There's a race on CPU unplug where we free the swevent hash array
while it can still have events on. This will result in a
use-after-free which is BAD.
Simply do not free the hash array on unplug. This leaves the thing
around and no use-after-free takes place.
When the last swevent dies, we do a for_each_possible_cpu() iteration
anyway to clean these up, at which time we'll free it, so no leakage
will occur.
Bug 1823317
But 1935735
Change-Id: I309528873f8576f96663afbe51ce2739934df16c
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Tested-by: Sasha Levin <sasha.levin@oracle.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1259934
(cherry picked from commit 5ea640855404df656d94bfa3990d8eba2b5f90f9)
Reviewed-on: https://git-master.nvidia.com/r/1690284
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
commit e3703f8cdfcf39c25c4338c3ad8e68891cca3731 upstream.
Drew Richardson reported that he could make the kernel go *boom* when hotplugging
while having perf events active.
It turned out that when you have a group event, the code in
__perf_event_exit_context() fails to remove the group siblings from
the context.
We then proceed with destroying and freeing the event, and when you
re-plug the CPU and try and add another event to that CPU, things go
*boom* because you've still got dead entries there.
Reported-by: Drew Richardson <drew.richardson@arm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-k6v5wundvusvcseqj1si0oz0@git.kernel.org
commit bf378d341e4873ed928dc3c636252e6895a21f50 upstream.
The PPC64 people noticed a missing memory barrier and crufty old
comments in the perf ring buffer code. So update all the comments and
add the missing barrier.
When the architecture implements local_t using atomic_long_t there
will be double barriers issued; but short of introducing more
conditional barrier primitives this is the best we can do.
Reported-by: Victor Kaplansky <victork@il.ibm.com>
Tested-by: Victor Kaplansky <victork@il.ibm.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: michael@ellerman.id.au
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: Michael Neuling <mikey@neuling.org>
Cc: anton@samba.org
Cc: benh@kernel.crashing.org
Link: http://lkml.kernel.org/r/20131025173749.GG19466@laptop.lan
commit 878b5a6efd38030c7a90895dc8346e8fb1e09b4c upstream.
Currently utask->depth is simply the number of allocated/pending
return_instance's in uprobe_task->return_instances list.
handle_trampoline() should decrement this counter every time we
handle/free an instance, but due to typo it does this only if
->chained == T. This means that in the likely case this counter
is never decremented and the probed task can't report more than
MAX_URETPROBE_DEPTH events.
Reported-by: Mikhail Kulemin <Mikhail.Kulemin@ru.ibm.com>
Reported-by: Hemant Kumar Shaw <hkshaw@linux.vnet.ibm.com>
Acked-by: Anton Arapov <anton@redhat.com>
Cc: masami.hiramatsu.pt@hitachi.com
Cc: srikar@linux.vnet.ibm.com
Cc: systemtap@sourceware.org
Link: http://lkml.kernel.org/r/20130911154726.GA8093@redhat.com
commit 058ebd0eba3aff16b144eabf4510ed9510e1416e upstream.
Jiri managed to trigger this warning:
[] [ INFO: possible circular locking dependency detected ]
[] 3.10.0+ #228 Tainted: G W
[] p/6613 is trying to acquire lock:
[] (rcu_node_0){..-...}, at: [<ffffffff810ca797>] rcu_read_unlock_special+0xa7/0x250
[] but task is already holding lock:
[] (&ctx->lock){-.-...}, at: [<ffffffff810f2879>] perf_lock_task_context+0xd9/0x2c0
[] which lock already depends on the new lock.
[] the existing dependency chain (in reverse order) is:
[] -> #4 (&ctx->lock){-.-...}:
[] -> #3 (&rq->lock){-.-.-.}:
[] -> #2 (&p->pi_lock){-.-.-.}:
[] -> #1 (&rnp->nocb_gp_wq[1]){......}:
[] -> #0 (rcu_node_0){..-...}:
Paul was quick to explain that due to preemptible RCU we cannot call
rcu_read_unlock() while holding scheduler (or nested) locks when part
of the read side critical section was preemptible.
Therefore solve it by making the entire RCU read side non-preemptible.
Also pull out the retry from under the non-preempt to play nice with RT.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Helped-out-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
commit 06f417968beac6e6b614e17b37d347aa6a6b1d30 upstream.
The '!ctx->is_active' check has a valid scenario, so
there's no need for the warning.
The reason is that there's a time window between the
'ctx->is_active' check in the perf_event_enable() function
and the __perf_event_enable() function having:
- IRQs on
- ctx->lock unlocked
where the task could be killed and 'ctx' deactivated by
perf_event_exit_task(), ending up with the warning below.
So remove the WARN_ON_ONCE() check and add comments to
explain it all.
This addresses the following warning reported by Vince Weaver:
[ 324.983534] ------------[ cut here ]------------
[ 324.984420] WARNING: at kernel/events/core.c:1953 __perf_event_enable+0x187/0x190()
[ 324.984420] Modules linked in:
[ 324.984420] CPU: 19 PID: 2715 Comm: nmi_bug_snb Not tainted 3.10.0+ #246
[ 324.984420] Hardware name: Supermicro X8DTN/X8DTN, BIOS 4.6.3 01/08/2010
[ 324.984420] 0000000000000009 ffff88043fce3ec8 ffffffff8160ea0b ffff88043fce3f00
[ 324.984420] ffffffff81080ff0 ffff8802314fdc00 ffff880231a8f800 ffff88043fcf7860
[ 324.984420] 0000000000000286 ffff880231a8f800 ffff88043fce3f10 ffffffff8108103a
[ 324.984420] Call Trace:
[ 324.984420] <IRQ> [<ffffffff8160ea0b>] dump_stack+0x19/0x1b
[ 324.984420] [<ffffffff81080ff0>] warn_slowpath_common+0x70/0xa0
[ 324.984420] [<ffffffff8108103a>] warn_slowpath_null+0x1a/0x20
[ 324.984420] [<ffffffff81134437>] __perf_event_enable+0x187/0x190
[ 324.984420] [<ffffffff81130030>] remote_function+0x40/0x50
[ 324.984420] [<ffffffff810e51de>] generic_smp_call_function_single_interrupt+0xbe/0x130
[ 324.984420] [<ffffffff81066a47>] smp_call_function_single_interrupt+0x27/0x40
[ 324.984420] [<ffffffff8161fd2f>] call_function_single_interrupt+0x6f/0x80
[ 324.984420] <EOI> [<ffffffff816161a1>] ? _raw_spin_unlock_irqrestore+0x41/0x70
[ 324.984420] [<ffffffff8113799d>] perf_event_exit_task+0x14d/0x210
[ 324.984420] [<ffffffff810acd04>] ? switch_task_namespaces+0x24/0x60
[ 324.984420] [<ffffffff81086946>] do_exit+0x2b6/0xa40
[ 324.984420] [<ffffffff8161615c>] ? _raw_spin_unlock_irq+0x2c/0x30
[ 324.984420] [<ffffffff81087279>] do_group_exit+0x49/0xc0
[ 324.984420] [<ffffffff81096854>] get_signal_to_deliver+0x254/0x620
[ 324.984420] [<ffffffff81043057>] do_signal+0x57/0x5a0
[ 324.984420] [<ffffffff8161a164>] ? __do_page_fault+0x2a4/0x4e0
[ 324.984420] [<ffffffff8161665c>] ? retint_restore_args+0xe/0xe
[ 324.984420] [<ffffffff816166cd>] ? retint_signal+0x11/0x84
[ 324.984420] [<ffffffff81043605>] do_notify_resume+0x65/0x80
[ 324.984420] [<ffffffff81616702>] retint_signal+0x46/0x84
[ 324.984420] ---[ end trace 442ec2f04db3771a ]---
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1373384651-6109-2-git-send-email-jolsa@redhat.com
commit 734df5ab549ca44f40de0f07af1c8803856dfb18 upstream.
Currently when the child context for inherited events is
created, it's based on the pmu object of the first event
of the parent context.
This is wrong for the following scenario:
- HW context having HW and SW event
- HW event got removed (closed)
- SW event stays in HW context as the only event
and its pmu is used to clone the child context
The issue starts when the cpu context object is touched
based on the pmu context object (__get_cpu_context). In
this case the HW context will work with SW cpu context
ending up with following WARN below.
Fixing this by using parent context pmu object to clone
from child context.
Addresses the following warning reported by Vince Weaver:
[ 2716.472065] ------------[ cut here ]------------
[ 2716.476035] WARNING: at kernel/events/core.c:2122 task_ctx_sched_out+0x3c/0x)
[ 2716.476035] Modules linked in: nfsd auth_rpcgss oid_registry nfs_acl nfs locn
[ 2716.476035] CPU: 0 PID: 3164 Comm: perf_fuzzer Not tainted 3.10.0-rc4 #2
[ 2716.476035] Hardware name: AOpen DE7000/nMCP7ALPx-DE R1.06 Oct.19.2012, BI2
[ 2716.476035] 0000000000000000 ffffffff8102e215 0000000000000000 ffff88011fc18
[ 2716.476035] ffff8801175557f0 0000000000000000 ffff880119fda88c ffffffff810ad
[ 2716.476035] ffff880119fda880 ffffffff810af02a 0000000000000009 ffff880117550
[ 2716.476035] Call Trace:
[ 2716.476035] [<ffffffff8102e215>] ? warn_slowpath_common+0x5b/0x70
[ 2716.476035] [<ffffffff810ab2bd>] ? task_ctx_sched_out+0x3c/0x5f
[ 2716.476035] [<ffffffff810af02a>] ? perf_event_exit_task+0xbf/0x194
[ 2716.476035] [<ffffffff81032a37>] ? do_exit+0x3e7/0x90c
[ 2716.476035] [<ffffffff810cd5ab>] ? __do_fault+0x359/0x394
[ 2716.476035] [<ffffffff81032fe6>] ? do_group_exit+0x66/0x98
[ 2716.476035] [<ffffffff8103dbcd>] ? get_signal_to_deliver+0x479/0x4ad
[ 2716.476035] [<ffffffff810ac05c>] ? __perf_event_task_sched_out+0x230/0x2d1
[ 2716.476035] [<ffffffff8100205d>] ? do_signal+0x3c/0x432
[ 2716.476035] [<ffffffff810abbf9>] ? ctx_sched_in+0x43/0x141
[ 2716.476035] [<ffffffff810ac2ca>] ? perf_event_context_sched_in+0x7a/0x90
[ 2716.476035] [<ffffffff810ac311>] ? __perf_event_task_sched_in+0x31/0x118
[ 2716.476035] [<ffffffff81050dd9>] ? mmdrop+0xd/0x1c
[ 2716.476035] [<ffffffff81051a39>] ? finish_task_switch+0x7d/0xa6
[ 2716.476035] [<ffffffff81002473>] ? do_notify_resume+0x20/0x5d
[ 2716.476035] [<ffffffff813654f5>] ? retint_signal+0x3d/0x78
[ 2716.476035] ---[ end trace 827178d8a5966c3d ]---
Link: http://lkml.kernel.org/r/1373384651-6109-1-git-send-email-jolsa@redhat.com
fetch_bp_busy_slots() and toggle_bp_slot() use
for_each_online_cpu(), this is obviously wrong wrt cpu_up() or
cpu_down(), we can over/under account the per-cpu numbers.
For example:
# echo 0 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10 -p 1 &
# echo 1 >> /sys/devices/system/cpu/cpu1/online
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10 -C1 -a &
# taskset -p 0x2 1
triggers the same WARN_ONCE("Can't find any breakpoint slot") in
arch_install_hw_breakpoint().
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20130620155009.GA6327@redhat.com
trinity fuzzer triggered WARN_ONCE("Can't find any breakpoint
slot") in arch_install_hw_breakpoint() but the problem is not
arch-specific.
The problem is, task_bp_pinned(cpu) checks "cpu == iter->cpu"
but this doesn't account the "all cpus" events with iter->cpu <
0.
This means that, say, register_user_hw_breakpoint(tsk) can
happily create the arbitrary number > HBP_NUM of breakpoints
which can not be activated. toggle_bp_task_slot() is equally
wrong by the same reason and nr_task_bp_pinned[] can have
negative entries.
Simple test:
# perl -e 'sleep 1 while 1' &
# perf record -e mem:0x10,mem:0x10,mem:0x10,mem:0x10,mem:0x10 -p `pidof perl`
Before this patch this triggers the same problem/WARN_ON(),
after the patch it correctly fails with -ENOSPC.
Link: http://lkml.kernel.org/r/20130620155006.GA6324@redhat.com
Vince's fuzzer once again found holes. This time it spotted a leak in
the locked page accounting.
When an event had redirected output and its close() was the last
reference to the buffer we didn't have a vm context to undo accounting.
Change the code to destroy the buffer on the last munmap() and detach
all redirected events at that time. This provides us the right context
to undo the vm accounting.
Reported-and-tested-by: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/20130604084421.GI8923@twins.programming.kicks-ass.net
Cc: <stable@kernel.org>
Vince reported a problem found by his perf specific trinity
fuzzer.
Al noticed 2 problems with perf's mmap():
- it has issues against fork() since we use vma->vm_mm for accounting.
- it has an rb refcount leak on double mmap().
We fix the issues against fork() by using VM_DONTCOPY; I don't
think there's code out there that uses this; we didn't hear
about weird accounting problems/crashes. If we do need this to
work, the previously proposed VM_PINNED could make this work.
Aside from the rb reference leak spotted by Al, Vince's example
prog was indeed doing a double mmap() through the use of
perf_event_set_output().
This exposes another problem, since we now have 2 events with
one buffer, the accounting gets screwy because we account per
event. Fix this by making the buffer responsible for its own
accounting.
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130528085548.GA12193@twins.programming.kicks-ass.net
Add perf_event_aux() function to send out all types of
auxiliary events - mmap, task, comm events. For each type
there's match and output functions defined and used as
callbacks during perf_event_aux processing.
This way we can centralize the pmu/context iterating and
event matching logic. Also since lot of the code was
duplicated, this patch reduces the .text size about 2kB
on my setup:
snipped output from 'objdump -x kernel/events/core.o'
before:
Idx Name Size
0 .text 0000d313
after:
Idx Name Size
0 .text 0000cad3
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/1367857638-27631-3-git-send-email-jolsa@redhat.com
The perf_event_task_ctx() function needs to be called with
preemption disabled, since it's checking for currently
scheduled cpu against event cpu.
We disable preemption for task related perf event context
if there's one defined, leaving up to the chance which cpu
it gets scheduled in.
Link: http://lkml.kernel.org/r/1367857638-27631-2-git-send-email-jolsa@redhat.com
Pull 'full dynticks' support from Ingo Molnar:
"This tree from Frederic Weisbecker adds a new, (exciting! :-) core
kernel feature to the timer and scheduler subsystems: 'full dynticks',
or CONFIG_NO_HZ_FULL=y.
This feature extends the nohz variable-size timer tick feature from
idle to busy CPUs (running at most one task) as well, potentially
reducing the number of timer interrupts significantly.
This feature got motivated by real-time folks and the -rt tree, but
the general utility and motivation of full-dynticks runs wider than
that:
- HPC workloads get faster: CPUs running a single task should be able
to utilize a maximum amount of CPU power. A periodic timer tick at
HZ=1000 can cause a constant overhead of up to 1.0%. This feature
removes that overhead - and speeds up the system by 0.5%-1.0% on
typical distro configs even on modern systems.
- Real-time workload latency reduction: CPUs running critical tasks
should experience as little jitter as possible. The last remaining
source of kernel-related jitter was the periodic timer tick.
- A single task executing on a CPU is a pretty common situation,
especially with an increasing number of cores/CPUs, so this feature
helps desktop and mobile workloads as well.
The cost of the feature is mainly related to increased timer
reprogramming overhead when a CPU switches its tick period, and thus
slightly longer to-idle and from-idle latency.
Configuration-wise a third mode of operation is added to the existing
two NOHZ kconfig modes:
- CONFIG_HZ_PERIODIC: [formerly !CONFIG_NO_HZ], now explicitly named
as a config option. This is the traditional Linux periodic tick
design: there's a HZ tick going on all the time, regardless of
whether a CPU is idle or not.
- CONFIG_NO_HZ_IDLE: [formerly CONFIG_NO_HZ=y], this turns off the
periodic tick when a CPU enters idle mode.
- CONFIG_NO_HZ_FULL: this new mode, in addition to turning off the
tick when a CPU is idle, also slows the tick down to 1 Hz (one
timer interrupt per second) when only a single task is running on a
CPU.
The .config behavior is compatible: existing !CONFIG_NO_HZ and
CONFIG_NO_HZ=y settings get translated to the new values, without the
user having to configure anything. CONFIG_NO_HZ_FULL is turned off by
default.
This feature is based on a lot of infrastructure work that has been
steadily going upstream in the last 2-3 cycles: related RCU support
and non-periodic cputime support in particular is upstream already.
This tree adds the final pieces and activates the feature. The pull
request is marked RFC because:
- it's marked 64-bit only at the moment - the 32-bit support patch is
small but did not get ready in time.
- it has a number of fresh commits that came in after the merge
window. The overwhelming majority of commits are from before the
merge window, but still some aspects of the tree are fresh and so I
marked it RFC.
- it's a pretty wide-reaching feature with lots of effects - and
while the components have been in testing for some time, the full
combination is still not very widely used. That it's default-off
should reduce its regression abilities and obviously there are no
known regressions with CONFIG_NO_HZ_FULL=y enabled either.
- the feature is not completely idempotent: there is no 100%
equivalent replacement for a periodic scheduler/timer tick. In
particular there's ongoing work to map out and reduce its effects
on scheduler load-balancing and statistics. This should not impact
correctness though, there are no known regressions related to this
feature at this point.
- it's a pretty ambitious feature that with time will likely be
enabled by most Linux distros, and we'd like you to make input on
its design/implementation, if you dislike some aspect we missed.
Without flaming us to crisp! :-)
Future plans:
- there's ongoing work to reduce 1Hz to 0Hz, to essentially shut off
the periodic tick altogether when there's a single busy task on a
CPU. We'd first like 1 Hz to be exposed more widely before we go
for the 0 Hz target though.
- once we reach 0 Hz we can remove the periodic tick assumption from
nr_running>=2 as well, by essentially interrupting busy tasks only
as frequently as the sched_latency constraints require us to do -
once every 4-40 msecs, depending on nr_running.
I am personally leaning towards biting the bullet and doing this in
v3.10, like the -rt tree this effort has been going on for too long -
but the final word is up to you as usual.
More technical details can be found in Documentation/timers/NO_HZ.txt"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits)
sched: Keep at least 1 tick per second for active dynticks tasks
rcu: Fix full dynticks' dependency on wide RCU nocb mode
nohz: Protect smp_processor_id() in tick_nohz_task_switch()
nohz_full: Add documentation.
cputime_nsecs: use math64.h for nsec resolution conversion helpers
nohz: Select VIRT_CPU_ACCOUNTING_GEN from full dynticks config
nohz: Reduce overhead under high-freq idling patterns
nohz: Remove full dynticks' superfluous dependency on RCU tree
nohz: Fix unavailable tick_stop tracepoint in dynticks idle
nohz: Add basic tracing
nohz: Select wide RCU nocb for full dynticks
nohz: Disable the tick when irq resume in full dynticks CPU
nohz: Re-evaluate the tick for the new task after a context switch
nohz: Prepare to stop the tick on irq exit
nohz: Implement full dynticks kick
nohz: Re-evaluate the tick from the scheduler IPI
sched: New helper to prevent from stopping the tick in full dynticks
sched: Kick full dynticks CPU that have more than one task enqueued.
perf: New helper to prevent full dynticks CPUs from stopping tick
perf: Kick full dynticks CPU if events rotation is needed
Pull perf fixes from Ingo Molnar:
"Misc fixes plus a small hw-enablement patch for Intel IB model 58
uncore events"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel/lbr: Demand proper privileges for PERF_SAMPLE_BRANCH_KERNEL
perf/x86/intel/lbr: Fix LBR filter
perf/x86: Blacklist all MEM_*_RETIRED events for Ivy Bridge
perf: Fix vmalloc ring buffer pages handling
perf/x86/intel: Fix unintended variable name reuse
perf/x86/intel: Add support for IvyBridge model 58 Uncore
perf/x86/intel: Fix typo in perf_event_intel_uncore.c
x86: Eliminate irq_mis_count counted in arch_irq_stat
The full dynticks tree needs the latest RCU and sched
upstream updates in order to fix some dependencies.
Merge a common upstream merge point that has these
updates.
include/linux/perf_event.h
kernel/rcutree.h
kernel/rcutree_plugin.h
If we allocate perf ring buffer with the size of single (user)
page, we will get memory corruption when releasing itin
rb_free_work function (for CONFIG_PERF_USE_VMALLOC option).
For single page sized ring buffer the page_order is -1 (because
nr_pages is 0). This needs to be recognized in the rb_free_work
function to release proper amount of pages.
Adding data_page_nr function that returns number of allocated
data pages. Customizing the rest of the code to use it.
Reported-by: Jan Stancek <jstancek@redhat.com>
Original-patch-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Link: http://lkml.kernel.org/r/20130319143509.GA1128@krava.brq.redhat.com
Pull perf updates from Ingo Molnar:
"Features:
- Add "uretprobes" - an optimization to uprobes, like kretprobes are
an optimization to kprobes. "perf probe -x file sym%return" now
works like kretprobes. By Oleg Nesterov.
- Introduce per core aggregation in 'perf stat', from Stephane
Eranian.
- Add memory profiling via PEBS, from Stephane Eranian.
- Event group view for 'annotate' in --stdio, --tui and --gtk, from
Namhyung Kim.
- Add support for AMD NB and L2I "uncore" counters, by Jacob Shin.
- Add Ivy Bridge-EP uncore support, by Zheng Yan
- IBM zEnterprise EC12 oprofile support patchlet from Robert Richter.
- Add perf test entries for checking breakpoint overflow signal
handler issues, from Jiri Olsa.
- Add perf test entry for for checking number of EXIT events, from
Namhyung Kim.
- Add perf test entries for checking --cpu in record and stat, from
Jiri Olsa.
- Introduce perf stat --repeat forever, from Frederik Deweerdt.
- Add --no-demangle to report/top, from Namhyung Kim.
- PowerPC fixes plus a couple of cleanups/optimizations in uprobes
and trace_uprobes, by Oleg Nesterov.
Various fixes and refactorings:
- Fix dependency of the python binding wrt libtraceevent, from
Naohiro Aota.
- Simplify some perf_evlist methods and to allow 'stat' to share code
with 'record' and 'trace', by Arnaldo Carvalho de Melo.
- Remove dead code in related to libtraceevent integration, from
Namhyung Kim.
- Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf
sched lat' back working, by Arnaldo Carvalho de Melo
- We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho
de Melo.
- Kill a bunch of die() calls, from Namhyung Kim.
- Fix build on non-glibc systems due to libio.h absence, from Cody P
Schafer.
- Remove some perf_session and tracing dead code, from David Ahern.
- Honor parallel jobs, fix from Borislav Petkov
- Introduce tools/lib/lk library, initially just removing duplication
among tools/perf and tools/vm. from Borislav Petkov
... and many more I missed to list, see the shortlog and git log for
more details."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits)
perf/x86/intel/P4: Robistify P4 PMU types
perf/x86/amd: Fix AMD NB and L2I "uncore" support
perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c
perf/x86: Check all MSRs before passing hw check
perf/x86/amd: Add support for AMD NB and L2I "uncore" counters
perf/x86/intel: Add Ivy Bridge-EP uncore support
perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management
perf/x86: Avoid kfree() in CPU_{STARTING,DYING}
uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty
uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit()
uprobes/tracing: Change create_trace_uprobe() to support uretprobes
uprobes/tracing: Make seq_printf() code uretprobe-friendly
uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly
uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly
uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher()
uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers
uprobes/tracing: Generalize struct uprobe_trace_entry_head
uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls
uprobes/tracing: Kill the pointless seq_print_ip_sym() call
uprobes/tracing: Kill the pointless task_pt_regs() calls
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- Fixes and a lot of cleanups. Locking cleanup is finally complete.
cgroup_mutex is no longer exposed to individual controlelrs which
used to cause nasty deadlock issues. Li fixed and cleaned up quite a
bit including long standing ones like racy cgroup_path().
- device cgroup now supports proper hierarchy thanks to Aristeu.
- perf_event cgroup now supports proper hierarchy.
- A new mount option "__DEVEL__sane_behavior" is added. As indicated
by the name, this option is to be used for development only at this
point and generates a warning message when used. Unfortunately,
cgroup interface currently has too many brekages and inconsistencies
to implement a consistent and unified hierarchy on top. The new flag
is used to collect the behavior changes which are necessary to
implement consistent unified hierarchy. It's likely that this flag
won't be used verbatim when it becomes ready but will be enabled
implicitly along with unified hierarchy.
The option currently disables some of broken behaviors in cgroup core
and also .use_hierarchy switch in memcg (will be routed through -mm),
which can be used to make very unusual hierarchy where nesting is
partially honored. It will also be used to implement hierarchy
support for blk-throttle which would be impossible otherwise without
introducing a full separate set of control knobs.
This is essentially versioning of interface which isn't very nice but
at this point I can't see any other options which would allow keeping
the interface the same while moving towards hierarchy behavior which
is at least somewhat sane. The planned unified hierarchy is likely
to require some level of adaptation from userland anyway, so I think
it'd be best to take the chance and update the interface such that
it's supportable in the long term.
Maintaining the existing interface does complicate cgroup core but
shouldn't put too much strain on individual controllers and I think
it'd be manageable for the foreseeable future. Maybe we'll be able
to drop it in a decade.
Fix up conflicts (including a semantic one adding a new #include to ppc
that was uncovered by header the file changes) as per Tejun.
* 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (45 commits)
cpuset: fix compile warning when CONFIG_SMP=n
cpuset: fix cpu hotplug vs rebuild_sched_domains() race
cpuset: use rebuild_sched_domains() in cpuset_hotplug_workfn()
cgroup: restore the call to eventfd->poll()
cgroup: fix use-after-free when umounting cgroupfs
cgroup: fix broken file xattrs
devcg: remove parent_cgroup.
memcg: force use_hierarchy if sane_behavior
cgroup: remove cgrp->top_cgroup
cgroup: introduce sane_behavior mount option
move cgroupfs_root to include/linux/cgroup.h
cgroup: convert cgroupfs_root flag bits to masks and add CGRP_ prefix
cgroup: make cgroup_path() not print double slashes
Revert "cgroup: remove bind() method from cgroup_subsys."
perf: make perf_event cgroup hierarchical
cgroup: implement cgroup_is_descendant()
cgroup: make sure parent won't be destroyed before its children
devcg: remove broken_hierarchy tag
cgroup: remove cgroup_lock_is_held()
Provide a new helper that help full dynticks CPUs to prevent
from stopping their tick in case there are events in the local
rotation list.
This way we make sure that perf_event_task_tick() is serviced
on demand.
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Gilad Ben Yossef <gilad@benyossef.com>
Cc: Hakan Akkan <hakanakkan@gmail.com>
Cc: Kevin Hilman <khilman@linaro.org>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Kick the current CPU's tick by sending it a self IPI when
an event is queued on the rotation list and it is the first
element inserted. This makes sure that perf_event_task_tick()
works on full dynticks CPUs.
The following RCU splat indicates lack of RCU protection:
[ 953.267649] ===============================
[ 953.267652] [ INFO: suspicious RCU usage. ]
[ 953.267657] 3.9.0-0.rc6.git2.4.fc19.ppc64p7 #1 Not tainted
[ 953.267661] -------------------------------
[ 953.267664] include/linux/cgroup.h:534 suspicious rcu_dereference_check() usage!
[ 953.267669]
[ 953.267669] other info that might help us debug this:
[ 953.267669]
[ 953.267675]
[ 953.267675] rcu_scheduler_active = 1, debug_locks = 0
[ 953.267680] 1 lock held by glxgears/1289:
[ 953.267683] #0: (&sig->cred_guard_mutex){+.+.+.}, at: [<c00000000027f884>] .prepare_bprm_creds+0x34/0xa0
[ 953.267700]
[ 953.267700] stack backtrace:
[ 953.267704] Call Trace:
[ 953.267709] [c0000001f0d1b6e0] [c000000000016e30] .show_stack+0x130/0x200 (unreliable)
[ 953.267717] [c0000001f0d1b7b0] [c0000000001267f8] .lockdep_rcu_suspicious+0x138/0x180
[ 953.267724] [c0000001f0d1b840] [c0000000001d43a4] .perf_event_comm+0x4c4/0x690
[ 953.267731] [c0000001f0d1b950] [c00000000027f6e4] .set_task_comm+0x84/0x1f0
[ 953.267737] [c0000001f0d1b9f0] [c000000000280414] .setup_new_exec+0x94/0x220
[ 953.267744] [c0000001f0d1ba70] [c0000000002f665c] .load_elf_binary+0x58c/0x19b0
This commit therefore adds the required RCU read-side critical
section to perf_event_comm().
Reported-by: Adam Jackson <ajax@redhat.com>
Cc: a.p.zijlstra@chello.nl
Cc: paulus@samba.org
Cc: acme@ghostprotocols.net
Link: http://lkml.kernel.org/r/20130419190124.GA8638@linux.vnet.ibm.com
Tested-by: Gustavo Luiz Duarte <gusld@br.ibm.com>
arch/x86/kernel/cpu/perf_event_intel.c
Merge in the latest fixes before applying new patches, resolve the conflict.
Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: davej@redhat.com
Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com
Enclose return probes implementation.
Signed-off-by: Anton Arapov <anton@redhat.com>
Acked-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Unlike the kretprobes we can't trust userspace, thus must have
protection from user space attacks. User-space have "unlimited"
stack, and this patch limits the return probes nestedness as a
simple remedy for it.
Note that this implementation leaks return_instance on siglongjmp
until exit()/exec().
The intention is to have KISS and bare minimum solution for the
initial implementation in order to not complicate the uretprobes
code.
In the future we may come up with more sophisticated solution that
remove this depth limitation. It is not easy task and lays beyond
this patchset.
Uretprobe handlers are invoked when the trampoline is hit, on completion
the trampoline is replaced with the saved return address and the uretprobe
instance deleted.
TODO: handle_trampoline() assumes that ->return_instances is always valid.
We should teach it to handle longjmp() which can invalidate the pending
return_instance's. This is nontrivial, we will try to do this in a separate
series.
When a uprobe with return probe consumer is hit, prepare_uretprobe()
function is invoked. It creates return_instance, hijacks return address
and replaces it with the trampoline.
* Return instances are kept as stack per uprobed task.
* Return instance is chained, when the original return address is
trampoline's page vaddr (e.g. recursive call of the probed function).
Allocate trampoline page, as the very first one in uprobed
task xol area, and fill it with breakpoint opcode.
Also introduce get_trampoline_vaddr() helper, to wrap the
trampoline address extraction from area->vaddr. That removes
confusion and eases the debug experience in case ->vaddr
notion will be changed.
Enclose return probes implementation, introduce ->ret_handler() and update
existing code to rely on ->handler() *and* ->ret_handler() for uprobe and
uretprobe respectively.
Fix to return -ENOMEM in the allocation error case instead of 0
(if pmu_bus_running == 1), as done elsewhere in this function.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Link: http://lkml.kernel.org/r/CAPgLHd8j_fWcgqe%3DKLWjpBj%2B%3Do0Pw6Z-SEq%3DNTPU08c2w1tngQ@mail.gmail.com
[ Tweaked the error code setting placement and the changelog. ]
perf_event is one of a couple remaining cgroup controllers with broken
hierarchy support. Converting it to support hierarchy is almost
trivial. The only thing necessary is to consider a task belonging to
a descendant cgroup as a match. IOW, if the cgroup of the currently
executing task (@cpuctx->cgrp) equals or is a descendant of the
event's cgroup (@event->cgrp), then the event should be enabled.
Implement hierarchy support and remove .broken_hierarchy tag along
with the incorrect comment on what needs to be done for hierarchy
support.
Cc: Namhyung Kim <namhyung.kim@lge.com>
For NUL terminated string, always make sure that there's '\0' at the end.
In our case we need a return value, so still use strncpy() and
fix up the tail explicitly.
(strlcpy() returns the size, not the pointer)
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Cc: a.p.zijlstra@chello.nl <a.p.zijlstra@chello.nl>
Cc: paulus@samba.org <paulus@samba.org>
Cc: acme@ghostprotocols.net <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/51623E0B.7070101@asianux.com
Change write_opcode() to use copy_highpage() + copy_to_page()
and simplify the code.
Extract the kmap_atomic/memcpy/kunmap_atomic code from
xol_get_insn_slot() into the new simple helper, copy_to_page().
It will have more users soon.
__copy_insn(filp) can only be called after valid_vma() returns T,
vma->vm_file passed as "filp" can not be NULL.
Change __copy_insn() to use copy_from_page() and simplify the code.
No functional changes. Rename copy_opcode() into copy_from_page() and
add the new "int len" argument to make it more more generic for the
new users.
Some architectures like powerpc have multiple variants of the trap
instruction. Introduce an additional helper is_trap_insn() for run-time
handling of non-uprobe traps on such architectures.
While there, change is_swbp_at_addr() to is_trap_at_addr() for reading
clarity.
With this change, the uprobe registration path will supercede any trap
instruction inserted at the requested location, while taking care of
delivering the SIGTRAP for cases where the trap notification came in
for an address without a uprobe. See [1] for a more detailed explanation.
[1] https://lists.ozlabs.org/pipermail/linuxppc-dev/2013-March/104771.html
This change was suggested by Oleg Nesterov.
Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cleanup. Now that we have f_inode/file_inode() we can use it instead
of vm_file->f_mapping->host.
This should not make any difference for uprobes, but in theory this
change is more correct. We use this inode as a key, to compare it
with uprobe->inode set by uprobe_register(inode), and the caller uses
d_inode.
Type of mapping was lost and made it hard for a tool
to distinguish code vs. data mmaps. Perf has the ability
to distinguish the two.
Use a bit in the header->misc bitmask to keep track of
the mmap type. If PERF_RECORD_MISC_MMAP_DATA is set then
the mapping is not executable (!VM_EXEC). If not set, then
the mapping is executable.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: peterz@infradead.org
Cc: ak@linux.intel.com
Cc: acme@redhat.com
Cc: jolsa@redhat.com
Cc: namhyung.kim@lge.com
Link: http://lkml.kernel.org/r/1359040242-8269-16-git-send-email-eranian@google.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This patch adds PERF_SAMPLE_DATA_SRC.
PERF_SAMPLE_DATA_SRC collects the data source, i.e., where
did the data associated with the sampled instruction
come from. Information is stored in a perf_mem_data_src
structure. It contains opcode, mem level, tlb, snoop,
lock information, subject to availability in hardware.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1359040242-8269-8-git-send-email-eranian@google.com
For some events it's useful to weight sample with a hardware
provided number. This expresses how expensive the action the
sample represent was. This allows the profiler to scale
the samples to be more informative to the programmer.
There is already the period which is used similarly, but it
means something different, so I chose to not overload it.
Instead a new sample type for WEIGHT is added.
Can be used for multiple things. Initially it is used for TSX
abort costs and profiling by memory latencies (so to make
expensive load appear higher up in the histograms). The concept
is quite generic and can be extended to many other kinds of
events or architectures, as long as the hardware provides
suitable auxillary values. In principle it could be also used
for software tracepoints.
This adds the generic glue. A new optional sample format for a
64-bit weight value.
Cc: acme@redhat.com
Link: http://lkml.kernel.org/r/1359040242-8269-5-git-send-email-eranian@google.com
This patch fixes a flaw in perf_output_space(). In case the size
of the space needed is bigger than the actual buffer size, there
may be situations where the function would return true (i.e.,
there is space) when it should not. head > offset due to
rounding of the masking logic.
The problem can be tested by activating BTS on Intel processors.
A BTS record can be as big as 16 pages. The following command
fails:
$ perf record -m 4 -c 1 -e branches:u my_test_program
You will get a buffer corruption with this. Perf report won't be
able to parse the perf.data.
The fix is to first check that the requested space is smaller
than the buffer size. If so, then the masking logic will work
fine. If not, then there is no chance the record can be saved
and it will be gracefully handled by upper code layers.
[ In v2, we also make the logic for the writable more explicit by
renaming it to rb->overwrite because it tells whether or not the
buffer can overwrite its tail (suggested by PeterZ). ]
Cc: fweisbec@gmail.com
Link: http://lkml.kernel.org/r/20130318133327.GA3056@quad
Merge in all pending fixes, before pulling the latest development
bits from Arnaldo - which will involve merge conflicts.
It's a per-cpu data structure but missed the __percpu annotation.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: Li Zefan <lizefan@huawei.com>
Link: http://lkml.kernel.org/r/1363600594-11453-1-git-send-email-namhyung@kernel.org
perf_event_task_event() iterates pmu list and generate events
for each eligible pmu context. But if task_event has task_ctx
like in EXIT it'll generate events even though the pmu doesn't
have an eligible one. Fix it by moving the code to proper
places.
Before this patch:
$ perf record -n true
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.006 MB perf.data (~248 samples) ]
$ perf report -D | tail
Aggregated stats:
TOTAL events: 73
MMAP events: 67
COMM events: 2
EXIT events: 4
cycles stats:
TOTAL events: 73
MMAP events: 67
COMM events: 2
EXIT events: 4
After this patch:
Aggregated stats:
TOTAL events: 70
MMAP events: 67
COMM events: 2
EXIT events: 1
cycles stats:
TOTAL events: 70
MMAP events: 67
COMM events: 2
EXIT events: 1
Link: http://lkml.kernel.org/r/1363332433-7637-1-git-send-email-namhyung@kernel.org
When cpu/task clock events are initialized, their sampling
frequencies are converted to have a fixed value. However it
missed to update the hwc->last_period which was set to 1 for
initial sampling frequency calibration.
Because this hwc->last_period value is used as a period in
perf_swevent_ hrtime(), every recorded sample will have an
incorrected period of 1.
$ perf record -e task-clock noploop 1
[ perf record: Captured and wrote 0.158 MB perf.data (~6919 samples) ]
$ perf report -n --show-total-period --stdio
# Samples: 4K of event 'task-clock'
# Event count (approx.): 4000
# Overhead Samples Period Command Shared Object Symbol
99.95% 3998 3998 noploop noploop [.] main
0.03% 1 1 noploop libc-2.15.so [.] init_cacheinfo
0.03% 1 1 noploop ld-2.15.so [.] open_verify
Note that it doesn't affect the non-sampling event so that the
perf stat still gets correct value with or without this patch.
$ perf stat -e task-clock noploop 1
Performance counter stats for 'noploop 1':
1000.272525 task-clock # 1.000 CPUs utilized
1.000560605 seconds time elapsed
Link: http://lkml.kernel.org/r/1363574507-18808-1-git-send-email-namhyung@kernel.org
Move struct perf_cgroup_info and perf_cgroup to
kernel/perf/core.c, and then we can remove include of cgroup.h.
Signed-off-by: Li Zefan <lizefan@huawei.com>
Link: http://lkml.kernel.org/r/513568A0.6020804@huawei.com
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
