path: root/kernel
2018-04-19perf: Fix race in swevent hashAmulya Y
There's a race on CPU unplug where we free the swevent hash array while it can still have events on. This will result in a use-after-free which is BAD. Simply do not free the hash array on unplug. This leaves the thing around and no use-after-free takes place. When the last swevent dies, we do a for_each_possible_cpu() iteration anyway to clean these up, at which time we'll free it, so no leakage will occur. Bug 1823317 But 1935735 Change-Id: I309528873f8576f96663afbe51ce2739934df16c Reported-by: Sasha Levin <sasha.levin@oracle.com> Tested-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Gagan Grover <ggrover@nvidia.com> Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com> Reviewed-on: http://git-master/r/1259934 (cherry picked from commit 5ea640855404df656d94bfa3990d8eba2b5f90f9) Reviewed-on: https://git-master.nvidia.com/r/1690284 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2018-04-19cgroup: Correct the address format specifierAmulya Y
The format specifier %p can leak kernel addresses while not valuing the kptr_restrict system settings.The fix is designed to use %pK instead of %p, which also evaluates whether kptr_restrict is set. Bug 1823317 Bug 1935735 Change-Id: I19dc309e7f5341663add987f5d0b47ee32e1be50 Signed-off-by: Gagan Grover <ggrover@nvidia.com> Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com> Reviewed-on: http://git-master/r/1260110 (cherry picked from commit d018ef6518a7527562bedae1eab86838cfcc0570) Reviewed-on: https://git-master.nvidia.com/r/1690299 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2018-04-19audit: fix a double fetch in audit_log_single_execve_arg()Paul Moore
There is a double fetch problem in audit_log_single_execve_arg() where we first check the execve(2) argumnets for any "bad" characters which would require hex encoding and then re-fetch the arguments for logging in the audit record[1]. Of course this leaves a window of opportunity for an unsavory application to munge with the data. This patch reworks things by only fetching the argument data once[2] into a buffer where it is scanned and logged into the audit records(s). In addition to fixing the double fetch, this patch improves on the original code in a few other ways: better handling of large arguments which require encoding, stricter record length checking, and some performance improvements (completely unverified, but we got rid of some strlen() calls, that's got to be a good thing). As part of the development of this patch, I've also created a basic regression test for the audit-testsuite, the test can be tracked on GitHub at the following link: * https://github.com/linux-audit/audit-testsuite/issues/25 [1] If you pay careful attention, there is actually a triple fetch problem due to a strnlen_user() call at the top of the function. [2] This is a tiny white lie, we do make a call to strnlen_user() prior to fetching the argument data. I don't like it, but due to the way the audit record is structured we really have no choice unless we copy the entire argument at once (which would require a rather wasteful allocation). The good news is that with this patch the kernel no longer relies on this strnlen_user() value for anything beyond recording it in the log, we also update it with a trustworthy value whenever possible. Bug 1823317 Bug 1935735 Change-Id: I500834e1e699cb43d207333fa91292673de54933 Reported-by: Pengfei Wang <wpengfeinudt@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Gagan Grover <ggrover@nvidia.com> Reviewed-on: http://git-master/r/1261377 (cherry picked from commit 1cc418b165a23b352e06aa5ab66a2d1e1a942a98) Reviewed-on: https://git-master.nvidia.com/r/1690297 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2015-06-08watchdog: use FIQ WDT for soft lockup stack dumpRenn Wu
Using Tegra WDT to trigger FIQ when system is in soft lockup. Bug 1581432 Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a Signed-off-by: Renn Wu <rewu@nvidia.com> Reviewed-on: http://git-master/r/265871 (cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846) Reviewed-on: http://git-master/r/680353 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2014-06-24cpu: enhance power efficiencySumit Singh
Here we are trying to reduce power usage through the use of macros cpu_relaxed_read and relaxed version of idle_cpu(). Bug 1440421 Change-Id: I0a8c5d358c154782b41570059d03d7e0de87e82c Signed-off-by: Sumit Singh <sumsingh@nvidia.com> Reviewed-on: http://git-master/r/426485 Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
2014-06-24sched: defining relaxed version of idle_cpuSumit Singh
Defining relaxed version of idle_cpu, which uses macro cpu_relaxed_read_long, that will be used to enhance power efficiency. bug 1440421 Change-Id: I6ba2185632ad0fba766a2548b0ddac743defb1b9 Signed-off-by: Sumit Singh <sumsingh@nvidia.com> Reviewed-on: http://git-master/r/426484 Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
2014-06-24smp: enhance power efficiencySumit Singh
Here we are trying to reduce power usage through the use of macros cpu_relaxed_read_short and cpu_relaxed_read. Bug 1440421 Change-Id: I114d122cf58b1cf7b93b4b5f5d712360a2f1e096 Signed-off-by: Sumit Singh <sumsingh@nvidia.com> Reviewed-on: http://git-master/r/425947 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
2014-06-20futex : Forbid uaddr == uaddr2 in futex_requeue(..., requeue_pi=1)Thomas Gleixner
Bug 200012742 futex-prevent-requeue-pi-on-same-futex.patch futex: Forbid uaddr == uaddr2 in futex_requeue(..., requeue_pi=1) If uaddr == uaddr2, then we have broken the rule of only requeueing from a non-pi futex to a pi futex with this call. If we attempt this, then dangling pointers may be left for rt_waiter resulting in an exploitable condition. This change brings futex_requeue() in line with futex_wait_requeue_pi() which performs the same check as per commit 6f7b0a2a5c0f ("futex: Forbid uaddr == uaddr2 in futex_wait_requeue_pi()") [ tglx: Compare the resulting keys as well, as uaddrs might be different depending on the mapping ] Fixes CVE-2014-3153. Reported-by: Pinkie Pie Signed-off-by: Will Drewry <wad@chromium.org> Signed-off-by: Kees Cook <keescook@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Change-Id: I98b5f95d3f5c9e4d35c3aeec22960fdb34731c18 Reviewed-on: http://git-master/r/424612 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-06-10Merge commit 'refs/changes/82/419382/1' of ssh://git-master:12001/linux-3.10 ↵Mandar padmawar
into promotion_build Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
2014-06-05introduce for_each_thread() to replace the buggy while_each_thread()Oleg Nesterov
while_each_thread() and next_thread() should die, almost every lockless usage is wrong. 1. Unless g == current, the lockless while_each_thread() is not safe. while_each_thread(g, t) can loop forever if g exits, next_thread() can't reach the unhashed thread in this case. Note that this can happen even if g is the group leader, it can exec. 2. Even if while_each_thread() itself was correct, people often use it wrongly. It was never safe to just take rcu_read_lock() and loop unless you verify that pid_alive(g) == T, even the first next_thread() can point to the already freed/reused memory. This patch adds signal_struct->thread_head and task->thread_node to create the normal rcu-safe list with the stable head. The new for_each_thread(g, t) helper is always safe under rcu_read_lock() as long as this task_struct can't go away. Note: of course it is ugly to have both task_struct->thread_node and the old task_struct->thread_group, we will kill it later, after we change the users of while_each_thread() to use for_each_thread(). Perhaps we can kill it even before we convert all users, we can reimplement next_thread(t) using the new thread_head/thread_node. But we can't do this right now because this will lead to subtle behavioural changes. For example, do/while_each_thread() always sees at least one task, while for_each_thread() can do nothing if the whole thread group has died. Or thread_group_empty(), currently its semantics is not clear unless thread_group_leader(p) and we need to audit the callers before we can change it. So this patch adds the new interface which has to coexist with the old one for some time, hopefully the next changes will be more or less straightforward and the old one will go away soon. Bug 200004307 Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reviewed-by: Sergey Dyasly <dserrg@gmail.com> Tested-by: Sergey Dyasly <dserrg@gmail.com> Reviewed-by: Sameer Nanda <snanda@chromium.org> Acked-by: David Rientjes <rientjes@google.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mandeep Singh Baines <msb@chromium.org> Cc: "Ma, Xindong" <xindong.ma@intel.com> Cc: Michal Hocko <mhocko@suse.cz> Cc: "Tu, Xiaobing" <xiaobing.tu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 0c740d0afc3bff0a097ad03a1c8df92757516f5c) Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com> Change-Id: Id689cb1383ceba2561b66188d88258619b68f5c6 Reviewed-on: http://git-master/r/419041 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-06-05Merge branch 'linux-3.10.40' into rel-21Ishan Mittal
Bug 200004122 Conflicts: drivers/cpufreq/cpufreq.c drivers/regulator/core.c sound/soc/codecs/max98090.c Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-29Merge commit 'refs/changes/16/411516/5' of ssh://git-master:12001/linux-3.10 ↵Mandar padmawar
2014-05-29Merge branch 'android-3.10' into rel-21Ishan Mittal
Bug 200004122 Bug 1511804 This merge takes AOSP commits from android-3.10 branch Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-27PM QoS: Fix pmqos notifiers in pm_qos_enabled_setSai Gurrappadi
Send out the notifiers if the enabled flag has been changed. This will ensure that the notifier fires in all cases. Bug 1516219 Change-Id: Ie97422f61a9ad56f0ce194a99ce69193d429eadc Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/413433 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2014-05-27time: tegra: post-lp0 sync system to rtc timeBitan Biswas
Ensure system time is read from rtc i.e. PMIC RTC in case of tegra after system resume. - Change is applicable to all PMIC RTC drivers. bug 1510843 Reviewed-on: http://git-master/r/413365/ Reviewed-on: http://git-master/r/414163/ Reviewed-on: http://git-master/r/414169/ Reviewed-on: http://git-master/r/414200/ Reviewed-on: http://git-master/r/414201/ Change-Id: I8194f9f4be581216d662e6a6e0d7e98a9495159c Signed-off-by: Bitan Biswas <bbiswas@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-on: http://git-master/r/414203 GVS: Gerrit_Virtual_Submit
2014-05-23mutex: save power with better cpu_relaxAlex Van Brunt
Use cpu_relaxed_read and cpu_read_relax to allow more architectures to be able to "relax" instead of busy spinning. Bug 1440421 Change-Id: I48e36d7b3c953fe43ebb23ea814de7738c91e394 Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com> Reviewed-on: http://git-master/r/412712 Reviewed-by: Sumit Singh <sumsingh@nvidia.com> GVS: Gerrit_Virtual_Submit
2014-05-22fixup! net: ipv6: Add IPv6 support to the ping socket.Dan Willemsen
During the integration of this change to 3.10, this error check was commented out. Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com> Change-Id: I7e2fa114b0efbe58134f7acc60ec4d18b1bbee0e Reviewed-on: http://git-master/r/409994 Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
2014-05-14syscalls: add trace events for system callsAlex Van Brunt
Add trace events for the entry point and exit point of all system calls. This makes it possible to account for the time spent in each system call. Change-Id: Iba88c0a38424ea8e986954e23f13f4417578379d Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com> Reviewed-on: http://git-master/r/407691 GVS: Gerrit_Virtual_Submit
2014-05-14sched: add event for context switch endAlex Van Brunt
Add a trace envent for the end of a context switch. The makes it possible to account for the time spent context switching using the event log. Change-Id: Idc7bcc47cf51d5e2200e2f9380ba0100e1e56884 Signed-off-by: Alex Van Brunt <avanbrunt@nvidia.com> Reviewed-on: http://git-master/r/407689 GVS: Gerrit_Virtual_Submit
2014-05-06hung_task: check the value of "sysctl_hung_task_timeout_sec"Liu Hua
commit 80df28476505ed4e6701c3448c63c9229a50c655 upstream. As sysctl_hung_task_timeout_sec is unsigned long, when this value is larger then LONG_MAX/HZ, the function schedule_timeout_interruptible in watchdog will return immediately without sleep and with print : schedule_timeout: wrong timeout value ffffffffffffff83 and then the funtion watchdog will call schedule_timeout_interruptible again and again. The screen will be filled with "schedule_timeout: wrong timeout value ffffffffffffff83" This patch does some check and correction in sysctl, to let the function schedule_timeout_interruptible allways get the valid parameter. Signed-off-by: Liu Hua <sdu.liu@huawei.com> Tested-by: Satoru Takeuchi <satoru.takeuchi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-05Merge branch 'ARM64 Upstream' into rel-21Ishan Mittal
* ARM64 Upstream changes: (113 commits) Bug 1494135 Change-Id: I2e7c054d5bd6f702115f0697693298480d83e0b4 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-04-30kernel: remove CONFIG_USE_GENERIC_SMP_HELPERSChristoph Hellwig
We've switched over every architecture that supports SMP to it, so remove the new useless config variable. Conflicts: arch/arm/Kconfig block/blk-mq.c Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a) Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-04-30constify copy_siginfo_to_user{,32}()Al Viro
Conflicts: arch/x86/ia32/ia32_signal.c Change-Id: I701cb58fffb756a2d29e7c828728d149c35e6c6a Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> (cherry picked from commit ce3959604878c1c693979ec552069dc8bdb5ccde) Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-04-29ARM: tegra: add armv8 cpu registers to nvdumperYifei Wan
Bug 1498965 Change-Id: I353b383acd5ae32338ef38468787644fc9eafe48 Signed-off-by: Yifei Wan <ywan@nvidia.com> Reviewed-on: http://git-master/r/400929 Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com> Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
2014-04-26exit: call disassociate_ctty() before exit_task_namespaces()Oleg Nesterov
commit c39df5fa37b0623589508c95515b4aa1531c524e upstream. Commit 8aac62706ada ("move exit_task_namespaces() outside of exit_notify()") breaks pppd and the exiting service crashes the kernel: BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 IP: ppp_register_channel+0x13/0x20 [ppp_generic] Call Trace: ppp_asynctty_open+0x12b/0x170 [ppp_async] tty_ldisc_open.isra.2+0x27/0x60 tty_ldisc_hangup+0x1e3/0x220 __tty_hangup+0x2c4/0x440 disassociate_ctty+0x61/0x270 do_exit+0x7f2/0xa50 ppp_register_channel() needs ->net_ns and current->nsproxy == NULL. Move disassociate_ctty() before exit_task_namespaces(), it doesn't make sense to delay it after perf_event_exit_task() or cgroup_exit(). This also allows to use task_work_add() inside the (nontrivial) code paths in disassociate_ctty(). Investigated by Peter Hurley. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Sree Harsha Totakura <sreeharsha@totakura.in> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Sree Harsha Totakura <sreeharsha@totakura.in> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Andrey Vagin <avagin@openvz.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26wait: fix reparent_leader() vs EXIT_DEAD->EXIT_ZOMBIE raceOleg Nesterov
commit dfccbb5e49a621c1b21a62527d61fc4305617aca upstream. wait_task_zombie() first does EXIT_ZOMBIE->EXIT_DEAD transition and drops tasklist_lock. If this task is not the natural child and it is traced, we change its state back to EXIT_ZOMBIE for ->real_parent. The last transition is racy, this is even documented in 50b8d257486a "ptrace: partially fix the do_wait(WEXITED) vs EXIT_DEAD->EXIT_ZOMBIE race". wait_consider_task() tries to detect this transition and clear ->notask_error but we can't rely on ptrace_reparented(), debugger can exit and do ptrace_unlink() before its sub-thread sets EXIT_ZOMBIE. And there is another problem which were missed before: this transition can also race with reparent_leader() which doesn't reset >exit_signal if EXIT_DEAD, assuming that this task must be reaped by someone else. So the tracee can be re-parented with ->exit_signal != SIGCHLD, and if /sbin/init doesn't use __WALL it becomes unreapable. Change reparent_leader() to update ->exit_signal even if EXIT_DEAD. Note: this is the simple temporary hack for -stable, it doesn't try to solve all problems, it will be reverted by the next changes. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Reported-by: Jan Kratochvil <jan.kratochvil@redhat.com> Reported-by: Michal Schmidt <mschmidt@redhat.com> Tested-by: Michal Schmidt <mschmidt@redhat.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Lennart Poettering <lpoetter@redhat.com> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26pid_namespace: pidns_get() should check task_active_pid_ns() != NULLOleg Nesterov
commit d23082257d83e4bc89727d5aedee197e907999d2 upstream. pidns_get()->get_pid_ns() can hit ns == NULL. This task_struct can't go away, but task_active_pid_ns(task) is NULL if release_task(task) was already called. Alternatively we could change get_pid_ns(ns) to check ns != NULL, but it seems that other callers are fine. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eric W. Biederman ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-26user namespace: fix incorrect memory barriersMikulas Patocka
commit e79323bd87808fdfbc68ce6c5371bd224d9672ee upstream. smp_read_barrier_depends() can be used if there is data dependency between the readers - i.e. if the read operation after the barrier uses address that was obtained from the read operation before the barrier. In this file, there is only control dependency, no data dependecy, so the use of smp_read_barrier_depends() is incorrect. The code could fail in the following way: * the cpu predicts that idx < entries is true and starts executing the body of the for loop * the cpu fetches map->extent[0].first and map->extent[0].count * the cpu fetches map->nr_extents * the cpu verifies that idx < extents is true, so it commits the instructions in the body of the for loop The problem is that in this scenario, the cpu read map->extent[0].first and map->nr_extents in the wrong order. We need a full read memory barrier to prevent it. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-24Power: Changes the permission to read only for sysfs fileRuchi Kandoi
/sys/kernel/wakeup_reasons/last_resume_reason Change-Id: I8ac568a7cb58c31decd379195de517ff3c6f9c65 Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-04-22prctl: adds PR_SET_TIMERSLACK_PID for setting timer slack of an arbitrary ↵Ruchi Kandoi
thread. Second argument is similar to PR_SET_TIMERSLACK, if non-zero then the slack is set to that value otherwise sets it to the default for the thread. Takes PID of the thread as the third argument. This allows power/performance management software to set timer slack for other threads according to its policy for the thread (such as when the thread is designated foreground vs. background activity) Change-Id: I744d451ff4e60dae69f38f53948ff36c51c14a3f Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-04-14futex: Allow architectures to skip futex_atomic_cmpxchg_inatomic() testHeiko Carstens
commit 03b8c7b623c80af264c4c8d6111e5c6289933666 upstream. If an architecture has futex_atomic_cmpxchg_inatomic() implemented and there is no runtime check necessary, allow to skip the test within futex_init(). This allows to get rid of some code which would always give the same result, and also allows the compiler to optimize a couple of if statements away. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Link: http://lkml.kernel.org/r/20140302120947.GA3641@osiris Signed-off-by: Thomas Gleixner <tglx@linutronix.de> [geert: Backported to v3.10..v3.13] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-02tick: Don't clear idle and iowait sums on CPU downSai Gurrappadi
NOHZ related per-cpu data is cleared on CPU down. This was introduced by 4b0c0f294 "tick: Cleanup NOHZ per cpu data on cpu down" which breaks /proc/stats because the idle and iowait sums are now non-monotonic across a CPU down/up cycle. Fix this by not clearing the idle_sleeptime and iowait_sleeptime fields on CPU down. Bug 1484092 Change-Id: Ia57f5690672c0f35cf36098f92f242b94b545bb7 Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/386664 Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2014-03-31sched/autogroup: Fix race with task_groups listGerald Schaefer
commit 41261b6a832ea0e788627f6a8707854423f9ff49 upstream. In autogroup_create(), a tg is allocated and added to the task_groups list. If CONFIG_RT_GROUP_SCHED is set, this tg is then modified while on the list, without locking. This can race with someone walking the list, like __enable_runtime() during CPU unplug, and result in a use-after-free bug. To fix this, move sched_online_group(), which adds the tg to the list, to the end of the autogroup_create() function after the modification. Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1369411669-46971-2-git-send-email-gerald.schaefer@de.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-31tracing: Fix array size mismatch in format stringVaibhav Nagarnaik
commit 87291347c49dc40aa339f587b209618201c2e527 upstream. In event format strings, the array size is reported in two locations. One in array subscript and then via the "size:" attribute. The values reported there have a mismatch. For e.g., in sched:sched_switch the prev_comm and next_comm character arrays have subscript values as [32] where as the actual field size is 16. name: sched_switch ID: 301 format: field:unsigned short common_type; offset:0; size:2; signed:0; field:unsigned char common_flags; offset:2; size:1; signed:0; field:unsigned char common_preempt_count; offset:3; size:1;signed:0; field:int common_pid; offset:4; size:4; signed:1; field:char prev_comm[32]; offset:8; size:16; signed:1; field:pid_t prev_pid; offset:24; size:4; signed:1; field:int prev_prio; offset:28; size:4; signed:1; field:long prev_state; offset:32; size:8; signed:1; field:char next_comm[32]; offset:40; size:16; signed:1; field:pid_t next_pid; offset:56; size:4; signed:1; field:int next_prio; offset:60; size:4; signed:1; After bisection, the following commit was blamed: 92edca0 tracing: Use direct field, type and system names This commit removes the duplication of strings for field->name and field->type assuming that all the strings passed in __trace_define_field() are immutable. This is not true for arrays, where the type string is created in event_storage variable and field->type for all array fields points to event_storage. Use __stringify() to create a string constant for the type string. Also, get rid of event_storage and event_storage_mutex that are not needed anymore. also, an added benefit is that this reduces the overhead of events a bit more: text data bss dec hex filename 8424787 2036472 1302528 11763787 b3804b vmlinux 8420814 2036408 1302528 11759750 b37086 vmlinux.patched Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com Cc: Laurent Chavey <chavey@google.com> Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-24sched: Trying to reduce power usageSumit Singh
Using macros cpu_relaxed_read, cpu_relaxed_read_long and cpu_read_relax in core.c to improve power efficiency. Bug 1440421 Change-Id: Ic49b88fa6fb0cb847fed49886b2865bed72203db Signed-off-by: Sumit Singh <sumsingh@nvidia.com> Reviewed-on: http://git-master/r/368841 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2014-03-23tick: Make oneshot broadcast robust vs. CPU offliningThomas Gleixner
commit c9b5a266b103af873abb9ac03bc3d067702c8f4b upstream. In periodic mode we remove offline cpus from the broadcast propagation mask. In oneshot mode we fail to do so. This was not a problem so far, but the recent changes to the broadcast propagation introduced a constellation which can result in a NULL pointer dereference. What happens is: CPU0 CPU1 idle() arch_idle() tick_broadcast_oneshot_control(OFF); set cpu1 in tick_broadcast_force_mask if (cpu_offline()) arch_cpu_dead() cpu_dead_cleanup(cpu1) cpu1 tickdevice pointer = NULL broadcast interrupt dereference cpu1 tickdevice pointer -> OOPS We dereference the pointer because cpu1 is still set in tick_broadcast_force_mask and tick_do_broadcast() expects a valid cpumask and therefor lacks any further checks. Remove the cpu from the tick_broadcast_force_mask before we set the tick device pointer to NULL. Also add a sanity check to the oneshot broadcast function, so we can detect such issues w/o crashing the machine. Reported-by: Prarit Bhargava <prarit@redhat.com> Cc: athorlton@sgi.com Cc: CAI Qian <caiqian@redhat.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1306261303260.4013@ionos.tec.linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23tracing: Do not add event files for modules that fail tracepointsSteven Rostedt (Red Hat)
commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream. If a module fails to add its tracepoints due to module tainting, do not create the module event infrastructure in the debugfs directory. As the events will not work and worse yet, they will silently fail, making the user wonder why the events they enable do not display anything. Having a warning on module load and the events not visible to the users will make the cause of the problem much clearer. Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT" Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23cpuset: fix a race condition in __cpuset_node_allowed_softwall()Li Zefan
commit 99afb0fd5f05aac467ffa85c36778fec4396209b upstream. It's not safe to access task's cpuset after releasing task_lock(). Holding callback_mutex won't help. Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23genirq: Remove racy waitqueue_active checkChuansheng Liu
commit c685689fd24d310343ac33942e9a54a974ae9c43 upstream. We hit one rare case below: T1 calling disable_irq(), but hanging at synchronize_irq() always; The corresponding irq thread is in sleeping state; And all CPUs are in idle state; After analysis, we found there is one possible scenerio which causes T1 is waiting there forever: CPU0 CPU1 synchronize_irq() wait_event() spin_lock() atomic_dec_and_test(&threads_active) insert the __wait into queue spin_unlock() if(waitqueue_active) atomic_read(&threads_active) wake_up() Here after inserted the __wait into queue on CPU0, and before test if queue is empty on CPU1, there is no barrier, it maybe cause it is not visible for CPU1 immediately, although CPU0 has updated the queue list. It is similar for CPU0 atomic_read() threads_active also. So we'd need one smp_mb() before waitqueue_active.that, but removing the waitqueue_active() check solves it as wel l and it makes things simple and clear. Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> Cc: Xiaoming Wang <xiaoming.wang@intel.com> Link: http://lkml.kernel.org/r/1393212590-32543-1-git-send-email-chuansheng.liu@intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23sched: Fix double normalization of vruntimeGeorge McCollister
commit 791c9e0292671a3bfa95286bb5c08129d8605618 upstream. dequeue_entity() is called when p->on_rq and sets se->on_rq = 0 which appears to guarentee that the !se->on_rq condition is met. If the task has done set_current_state(TASK_INTERRUPTIBLE) without schedule() the second condition will be met and vruntime will be incorrectly adjusted twice. In certain cases this can result in the task's vruntime never increasing past the vruntime of other tasks on the CFS' run queue, starving them of CPU time. This patch changes switched_from_fair() to use !p->on_rq instead of !se->on_rq. I'm able to cause a task with a priority of 120 to starve all other tasks with the same priority on an ARM platform running 3.2.51-rt72 PREEMPT RT by writing one character at time to a serial tty (16550 UART) in a tight loop. I'm also able to verify making this change corrects the problem on that platform and kernel version. Signed-off-by: George McCollister <george.mccollister@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1392767811-28916-1-git-send-email-george.mccollister@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-18Revert "Revert parts of "hlist: drop the node parameter from iterators""Seema Khowala
This reverts commit dc893e19b5800d7743fb58235877bfa9091805ff. Bug 1481993 Change-Id: I147913ac71e89cba13a5a99a751e142c1d3a61da Signed-off-by: Seema Khowala <seemaj@nvidia.com> Reviewed-on: http://git-master/r/382701 Reviewed-by: Alexander Van Brunt <avanbrunt@nvidia.com>
2014-03-13Merge branch 'linux-3.10.33' into dev-kernel-3.10Deepak Nibade
Bug 1456092 Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53 Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
2014-03-10power: wakeup_reason: rename irq_count to irqcountGreg Hackmann
On x86, irq_count conflicts with a declaration in arch/x86/include/asm/processor.h Change-Id: I3e4fde0ff64ef59ff5ed2adc0ea3a644641ee0b7 Signed-off-by: Greg Hackmann <ghackmann@google.com>
2014-03-10Power: Add guard condition for maximum wakeup reasonsRuchi Kandoi
Ensure the array for the wakeup reason IRQs does not overflow. Change-Id: Iddc57a3aeb1888f39d4e7b004164611803a4d37c Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com> (cherry picked from commit b5ea40cdfcf38296535f931a7e5e7bf47b6fad7f)
2014-03-06perf: Fix hotplug splatPeter Zijlstra
commit e3703f8cdfcf39c25c4338c3ad8e68891cca3731 upstream. Drew Richardson reported that he could make the kernel go *boom* when hotplugging while having perf events active. It turned out that when you have a group event, the code in __perf_event_exit_context() fails to remove the group siblings from the context. We then proceed with destroying and freeing the event, and when you re-plug the CPU and try and add another event to that CPU, things go *boom* because you've still got dead entries there. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/n/tip-k6v5wundvusvcseqj1si0oz0@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-06workqueue: ensure @task is valid across kthread_stop()Lai Jiangshan
commit 5bdfff96c69a4d5ab9c49e60abf9e070ecd2acbb upstream. When a kworker should die, the kworkre is notified through WORKER_DIE flag instead of kthread_should_stop(). This, IIRC, is primarily to keep the test synchronized inside worker_pool lock. WORKER_DIE is first set while holding pool->lock, the lock is dropped and kthread_stop() is called. Unfortunately, this means that there's a slight chance that the target kworker may see WORKER_DIE before kthread_stop() finishes and exits and frees the target task before or during kthread_stop(). Fix it by pinning the target task before setting WORKER_DIE and putting it after kthread_stop() is done. tj: Improved patch description and comment. Moved pinning above WORKER_DIE for better signify what it's protecting. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-03sched: Force sleep on consecutive sched_yieldsSai Gurrappadi
If a task sched_yields to itself continuously, force the task to sleep in sched_yield. This will lower the CPU load of this task thereby lowering the cpu frequency and improving power. Added a stat variable to track how many times we sleep due these consecutive sched_yields. Also added sysctl knobs to control the number of consecutive sched_yields before which the sleep kicks in and the duration fo the sleep in us. Bug 1424617 Change-Id: Ie92412b8b900365816e17237fcbd0aac6e9c94ce Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/358455 Reviewed-by: Wen Yi <wyi@nvidia.com> Reviewed-by: Peter Zu <pzu@nvidia.com> GVS: Gerrit_Virtual_Submit Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2014-02-22genirq: Add missing irq_to_desc export for CONFIG_SPARSE_IRQ=nPaul Gortmaker
commit 2c45aada341121438affc4cb8d5b4cfaa2813d3d upstream. In allmodconfig builds for sparc and any other arch which does not set CONFIG_SPARSE_IRQ, the following will be seen at modpost: CC [M] lib/cpu-notifier-error-inject.o CC [M] lib/pm-notifier-error-inject.o ERROR: "irq_to_desc" [drivers/gpio/gpio-mcp23s08.ko] undefined! make[2]: *** [__modpost] Error 1 This happens because commit 3911ff30f5 ("genirq: export handle_edge_irq() and irq_to_desc()") added one export for it, but there were actually two instances of it, in an if/else clause for CONFIG_SPARSE_IRQ. Add the second one. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Jiri Kosina <jkosina@suse.cz> Link: http://lkml.kernel.org/r/1392057610-11514-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22ring-buffer: Fix first commit on sub-buffer having non-zero deltaSteven Rostedt (Red Hat)
commit d651aa1d68a2f0a7ee65697b04c6a92f8c0a12f2 upstream. Each sub-buffer (buffer page) has a full 64 bit timestamp. The events on that page use a 27 bit delta against that timestamp in order to save on bits written to the ring buffer. If the time between events is larger than what the 27 bits can hold, a "time extend" event is added to hold the entire 64 bit timestamp again and the events after that hold a delta from that timestamp. As a "time extend" is always paired with an event, it is logical to just allocate the event with the time extend, to make things a bit more efficient. Unfortunately, when the pairing code was written, it removed the "delta = 0" from the first commit on a page, causing the events on the page to be slightly skewed. Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together" Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-22time: Fix overflow when HZ is smaller than 60Mikulas Patocka
commit 80d767d770fd9c697e434fd080c2db7b5c60c6dd upstream. When compiling for the IA-64 ski emulator, HZ is set to 32 because the emulation is slow and we don't want to waste too many cycles processing timers. Alpha also has an option to set HZ to 32. This causes integer underflow in kernel/time/jiffies.c: kernel/time/jiffies.c:66:2: warning: large integer implicitly truncated to unsigned type [-Woverflow] .mult = NSEC_PER_JIFFY << JIFFIES_SHIFT, /* details above */ ^ This patch reduces the JIFFIES_SHIFT value to avoid the overflow. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1401241639100.23871@file01.intranet.prod.int.rdu2.redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
