commit ed65df63a39a3f6ed04f7258de8b6789e5021c18 upstream.
While writing an email explaining the "bit = 0" logic for a discussion on
making ftrace_test_recursion_trylock() disable preemption, I discovered a
path that makes the "not do the logic if bit is zero" unsafe.
The recursion logic is done in hot paths like the function tracer. Thus,
any code executed causes noticeable overhead. Thus, tricks are done to try
to limit the amount of code executed. This included the recursion testing
logic.
Having recursion testing is important, as there are many paths that can
end up in an infinite recursion cycle when tracing every function in the
kernel. Thus protection is needed to prevent that from happening.
Because it is OK to recurse due to different running context levels (e.g.
an interrupt preempts a trace, and then a trace occurs in the interrupt
handler), a set of bits are used to know which context one is in (normal,
softirq, irq and NMI). If a recursion occurs in the same level, it is
prevented*.
Then there are infrastructure levels of recursion as well. When more than
one callback is attached to the same function to trace, it calls a loop
function to iterate over all the callbacks. Both the callbacks and the
loop function have recursion protection. The callbacks use the
"ftrace_test_recursion_trylock()" which has a "function" set of context
bits to test, and the loop function calls the internal
trace_test_and_set_recursion() directly, with an "internal" set of bits.
If an architecture does not implement all the features supported by ftrace
then the callbacks are never called directly, and the loop function is
called instead, which will implement the features of ftrace.
Since both the loop function and the callbacks do recursion protection, it
was seemed unnecessary to do it in both locations. Thus, a trick was made
to have the internal set of recursion bits at a more significant bit
location than the function bits. Then, if any of the higher bits were set,
the logic of the function bits could be skipped, as any new recursion
would first have to go through the loop function.
This is true for architectures that do not support all the ftrace
features, because all functions being traced must first go through the
loop function before going to the callbacks. But this is not true for
architectures that support all the ftrace features. That's because the
loop function could be called due to two callbacks attached to the same
function, but then a recursion function inside the callback could be
called that does not share any other callback, and it will be called
directly.
i.e.
traced_function_1: [ more than one callback tracing it ]
call loop_func
loop_func:
trace_recursion set internal bit
call callback
callback:
trace_recursion [ skipped because internal bit is set, return 0 ]
call traced_function_2
traced_function_2: [ only traced by above callback ]
call callback
callback:
[ wash, rinse, repeat, BOOM! out of shampoo! ]
Thus, the "bit == 0 skip" trick is not safe, unless the loop function is
call for all functions.
Since we want to encourage architectures to implement all ftrace features,
having them slow down due to this extra logic may encourage the
maintainers to update to the latest ftrace features. And because this
logic is only safe for them, remove it completely.
[*] There is on layer of recursion that is allowed, and that is to allow
for the transition between interrupt context (normal -> softirq ->
irq -> NMI), because a trace may occur before the context update is
visible to the trace recursion logic.
Link: https://lore.kernel.org/all/609b565a-ed6e-a1da-f025-166691b5d994@linux.alibaba.com/
Link: https://lkml.kernel.org/r/20211018154412.09fcad3c@gandalf.local.home
Cc: Petr Mladek <pmladek@suse.com>
Cc: "James E.J. Bottomley" <James.Bottomley@hansenpartnership.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Paul Walmsley <paul.walmsley@sifive.com>
Cc: Palmer Dabbelt <palmer@dabbelt.com>
Cc: Albert Ou <aou@eecs.berkeley.edu>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Kosina <jikos@kernel.org>
Cc: Miroslav Benes <mbenes@suse.cz>
Cc: Joe Lawrence <joe.lawrence@redhat.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Nicholas Piggin <npiggin@gmail.com>
Cc: Jisheng Zhang <jszhang@kernel.org>
Cc: =?utf-8?b?546L6LSH?= <yun.wang@linux.alibaba.com>
Cc: Guo Ren <guoren@kernel.org>
Cc: stable@vger.kernel.org
Fixes: edc15cafcbfa3 ("tracing: Avoid unnecessary multiple recursion checks")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 6c14133d2d3f768e0a35128faac8aa6ed4815051 upstream.
It was reported that a bug on arm64 caused a bad ip address to be used for
updating into a nop in ftrace_init(), but the error path (rightfully)
returned -EINVAL and not -EFAULT, as the bug caused more than one error to
occur. But because -EINVAL was returned, the ftrace_bug() tried to report
what was at the location of the ip address, and read it directly. This
caused the machine to panic, as the ip was not pointing to a valid memory
address.
Instead, read the ip address with copy_from_kernel_nofault() to safely
access the memory, and if it faults, report that the address faulted,
otherwise report what was in that location.
Link: https://lore.kernel.org/lkml/20210607032329.28671-1-mark-pk.tsai@mediatek.com/
Fixes: 05736a427f7e1 ("ftrace: warn on failure to disable mcount callers")
Reported-by: Mark-PK Tsai <mark-pk.tsai@mediatek.com>
Tested-by: Mark-PK Tsai <mark-pk.tsai@mediatek.com>
commit 8c9af478c06bb1ab1422f90d8ecbc53defd44bc3 upstream.
# echo switch_mm:traceoff > /sys/kernel/tracing/set_ftrace_filter
will cause switch_mm to stop tracing by the traceoff command.
# echo -n switch_mm:traceoff > /sys/kernel/tracing/set_ftrace_filter
does nothing.
The reason is that the parsing in the write function only processes
commands if it finished parsing (there is white space written after the
command). That's to handle:
write(fd, "switch_mm:", 10);
write(fd, "traceoff", 8);
cases, where the command is broken over multiple writes.
The problem is if the file descriptor is closed, then the write call is
not processed, and the command needs to be processed in the release code.
The release code can handle matching of functions, but does not handle
commands.
Fixes: eda1e32855656 ("tracing: handle broken names in ftrace filter")
commit 7e0a9220467dbcfdc5bc62825724f3e52e50ab31 upstream.
On some archs, the idle task can call into cpu_suspend(). The cpu_suspend()
will disable or pause function graph tracing, as there's some paths in
bringing down the CPU that can have issues with its return address being
modified. The task_struct structure has a "tracing_graph_pause" atomic
counter, that when set to something other than zero, the function graph
tracer will not modify the return address.
The problem is that the tracing_graph_pause counter is initialized when the
function graph tracer is enabled. This can corrupt the counter for the idle
task if it is suspended in these architectures.
CPU 1 CPU 2
do_idle()
cpu_suspend()
pause_graph_tracing()
task_struct->tracing_graph_pause++ (0 -> 1)
start_graph_tracing()
for_each_online_cpu(cpu) {
ftrace_graph_init_idle_task(cpu)
task-struct->tracing_graph_pause = 0 (1 -> 0)
unpause_graph_tracing()
task_struct->tracing_graph_pause-- (0 -> -1)
The above should have gone from 1 to zero, and enabled function graph
tracing again. But instead, it is set to -1, which keeps it disabled.
There's no reason that the field tracing_graph_pause on the task_struct can
not be initialized at boot up.
Fixes: 380c4b1411ccd ("tracing/function-graph-tracer: append the tracing_graph_flag")
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=211339
Reported-by: pierre.gondois@arm.com
[ Upstream commit 8a224ffb3f52b0027f6b7279854c71a31c48fc97 ]
When module loaded and enabled, we will use __ftrace_replace_code
for module if any ftrace_ops referenced it found. But we will get
wrong ftrace_addr for module rec in ftrace_get_addr_new, because
rec->flags has not been setup correctly. It can cause the callback
function of a ftrace_ops has FTRACE_OPS_FL_SAVE_REGS to be called
with pt_regs set to NULL.
So setup correct FTRACE_FL_REGS flags for rec when we call
referenced_filters to find ftrace_ops references it.
Link: https://lkml.kernel.org/r/20200728180554.65203-1-zhouchengming@bytedance.com
Fixes: 8c4f3c3fa9681 ("ftrace: Check module functions being traced on reload")
Signed-off-by: Chengming Zhou <zhouchengming@bytedance.com>
Signed-off-by: Muchun Song <songmuchun@bytedance.com>
commit e31f7939c1c27faa5d0e3f14519eaf7c89e8a69d upstream.
The ftrace_profile->counter is unsigned long and
do_div truncates it to 32 bits, which means it can test
non-zero and be truncated to zero for division.
Fix this issue by using div64_ul() instead.
Link: http://lkml.kernel.org/r/20200103030248.14516-1-wenyang@linux.alibaba.com
Fixes: e330b3bcd8319 ("tracing: Show sample std dev in function profiling")
Fixes: 34886c8bc590f ("tracing: add average time in function to function profiler")
Signed-off-by: Wen Yang <wenyang@linux.alibaba.com>
commit fabe38ab6b2bd9418350284c63825f13b8a6abba upstream.
Mark ftrace mcount handler functions nokprobe since
probing on these functions with kretprobe pushes
return address incorrectly on kretprobe shadow stack.
Reported-by: Francis Deslauriers <francis.deslauriers@efficios.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/155094062044.6137.6419622920568680640.stgit@devbox
commit 2840f84f74035e5a535959d5f17269c69fa6edc5 upstream.
The following commands will cause a memory leak:
# cd /sys/kernel/tracing
# mkdir instances/foo
# echo schedule > instance/foo/set_ftrace_filter
# rmdir instances/foo
The reason is that the hashes that hold the filters to set_ftrace_filter and
set_ftrace_notrace are not freed if they contain any data on the instance
and the instance is removed.
Found by kmemleak detector.
Fixes: 591dffdade9f ("ftrace: Allow for function tracing instance to filter functions")
commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
commit 2b0b8499ae75df91455bbeb7491d45affc384fb0 upstream.
The trampoline allocated by function tracer was overwriten by function_graph
tracer, and caused a memory leak. The save_global_trampoline should have
saved the previous trampoline in register_ftrace_graph() and restored it in
unregister_ftrace_graph(). But as it is implemented, save_global_trampoline was
only used in unregister_ftrace_graph as default value 0, and it overwrote the
previous trampoline's value. Causing the previous allocated trampoline to be
lost.
kmmeleak backtrace:
kmemleak_vmalloc+0x77/0xc0
__vmalloc_node_range+0x1b5/0x2c0
module_alloc+0x7c/0xd0
arch_ftrace_update_trampoline+0xb5/0x290
ftrace_startup+0x78/0x210
register_ftrace_function+0x8b/0xd0
function_trace_init+0x4f/0x80
tracing_set_tracer+0xe6/0x170
tracing_set_trace_write+0x90/0xd0
__vfs_write+0x37/0x170
vfs_write+0xb2/0x1b0
SyS_write+0x55/0xc0
do_syscall_64+0x67/0x180
return_from_SYSCALL_64+0x0/0x6a
Looking further into this, I found that this was left over from when the
function and function graph tracers shared the same ftrace_ops. But in
commit 5f151b2401 ("ftrace: Fix function_profiler and function tracer
together"), the two were separated, and the save_global_trampoline no
longer was necessary (and it may have been broken back then too).
-- Steven Rostedt
Link: http://lkml.kernel.org/r/20170912021454.5976-1-shuwang@redhat.com
Fixes: 5f151b2401 ("ftrace: Fix function_profiler and function tracer together")
Signed-off-by: Shu Wang <shuwang@redhat.com>
commit edb096e00724f02db5f6ec7900f3bbd465c6c76f upstream.
If function tracing is disabled by the user via the function-trace option or
the proc sysctl file, and a ftrace_ops that was allocated on the heap is
unregistered, then the shutdown code exits out without doing the proper
clean up. This was found via kmemleak and running the ftrace selftests, as
one of the tests unregisters with function tracing disabled.
# cat kmemleak
unreferenced object 0xffffffffa0020000 (size 4096):
comm "swapper/0", pid 1, jiffies 4294668889 (age 569.209s)
hex dump (first 32 bytes):
55 ff 74 24 10 55 48 89 e5 ff 74 24 18 55 48 89 U.t$.UH...t$.UH.
e5 48 81 ec a8 00 00 00 48 89 44 24 50 48 89 4c .H......H.D$PH.L
backtrace:
[<ffffffff81d64665>] kmemleak_vmalloc+0x85/0xf0
[<ffffffff81355631>] __vmalloc_node_range+0x281/0x3e0
[<ffffffff8109697f>] module_alloc+0x4f/0x90
[<ffffffff81091170>] arch_ftrace_update_trampoline+0x160/0x420
[<ffffffff81249947>] ftrace_startup+0xe7/0x300
[<ffffffff81249bd2>] register_ftrace_function+0x72/0x90
[<ffffffff81263786>] trace_selftest_ops+0x204/0x397
[<ffffffff82bb8971>] trace_selftest_startup_function+0x394/0x624
[<ffffffff81263a75>] run_tracer_selftest+0x15c/0x1d7
[<ffffffff82bb83f1>] init_trace_selftests+0x75/0x192
[<ffffffff81002230>] do_one_initcall+0x90/0x1e2
[<ffffffff82b7d620>] kernel_init_freeable+0x350/0x3fe
[<ffffffff81d61ec3>] kernel_init+0x13/0x122
[<ffffffff81d72c6a>] ret_from_fork+0x2a/0x40
[<ffffffffffffffff>] 0xffffffffffffffff
Fixes: 12cce594fa ("ftrace/x86: Allow !CONFIG_PREEMPT dynamic ops to use allocated trampolines")
commit 2e028c4fe12907f226b8221815f16c2486ad3aa7 upstream.
My static checker complains that if "func" is NULL then "clear_filter"
is uninitialized. This seems like it could be true, although it's
possible something subtle is happening that I haven't seen.
kernel/trace/ftrace.c:3844 match_records()
error: uninitialized symbol 'clear_filter'.
Link: http://lkml.kernel.org/r/20170712073556.h6tkpjcdzjaozozs@mwanda
Fixes: f0a3b154bd7 ("ftrace: Clarify code for mod command")
commit 82cc4fc2e70ec5baeff8f776f2773abc8b2cc0ae upstream.
When two function probes are added to set_ftrace_filter, and then one of
them is removed, the update to the function locations is not performed, and
the record keeping of the function states are corrupted, and causes an
ftrace_bug() to occur.
This is easily reproducable by adding two probes, removing one, and then
adding it back again.
# cd /sys/kernel/debug/tracing
# echo schedule:traceoff > set_ftrace_filter
# echo do_IRQ:traceoff > set_ftrace_filter
# echo \!do_IRQ:traceoff > /debug/tracing/set_ftrace_filter
Causes:
WARNING: CPU: 2 PID: 1098 at kernel/trace/ftrace.c:2369 ftrace_get_addr_curr+0x143/0x220
Modules linked in: [...]
CPU: 2 PID: 1098 Comm: bash Not tainted 4.10.0-test+ #405
Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012
Call Trace:
dump_stack+0x68/0x9f
__warn+0x111/0x130
? trace_irq_work_interrupt+0xa0/0xa0
warn_slowpath_null+0x1d/0x20
? __fentry__+0x10/0x10
ftrace_replace_code+0xe3/0x4f0
? ftrace_int3_handler+0x90/0x90
? printk+0x99/0xb5
? 0xffffffff81000000
ftrace_modify_all_code+0x97/0x110
arch_ftrace_update_code+0x10/0x20
ftrace_run_update_code+0x1c/0x60
ftrace_run_modify_code.isra.48.constprop.62+0x8e/0xd0
register_ftrace_function_probe+0x4b6/0x590
? ftrace_startup+0x310/0x310
? debug_lockdep_rcu_enabled.part.4+0x1a/0x30
? update_stack_state+0x88/0x110
? ftrace_regex_write.isra.43.part.44+0x1d3/0x320
? preempt_count_sub+0x18/0xd0
? mutex_lock_nested+0x104/0x800
? __unwind_start+0x1c0/0x1c0
? _mutex_lock_nest_lock+0x800/0x800
ftrace_trace_probe_callback.isra.3+0xc0/0x130
? func_set_flag+0xe0/0xe0
? __lock_acquire+0x642/0x1790
? __might_fault+0x1e/0x20
? trace_get_user+0x398/0x470
? strcmp+0x35/0x60
ftrace_trace_onoff_callback+0x48/0x70
ftrace_regex_write.isra.43.part.44+0x251/0x320
? match_records+0x420/0x420
ftrace_filter_write+0x2b/0x30
__vfs_write+0xd7/0x330
? do_loop_readv_writev+0x120/0x120
? locks_remove_posix+0x90/0x2f0
? do_lock_file_wait+0x160/0x160
? __lock_is_held+0x93/0x100
? rcu_read_lock_sched_held+0x5c/0xb0
? __sb_start_write+0x10a/0x230
? vfs_write+0x222/0x240
vfs_write+0xef/0x240
SyS_write+0xab/0x130
? SyS_read+0x130/0x130
? trace_hardirqs_on_caller+0x182/0x280
? trace_hardirqs_on_thunk+0x1a/0x1c
entry_SYSCALL_64_fastpath+0x18/0xad
RIP: 0033:0x7fe61c157c30
RSP: 002b:00007ffe87890258 EFLAGS: 00000246 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: ffffffff8114a410 RCX: 00007fe61c157c30
RDX: 0000000000000010 RSI: 000055814798f5e0 RDI: 0000000000000001
RBP: ffff8800c9027f98 R08: 00007fe61c422740 R09: 00007fe61ca53700
R10: 0000000000000073 R11: 0000000000000246 R12: 0000558147a36400
R13: 00007ffe8788f160 R14: 0000000000000024 R15: 00007ffe8788f15c
? trace_hardirqs_off_caller+0xc0/0x110
---[ end trace 99fa09b3d9869c2c ]---
Bad trampoline accounting at: ffffffff81cc3b00 (do_IRQ+0x0/0x150)
Fixes: 59df055f1991 ("ftrace: trace different functions with a different tracer")
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracking updates from Steven Rostedt:
"Most of the changes are clean ups and small fixes. Some of them have
stable tags to them. I searched through my INBOX just as the merge
window opened and found lots of patches to pull. I ran them through
all my tests and they were in linux-next for a few days.
Features added this release:
- Module globbing. You can now filter function tracing to several
modules. # echo '*:mod:*snd*' > set_ftrace_filter (Dmitry Safonov)
- Tracer specific options are now visible even when the tracer is not
active. It was rather annoying that you can only see and modify
tracer options after enabling the tracer. Now they are in the
options/ directory even when the tracer is not active. Although
they are still only visible when the tracer is active in the
trace_options file.
- Trace options are now per instance (although some of the tracer
specific options are global)
- New tracefs file: set_event_pid. If any pid is added to this file,
then all events in the instance will filter out events that are not
part of this pid. sched_switch and sched_wakeup events handle next
and the wakee pids"
* tag 'trace-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (68 commits)
tracefs: Fix refcount imbalance in start_creating()
tracing: Put back comma for empty fields in boot string parsing
tracing: Apply tracer specific options from kernel command line.
tracing: Add some documentation about set_event_pid
ring_buffer: Remove unneeded smp_wmb() before wakeup of reader benchmark
tracing: Allow dumping traces without tracking trace started cpus
ring_buffer: Fix more races when terminating the producer in the benchmark
ring_buffer: Do no not complete benchmark reader too early
tracing: Remove redundant TP_ARGS redefining
tracing: Rename max_stack_lock to stack_trace_max_lock
tracing: Allow arch-specific stack tracer
recordmcount: arm64: Replace the ignored mcount call into nop
recordmcount: Fix endianness handling bug for nop_mcount
tracepoints: Fix documentation of RCU lockdep checks
tracing: ftrace_event_is_function() can return boolean
tracing: is_legal_op() can return boolean
ring-buffer: rb_event_is_commit() can return boolean
ring-buffer: rb_per_cpu_empty() can return boolean
ring_buffer: ring_buffer_empty{cpu}() can return boolean
ring-buffer: rb_is_reader_page() can return boolean
Extend module command for function filter selection with globbing.
It uses the same globbing as function filter.
sh# echo '*alloc*:mod:*' > set_ftrace_filter
Will trace any function with the letters 'alloc' in the name in any
module but not in kernel.
sh# echo '!*alloc*:mod:ipv6' >> set_ftrace_filter
Will prevent from tracing functions with 'alloc' in the name from module
ipv6 (do not forget to append to set_ftrace_filter file).
sh# echo '*alloc*:mod:!ipv6' > set_ftrace_filter
Will trace functions with 'alloc' in the name from kernel and any
module except ipv6.
sh# echo '*alloc*:mod:!*' > set_ftrace_filter
Will trace any function with the letters 'alloc' in the name only from
kernel, but not from any module.
sh# echo '*:mod:!*' > set_ftrace_filter
or
sh# echo ':mod:!' > set_ftrace_filter
Will trace every function in the kernel, but will not trace functions
from any module.
sh# echo '*:mod:*' > set_ftrace_filter
or
sh# echo ':mod:' > set_ftrace_filter
As the opposite will trace all functions from all modules, but not from
kernel.
sh# echo '*:mod:*snd*' > set_ftrace_filter
Will trace your sound drivers only (if any).
Link: http://lkml.kernel.org/r/1443545176-3215-4-git-send-email-0x7f454c46@gmail.com
Signed-off-by: Dmitry Safonov <0x7f454c46@gmail.com>
[ Made format changes ]
ftrace_match parameters are very related and I reduce the number of local
variables & parameters with it.
This is also preparation for module globbing as it would introduce more
realated variables & parameters.
Link: http://lkml.kernel.org/r/1443545176-3215-3-git-send-email-0x7f454c46@gmail.com
[ Made some formatting changes ]
"Not" is too abstract variable name - changed to clear_filter.
Removed ftrace_match_module_records function: comparison with !* or *
not does the general code in filter_parse_regex() as it works without
mod command for
sh# echo '!*' > /sys/kernel/debug/tracing/set_ftrace_filter
Link: http://lkml.kernel.org/r/1443545176-3215-2-git-send-email-0x7f454c46@gmail.com
By now there isn't any subcommand for mod.
Before:
sh$ echo '*:mod:ipv6:a' > set_ftrace_filter
sh$ echo '*:mod:ipv6' > set_ftrace_filter
had the same results, but now first will result in:
-bash: echo: write error: Invalid argument
Also, I clarified ftrace_mod_callback code a little.
Link: http://lkml.kernel.org/r/1443545176-3215-1-git-send-email-0x7f454c46@gmail.com
[ converted 'if (ret == 0)' to 'if (!ret)' ]
__trace_sched_switch_state() is the last remaining PREEMPT_ACTIVE
user, move trace_sched_switch() from prepare_task_switch() to
__schedule() and propagate the @preempt argument.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
To cover the common case of sorting an array of pointers, Daniel
Wagner recently modified the library sort() to use a specific swap
function for size==8, in addition to the size==4 case which was
already handled. Since sizeof(long) is either 4 or 8,
ftrace_swap_ips() is redundant and we can just let sort() pick an
appropriate and fast swap callback.
Link: http://lkml.kernel.org/r/1441834023-13130-1-git-send-email-linux@rasmusvillemoes.dk
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
The sleep-time and graph-time options are only for the function graph tracer
and are not used by anything else. As tracer options are now visible when
the tracer is not activated, its better to move the function graph specific
tracer options into the function graph tracer.
Pull tracing update from Steven Rostedt:
"Mostly this is just clean ups and micro optimizations.
The changes with more meat are:
- Allowing the trace event filters to filter on CPU number and
process ids
- Two new markers for trace output latency were added (10 and 100
msec latencies)
- Have tracing_thresh filter function profiling time
I also worked on modifying the ring buffer code for some future work,
and moved the adding of the timestamp around. One of my changes
caused a regression, and since other changes were built on top of it
and already tested, I had to operate a revert of that change. Instead
of rebasing, this change set has the code that caused a regression as
well as the code to revert that change without touching the other
changes that were made on top of it"
* tag 'trace-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Revert "ring-buffer: Get timestamp after event is allocated"
tracing: Don't make assumptions about length of string on task rename
tracing: Allow triggers to filter for CPU ids and process names
ftrace: Format MCOUNT_ADDR address as type unsigned long
tracing: Introduce two additional marks for delay
ftrace: Fix function_graph duration spacing with 7-digits
ftrace: add tracing_thresh to function profile
tracing: Clean up stack tracing and fix fentry updates
ring-buffer: Reorganize function locations
ring-buffer: Make sure event has enough room for extend and padding
ring-buffer: Move the adding of the extended timestamp out of line
ring-buffer: Add event descriptor to simplify passing data
ftrace: correct the counter increment for trace_buffer data
tracing: Fix for non-continuous cpu ids
tracing: Prefer kcalloc over kzalloc with multiply
Commit 4104d326b670 ("ftrace: Remove global function list and call function
directly") simplified the ftrace code by removing the global_ops list with a
new design. But this cleanup also broke the filtering of PIDs that are added
to the set_ftrace_pid file.
Add back the proper hooks to have pid filtering working once again.
Cc: stable@vger.kernel.org # 3.16+
Reported-by: Matt Fleming <matt@console-pimps.org>
Reported-by: Richard Weinberger <richard.weinberger@gmail.com>
Tested-by: Matt Fleming <matt@console-pimps.org>
This patch extends tracing_thresh functionality to function profile tracer.
If tracing_thresh is set, print those entries only,
whose average is > tracing thresh.
Link: http://lkml.kernel.org/r/1434972488-8571-1-git-send-email-umesh.t@samsung.com
Signed-off-by: Umesh Tiwari <umesh.t@samsung.com>
[ Removed unnecessary 'moved' comment ]
Pull tracing updates from Steven Rostedt:
"Some clean ups and small fixes, but the biggest change is the addition
of the TRACE_DEFINE_ENUM() macro that can be used by tracepoints.
Tracepoints have helper functions for the TP_printk() called
__print_symbolic() and __print_flags() that lets a numeric number be
displayed as a a human comprehensible text. What is placed in the
TP_printk() is also shown in the tracepoint format file such that user
space tools like perf and trace-cmd can parse the binary data and
express the values too. Unfortunately, the way the TRACE_EVENT()
macro works, anything placed in the TP_printk() will be shown pretty
much exactly as is. The problem arises when enums are used. That's
because unlike macros, enums will not be changed into their values by
the C pre-processor. Thus, the enum string is exported to the format
file, and this makes it useless for user space tools.
The TRACE_DEFINE_ENUM() solves this by converting the enum strings in
the TP_printk() format into their number, and that is what is shown to
user space. For example, the tracepoint tlb_flush currently has this
in its format file:
__print_symbolic(REC->reason,
{ TLB_FLUSH_ON_TASK_SWITCH, "flush on task switch" },
{ TLB_REMOTE_SHOOTDOWN, "remote shootdown" },
{ TLB_LOCAL_SHOOTDOWN, "local shootdown" },
{ TLB_LOCAL_MM_SHOOTDOWN, "local mm shootdown" })
After adding:
TRACE_DEFINE_ENUM(TLB_FLUSH_ON_TASK_SWITCH);
TRACE_DEFINE_ENUM(TLB_REMOTE_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_SHOOTDOWN);
TRACE_DEFINE_ENUM(TLB_LOCAL_MM_SHOOTDOWN);
Its format file will contain this:
{ 0, "flush on task switch" },
{ 1, "remote shootdown" },
{ 2, "local shootdown" },
{ 3, "local mm shootdown" })"
* tag 'trace-v4.1' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (27 commits)
tracing: Add enum_map file to show enums that have been mapped
writeback: Export enums used by tracepoint to user space
v4l: Export enums used by tracepoints to user space
SUNRPC: Export enums in tracepoints to user space
mm: tracing: Export enums in tracepoints to user space
irq/tracing: Export enums in tracepoints to user space
f2fs: Export the enums in the tracepoints to userspace
net/9p/tracing: Export enums in tracepoints to userspace
x86/tlb/trace: Export enums in used by tlb_flush tracepoint
tracing/samples: Update the trace-event-sample.h with TRACE_DEFINE_ENUM()
tracing: Allow for modules to convert their enums to values
tracing: Add TRACE_DEFINE_ENUM() macro to map enums to their values
tracing: Update trace-event-sample with TRACE_SYSTEM_VAR documentation
tracing: Give system name a pointer
brcmsmac: Move each system tracepoints to their own header
iwlwifi: Move each system tracepoints to their own header
mac80211: Move message tracepoints to their own header
tracing: Add TRACE_SYSTEM_VAR to xhci-hcd
tracing: Add TRACE_SYSTEM_VAR to kvm-s390
tracing: Add TRACE_SYSTEM_VAR to intel-sst
Pull tracefs from Steven Rostedt:
"This adds the new tracefs file system.
This has been in linux-next for more than one release, as I had it
ready for the 4.0 merge window, but a last minute thing that needed to
go into Linux first had to be done. That was that perf hard coded the
file system number when reading /sys/kernel/debugfs/tracing directory
making sure that the path had the debugfs mount # before it would
parse the tracing file. This broke other use cases of perf, and the
check is removed.
Now when mounting /sys/kernel/debug, tracefs is automatically mounted
in /sys/kernel/debug/tracing such that old tools will still see that
path as expected. But now system admins can mount tracefs directly
and not need to mount debugfs, which can expose security issues. A
new directory is created when tracefs is configured such that system
admins can now mount it separately (/sys/kernel/tracing)"
* tag 'trace-4.1-tracefs' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Have mkdir and rmdir be part of tracefs
tracefs: Add directory /sys/kernel/tracing
tracing: Automatically mount tracefs on debugfs/tracing
tracing: Convert the tracing facility over to use tracefs
tracefs: Add new tracefs file system
tracing: Create cmdline tracer options on tracing fs init
tracing: Only create tracer options files if directory exists
debugfs: Provide a file creation function that also takes an initial size
Dynamically allocated trampolines call ftrace_ops_get_func to get the
function which they should call. For dynamic fops (FTRACE_OPS_FL_DYNAMIC
flag is set) ftrace_ops_list_func is always returned. This is reasonable
for static trampolines but goes against the main advantage of dynamic
ones, that is avoidance of going through the list of all registered
callbacks for functions that are only being traced by a single callback.
We can fix it by returning ops->func (or recursion safe version) from
ftrace_ops_get_func whenever it is possible for dynamic trampolines.
Note that dynamic trampolines are not allowed for dynamic fops if
CONFIG_PREEMPT=y.
Link: http://lkml.kernel.org/r/alpine.LNX.2.00.1501291023000.25445@pobox.suse.cz
Link: http://lkml.kernel.org/r/1424357773-13536-1-git-send-email-mbenes@suse.cz
Reported-by: Miroslav Benes <mbenes@suse.cz>
Some archs (specifically PowerPC), are sensitive with the ordering of
the enabling of the calls to function tracing and setting of the
function to use to be traced.
That is, update_ftrace_function() sets what function the ftrace_caller
trampoline should call. Some archs require this to be set before
calling ftrace_run_update_code().
Another bug was discovered, that ftrace_startup_sysctl() called
ftrace_run_update_code() directly. If the function the ftrace_caller
trampoline changes, then it will not be updated. Instead a call
to ftrace_startup_enable() should be called because it tests to see
if the callback changed since the code was disabled, and will
tell the arch to update appropriately. Most archs do not need this
notification, but PowerPC does.
The problem could be seen by the following commands:
# echo 0 > /proc/sys/kernel/ftrace_enabled
# echo function > /sys/kernel/debug/tracing/current_tracer
# echo 1 > /proc/sys/kernel/ftrace_enabled
# cat /sys/kernel/debug/tracing/trace
The trace will show that function tracing was not active.
Cc: stable@vger.kernel.org # 2.6.27+
When ftrace is enabled globally through the proc interface, we must check if
ftrace_graph_active is set. If it is set, then we should also pass the
FTRACE_START_FUNC_RET command to ftrace_run_update_code(). Similarly, when
ftrace is disabled globally through the proc interface, we must check if
FTRACE_STOP_FUNC_RET command to ftrace_run_update_code().
Consider the following situation.
After this ftrace_enabled = 0.
# echo function_graph > /sys/kernel/debug/tracing/current_tracer
Since ftrace_enabled = 0, ftrace_enable_ftrace_graph_caller() is never
called.
Now ftrace_enabled will be set to true, but still
ftrace_enable_ftrace_graph_caller() will not be called, which is not
desired.
Further if we execute the following after this:
# echo nop > /sys/kernel/debug/tracing/current_tracer
Now since ftrace_enabled is set it will call
ftrace_disable_ftrace_graph_caller(), which causes a kernel warning on
the ARM platform.
On the ARM platform, when ftrace_enable_ftrace_graph_caller() is called,
it checks whether the old instruction is a nop or not. If it's not a nop,
then it returns an error. If it is a nop then it replaces instruction at
that address with a branch to ftrace_graph_caller.
ftrace_disable_ftrace_graph_caller() behaves just the opposite. Therefore,
if generic ftrace code ever calls either ftrace_enable_ftrace_graph_caller()
or ftrace_disable_ftrace_graph_caller() consecutively two times in a row,
then it will return an error, which will cause the generic ftrace code to
raise a warning.
Note, x86 does not have an issue with this because the architecture
specific code for ftrace_enable_ftrace_graph_caller() and
ftrace_disable_ftrace_graph_caller() does not check the previous state,
and calling either of these functions twice in a row has no ill effect.
Link: http://lkml.kernel.org/r/e4fbe64cdac0dd0e86a3bf914b0f83c0b419f146.1425666454.git.panand@redhat.com
Cc: stable@vger.kernel.org # 2.6.31+
Signed-off-by: Pratyush Anand <panand@redhat.com>
removed extra if (ftrace_start_up) and defined ftrace_graph_active as 0
if CONFIG_FUNCTION_GRAPH_TRACER is not set.
When /proc/sys/kernel/ftrace_enabled is set to zero, all function
tracing is disabled. But the records that represent the functions
still hold information about the ftrace_ops that are hooked to them.
ftrace_ops may request "REGS" (have a full set of pt_regs passed to
the callback), or "TRAMP" (the ops has its own trampoline to use).
When the record is updated to represent the state of the ops hooked
to it, it sets "REGS_EN" and/or "TRAMP_EN" to state that the callback
points to the correct trampoline (REGS has its own trampoline).
When ftrace_enabled is set to zero, all ftrace locations are a nop,
so they do not point to any trampoline. But the _EN flags are still
set. This can cause the accounting to go wrong when ftrace_enabled
is cleared and an ops that has a trampoline is registered or unregistered.
For example, the following will cause ftrace to crash:
As function_graph uses a trampoline, when ftrace_enabled is set to zero
the updates to the record are not done. When enabling function_graph
again, the record will still have the TRAMP_EN flag set, and it will
look for an op that has a trampoline other than the function_graph
ops, and fail to find one.
Cc: stable@vger.kernel.org # 3.17+
Reported-by: Pratyush Anand <panand@redhat.com>
"The updates included in this pull request for ftrace are:
o Several clean ups to the code
One such clean up was to convert to 64 bit time keeping, in the
ring buffer benchmark code.
o Adding of __print_array() helper macro for TRACE_EVENT()
o Updating the sample/trace_events/ to add samples of different ways
to make trace events. Lots of features have been added since the
sample code was made, and these features are mostly unknown.
Developers have been making their own hacks to do things that are
already available.
o Performance improvements. Most notably, I found a performance bug
where a waiter that is waiting for a full page from the ring buffer
will see that a full page is not available, and go to sleep. The
sched event caused by it going to sleep would cause it to wake up
again. It would see that there was still not a full page, and go
back to sleep again, and that would wake it up again, until finally
it would see a full page. This change has been marked for stable.
Other improvements include removing global locks from fast paths"
* tag 'trace-v3.20' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
ring-buffer: Do not wake up a splice waiter when page is not full
tracing: Fix unmapping loop in tracing_mark_write
tracing: Add samples of DECLARE_EVENT_CLASS() and DEFINE_EVENT()
tracing: Add TRACE_EVENT_FN example
tracing: Add TRACE_EVENT_CONDITION sample
tracing: Update the TRACE_EVENT fields available in the sample code
tracing: Separate out initializing top level dir from instances
tracing: Make tracing_init_dentry_tr() static
trace: Use 64-bit timekeeping
tracing: Add array printing helper
tracing: Remove newline from trace_printk warning banner
tracing: Use IS_ERR() check for return value of tracing_init_dentry()
tracing: Remove unneeded includes of debugfs.h and fs.h
tracing: Remove taking of trace_types_lock in pipe files
tracing: Add ref count to tracer for when they are being read by pipe
debugfs was fine for the tracing facility as a quick way to get
an interface. Now that tracing has matured, it should separate itself
from debugfs such that it can be mounted separately without needing
to mount all of debugfs with it. That is, users resist using tracing
because it requires mounting debugfs. Having tracing have its own file
system lets users get the features of tracing without needing to bring
in the rest of the kernel's debug infrastructure.
Another reason for tracefs is that debubfs does not support mkdir.
Currently, to create instances, one does a mkdir in the tracing/instance
directory. This is implemented via a hack that forces debugfs to do
something it is not intended on doing. By converting over to tracefs, this
hack can be removed and mkdir can be properly implemented. This patch does
not address this yet, but it lays the ground work for that to be done.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs into trace/ftrace/tracefs
Pull in Al Viro's changes to debugfs that implement the new primitive:
debugfs_create_automount(), that creates a directory in debugfs that will
safely mount another file system automatically when debugfs is mounted.
This will let tracefs automount itself on top of debugfs/tracing directory.
tracing_init_dentry() will soon return NULL as a valid pointer for the
top level tracing directroy. NULL can not be used as an error value.
Instead, switch to ERR_PTR() and check the return status with
IS_ERR().
Using just the filter for checking for trampolines or regs is not enough
when updating the code against the records that represent all functions.
Both the filter hash and the notrace hash need to be checked.
To trigger this bug (using trace-cmd and perf):
# perf probe -a do_fork
# trace-cmd start -B foo -e probe
# trace-cmd record -p function_graph -n do_fork sleep 1
The trace-cmd record at the end clears the filter before it disables
function_graph tracing and then that causes the accounting of the
ftrace function records to become incorrect and causes ftrace to bug.
Link: http://lkml.kernel.org/r/20150114154329.358378039@goodmis.org
[ still need to switch old_hash_ops to old_ops_hash ]
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
As the set_ftrace_filter affects both the function tracer as well as the
function graph tracer, the ops that represent each have a shared
ftrace_ops_hash structure. This allows both to be updated when the filter
files are updated.
But if function graph is enabled and the global_ops (function tracing) ops
is not, then it is possible that the filter could be changed without the
update happening for the function graph ops. This will cause the changes
to not take place and may even cause a ftrace_bug to occur as it could mess
with the trampoline accounting.
The solution is to check if the ops uses the shared global_ops filter and
if the ops itself is not enabled, to check if there's another ops that is
enabled and also shares the global_ops filter. In that case, the
modification still needs to be executed.
Link: http://lkml.kernel.org/r/20150114154329.055980438@goodmis.org
Introduce FTRACE_OPS_FL_IPMODIFY to avoid conflict among
ftrace users who may modify regs->ip to change the execution
path. If two or more users modify the regs->ip on the same
function entry, one of them will be broken. So they must add
IPMODIFY flag and make sure that ftrace_set_filter_ip() succeeds.
Note that ftrace doesn't allow ftrace_ops which has IPMODIFY
flag to have notrace hash, and the ftrace_ops must have a
filter hash (so that the ftrace_ops can hook only specific
entries), because it strongly depends on the address and
must be allowed for only few selected functions.
Link: http://lkml.kernel.org/r/20141121102516.11844.27829.stgit@localhost.localdomain
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Seth Jennings <sjenning@redhat.com>
Cc: Petr Mladek <pmladek@suse.cz>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
[ fixed up some of the comments ]
Fix up a few typos in comments and convert an int into a bool in
update_traceon_count().
Link: http://lkml.kernel.org/r/546DD445.5080108@hitachi.com
Suggested-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Stack traces that happen from function tracing check if the address
on the stack is a __kernel_text_address(). That is, is the address
kernel code. This calls core_kernel_text() which returns true
if the address is part of the builtin kernel code. It also calls
is_module_text_address() which returns true if the address belongs
to module code.
But what is missing is ftrace dynamically allocated trampolines.
These trampolines are allocated for individual ftrace_ops that
call the ftrace_ops callback functions directly. But if they do a
stack trace, the code checking the stack wont detect them as they
are neither core kernel code nor module address space.
Adding another field to ftrace_ops that also stores the size of
the trampoline assigned to it we can create a new function called
is_ftrace_trampoline() that returns true if the address is a
dynamically allocate ftrace trampoline. Note, it ignores trampolines
that are not dynamically allocated as they will return true with
the core_kernel_text() function.
Link: http://lkml.kernel.org/r/20141119034829.497125839@goodmis.org
Using seq_printf to print a simple string or a single character is a
lot more expensive than it needs to be, since seq_puts and seq_putc
exist.
These patches do
seq_printf(m, s) -> seq_puts(m, s)
seq_printf(m, "%s", s) -> seq_puts(m, s)
seq_printf(m, "%c", c) -> seq_putc(m, c)
Subsequent patches will simplify further.
Link: http://lkml.kernel.org/r/1415479332-25944-2-git-send-email-linux@rasmusvillemoes.dk
With the new logic, if only a single user of ftrace function hooks is
used, it will get its own trampoline assigned to it.
The problem is that the control_ops is an indirect ops that perf ops
uses. What that means is that when perf registers its ops with
register_ftrace_function(), it has the CONTROL flag set and gets added
to the control list instead of the global ftrace list. The control_ops
gets added to that instead and the mcount trampoline calls the control_ops
function. The control_ops function will iterate the control list and
call the ops functions that are attached to it.
But currently the trampoline is added to the perf ops and not the
control ops, and when ftrace tries to find a trampoline hook for it,
it fails to find one and gives the following splat:
WARNING: CPU: 0 PID: 10133 at kernel/trace/ftrace.c:2033 ftrace_get_addr_new+0x6f/0xc0()
CPU: 0 PID: 10133 Comm: perf Tainted: P 3.18.0-rc1-test+ #388
00000000000007f1 ffff8800c2643bc8 ffffffff814fca6e ffff88011ea0ed01
0000000000000000 ffff8800c2643c08 ffffffff81041ffd 0000000000000000
ffffffff810c388c ffffffff81a5a350 ffff880119b00000 ffffffff810001c8
Call Trace:
[<ffffffff814fca6e>] dump_stack+0x46/0x58
[<ffffffff81041ffd>] warn_slowpath_common+0x81/0x9b
[<ffffffff810c388c>] ? ftrace_get_addr_new+0x6f/0xc0
[<ffffffff810001c8>] ? 0xffffffff810001c8
[<ffffffff81042031>] warn_slowpath_null+0x1a/0x1c
[<ffffffff810c388c>] ftrace_get_addr_new+0x6f/0xc0
[<ffffffff8102e938>] ftrace_replace_code+0xd6/0x334
[<ffffffff810c4116>] ftrace_modify_all_code+0x41/0xc5
[<ffffffff8102eba6>] arch_ftrace_update_code+0x10/0x19
[<ffffffff810c293c>] ftrace_run_update_code+0x21/0x42
[<ffffffff810c298f>] ftrace_startup_enable+0x32/0x34
[<ffffffff810c3049>] ftrace_startup+0x14e/0x15a
[<ffffffff810c307c>] register_ftrace_function+0x27/0x40
[<ffffffff810dc118>] perf_ftrace_event_register+0x3e/0xee
[<ffffffff810dbfbe>] perf_trace_init+0x29d/0x2a9
[<ffffffff810eb422>] perf_tp_event_init+0x27/0x3a
[<ffffffff810f18bc>] perf_init_event+0x9e/0xed
[<ffffffff810f1ba4>] perf_event_alloc+0x299/0x330
[<ffffffff810f236b>] SYSC_perf_event_open+0x3ee/0x816
[<ffffffff8115a066>] ? mntput+0x2d/0x2f
[<ffffffff81142b00>] ? __fput+0xa7/0x1b2
[<ffffffff81091300>] ? do_gettimeofday+0x22/0x3a
[<ffffffff810f279c>] SyS_perf_event_open+0x9/0xb
[<ffffffff81502a92>] system_call_fastpath+0x12/0x17
---[ end trace 81a53565150e4982 ]---
Bad trampoline accounting at: ffffffff810001c8 (run_init_process+0x0/0x2d) (10000001)
Update the control_ops trampoline instead of the perf ops one.
Reported-by: lkp@01.org
With the introduction of the dynamic trampolines, it is useful that if
things go wrong that ftrace_bug() produces more information about what
the current state is. This can help debug issues that may arise.
Ftrace has lots of checks to make sure that the state of the system it
touchs is exactly what it expects it to be. When it detects an abnormality
it calls ftrace_bug() and disables itself to prevent any further damage.
It is crucial that ftrace_bug() produces sufficient information that
can be used to debug the situation.
Acked-by: Borislav Petkov <bp@suse.de>
Tested-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Tested-by: Jiri Kosina <jkosina@suse.cz>
When the static ftrace_ops (like function tracer) enables tracing, and it
is the only callback that is referencing a function, a trampoline is
dynamically allocated to the function that calls the callback directly
instead of calling a loop function that iterates over all the registered
ftrace ops (if more than one ops is registered).
But when it comes to dynamically allocated ftrace_ops, where they may be
freed, on a CONFIG_PREEMPT kernel there's no way to know when it is safe
to free the trampoline. If a task was preempted while executing on the
trampoline, there's currently no way to know when it will be off that
trampoline.
But this is not true when it comes to !CONFIG_PREEMPT. The current method
of calling schedule_on_each_cpu() will force tasks off the trampoline,
becaues they can not schedule while on it (kernel preemption is not
configured). That means it is safe to free a dynamically allocated
ftrace ops trampoline when CONFIG_PREEMPT is not configured.
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The file /sys/kernel/debug/tracing/eneabled_functions is used to debug
ftrace function hooks. Add to the output what function is being called
by the trampoline if the arch supports it.
Add support for this feature in x86_64.
The current method of handling multiple function callbacks is to register
a list function callback that calls all the other callbacks based on
their hash tables and compare it to the function that the callback was
called on. But this is very inefficient.
For example, if you are tracing all functions in the kernel and then
add a kprobe to a function such that the kprobe uses ftrace, the
mcount trampoline will switch from calling the function trace callback
to calling the list callback that will iterate over all registered
ftrace_ops (in this case, the function tracer and the kprobes callback).
That means for every function being traced it checks the hash of the
ftrace_ops for function tracing and kprobes, even though the kprobes
is only set at a single function. The kprobes ftrace_ops is checked
for every function being traced!
Instead of calling the list function for functions that are only being
traced by a single callback, we can call a dynamically allocated
trampoline that calls the callback directly. The function graph tracer
already uses a direct call trampoline when it is being traced by itself
but it is not dynamically allocated. It's trampoline is static in the
kernel core. The infrastructure that called the function graph trampoline
can also be used to call a dynamically allocated one.
For now, only ftrace_ops that are not dynamically allocated can have
a trampoline. That is, users such as function tracer or stack tracer.
kprobes and perf allocate their ftrace_ops, and until there's a safe
way to free the trampoline, it can not be used. The dynamically allocated
ftrace_ops may, although, use the trampoline if the kernel is not
compiled with CONFIG_PREEMPT. But that will come later.
When modifying code, ftrace has several checks to make sure things
are being done correctly. One of them is to make sure any code it
modifies is exactly what it expects it to be before it modifies it.
In order to do so with the new trampoline logic, it must be able
to find out what trampoline a function is hooked to in order to
see if the code that hooks to it is what's expected.
The logic to find the trampoline from a record (accounting descriptor
for a function that is hooked) needs to only look at the "old_hash"
of an ops that is being modified. The old_hash is the list of function
an ops is hooked to before its update. Since a record would only be
pointing to an ops that is being modified if it was already hooked
before.
Currently, it can pick a modified ops based on its new functions it
will be hooked to, and this picks the wrong trampoline and causes
the check to fail, disabling ftrace.
ftrace: squash into ordering of ops for modification
The code that checks for trampolines when modifying function hooks
tests against a modified ops "old_hash". But the ops old_hash pointer
is not being updated before the changes are made, making it possible
to not find the right hash to the callback and possibly causing
ftrace to break in accounting and disable itself.
Have the ops set its old_hash before the modifying takes place.
When the last ftrace_ops is unregistered, all the function records should
have a zeroed flags value. Make sure that is the case when the last ftrace_ops
is unregistered.
Allowing function callbacks to declare their own trampolines requires
that each ftrace_ops that has a trampoline must have some sort of
accounting that keeps track of which ops has a trampoline attached
to a record.
The easy way to solve this was to add a "tramp_hash" that created a
hash entry for every function that a ops uses with a trampoline.
But since we can have literally tens of thousands of functions being
traced, that means we need tens of thousands of descriptors to map
the ops to the function in the hash. This is quite expensive and
can cause enabling and disabling the function graph tracer to take
some time to start and stop. It can take up to several seconds to
disable or enable all functions in the function graph tracer for this
reason.
The better approach albeit more complex, is to keep track of how ops
are being enabled and disabled, and use that along with the counting
of the number of ops attached to records, to determive what ops has
a trampoline attached to a record at enabling and disabling of
tracing.
To do this, the tramp_hash has been replaced with an old_filter_hash
and old_notrace_hash, which get the copy of the ops filter_hash and
notrace_hash respectively. The old hashes is kept until the ops has
been modified or removed and the old hashes are used with the logic
of the accounting to determine the ops that have the trampoline of
a record. The reason this has less of a footprint is due to the trick
that an "empty" hash in the filter_hash means "all functions" and
an empty hash in the notrace hash means "no functions" in the hash.
This is much more efficienct, doesn't have the delay, and takes up
much less memory, as we do not need to map all the functions but
just figure out which functions are mapped at the time it is
enabled or disabled.
Add three new flags for ftrace_ops:
FTRACE_OPS_FL_ADDING
FTRACE_OPS_FL_REMOVING
FTRACE_OPS_FL_MODIFYING
These will be set for the ftrace_ops when they are first added
to the function tracing, being removed from function tracing
or just having their functions changed from function tracing,
respectively.
This will be needed to remove the tramp_hash, which can grow quite
big. The tramp_hash is used to note what functions a ftrace_ops
is using a trampoline for. Denoting which ftrace_ops is being
modified, will allow us to use the ftrace_ops hashes themselves,
which are much smaller as they have a global flag to denote if
a ftrace_ops is tracing all functions, as well as a notrace hash
if the ftrace_ops is tracing all but a few. The tramp_hash just
creates a hash item for every function, which can go into the 10s
of thousands if all functions are using the ftrace_ops trampoline.
