Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Ensure system time is read from rtc i.e. PMIC RTC
in case of tegra after system resume.
- Change is applicable to all PMIC RTC drivers.
bug 1510843
Reviewed-on: http://git-master/r/413365/
Reviewed-on: http://git-master/r/414163/
Reviewed-on: http://git-master/r/414169/
Reviewed-on: http://git-master/r/414200/
Reviewed-on: http://git-master/r/414201/
Change-Id: I8194f9f4be581216d662e6a6e0d7e98a9495159c
Signed-off-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-on: http://git-master/r/414203
GVS: Gerrit_Virtual_Submit
NOHZ related per-cpu data is cleared on CPU down. This was introduced by
4b0c0f294 "tick: Cleanup NOHZ per cpu data on cpu down" which breaks
/proc/stats because the idle and iowait sums are now non-monotonic
across a CPU down/up cycle.
Fix this by not clearing the idle_sleeptime and iowait_sleeptime fields
on CPU down.
Bug 1484092
Change-Id: Ia57f5690672c0f35cf36098f92f242b94b545bb7
Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/386664
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
commit c9b5a266b103af873abb9ac03bc3d067702c8f4b upstream.
In periodic mode we remove offline cpus from the broadcast propagation
mask. In oneshot mode we fail to do so. This was not a problem so far,
but the recent changes to the broadcast propagation introduced a
constellation which can result in a NULL pointer dereference.
What happens is:
CPU0 CPU1
idle()
arch_idle()
tick_broadcast_oneshot_control(OFF);
set cpu1 in tick_broadcast_force_mask
if (cpu_offline())
arch_cpu_dead()
cpu_dead_cleanup(cpu1)
cpu1 tickdevice pointer = NULL
broadcast interrupt
dereference cpu1 tickdevice pointer -> OOPS
We dereference the pointer because cpu1 is still set in
tick_broadcast_force_mask and tick_do_broadcast() expects a valid
cpumask and therefor lacks any further checks.
Remove the cpu from the tick_broadcast_force_mask before we set the
tick device pointer to NULL. Also add a sanity check to the oneshot
broadcast function, so we can detect such issues w/o crashing the
machine.
Reported-by: Prarit Bhargava <prarit@redhat.com>
Cc: athorlton@sgi.com
Cc: CAI Qian <caiqian@redhat.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1306261303260.4013@ionos.tec.linutronix.de
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit 80d767d770fd9c697e434fd080c2db7b5c60c6dd upstream.
When compiling for the IA-64 ski emulator, HZ is set to 32 because the
emulation is slow and we don't want to waste too many cycles processing
timers. Alpha also has an option to set HZ to 32.
This causes integer underflow in
kernel/time/jiffies.c:
kernel/time/jiffies.c:66:2: warning: large integer implicitly truncated to unsigned type [-Woverflow]
.mult = NSEC_PER_JIFFY << JIFFIES_SHIFT, /* details above */
This patch reduces the JIFFIES_SHIFT value to avoid the overflow.
Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Link: http://lkml.kernel.org/r/alpine.LRH.2.02.1401241639100.23871@file01.intranet.prod.int.rdu2.redhat.com
commit dd5fd9b91a77b4c9c28b7ef9c181b1a875820d0a upstream.
AMD systems which use the C1E workaround in the amd_e400_idle routine
trigger the WARN_ON_ONCE in the broadcast code when onlining a CPU.
The reason is that the idle routine of those AMD systems switches the
cpu into forced broadcast mode early on before the newly brought up
CPU can switch over to high resolution / NOHZ mode. The timer related
CPU1 bringup looks like this:
clockevent_register_device(local_apic);
tick_setup(local_apic);
idle()
tick_broadcast_on_off(FORCE);
tick_broadcast_oneshot_control(ENTER)
cpumask_set(cpu, broadcast_oneshot_mask);
halt();
Now the broadcast interrupt on CPU0 sets CPU1 in the
broadcast_pending_mask and wakes CPU1. So CPU1 continues:
local_apic_timer_interrupt()
tick_handle_periodic();
softirq()
tick_init_highres();
cpumask_clr(cpu, broadcast_oneshot_mask);
WARN_ON(cpumask_test(cpu, broadcast_pending_mask);
So while we remove CPU1 from the broadcast_oneshot_mask when we switch
over to highres mode, we do not clear the pending bit, which then
triggers the warning when we go back to idle.
The reason why this is only visible on C1E affected AMD systems is
that the other machines enter the deep sleep states via
acpi_idle/intel_idle and exit the broadcast mode before executing the
remote triggered local_apic_timer_interrupt. So the pending bit is
already cleared when the switch over to highres mode is clearing the
oneshot mask.
The solution is simple: Clear the pending bit together with the mask
bit when we switch over to highres mode.
Stanislaw came up independently with the same patch by enforcing the
C1E workaround and debugging the fallout. I picked mine, because mine
has a changelog :)
Reported-by: poma <pomidorabelisima@gmail.com>
Debugged-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Dave Jones <davej@redhat.com>
Cc: Justin M. Forbes <jforbes@redhat.com>
Cc: Josh Boyer <jwboyer@redhat.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1402111434180.21991@ionos.tec.linutronix.de
commit 6fdda9a9c5db367130cf32df5d6618d08b89f46a upstream.
As part of normal operaions, the hrtimer subsystem frequently calls
into the timekeeping code, creating a locking order of
hrtimer locks -> timekeeping locks
clock_was_set_delayed() was suppoed to allow us to avoid deadlocks
between the timekeeping the hrtimer subsystem, so that we could
notify the hrtimer subsytem the time had changed while holding
the timekeeping locks. This was done by scheduling delayed work
that would run later once we were out of the timekeeing code.
But unfortunately the lock chains are complex enoguh that in
scheduling delayed work, we end up eventually trying to grab
an hrtimer lock.
Sasha Levin noticed this in testing when the new seqlock lockdep
enablement triggered the following (somewhat abrieviated) message:
[ 251.100221] ======================================================
[ 251.100221] [ INFO: possible circular locking dependency detected ]
[ 251.100221] 3.13.0-rc2-next-20131206-sasha-00005-g8be2375-dirty #4053 Not tainted
[ 251.101967] -------------------------------------------------------
[ 251.101967] kworker/10:1/4506 is trying to acquire lock:
[ 251.101967] (timekeeper_seq){----..}, at: [<ffffffff81160e96>] retrigger_next_event+0x56/0x70
[ 251.101967]
[ 251.101967] but task is already holding lock:
[ 251.101967] (hrtimer_bases.lock#11){-.-...}, at: [<ffffffff81160e7c>] retrigger_next_event+0x3c/0x70
[ 251.101967]
[ 251.101967] which lock already depends on the new lock.
[ 251.101967]
[ 251.101967]
[ 251.101967] the existing dependency chain (in reverse order) is:
[ 251.101967]
-> #5 (hrtimer_bases.lock#11){-.-...}:
[snipped]
-> #4 (&rt_b->rt_runtime_lock){-.-...}:
[snipped]
-> #3 (&rq->lock){-.-.-.}:
[snipped]
-> #2 (&p->pi_lock){-.-.-.}:
[snipped]
-> #1 (&(&pool->lock)->rlock){-.-...}:
[ 251.101967] [<ffffffff81194803>] validate_chain+0x6c3/0x7b0
[ 251.101967] [<ffffffff81194d9d>] __lock_acquire+0x4ad/0x580
[ 251.101967] [<ffffffff81194ff2>] lock_acquire+0x182/0x1d0
[ 251.101967] [<ffffffff84398500>] _raw_spin_lock+0x40/0x80
[ 251.101967] [<ffffffff81153e69>] __queue_work+0x1a9/0x3f0
[ 251.101967] [<ffffffff81154168>] queue_work_on+0x98/0x120
[ 251.101967] [<ffffffff81161351>] clock_was_set_delayed+0x21/0x30
[ 251.101967] [<ffffffff811c4bd1>] do_adjtimex+0x111/0x160
[ 251.101967] [<ffffffff811e2711>] compat_sys_adjtimex+0x41/0x70
[ 251.101967] [<ffffffff843a4b49>] ia32_sysret+0x0/0x5
[ 251.101967]
-> #0 (timekeeper_seq){----..}:
[snipped]
[ 251.101967] other info that might help us debug this:
[ 251.101967]
[ 251.101967] Chain exists of:
timekeeper_seq --> &rt_b->rt_runtime_lock --> hrtimer_bases.lock#11
[ 251.101967] Possible unsafe locking scenario:
[ 251.101967]
[ 251.101967] CPU0 CPU1
[ 251.101967] ---- ----
[ 251.101967] lock(hrtimer_bases.lock#11);
[ 251.101967] lock(&rt_b->rt_runtime_lock);
[ 251.101967] lock(timekeeper_seq);
[ 251.101967]
[ 251.101967] *** DEADLOCK ***
[ 251.101967]
[ 251.101967] 3 locks held by kworker/10:1/4506:
[ 251.101967] #0: (events){.+.+.+}, at: [<ffffffff81154960>] process_one_work+0x200/0x530
[ 251.101967] #1: (hrtimer_work){+.+...}, at: [<ffffffff81154960>] process_one_work+0x200/0x530
[ 251.101967] #2: (hrtimer_bases.lock#11){-.-...}, at: [<ffffffff81160e7c>] retrigger_next_event+0x3c/0x70
[ 251.101967]
[ 251.101967] stack backtrace:
[ 251.101967] CPU: 10 PID: 4506 Comm: kworker/10:1 Not tainted 3.13.0-rc2-next-20131206-sasha-00005-g8be2375-dirty #4053
[ 251.101967] Workqueue: events clock_was_set_work
So the best solution is to avoid calling clock_was_set_delayed() while
holding the timekeeping lock, and instead using a flag variable to
decide if we should call clock_was_set() once we've released the locks.
This works for the case here, where the do_adjtimex() was the deadlock
trigger point. Unfortuantely, in update_wall_time() we still hold
the jiffies lock, which would deadlock with the ipi triggered by
clock_was_set(), preventing us from calling it even after we drop the
timekeeping lock. So instead call clock_was_set_delayed() at that point.
Cc: Prarit Bhargava <prarit@redhat.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit 330a1617b0a6268d427aa5922c94d082b1d3e96d upstream.
Since 48cdc135d4840 (Implement a shadow timekeeper), we have to
call timekeeping_update() after any adjustment to the timekeeping
structure in order to make sure that any adjustments to the structure
persist.
In the timekeeping suspend path, we udpate the timekeeper
structure, so we should be sure to update the shadow-timekeeper
before releasing the timekeeping locks. Currently this isn't done.
In most cases, the next time related code to run would be
timekeeping_resume, which does update the shadow-timekeeper, but
in an abundence of caution, this patch adds the call to
timekeeping_update() in the suspend path.
commit 04005f6011e3b504cd4d791d9769f7cb9a3b2eae upstream.
A think-o in the calculation of the monotonic -> tai time offset
results in CLOCK_TAI timers and nanosleeps to expire late (the
latency is ~2x the tai offset).
Fix this by adding the tai offset from the realtime offset instead
of subtracting.
commit f55c07607a38f84b5c7e6066ee1cfe433fa5643c upstream.
persist.
Unfortunately, the updates to the tai offset via adjtimex do not
trigger this update, causing adjustments to the tai offset to be
made and then over-written by the previous value at the next
update_wall_time() call.
This patch resovles the issue by calling timekeeping_update()
right after setting the tai offset.
Bo Shen sent a patch to change this to 1Mhz instead of 4Mhz but according
to Russell King the use of 4Mhz was intentional. Add a comment to this
effect so that others don't try to change the code as well.
Bug 1399318
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Bo Shen <voice.shen@atmel.com>
(cherry picked from commit 21e79dee7fe571f59aca2d946032736b0d89ef46)
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Change-Id: If9755b79575739f8be1a4a221a05b34f19ef4b78
Nobody is using sched_clock_func() anymore now that sched_clock
supports up to 64 bits. Remove the hook so that new code only
uses sched_clock_register().
Bug 1399318
(cherry picked from commit b4042ceaabbd913bc5b397ddd1e396eeb312d72f)
Change-Id: I893740dddcb2ded37acecf0ce87f7f6bcce0cfe8
We need to calculate the same number in the clocksource code and
the sched_clock code, so extract this code into its own function.
We also drop the min_t and just use min() because the two types
are the same.
Bug 1399318
(cherry picked from commit 87d8b9eb7eb6669aad6435a51e9862362141ba76)
Change-Id: Id1208090d9fcc282a162ce6fdb5e4a64d0b33907
The ARM architected system counter has at least 56 usable bits.
Add support for counters with more than 32 bits to the generic
sched_clock implementation so we can increase the time between
wakeups due to dealing with wrap-around on these devices while
benefiting from the irqtime accounting and suspend/resume
handling that the generic sched_clock code already has. On my
system using 56 bits over 32 bits changes the wraparound time
from a few minutes to an hour. For faster running counters (GHz
range) this is even more important because we may not be able to
execute the timer in time to deal with the wraparound if only 32
bits are used.
We choose a maxsec value of 3600 seconds because we assume no
system will go idle for more than an hour. In the future we may
need to increase this value.
Note: All users should switch over to the 64-bit read function so
we can remove setup_sched_clock() in favor of sched_clock_register().
Bug 1399318
(cherry picked from commit e7e3ff1bfe9c42ee31172e9afdc0383a9e595e29)
Change-Id: I7c20d4185232868b362368f034c97337e48b0dc8
In the next patch we're going to increase the number of bits that
the generic sched_clock can handle to be greater than 32. With
more than 32 bits the wraparound time can be larger than what can
fit into the units that msecs_to_jiffies takes (unsigned int).
Luckily, the wraparound is initially calculated in nanoseconds
which we can easily use with hrtimers, so switch to using an
hrtimer.
Bug 1399318
[jstultz: Fixup hrtimer intitialization order issue]
(cherry picked from commit a08ca5d1089da03724f96fa0870c64968e66765b)
Change-Id: I17a9bd3140e7f41f0985c070a14eea17696b3770
We're going to increase the cyc value to 64 bits in the near
future. Doing that is going to break the custom seqcount
implementation in the sched_clock code because 64 bit numbers
aren't guaranteed to be atomic. Replace the cyc_copy with a
seqcount to avoid this problem.
Bug 1399318
Acked-by: Will Deacon <will.deacon@arm.com>
(cherry picked from commit 85c3d2dd15be4d577a37ffb8bbbd019fc8e3280a)
Change-Id: Iff7ec4aca829452c5b51576dae9437a37ed8f619
The expression '(1 << 32)' happens to evaluate as 0 on ARM, but
it evaluates as 1 on xtensa and x86_64. This zeros sched_clock_mask,
and breaks sched_clock().
Set the type of 1 to 'unsigned long long' to get the value we need.
Bug 1399318
Reported-by: Max Filippov <jcmvbkbc@gmail.com>
Tested-by: Max Filippov <jcmvbkbc@gmail.com>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
(cherry picked from commit 53c035204253efe373d9ff166fae6147e8c693b6)
Change-Id: I9bbe733430f9f7850e4073feef4265f626e6dc8f
There is a small race between when the cycle count is read from
the hardware and when the epoch stabilizes. Consider this
scenario:
CPU0 CPU1
cyc = read_sched_clock()
cyc_to_sched_clock()
update_sched_clock()
cd.epoch_cyc = cyc;
epoch_cyc = cd.epoch_cyc;
epoch_ns + cyc_to_ns((cyc - epoch_cyc)
The cyc on cpu0 was read before the epoch changed. But we
calculate the nanoseconds based on the new epoch by subtracting
the new epoch from the old cycle count. Since epoch is most likely
larger than the old cycle count we calculate a large number that
will be converted to nanoseconds and added to epoch_ns, causing
time to jump forward too much.
Fix this problem by reading the hardware after the epoch has
stabilized.
Bug 1399318
(cherry picked from commit 336ae1180df5f69b9e0fb6561bec01c5f64361cf)
Change-Id: I50aedb0eb050206de4ab20505e84a561ec1ca0fb
Nothing about the sched_clock implementation in the ARM port is
specific to the architecture. Generalize the code so that other
architectures can use it by selecting GENERIC_SCHED_CLOCK.
Bug 1399318
[jstultz: Merge minor collisions with other patches in my tree]
(cherry picked from commit 38ff87f77af0b5a93fc8581cff1d6e5692ab8970)
Change-Id: Iaac325635344ef4adee8fa0f9ca11aee089bce0f
This is the 3.10.24 stable release
Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
commit 4be77398ac9d948773116b6be4a3c91b3d6ea18c upstream.
Since commit 1e75fa8be9f (time: Condense timekeeper.xtime
into xtime_sec - merged in v3.6), there has been an problem
with the error accounting in the timekeeping code, such that
when truncating to nanoseconds, we round up to the next nsec,
but the balancing adjustment to the ntp_error value was dropped.
This causes 1ns per tick drift forward of the clock.
In 3.7, this logic was isolated to only GENERIC_TIME_VSYSCALL_OLD
architectures (s390, ia64, powerpc).
The fix is simply to balance the accounting and to subtract the
added nanosecond from ntp_error. This allows the internal long-term
clock steering to keep the clock accurate.
While this fix removes the regression added in 1e75fa8be9f, the
ideal solution is to move away from GENERIC_TIME_VSYSCALL_OLD
and use the new VSYSCALL method, which avoids entirely the
nanosecond granular rounding, and the resulting short-term clock
adjustment oscillation needed to keep long term accurate time.
[ jstultz: Many thanks to Martin for his efforts identifying this
subtle bug, and providing the fix. ]
Originally-from: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1385149491-20307-1-git-send-email-john.stultz@linaro.org
commit a97ad0c4b447a132a322cedc3a5f7fa4cab4b304 upstream.
The current code requires that the scheduled update of the RTC happens
in the closest tick to the half of the second. This seems to be
difficult to achieve reliably. The scheduled work may be missing the
target time by a tick or two and be constantly rescheduled every second.
Relax the limit to 10 ticks. As a typical RTC drifts in the 11-minute
update interval by several milliseconds, this shouldn't affect the
overall accuracy of the RTC much.
Signed-off-by: Miroslav Lichvar <mlichvar@redhat.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit 70e5975d3a04be5479a28eec4a2fb10f98ad2785 upstream.
On an SMP system with only one global clockevent and a dummy
clockevent per CPU we run into problems. We want the dummy
clockevents to be registered as the per CPU tick devices, but
we can only achieve that if we register the dummy clockevents
before the global clockevent or if we artificially inflate the
rating of the dummy clockevents to be higher than the rating
of the global clockevent. Failure to do so leads to boot
hangs when the dummy timers are registered on all other CPUs
besides the CPU that accepted the global clockevent as its tick
device and there is no broadcast timer to poke the dummy
devices.
If we're registering multiple clockevents and one clockevent is
global and the other is local to a particular CPU we should
choose to use the local clockevent regardless of the rating of
the device. This way, if the clockevent is a dummy it will take
the tick device duty as long as there isn't a higher rated tick
device and any global clockevent will be bumped out into
broadcast mode, fixing the problem described above.
Reported-and-tested-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: soren.brinkmann@xilinx.com
Cc: John Stultz <john.stultz@linaro.org>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Link: http://lkml.kernel.org/r/20130613183950.GA32061@codeaurora.org
Cc: Kim Phillips <kim.phillips@linaro.org>
commit 45cb8e01b2ecef1c2afb18333e95793fa1a90281 upstream.
Split out the clockevent device selection logic. Preparatory patch to
allow unbinding active clockevent devices.
Cc: Magnus Damm <magnus.damm@gmail.com>
Link: http://lkml.kernel.org/r/20130425143436.431796247@linutronix.de
commit ccf33d6880f39a35158fff66db13000ae4943fac upstream.
We want to be able to remove clockevent modules as well. Add a
refcount so we don't remove a module with an active clock event
device.
Link: http://lkml.kernel.org/r/20130425143436.307435149@linutronix.de
commit 7172a286ced0c1f4f239a0fa09db54ed37d3ead2 upstream.
7+ years and still a single user. Kill it.
Link: http://lkml.kernel.org/r/20130425143436.098520211@linutronix.de
commit 98d6f4dd84a134d942827584a3c5f67ffd8ec35f upstream.
Fedora Ruby maintainer reported latest Ruby doesn't work on Fedora Rawhide
on ARM. (http://bugs.ruby-lang.org/issues/9008)
Because of, commit 1c6b39ad3f (alarmtimers: Return -ENOTSUPP if no
RTC device is present) intruduced to return ENOTSUPP when
clock_get{time,res} can't find a RTC device. However this is incorrect.
First, ENOTSUPP isn't exported to userland (ENOTSUP or EOPNOTSUP are the
closest userland equivlents).
Second, Posix and Linux man pages agree that clock_gettime and
clock_getres should return EINVAL if clk_id argument is invalid.
While the arugment that the clockid is valid, but just not supported
on this hardware could be made, this is just a technicality that
doesn't help userspace applicaitons, and only complicates error
handling.
Thus, this patch changes the code to use EINVAL.
Reported-by: Vit Ondruch <v.ondruch@tiscali.cz>
[jstultz: Tweaks to commit message to include full rational]
commit 97b9410643475d6557d2517c2aff9fd2221141a9 upstream.
Marc Kleine-Budde pointed out, that commit 77cc982 "clocksource: use
clockevents_config_and_register() where possible" caused a regression
for some of the converted subarchs.
The reason is, that the clockevents core code converts the minimal
hardware tick delta to a nanosecond value for core internal
usage. This conversion is affected by integer math rounding loss, so
the backwards conversion to hardware ticks will likely result in a
value which is less than the configured hardware limitation. The
affected subarchs used their own workaround (SIGH!) which got lost in
the conversion.
The solution for the issue at hand is simple: adding evt->mult - 1 to
the shifted value before the integer divison in the core conversion
function takes care of it. But this only works for the case where for
the scaled math mult/shift pair "mult <= 1 << shift" is true. For the
case where "mult > 1 << shift" we can apply the rounding add only for
the minimum delta value to make sure that the backward conversion is
not less than the given hardware limit. For the upper bound we need to
omit the rounding add, because the backwards conversion is always
larger than the original latch value. That would violate the upper
bound of the hardware device.
Though looking closer at the details of that function reveals another
bogosity: The upper bounds check is broken as well. Checking for a
resulting "clc" value greater than KTIME_MAX after the conversion is
pointless. The conversion does:
u64 clc = (latch << evt->shift) / evt->mult;
So there is no sanity check for (latch << evt->shift) exceeding the
64bit boundary. The latch argument is "unsigned long", so on a 64bit
arch the handed in argument could easily lead to an unnoticed shift
overflow. With the above rounding fix applied the calculation before
the divison is:
u64 clc = (latch << evt->shift) + evt->mult - 1;
So we need to make sure, that neither the shift nor the rounding add
is overflowing the u64 boundary.
[ukl: move assignment to rnd after eventually changing mult, fix build
issue and correct comment with the right math]
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
Cc: nicolas.ferre@atmel.com
Cc: Marc Pignat <marc.pignat@hevs.ch>
Cc: john.stultz@linaro.org
Cc: kernel@pengutronix.de
Cc: Ronald Wahl <ronald.wahl@raritan.com>
Cc: LAK <linux-arm-kernel@lists.infradead.org>
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Link: http://lkml.kernel.org/r/1380052223-24139-1-git-send-email-u.kleine-koenig@pengutronix.de
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
commit 7bd36014460f793c19e7d6c94dab67b0afcfcb7f upstream.
Gerlando Falauto reported that when HRTICK is enabled, it is
possible to trigger system deadlocks. These were hard to
reproduce, as HRTICK has been broken in the past, but seemed
to be connected to the timekeeping_seq lock.
Since seqlock/seqcount's aren't supported w/ lockdep, I added
some extra spinlock based locking and triggered the following
lockdep output:
[ 15.849182] ntpd/4062 is trying to acquire lock:
[ 15.849765] (&(&pool->lock)->rlock){..-...}, at: [<ffffffff810aa9b5>] __queue_work+0x145/0x480
[ 15.850051]
[ 15.850051] but task is already holding lock:
[ 15.850051] (timekeeper_lock){-.-.-.}, at: [<ffffffff810df6df>] do_adjtimex+0x7f/0x100
<snip>
[ 15.850051] Chain exists of: &(&pool->lock)->rlock --> &p->pi_lock --> timekeeper_lock
[ 15.850051] Possible unsafe locking scenario:
[ 15.850051]
[ 15.850051] CPU0 CPU1
[ 15.850051] ---- ----
[ 15.850051] lock(timekeeper_lock);
[ 15.850051] lock(&p->pi_lock);
[ 15.850051] lock(&(&pool->lock)->rlock);
[ 15.850051]
[ 15.850051] *** DEADLOCK ***
The deadlock was introduced by 06c017fdd4dc48451a ("timekeeping:
Hold timekeepering locks in do_adjtimex and hardpps") in 3.10
This patch avoids this deadlock, by moving the call to
schedule_delayed_work() outside of the timekeeper lock
critical section.
Reported-by: Gerlando Falauto <gerlando.falauto@keymile.com>
Tested-by: Lin Ming <minggr@gmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/1378943457-27314-1-git-send-email-john.stultz@linaro.org
Correct the issue with /proc/timer_list reported by Holger. When reading
from the proc file with a sufficiently small buffer, 2k so not really that
small, there was one could get hung trying to read the file a chunk at a
time.
The timer_list_start function failed to account for the possibility that
the offset was adjusted outside the timer_list_next.
Signed-off-by: Nathan Zimmer <nzimmer@sgi.com>
Reported-by: Holger Hans Peter Freyther <holger@freyther.de>
Cc: Berke Durak <berke.durak@xiphos.com>
Cc: Jeff Layton <jlayton@redhat.com>
Tested-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: <stable@vger.kernel.org> # 3.10.x
(cherry picked from commit 231efe79024840d9665f61f19cce032aaa8d8cea)
Change-Id: Ie543eb9649a0cb0f12a3f74b291e065c9d23cf18
Reviewed-on: http://git-master/r/270878
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Tested-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Change-Id: If8410d4059f778b475fd28663ade50c5132cc540
Signed-off-by: Sami Liedes <sliedes@nvidia.com>
Reviewed-on: http://git-master/r/225723
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Print/display the cause of error if suspend fails. This helps in
debugging the failure case.
(Cherrypicked commit
2a5cd5441333ffd1b8e72c2b0d70734b9ca5fdeb)
Reviewed-on: http://git-master/r/202454
Change-Id: I5fa1ea4a542d8ee8f8bdf106a97eefc2c5e3d8d3
Reviewed-on: http://git-master/r/215100
Since cpustat[CPUTIME_IDLE] is never connected to ts->idle_sleeptime,
never read from cpustat[CPUTIME_IDLE] when reporting stats in
/proc/stat.
Note this was rejected by Michal Hocko when it was initially proposed
by Martin Schwidefsky in LKML, so if you want to upstream it, better
find an alternative (either completely disable cpustat[CPUTIME_IDLE]
for CONFIG_NO_HZ or somehow connect them to keep them in sync.)
bug 1190321
Change-Id: Idc92488910b826aff850a010016d8326c7ab9e6c
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/212224
(cherry picked from commit e7a9220f5883bf3816e24895a34239a34a7d9ece)
Reviewed-on: http://git-master/r/212907
Reviewed-by: Liang Cheng (SW) <licheng@nvidia.com>
Removed the check if device has wakeup capablity
while registration as the wakeup policy has to come from
user space as per Documentation/power/devices.txt
Bug 1219152
Change-Id: I4994c603aac0afd54381dcaec239f2315831849f
Signed-off-by: Chaitanya Bandi <bandik@nvidia.com>
Reviewed-on: http://git-master/r/195109
- Remove redefintion of stub function
Change-Id: Id31c25707347cfa2947a83317ba5bf5bacfaa442
Reviewed-on: http://git-master/r/115069
Reviewed-by: Krishna Monian <kmonian@nvidia.com>
Tested-by: Krishna Monian <kmonian@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Rebase-Id: R50526c83eaec6b30319fa4adb7033d81e749399d
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
after-upstream-android
arch/arm/common/Kconfig
arch/arm/mm/Makefile
arch/arm/mm/cache-l2x0.c
arch/arm/mm/mmu.c
drivers/input/Kconfig
drivers/input/Makefile
drivers/power/Kconfig
kernel/futex.c
commit 84a78a6504f5c5394a8e558702e5b54131f01d14 upstream.
Correct an issue with /proc/timer_list reported by Holger.
When reading from the proc file with a sufficiently small buffer, 2k so
not really that small, there was one could get hung trying to read the
file a chunk at a time.
commit 148519120c6d1f19ad53349683aeae9f228b0b8d upstream.
Revert commit 69a37bea (cpuidle: Quickly notice prediction failure for
repeat mode), because it has been identified as the source of a
significant performance regression in v3.8 and later as explained by
Jeremy Eder:
We believe we've identified a particular commit to the cpuidle code
that seems to be impacting performance of variety of workloads.
The simplest way to reproduce is using netperf TCP_RR test, so
we're using that, on a pair of Sandy Bridge based servers. We also
have data from a large database setup where performance is also
measurably/positively impacted, though that test data isn't easily
share-able.
Included below are test results from 3 test kernels:
kernel reverts
1) vanilla upstream (no reverts)
2) perfteam2 reverts e11538d1f03914eb92af5a1a378375c05ae8520c
3) test reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
In summary, netperf TCP_RR numbers improve by approximately 4%
after reverting 69a37beabf1f0a6705c08e879bdd5d82ff6486c4. When
69a37beabf1f0a6705c08e879bdd5d82ff6486c4 is included, C0 residency
never seems to get above 40%. Taking that patch out gets C0 near
100% quite often, and performance increases.
The below data are histograms representing the %c0 residency @
1-second sample rates (using turbostat), while under netperf test.
- If you look at the first 4 histograms, you can see %c0 residency
almost entirely in the 30,40% bin.
- The last pair, which reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4,
shows %c0 in the 80,90,100% bins.
Below each kernel name are netperf TCP_RR trans/s numbers for the
particular kernel that can be disclosed publicly, comparing the 3
test kernels. We ran a 4th test with the vanilla kernel where
we've also set /dev/cpu_dma_latency=0 to show overall impact
boosting single-threaded TCP_RR performance over 11% above
baseline.
3.10-rc2 vanilla RX + c0 lock (/dev/cpu_dma_latency=0):
TCP_RR trans/s 54323.78
3.10-rc2 vanilla RX (no reverts)
TCP_RR trans/s 48192.47
Receiver %c0
0.0000 - 10.0000 [ 1]: *
10.0000 - 20.0000 [ 0]:
20.0000 - 30.0000 [ 0]:
30.0000 - 40.0000 [ 59]:
40.0000 - 50.0000 [ 1]: *
50.0000 - 60.0000 [ 0]:
60.0000 - 70.0000 [ 0]:
70.0000 - 80.0000 [ 0]:
80.0000 - 90.0000 [ 0]:
90.0000 - 100.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 11]: ***********
40.0000 - 50.0000 [ 49]:
3.10-rc2 perfteam2 RX (reverts commit
e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 49698.69
Receiver %c0
10.0000 - 20.0000 [ 1]: *
40.0000 - 50.0000 [ 0]:
Sender %c0
30.0000 - 40.0000 [ 2]: **
40.0000 - 50.0000 [ 58]:
3.10-rc2 test RX (reverts 69a37beabf1f0a6705c08e879bdd5d82ff6486c4
and e11538d1f03914eb92af5a1a378375c05ae8520c)
TCP_RR trans/s 47766.95
Receiver %c0
30.0000 - 40.0000 [ 27]: ***************************
40.0000 - 50.0000 [ 2]: **
60.0000 - 70.0000 [ 2]: **
90.0000 - 100.0000 [ 28]: ****************************
Sender:
50.0000 - 60.0000 [ 1]: *
70.0000 - 80.0000 [ 3]: ***
80.0000 - 90.0000 [ 7]: *******
90.0000 - 100.0000 [ 38]: **************************************
These results demonstrate gaining back the tendency of the CPU to
stay in more responsive, performant C-states (and thus yield
measurably better performance), by reverting commit
Requested-by: Jeremy Eder <jeder@redhat.com>
Tested-by: Len Brown <len.brown@intel.com>
commit 1f73a9806bdd07a5106409bbcab3884078bd34fe upstream.
When the system switches from periodic to oneshot mode, the broadcast
logic causes a possibility that a CPU which has not yet switched to
oneshot mode puts its own clock event device into oneshot mode without
updating the state and the timer handler.
CPU0 CPU1
per cpu tickdev is in periodic mode
and switched to broadcast
Switch to oneshot mode
tick_broadcast_switch_to_oneshot()
cpumask_copy(tick_oneshot_broacast_mask,
tick_broadcast_mask);
broadcast device mode = oneshot
Timer interrupt
irq_enter()
tick_check_oneshot_broadcast()
dev->set_mode(ONESHOT);
if (dev->mode == ONESHOT)
dev->next_event += period;
FAIL.
We fail, because dev->next_event contains KTIME_MAX, if the device was
in periodic mode before the uncontrolled switch to oneshot happened.
We must copy the broadcast bits over to the oneshot mask, because
otherwise a CPU which relies on the broadcast would not been woken up
anymore after the broadcast device switched to oneshot mode.
So we need to verify in tick_check_oneshot_broadcast() whether the CPU
has already switched to oneshot mode. If not, leave the device
untouched and let the CPU switch controlled into oneshot mode.
This is a long standing bug, which was never noticed, because the main
user of the broadcast x86 cannot run into that scenario, AFAICT. The
nonarchitected timer mess of ARM creates a gazillion of differently
broken abominations which trigger the shortcomings of that broadcast
code, which better had never been necessary in the first place.
Reported-and-tested-by: Stehle Vincent-B46079 <B46079@freescale.com>
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Mark Rutland <mark.rutland@arm.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1307012153060.4013@ionos.tec.linutronix.de
commit 07bd1172902e782f288e4d44b1fde7dec0f08b6f upstream.
The recent implementation of a generic dummy timer resulted in a
different registration order of per cpu local timers which made the
broadcast control logic go belly up.
If the dummy timer is the first clock event device which is registered
for a CPU, then it is installed, the broadcast timer is initialized
and the CPU is marked as broadcast target.
If a real clock event device is installed after that, we can fail to
take the CPU out of the broadcast mask. In the worst case we end up
with two periodic timer events firing for the same CPU. One from the
per cpu hardware device and one from the broadcast.
Now the problem is that we have no way to distinguish whether the
system is in a state which makes broadcasting necessary or the
broadcast bit was set due to the nonfunctional dummy timer
installment.
To solve this we need to keep track of the system state seperately and
provide a more detailed decision logic whether we keep the CPU in
broadcast mode or not.
The old decision logic only clears the broadcast mode, if the newly
installed clock event device is not affected by power states.
The new logic clears the broadcast mode if one of the following is
true:
- The new device is not affected by power states.
- The system is not in a power state affected mode
- The system has switched to oneshot mode. The oneshot broadcast is
controlled from the deep idle state. The CPU is not in idle at
this point, so it's safe to remove it from the mask.
If we clear the broadcast bit for the CPU when a new device is
installed, we also shutdown the broadcast device when this was the
last CPU in the broadcast mask.
If the broadcast bit is kept, then we leave the new device in shutdown
state and rely on the broadcast to deliver the timer interrupts via
the broadcast ipis.
Similar to hrtimer_expires_remaining, return the amount of time
remaining until alarm expiry.
Change-Id: I8c57512d619ac66bcdaf2d9ccdf0d7f74af2ff66
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Start an alarmtimer with an expires time relative to the current time
of the associated clock.
Change-Id: Ifb5309a15e0d502bb4d0209ca5510a56ee7fa88c
Similar to hrtimer_forward_now, move the expires time forward to an
interval from the current time of the associated clock.
Change-Id: I73fed223321167507b6eddcb7a57d235ffcfc1be
Analogous to hrtimer_restart, restart an alarmtimer after the expires
time has already been updated (as with alarm_forward).
Change-Id: Ia2613bbb467404cb2c35c11efa772bc56294963a
The recent modification in the cpuidle framework consolidated the
timer broadcast code across the different drivers by setting a new
flag in the idle state. It tells the cpuidle core code to enter/exit
the broadcast mode for the cpu when entering a deep idle state. The
broadcast timer enter/exit is no longer handled by the back-end
driver.
This change made the local interrupt to be enabled *before* calling
CLOCK_EVENT_NOTIFY_EXIT.
On a tegra114, a four cores system, when the flag has been introduced
in the driver, the following warning appeared:
WARNING: at kernel/time/tick-broadcast.c:578 tick_broadcast_oneshot_control
CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.0-rc3-next-20130529+ #15
[<c00667f8>] (tick_broadcast_oneshot_control+0x1a4/0x1d0) from [<c0065cd0>] (tick_notify+0x240/0x40c)
[<c0065cd0>] (tick_notify+0x240/0x40c) from [<c0044724>] (notifier_call_chain+0x44/0x84)
[<c0044724>] (notifier_call_chain+0x44/0x84) from [<c0044828>] (raw_notifier_call_chain+0x18/0x20)
[<c0044828>] (raw_notifier_call_chain+0x18/0x20) from [<c00650cc>] (clockevents_notify+0x28/0x170)
[<c00650cc>] (clockevents_notify+0x28/0x170) from [<c033f1f0>] (cpuidle_idle_call+0x11c/0x168)
[<c033f1f0>] (cpuidle_idle_call+0x11c/0x168) from [<c000ea94>] (arch_cpu_idle+0x8/0x38)
[<c000ea94>] (arch_cpu_idle+0x8/0x38) from [<c005ea80>] (cpu_startup_entry+0x60/0x134)
[<c005ea80>] (cpu_startup_entry+0x60/0x134) from [<804fe9a4>] (0x804fe9a4)
I don't have the hardware, so I wasn't able to reproduce the warning
but after looking a while at the code, I deduced the following:
1. the CPU2 enters a deep idle state and sets the broadcast timer
2. the timer expires, the tick_handle_oneshot_broadcast function is
called, setting the tick_broadcast_pending_mask and waking up the
idle cpu CPU2
3. the CPU2 exits idle handles the interrupt and then invokes
tick_broadcast_oneshot_control with CLOCK_EVENT_NOTIFY_EXIT which
runs the following code:
if (dev->next_event.tv64 == KTIME_MAX)
goto out;
if (cpumask_test_and_clear_cpu(cpu,
tick_broadcast_pending_mask))
goto out;
So if there is no next event scheduled for CPU2, we fulfil the
first condition and jump out without clearing the
tick_broadcast_pending_mask.
4. CPU2 goes to deep idle again and calls
tick_broadcast_oneshot_control with CLOCK_NOTIFY_EVENT_ENTER but
with the tick_broadcast_pending_mask set for CPU2, triggering the
warning.
The issue only surfaced due to the modifications of the cpuidle
framework, which resulted in interrupts being enabled before the call
to the clockevents code. If the call happens before interrupts have
been enabled, the warning cannot trigger, because there is still the
event pending which caused the broadcast timer expiry.
Move the check for the next event below the check for the pending bit,
so the pending bit gets cleared whether an event is scheduled on the
cpu or not.
[ tglx: Massaged changelog ]
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
Reported-and-tested-by: Joseph Lo <josephl@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: linaro-kernel@lists.linaro.org
Link: http://lkml.kernel.org/r/1371485735-31249-1-git-send-email-daniel.lezcano@linaro.org
Since 7300711e ("clockevents: broadcast fixup possible waiters"),
the timekeeping duty is assigned to the CPU that handles the tick
broadcast clock device by the time it is set in one shot mode.
This is an issue in full dynticks mode where the timekeeping duty
must stay handled by the boot CPU for now. Otherwise it prevents
secondary CPUs from offlining and this breaks
suspend/shutdown/reboot/...
As it appears there is no reason for this timekeeping duty to be
moved to the broadcast CPU, besides nothing prevent it from being
later re-assigned to another target, let's simply remove it.
Signed-off-by: Jiri Bohac <jbohac@suse.cz>
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
In tick_nohz_cpu_down_callback() if the cpu is the one handling
timekeeping, we must return something that stops the CPU_DOWN_PREPARE
notifiers and then start notify CPU_DOWN_FAILED on the already called
notifier call backs.
However traditional errno values are not handled by the notifier unless
these are encapsulated using errno_to_notifier().
Hence the current -EINVAL is misinterpreted and converted to junk after
notifier_to_errno(), leaving the notifier subsystem to random behaviour
such as eventually allowing the cpu to go down.
Fix this by using the standard NOTIFY_BAD instead.
Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
