thread.
Second argument is similar to PR_SET_TIMERSLACK, if non-zero then the
slack is set to that value otherwise sets it to the default for the thread.
Takes PID of the thread as the third argument.
This allows power/performance management software to set timer slack for
other threads according to its policy for the thread (such as when the
thread is designated foreground vs. background activity)
Change-Id: I744d451ff4e60dae69f38f53948ff36c51c14a3f
Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
Disable PR_SET_VMA when building with !MMU
Change-Id: I896b6979b99aa61df85caf4c3ec22eb8a8204e64
Signed-off-by: Colin Cross <ccross@android.com>
Fix two bugs caused by merging anon vma_naming, a typo in
mempolicy.c and a bad merge in sys.c.
Change-Id: Ia4ced447d50573e68195e95ea2f2b4d9456b8a90
Userspace processes often have multiple allocators that each do
anonymous mmaps to get memory. When examining memory usage of
individual processes or systems as a whole, it is useful to be
able to break down the various heaps that were allocated by
each layer and examine their size, RSS, and physical memory
usage.
This patch adds a user pointer to the shared union in
vm_area_struct that points to a null terminated string inside
the user process containing a name for the vma. vmas that
point to the same address will be merged, but vmas that
point to equivalent strings at different addresses will
not be merged.
Userspace can set the name for a region of memory by calling
prctl(PR_SET_VMA, PR_SET_VMA_ANON_NAME, start, len, (unsigned long)name);
Setting the name to NULL clears it.
The names of named anonymous vmas are shown in /proc/pid/maps
as [anon:<name>] and in /proc/pid/smaps in a new "Name" field
that is only present for named vmas. If the userspace pointer
is no longer valid all or part of the name will be replaced
with "<fault>".
The idea to store a userspace pointer to reduce the complexity
within mm (at the expense of the complexity of reading
/proc/pid/mem) came from Dave Hansen. This results in no
runtime overhead in the mm subsystem other than comparing
the anon_name pointers when considering vma merging. The pointer
is stored in a union with fieds that are only used on file-backed
mappings, so it does not increase memory usage.
Change-Id: Ie2ffc0967d4ffe7ee4c70781313c7b00cf7e3092
We recently noticed that reboot of a 1024 cpu machine takes approx 16
minutes of just stopping the cpus. The slowdown was tracked to commit
f96972f2dc63 ("kernel/sys.c: call disable_nonboot_cpus() in
kernel_restart()").
The current implementation does all the work of hot removing the cpus
before halting the system. We are switching to just migrating to the
boot cpu and then continuing with shutdown/reboot.
This also has the effect of not breaking x86's command line parameter
for specifying the reboot cpu. Note, this code was shamelessly copied
from arch/x86/kernel/reboot.c with bits removed pertaining to the
reboot_cpu command line parameter.
Signed-off-by: Robin Holt <holt@sgi.com>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Cc: "Srivatsa S. Bhat" <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Robin Holt <holt@sgi.com>
Cc: Guan Xuetao <gxt@mprc.pku.edu.cn>
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
The purpose of this patch is to allow privileged processes to set
their own per-memory memory-region fields:
start_code, end_code, start_data, end_data, start_brk, brk,
start_stack, arg_start, arg_end, env_start, env_end.
This functionality is needed by any application or package that needs to
reconstruct Linux processes, that is, to start them in any way other than
by means of an "execve()" from an executable file. This includes:
1. Restoring processes from a checkpoint-file (by all potential
user-level checkpointing packages, not only CRIU's).
2. Restarting processes on another node after process migration.
3. Starting duplicated copies of a running process (for reliability
and high-availablity).
4. Starting a process from an executable format that is not supported
by Linux, thus requiring a "manual execve" by a user-level utility.
5. Similarly, starting a process from a networked and/or crypted
executable that, for confidentiality, licensing or other reasons,
may not be written to the local file-systems.
The code that does that was already included in the Linux kernel by the
CRIU group, in the form of "prctl(PR_SET_MM)", but prior to this was
enclosed within their private "#ifdef CONFIG_CHECKPOINT_RESTORE", which is
normally disabled. The patch removes those ifdefs.
Signed-off-by: Amnon Shiloh <u3557@miso.sublimeip.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Andrew Morton noted:
akpm3:/usr/src/25> grep SYSCALL kernel/timer.c
SYSCALL_DEFINE1(alarm, unsigned int, seconds)
SYSCALL_DEFINE0(getpid)
SYSCALL_DEFINE0(getppid)
SYSCALL_DEFINE0(getuid)
SYSCALL_DEFINE0(geteuid)
SYSCALL_DEFINE0(getgid)
SYSCALL_DEFINE0(getegid)
SYSCALL_DEFINE0(gettid)
SYSCALL_DEFINE1(sysinfo, struct sysinfo __user *, info)
COMPAT_SYSCALL_DEFINE1(sysinfo, struct compat_sysinfo __user *, info)
Only one of those should be in kernel/timer.c. Who wrote this thing?
As commit 40dc166c (PM / Core: Introduce struct syscore_ops for core
subsystems PM) say, syscore_ops operations should be carried with one
CPU on-line and interrupts disabled. However, after commit f96972f2d
(kernel/sys.c: call disable_nonboot_cpus() in kernel_restart()),
syscore_shutdown() is called before disable_nonboot_cpus(), so break
the rules. We have a MIPS machine with a 8259A PIC, and there is an
external timer (HPET) linked at 8259A. Since 8259A has been shutdown
too early (by syscore_shutdown()), disable_nonboot_cpus() runs without
timer interrupt, so it hangs and reboot fails. This patch call
syscore_shutdown() a little later (after disable_nonboot_cpus()) to
avoid reboot failure, this is the same way as poweroff does.
For consistency, add disable_nonboot_cpus() to kernel_halt().
Signed-off-by: Huacai Chen <chenhc@lemote.com>
David said:
Commit 6c0c0d4d1080 ("poweroff: fix bug in orderly_poweroff()")
apparently fixes one bug in orderly_poweroff(), but introduces
another. The comments on orderly_poweroff() claim it can be called
from any context - and indeed we call it from interrupt context in
arch/powerpc/platforms/pseries/ras.c for example. But since that
commit this is no longer safe, since call_usermodehelper_fns() is not
safe in interrupt context without the UMH_NO_WAIT option.
orderly_poweroff() can be used from any context but UMH_WAIT_EXEC is
sleepable. Move the "force" logic into __orderly_poweroff() and change
orderly_poweroff() to use the global poweroff_work which simply calls
__orderly_poweroff().
While at it, remove the unneeded "int argc" and change argv_split() to
use GFP_KERNEL.
We use the global "bool poweroff_force" to pass the argument, this can
obviously affect the previous request if it is pending/running. So we
only allow the "false => true" transition assuming that the pending
"true" should succeed anyway. If schedule_work() fails after that we
know that work->func() was not called yet, it must see the new value.
This means that orderly_poweroff() becomes async even if we do not run
the command and always succeeds, schedule_work() can only fail if the
work is already pending. We can export __orderly_poweroff() and change
the non-atomic callers which want the old semantics.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Reported-by: David Gibson <david@gibson.dropbear.id.au>
Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: Feng Hong <hongfeng@marvell.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
__orderly_poweroff() does argv_free() if call_usermodehelper_fns()
returns -ENOMEM. As Lucas pointed out, this can be wrong if -ENOMEM was
not triggered by the failing call_usermodehelper_setup(), in this case
both __orderly_poweroff() and argv_cleanup() can do kfree().
Kill argv_cleanup() and change __orderly_poweroff() to call argv_free()
unconditionally like do_coredump() does. This info->cleanup() is not
needed (and wrong) since 6c0c0d4d "fix bug in orderly_poweroff() which
did the UMH_NO_WAIT => UMH_WAIT_EXEC change, we can rely on the fact
that CLONE_VFORK can't return until do_execve() succeeds/fails.
Reported-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
Cc: James Morris <james.l.morris@oracle.com>
Cc: hongfeng <hongfeng@marvell.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace and namespace infrastructure changes from Eric W Biederman:
"This set of changes starts with a few small enhnacements to the user
namespace. reboot support, allowing more arbitrary mappings, and
support for mounting devpts, ramfs, tmpfs, and mqueuefs as just the
user namespace root.
I do my best to document that if you care about limiting your
unprivileged users that when you have the user namespace support
enabled you will need to enable memory control groups.
There is a minor bug fix to prevent overflowing the stack if someone
creates way too many user namespaces.
The bulk of the changes are a continuation of the kuid/kgid push down
work through the filesystems. These changes make using uids and gids
typesafe which ensures that these filesystems are safe to use when
multiple user namespaces are in use. The filesystems converted for
3.9 are ceph, 9p, afs, ocfs2, gfs2, ncpfs, nfs, nfsd, and cifs. The
changes for these filesystems were a little more involved so I split
the changes into smaller hopefully obviously correct changes.
XFS is the only filesystem that remains. I was hoping I could get
that in this release so that user namespace support would be enabled
with an allyesconfig or an allmodconfig but it looks like the xfs
changes need another couple of days before it they are ready."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (93 commits)
cifs: Enable building with user namespaces enabled.
cifs: Convert struct cifs_ses to use a kuid_t and a kgid_t
cifs: Convert struct cifs_sb_info to use kuids and kgids
cifs: Modify struct smb_vol to use kuids and kgids
cifs: Convert struct cifsFileInfo to use a kuid
cifs: Convert struct cifs_fattr to use kuid and kgids
cifs: Convert struct tcon_link to use a kuid.
cifs: Modify struct cifs_unix_set_info_args to hold a kuid_t and a kgid_t
cifs: Convert from a kuid before printing current_fsuid
cifs: Use kuids and kgids SID to uid/gid mapping
cifs: Pass GLOBAL_ROOT_UID and GLOBAL_ROOT_GID to keyring_alloc
cifs: Use BUILD_BUG_ON to validate uids and gids are the same size
cifs: Override unmappable incoming uids and gids
nfsd: Enable building with user namespaces enabled.
nfsd: Properly compare and initialize kuids and kgids
nfsd: Store ex_anon_uid and ex_anon_gid as kuids and kgids
nfsd: Modify nfsd4_cb_sec to use kuids and kgids
nfsd: Handle kuids and kgids in the nfs4acl to posix_acl conversion
nfsd: Convert nfsxdr to use kuids and kgids
nfsd: Convert nfs3xdr to use kuids and kgids
Remove a tabstop from the switch statement, in the usual fashion. A few
instances of weirdwrapping were removed as a result.
Cc: Chen Gang <gang.chen@asianux.com>
arg2 will never < 0, for its type is 'unsigned long'
Also, use the provided macros.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Reported-by: Cyrill Gorcunov <gorcunov@openvz.org>
In a container with its own pid namespace and user namespace, rebooting
the system won't reboot the host, but terminate all the processes in
it and thus have the container shutdown, so it's safe.
Signed-off-by: Li Zefan <lizefan@huawei.com>
We have thread_group_cputime() and thread_group_times(). The naming
doesn't provide enough information about the difference between
these two APIs.
To lower the confusion, rename thread_group_times() to
thread_group_cputime_adjusted(). This name better suggests that
it's a version of thread_group_cputime() that does some stabilization
on the raw cputime values. ie here: scale on top of CFS runtime
stats and bound lower value for monotonicity.
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
The min/max call needed to have explicit types on some architectures
(e.g. mn10300). Use clamp_t instead to avoid the warning:
kernel/sys.c: In function 'override_release':
kernel/sys.c:1287:10: warning: comparison of distinct pointer types lacks a cast [enabled by default]
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Calling uname() with the UNAME26 personality set allows a leak of kernel
stack contents. This fixes it by defensively calculating the length of
copy_to_user() call, making the len argument unsigned, and initializing
the stack buffer to zero (now technically unneeded, but hey, overkill).
CVE-2012-0957
Reported-by: PaX Team <pageexec@freemail.hu>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Brad Spengler <spender@grsecurity.net>
orderly_poweroff is trying to poweroff platform in two steps:
step 1: Call user space application to poweroff
step 2: If user space poweroff fail, then do a force power off if force param
is set.
The bug here is, step 1 is always successful with param UMH_NO_WAIT, which obey
the design goal of orderly_poweroff.
We have two choices here:
UMH_WAIT_EXEC which means wait for the exec, but not the process;
UMH_WAIT_PROC which means wait for the process to complete.
we need to trade off the two choices:
If using UMH_WAIT_EXEC, there is potential issue comments by Serge E.
Hallyn: The exec will have started, but may for whatever (very unlikely)
reason fail.
If using UMH_WAIT_PROC, there is potential issue comments by Eric W.
Biederman: If the caller is not running in a kernel thread then we can
easily get into a case where the user space caller will block waiting for
us when we are waiting for the user space caller.
Thanks for their excellent ideas, based on the above discussion, we
finally choose UMH_WAIT_EXEC, which is much more safe, if the user
application really fails, we just complain the application itself, it
seems a better choice here.
Signed-off-by: Feng Hong <hongfeng@marvell.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
As kernel_power_off() calls disable_nonboot_cpus(), we may also want to
have kernel_restart() call disable_nonboot_cpus(). Doing so can help
machines that require boot cpu be the last alive cpu during reboot to
survive with kernel restart.
This fixes one reboot issue seen on imx6q (Cortex-A9 Quad). The machine
requires that the restart routine be run on the primary cpu rather than
secondary ones. Otherwise, the secondary core running the restart
routine will fail to come to online after reboot.
If argv_split() failed, the code will end up calling argv_free(NULL). Fix
it up and clean things up a bit.
Addresses Coverity report 703573.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
Just setting the "error" to error number is enough on failure and It
doesn't require to set "error" variable to zero in each switch case,
since it was already initialized with zero. And also removed return 0
in switch case with break statement
Signed-off-by: Sasikantha babu <sasikanth.v19@gmail.com>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
"no other files mapped" requirement from my previous patch (c/r: prctl:
update prctl_set_mm_exe_file() after mm->num_exe_file_vmas removal) is too
paranoid, it forbids operation even if there mapped one shared-anon vma.
Let's check that current mm->exe_file already unmapped, in this case
exe_file symlink already outdated and its changing is reasonable.
Plus, this patch fixes exit code in case operation success.
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Tested-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Tejun Heo <tj@kernel.org>
During merging of PR_GET_TID_ADDRESS patch the code has been misplaced (it
happened to appear under PR_MCE_KILL) in result noone can use this option.
Fix it by moving code snippet to a proper place.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Andrey Vagin <avagin@openvz.org>
In commit b76437579d13 ("procfs: mark thread stack correctly in
proc/<pid>/maps") the stack allocated via clone() is marked in
/proc/<pid>/maps as [stack:%d] thus it might be out of the former
mm->start_stack/end_stack values (and even has some custom VMA flags
set).
So to be able to restore mm->start_stack/end_stack drop vma flags test,
but still require the underlying VMA to exist.
As always note this feature is under CONFIG_CHECKPOINT_RESTORE and
requires CAP_SYS_RESOURCE to be granted.
Zero is written at clear_tid_address when the process exits. This
functionality is used by pthread_join().
We already have sys_set_tid_address() to change this address for the
current task but there is no way to obtain it from user space.
Without the ability to find this address and dump it we can't restore
pthread'ed apps which call pthread_join() once they have been restored.
This patch introduces the PR_GET_TID_ADDRESS prctl option which allows
the current process to obtain own clear_tid_address.
This feature is available iif CONFIG_CHECKPOINT_RESTORE is set.
[akpm@linux-foundation.org: fix prctl numbering]
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Cc: Pedro Alves <palves@redhat.com>
Make sure the address being set is greater than mmap_min_addr (as
suggested by Kees Cook).
A fix for commit b32dfe377102 ("c/r: prctl: add ability to set new
mm_struct::exe_file").
After removing mm->num_exe_file_vmas kernel keeps mm->exe_file until
final mmput(), it never becomes NULL while task is alive.
We can check for other mapped files in mm instead of checking
mm->num_exe_file_vmas, and mark mm with flag MMF_EXE_FILE_CHANGED in
order to forbid second changing of mm->exe_file.
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
When we do restore we would like to have a way to setup a former
mm_struct::exe_file so that /proc/pid/exe would point to the original
executable file a process had at checkpoint time.
For this the PR_SET_MM_EXE_FILE code is introduced. This option takes a
file descriptor which will be set as a source for new /proc/$pid/exe
symlink.
Note it allows to change /proc/$pid/exe if there are no VM_EXECUTABLE
vmas present for current process, simply because this feature is a special
to C/R and mm::num_exe_file_vmas become meaningless after that.
To minimize the amount of transition the /proc/pid/exe symlink might have,
this feature is implemented in one-shot manner. Thus once changed the
symlink can't be changed again. This should help sysadmins to monitor the
symlinks over all process running in a system.
In particular one could make a snapshot of processes and ring alarm if
there unexpected changes of /proc/pid/exe's in a system.
Note -- this feature is available iif CONFIG_CHECKPOINT_RESTORE is set and
the caller must have CAP_SYS_RESOURCE capability granted, otherwise the
request to change symlink will be rejected.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
During checkpoint we dump whole process memory to a file and the dump
includes process stack memory. But among stack data itself, the stack
carries additional parameters such as command line arguments, environment
data and auxiliary vector.
So when we do restore procedure and once we've restored stack data itself
we need to setup mm_struct::arg_start/end, env_start/end, so restored
process would be able to find command line arguments and environment data
it had at checkpoint time. The same applies to auxiliary vector.
For this reason additional PR_SET_MM_(ARG_START | ARG_END | ENV_START |
ENV_END | AUXV) codes are introduced.
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Vasiliy Kulikov <segoon@openwall.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Both kernel/sys.c && security/keys/request_key.c where inlining the exact
same code as call_usermodehelper_fns(); So simply convert these sites to
directly use call_usermodehelper_fns().
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
uts_kern_table
sethostname() and setdomainname() notify userspace on failure (without
modifying uts_kern_table). Change things so that we only notify userspace
on success, when uts_kern_table was actually modified.
Cc: WANG Cong <amwang@redhat.com>
Pull user namespace enhancements from Eric Biederman:
"This is a course correction for the user namespace, so that we can
reach an inexpensive, maintainable, and reasonably complete
implementation.
Highlights:
- Config guards make it impossible to enable the user namespace and
code that has not been converted to be user namespace safe.
- Use of the new kuid_t type ensures the if you somehow get past the
config guards the kernel will encounter type errors if you enable
user namespaces and attempt to compile in code whose permission
checks have not been updated to be user namespace safe.
- All uids from child user namespaces are mapped into the initial
user namespace before they are processed. Removing the need to add
an additional check to see if the user namespace of the compared
uids remains the same.
- With the user namespaces compiled out the performance is as good or
better than it is today.
- For most operations absolutely nothing changes performance or
operationally with the user namespace enabled.
- The worst case performance I could come up with was timing 1
billion cache cold stat operations with the user namespace code
enabled. This went from 156s to 164s on my laptop (or 156ns to
164ns per stat operation).
- (uid_t)-1 and (gid_t)-1 are reserved as an internal error value.
Most uid/gid setting system calls treat these value specially
anyway so attempting to use -1 as a uid would likely cause
entertaining failures in userspace.
- If setuid is called with a uid that can not be mapped setuid fails.
I have looked at sendmail, login, ssh and every other program I
could think of that would call setuid and they all check for and
handle the case where setuid fails.
- If stat or a similar system call is called from a context in which
we can not map a uid we lie and return overflowuid. The LFS
experience suggests not lying and returning an error code might be
better, but the historical precedent with uids is different and I
can not think of anything that would break by lying about a uid we
can't map.
- Capabilities are localized to the current user namespace making it
safe to give the initial user in a user namespace all capabilities.
My git tree covers all of the modifications needed to convert the core
kernel and enough changes to make a system bootable to runlevel 1."
Fix up trivial conflicts due to nearby independent changes in fs/stat.c
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (46 commits)
userns: Silence silly gcc warning.
cred: use correct cred accessor with regards to rcu read lock
userns: Convert the move_pages, and migrate_pages permission checks to use uid_eq
userns: Convert cgroup permission checks to use uid_eq
userns: Convert tmpfs to use kuid and kgid where appropriate
userns: Convert sysfs to use kgid/kuid where appropriate
userns: Convert sysctl permission checks to use kuid and kgids.
userns: Convert proc to use kuid/kgid where appropriate
userns: Convert ext4 to user kuid/kgid where appropriate
userns: Convert ext3 to use kuid/kgid where appropriate
userns: Convert ext2 to use kuid/kgid where appropriate.
userns: Convert devpts to use kuid/kgid where appropriate
userns: Convert binary formats to use kuid/kgid where appropriate
userns: Add negative depends on entries to avoid building code that is userns unsafe
userns: signal remove unnecessary map_cred_ns
userns: Teach inode_capable to understand inodes whose uids map to other namespaces.
userns: Fail exec for suid and sgid binaries with ids outside our user namespace.
userns: Convert stat to return values mapped from kuids and kgids
userns: Convert user specfied uids and gids in chown into kuids and kgid
userns: Use uid_eq gid_eq helpers when comparing kuids and kgids in the vfs
kuids and kgids
Update the permission checks to use the new uid_eq and gid_eq helpers
and remove the now unnecessary user_ns equality comparison.
kgid
Convert setregid, setgid, setreuid, setuid,
setresuid, getresuid, setresgid, getresgid, setfsuid, setfsgid,
getuid, geteuid, getgid, getegid,
waitpid, waitid, wait4.
Convert userspace uids and gids into kuids and kgids before
being placed on struct cred. Convert struct cred kuids and
kgids into userspace uids and gids when returning them.
cred.h and a few trivial users of struct cred are changed. The rest of the users
of struct cred are left for other patches as there are too many changes to make
in one go and leave the change reviewable. If the user namespace is disabled and
CONFIG_UIDGID_STRICT_TYPE_CHECKS are disabled the code will contiue to compile
and behave correctly.
[This patch depends on luto@mit.edu's no_new_privs patch:
https://lkml.org/lkml/2012/1/30/264
The whole series including Andrew's patches can be found here:
https://github.com/redpig/linux/tree/seccomp
Complete diff here:
https://github.com/redpig/linux/compare/1dc65fed...seccomp
This patch adds support for seccomp mode 2. Mode 2 introduces the
ability for unprivileged processes to install system call filtering
policy expressed in terms of a Berkeley Packet Filter (BPF) program.
This program will be evaluated in the kernel for each system call
the task makes and computes a result based on data in the format
of struct seccomp_data.
A filter program may be installed by calling:
struct sock_fprog fprog = { ... };
prctl(PR_SET_SECCOMP, SECCOMP_MODE_FILTER, &fprog);
The return value of the filter program determines if the system call is
allowed to proceed or denied. If the first filter program installed
allows prctl(2) calls, then the above call may be made repeatedly
by a task to further reduce its access to the kernel. All attached
programs must be evaluated before a system call will be allowed to
proceed.
Filter programs will be inherited across fork/clone and execve.
However, if the task attaching the filter is unprivileged
(!CAP_SYS_ADMIN) the no_new_privs bit will be set on the task. This
ensures that unprivileged tasks cannot attach filters that affect
privileged tasks (e.g., setuid binary).
There are a number of benefits to this approach. A few of which are
as follows:
- BPF has been exposed to userland for a long time
- BPF optimization (and JIT'ing) are well understood
- Userland already knows its ABI: system call numbers and desired
arguments
- No time-of-check-time-of-use vulnerable data accesses are possible.
- system call arguments are loaded on access only to minimize copying
required for system call policy decisions.
Mode 2 support is restricted to architectures that enable
HAVE_ARCH_SECCOMP_FILTER. In this patch, the primary dependency is on
syscall_get_arguments(). The full desired scope of this feature will
add a few minor additional requirements expressed later in this series.
Based on discussion, SECCOMP_RET_ERRNO and SECCOMP_RET_TRACE seem to be
the desired additional functionality.
No architectures are enabled in this patch.
Signed-off-by: Will Drewry <wad@chromium.org>
Reviewed-by: Indan Zupancic <indan@nul.nu>
Acked-by: Eric Paris <eparis@redhat.com>
v18: - rebase to v3.4-rc2
- s/chk/check/ (akpm@linux-foundation.org,jmorris@namei.org)
- allocate with GFP_KERNEL|__GFP_NOWARN (indan@nul.nu)
- add a comment for get_u32 regarding endianness (akpm@)
- fix other typos, style mistakes (akpm@)
- added acked-by
v17: - properly guard seccomp filter needed headers (leann@ubuntu.com)
- tighten return mask to 0x7fff0000
v16: - no change
v15: - add a 4 instr penalty when counting a path to account for seccomp_filter
size (indan@nul.nu)
- drop the max insns to 256KB (indan@nul.nu)
- return ENOMEM if the max insns limit has been hit (indan@nul.nu)
- move IP checks after args (indan@nul.nu)
- drop !user_filter check (indan@nul.nu)
- only allow explicit bpf codes (indan@nul.nu)
- exit_code -> exit_sig
v14: - put/get_seccomp_filter takes struct task_struct
(indan@nul.nu,keescook@chromium.org)
- adds seccomp_chk_filter and drops general bpf_run/chk_filter user
- add seccomp_bpf_load for use by net/core/filter.c
- lower max per-process/per-hierarchy: 1MB
- moved nnp/capability check prior to allocation
(all of the above: indan@nul.nu)
v13: - rebase on to 88ebdda6159ffc15699f204c33feb3e431bf9bdc
v12: - added a maximum instruction count per path (indan@nul.nu,oleg@redhat.com)
- removed copy_seccomp (keescook@chromium.org,indan@nul.nu)
- reworded the prctl_set_seccomp comment (indan@nul.nu)
v11: - reorder struct seccomp_data to allow future args expansion (hpa@zytor.com)
- style clean up, @compat dropped, compat_sock_fprog32 (indan@nul.nu)
- do_exit(SIGSYS) (keescook@chromium.org, luto@mit.edu)
- pare down Kconfig doc reference.
- extra comment clean up
v10: - seccomp_data has changed again to be more aesthetically pleasing
(hpa@zytor.com)
- calling convention is noted in a new u32 field using syscall_get_arch.
This allows for cross-calling convention tasks to use seccomp filters.
(hpa@zytor.com)
- lots of clean up (thanks, Indan!)
v9: - n/a
v8: - use bpf_chk_filter, bpf_run_filter. update load_fns
- Lots of fixes courtesy of indan@nul.nu:
-- fix up load behavior, compat fixups, and merge alloc code,
-- renamed pc and dropped __packed, use bool compat.
-- Added a hidden CONFIG_SECCOMP_FILTER to synthesize non-arch
dependencies
v7: (massive overhaul thanks to Indan, others)
- added CONFIG_HAVE_ARCH_SECCOMP_FILTER
- merged into seccomp.c
- minimal seccomp_filter.h
- no config option (part of seccomp)
- no new prctl
- doesn't break seccomp on systems without asm/syscall.h
(works but arg access always fails)
- dropped seccomp_init_task, extra free functions, ...
- dropped the no-asm/syscall.h code paths
- merges with network sk_run_filter and sk_chk_filter
v6: - fix memory leak on attach compat check failure
- require no_new_privs || CAP_SYS_ADMIN prior to filter
installation. (luto@mit.edu)
- s/seccomp_struct_/seccomp_/ for macros/functions (amwang@redhat.com)
- cleaned up Kconfig (amwang@redhat.com)
- on block, note if the call was compat (so the # means something)
v5: - uses syscall_get_arguments
(indan@nul.nu,oleg@redhat.com, mcgrathr@chromium.org)
- uses union-based arg storage with hi/lo struct to
handle endianness. Compromises between the two alternate
proposals to minimize extra arg shuffling and account for
endianness assuming userspace uses offsetof().
(mcgrathr@chromium.org, indan@nul.nu)
- update Kconfig description
- add include/seccomp_filter.h and add its installation
- (naive) on-demand syscall argument loading
- drop seccomp_t (eparis@redhat.com)
v4: - adjusted prctl to make room for PR_[SG]ET_NO_NEW_PRIVS
- now uses current->no_new_privs
(luto@mit.edu,torvalds@linux-foundation.com)
- assign names to seccomp modes (rdunlap@xenotime.net)
- fix style issues (rdunlap@xenotime.net)
- reworded Kconfig entry (rdunlap@xenotime.net)
v3: - macros to inline (oleg@redhat.com)
- init_task behavior fixed (oleg@redhat.com)
- drop creator entry and extra NULL check (oleg@redhat.com)
- alloc returns -EINVAL on bad sizing (serge.hallyn@canonical.com)
- adds tentative use of "always_unprivileged" as per
torvalds@linux-foundation.org and luto@mit.edu
v2: - (patch 2 only)
Signed-off-by: James Morris <james.l.morris@oracle.com>
With this change, calling
prctl(PR_SET_NO_NEW_PRIVS, 1, 0, 0, 0)
disables privilege granting operations at execve-time. For example, a
process will not be able to execute a setuid binary to change their uid
or gid if this bit is set. The same is true for file capabilities.
Additionally, LSM_UNSAFE_NO_NEW_PRIVS is defined to ensure that
LSMs respect the requested behavior.
To determine if the NO_NEW_PRIVS bit is set, a task may call
prctl(PR_GET_NO_NEW_PRIVS, 0, 0, 0, 0);
It returns 1 if set and 0 if it is not set. If any of the arguments are
non-zero, it will return -1 and set errno to -EINVAL.
(PR_SET_NO_NEW_PRIVS behaves similarly.)
This functionality is desired for the proposed seccomp filter patch
series. By using PR_SET_NO_NEW_PRIVS, it allows a task to modify the
system call behavior for itself and its child tasks without being
able to impact the behavior of a more privileged task.
Another potential use is making certain privileged operations
unprivileged. For example, chroot may be considered "safe" if it cannot
affect privileged tasks.
Note, this patch causes execve to fail when PR_SET_NO_NEW_PRIVS is
set and AppArmor is in use. It is fixed in a subsequent patch.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
v18: updated change desc
v17: using new define values as per 3.4
Modify alloc_uid to take a kuid and make the user hash table global.
Stop holding a reference to the user namespace in struct user_struct.
This simplifies the code and makes the per user accounting not
care about which user namespace a uid happens to appear in.
Start distinguishing between internal kernel uids and gids and
values that userspace can use. This is done by introducing two
new types: kuid_t and kgid_t. These types and their associated
functions are infrastructure are declared in the new header
uidgid.h.
Ultimately there will be a different implementation of the mapping
functions for use with user namespaces. But to keep it simple
we introduce the mapping functions first to separate the meat
from the mechanical code conversions.
Export overflowuid and overflowgid so we can use from_kuid_munged
and from_kgid_munged in modular code.
Optimize performance and prepare for the removal of the user_ns reference
from user_struct. Remove the slow long walk through cred->user->user_ns and
instead go straight to cred->user_ns.
In struct cred the user member is and has always been declared struct user_struct *user.
At most a constant struct cred will have a constant pointer to non-constant user_struct
so remove this unnecessary cast.
In the case of a child pid namespace, rebooting the system does not really
makes sense. When the pid namespace is used in conjunction with the other
namespaces in order to create a linux container, the reboot syscall leads
to some problems.
A container can reboot the host. That can be fixed by dropping the
sys_reboot capability but we are unable to correctly to poweroff/
halt/reboot a container and the container stays stuck at the shutdown time
with the container's init process waiting indefinitively.
After several attempts, no solution from userspace was found to reliabily
handle the shutdown from a container.
This patch propose to make the init process of the child pid namespace to
exit with a signal status set to : SIGINT if the child pid namespace
called "halt/poweroff" and SIGHUP if the child pid namespace called
"reboot". When the reboot syscall is called and we are not in the initial
pid namespace, we kill the pid namespace for "HALT", "POWEROFF",
"RESTART", and "RESTART2". Otherwise we return EINVAL.
Returning EINVAL is also an easy way to check if this feature is supported
by the kernel when invoking another 'reboot' option like CAD.
By this way the parent process of the child pid namespace knows if it
rebooted or not and can take the right decision.
Test case:
#include <alloca.h>
#include <stdio.h>
#include <sched.h>
#include <unistd.h>
#include <signal.h>
#include <sys/reboot.h>
#include <sys/types.h>
#include <sys/wait.h>
#include <linux/reboot.h>
static int do_reboot(void *arg)
int *cmd = arg;
if (reboot(*cmd))
printf("failed to reboot(%d): %m\n", *cmd);
int test_reboot(int cmd, int sig)
long stack_size = 4096;
void *stack = alloca(stack_size) + stack_size;
int status;
pid_t ret;
ret = clone(do_reboot, stack, CLONE_NEWPID | SIGCHLD, &cmd);
if (ret < 0) {
printf("failed to clone: %m\n");
return -1;
if (wait(&status) < 0) {
printf("unexpected wait error: %m\n");
return -1;
if (!WIFSIGNALED(status)) {
printf("child process exited but was not signaled\n");
return -1;
if (WTERMSIG(status) != sig) {
printf("signal termination is not the one expected\n");
return -1;
return 0;
int main(int argc, char *argv[])
int status;
status = test_reboot(LINUX_REBOOT_CMD_RESTART, SIGHUP);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_RESTART) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_RESTART2, SIGHUP);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_RESTART2) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_HALT, SIGINT);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_HALT) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_POWER_OFF, SIGINT);
if (status < 0)
return 1;
printf("reboot(LINUX_REBOOT_CMD_POWERR_OFF) succeed\n");
status = test_reboot(LINUX_REBOOT_CMD_CAD_ON, -1);
if (status >= 0) {
printf("reboot(LINUX_REBOOT_CMD_CAD_ON) should have failed\n");
return 1;
printf("reboot(LINUX_REBOOT_CMD_CAD_ON) has failed as expected\n");
return 0;
[akpm@linux-foundation.org: tweak and add comments]
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr>
Tested-by: Serge Hallyn <serge.hallyn@canonical.com>
Userspace service managers/supervisors need to track their started
services. Many services daemonize by double-forking and get implicitly
re-parented to PID 1. The service manager will no longer be able to
receive the SIGCHLD signals for them, and is no longer in charge of
reaping the children with wait(). All information about the children is
lost at the moment PID 1 cleans up the re-parented processes.
With this prctl, a service manager process can mark itself as a sort of
'sub-init', able to stay as the parent for all orphaned processes
created by the started services. All SIGCHLD signals will be delivered
to the service manager.
Receiving SIGCHLD and doing wait() is in cases of a service-manager much
preferred over any possible asynchronous notification about specific
PIDs, because the service manager has full access to the child process
data in /proc and the PID can not be re-used until the wait(), the
service-manager itself is in charge of, has happened.
As a side effect, the relevant parent PID information does not get lost
by a double-fork, which results in a more elaborate process tree and
'ps' output:
before:
# ps afx
253 ? Ss 0:00 /bin/dbus-daemon --system --nofork
294 ? Sl 0:00 /usr/libexec/polkit-1/polkitd
328 ? S 0:00 /usr/sbin/modem-manager
608 ? Sl 0:00 /usr/libexec/colord
658 ? Sl 0:00 /usr/libexec/upowerd
819 ? Sl 0:00 /usr/libexec/imsettings-daemon
916 ? Sl 0:00 /usr/libexec/udisks-daemon
917 ? S 0:00 \_ udisks-daemon: not polling any devices
after:
# ps afx
294 ? Ss 0:00 /bin/dbus-daemon --system --nofork
426 ? Sl 0:00 \_ /usr/libexec/polkit-1/polkitd
449 ? S 0:00 \_ /usr/sbin/modem-manager
635 ? Sl 0:00 \_ /usr/libexec/colord
705 ? Sl 0:00 \_ /usr/libexec/upowerd
959 ? Sl 0:00 \_ /usr/libexec/udisks-daemon
960 ? S 0:00 | \_ udisks-daemon: not polling any devices
977 ? Sl 0:00 \_ /usr/libexec/packagekitd
This prctl is orthogonal to PID namespaces. PID namespaces are isolated
from each other, while a service management process usually requires the
services to live in the same namespace, to be able to talk to each
other.
Users of this will be the systemd per-user instance, which provides
init-like functionality for the user's login session and D-Bus, which
activates bus services on-demand. Both need init-like capabilities to
be able to properly keep track of the services they start.
Many thanks to Oleg for several rounds of review and insights.
[akpm@linux-foundation.org: fix comment layout and spelling]
[akpm@linux-foundation.org: add lengthy code comment from Oleg]
Signed-off-by: Lennart Poettering <lennart@poettering.net>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
CAP_SYS_ADMIN is already overloaded left and right, so to have more
fine-grained access control use CAP_SYS_RESOURCE here.
The CAP_SYS_RESOUCE is chosen because this prctl option allows a current
process to adjust some fields of memory map descriptor which rather
represents what the process owns: pointers to code, data, stack
segments, command line, auxiliary vector data and etc.
Suggested-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
