path: root/kernel/kallsyms.c
2013-04-15kernel: kallsyms: memory override issue, need check destination buffer lengthChen Gang
We don't export any symbols > 128 characters, but if we did then kallsyms_expand_symbol() would overflow the buffer handed to it. So we need check destination buffer length when copying. the related test: if we define an EXPORT function which name more than 128. will panic when call kallsyms_lookup_name by init_kprobes on booting. after check the length (provide this patch), it is ok. Implementaion: add additional destination buffer length parameter (maxlen) if uncompressed string is too long (>= maxlen), it will be truncated. not check the parameters whether valid, since it is a static function. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-05-29vsprintf: fix %ps on non symbols when using kallsymsStephen Boyd
Using %ps in a printk format will sometimes fail silently and print the empty string if the address passed in does not match a symbol that kallsyms knows about. But using %pS will fall back to printing the full address if kallsyms can't find the symbol. Make %ps act the same as %pS by falling back to printing the address. While we're here also make %ps print the module that a symbol comes from so that it matches what %pS already does. Take this simple function for example (in a module): static void test_printk(void) { int test; pr_info("with pS: %pS\n", &test); pr_info("with ps: %ps\n", &test); } Before this patch: with pS: 0xdff7df44 with ps: After this patch: with pS: 0xdff7df44 with ps: 0xdff7df44 Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix WARN_ON() test for UP WARN_ON_SMP(): Allow use in if() statements on UP x86, dumpstack: Use %pB format specifier for stack trace vsprintf: Introduce %pB format specifier lockdep: Remove unused 'factor' variable from lockdep_stats_show()
2011-03-24vsprintf: Introduce %pB format specifierNamhyung Kim
The %pB format specifier is for stack backtrace. Its handler sprint_backtrace() does symbol lookup using (address-1) to ensure the address will not point outside of the function. If there is a tail-call to the function marked "noreturn", gcc optimized out the code after the call then causes saved return address points outside of the function (i.e. the start of the next function), so pollutes call trace somewhat. This patch adds the %pB printk mechanism that allows architecture call-trace printout functions to improve backtrace printouts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-arch@vger.kernel.org LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23mm: arch: rename in_gate_area_no_task to in_gate_area_no_mmStephen Wilson
Now that gate vma's are referenced with respect to a particular mm and not a particular task it only makes sense to propagate the change to this predicate as well. Signed-off-by: Stephen Wilson <wilsons@start.ca> Reviewed-by: Michel Lespinasse <walken@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-22printk: use %pK for /proc/kallsyms and /proc/modulesKees Cook
In an effort to reduce kernel address leaks that might be used to help target kernel privilege escalation exploits, this patch uses %pK when displaying addresses in /proc/kallsyms, /proc/modules, and /sys/module/*/sections/*. Note that this changes %x to %p, so some legitimately 0 values in /proc/kallsyms would have changed from 00000000 to "(null)". To avoid this, "(null)" is not used when using the "K" format. Anything that was already successfully parsing "(null)" in addition to full hex digits should have no problem with this change. (Thanks to Joe Perches for the suggestion.) Due to the %x to %p, "void *" casts are needed since these addresses are already "unsigned long" everywhere internally, due to their starting life as ELF section offsets. Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: Eugene Teo <eugene@redhat.com> Cc: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-19Revert "kernel: make /proc/kallsyms mode 400 to reduce ease of attacking"Linus Torvalds
This reverts commit 59365d136d205cc20fe666ca7f89b1c5001b0d5a. It turns out that this can break certain existing user land setups. Quoth Sarah Sharp: "On Wednesday, I updated my branch to commit 460781b from linus' tree, and my box would not boot. klogd segfaulted, which stalled the whole system. At first I thought it actually hung the box, but it continued booting after 5 minutes, and I was able to log in. It dropped back to the text console instead of the graphical bootup display for that period of time. dmesg surprisingly still works. I've bisected the problem down to this commit (commit 59365d136d205cc20fe666ca7f89b1c5001b0d5a) The box is running klogd 1.5.5ubuntu3 (from Jaunty). Yes, I know that's old. I read the bit in the commit about changing the permissions of kallsyms after boot, but if I can't boot that doesn't help." So let's just keep the old default, and encourage distributions to do the "chmod -r /proc/kallsyms" in their bootup scripts. This is not worth a kernel option to change default behavior, since it's so easily done in user space. Reported-and-bisected-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Marcus Meissner <meissner@suse.de> Cc: Tejun Heo <tj@kernel.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16kernel: make /proc/kallsyms mode 400 to reduce ease of attackingMarcus Meissner
Making /proc/kallsyms readable only for root by default makes it slightly harder for attackers to write generic kernel exploits by removing one source of knowledge where things are in the kernel. This is the second submit, discussion happened on this on first submit and mostly concerned that this is just one hole of the sieve ... but one of the bigger ones. Changing the permissions of at least System.map and vmlinux is also required to fix the same set, but a packaging issue. Target of this starter patch and follow ups is removing any kind of kernel space address information leak from the kernel. [ Side note: the default of root-only reading is the "safe" value, and it's easy enough to then override at any time after boot. The /proc filesystem allows root to change the permissions with a regular chmod, so you can "revert" this at run-time by simply doing chmod og+r /proc/kallsyms as root if you really want regular users to see the kernel symbols. It does help some tools like "perf" figure them out without any setup, so it may well make sense in some situations. - Linus ] Signed-off-by: Marcus Meissner <meissner@suse.de> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Eugene Teo <eugeneteo@kernel.org> Reviewed-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-20kdb: core for kgdb back end (2 of 2)Jason Wessel
This patch contains the hooks and instrumentation into kernel which live outside the kernel/debug directory, which the kdb core will call to run commands like lsmod, dmesg, bt etc... CC: linux-arch@vger.kernel.org Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Martin Hicks <mort@sgi.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-10hw-breakpoints: Fix broken hw-breakpoint sample moduleFrederic Weisbecker
The hw-breakpoint sample module has been broken during the hw-breakpoint internals refactoring. Propagate the changes to it. Reported-by: "K. Prasad" <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-23kallsyms: use new arch_is_kernel_text()Mike Frysinger
This allows kallsyms to locate symbols that are in arch-specific text sections (such as text in Blackfin on-chip SRAM regions). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Robin Getz <rgetz@blackfin.uclinux.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-09kernel/kallsyms.c: replace deprecated __initcall with device_initcall and ↵Manish Katiyar
fix whitespace Fix coding style whitespace issues and replace __initcall with device_initcall. Fixed multi-line comments as per coding style. Errors as reported by checkpatch.pl :- Before: total: 14 errors, 14 warnings, 487 lines checked After : total: 0 errors, 8 warnings, 507 lines checked Compile tested binary verified as :- Before: text data bss dec hex filename 2405 4 0 2409 969 kernel/kallsyms.o After : text data bss dec hex filename 2405 4 0 2409 969 kernel/kallsyms.o Signed-off-by: Manish Katiyar <mkatiyar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-03-31Ksplice: Add functions for walking kallsyms symbolsAnders Kaseorg
Impact: New API kallsyms_lookup_name only returns the first match that it finds. Ksplice needs information about all symbols with a given name in order to correctly resolve local symbols. kallsyms_on_each_symbol provides a generic mechanism for iterating over the kallsyms table. Cc: Jeff Arnold <jbarnold@mit.edu> Cc: Tim Abbott <tabbott@mit.edu> Signed-off-by: Anders Kaseorg <andersk@mit.edu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-01-14Revert "kbuild: strip generated symbols from *.ko"Sam Ravnborg
This reverts commit ad7a953c522ceb496611d127e51e278bfe0ff483. And commit: ("allow stripping of generated symbols under CONFIG_KALLSYMS_ALL") 9bb482476c6c9d1ae033306440c51ceac93ea80c These stripping patches has caused a set of issues: 1) People have reported compatibility issues with binutils due to lack of support for `--strip-unneeded-symbols' with objcopy 2.15.92.0.2 Reported by: Wenji 2) ccache and distcc no longer works as expeced Reported by: Ted, Roland, + others 3) The installed modules increased a lot in size Reported by: Ted, Davej + others Reported-by: Wenji Huang <wenji.huang@oracle.com> Reported-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Dave Jones <davej@redhat.com> Reported-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-12-19allow stripping of generated symbols under CONFIG_KALLSYMS_ALLJan Beulich
Building upon parts of the module stripping patch, this patch introduces similar stripping for vmlinux when CONFIG_KALLSYMS_ALL=y. Using CONFIG_KALLSYMS_STRIP_GENERATED reduces the overhead of CONFIG_KALLSYMS_ALL from 245k/310k to 65k/80k for the (i386/x86-64) kernels I tested with. The patch also does away with the need to special case the kallsyms- internal symbols by making them available even in the first linking stage. While it is a generated file, the patch includes the changes to scripts/genksyms/keywords.c_shipped, as I'm unsure what the procedure here is. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-11-19sprint_symbol(): use less stackHugh Dickins
sprint_symbol(), itself used when dumping stacks, has been wasting 128 bytes of stack: lookup the symbol directly into the buffer supplied by the caller, instead of using a locally declared namebuf. I believe the name != buffer strcpy() is obsolete: the design here dates from when module symbol lookup pointed into a supposedly const but sadly volatile table; nowadays it copies, but an uncalled strcpy() looks better here than the risk of a recursive BUG_ON(). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16kernel/kallsyms.c: fix double returnWANG Cong
Commit 6dd06c9fbe025f542bce4cdb91790c0f91962722 ("module: make module_address_lookup safe") introduced double returns in the function kallsyms_lookup(), it's weird. The second one should be removed. Signed-off-by: WANG Cong <wangcong@zeuux.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25kallsyms: fix potential overflow in binary searchVegard Nossum
This will probably never trigger... but it won't hurt to be careful. http://googleresearch.blogspot.com/2006/06/extra-extra-read-all-about-it-nearly.html Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: Joshua Bloch <jjb@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06remove support for un-needed _extratext sectionRobin Getz
When passing a zero address to kallsyms_lookup(), the kernel thought it was a valid kernel address, even if it is not. This is because is_ksym_addr() called is_kernel_extratext() and checked against labels that don't exist on many archs (which default as zero). Since PPC was the only kernel which defines _extra_text, (in 2005), and no longer needs it, this patch removes _extra_text support. For some history (provided by Jon): http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019734.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019736.html http://ozlabs.org/pipermail/linuxppc-dev/2005-September/019751.html [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Robin Getz <rgetz@blackfin.uclinux.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jon Loeliger <jdl@freescale.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-29module: make module_address_lookup safeRusty Russell
module_address_lookup releases preemption then returns a pointer into the module space. The only user (kallsyms) copies the result, so just do that under the preempt disable. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-11-29FRV: fix the extern declaration of kallsyms_num_symsDavid Howells
Fix the extern declaration of kallsyms_num_syms to indicate that the symbol does not reside in the small-data storage space, and so may not be accessed relative to the small data base register. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kallsyms: make KSYM_NAME_LEN include space for trailing '\0'Tejun Heo
KSYM_NAME_LEN is peculiar in that it does not include the space for the trailing '\0', forcing all users to use KSYM_NAME_LEN + 1 when allocating buffer. This is nonsense and error-prone. Moreover, when the caller forgets that it's very likely to subtly bite back by corrupting the stack because the last position of the buffer is always cleared to zero. This patch increments KSYM_NAME_LEN by one and updates code accordingly. * off-by-one bug in asm-powerpc/kprobes.h::kprobe_lookup_name() macro is fixed. * Where MODULE_NAME_LEN and KSYM_NAME_LEN were used together, MODULE_NAME_LEN was treated as if it didn't include space for the trailing '\0'. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16sprint_symbol() cleanupAndrew Morton
Remove pointless `else'. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30fix possible null ptr deref in kallsyms_lookupKyle McMartin
ugh, this function gets called by our unwinder. recursive backtrace for the win... bisection to find this one was "fun." Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kallsyms: cleanup: use seq_release_private() where appropriateMartin Peschke
We can save some lines of code by using seq_release_private(). Signed-off-by: Martin Peschke <mp3@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/slab_allocators and rmmodAlexey Dobriyan
Same story as with cat /proc/*/wchan race vs rmmod race, only /proc/slab_allocators want more info than just symbol name. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/*/wchan and rmmod et alAlexey Dobriyan
kallsyms_lookup() can go iterating over modules list unprotected which is OK for emergency situations (oops), but not OK for regular stuff like /proc/*/wchan. Introduce lookup_symbol_name()/lookup_module_symbol_name() which copy symbol name into caller-supplied buffer or return -ERANGE. All copying is done with module_mutex held, so... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Simplify kallsyms_lookup()Alexey Dobriyan
Several kallsyms_lookup() pass dummy arguments but only need, say, module's name. Make kallsyms_lookup() accept NULLs where possible. Also, makes picture clearer about what interfaces are needed for all symbol resolving business. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between rmmod and cat /proc/kallsymsAlexey Dobriyan
module_get_kallsym() leaks "struct module *" outside of module_mutex which is no-no, because module can dissapear right after mutex unlock. Copy all needed information from inside module_mutex into caller-supplied space. [bunk@stusta.de: is_exported() can now become static] Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Simplify module_get_kallsym() by dropping length argAlexey Dobriyan
module_get_kallsym() could in theory truncate module symbol name to fit in buffer, but nobody does this. Always use KSYM_NAME_LEN + 1 bytes for name. Suggested by lg^WRusty. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Extend print_symbol capabilityRobert Peterson
Today's print_symbol function dumps a kernel symbol with printk. This patch extends the functionality of kallsyms.c so that the symbol lookup function may be used without the printk. This is useful for modules that want to dump symbols elsewhere, for example, to debugfs. I intend to use the new function call in the GFS2 file system (which will be a separate patch). [akpm@linux-foundation.org: build fix] [clameter@sgi.com: sprint_symbol should return length of string like sprintf] Signed-off-by: Robert Peterson <rpeterso@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] move kallsyms data to .rodataJan Beulich
Kallsyms data is never written to, so it can as well benefit from CONFIG_DEBUG_RODATA. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] /proc/kallsyms reports lower-case types for some non-exported symbolsAdam B. Jerome
This patch addresses incorrect symbol type information reported through /proc/kallsyms. A lowercase character should designate the symbol as local (or non-exported). An uppercase character should designate the symbol as global (or external). Without this patch, some non-exported symbols are incorrectly assigned an upper-case designation in /proc/kallsyms. This patch corrects this condition by converting non-exported symbols types to lower case when appropriate and eliminates the superfluous upcase_if_global function Signed-off-by: Adam B. Jerome <abj@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] Create kallsyms_lookup_size_offset()Franck Bui-Huu
Some uses of kallsyms_lookup() do not need to find out the name of a symbol and its module's name it belongs. This is specially true in arch specific code, which needs to unwind the stack to show the back trace during oops (mips is an example). In this specific case, we just need to retreive the function's size and the offset of the active intruction inside it. Adds a new entry "kallsyms_lookup_size_offset()" This new entry does exactly the same as kallsyms_lookup() but does not require any buffers to store any names. It returns 0 if it fails otherwise 1. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02[PATCH] Kprobes: Make kprobe modules more portableAnanth N Mavinakayanahalli
In an effort to make kprobe modules more portable, here is a patch that: o Introduces the "symbol_name" field to struct kprobe. The symbol->address resolution now happens in the kernel in an architecture agnostic manner. 64-bit powerpc users no longer have to specify the ".symbols" o Introduces the "offset" field to struct kprobe to allow a user to specify an offset into a symbol. o The legacy mechanism of specifying the kprobe.addr is still supported. However, if both the kprobe.addr and kprobe.symbol_name are specified, probe registration fails with an -EINVAL. o The symbol resolution code uses kallsyms_lookup_name(). So CONFIG_KPROBES now depends on CONFIG_KALLSYMS o Apparantly kprobe modules were the only legitimate out-of-tree user of the kallsyms_lookup_name() EXPORT. Now that the symbol resolution happens in-kernel, remove the EXPORT as suggested by Christoph Hellwig o Modify tcp_probe.c that uses the kprobe interface so as to make it work on multiple platforms (in its earlier form, the code wouldn't work, say, on powerpc) Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Prasanna S Panchamukhi <prasanna@in.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] null-terminate over-long /proc/kallsyms symbolsAndreas Gruenbacher
Got a customer bug report (https://bugzilla.novell.com/190296) about kernel symbols longer than 127 characters which end up in a string buffer that is not NULL terminated, leading to garbage in /proc/kallsyms. Using strlcpy prevents this from happening, even though such symbols still won't come out right. A better fix would be to not use a fixed-size buffer, but it's probably not worth the trouble. (Modversion'ed symbols even have a length limit of 60.) [bunk@stusta.de: build fix] Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] ppc32: platform-specific functions missing from kallsyms.David Woodhouse
The PPC32 kernel puts platform-specific functions into separate sections so that unneeded parts of it can be freed when we've booted and actually worked out what we're running on today. This makes kallsyms ignore those functions, because they're not between _[se]text or _[se]inittext. Rather than teaching kallsyms about the various pmac/chrp/etc sections, this patch adds '_[se]extratext' markers for kallsyms. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
