c: call disable_nonboot_cpus() in kernel_restart()"). The current implementation does all the work of hot removing the cpus before halting the system. We are switching to just migrating to the boot cpu and then continuing with shutdown/reboot. This also has the effect of not breaking x86's command line parameter for specifying the reboot cpu. Note, this code was shamelessly copied from arch/x86/kernel/reboot.c with bits removed pertaining to the reboot_cpu command line parameter. Signed-off-by: Robin Holt <holt@sgi.com> Tested-by: Shawn Guo <shawn.guo@linaro.org> Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12CPU hotplug: provide a generic helper to disable/enable CPU hotplugSrivatsa S. Bhat
There are instances in the kernel where we would like to disable CPU hotplug (from sysfs) during some important operation. Today the freezer code depends on this and the code to do it was kinda tailor-made for that. Restructure the code and make it generic enough to be useful for other usecases too. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Signed-off-by: Robin Holt <holt@sgi.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russ Anderson <rja@sgi.com> Cc: Robin Holt <holt@sgi.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-12Merge tag 'trace-fixes-v3.10-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "Yoshihiro Yunomae fixed a regression in the output format when using one of the counter clocks. The new multibuffer code changed the trace_clock file to update the trace instances tr->clock_id but the actual traces still used the value from the obsolete global variable trace_clock_id" * tag 'trace-fixes-v3.10-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Fix outputting formats of x86-tsc and counter when use trace_clock
2013-06-11idle: Add the stack canary init to cpu_startup_entry()Thomas Gleixner
Moving x86 to the generic idle implementation (commit 7d1a9417 "x86: Use generic idle loop") wreckaged the stack protector. I stupidly missed that boot_init_stack_canary() must be inlined from a function which never returns, but I put that call into arch_cpu_idle_prepare() which of course returns. I pondered to play tricks with arch_cpu_idle_prepare() first, but then I noticed, that the other archs which have implemented the stackprotector (ARM and SH) do not initialize the canary for the non-boot cpus. So I decided to move the boot_init_stack_canary() call into cpu_startup_entry() ifdeffed with an CONFIG_X86 for now. This #ifdef is just a temporary measure as I don't want to inflict the boot_init_stack_canary() call on ARM and SH that late in the cycle. I'll queue a patch for 3.11 which removes the #ifdef if the ARM/SH maintainers have no objection. Reported-by: Wouter van Kesteren <woutershep@gmail.com> Cc: x86@kernel.org Cc: Russell King <linux@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-06-11tracing: Fix outputting formats of x86-tsc and counter when use trace_clockYoshihiro YUNOMAE
Outputting formats of x86-tsc and counter should be a raw format, but after applying the patch(2b6080f28c7cc3efc8625ab71495aae89aeb63a0), the format was changed to nanosec. This is because the global variable trace_clock_id was used. When we use multiple buffers, clock_id of each sub-buffer should be used. Then, this patch uses tr->clock_id instead of the global variable trace_clock_id. [ Basically, this fixes a regression where the multibuffer code changed the trace_clock file to update tr->clock_id but the traces still use the old global trace_clock_id variable, negating the file's effect. The global trace_clock_id variable is obsolete and removed. - SR ] Link: http://lkml.kernel.org/r/20130423013239.22334.7394.stgit@yunodevel Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-06-10Fix lockup related to stop_machine being stuck in __do_softirq.Ben Greear
The stop machine logic can lock up if all but one of the migration threads make it through the disable-irq step and the one remaining thread gets stuck in __do_softirq. The reason __do_softirq can hang is that it has a bail-out based on jiffies timeout, but in the lockup case, jiffies itself is not incremented. To work around this, re-add the max_restart counter in __do_irq and stop processing irqs after 10 restarts. Thanks to Tejun Heo and Rusty Russell and others for helping me track this down. This was introduced in 3.9 by commit c10d73671ad3 ("softirq: reduce latencies"). It may be worth looking into ath9k to see if it has issues with its irq handler at a later date. The hang stack traces look something like this: ------------[ cut here ]------------ WARNING: at kernel/watchdog.c:245 watchdog_overflow_callback+0x9c/0xa7() Watchdog detected hard LOCKUP on cpu 2 Modules linked in: ath9k ath9k_common ath9k_hw ath mac80211 cfg80211 nfsv4 auth_rpcgss nfs fscache nf_nat_ipv4 nf_nat veth 8021q garp stp mrp llc pktgen lockd sunrpc] Pid: 23, comm: migration/2 Tainted: G C 3.9.4+ #11 Call Trace: <NMI> warn_slowpath_common+0x85/0x9f warn_slowpath_fmt+0x46/0x48 watchdog_overflow_callback+0x9c/0xa7 __perf_event_overflow+0x137/0x1cb perf_event_overflow+0x14/0x16 intel_pmu_handle_irq+0x2dc/0x359 perf_event_nmi_handler+0x19/0x1b nmi_handle+0x7f/0xc2 do_nmi+0xbc/0x304 end_repeat_nmi+0x1e/0x2e <<EOE>> cpu_stopper_thread+0xae/0x162 smpboot_thread_fn+0x258/0x260 kthread+0xc7/0xcf ret_from_fork+0x7c/0xb0 ---[ end trace 4947dfa9b0a4cec3 ]--- BUG: soft lockup - CPU#1 stuck for 22s! [migration/1:17] Modules linked in: ath9k ath9k_common ath9k_hw ath mac80211 cfg80211 nfsv4 auth_rpcgss nfs fscache nf_nat_ipv4 nf_nat veth 8021q garp stp mrp llc pktgen lockd sunrpc] irq event stamp: 835637905 hardirqs last enabled at (835637904): __do_softirq+0x9f/0x257 hardirqs last disabled at (835637905): apic_timer_interrupt+0x6d/0x80 softirqs last enabled at (5654720): __do_softirq+0x1ff/0x257 softirqs last disabled at (5654725): irq_exit+0x5f/0xbb CPU 1 Pid: 17, comm: migration/1 Tainted: G WC 3.9.4+ #11 To be filled by O.E.M. To be filled by O.E.M./To be filled by O.E.M. RIP: tasklet_hi_action+0xf0/0xf0 Process migration/1 Call Trace: <IRQ> __do_softirq+0x117/0x257 irq_exit+0x5f/0xbb smp_apic_timer_interrupt+0x8a/0x98 apic_timer_interrupt+0x72/0x80 <EOI> printk+0x4d/0x4f stop_machine_cpu_stop+0x22c/0x274 cpu_stopper_thread+0xae/0x162 smpboot_thread_fn+0x258/0x260 kthread+0xc7/0xcf ret_from_fork+0x7c/0xb0 Signed-off-by: Ben Greear <greearb@candelatech.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Pekka Riikonen <priikone@iki.fi> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-10rcu: Fix deadlock with CPU hotplug, RCU GP init, and timer migrationPaul E. McKenney
In Steven Rostedt's words: > I've been debugging the last couple of days why my tests have been > locking up. One of my tracing tests, runs all available tracers. The > lockup always happened with the mmiotrace, which is used to trace > interactions between priority drivers and the kernel. But to do this > easily, when the tracer gets registered, it disables all but the boot > CPUs. The lockup always happened after it got done disabling the CPUs. > > Then I decided to try this: > > while :; do > for i in 1 2 3; do > echo 0 > /sys/devices/system/cpu/cpu$i/online > done > for i in 1 2 3; do > echo 1 > /sys/devices/system/cpu/cpu$i/online > done > done > > Well, sure enough, that locked up too, with the same users. Doing a > sysrq-w (showing all blocked tasks): > > [ 2991.344562] task PC stack pid father > [ 2991.344562] rcu_preempt D ffff88007986fdf8 0 10 2 0x00000000 > [ 2991.344562] ffff88007986fc98 0000000000000002 ffff88007986fc48 0000000000000908 > [ 2991.344562] ffff88007986c280 ffff88007986ffd8 ffff88007986ffd8 00000000001d3c80 > [ 2991.344562] ffff880079248a40 ffff88007986c280 0000000000000000 00000000fffd4295 > [ 2991.344562] Call Trace: > [ 2991.344562] [<ffffffff815437ba>] schedule+0x64/0x66 > [ 2991.344562] [<ffffffff81541750>] schedule_timeout+0xbc/0xf9 > [ 2991.344562] [<ffffffff8154bec0>] ? ftrace_call+0x5/0x2f > [ 2991.344562] [<ffffffff81049513>] ? cascade+0xa8/0xa8 > [ 2991.344562] [<ffffffff815417ab>] schedule_timeout_uninterruptible+0x1e/0x20 > [ 2991.344562] [<ffffffff810c980c>] rcu_gp_kthread+0x502/0x94b > [ 2991.344562] [<ffffffff81062791>] ? __init_waitqueue_head+0x50/0x50 > [ 2991.344562] [<ffffffff810c930a>] ? rcu_gp_fqs+0x64/0x64 > [ 2991.344562] [<ffffffff81061cdb>] kthread+0xb1/0xb9 > [ 2991.344562] [<ffffffff81091e31>] ? lock_release_holdtime.part.23+0x4e/0x55 > [ 2991.344562] [<ffffffff81061c2a>] ? __init_kthread_worker+0x58/0x58 > [ 2991.344562] [<ffffffff8154c1dc>] ret_from_fork+0x7c/0xb0 > [ 2991.344562] [<ffffffff81061c2a>] ? __init_kthread_worker+0x58/0x58 > [ 2991.344562] kworker/0:1 D ffffffff81a30680 0 47 2 0x00000000 > [ 2991.344562] Workqueue: events cpuset_hotplug_workfn > [ 2991.344562] ffff880078dbbb58 0000000000000002 0000000000000006 00000000000000d8 > [ 2991.344562] ffff880078db8100 ffff880078dbbfd8 ffff880078dbbfd8 00000000001d3c80 > [ 2991.344562] ffff8800779ca5c0 ffff880078db8100 ffffffff81541fcf 0000000000000000 > [ 2991.344562] Call Trace: > [ 2991.344562] [<ffffffff81541fcf>] ? __mutex_lock_common+0x3d4/0x609 > [ 2991.344562] [<ffffffff815437ba>] schedule+0x64/0x66 > [ 2991.344562] [<ffffffff81543a39>] schedule_preempt_disabled+0x18/0x24 > [ 2991.344562] [<ffffffff81541fcf>] __mutex_lock_common+0x3d4/0x609 > [ 2991.344562] [<ffffffff8103d11b>] ? get_online_cpus+0x3c/0x50 > [ 2991.344562] [<ffffffff8103d11b>] ? get_online_cpus+0x3c/0x50 > [ 2991.344562] [<ffffffff815422ff>] mutex_lock_nested+0x3b/0x40 > [ 2991.344562] [<ffffffff8103d11b>] get_online_cpus+0x3c/0x50 > [ 2991.344562] [<ffffffff810af7e6>] rebuild_sched_domains_locked+0x6e/0x3a8 > [ 2991.344562] [<ffffffff810b0ec6>] rebuild_sched_domains+0x1c/0x2a > [ 2991.344562] [<ffffffff810b109b>] cpuset_hotplug_workfn+0x1c7/0x1d3 > [ 2991.344562] [<ffffffff810b0ed9>] ? cpuset_hotplug_workfn+0x5/0x1d3 > [ 2991.344562] [<ffffffff81058e07>] process_one_work+0x2d4/0x4d1 > [ 2991.344562] [<ffffffff81058d3a>] ? process_one_work+0x207/0x4d1 > [ 2991.344562] [<ffffffff8105964c>] worker_thread+0x2e7/0x3b5 > [ 2991.344562] [<ffffffff81059365>] ? rescuer_thread+0x332/0x332 > [ 2991.344562] [<ffffffff81061cdb>] kthread+0xb1/0xb9 > [ 2991.344562] [<ffffffff81061c2a>] ? __init_kthread_worker+0x58/0x58 > [ 2991.344562] [<ffffffff8154c1dc>] ret_from_fork+0x7c/0xb0 > [ 2991.344562] [<ffffffff81061c2a>] ? __init_kthread_worker+0x58/0x58 > [ 2991.344562] bash D ffffffff81a4aa80 0 2618 2612 0x10000000 > [ 2991.344562] ffff8800379abb58 0000000000000002 0000000000000006 0000000000000c2c > [ 2991.344562] ffff880077fea140 ffff8800379abfd8 ffff8800379abfd8 00000000001d3c80 > [ 2991.344562] ffff8800779ca5c0 ffff880077fea140 ffffffff81541fcf 0000000000000000 > [ 2991.344562] Call Trace: > [ 2991.344562] [<ffffffff81541fcf>] ? __mutex_lock_common+0x3d4/0x609 > [ 2991.344562] [<ffffffff815437ba>] schedule+0x64/0x66 > [ 2991.344562] [<ffffffff81543a39>] schedule_preempt_disabled+0x18/0x24 > [ 2991.344562] [<ffffffff81541fcf>] __mutex_lock_common+0x3d4/0x609 > [ 2991.344562] [<ffffffff81530078>] ? rcu_cpu_notify+0x2f5/0x86e > [ 2991.344562] [<ffffffff81530078>] ? rcu_cpu_notify+0x2f5/0x86e > [ 2991.344562] [<ffffffff815422ff>] mutex_lock_nested+0x3b/0x40 > [ 2991.344562] [<ffffffff81530078>] rcu_cpu_notify+0x2f5/0x86e > [ 2991.344562] [<ffffffff81091c99>] ? __lock_is_held+0x32/0x53 > [ 2991.344562] [<ffffffff81548912>] notifier_call_chain+0x6b/0x98 > [ 2991.344562] [<ffffffff810671fd>] __raw_notifier_call_chain+0xe/0x10 > [ 2991.344562] [<ffffffff8103cf64>] __cpu_notify+0x20/0x32 > [ 2991.344562] [<ffffffff8103cf8d>] cpu_notify_nofail+0x17/0x36 > [ 2991.344562] [<ffffffff815225de>] _cpu_down+0x154/0x259 > [ 2991.344562] [<ffffffff81522710>] cpu_down+0x2d/0x3a > [ 2991.344562] [<ffffffff81526351>] store_online+0x4e/0xe7 > [ 2991.344562] [<ffffffff8134d764>] dev_attr_store+0x20/0x22 > [ 2991.344562] [<ffffffff811b3c5f>] sysfs_write_file+0x108/0x144 > [ 2991.344562] [<ffffffff8114c5ef>] vfs_write+0xfd/0x158 > [ 2991.344562] [<ffffffff8114c928>] SyS_write+0x5c/0x83 > [ 2991.344562] [<ffffffff8154c494>] tracesys+0xdd/0xe2 > > As well as held locks: > > [ 3034.728033] Showing all locks held in the system: > [ 3034.728033] 1 lock held by rcu_preempt/10: > [ 3034.728033] #0: (rcu_preempt_state.onoff_mutex){+.+...}, at: [<ffffffff810c9471>] rcu_gp_kthread+0x167/0x94b > [ 3034.728033] 4 locks held by kworker/0:1/47: > [ 3034.728033] #0: (events){.+.+.+}, at: [<ffffffff81058d3a>] process_one_work+0x207/0x4d1 > [ 3034.728033] #1: (cpuset_hotplug_work){+.+.+.}, at: [<ffffffff81058d3a>] process_one_work+0x207/0x4d1 > [ 3034.728033] #2: (cpuset_mutex){+.+.+.}, at: [<ffffffff810b0ec1>] rebuild_sched_domains+0x17/0x2a > [ 3034.728033] #3: (cpu_hotplug.lock){+.+.+.}, at: [<ffffffff8103d11b>] get_online_cpus+0x3c/0x50 > [ 3034.728033] 1 lock held by mingetty/2563: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > [ 3034.728033] 1 lock held by mingetty/2565: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > [ 3034.728033] 1 lock held by mingetty/2569: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > [ 3034.728033] 1 lock held by mingetty/2572: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > [ 3034.728033] 1 lock held by mingetty/2575: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > [ 3034.728033] 7 locks held by bash/2618: > [ 3034.728033] #0: (sb_writers#5){.+.+.+}, at: [<ffffffff8114bc3f>] file_start_write+0x2a/0x2c > [ 3034.728033] #1: (&buffer->mutex#2){+.+.+.}, at: [<ffffffff811b3b93>] sysfs_write_file+0x3c/0x144 > [ 3034.728033] #2: (s_active#54){.+.+.+}, at: [<ffffffff811b3c3e>] sysfs_write_file+0xe7/0x144 > [ 3034.728033] #3: (x86_cpu_hotplug_driver_mutex){+.+.+.}, at: [<ffffffff810217c2>] cpu_hotplug_driver_lock+0x17/0x19 > [ 3034.728033] #4: (cpu_add_remove_lock){+.+.+.}, at: [<ffffffff8103d196>] cpu_maps_update_begin+0x17/0x19 > [ 3034.728033] #5: (cpu_hotplug.lock){+.+.+.}, at: [<ffffffff8103cfd8>] cpu_hotplug_begin+0x2c/0x6d > [ 3034.728033] #6: (rcu_preempt_state.onoff_mutex){+.+...}, at: [<ffffffff81530078>] rcu_cpu_notify+0x2f5/0x86e > [ 3034.728033] 1 lock held by bash/2980: > [ 3034.728033] #0: (&ldata->atomic_read_lock){+.+...}, at: [<ffffffff8131e28a>] n_tty_read+0x252/0x7e8 > > Things looked a little weird. Also, this is a deadlock that lockdep did > not catch. But what we have here does not look like a circular lock > issue: > > Bash is blocked in rcu_cpu_notify(): > > 1961 /* Exclude any attempts to start a new grace period. */ > 1962 mutex_lock(&rsp->onoff_mutex); > > > kworker is blocked in get_online_cpus(), which makes sense as we are > currently taking down a CPU. > > But rcu_preempt is not blocked on anything. It is simply sleeping in > rcu_gp_kthread (really rcu_gp_init) here: > > 1453 #ifdef CONFIG_PROVE_RCU_DELAY > 1454 if ((prandom_u32() % (rcu_num_nodes * 8)) == 0 && > 1455 system_state == SYSTEM_RUNNING) > 1456 schedule_timeout_uninterruptible(2); > 1457 #endif /* #ifdef CONFIG_PROVE_RCU_DELAY */ > > And it does this while holding the onoff_mutex that bash is waiting for. > > Doing a function trace, it showed me where it happened: > > [ 125.940066] rcu_pree-10 3.... 28384115273: schedule_timeout_uninterruptible <-rcu_gp_kthread > [...] > [ 125.940066] rcu_pree-10 3d..3 28384202439: sched_switch: prev_comm=rcu_preempt prev_pid=10 prev_prio=120 prev_state=D ==> next_comm=watchdog/3 next_pid=38 next_prio=120 > > The watchdog ran, and then: > > [ 125.940066] watchdog-38 3d..3 28384692863: sched_switch: prev_comm=watchdog/3 prev_pid=38 prev_prio=120 prev_state=P ==> next_comm=modprobe next_pid=2848 next_prio=118 > > Not sure what modprobe was doing, but shortly after that: > > [ 125.940066] modprobe-2848 3d..3 28385041749: sched_switch: prev_comm=modprobe prev_pid=2848 prev_prio=118 prev_state=R+ ==> next_comm=migration/3 next_pid=40 next_prio=0 > > Where the migration thread took down the CPU: > > [ 125.940066] migratio-40 3d..3 28389148276: sched_switch: prev_comm=migration/3 prev_pid=40 prev_prio=0 prev_state=P ==> next_comm=swapper/3 next_pid=0 next_prio=120 > > which finally did: > > [ 125.940066] <idle>-0 3...1 28389282142: arch_cpu_idle_dead <-cpu_startup_entry > [ 125.940066] <idle>-0 3...1 28389282548: native_play_dead <-arch_cpu_idle_dead > [ 125.940066] <idle>-0 3...1 28389282924: play_dead_common <-native_play_dead > [ 125.940066] <idle>-0 3...1 28389283468: idle_task_exit <-play_dead_common > [ 125.940066] <idle>-0 3...1 28389284644: amd_e400_remove_cpu <-play_dead_common > > > CPU 3 is now offline, the rcu_preempt thread that ran on CPU 3 is still > doing a schedule_timeout_uninterruptible() and it registered it's > timeout to the timer base for CPU 3. You would think that it would get > migrated right? The issue here is that the timer migration happens at > the CPU notifier for CPU_DEAD. The problem is that the rcu notifier for > CPU_DOWN is blocked waiting for the onoff_mutex to be released, which is > held by the thread that just put itself into a uninterruptible sleep, > that wont wake up until the CPU_DEAD notifier of the timer > infrastructure is called, which wont happen until the rcu notifier > finishes. Here's our deadlock! This commit breaks this deadlock cycle by substituting a shorter udelay() for the previous schedule_timeout_uninterruptible(), while at the same time increasing the probability of the delay. This maintains the intensity of the testing. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Steven Rostedt <rostedt@goodmis.org>
2013-06-10rcu: Don't call wakeup() with rcu_node structure ->lock heldSteven Rostedt
This commit fixes a lockdep-detected deadlock by moving a wake_up() call out from a rnp->lock critical section. Please see below for the long version of this story. On Tue, 2013-05-28 at 16:13 -0400, Dave Jones wrote: > [12572.705832] ====================================================== > [12572.750317] [ INFO: possible circular locking dependency detected ] > [12572.796978] 3.10.0-rc3+ #39 Not tainted > [12572.833381] ------------------------------------------------------- > [12572.862233] trinity-child17/31341 is trying to acquire lock: > [12572.870390] (rcu_node_0){..-.-.}, at: [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12572.878859] > but task is already holding lock: > [12572.894894] (&ctx->lock){-.-...}, at: [<ffffffff811390ed>] perf_lock_task_context+0x7d/0x2d0 > [12572.903381] > which lock already depends on the new lock. > > [12572.927541] > the existing dependency chain (in reverse order) is: > [12572.943736] > -> #4 (&ctx->lock){-.-...}: > [12572.960032] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12572.968337] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12572.976633] [<ffffffff8113c987>] __perf_event_task_sched_out+0x2e7/0x5e0 > [12572.984969] [<ffffffff81088953>] perf_event_task_sched_out+0x93/0xa0 > [12572.993326] [<ffffffff816ea0bf>] __schedule+0x2cf/0x9c0 > [12573.001652] [<ffffffff816eacfe>] schedule_user+0x2e/0x70 > [12573.009998] [<ffffffff816ecd64>] retint_careful+0x12/0x2e > [12573.018321] > -> #3 (&rq->lock){-.-.-.}: > [12573.034628] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.042930] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.051248] [<ffffffff8108e6a7>] wake_up_new_task+0xb7/0x260 > [12573.059579] [<ffffffff810492f5>] do_fork+0x105/0x470 > [12573.067880] [<ffffffff81049686>] kernel_thread+0x26/0x30 > [12573.076202] [<ffffffff816cee63>] rest_init+0x23/0x140 > [12573.084508] [<ffffffff81ed8e1f>] start_kernel+0x3f1/0x3fe > [12573.092852] [<ffffffff81ed856f>] x86_64_start_reservations+0x2a/0x2c > [12573.101233] [<ffffffff81ed863d>] x86_64_start_kernel+0xcc/0xcf > [12573.109528] > -> #2 (&p->pi_lock){-.-.-.}: > [12573.125675] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.133829] [<ffffffff816ebe9b>] _raw_spin_lock_irqsave+0x4b/0x90 > [12573.141964] [<ffffffff8108e881>] try_to_wake_up+0x31/0x320 > [12573.150065] [<ffffffff8108ebe2>] default_wake_function+0x12/0x20 > [12573.158151] [<ffffffff8107bbf8>] autoremove_wake_function+0x18/0x40 > [12573.166195] [<ffffffff81085398>] __wake_up_common+0x58/0x90 > [12573.174215] [<ffffffff81086909>] __wake_up+0x39/0x50 > [12573.182146] [<ffffffff810fc3da>] rcu_start_gp_advanced.isra.11+0x4a/0x50 > [12573.190119] [<ffffffff810fdb09>] rcu_start_future_gp+0x1c9/0x1f0 > [12573.198023] [<ffffffff810fe2c4>] rcu_nocb_kthread+0x114/0x930 > [12573.205860] [<ffffffff8107a91d>] kthread+0xed/0x100 > [12573.213656] [<ffffffff816f4b1c>] ret_from_fork+0x7c/0xb0 > [12573.221379] > -> #1 (&rsp->gp_wq){..-.-.}: > [12573.236329] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.243783] [<ffffffff816ebe9b>] _raw_spin_lock_irqsave+0x4b/0x90 > [12573.251178] [<ffffffff810868f3>] __wake_up+0x23/0x50 > [12573.258505] [<ffffffff810fc3da>] rcu_start_gp_advanced.isra.11+0x4a/0x50 > [12573.265891] [<ffffffff810fdb09>] rcu_start_future_gp+0x1c9/0x1f0 > [12573.273248] [<ffffffff810fe2c4>] rcu_nocb_kthread+0x114/0x930 > [12573.280564] [<ffffffff8107a91d>] kthread+0xed/0x100 > [12573.287807] [<ffffffff816f4b1c>] ret_from_fork+0x7c/0xb0 Notice the above call chain. rcu_start_future_gp() is called with the rnp->lock held. Then it calls rcu_start_gp_advance, which does a wakeup. You can't do wakeups while holding the rnp->lock, as that would mean that you could not do a rcu_read_unlock() while holding the rq lock, or any lock that was taken while holding the rq lock. This is because... (See below). > [12573.295067] > -> #0 (rcu_node_0){..-.-.}: > [12573.309293] [<ffffffff810b8d36>] __lock_acquire+0x1786/0x1af0 > [12573.316568] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.323825] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.331081] [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12573.338377] [<ffffffff810760a6>] __rcu_read_unlock+0x96/0xa0 > [12573.345648] [<ffffffff811391b3>] perf_lock_task_context+0x143/0x2d0 > [12573.352942] [<ffffffff8113938e>] find_get_context+0x4e/0x1f0 > [12573.360211] [<ffffffff811403f4>] SYSC_perf_event_open+0x514/0xbd0 > [12573.367514] [<ffffffff81140e49>] SyS_perf_event_open+0x9/0x10 > [12573.374816] [<ffffffff816f4dd4>] tracesys+0xdd/0xe2 Notice the above trace. perf took its own ctx->lock, which can be taken while holding the rq lock. While holding this lock, it did a rcu_read_unlock(). The perf_lock_task_context() basically looks like: rcu_read_lock(); raw_spin_lock(ctx->lock); rcu_read_unlock(); Now, what looks to have happened, is that we scheduled after taking that first rcu_read_lock() but before taking the spin lock. When we scheduled back in and took the ctx->lock, the following rcu_read_unlock() triggered the "special" code. The rcu_read_unlock_special() takes the rnp->lock, which gives us a possible deadlock scenario. CPU0 CPU1 CPU2 ---- ---- ---- rcu_nocb_kthread() lock(rq->lock); lock(ctx->lock); lock(rnp->lock); wake_up(); lock(rq->lock); rcu_read_unlock(); rcu_read_unlock_special(); lock(rnp->lock); lock(ctx->lock); **** DEADLOCK **** > [12573.382068] > other info that might help us debug this: > > [12573.403229] Chain exists of: > rcu_node_0 --> &rq->lock --> &ctx->lock > > [12573.424471] Possible unsafe locking scenario: > > [12573.438499] CPU0 CPU1 > [12573.445599] ---- ---- > [12573.452691] lock(&ctx->lock); > [12573.459799] lock(&rq->lock); > [12573.467010] lock(&ctx->lock); > [12573.474192] lock(rcu_node_0); > [12573.481262] > *** DEADLOCK *** > > [12573.501931] 1 lock held by trinity-child17/31341: > [12573.508990] #0: (&ctx->lock){-.-...}, at: [<ffffffff811390ed>] perf_lock_task_context+0x7d/0x2d0 > [12573.516475] > stack backtrace: > [12573.530395] CPU: 1 PID: 31341 Comm: trinity-child17 Not tainted 3.10.0-rc3+ #39 > [12573.545357] ffffffff825b4f90 ffff880219f1dbc0 ffffffff816e375b ffff880219f1dc00 > [12573.552868] ffffffff816dfa5d ffff880219f1dc50 ffff88023ce4d1f8 ffff88023ce4ca40 > [12573.560353] 0000000000000001 0000000000000001 ffff88023ce4d1f8 ffff880219f1dcc0 > [12573.567856] Call Trace: > [12573.575011] [<ffffffff816e375b>] dump_stack+0x19/0x1b > [12573.582284] [<ffffffff816dfa5d>] print_circular_bug+0x200/0x20f > [12573.589637] [<ffffffff810b8d36>] __lock_acquire+0x1786/0x1af0 > [12573.596982] [<ffffffff810918f5>] ? sched_clock_cpu+0xb5/0x100 > [12573.604344] [<ffffffff810b9851>] lock_acquire+0x91/0x1f0 > [12573.611652] [<ffffffff811054ff>] ? rcu_read_unlock_special+0x9f/0x4c0 > [12573.619030] [<ffffffff816ebc90>] _raw_spin_lock+0x40/0x80 > [12573.626331] [<ffffffff811054ff>] ? rcu_read_unlock_special+0x9f/0x4c0 > [12573.633671] [<ffffffff811054ff>] rcu_read_unlock_special+0x9f/0x4c0 > [12573.640992] [<ffffffff811390ed>] ? perf_lock_task_context+0x7d/0x2d0 > [12573.648330] [<ffffffff810b429e>] ? put_lock_stats.isra.29+0xe/0x40 > [12573.655662] [<ffffffff813095a0>] ? delay_tsc+0x90/0xe0 > [12573.662964] [<ffffffff810760a6>] __rcu_read_unlock+0x96/0xa0 > [12573.670276] [<ffffffff811391b3>] perf_lock_task_context+0x143/0x2d0 > [12573.677622] [<ffffffff81139070>] ? __perf_event_enable+0x370/0x370 > [12573.684981] [<ffffffff8113938e>] find_get_context+0x4e/0x1f0 > [12573.692358] [<ffffffff811403f4>] SYSC_perf_event_open+0x514/0xbd0 > [12573.699753] [<ffffffff8108cd9d>] ? get_parent_ip+0xd/0x50 > [12573.707135] [<ffffffff810b71fd>] ? trace_hardirqs_on_caller+0xfd/0x1c0 > [12573.714599] [<ffffffff81140e49>] SyS_perf_event_open+0x9/0x10 > [12573.721996] [<ffffffff816f4dd4>] tracesys+0xdd/0xe2 This commit delays the wakeup via irq_work(), which is what perf and ftrace use to perform wakeups in critical sections. Reported-by: Dave Jones <davej@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2013-06-08Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: - Trivial: unused variable removal - Posix-timers: Add the clock ID to the new proc interface to make it useful. The interface is new and should be functional when we reach the final 3.10 release. - Cure a false positive warning in the tick code introduced by the overhaul in 3.10 - Fix for a persistent clock detection regression introduced in this cycle * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timekeeping: Correct run-time detection of persistent_clock. ntp: Remove unused variable flags in __hardpps posix-timers: Show clock ID in proc file tick: Cure broadcast false positive pending bit warning
2013-06-08Merge tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linuxLinus Torvalds
Pull irqdomain bug fixes from Grant Likely: "This branch contains a set of straight forward bug fixes to the irqdomain code and to a couple of drivers that make use of it." * tag 'irqdomain-for-linus' of git://git.secretlab.ca/git/linux: irqchip: Return -EPERM for reserved IRQs irqdomain: document the simple domain first_irq kernel/irq/irqdomain.c: before use 'irq_data', need check it whether valid. irqdomain: export irq_domain_add_simple
2013-06-08irqdomain: document the simple domain first_irqLinus Walleij
The first_irq needs to be zero to get a linear domain and that comes with special semantics. We want to simplify this going forward but some documentation never hurts. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08kernel/irq/irqdomain.c: before use 'irq_data', need check it whether valid.Chen Gang
Since irq_data may be NULL, if so, we WARN_ON(), and continue, 'hwirq' which related with 'irq_data' has to initialize later, or it will cause issue. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-08irqdomain: export irq_domain_add_simpleArnd Bergmann
All other irq_domain_add_* functions are exported already, and apparently this one got left out by mistake, which causes build errors for ARM allmodconfig kernels: ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-rcar.ko] undefined! ERROR: "irq_domain_add_simple" [drivers/gpio/gpio-em.ko] undefined! Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Simon Horman <horms+renesas@verge.net.au> Signed-off-by: Grant Likely <grant.likely@linaro.org>
2013-06-07Merge tag 'trace-fixes-v3.10-rc3-v3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fixes from Steven Rostedt: "This contains 4 fixes. The first two fix the case where full RCU debugging is enabled, enabling function tracing causes a live lock of the system. This is due to the added debug checks in rcu_dereference_raw() that is used by the function tracer. These checks are also traced by the function tracer as well as cause enough overhead to the function tracer to slow down the system enough that the time to finish an interrupt can take longer than when the next interrupt is triggered, causing a live lock from the timer interrupt. Talking this over with Paul McKenney, we came up with a fix that adds a new rcu_dereference_raw_notrace() that does not perform these added checks, and let the function tracer use that. The third commit fixes a failed compile when branch tracing is enabled, due to the conversion of the trace_test_buffer() selftest that the branch trace wasn't converted for. The forth patch fixes a bug caught by the RCU lockdep code where a rcu_read_lock() is performed when rcu is disabled (either going to or from idle, or user space). This happened on the irqsoff tracer as it calls task_uid(). The fix here was to use current_uid() when possible that doesn't use rcu locking. Which luckily, is always used when irqsoff calls this code." * tag 'trace-fixes-v3.10-rc3-v3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Use current_uid() for critical time tracing tracing: Fix bad parameter passed in branch selftest ftrace: Use the rcu _notrace variants for rcu_dereference_raw() and friends rcu: Add _notrace variation of rcu_dereference_raw() and hlist_for_each_entry_rcu()
2013-06-06tracing: Use current_uid() for critical time tracingSteven Rostedt (Red Hat)
The irqsoff tracer records the max time that interrupts are disabled. There are hooks in the assembly code that calls back into the tracer when interrupts are disabled or enabled. When they are enabled, the tracer checks if the amount of time they were disabled is larger than the previous recorded max interrupts off time. If it is, it creates a snapshot of the currently running trace to store where the last largest interrupts off time was held and how it happened. During testing, this RCU lockdep dump appeared: [ 1257.829021] =============================== [ 1257.829021] [ INFO: suspicious RCU usage. ] [ 1257.829021] 3.10.0-rc1-test+ #171 Tainted: G W [ 1257.829021] ------------------------------- [ 1257.829021] /home/rostedt/work/git/linux-trace.git/include/linux/rcupdate.h:780 rcu_read_lock() used illegally while idle! [ 1257.829021] [ 1257.829021] other info that might help us debug this: [ 1257.829021] [ 1257.829021] [ 1257.829021] RCU used illegally from idle CPU! [ 1257.829021] rcu_scheduler_active = 1, debug_locks = 0 [ 1257.829021] RCU used illegally from extended quiescent state! [ 1257.829021] 2 locks held by trace-cmd/4831: [ 1257.829021] #0: (max_trace_lock){......}, at: [<ffffffff810e2b77>] stop_critical_timing+0x1a3/0x209 [ 1257.829021] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff810dae5a>] __update_max_tr+0x88/0x1ee [ 1257.829021] [ 1257.829021] stack backtrace: [ 1257.829021] CPU: 3 PID: 4831 Comm: trace-cmd Tainted: G W 3.10.0-rc1-test+ #171 [ 1257.829021] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 [ 1257.829021] 0000000000000001 ffff880065f49da8 ffffffff8153dd2b ffff880065f49dd8 [ 1257.829021] ffffffff81092a00 ffff88006bd78680 ffff88007add7500 0000000000000003 [ 1257.829021] ffff88006bd78680 ffff880065f49e18 ffffffff810daebf ffffffff810dae5a [ 1257.829021] Call Trace: [ 1257.829021] [<ffffffff8153dd2b>] dump_stack+0x19/0x1b [ 1257.829021] [<ffffffff81092a00>] lockdep_rcu_suspicious+0x109/0x112 [ 1257.829021] [<ffffffff810daebf>] __update_max_tr+0xed/0x1ee [ 1257.829021] [<ffffffff810dae5a>] ? __update_max_tr+0x88/0x1ee [ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107 [ 1257.829021] [<ffffffff810dbf85>] update_max_tr_single+0x11d/0x12d [ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107 [ 1257.829021] [<ffffffff810e2b15>] stop_critical_timing+0x141/0x209 [ 1257.829021] [<ffffffff8109569a>] ? trace_hardirqs_on+0xd/0xf [ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107 [ 1257.829021] [<ffffffff810e3057>] time_hardirqs_on+0x2a/0x2f [ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107 [ 1257.829021] [<ffffffff8109550c>] trace_hardirqs_on_caller+0x16/0x197 [ 1257.829021] [<ffffffff8109569a>] trace_hardirqs_on+0xd/0xf [ 1257.829021] [<ffffffff811002b9>] user_enter+0xfd/0x107 [ 1257.829021] [<ffffffff810029b4>] do_notify_resume+0x92/0x97 [ 1257.829021] [<ffffffff8154bdca>] int_signal+0x12/0x17 What happened was entering into the user code, the interrupts were enabled and a max interrupts off was recorded. The trace buffer was saved along with various information about the task: comm, pid, uid, priority, etc. The uid is recorded with task_uid(tsk). But this is a macro that uses rcu_read_lock() to retrieve the data, and this happened to happen where RCU is blind (user_enter). As only the preempt and irqs off tracers can have this happen, and they both only have the tsk == current, if tsk == current, use current_uid() instead of task_uid(), as current_uid() does not use RCU as only current can change its uid. This fixes the RCU suspicious splat. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-06-03Merge branch 'for-3.10-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup fixes from Tejun Heo: - Fix for yet another xattr bug which may lead to NULL deref. - A subtle bug in for_each_descendant_pre(). This bug requires quite specific conditions to trigger and isn't too likely to actually happen in the wild, but maybe that just makes it that much more nastier. - A warning message added for silly cgroup re-mount (not -o remount, but unmount followed by mount) behavior. * 'for-3.10-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: cgroup: warn about mismatching options of a new mount of an existing hierarchy cgroup: fix a subtle bug in descendant pre-order walk cgroup: initialize xattr before calling d_instantiate()
2013-05-31tick: Remove useless timekeeping duty attribution to broadcast sourceJiri Bohac
Since 7300711e ("clockevents: broadcast fixup possible waiters"), the timekeeping duty is assigned to the CPU that handles the tick broadcast clock device by the time it is set in one shot mode. This is an issue in full dynticks mode where the timekeeping duty must stay handled by the boot CPU for now. Otherwise it prevents secondary CPUs from offlining and this breaks suspend/shutdown/reboot/... As it appears there is no reason for this timekeeping duty to be moved to the broadcast CPU, besides nothing prevent it from being later re-assigned to another target, let's simply remove it. Signed-off-by: Jiri Bohac <jbohac@suse.cz> Reported-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-31nohz: Fix notifier return val that enforce timekeepingLi Zhong
In tick_nohz_cpu_down_callback() if the cpu is the one handling timekeeping, we must return something that stops the CPU_DOWN_PREPARE notifiers and then start notify CPU_DOWN_FAILED on the already called notifier call backs. However traditional errno values are not handled by the notifier unless these are encapsulated using errno_to_notifier(). Hence the current -EINVAL is misinterpreted and converted to junk after notifier_to_errno(), leaving the notifier subsystem to random behaviour such as eventually allowing the cpu to go down. Fix this by using the standard NOTIFY_BAD instead. Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-31kvm: Move guest entry/exit APIs to context_trackingFrederic Weisbecker
The kvm_host.h header file doesn't handle well inclusion when archs don't support KVM. This results in build crashes for such archs when they want to implement context tracking because this subsystem includes kvm_host.h in order to implement the guest_enter/exit APIs but it doesn't handle KVM off case. To fix this, move the guest_enter()/guest_exit() declarations and generic implementation to the context tracking headers. These generic APIs actually belong to this subsystem, besides other domains boundary tracking like user_enter() et al. KVM now properly becomes a user of this library, not the other buggy way around. Reported-by: Kevin Hilman <khilman@linaro.org> Reviewed-by: Kevin Hilman <khilman@linaro.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Kevin Hilman <khilman@linaro.org> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-31vtime: Use consistent clocks among nohz accountingFrederic Weisbecker
While computing the cputime delta of dynticks CPUs, we are mixing up clocks of differents natures: * local_clock() which takes care of unstable clock sources and fix these if needed. * sched_clock() which is the weaker version of local_clock(). It doesn't compute any fixup in case of unstable source. If the clock source is stable, those two clocks are the same and we can safely compute the difference against two random points. Otherwise it results in random deltas as sched_clock() can randomly drift away, back or forward, from local_clock(). As a consequence, some strange behaviour with unstable tsc has been observed such as non progressing constant zero cputime. (The 'top' command showing no load). Fix this by only using local_clock(), or its irq safe/remote equivalent, in vtime code. Reported-by: Mike Galbraith <efault@gmx.de> Suggested-by: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-05-31Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Peter Anvin: - Three EFI-related fixes - Two early memory initialization fixes - build fix for older binutils - fix for an eager FPU performance regression -- currently we don't allow the use of the FPU at interrupt time *at all* in eager mode, which is clearly wrong. * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Allow FPU to be used at interrupt time even with eagerfpu x86, crc32-pclmul: Fix build with older binutils x86-64, init: Fix a possible wraparound bug in switchover in head_64.S x86, range: fix missing merge during add range x86, efi: initial the local variable of DataSize to zero efivar: fix oops in efivar_update_sysfs_entries() caused by memory reuse efivarfs: Never return ENOENT from firmware again
2013-05-29tracing: Fix bad parameter passed in branch selftestSteven Rostedt (Red Hat)
The branch selftest calls trace_test_buffer(), but with the new code it expects the first parameter to be a pointer to a struct trace_buffer. All self tests were changed but the branch selftest was missed. This caused either a crash or failed test when the branch selftest was enabled. Link: http://lkml.kernel.org/r/20130529141333.GA24064@localhost Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-05-29Merge branch 'fortglx/3.10/time' of ↵Thomas Gleixner
git://git.linaro.org/people/jstultz/linux into timers/urgent
2013-05-28ftrace: Use the rcu _notrace variants for rcu_dereference_raw() and friendsSteven Rostedt
As rcu_dereference_raw() under RCU debug config options can add quite a bit of checks, and that tracing uses rcu_dereference_raw(), these checks happen with the function tracer. The function tracer also happens to trace these debug checks too. This added overhead can livelock the system. Have the function tracer use the new RCU _notrace equivalents that do not do the debug checks for RCU. Link: http://lkml.kernel.org/r/20130528184209.467603904@goodmis.org Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-05-29cgroup: warn about mismatching options of a new mount of an existing hierarchyJeff Liu
With the new __DEVEL__sane_behavior mount option was introduced, if the root cgroup is alive with no xattr function, to mount a new cgroup with xattr will be rejected in terms of design which just fine. However, if the root cgroup does not mounted with __DEVEL__sane_hehavior, to create a new cgroup with xattr option will succeed although after that the EA function does not works as expected but will get ENOTSUPP for setting up attributes under either cgroup. e.g. setfattr: /cgroup2/test: Operation not supported Instead of keeping silence in this case, it's better to drop a log entry in warning level. That would be helpful to understand the reason behind the scene from the user's perspective, and this is essentially an improvement does not break the backward compatibilities. With this fix, above mount attemption will keep up works as usual but the following line cound be found at the system log: [ ...] cgroup: new mount options do not match the existing superblock tj: minor formatting / message updates. Signed-off-by: Jie Liu <jeff.liu@oracle.com> Reported-by: Alexey Kodanev <alexey.kodanev@oracle.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: stable@vger.kernel.org
