path: root/kernel/power
2014-05-29Merge commit 'refs/changes/16/411516/5' of ssh://git-master:12001/linux-3.10 ↵Mandar padmawar
into promotion_build
2014-05-29Merge branch 'android-3.10' into rel-21Ishan Mittal
Bug 200004122 Bug 1511804 This merge takes AOSP commits from android-3.10 branch Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45 Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2014-05-27PM QoS: Fix pmqos notifiers in pm_qos_enabled_setSai Gurrappadi
Send out the notifiers if the enabled flag has been changed. This will ensure that the notifier fires in all cases. Bug 1516219 Change-Id: Ie97422f61a9ad56f0ce194a99ce69193d429eadc Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/413433 Reviewed-by: Automatic_Commit_Validation_User Tested-by: Diwakar Tundlam <dtundlam@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2014-04-24Power: Changes the permission to read only for sysfs fileRuchi Kandoi
/sys/kernel/wakeup_reasons/last_resume_reason Change-Id: I8ac568a7cb58c31decd379195de517ff3c6f9c65 Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-03-10power: wakeup_reason: rename irq_count to irqcountGreg Hackmann
On x86, irq_count conflicts with a declaration in arch/x86/include/asm/processor.h Change-Id: I3e4fde0ff64ef59ff5ed2adc0ea3a644641ee0b7 Signed-off-by: Greg Hackmann <ghackmann@google.com>
2014-03-10Power: Add guard condition for maximum wakeup reasonsRuchi Kandoi
Ensure the array for the wakeup reason IRQs does not overflow. Change-Id: Iddc57a3aeb1888f39d4e7b004164611803a4d37c Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com> (cherry picked from commit b5ea40cdfcf38296535f931a7e5e7bf47b6fad7f)
2014-02-21POWER: fix compile warnings in log_wakeup_reasonRuchi Kandoi
Change I81addaf420f1338255c5d0638b0d244a99d777d1 introduced compile warnings, fix these. Change-Id: I05482a5335599ab96c0a088a7d175c8d4cf1cf69 Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-02-20Power: add an API to log wakeup reasonsRuchi Kandoi
Add API log_wakeup_reason() and expose it to userspace via sysfs path /sys/kernel/wakeup_reasons/last_resume_reason Change-Id: I81addaf420f1338255c5d0638b0d244a99d777d1 Signed-off-by: Ruchi Kandoi <kandoiruchi@google.com>
2014-01-29Power: pmqos: Add emc freq pmqos constraintPuneet Saxena
It adds min emc freq pmqos. Bug 1432476 Change-Id: If05c2e8cceffc9ca071ed0b023c29e1ef2921245 Signed-off-by: Puneet Saxena <puneets@nvidia.com> Reviewed-on: http://git-master/r/360379 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Sachin Nikam <snikam@nvidia.com>
2014-01-14power: Fix coverity errorSai Gurrappadi
Properly null-terminate userspace input string. Otherwise, the subsequent strsep() could continue off into arbitrary chunks of kmalloc() space that aren't part of the original string buffer. Change-Id: I3868dbcdd9df7e7172c001eb6bc41c605d48604b Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/355578 Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2013-12-16Merge tag 'v3.10.24' into HEADAjay Nandakumar
This is the 3.10.24 stable release Change-Id: Ibd2734f93d44385ab86867272a1359158635133b
2013-12-04PM / hibernate: Avoid overflow in hibernate_preallocate_memory()Aaron Lu
commit fd432b9f8c7c88428a4635b9f5a9c6e174df6e36 upstream. When system has a lot of highmem (e.g. 16GiB using a 32 bits kernel), the code to calculate how much memory we need to preallocate in normal zone may cause overflow. As Leon has analysed: It looks that during computing 'alloc' variable there is overflow: alloc = (3943404 - 1970542) - 1978280 = -5418 (signed) And this function goes to err_out. Fix this by avoiding that overflow. References: https://bugzilla.kernel.org/show_bug.cgi?id=60817 Reported-and-tested-by: Leon Drugi <eyak@wp.pl> Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-21power: Prefer min over max for online cpusSai Gurrappadi
We prefered min_online_cpus over max_online_cpus if min > max. min_wins is now true for online cpu PmQoS requests. Bug 1270839 Change-Id: I2888538dd1a4616babb7cd1532264272de5cfe64 Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/301871 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2013-10-21PM / QoS: Add notifier for flagsTerje Bergstrom
dev_pm_qos has a notifier for DEV_PM_QOS_LATENCY. Add a similar notifier for DEV_PM_QOS_FLAGS. Bug 1364240 Change-Id: Ica4c58708855938818a1e75896503b9023b96573 Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-on: http://git-master/r/288810
2013-10-18power: PM QoS support for bounded constraintsSai Gurrappadi
Extended PM QoS to allow binding of two constraints. Bounded constraints add the following functionality: - Priority for min/max bound requests. Targets bounds are set to satisfy all priorities (intersection of all ranges). If it is not possible to do so, higher priorities prevail - Timeouts for bound requests - Userspace interface that exposes bound requests PM QoS still supports its original kernelspace and userspace interfaces Bug 1270839 Bug 1349096 Change-Id: Ic83444912b330fc71335d9a5b59077b1d16496bd Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/299037 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Paul Walmsley <pwalmsley@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2013-10-18pmqos: Replace spinlock with mutex for pm_qos_lockSai Gurrappadi
Using a spinlock (taken with irqsave) meant that pm_qos_lock couldn't be used to synchronize on the notifiers in order to ensure proper order of the notifications. This is needed in case where there might be two near simultaneous pmqos client requests for a bound on the same constraint; the notifiers in pm_qos_update_target for the two clients could potentially engage in a race. Example: Assume two requests are made (A, B with A coming first) for max cpufreq and these are the only requests currently available. Current behavior can result in: notify(max_cpu_freq, minof(A, B)) notify(max_cpu_freq, minof(LONG_MAX, A)) Expected behavior: notify(max_cpu_freq, minof(LONG_MAX, A)) notify(max_cpu_freq, minof(A, B)) Most of the PM QoS and Dev PM QoS requester clients were reviewed and none of them were found to be calling pm_qos_add/update/remove request from interrupt or atomic context since those calls include the blocking notifier call which cannot be done in atomic context. Change-Id: I2fb43cc38da4c701e4872b937dd82cd38f1a1c1e Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com> Reviewed-on: http://git-master/r/299036 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
2013-10-08Revert "PM / Sleep: Require CAP_BLOCK_SUSPEND to use wake_lock/wake_unlock"Ajay Nandakumar
This reverts commit 11388c87d2abca1f01975ced28ce9eacea239104. The issue is that no wake lock is held at the user space i.e by Power Manager service.This is because the PowerManagerService fails to acquire the Wakelock.In 3.8 the wakelock module in the kernel expects the user process to have the capability of CAP_BLOCK_SUSPEND.Which the powermangersevice does not have. Bug 1274297 Bug 1384311 Change-Id: I3b696108d47278cf40abce8d5a9bd012f98f2925 Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com> (cherry picked from commit e8464e785027a15279a13e6e32cd1aecd22d5a00) Reviewed-on: http://git-master/r/282698 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-09-27kernel: power: Add PM_USERSPACE_FROZEN workqueueArto Merilainen
Some device drivers require a callback to be called after the userspace processes are frozen. This patch adds PM_USERSPACE_FROZEN workqueue which is called after userspace processes are frozen but when the kernel threads are still functioning. Bug 1344551 Change-Id: I0e6fd7e2473db168d01c88bc0192326ceea92ebe Signed-off-by: Arto Merilainen <amerilainen@nvidia.com> Reviewed-on: http://git-master/r/266774 (cherry picked from commit d964493291ef87eea1a2ee47b5b66305bb18bcf3) Reviewed-on: http://git-master/r/274939 Tested-by: Sang-Hun Lee <sanlee@nvidia.com> Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com> Reviewed-by: Mitch Luban <mluban@nvidia.com>
2013-09-16PM QoS: Add GPU frequency limits to PM QoSAlex Frid
Added GPU frequency min/max as PM QoS classes. Bug 1330780 Change-Id: I2428c62748521c17e23b2df9ca409deda8b36160 Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/267702 Reviewed-by: Ilan Aelion <iaelion@nvidia.com> Reviewed-by: Mitch Luban <mluban@nvidia.com> Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
2013-09-14freezer: set PF_SUSPEND_TASK flag on tasks that call freeze_processesColin Cross
Calling freeze_processes sets a global flag that will cause any process that calls try_to_freeze to enter the refrigerator. It skips sending a signal to the current task, but if the current task ever hits try_to_freeze, all threads will be frozen and the system will deadlock. Set a new flag, PF_SUSPEND_TASK, on the task that calls freeze_processes. The flag notifies the freezer that the thread is involved in suspend and should not be frozen. Also add a WARN_ON in thaw_processes if the caller does not have the PF_SUSPEND_TASK flag set to catch if a different task calls thaw_processes than the one that called freeze_processes, leaving a task with PF_SUSPEND_TASK permanently set on it. Threads that spawn off a task with PF_SUSPEND_TASK set (which swsusp does) will also have PF_SUSPEND_TASK set, preventing them from freezing while they are helping with suspend, but they need to be dead by the time suspend is triggered, otherwise they may run when userspace is expected to be frozen. Add a WARN_ON in thaw_processes if more than one thread has the PF_SUSPEND_TASK flag set. Reported-and-tested-by: Michael Leun <lkml20130126@newton.leun.net> Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> (cherry picked from commit 2b44c4db2e2f1765d35163a861d301038e0c8a75) Change-Id: I12e00d2ba61db827c07b8f4ef48e88a722f02d71 Reviewed-on: http://git-master/r/259126 Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com> Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-09-14PM: Add prompt and help for wakelock in KconfigNaveen Kumar S
Adding bool prompt and help description for CONFIG_WAKELOCK and CONFIG_HAS_WAKELOCK options in Kconfig file to ease menuconfig operations Bug 1314808 Change-Id: I5c450ef0994a08c1bf51e8c9849bb96c69c69081 Signed-off-by: Naveen Kumar S <nkumars@nvidia.com> Reviewed-on: http://git-master/r/243459 (cherry picked from commit 2dda2db4db3fca12301cab3b9c59fba758573652) Reviewed-on: http://git-master/r/244781 (cherry picked from commit f3c8128a972e0e9f4df0a6b3d364cb14b5f29a9c) Reviewed-on: http://git-master/r/247680 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Kiran Adduri <kadduri@nvidia.com> Reviewed-by: Laxman Dewangan <ldewangan@nvidia.com>
2013-09-14PM / QoS: export pm_qos_update_request_timeout()Li Li
This pm_qos_update_request_timeout() was introduced without being exported. Should export it as all of the other PM QoS APIs so those drivers compiled as modules can use it. Change-Id: Ie51ce52db4ca633117fe18441c42b562220399e8 Signed-off-by: Li Li <lli5@nvidia.com> Reviewed-on: http://git-master/r/189306 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Eric Miao <emiao@nvidia.com> Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-09-14unknown changes from android-tegra-nv-3.4Dan Willemsen
Rebase-Id: R940fad74c7e91ef3d1d3d589a48064ccb7335541
2013-09-14Merge commit 'a88f9e27498afaea615ad3e93af4f26df1f84987' into ↵Dan Willemsen
after-upstream-android Conflicts: arch/arm/common/Kconfig arch/arm/mm/Makefile arch/arm/mm/cache-l2x0.c arch/arm/mm/mmu.c drivers/input/Kconfig drivers/input/Makefile drivers/power/Kconfig kernel/futex.c
2013-09-14PM QoS: Add disable parameterAntti P Miettinen
For testing purposes it is useful to be able to disable PM Qos. Bug 1020898 Bug 917572 Reviewed-on: http://git-master/r/124667 Change-Id: I266f5b5730cfe4705197d8b09db7f9eda6766c7c Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Rebase-Id: Re2088674f90436e0b9dd74310d5cda1f9e2868e4
2013-09-14PM Qos: Add min online cpus as PM QoS parameterGaurav Sarode
Bug 940061 Change-Id: Ibae842fdc3af3c92ec7e6125c602417110d8b55e Signed-off-by: Gaurav Sarode <gsarode@nvidia.com> Reviewed-on: http://git-master/r/84521 Reviewed-by: Sachin Nikam <snikam@nvidia.com> Tested-by: Aleksandr Frid <afrid@nvidia.com> Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com> Rebase-Id: R830d4e99f1e03b61a8c4e52e11645b7ed2f10f56
2013-09-14PM QoS: Add CPU frequency min/max as PM QoS paramsAntti P Miettinen
Add minimum and maximum CPU frequency as PM QoS parameters. Bug 888312 Change-Id: I18abddded35a044a6ad8365035e31d1a2213a329 Reviewed-on: http://git-master/r/72206 Signed-off-by: Antti P Miettinen <amiettinen@nvidia.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Reviewed-on: http://git-master/r/75883 Reviewed-by: Automatic_Commit_Validation_User Rebase-Id: R1007bbef60489ecc81a9acd0ce3b0abfa9a05f3e
2013-09-14PM QoS: Add max online cpus as PM QoS parameterAlex Frid
Bug 894200 Change-Id: Ieb009a13c6ef9bca2388e234eb973d65a4e3a58b Signed-off-by: Alex Frid <afrid@nvidia.com> Reviewed-on: http://git-master/r/71034 Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com> Rebase-Id: R5791d3cb0bb66f3b8079f5a8af5fa758fb3c6705
2013-08-30UPSTREAM next (v3.11): freezer: shorten freezer sleep time using exponential ↵Colin Cross
backoff All tasks can easily be frozen in under 10 ms, switch to using an initial 1 ms sleep followed by exponential backoff until 8 ms. Also convert the printed time to ms instead of centiseconds. Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> (cherry picked from commit 18ad0c6297df1d671ecea83b608cd9e432642a05) Change-Id: I470afcff3d1de66161e9545aa940a5910d41d122 Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com> Reviewed-on: http://git-master/r/228690 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2013-08-20PM / QoS: Fix workqueue deadlock when using pm_qos_update_request_timeout()Stephen Boyd
commit 40fea92ffb5fa0ef26d10ae0fe5688bc8e61c791 upstream. pm_qos_update_request_timeout() updates a qos and then schedules a delayed work item to bring the qos back down to the default after the timeout. When the work item runs, pm_qos_work_fn() will call pm_qos_update_request() and deadlock because it tries to cancel itself via cancel_delayed_work_sync(). Future callers of that qos will also hang waiting to cancel the work that is canceling itself. Let's extract the little bit of code that does the real work of pm_qos_update_request() and call it from the work function so that we don't deadlock. Before ed1ac6e (PM: don't use [delayed_]work_pending()) this didn't happen because the work function wouldn't try to cancel itself. [backport to 3.10 - gregkh] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Tejun Heo <tj@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-28PM / Sleep: avoid 'autosleep' in shutdown progressLiu ShuoX
commit e5248a111bf4048a9f3fab1a9c94c4630a10592a upstream. Prevent automatic system suspend from happening during system shutdown by making try_to_suspend() check system_state and return immediately if it is not SYSTEM_RUNNING. This prevents the following breakage from happening (scenario from Zhang Yanmin): Kernel starts shutdown and calls all device driver's shutdown callback. When a driver's shutdown is called, the last wakelock is released and suspend-to-ram starts. However, as some driver's shut down callbacks already shut down devices and disabled runtime pm, the suspend-to-ram calls driver's suspend callback without noticing that device is already off and causes crash. [rjw: Changelog] Signed-off-by: Liu ShuoX <shuox.liu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-01freezer: shorten freezer sleep time using exponential backoffColin Cross
All tasks can easily be frozen in under 10 ms, switch to using an initial 1 ms sleep followed by exponential backoff until 8 ms. Also convert the printed time to ms instead of centiseconds. Change-Id: I7b198b16eefb623c2b0fc45dce50d9bca320afdc Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-01PM / Suspend: Print wall time at suspend entry and exitTodd Poynor
Change-Id: I92f252414c013b018b9a392eae1ee039aa0e89dc Signed-off-by: Todd Poynor <toddpoynor@google.com>
2013-07-01PM / Sleep: Add wake lock api wrapper on top of wakeup sourcesArve Hjønnevåg
Change-Id: Icaad02fe1e8856fdc2e4215f380594a5dde8e002 Signed-off-by: Arve Hjønnevåg <arve@android.com>
2013-07-01power: Add option to log time spent in suspendColin Cross
Prints the time spent in suspend in the kernel log, and keeps statistics on the time spent in suspend in /sys/kernel/debug/suspend_time Change-Id: Ia6b9ebe4baa0f7f5cd211c6a4f7e813aefd3fa1d Signed-off-by: Colin Cross <ccross@android.com> Signed-off-by: Todd Poynor <toddpoynor@google.com>
2013-05-02Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "This is the main drm pull request for 3.10. Wierd bits: - OMAP drm changes required OMAP dss changes, in drivers/video, so I took them in here. - one more fbcon fix for font handover - VT switch avoidance in pm code - scatterlist helpers for gpu drivers - have acks from akpm Highlights: - qxl kms driver - driver for the spice qxl virtual GPU Nouveau: - fermi/kepler VRAM compression - GK110/nvf0 modesetting support. Tegra: - host1x core merged with 2D engine support i915: - vt switchless resume - more valleyview support - vblank fixes - modesetting pipe config rework radeon: - UVD engine support - SI chip tiling support - GPU registers initialisation from golden values. exynos: - device tree changes - fimc block support Otherwise: - bunches of fixes all over the place." * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (513 commits) qxl: update to new idr interfaces. drm/nouveau: fix build with nv50->nvc0 drm/radeon: fix handling of v6 power tables drm/radeon: clarify family checks in pm table parsing drm/radeon: consolidate UVD clock programming drm/radeon: fix UPLL_REF_DIV_MASK definition radeon: add bo tracking debugfs drm/radeon: add new richland pci ids drm/radeon: add some new SI PCI ids drm/radeon: fix scratch reg handling for UVD fence drm/radeon: allocate SA bo in the requested domain drm/radeon: fix possible segfault when parsing pm tables drm/radeon: fix endian bugs in atom_allocate_fb_scratch() OMAPDSS: TFP410: return EPROBE_DEFER if the i2c adapter not found OMAPDSS: VENC: Add error handling for venc_probe_pdata OMAPDSS: HDMI: Add error handling for hdmi_probe_pdata OMAPDSS: RFBI: Add error handling for rfbi_probe_pdata OMAPDSS: DSI: Add error handling for dsi_probe_pdata OMAPDSS: SDI: Add error handling for sdi_probe_pdata OMAPDSS: DPI: Add error handling for dpi_probe_pdata ...
2013-04-30Merge branch 'akpm' (incoming from Andrew)Linus Torvalds
Merge third batch of fixes from Andrew Morton: "Most of the rest. I still have two large patchsets against AIO and IPC, but they're a bit stuck behind other trees and I'm about to vanish for six days. - random fixlets - inotify - more of the MM queue - show_stack() cleanups - DMI update - kthread/workqueue things - compat cleanups - epoll udpates - binfmt updates - nilfs2 - hfs - hfsplus - ptrace - kmod - coredump - kexec - rbtree - pids - pidns - pps - semaphore tweaks - some w1 patches - relay updates - core Kconfig changes - sysrq tweaks" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (109 commits) Documentation/sysrq: fix inconstistent help message of sysrq key ethernet/emac/sysrq: fix inconstistent help message of sysrq key sparc/sysrq: fix inconstistent help message of sysrq key powerpc/xmon/sysrq: fix inconstistent help message of sysrq key ARM/etm/sysrq: fix inconstistent help message of sysrq key power/sysrq: fix inconstistent help message of sysrq key kgdb/sysrq: fix inconstistent help message of sysrq key lib/decompress.c: fix initconst notifier-error-inject: fix module names in Kconfig kernel/sys.c: make prctl(PR_SET_MM) generally available UAPI: remove empty Kbuild files menuconfig: print more info for symbol without prompts init/Kconfig: re-order CONFIG_EXPERT options to fix menuconfig display kconfig menu: move Virtualization drivers near other virtualization options Kconfig: consolidate CONFIG_DEBUG_STRICT_USER_COPY_CHECKS relay: use macro PAGE_ALIGN instead of FIX_SIZE kernel/relay.c: move FIX_SIZE macro into relay.c kernel/relay.c: remove unused function argument actor drivers/w1/slaves/w1_ds2760.c: fix the error handling in w1_ds2760_add_slave() drivers/w1/slaves/w1_ds2781.c: fix the error handling in w1_ds2781_add_slave() ...
2013-04-30power/sysrq: fix inconstistent help message of sysrq keyzhangwei(Jovi)
Currently help message of /proc/sysrq-trigger highlight its upper-case characters, like below: SysRq : HELP : loglevel(0-9) reBoot Crash terminate-all-tasks(E) memory-full-oom-kill(F) kill-all-tasks(I) ... this would confuse user trigger sysrq by upper-case character, which is inconsistent with the real lower-case character registed key. This inconsistent help message will also lead more confused when 26 upper-case letters put into use in future. This patch fix power off sysrq key: "poweroff(o)" Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-05PM / sleep: invalidate TEST_CPUS and TEST_CORE support for freeze stateZhang Rui
freeze state is a software suspend state that does not run into low-level platform callbacks which may interact with BIOS. And freeze state does not need to disable the processors. But the current pm_test support misleads users because users can enter freeze state with pm_test set to TEST_CPUS/TEST_CORE, while this pm_test setting never takes actions. So, invalidate TEST_CPUS/TEST_CORE for freeze state in this patch. Then users will get an error instead, when trying to enter freeze state with pm_test mode set to TEST_CPUS/TEST_CORE. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-04-05PM / sleep: add TEST_PLATFORM support for freeze stateZhang Rui
Invoke freeze_enter() after suspend_test(TEST_PLATFORM) being invoked. So when setting /sys/power/pm_test to "platform", it can be used to check if freeze state is working well after all devices are suspended and before processors are blocked, Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-03-19Merge tag 'v3.9-rc3' into drm-intel-next-queuedDaniel Vetter
Backmerge so that I can merge Imre Deak's coalesced sg entries fixes, which depend upon the new for_each_sg_page introduce in commit a321e91b6d73ed011ffceed384c40d2785cf723b Author: Imre Deak <imre.deak@intel.com> Date: Wed Feb 27 17:02:56 2013 -0800 lib/scatterlist: add simple page iterator The merge itself is just two trivial conflicts: Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-20PM: make VT switching to the suspend console optional v3Jesse Barnes
KMS drivers can potentially restore the display configuration without userspace help. Such drivers can can call a new funciton, pm_vt_switch_required(false) if they support this feature. In that case, the PM layer won't VT switch to the suspend console at suspend time and then back to the original VT on resume, but rather leave things alone for a nicer looking suspend and resume sequence. v2: make a function so we can handle multiple drivers (Alan) v3: use a list to track device requests (Rafael) v4: Squash in build fix from Jesse for CONFIG_VT_CONSOLE_SLEEP=n v5: Squash in patch from Wu Fengguang to add a few missing static qualifiers. v6: Add missing EXPORT_SYMBOL. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Reviewed-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> (v3) Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2013-02-09suspend: enable freeze timeout configuration through sysLi Fei
At present, the value of timeout for freezing is 20s, which is meaningless in case that one thread is frozen with mutex locked and another thread is trying to lock the mutex, as this time of freezing will fail unavoidably. And if there is no new wakeup event registered, the system will waste at most 20s for such meaningless trying of freezing. With this patch, the value of timeout can be configured to smaller value, so such meaningless trying of freezing will be aborted in earlier time, and later freezing can be also triggered in earlier time. And more power will be saved. In normal case on mobile phone, it costs real little time to freeze processes. On some platform, it only costs about 20ms to freeze user space processes and 10ms to freeze kernel freezable threads. Signed-off-by: Liu Chuansheng <chuansheng.liu@intel.com> Signed-off-by: Li Fei <fei.li@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-09PM: Introduce suspend state PM_SUSPEND_FREEZEZhang Rui
PM_SUSPEND_FREEZE state is a general state that does not need any platform specific support, it equals frozen processes + suspended devices + idle processors. Compared with PM_SUSPEND_MEMORY, PM_SUSPEND_FREEZE saves less power because the system is still in a running state. PM_SUSPEND_FREEZE has less resume latency because it does not touch BIOS, and the processors are in idle state. Compared with RTPM/idle, PM_SUSPEND_FREEZE saves more power as 1. the processor has longer sleep time because processes are frozen. The deeper c-state the processor supports, more power saving we can get. 2. PM_SUSPEND_FREEZE uses system suspend code path, thus we can get more power saving from the devices that does not have good RTPM support. This state is useful for 1) platforms that do not have STR, or have a broken STR. 2) platforms that have an extremely low power idle state, which can be used to replace STR. The following describes how PM_SUSPEND_FREEZE state works. 1. echo freeze > /sys/power/state 2. the processes are frozen. 3. all the devices are suspended. 4. all the processors are blocked by a wait queue 5. all the processors idles and enters (Deep) c-state. 6. an interrupt fires. 7. a processor is woken up and handles the irq. 8. if it is a general event, a) the irq handler runs and quites. b) goto step 4. 9. if it is a real wake event, say, power button pressing, keyboard touch, mouse moving, a) the irq handler runs and activate the wakeup source b) wakeup_source_activate() notifies the wait queue. c) system starts resuming from PM_SUSPEND_FREEZE 10. all the devices are resumed. 11. all the processes are unfrozen. 12. system is back to working. Known Issue: The wakeup of this new PM_SUSPEND_FREEZE state may behave differently from the previous suspend state. Take ACPI platform for example, there are some GPEs that only enabled when the system is in sleep state, to wake the system backk from S3/S4. But we are not touching these GPEs during transition to PM_SUSPEND_FREEZE. This means we may lose some wake event. But on the other hand, as we do not disable all the Interrupts during PM_SUSPEND_FREEZE, we may get some extra "wakeup" Interrupts, that are not available for S3/S4. The patches has been tested on an old Sony laptop, and here are the results: Average Power: 1. RPTM/idle for half an hour: 14.8W, 12.6W, 14.1W, 12.5W, 14.4W, 13.2W, 12.9W 2. Freeze for half an hour: 11W, 10.4W, 9.4W, 11.3W 10.5W 3. RTPM/idle for three hours: 11.6W 4. Freeze for three hours: 10W 5. Suspend to Memory: 0.5~0.9W Average Resume Latency: 1. RTPM/idle with a black screen: (From pressing keyboard to screen back) Less than 0.2s 2. Freeze: (From pressing power button to screen back) 2.50s 3. Suspend to Memory: (From pressing power button to screen back) 4.33s >From the results, we can see that all the platforms should benefit from this patch, even if it does not have Low Power S0. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-26PM: don't use [delayed_]work_pending()Tejun Heo
There's no need to test whether a (delayed) work item is pending before queueing, flushing or cancelling it, so remove work_pending() tests used in those cases. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-12-12Merge branch 'for-3.8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "A lot of activities on cgroup side. The big changes are focused on making cgroup hierarchy handling saner. - cgroup_rmdir() had peculiar semantics - it allowed cgroup destruction to be vetoed by individual controllers and tried to drain refcnt synchronously. The vetoing never worked properly and caused good deal of contortions in cgroup. memcg was the last reamining user. Michal Hocko removed the usage and cgroup_rmdir() path has been simplified significantly. This was done in a separate branch so that the memcg people can base further memcg changes on top. - The above allowed cleaning up cgroup lifecycle management and implementation of generic cgroup iterators which are used to improve hierarchy support. - cgroup_freezer updated to allow migration in and out of a frozen cgroup and handle hierarchy. If a cgroup is frozen, all descendant cgroups are frozen. - netcls_cgroup and netprio_cgroup updated to handle hierarchy properly. - Various fixes and cleanups. - Two merge commits. One to pull in memcg and rmdir cleanups (needed to build iterators). The other pulled in cgroup/for-3.7-fixes for device_cgroup fixes so that further device_cgroup patches can be stacked on top." Fixed up a trivial conflict in mm/memcontrol.c as per Tejun (due to commit bea8c150a7 ("memcg: fix hotplugged memory zone oops") in master touching code close to commit 2ef37d3fe4 ("memcg: Simplify mem_cgroup_force_empty_list error handling") in for-3.8) * 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (65 commits) cgroup: update Documentation/cgroups/00-INDEX cgroup_rm_file: don't delete the uncreated files cgroup: remove subsystem files when remounting cgroup cgroup: use cgroup_addrm_files() in cgroup_clear_directory() cgroup: warn about broken hierarchies only after css_online cgroup: list_del_init() on removed events cgroup: fix lockdep warning for event_control cgroup: move list add after list head initilization netprio_cgroup: allow nesting and inherit config on cgroup creation netprio_cgroup: implement netprio[_set]_prio() helpers netprio_cgroup: use cgroup->id instead of cgroup_netprio_state->prioidx netprio_cgroup: reimplement priomap expansion netprio_cgroup: shorten variable names in extend_netdev_table() netprio_cgroup: simplify write_priomap() netcls_cgroup: move config inheritance to ->css_online() and remove .broken_hierarchy marking cgroup: remove obsolete guarantee from cgroup_task_migrate. cgroup: add cgroup->id cgroup, cpuset: remove cgroup_subsys->post_clone() cgroup: s/CGRP_CLONE_CHILDREN/CGRP_CPUSET_CLONE_CHILDREN/ cgroup: rename ->create/post_create/pre_destroy/destroy() to ->css_alloc/online/offline/free() ...
2012-11-29Merge branch 'pm-sleep'Rafael J. Wysocki
* pm-sleep: PM / Freezer: Fixup compile error of try_to_freeze_nowarn() driver core / PM: move the calling to device_pm_remove behind the calling to bus_remove_device PM / Hibernate: use rb_entry PM / sysfs: replace strict_str* with kstrto*
2012-11-15PM / Hibernate: use rb_entryDavidlohr Bueso
Since the software suspend extents are organized in an rbtree, use rb_entry instead of container_of, as it is semantically more appropriate in order to get a node as it is iterated. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
