SFR reported this 2013-05-15:
> After merging the final tree, today's linux-next build (i386 defconfig)
> produced this warning:
> kernel/auditfilter.c: In function 'audit_data_to_entry':
> kernel/auditfilter.c:426:3: warning: this decimal constant is unsigned only
> in ISO C90 [enabled by default]
> Introduced by commit 780a7654cee8 ("audit: Make testing for a valid
> loginuid explicit") from Linus' tree.
Replace this decimal constant in the code with a macro to make it more readable
(add to the unsigned cast to quiet the warning).
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
(cherry picked from commit 42f74461a5b60cf6b42887e6d2ff5b7be4abf1ca)
Change-Id: Ic6bf1f225cb8d8d9678b209a963bacfa8d9b0216
Signed-off-by: Philip Rakity <prakity@nvidia.com>
Reviewed-on: http://git-master/r/361012
Fix kernel-doc warnings in kernel/auditfilter.c:
Warning(kernel/auditfilter.c:1029): Excess function parameter 'loginuid' description in 'audit_receive_filter'
Warning(kernel/auditfilter.c:1029): Excess function parameter 'sessionid' description in 'audit_receive_filter'
Warning(kernel/auditfilter.c:1029): Excess function parameter 'sid' description in 'audit_receive_filter'
Cc: Eric Paris <eparis@redhat.com>
Pull audit changes from Eric Paris:
"Al used to send pull requests every couple of years but he told me to
just start pushing them to you directly.
Our touching outside of core audit code is pretty straight forward. A
couple of interface changes which hit net/. A simple argument bug
calling audit functions in namei.c and the removal of some assembly
branch prediction code on ppc"
* git://git.infradead.org/users/eparis/audit: (31 commits)
audit: fix message spacing printing auid
Revert "audit: move kaudit thread start from auditd registration to kaudit init"
audit: vfs: fix audit_inode call in O_CREAT case of do_last
audit: Make testing for a valid loginuid explicit.
audit: fix event coverage of AUDIT_ANOM_LINK
audit: use spin_lock in audit_receive_msg to process tty logging
audit: do not needlessly take a lock in tty_audit_exit
audit: do not needlessly take a spinlock in copy_signal
audit: add an option to control logging of passwords with pam_tty_audit
audit: use spin_lock_irqsave/restore in audit tty code
helper for some session id stuff
audit: use a consistent audit helper to log lsm information
audit: push loginuid and sessionid processing down
audit: stop pushing loginid, uid, sessionid as arguments
audit: remove the old depricated kernel interface
audit: make validity checking generic
audit: allow checking the type of audit message in the user filter
audit: fix build break when AUDIT_DEBUG == 2
audit: remove duplicate export of audit_enabled
Audit: do not print error when LSMs disabled
audit rule additions containing "-F auid!=4294967295" were failing
with EINVAL because of a regression caused by e1760bd.
Apparently some userland audit rule sets want to know if loginuid uid
has been set and are using a test for auid != 4294967295 to determine
that.
In practice that is a horrible way to ask if a value has been set,
because it relies on subtle implementation details and will break
every time the uid implementation in the kernel changes.
So add a clean way to test if the audit loginuid has been set, and
silently convert the old idiom to the cleaner and more comprehensible
new idiom.
Cc: <stable@vger.kernel.org> # 3.7
Reported-By: Richard Guy Briggs <rgb@redhat.com>
Tested-by: Richard Guy Briggs <rgb@redhat.com>
We have a number of places we were reimplementing the same code to write
out lsm labels. Just do it one darn place.
We always use current. Stop pulling this when the skb comes in and
pushing it around as arguments. Just get it at the end when you need
it.
We used to have an inflexible mechanism to add audit rules to the
kernel. It hasn't been used in a long time. Get rid of that stuff.
We have 2 interfaces to send audit rules. Rather than check validity of
things in 2 places make a helper function.
In audit_data_to_entry() when a failure occurs we must check and free
the tree and watch to avoid a memory leak.
test:
plan:
test command:
"auditctl -a exit,always -w /etc -F auid=-1"
(on fedora17, need modify auditctl to let "-w /etc" has effect)
running:
under fedora17 x86_64, 2 CPUs 3.20GHz, 2.5GB RAM.
let 15 auditctl processes continue running at the same time.
monitor command:
watch -d -n 1 "cat /proc/meminfo | awk '{print \$2}' \
| head -n 4 | xargs \
| awk '{print \"used \",\$1 - \$2 - \$3 - \$4}'"
result:
for original version:
will use up all memory, within 3 hours.
kill all auditctl, the memory still does not free.
for new version (apply this patch):
after 14 hours later, not find issues.
Signed-off-by: Chen Gang <gang.chen@asianux.com>
When userspace sends messages to the audit system it includes a type.
We want to be able to filter messages based on that type without have to
do the all or nothing option currently available on the
AUDIT_FILTER_TYPE filter list. Instead we should be able to use the
AUDIT_FILTER_USER filter list and just use the message type as one part
of the matching decision.
Fix new kernel-doc warning in auditfilter.c:
Warning(kernel/auditfilter.c:1157): Excess function parameter 'uid' description in 'audit_receive_filter'
Cc: linux-audit@redhat.com (subscribers-only)
In the cases where we already know the length of the parent, pass it as
a parm so we don't need to recompute it. In the cases where we don't
know the length, pass in AUDIT_NAME_FULL (-1) to indicate that it should
be determined.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
All the callers set this to NULL now.
Currently, this gets set mostly by happenstance when we call into
audit_inode_child. While that might be a little more efficient, it seems
wrong. If the syscall ends up failing before audit_inode_child ever gets
called, then you'll have an audit_names record that shows the full path
but has the parent inode info attached.
Fix this by passing in a parent flag when we call audit_inode that gets
set to the value of LOOKUP_PARENT. We can then fix up the pathname for
the audit entry correctly from the get-go.
While we're at it, clean up the no-op macro for audit_inode in the
!CONFIG_AUDITSYSCALL case.
Always store audit loginuids in type kuid_t.
Print loginuids by converting them into uids in the appropriate user
namespace, and then printing the resulting uid.
Modify audit_get_loginuid to return a kuid_t.
Modify audit_set_loginuid to take a kuid_t.
Modify /proc/<pid>/loginuid on read to convert the loginuid into the
user namespace of the opener of the file.
Modify /proc/<pid>/loginud on write to convert the loginuid
rom the user namespace of the opener of the file.
Cc: Paul Moore <paul@paul-moore.com> ?
The audit filter code guarantees that uid are always compared with
uids and gids are always compared with gids, as the comparason
operations are type specific. Take advantage of this proper to define
audit_uid_comparator and audit_gid_comparator which use the type safe
comparasons from uidgid.h.
Build on audit_uid_comparator and audit_gid_comparator and replace
audit_compare_id with audit_compare_uid and audit_compare_gid. This
is one of those odd cases where being type safe and duplicating code
leads to simpler shorter and more concise code.
Don't allow bitmask operations in uid and gid comparisons in
audit_data_to_entry. Bitmask operations are already denined in
audit_rule_to_entry.
Convert constants in audit_rule_to_entry and audit_data_to_entry into
kuids and kgids when appropriate.
Convert the uid and gid field in struct audit_names to be of type
kuid_t and kgid_t respectively, so that the new uid and gid comparators
can be applied in a type safe manner.
Get caller process uid and gid and pid values from the current task
instead of the NETLINK_CB. This is simpler than passing NETLINK_CREDS
from from audit_receive_msg to audit_filter_user_rules and avoid the
chance of being hit by the occassional bugs in netlink uid/gid
credential passing. This is a safe changes because all netlink
requests are processed in the task of the sending process.
We wish to be able to audit when a uid=500 task accesses a file which is
uid=0. Or vice versa. This patch introduces a new audit filter type
AUDIT_FIELD_COMPARE which takes as an 'enum' which indicates which fields
should be compared. At this point we only define the task->uid vs
inode->uid, but other comparisons can be added.
Much like the ability to filter audit on the uid of an inode collected, we
should be able to filter on the gid of the inode.
Allow syscall exit filter matching based on the uid of the owner of an
inode used in a syscall. aka:
auditctl -a always,exit -S open -F obj_uid=0 -F perm=wa
We deprecated entry,always rules a long time ago. Reject those rules as
invalid.
Every other filter that matches part of the inodes list collected by audit
will match against any of the inodes on that list. The filetype matching
however had a strange way of doing things. It allowed userspace to
indicated if it should match on the first of the second name collected by
the kernel. Name collection ordering seems like a kernel internal and
making userspace rules get that right just seems like a bad idea. As it
turns out the userspace audit writers had no idea it was doing this and
thus never overloaded the value field. The kernel always checked the first
name collected which for the tested rules was always correct.
This patch just makes the filetype matching like the major, minor, inode,
and LSM rules in that it will match against any of the names collected. It
also changes the rule validation to reject the old unused rule types.
Noone knew it was there. Noone used it. Why keep around the extra code?
Netlink message processing in the kernel is synchronous these days, the
session information can be collected when needed.
Add support for matching by security label (e.g. SELinux context) of
the sender of an user-space audit record.
The audit filter code already allows user space to configure such
filters, but they were ignored during evaluation. This patch implements
evaluation of these filters.
For example, after application of this patch, PAM authentication logs
caused by cron can be disabled using
auditctl -a user,never -F subj_type=crond_t
Signed-off-by: Miloslav Trmac <mitr@redhat.com>
Acked-by: Eric Paris <eparis@redhat.com>
deleting audit watch rules is not currently done under audit_filter_mutex.
It was done this way because we could not hold the mutex during inotify
manipulation. Since we are using fsnotify we don't need to do the extra
get/put pair nor do we need the private list on which to store the parents
while they are about to be freed.
No real changes, just cleanup to the audit_watch split patch which we done
with minimal code changes for easy review. Now fix interfaces to make
things work better.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
A number of places in the audit system we send an op= followed by a string
that includes spaces. Somehow this works but it's just wrong. This patch
moves all of those that I could find to be quoted.
Example:
Change From: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1
subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op=remove rule
key="number2" list=4 res=0
Change To: type=CONFIG_CHANGE msg=audit(1244666690.117:31): auid=0 ses=1
subj=unconfined_u:unconfined_r:auditctl_t:s0-s0:c0.c1023 op="remove rule"
audit_get_nd() is only used by audit_watch and could be more cleanly
implemented by having the audit watch functions call it when needed rather
than making the generic audit rule parsing code deal with those objects.
In preparation for converting audit to use fsnotify instead of inotify we
seperate the inode watching code into it's own file. This is similar to
how the audit tree watching code is already seperated into audit_tree.c
audit_update_watch() runs all of the rules for a given watch and duplicates
them, attaches a new watch to them, and then when it finishes that process
and has called free on all of the old rules (ok maybe still inside the rcu
grace period) it proceeds to use the last element from list_for_each_entry_safe()
as if it were a krule rather than being the audit_watch which was anchoring
the list to output a message about audit rules changing.
This patch unfies the audit message from two different places into a helper
function and calls it from the correct location in audit_update_rules(). We
will now get an audit message about the config changing for each rule (with
each rules filterkey) rather than the previous garbage.
When an audit watch is added to a parent the temporary watch inside the
original krule from userspace is freed. Yet the original watch is used after
the real watch was created in audit_add_rules()
There is what we believe to be a false positive reported by lockdep.
inotify_inode_queue_event() => take inotify_mutex => kernel_event() =>
kmalloc() => SLOB => alloc_pages_node() => page reclaim => slab reclaim =>
dcache reclaim => inotify_inode_is_dead => take inotify_mutex => deadlock
The plan is to fix this via lockdep annotation, but that is proving to be
quite involved.
The patch flips the allocation over to GFP_NFS to shut the warning up, for
the 2.6.30 release.
Hopefully we will fix this for real in 2.6.31. I'll queue a patch in -mm
to switch it back to GFP_KERNEL so we don't forget.
[ INFO: inconsistent lock state ]
2.6.30-rc2-next-20090417 #203
inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage.
kswapd0/380 [HC0[0]:SC0[0]:HE1:SE1] takes:
(&inode->inotify_mutex){+.+.?.}, at: [<ffffffff8112f1b5>] inotify_inode_is_dead+0x35/0xb0
{RECLAIM_FS-ON-W} state was registered at:
[<ffffffff81079188>] mark_held_locks+0x68/0x90
[<ffffffff810792a5>] lockdep_trace_alloc+0xf5/0x100
[<ffffffff810f5261>] __kmalloc_node+0x31/0x1e0
[<ffffffff81130652>] kernel_event+0xe2/0x190
[<ffffffff81130826>] inotify_dev_queue_event+0x126/0x230
[<ffffffff8112f096>] inotify_inode_queue_event+0xc6/0x110
[<ffffffff8110444d>] vfs_create+0xcd/0x140
[<ffffffff8110825d>] do_filp_open+0x88d/0xa20
[<ffffffff810f6b68>] do_sys_open+0x98/0x140
[<ffffffff810f6c50>] sys_open+0x20/0x30
[<ffffffff8100c272>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
irq event stamp: 690455
hardirqs last enabled at (690455): [<ffffffff81564fe4>] _spin_unlock_irqrestore+0x44/0x80
hardirqs last disabled at (690454): [<ffffffff81565372>] _spin_lock_irqsave+0x32/0xa0
softirqs last enabled at (690178): [<ffffffff81052282>] __do_softirq+0x202/0x220
softirqs last disabled at (690157): [<ffffffff8100d50c>] call_softirq+0x1c/0x50
2 locks held by kswapd0/380:
#0: (shrinker_rwsem){++++..}, at: [<ffffffff810d0bd7>] shrink_slab+0x37/0x180
#1: (&type->s_umount_key#17){++++..}, at: [<ffffffff8110cfbf>] shrink_dcache_memory+0x11f/0x1e0
stack backtrace:
Pid: 380, comm: kswapd0 Not tainted 2.6.30-rc2-next-20090417 #203
Call Trace:
[<ffffffff810789ef>] print_usage_bug+0x19f/0x200
[<ffffffff81018bff>] ? save_stack_trace+0x2f/0x50
[<ffffffff81078f0b>] mark_lock+0x4bb/0x6d0
[<ffffffff810799e0>] ? check_usage_forwards+0x0/0xc0
[<ffffffff8107b142>] __lock_acquire+0xc62/0x1ae0
[<ffffffff810f478c>] ? slob_free+0x10c/0x370
[<ffffffff8107c0a1>] lock_acquire+0xe1/0x120
[<ffffffff8112f1b5>] ? inotify_inode_is_dead+0x35/0xb0
[<ffffffff81562d43>] mutex_lock_nested+0x63/0x420
[<ffffffff81012fe9>] ? sched_clock+0x9/0x10
[<ffffffff81077165>] ? lock_release_holdtime+0x35/0x1c0
[<ffffffff8110c9dc>] dentry_iput+0xbc/0xe0
[<ffffffff8110cb23>] d_kill+0x33/0x60
[<ffffffff8110ce23>] __shrink_dcache_sb+0x2d3/0x350
[<ffffffff8110cffa>] shrink_dcache_memory+0x15a/0x1e0
[<ffffffff810d0cc5>] shrink_slab+0x125/0x180
[<ffffffff810d1540>] kswapd+0x560/0x7a0
[<ffffffff810ce160>] ? isolate_pages_global+0x0/0x2c0
[<ffffffff81065a30>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8107953d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff810d0fe0>] ? kswapd+0x0/0x7a0
[<ffffffff8106555b>] kthread+0x5b/0xa0
[<ffffffff8100d40a>] child_rip+0xa/0x20
[<ffffffff8100cdd0>] ? restore_args+0x0/0x30
[<ffffffff81065500>] ? kthread+0x0/0xa0
[<ffffffff8100d400>] ? child_rip+0x0/0x20
[eparis@redhat.com: fix audit too]
Cc: Matt Mackall <mpm@selenic.com>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
make the e->rule.xxx shorter in kernel/auditfilter.c
Zhenwen Xu - Open and Free
Home Page: http://zhwen.org
My Studio: http://dim4.cn
>From 99692dc640b278f1cb1a15646ce42f22e89c0f77 Mon Sep 17 00:00:00 2001
Date: Thu, 12 Mar 2009 22:04:59 +0800
Subject: [PATCH] make the e->rule.xxx shorter in kernel/auditfilter.c
Signed-off-by: Zhenwen Xu <Helight.Xu@gmail.com>
Don't store the field->op in the messy (and very inconvenient for e.g.
audit_comparator()) form; translate to dense set of values and do full
validation of userland-submitted value while we are at it.
->audit_init_rule() and ->audit_match_rule() get new values now; in-tree
instances updated.
Fix the actual rule listing; add per-type lists _not_ used for matching,
with all exit,... sitting on one such list. Simplifies "do something
for all rules" logics, while we are at it...
Problem: ordering between the rules on exit chain is currently lost;
all watch and inode rules are listed after everything else _and_
exit,never on one kind doesn't stop exit,always on another from
being matched.
Solution: assign priorities to rules, keep track of the current
highest-priority matching rule and its result (always/never).
Inotify watch removals suck violently.
To kick the watch out we need (in this order) inode->inotify_mutex and
ih->mutex. That's fine if we have a hold on inode; however, for all
other cases we need to make damn sure we don't race with umount. We can
*NOT* just grab a reference to a watch - inotify_unmount_inodes() will
happily sail past it and we'll end with reference to inode potentially
outliving its superblock.
Ideally we just want to grab an active reference to superblock if we
can; that will make sure we won't go into inotify_umount_inodes() until
we are done. Cleanup is just deactivate_super().
However, that leaves a messy case - what if we *are* racing with
umount() and active references to superblock can't be acquired anymore?
We can bump ->s_count, grab ->s_umount, which will almost certainly wait
until the superblock is shut down and the watch in question is pining
for fjords. That's fine, but there is a problem - we might have hit the
window between ->s_active getting to 0 / ->s_count - below S_BIAS (i.e.
the moment when superblock is past the point of no return and is heading
for shutdown) and the moment when deactivate_super() acquires
->s_umount.
We could just do drop_super() yield() and retry, but that's rather
antisocial and this stuff is luser-triggerable. OTOH, having grabbed
->s_umount and having found that we'd got there first (i.e. that
->s_root is non-NULL) we know that we won't race with
inotify_umount_inodes().
So we could grab a reference to watch and do the rest as above, just
with drop_super() instead of deactivate_super(), right? Wrong. We had
to drop ih->mutex before we could grab ->s_umount. So the watch
could've been gone already.
That still can be dealt with - we need to save watch->wd, do idr_find()
and compare its result with our pointer. If they match, we either have
the damn thing still alive or we'd lost not one but two races at once,
the watch had been killed and a new one got created with the same ->wd
at the same address. That couldn't have happened in inotify_destroy(),
but inotify_rm_wd() could run into that. Still, "new one got created"
is not a problem - we have every right to kill it or leave it alone,
whatever's more convenient.
So we can use idr_find(...) == watch && watch->inode->i_sb == sb as
"grab it and kill it" check. If it's been our original watch, we are
fine, if it's a newcomer - nevermind, just pretend that we'd won the
race and kill the fscker anyway; we are safe since we know that its
superblock won't be going away.
And yes, this is far beyond mere "not very pretty"; so's the entire
concept of inotify to start with.
Acked-by: Greg KH <greg@kroah.com>
audit messages
> shouldn't these be using the "audit_get_loginuid(current)" and if we
> are going to output loginuid we also should be outputting sessionid
Thanks for your detailed explanation.
I have made a new patch for outputing "loginuid" and "sessionid" by audit_get_loginuid(current) and audit_get_sessionid(current).
If there are some deficiencies, please give me your indication.
Signed-off-by: Zhang Xiliang <zhangxiliang@cn.fujitsu.com>
The second argument "type" is not used in audit_filter_user(), so I think that type can be removed. If I'm wrong, please tell me.
Signed-off-by: Peng Haitao <penght@cn.fujitsu.com>
Fix auditfilter kernel-doc misssing parameter description:
Warning(lin2626-rc3//kernel/auditfilter.c:1551): No description found for parameter 'sessionid'
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current
* 'audit.b50' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current:
[PATCH] new predicate - AUDIT_FILETYPE
[patch 2/2] Use find_task_by_vpid in audit code
[patch 1/2] audit: let userspace fully control TTY input auditing
[PATCH 2/2] audit: fix sparse shadowed variable warnings
[PATCH 1/2] audit: move extern declarations to audit.h
Audit: MAINTAINERS update
Audit: increase the maximum length of the key field
Audit: standardize string audit interfaces
Audit: stop deadlock from signals under load
Audit: save audit_backlog_limit audit messages in case auditd comes back
Audit: collect sessionid in netlink messages
Audit: end printk with newline
Some drivers have duplicated unlikely() macros. IS_ERR() already has
unlikely() in itself.
This patch cleans up such pointless code.
Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Argument is S_IF... | <index>, where index is normally 0 or 1.
Triggers if chosen element of ctx->names[] is present and the
mode of object in question matches the upper bits of argument.
I.e. for things like "is the argument of that chmod a directory",
etc.
Use msglen as the identifier.
kernel/audit.c:724:10: warning: symbol 'len' shadows an earlier one
kernel/audit.c:575:8: originally declared here
Don't use ino_f to check the inode field at the end of the functions.
kernel/auditfilter.c:429:22: warning: symbol 'f' shadows an earlier one
kernel/auditfilter.c:420:21: originally declared here
kernel/auditfilter.c:542:22: warning: symbol 'f' shadows an earlier one
kernel/auditfilter.c:529:21: originally declared here
i always used as a counter for a for loop and initialized to zero before
use. Eliminate the inner i variables.
kernel/auditsc.c:1295:8: warning: symbol 'i' shadows an earlier one
kernel/auditsc.c:1152:6: originally declared here
kernel/auditsc.c:1320:7: warning: symbol 'i' shadows an earlier one
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Leave audit_sig_{uid|pid|sid} protected by #ifdef CONFIG_AUDITSYSCALL.
Noticed by sparse:
kernel/audit.c:73:6: warning: symbol 'audit_ever_enabled' was not declared. Should it be static?
kernel/audit.c:100:8: warning: symbol 'audit_sig_uid' was not declared. Should it be static?
kernel/audit.c:101:8: warning: symbol 'audit_sig_pid' was not declared. Should it be static?
kernel/audit.c:102:6: warning: symbol 'audit_sig_sid' was not declared. Should it be static?
kernel/audit.c:117:23: warning: symbol 'audit_ih' was not declared. Should it be static?
kernel/auditfilter.c:78:18: warning: symbol 'audit_filter_list' was not declared. Should it be static?
