Commit "gcov-kernel: patch for Android toolchain 4.4.x support" broke
support for gcov on vanilla gcc. Introduce #ifdefs to make it work on
both of them.
Since the gcov ABI for Android gcc is different, the build system
must set CONFIG_GCOV_TOOLCHAIN_IS_ANDROID when compiling with an
Android toolchain.
Also remove a few magic numbers from the original gcov code and fix a
unused function warning.
Bug 1155439
Change-Id: I7c18938e5503df4ee1c3f8de2b6f5a99ceef7f71
Signed-off-by: Tuomas Tynkkynen <ttynkkynen@nvidia.com>
Reviewed-on: http://git-master/r/162711
GVS: Gerrit_Virtual_Submit
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Gcov's internal data structures, on which the kernel depends on, have
changed in GCC 4.6. This patch adds support for GCC 4.6 and should still
work on GCC 4.4 too.
For reference, look at 'struct gcov_fn_info' in GCC's 'gcc/gcov-io.h',
near line 698:
https://android.googlesource.com/toolchain/gcc/+/master/gcc-4.4.3/
https://android.googlesource.com/toolchain/gcc/+/master/gcc-4.6/
Bug 1003822
Change-Id: I527736f944c80b8b345d1685669c0b99eb38fb66
Reviewed-on: http://git-master/r/110073
Tested-by: Juha Tukkinen <jtukkinen@nvidia.com>
Rebase-Id: Rfdb0c2f3801fc41d3ed4b3696634adf79bdc232b
Based on work by George G. Davis <gdavis@mvista.com>.
See http://lwn.net/Articles/390419/
Change-Id: I8df700d20a154e179f8cf6cdfe4015efc5d384f2
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62998
Reviewed-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Rebase-Id: R2607a46c8bd1e521abe44a57a5ccf7317333d6c9
Based on work done for LTP in
http://ltp.cvs.sourceforge.net/viewvc/ltp/utils/analysis/gcov-kernel
Patch originates from Motorola kernel team (mkw348@motorola.com).
Change-Id: Ibb2a7c8afd79051e8d6c7fde83f04745be14f5fd
Reviewed-on: http://git-master/r/62997
Rebase-Id: R67557d023bc94fbe900bfc9deef2f5de9955ea43
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a
while now and is almost always enabled by default. As agreed during the
Linux kernel summit, remove it from any "depends on" lines in Kconfigs.
Cc: WANG Cong <xiyou.wangcong@gmail.com>
Acked-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com>
Selecting GCOV for UML causing configuration mismatch:
warning: (GCOV_KERNEL) selects CONSTRUCTORS which has unmet direct dependencies (!UML)
Constructors are not needed for UML.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
Cc: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
CONFIG_CONSTRUCTORS controls support for running constructor functions at
kernel init time. According to commit b99b87f70c7785ab ("kernel:
constructor support"), gcov (CONFIG_GCOV_KERNEL) needs this. However,
CONFIG_CONSTRUCTORS currently defaults to y, with no option to disable it,
and CONFIG_GCOV_KERNEL depends on it. Instead, default it to n and have
CONFIG_GCOV_KERNEL select it, so that the normal case of
CONFIG_GCOV_KERNEL=n will result in CONFIG_CONSTRUCTORS=n.
Observed in the short list of =y values in a minimal kernel configuration.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6
* 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits)
video: change to new flag variable
scsi: change to new flag variable
rtc: change to new flag variable
rapidio: change to new flag variable
pps: change to new flag variable
net: change to new flag variable
misc: change to new flag variable
message: change to new flag variable
memstick: change to new flag variable
isdn: change to new flag variable
ieee802154: change to new flag variable
ide: change to new flag variable
hwmon: change to new flag variable
dma: change to new flag variable
char: change to new flag variable
fs: change to new flag variable
xtensa: change to new flag variable
um: change to new flag variables
s390: change to new flag variable
mips: change to new flag variable
Fix up trivial conflict in drivers/hwmon/Makefile
Replace EXTRA_CFLAGS with ccflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
This patch enables gcov kernel profiling over the whole kernel for sh.
Profiling of specific files individually already worked. A handful of
files have to be explicitly excluded from the profiling to avoid
breaking things, notably pmb.c.
Signed-off-by: Chris Smith <chris.smith@st.com>
Signed-off-by: Stuart Menefy <stuart.menefy@st.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
The gcov-kernel infrastructure expects that each object file is loaded
only once. This may not be true, e.g. when loading multiple kernel
modules which are linked to the same object file. As a result, loading
such kernel modules will result in incorrect gcov results while unloading
will cause a null-pointer dereference.
This patch fixes these problems by changing the gcov-kernel infrastructure
so that multiple profiling data sets can be associated with one debugfs
entry. It applies to 2.6.36-rc1.
Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com>
Reported-by: Werner Spies <werner.spies@thalesgroup.com>
Cc: <stable@kernel.org>
Make it possible to enable GCOV code coverage measurement on powerpc.
Lightly tested on 64-bit, seems to work as expected.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Enable gcov profiling of the entire kernel on x86_64. Required changes
include disabling profiling for:
* arch/kernel/acpi/realmode and arch/kernel/boot/compressed:
not linked to main kernel
* arch/vdso, arch/kernel/vsyscall_64 and arch/kernel/hpet:
profiling causes segfaults during boot (incompatible context)
Cc: Huang Ying <ying.huang@intel.com>
Cc: Li Wei <W.Li@Sun.COM>
Cc: Michael Ellerman <michaele@au1.ibm.com>
Cc: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Cc: Martin Schwidefsky <mschwid2@linux.vnet.ibm.com>
Cc: Jeff Dike <jdike@addtoit.com>
Enable the use of GCC's coverage testing tool gcov [1] with the Linux
kernel. gcov may be useful for:
* debugging (has this code been reached at all?)
* test improvement (how do I change my test to cover these lines?)
* minimizing kernel configurations (do I need this option if the
associated code is never run?)
The profiling patch incorporates the following changes:
* change kbuild to include profiling flags
* provide functions needed by profiling code
* present profiling data as files in debugfs
Note that on some architectures, enabling gcc's profiling option
"-fprofile-arcs" for the entire kernel may trigger compile/link/
run-time problems, some of which are caused by toolchain bugs and
others which require adjustment of architecture code.
For this reason profiling the entire kernel is initially restricted
to those architectures for which it is known to work without changes.
This restriction can be lifted once an architecture has been tested
and found compatible with gcc's profiling. Profiling of single files
or directories is still available on all platforms (see config help
text).
[1] http://gcc.gnu.org/onlinedocs/gcc/Gcov.html
