path: root/kernel/Kconfig.hz
2014-04-30kernel: remove CONFIG_USE_GENERIC_SMP_HELPERSChristoph Hellwig
We've switched over every architecture that supports SMP to it, so remove the new useless config variable. Conflicts: arch/arm/Kconfig block/blk-mq.c Change-Id: Ic19c3ac07a38a1636d6aa2fed5e55a58833f9b2c Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit 0a06ff068f1255bcd7965ab07bc0f4adc3eb639a) Signed-off-by: Ishan Mittal <imittal@nvidia.com>
2008-07-28sched: fix SCHED_HRTICK dependencyOGAWA Hirofumi
Currently, it seems SCHED_HRTICK allowed for !SMP. But, it seems to have no dependency of it. Fix it. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-23sched: fix hrtick & generic-ipi dependencyIngo Molnar
Andrew Morton reported this s390 allmodconfig build failure: kernel/built-in.o: In function `hrtick_start_fair': sched.c:(.text+0x69c6): undefined reference to `__smp_call_function_single' the reason is that s390 is not a generic-ipi SMP platform yet, while the hrtick code relies on it. Fix the dependency. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-20sched, x86: clean up hrtick implementationPeter Zijlstra
random uvesafb failures were reported against Gentoo: http://bugs.gentoo.org/show_bug.cgi?id=222799 and Mihai Moldovan bisected it back to: > 8f4d37ec073c17e2d4aa8851df5837d798606d6f is first bad commit > commit 8f4d37ec073c17e2d4aa8851df5837d798606d6f > Author: Peter Zijlstra <a.p.zijlstra@chello.nl> > Date: Fri Jan 25 21:08:29 2008 +0100 > > sched: high-res preemption tick Linus suspected it to be hrtick + vm86 interaction and observed: > Btw, Peter, Ingo: I think that commit is doing bad things. They aren't > _incorrect_ per se, but they are definitely bad. > > Why? > > Using random _TIF_WORK_MASK flags is really impolite for doing > "scheduling" work. There's a reason that arch/x86/kernel/entry_32.S > special-cases the _TIF_NEED_RESCHED flag: we don't want to exit out of > vm86 mode unnecessarily. > > See the "work_notifysig_v86" label, and how it does that > "save_v86_state()" thing etc etc. Right, I never liked having to fiddle with those TIF flags. Initially I needed it because the hrtimer base lock could not nest in the rq lock. That however is fixed these days. Currently the only reason left to fiddle with the TIF flags is remote wakeups. We cannot program a remote cpu's hrtimer. I've been thinking about using the new and improved IPI function call stuff to implement hrtimer_start_on(). However that does require that smp_call_function_single(.wait=0) works from interrupt context - /me looks at the latest series from Jens - Yes that does seem to be supported, good. Here's a stab at cleaning this stuff up ... Mihai reported test success as well. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Mihai Moldovan <ionic@ionic.de> Cc: Michal Januszewski <spock@gentoo.org> Cc: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25sched: high-res preemption tickPeter Zijlstra
Use HR-timers (when available) to deliver an accurate preemption tick. The regular scheduler tick that runs at 1/HZ can be too coarse when nice level are used. The fairness system will still keep the cpu utilisation 'fair' by then delaying the task that got an excessive amount of CPU time but try to minimize this by delivering preemption points spot-on. The average frequency of this extra interrupt is sched_latency / nr_latency. Which need not be higher than 1/HZ, its just that the distribution within the sched_latency period is important. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-12-07[PATCH] HZ: 300Hz supportAlan Cox
Fix two things. Firstly the unit is "Hz" not "HZ". Secondly it is useful to have 300Hz support when doing multimedia work. 250 is fine for us in Europe but the US frame rate is 30fps (29.99 blah for pedants). 300 gives us a tick divisible by both 25 and 30, and for interlace work 50 and 60. It's also giving similar performance to 250Hz. I'd argue we should remove 250 and add 300, but that might be excess disruption for now. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] i386: Selectable Frequency of the Timer InterruptChristoph Lameter
Make the timer frequency selectable. The timer interrupt may cause bus and memory contention in large NUMA systems since the interrupt occurs on each processor HZ times per second. Signed-off-by: Christoph Lameter <christoph@lameter.com> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
