commit 0711f0d7050b9e07c44bc159bbc64ac0a1022c7f upstream.
During boot, kernel_init_freeable() initializes `cad_pid` to the init
task's struct pid. Later on, we may change `cad_pid` via a sysctl, and
when this happens proc_do_cad_pid() will increment the refcount on the
new pid via get_pid(), and will decrement the refcount on the old pid
via put_pid(). As we never called get_pid() when we initialized
`cad_pid`, we decrement a reference we never incremented, can therefore
free the init task's struct pid early. As there can be dangling
references to the struct pid, we can later encounter a use-after-free
(e.g. when delivering signals).
This was spotted when fuzzing v5.13-rc3 with Syzkaller, but seems to
have been around since the conversion of `cad_pid` to struct pid in
commit 9ec52099e4b8 ("[PATCH] replace cad_pid by a struct pid") from the
pre-KASAN stone age of v2.6.19.
Fix this by getting a reference to the init task's struct pid when we
assign it to `cad_pid`.
Full KASAN splat below.
BUG: KASAN: use-after-free in ns_of_pid include/linux/pid.h:153 [inline]
BUG: KASAN: use-after-free in task_active_pid_ns+0xc0/0xc8 kernel/pid.c:509
Read of size 4 at addr ffff23794dda0004 by task syz-executor.0/273
CPU: 1 PID: 273 Comm: syz-executor.0 Not tainted 5.12.0-00001-g9aef892b2d15 #1
Hardware name: linux,dummy-virt (DT)
Call trace:
do_notify_parent+0x308/0xe60 kernel/signal.c:1950
exit_notify kernel/exit.c:682 [inline]
do_exit+0x2334/0x2bd0 kernel/exit.c:845
do_group_exit+0x108/0x2c8 kernel/exit.c:922
get_signal+0x4e4/0x2a88 kernel/signal.c:2781
do_signal arch/arm64/kernel/signal.c:882 [inline]
do_notify_resume+0x300/0x970 arch/arm64/kernel/signal.c:936
work_pending+0xc/0x2dc
Allocated by task 0:
slab_post_alloc_hook+0x50/0x5c0 mm/slab.h:516
slab_alloc_node mm/slub.c:2907 [inline]
slab_alloc mm/slub.c:2915 [inline]
kmem_cache_alloc+0x1f4/0x4c0 mm/slub.c:2920
alloc_pid+0xdc/0xc00 kernel/pid.c:180
copy_process+0x2794/0x5e18 kernel/fork.c:2129
kernel_clone+0x194/0x13c8 kernel/fork.c:2500
kernel_thread+0xd4/0x110 kernel/fork.c:2552
rest_init+0x44/0x4a0 init/main.c:687
arch_call_rest_init+0x1c/0x28
start_kernel+0x520/0x554 init/main.c:1064
0x0
Freed by task 270:
slab_free_hook mm/slub.c:1562 [inline]
slab_free_freelist_hook+0x98/0x260 mm/slub.c:1600
slab_free mm/slub.c:3161 [inline]
kmem_cache_free+0x224/0x8e0 mm/slub.c:3177
put_pid.part.4+0xe0/0x1a8 kernel/pid.c:114
put_pid+0x30/0x48 kernel/pid.c:109
proc_do_cad_pid+0x190/0x1b0 kernel/sysctl.c:1401
proc_sys_call_handler+0x338/0x4b0 fs/proc/proc_sysctl.c:591
proc_sys_write+0x34/0x48 fs/proc/proc_sysctl.c:617
call_write_iter include/linux/fs.h:1977 [inline]
new_sync_write+0x3ac/0x510 fs/read_write.c:518
vfs_write fs/read_write.c:605 [inline]
vfs_write+0x9c4/0x1018 fs/read_write.c:585
ksys_write+0x124/0x240 fs/read_write.c:658
__do_sys_write fs/read_write.c:670 [inline]
__se_sys_write fs/read_write.c:667 [inline]
__arm64_sys_write+0x78/0xb0 fs/read_write.c:667
__invoke_syscall arch/arm64/kernel/syscall.c:37 [inline]
invoke_syscall arch/arm64/kernel/syscall.c:49 [inline]
el0_svc_common.constprop.1+0x16c/0x388 arch/arm64/kernel/syscall.c:129
do_el0_svc+0xf8/0x150 arch/arm64/kernel/syscall.c:168
el0_svc+0x28/0x38 arch/arm64/kernel/entry-common.c:416
el0_sync_handler+0x134/0x180 arch/arm64/kernel/entry-common.c:432
el0_sync+0x154/0x180 arch/arm64/kernel/entry.S:701
The buggy address belongs to the object at ffff23794dda0000
which belongs to the cache pid of size 224
The buggy address is located 4 bytes inside of
224-byte region [ffff23794dda0000, ffff23794dda00e0)
The buggy address belongs to the page:
page:(____ptrval____) refcount:1 mapcount:0 mapping:0000000000000000 index:0x0 pfn:0x4dda0
head:(____ptrval____) order:1 compound_mapcount:0
flags: 0x3fffc0000010200(slab|head)
raw: 03fffc0000010200 dead000000000100 dead000000000122 ffff23794d40d080
raw: 0000000000000000 0000000000190019 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff23794dd9ff00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff23794dd9ff80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff23794dda0000: fa fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff23794dda0080: fb fb fb fb fb fb fb fb fb fb fb fb fc fc fc fc
ffff23794dda0100: fc fc fc fc fc fc fc fc 00 00 00 00 00 00 00 00
Link: https://lkml.kernel.org/r/20210524172230.38715-1-mark.rutland@arm.com
Fixes: 9ec52099e4b8678a ("[PATCH] replace cad_pid by a struct pid")
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Acked-by: Christian Brauner <christian.brauner@ubuntu.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Christian Brauner <christian@brauner.io>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Kees Cook <keescook@chromium.org
Cc: <stable@vger.kernel.org>
commit ea29b20a828511de3348334e529a3d046a180416 upstream.
I read the commit log of the following two:
- bc083a64b6c0 ("init/Kconfig: make COMPILE_TEST depend on !UML")
- 334ef6ed06fa ("init/Kconfig: make COMPILE_TEST depend on !S390")
Both are talking about HAS_IOMEM dependency missing in many drivers.
So, 'depends on HAS_IOMEM' seems the direct, sensible solution to me.
This does not change the behavior of UML. UML still cannot enable
COMPILE_TEST because it does not provide HAS_IOMEM.
The current dependency for S390 is too strong. Under the condition of
CONFIG_PCI=y, S390 provides HAS_IOMEM, hence can enable COMPILE_TEST.
I also removed the meaningless 'default n'.
Link: https://lkml.kernel.org/r/20210224140809.1067582-1-masahiroy@kernel.org
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Cc: Heiko Carstens <hca@linux.ibm.com>
Cc: Arnd Bergmann <arnd@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: KP Singh <kpsingh@google.com>
Cc: Nathan Chancellor <nathan@kernel.org>
Cc: Nick Terrell <terrelln@fb.com>
Cc: Quentin Perret <qperret@google.com>
Cc: Valentin Schneider <valentin.schneider@arm.com>
Cc: "Enrico Weigelt, metux IT consult" <lkml@metux.net>
commit 334ef6ed06fa1a54e35296b77b693bcf6d63ee9e upstream.
While allmodconfig and allyesconfig build for s390 there are also
various bots running compile tests with randconfig, where PCI is
disabled. This reveals that a lot of drivers should actually depend on
HAS_IOMEM.
Adding this to each device driver would be a never ending story,
therefore just disable COMPILE_TEST for s390.
The reasoning is more or less the same as described in
commit bc083a64b6c0 ("init/Kconfig: make COMPILE_TEST depend on !UML").
Reported-by: kernel test robot <lkp@intel.com>
Suggested-by: Arnd Bergmann <arnd@kernel.org>
Signed-off-by: Heiko Carstens <hca@linux.ibm.com>
commit bc083a64b6c035135c0f80718f9e9192cc0867c6 upstream.
UML is a bit special since it does not have iomem nor dma. That means a
lot of drivers will not build if they miss a dependency on HAS_IOMEM.
s390 used to have the same issues but since it gained PCI support UML is
the only stranger.
We are tired of patching dozens of new drivers after every merge window
just to un-break allmod/yesconfig UML builds. One could argue that a
decent driver has to know on what it depends and therefore a missing
HAS_IOMEM dependency is a clear driver bug. But the dependency not
obvious and not everyone does UML builds with COMPILE_TEST enabled when
developing a device driver.
A possible solution to make these builds succeed on UML would be
providing stub functions for ioremap() and friends which fail upon
runtime. Another one is simply disabling COMPILE_TEST for UML. Since
it is the least hassle and does not force use to fake iomem support
let's do the latter.
Link: http://lkml.kernel.org/r/1466152995-28367-1-git-send-email-richard@nod.at
Signed-off-by: Richard Weinberger <richard@nod.at>
[ Upstream commit 550c10d28d21bd82a8bb48debbb27e6ed53262f6 ]
The .bss section for the h8300 is relatively small. A value of
CONFIG_LOG_BUF_SHIFT that is larger than 19 will create a static
printk ringbuffer that is too large. Limit the range appropriately
for the H8300.
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Reviewed-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Petr Mladek <pmladek@suse.com>
Link: https://lore.kernel.org/r/20200812073122.25412-1-john.ogness@linutronix.de
commit a9a3ed1eff3601b63aea4fb462d8b3b92c7c1e7e upstream.
... or the odyssey of trying to disable the stack protector for the
function which generates the stack canary value.
The whole story started with Sergei reporting a boot crash with a kernel
built with gcc-10:
Kernel panic — not syncing: stack-protector: Kernel stack is corrupted in: start_secondary
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.6.0-rc5—00235—gfffb08b37df9 #139
Hardware name: Gigabyte Technology Co., Ltd. To be filled by O.E.M./H77M—D3H, BIOS F12 11/14/2013
Call Trace:
dump_stack
panic
? start_secondary
__stack_chk_fail
start_secondary
secondary_startup_64
-—-[ end Kernel panic — not syncing: stack—protector: Kernel stack is corrupted in: start_secondary
This happens because gcc-10 tail-call optimizes the last function call
in start_secondary() - cpu_startup_entry() - and thus emits a stack
canary check which fails because the canary value changes after the
boot_init_stack_canary() call.
To fix that, the initial attempt was to mark the one function which
generates the stack canary with:
__attribute__((optimize("-fno-stack-protector"))) ... start_secondary(void *unused)
however, using the optimize attribute doesn't work cumulatively
as the attribute does not add to but rather replaces previously
supplied optimization options - roughly all -fxxx options.
The key one among them being -fno-omit-frame-pointer and thus leading to
not present frame pointer - frame pointer which the kernel needs.
The next attempt to prevent compilers from tail-call optimizing
the last function call cpu_startup_entry(), shy of carving out
start_secondary() into a separate compilation unit and building it with
-fno-stack-protector, was to add an empty asm("").
This current solution was short and sweet, and reportedly, is supported
by both compilers but we didn't get very far this time: future (LTO?)
optimization passes could potentially eliminate this, which leads us
to the third attempt: having an actual memory barrier there which the
compiler cannot ignore or move around etc.
That should hold for a long time, but hey we said that about the other
two solutions too so...
Reported-by: Sergei Trofimovich <slyfox@gentoo.org>
Tested-by: Kalle Valo <kvalo@codeaurora.org>
Link: https://lkml.kernel.org/r/20200314164451.346497-1-slyfox@gentoo.org
commit 78a5255ffb6a1af189a83e493d916ba1c54d8c75 upstream.
We have some rather random rules about when we accept the
"maybe-initialized" warnings, and when we don't.
For example, we consider it unreliable for gcc versions < 4.9, but also
if -O3 is enabled, or if optimizing for size. And then various kernel
config options disabled it, because they know that they trigger that
warning by confusing gcc sufficiently (ie PROFILE_ALL_BRANCHES).
And now gcc-10 seems to be introducing a lot of those warnings too, so
it falls under the same heading as 4.9 did.
At the same time, we have a very straightforward way to _enable_ that
warning when wanted: use "W=2" to enable more warnings.
So stop playing these ad-hoc games, and just disable that warning by
default, with the known and straight-forward "if you want to work on the
extra compiler warnings, use W=123".
Would it be great to have code that is always so obvious that it never
confuses the compiler whether a variable is used initialized or not?
Yes, it would. In a perfect world, the compilers would be smarter, and
our source code would be simpler.
That's currently not the world we live in, though.
commit b303c6df80c9f8f13785aa83a0471fca7e38b24d upstream.
Since -Wmaybe-uninitialized was introduced by GCC 4.7, we have patched
various false positives:
- commit e74fc973b6e5 ("Turn off -Wmaybe-uninitialized when building
with -Os") turned off this option for -Os.
- commit 815eb71e7149 ("Kbuild: disable 'maybe-uninitialized' warning
for CONFIG_PROFILE_ALL_BRANCHES") turned off this option for
- commit a76bcf557ef4 ("Kbuild: enable -Wmaybe-uninitialized warning
for "make W=1"") turned off this option for GCC < 4.9
Arnd provided more explanation in https://lkml.org/lkml/2017/3/14/903
I think this looks better by shifting the logic from Makefile to Kconfig.
Link: https://github.com/ClangBuiltLinux/linux/issues/350
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Nick Desaulniers <ndesaulniers@google.com>
commit c6c314a613cd7d03fb97713e0d642b493de42e69 upstream.
There are a few places in the kernel that access stack memory
belonging to a different task. Before we can start freeing task
stacks before the task_struct is freed, we need a way for those code
paths to pin the stack.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jann Horn <jann@thejh.net>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/17a434f50ad3d77000104f21666575e10a9c1fbd.1474003868.git.luto@kernel.org
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
commit c65eacbe290b8141554c71b2c94489e73ade8c8d upstream.
If an arch opts in by setting CONFIG_THREAD_INFO_IN_TASK_STRUCT,
then thread_info is defined as a single 'u32 flags' and is the first
entry of task_struct. thread_info::task is removed (it serves no
purpose if thread_info is embedded in task_struct), and
thread_info::cpu gets its own slot in task_struct.
This is heavily based on a patch written by Linus.
Originally-from: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/a0898196f0476195ca02713691a5037a14f2aac5.1473801993.git.luto@kernel.org
[ Upstream commit 6041186a32585fc7a1d0f6cfe2f138b05fdc3c82 ]
When a module option, or core kernel argument, toggles a static-key it
requires jump labels to be initialized early. While x86, PowerPC, and
ARM64 arrange for jump_label_init() to be called before parse_args(),
ARM does not.
Kernel command line: rdinit=/sbin/init page_alloc.shuffle=1 panic=-1 console=ttyAMA0,115200 page_alloc.shuffle=1
WARNING: CPU: 0 PID: 0 at ./include/linux/jump_label.h:303
page_alloc_shuffle+0x12c/0x1ac
static_key_enable(): static key 'page_alloc_shuffle_key+0x0/0x4' used
before call to jump_label_init()
Modules linked in:
CPU: 0 PID: 0 Comm: swapper Not tainted
5.1.0-rc4-next-20190410-00003-g3367c36ce744 #1
Hardware name: ARM Integrator/CP (Device Tree)
[<c0011c68>] (unwind_backtrace) from [<c000ec48>] (show_stack+0x10/0x18)
[<c000ec48>] (show_stack) from [<c07e9710>] (dump_stack+0x18/0x24)
[<c07e9710>] (dump_stack) from [<c001bb1c>] (__warn+0xe0/0x108)
[<c001bb1c>] (__warn) from [<c001bb88>] (warn_slowpath_fmt+0x44/0x6c)
[<c001bb88>] (warn_slowpath_fmt) from [<c0b0c4a8>]
(page_alloc_shuffle+0x12c/0x1ac)
[<c0b0c4a8>] (page_alloc_shuffle) from [<c0b0c550>] (shuffle_store+0x28/0x48)
[<c0b0c550>] (shuffle_store) from [<c003e6a0>] (parse_args+0x1f4/0x350)
[<c003e6a0>] (parse_args) from [<c0ac3c00>] (start_kernel+0x1c0/0x488)
Move the fallback call to jump_label_init() to occur before
parse_args().
The redundant calls to jump_label_init() in other archs are left intact
in case they have static key toggling use cases that are even earlier
than option parsing.
Link: http://lkml.kernel.org/r/155544804466.1032396.13418949511615676665.stgit@dwillia2-desk3.amr.corp.intel.com
Reported-by: Guenter Roeck <groeck@google.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
Cc: Russell King <rmk@armlinux.org.uk>
commit 877417e6ffb9578e8580abf76a71e15732473456 upstream.
CC_OPTIMIZE_FOR_SIZE disables the often useful -Wmaybe-unused warning,
because that causes a ridiculous amount of false positives when combined
with -Os.
This means a lot of warnings don't show up in testing by the developers
that should see them with an 'allmodconfig' kernel that has
CC_OPTIMIZE_FOR_SIZE enabled, but only later in randconfig builds
that don't.
This changes the Kconfig logic around CC_OPTIMIZE_FOR_SIZE to make
it a 'choice' statement defaulting to CC_OPTIMIZE_FOR_PERFORMANCE
that gets added for this purpose. The allmodconfig and allyesconfig
kernels now default to -O2 with the maybe-unused warning enabled.
Signed-off-by: Michal Marek <mmarek@suse.com>
Cc: Nathan Chancellor <natechancellor@gmail.com>
[ upstream commit 290af86629b25ffd1ed6232c4e9107da031705cb ]
The BPF interpreter has been used as part of the spectre 2 attack CVE-2017-5715.
A quote from goolge project zero blog:
"At this point, it would normally be necessary to locate gadgets in
the host kernel code that can be used to actually leak data by reading
from an attacker-controlled location, shifting and masking the result
appropriately and then using the result of that as offset to an
attacker-controlled address for a load. But piecing gadgets together
and figuring out which ones work in a speculation context seems annoying.
So instead, we decided to use the eBPF interpreter, which is built into
the host kernel - while there is no legitimate way to invoke it from inside
a VM, the presence of the code in the host kernel's text section is sufficient
to make it usable for the attack, just like with ordinary ROP gadgets."
To make attacker job harder introduce BPF_JIT_ALWAYS_ON config
option that removes interpreter from the kernel in favor of JIT-only mode.
So far eBPF JIT is supported by:
x64, arm64, arm32, sparc64, s390, powerpc64, mips64
The start of JITed program is randomized and code page is marked as read-only.
In addition "constant blinding" can be turned on with net.core.bpf_jit_harden
v2->v3:
- move __bpf_prog_ret0 under ifdef (Daniel)
v1->v2:
- fix init order, test_bpf and cBPF (Daniel's feedback)
- fix offloaded bpf (Jakub's feedback)
- add 'return 0' dummy in case something can invoke prog->bpf_func
- retarget bpf tree. For bpf-next the patch would need one extra hunk.
It will be sent when the trees are merged back to net-next
Considered doing:
int bpf_jit_enable __read_mostly = BPF_EBPF_JIT_DEFAULT;
but it seems better to land the patch as-is and in bpf-next remove
bpf_jit_enable global variable from all JITs, consolidate in one place
and remove this jit_init() function.
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Kaiser only needs to map one page of the stack; and
kernel/fork.c did not build on powerpc (no __PAGE_KERNEL).
It's all cleaner if linux/kaiser.h provides kaiser_map_thread_stack()
and kaiser_unmap_thread_stack() wrappers around asm/kaiser.h's
kaiser_add_mapping() and kaiser_remove_mapping(). And use
linux/kaiser.h in init/main.c to avoid the #ifdefs there.
Acked-by: Jiri Kosina <jkosina@suse.cz>
This patch introduces our implementation of KAISER (Kernel Address Isolation to
have Side-channels Efficiently Removed), a kernel isolation technique to close
hardware side channels on kernel address information.
More information about the patch can be found on:
https://github.com/IAIK/KAISER
From: Richard Fellner <richard.fellner@student.tugraz.at>
X-Subject: [RFC, PATCH] x86_64: KAISER - do not map kernel in user mode
Date: Thu, 4 May 2017 14:26:50 +0200
Link: http://marc.info/?l=linux-kernel&m=149390087310405&w=2
Kaiser-4.10-SHA1: c4b1831d44c6144d3762ccc72f0c4e71a0c713e5
To: <linux-kernel@vger.kernel.org>
To: <kernel-hardening@lists.openwall.com>
Cc: <clementine.maurice@iaik.tugraz.at>
Cc: <moritz.lipp@iaik.tugraz.at>
Cc: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Cc: Richard Fellner <richard.fellner@student.tugraz.at>
Cc: <kirill.shutemov@linux.intel.com>
Cc: <anders.fogh@gdata-adan.de>
After several recent works [1,2,3] KASLR on x86_64 was basically
considered dead by many researchers. We have been working on an
efficient but effective fix for this problem and found that not mapping
the kernel space when running in user mode is the solution to this
problem [4] (the corresponding paper [5] will be presented at ESSoS17).
With this RFC patch we allow anybody to configure their kernel with the
flag CONFIG_KAISER to add our defense mechanism.
If there are any questions we would love to answer them.
We also appreciate any comments!
Cheers,
Daniel (+ the KAISER team from Graz University of Technology)
[1] http://www.ieee-security.org/TC/SP2013/papers/4977a191.pdf
[2] https://www.blackhat.com/docs/us-16/materials/us-16-Fogh-Using-Undocumented-CPU-Behaviour-To-See-Into-Kernel-Mode-And-Break-KASLR-In-The-Process.pdf
[3] https://www.blackhat.com/docs/us-16/materials/us-16-Jang-Breaking-Kernel-Address-Space-Layout-Randomization-KASLR-With-Intel-TSX.pdf
[4] https://github.com/IAIK/KAISER
[5] https://gruss.cc/files/kaiser.pdf
[patch based also on
https://raw.githubusercontent.com/IAIK/KAISER/master/KAISER/0001-KAISER-Kernel-Address-Isolation.patch]
Signed-off-by: Richard Fellner <richard.fellner@student.tugraz.at>
Signed-off-by: Moritz Lipp <moritz.lipp@iaik.tugraz.at>
Signed-off-by: Daniel Gruss <daniel.gruss@iaik.tugraz.at>
Signed-off-by: Michael Schwarz <michael.schwarz@iaik.tugraz.at>
Currently the full stop_machine() routine is only enabled on SMP if
module unloading is enabled, or if the CPUs are hotpluggable. This
leads to configurations where stop_machine() is broken as it will then
only run the callback on the local CPU with irqs disabled, and not stop
the other CPUs or run the callback on them.
For example, this breaks MTRR setup on x86 in certain configs since
ea8596bb2d8d379 ("kprobes/x86: Remove unused text_poke_smp() and
text_poke_smp_batch() functions") as the MTRR is only established on the
boot CPU.
This patch removes the Kconfig option for STOP_MACHINE and uses the SMP
and HOTPLUG_CPU config options to compile the correct stop_machine() for
the architecture, removing the false dependency on MODULE_UNLOAD in the
process.
Link: https://lkml.org/lkml/2014/10/8/124
References: https://bugs.freedesktop.org/show_bug.cgi?id=84794
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Vladimir Davydov <vdavydov@parallels.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Iulia Manda <iulia.manda21@gmail.com>
Cc: Chuck Ebbert <cebbert.lkml@gmail.com>
Here is an implementation of a new system call, sys_membarrier(), which
executes a memory barrier on all threads running on the system. It is
implemented by calling synchronize_sched(). It can be used to
distribute the cost of user-space memory barriers asymmetrically by
transforming pairs of memory barriers into pairs consisting of
sys_membarrier() and a compiler barrier. For synchronization primitives
that distinguish between read-side and write-side (e.g. userspace RCU
[1], rwlocks), the read-side can be accelerated significantly by moving
the bulk of the memory barrier overhead to the write-side.
The existing applications of which I am aware that would be improved by
this system call are as follows:
* Through Userspace RCU library (http://urcu.so)
- DNS server (Knot DNS) https://www.knot-dns.cz/
- Network sniffer (http://netsniff-ng.org/)
- Distributed object storage (https://sheepdog.github.io/sheepdog/)
- User-space tracing (http://lttng.org)
- Network storage system (https://www.gluster.org/)
- Virtual routers (https://events.linuxfoundation.org/sites/events/files/slides/DPDK_RCU_0MQ.pdf)
- Financial software (https://lkml.org/lkml/2015/3/23/189)
Those projects use RCU in userspace to increase read-side speed and
scalability compared to locking. Especially in the case of RCU used by
libraries, sys_membarrier can speed up the read-side by moving the bulk of
the memory barrier cost to synchronize_rcu().
* Direct users of sys_membarrier
- core dotnet garbage collector (https://github.com/dotnet/coreclr/issues/198)
Microsoft core dotnet GC developers are planning to use the mprotect()
side-effect of issuing memory barriers through IPIs as a way to implement
Windows FlushProcessWriteBuffers() on Linux. They are referring to
sys_membarrier in their github thread, specifically stating that
sys_membarrier() is what they are looking for.
To explain the benefit of this scheme, let's introduce two example threads:
Thread A (non-frequent, e.g. executing liburcu synchronize_rcu())
Thread B (frequent, e.g. executing liburcu
rcu_read_lock()/rcu_read_unlock())
In a scheme where all smp_mb() in thread A are ordering memory accesses
with respect to smp_mb() present in Thread B, we can change each
smp_mb() within Thread A into calls to sys_membarrier() and each
smp_mb() within Thread B into compiler barriers "barrier()".
Before the change, we had, for each smp_mb() pairs:
Thread A Thread B
previous mem accesses previous mem accesses
smp_mb() smp_mb()
following mem accesses following mem accesses
After the change, these pairs become:
Thread A Thread B
prev mem accesses prev mem accesses
sys_membarrier() barrier()
follow mem accesses follow mem accesses
As we can see, there are two possible scenarios: either Thread B memory
accesses do not happen concurrently with Thread A accesses (1), or they
do (2).
1) Non-concurrent Thread A vs Thread B accesses:
Thread A Thread B
prev mem accesses
sys_membarrier()
follow mem accesses
prev mem accesses
barrier()
follow mem accesses
In this case, thread B accesses will be weakly ordered. This is OK,
because at that point, thread A is not particularly interested in
ordering them with respect to its own accesses.
2) Concurrent Thread A vs Thread B accesses
Thread A Thread B
In this case, thread B accesses, which are ensured to be in program
order thanks to the compiler barrier, will be "upgraded" to full
smp_mb() by synchronize_sched().
* Benchmarks
On Intel Xeon E5405 (8 cores)
(one thread is calling sys_membarrier, the other 7 threads are busy
looping)
1000 non-expedited sys_membarrier calls in 33s =3D 33 milliseconds/call.
* User-space user of this system call: Userspace RCU library
Both the signal-based and the sys_membarrier userspace RCU schemes
permit us to remove the memory barrier from the userspace RCU
rcu_read_lock() and rcu_read_unlock() primitives, thus significantly
accelerating them. These memory barriers are replaced by compiler
barriers on the read-side, and all matching memory barriers on the
write-side are turned into an invocation of a memory barrier on all
active threads in the process. By letting the kernel perform this
synchronization rather than dumbly sending a signal to every process
threads (as we currently do), we diminish the number of unnecessary wake
ups and only issue the memory barriers on active threads. Non-running
threads do not need to execute such barrier anyway, because these are
implied by the scheduler context switches.
Results in liburcu:
Operations in 10s, 6 readers, 2 writers:
memory barriers in reader: 1701557485 reads, 2202847 writes
signal-based scheme: 9830061167 reads, 6700 writes
sys_membarrier: 9952759104 reads, 425 writes
sys_membarrier (dyn. check): 7970328887 reads, 425 writes
The dynamic sys_membarrier availability check adds some overhead to
the read-side compared to the signal-based scheme, but besides that,
sys_membarrier slightly outperforms the signal-based scheme. However,
this non-expedited sys_membarrier implementation has a much slower grace
period than signal and memory barrier schemes.
Besides diminishing the number of wake-ups, one major advantage of the
membarrier system call over the signal-based scheme is that it does not
need to reserve a signal. This plays much more nicely with libraries,
and with processes injected into for tracing purposes, for which we
cannot expect that signals will be unused by the application.
An expedited version of this system call can be added later on to speed
up the grace period. Its implementation will likely depend on reading
the cpu_curr()->mm without holding each CPU's rq lock.
This patch adds the system call to x86 and to asm-generic.
[1] http://urcu.so
membarrier(2) man page:
MEMBARRIER(2) Linux Programmer's Manual MEMBARRIER(2)
NAME
membarrier - issue memory barriers on a set of threads
SYNOPSIS
#include <linux/membarrier.h>
int membarrier(int cmd, int flags);
DESCRIPTION
The cmd argument is one of the following:
MEMBARRIER_CMD_QUERY
Query the set of supported commands. It returns a bitmask of
supported commands.
MEMBARRIER_CMD_SHARED
Execute a memory barrier on all threads running on the system.
Upon return from system call, the caller thread is ensured that
all running threads have passed through a state where all memory
accesses to user-space addresses match program order between
entry to and return from the system call (non-running threads
are de facto in such a state). This covers threads from all pro=E2=80=90
cesses running on the system. This command returns 0.
The flags argument needs to be 0. For future extensions.
All memory accesses performed in program order from each targeted
thread is guaranteed to be ordered with respect to sys_membarrier(). If
we use the semantic "barrier()" to represent a compiler barrier forcing
memory accesses to be performed in program order across the barrier,
and smp_mb() to represent explicit memory barriers forcing full memory
ordering across the barrier, we have the following ordering table for
each pair of barrier(), sys_membarrier() and smp_mb():
The pair ordering is detailed as (O: ordered, X: not ordered):
barrier() smp_mb() sys_membarrier()
barrier() X X O
smp_mb() X O O
sys_membarrier() O O O
RETURN VALUE
On success, these system calls return zero. On error, -1 is returned,
and errno is set appropriately. For a given command, with flags
argument set to 0, this system call is guaranteed to always return the
same value until reboot.
ERRORS
ENOSYS System call is not implemented.
EINVAL Invalid arguments.
Linux 2015-04-15 MEMBARRIER(2)
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Cc: Nicholas Miell <nmiell@comcast.net>
Cc: Alan Cox <gnomes@lxorguk.ukuu.org.uk>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
We need to launch the usermodehelper kernel threads with the widest
affinity and this is partly why we use khelper. This workqueue has
unbound properties and thus a wide affinity inherited by all its children.
Now khelper also has special properties that we aren't much interested in:
ordered and singlethread. There is really no need about ordering as all
we do is creating kernel threads. This can be done concurrently. And
singlethread is a useless limitation as well.
The workqueue engine already proposes generic unbound workqueues that
don't share these useless properties and handle well parallel jobs.
The only worrysome specific is their affinity to the node of the current
CPU. It's fine for creating the usermodehelper kernel threads but those
inherit this affinity for longer jobs such as requesting modules.
This patch proposes to use these node affine unbound workqueues assuming
that a node is sufficient to handle several parallel usermodehelper
requests.
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Cc: Christoph Lameter <cl@linux.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security
Pull security subsystem updates from James Morris:
"Highlights:
- PKCS#7 support added to support signed kexec, also utilized for
module signing. See comments in 3f1e1bea.
** NOTE: this requires linking against the OpenSSL library, which
must be installed, e.g. the openssl-devel on Fedora **
- Smack
- add IPv6 host labeling; ignore labels on kernel threads
- support smack labeling mounts which use binary mount data
- SELinux:
- add ioctl whitelisting (see
http://kernsec.org/files/lss2015/vanderstoep.pdf)
- fix mprotect PROT_EXEC regression caused by mm change
- Seccomp:
- add ptrace options for suspend/resume"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (57 commits)
PKCS#7: Add OIDs for sha224, sha284 and sha512 hash algos and use them
Documentation/Changes: Now need OpenSSL devel packages for module signing
scripts: add extract-cert and sign-file to .gitignore
modsign: Handle signing key in source tree
modsign: Use if_changed rule for extracting cert from module signing key
Move certificate handling to its own directory
sign-file: Fix warning about BIO_reset() return value
PKCS#7: Add MODULE_LICENSE() to test module
Smack - Fix build error with bringup unconfigured
sign-file: Document dependency on OpenSSL devel libraries
PKCS#7: Appropriately restrict authenticated attributes and content type
KEYS: Add a name for PKEY_ID_PKCS7
PKCS#7: Improve and export the X.509 ASN.1 time object decoder
modsign: Use extract-cert to process CONFIG_SYSTEM_TRUSTED_KEYS
extract-cert: Cope with multiple X.509 certificates in a single file
sign-file: Generate CMS message as signature instead of PKCS#7
PKCS#7: Support CMS messages also [RFC5652]
X.509: Change recorded SKID & AKID to not include Subject or Issuer
PKCS#7: Check content type and versions
MAINTAINERS: The keyrings mailing list has moved
Pull vfs updates from Al Viro:
"In this one:
- d_move fixes (Eric Biederman)
- UFS fixes (me; locking is mostly sane now, a bunch of bugs in error
handling ought to be fixed)
- switch of sb_writers to percpu rwsem (Oleg Nesterov)
- superblock scalability (Josef Bacik and Dave Chinner)
- swapon(2) race fix (Hugh Dickins)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (65 commits)
vfs: Test for and handle paths that are unreachable from their mnt_root
dcache: Reduce the scope of i_lock in d_splice_alias
dcache: Handle escaped paths in prepend_path
mm: fix potential data race in SyS_swapon
inode: don't softlockup when evicting inodes
inode: rename i_wb_list to i_io_list
sync: serialise per-superblock sync operations
inode: convert inode_sb_list_lock to per-sb
inode: add hlist_fake to avoid the inode hash lock in evict
writeback: plug writeback at a high level
change sb_writers to use percpu_rw_semaphore
shift percpu_counter_destroy() into destroy_super_work()
percpu-rwsem: kill CONFIG_PERCPU_RWSEM
percpu-rwsem: introduce percpu_rwsem_release() and percpu_rwsem_acquire()
percpu-rwsem: introduce percpu_down_read_trylock()
document rwsem_release() in sb_wait_write()
fix the broken lockdep logic in __sb_start_write()
introduce __sb_writers_{acquired,release}() helpers
ufs_inode_get{frag,block}(): get rid of 'phys' argument
ufs_getfrag_block(): tidy up a bit
Merge patch-bomb from Andrew Morton:
- a few misc things
- Andy's "ambient capabilities"
- fs/nofity updates
- the ocfs2 queue
- kernel/watchdog.c updates and feature work.
- some of MM. Includes Andrea's userfaultfd feature.
[ Hadn't noticed that userfaultfd was 'default y' when applying the
patches, so that got fixed in this merge instead. We do _not_ mark
new features that nobody uses yet 'default y' - Linus ]
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (118 commits)
mm/hugetlb.c: make vma_has_reserves() return bool
mm/madvise.c: make madvise_behaviour_valid() return bool
mm/memory.c: make tlb_next_batch() return bool
mm/dmapool.c: change is_page_busy() return from int to bool
mm: remove struct node_active_region
mremap: simplify the "overlap" check in mremap_to()
mremap: don't do uneccesary checks if new_len == old_len
mremap: don't do mm_populate(new_addr) on failure
mm: move ->mremap() from file_operations to vm_operations_struct
mremap: don't leak new_vma if f_op->mremap() fails
mm/hugetlb.c: make vma_shareable() return bool
mm: make GUP handle pfn mapping unless FOLL_GET is requested
mm: fix status code which move_pages() returns for zero page
mm: memcontrol: bring back the VM_BUG_ON() in mem_cgroup_swapout()
genalloc: add support of multiple gen_pools per device
genalloc: add name arg to gen_pool_get() and devm_gen_pool_create()
mm/memblock: WARN_ON when nid differs from overlap region
Documentation/features/vm: add feature description and arch support status for batched TLB flush after unmap
mm: defer flush of writable TLB entries
mm: send one IPI per CPU to TLB flush all entries after unmapping pages
An IPI is sent to flush remote TLBs when a page is unmapped that was
potentially accesssed by other CPUs. There are many circumstances where
this happens but the obvious one is kswapd reclaiming pages belonging to a
running process as kswapd and the task are likely running on separate
CPUs.
On small machines, this is not a significant problem but as machine gets
larger with more cores and more memory, the cost of these IPIs can be
high. This patch uses a simple structure that tracks CPUs that
potentially have TLB entries for pages being unmapped. When the unmapping
is complete, the full TLB is flushed on the assumption that a refill cost
is lower than flushing individual entries.
Architectures wishing to do this must give the following guarantee.
If a clean page is unmapped and not immediately flushed, the
architecture must guarantee that a write to that linear address
from a CPU with a cached TLB entry will trap a page fault.
This is essentially what the kernel already depends on but the window is
much larger with this patch applied and is worth highlighting. The
architecture should consider whether the cost of the full TLB flush is
higher than sending an IPI to flush each individual entry. An additional
architecture helper called flush_tlb_local is required. It's a trivial
wrapper with some accounting in the x86 case.
The impact of this patch depends on the workload as measuring any benefit
requires both mapped pages co-located on the LRU and memory pressure. The
case with the biggest impact is multiple processes reading mapped pages
taken from the vm-scalability test suite. The test case uses NR_CPU
readers of mapped files that consume 10*RAM.
Linear mapped reader on a 4-node machine with 64G RAM and 48 CPUs
4.2.0-rc1 4.2.0-rc1
vanilla flushfull-v7
Ops lru-file-mmap-read-elapsed 159.62 ( 0.00%) 120.68 ( 24.40%)
Ops lru-file-mmap-read-time_range 30.59 ( 0.00%) 2.80 ( 90.85%)
Ops lru-file-mmap-read-time_stddv 6.70 ( 0.00%) 0.64 ( 90.38%)
4.2.0-rc1 4.2.0-rc1
User 581.00 611.43
System 5804.93 4111.76
Elapsed 161.03 122.12
This is showing that the readers completed 24.40% faster with 29% less
system CPU time. From vmstats, it is known that the vanilla kernel was
interrupted roughly 900K times per second during the steady phase of the
test and the patched kernel was interrupts 180K times per second.
The impact is lower on a single socket machine.
4.2.0-rc1 4.2.0-rc1
Ops lru-file-mmap-read-elapsed 25.33 ( 0.00%) 20.38 ( 19.54%)
Ops lru-file-mmap-read-time_range 0.91 ( 0.00%) 1.44 (-58.24%)
Ops lru-file-mmap-read-time_stddv 0.28 ( 0.00%) 0.47 (-65.34%)
4.2.0-rc1 4.2.0-rc1
User 58.09 57.64
System 111.82 76.56
Elapsed 27.29 22.55
It's still a noticeable improvement with vmstat showing interrupts went
from roughly 500K per second to 45K per second.
The patch will have no impact on workloads with no memory pressure or have
relatively few mapped pages. It will have an unpredictable impact on the
workload running on the CPU being flushed as it'll depend on how many TLB
entries need to be refilled and how long that takes. Worst case, the TLB
will be completely cleared of active entries when the target PFNs were not
resident at all.
[sasha.levin@oracle.com: trace tlb flush after disabling preemption in try_to_unmap_flush]
Cc: Michal Hocko <mhocko@suse.com>
This allows to select the userfaultfd during configuration to build it.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
Cc: zhang.zhanghailiang@huawei.com
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Andres Lagar-Cavilla <andreslc@google.com>
Cc: Peter Feiner <pfeiner@google.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: "Huangpeng (Peter)" <peter.huangpeng@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup
Pull cgroup updates from Tejun Heo:
- a new PIDs controller is added. It turns out that PIDs are actually
an independent resource from kmem due to the limited PID space.
- more core preparations for the v2 interface. Once cpu side interface
is settled, it should be ready for lifting the devel mask.
for-4.3-unified-base was temporarily branched so that other trees
(block) can pull cgroup core changes that blkcg changes depend on.
- a non-critical idr_preload usage bug fix.
* 'for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: pids: fix invalid get/put usage
cgroup: introduce cgroup_subsys->legacy_name
cgroup: don't print subsystems for the default hierarchy
cgroup: make cftype->private a unsigned long
cgroup: export cgrp_dfl_root
cgroup: define controller file conventions
cgroup: fix idr_preload usage
cgroup: add documentation for the PIDs controller
cgroup: implement the PIDs subsystem
cgroup: allow a cgroup subsystem to reject a fork
Remove CONFIG_PERCPU_RWSEM, the next patch adds the unconditional
user of percpu_rw_semaphore.
Move certificate handling out of the kernel/ directory and into a certs/
directory to get all the weird stuff in one place and move the generated
signing keys into this directory.
Reviewed-by: David Woodhouse <David.Woodhouse@intel.com>
The revised sign-file program is no longer a script that wraps the openssl
program, but now rather a program that makes use of OpenSSL's crypto
library. This means that to build the sign-file program, the kernel build
process now has a dependency on the OpenSSL development packages in
addition to OpenSSL itself.
Document this in Kconfig and in module-signing.txt.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU changes from Paul E. McKenney:
- The combination of tree geometry-initialization simplifications
and OS-jitter-reduction changes to expedited grace periods.
These two are stacked due to the large number of conflicts
that would otherwise result.
[ With one addition, a temporary commit to silence a lockdep false
positive. Additional changes to the expedited grace-period
primitives (queued for 4.4) remove the cause of this false
positive, and therefore include a revert of this temporary commit. ]
- Documentation updates.
- Torture-test updates.
- Miscellaneous fixes.
Let the user explicitly provide a file containing trusted keys, instead of
just automatically finding files matching *.x509 in the build tree and
trusting whatever we find. This really ought to be an *explicit*
configuration, and the build rules for dealing with the files were
fairly painful too.
Fix applied from James Morris that removes an '=' from a macro definition
in kernel/Makefile as this is a feature that only exists from GNU make 3.82
onwards.
The current rule for generating signing_key.priv and signing_key.x509 is
a classic example of a bad rule which has a tendency to break parallel
make. When invoked to create *either* target, it generates the other
target as a side-effect that make didn't predict.
So let's switch to using a single file signing_key.pem which contains
both key and certificate. That matches what we do in the case of an
external key specified by CONFIG_MODULE_SIG_KEY anyway, so it's also
slightly cleaner.
Where an external PEM file or PKCS#11 URI is given, we can get the cert
from it for ourselves instead of making the user drop signing_key.x509
in place for us.
Extract the function that drives the PKCS#7 signature verification given a
data blob and a PKCS#7 blob out from the module signing code and lump it with
the system keyring code as it's generic. This makes it independent of module
config options and opens it to use by the firmware loader.
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Seth Forshee <seth.forshee@canonical.com>
Cc: Kyle McMartin <kyle@kernel.org>
Move to using PKCS#7 messages as module signatures because:
(1) We have to be able to support the use of X.509 certificates that don't
have a subjKeyId set. We're currently relying on this to look up the
X.509 certificate in the trusted keyring list.
(2) PKCS#7 message signed information blocks have a field that supplies the
data required to match with the X.509 certificate that signed it.
(3) The PKCS#7 certificate carries fields that specify the digest algorithm
used to generate the signature in a standardised way and the X.509
certificates specify the public key algorithm in a standardised way - so
we don't need our own methods of specifying these.
(4) We now have PKCS#7 message support in the kernel for signed kexec purposes
and we can make use of this.
To make this work, the old sign-file script has been replaced with a program
that needs compiling in a previous patch. The rules to build it are added
here.
Tested-by: Vivek Goyal <vgoyal@redhat.com>
Dave Hansen reported the following;
My laptop has been behaving strangely with 4.2-rc2. Once I log
in to my X session, I start getting all kinds of strange errors
from applications and see this in my dmesg:
VFS: file-max limit 8192 reached
The problem is that the file-max is calculated before memory is fully
initialised and miscalculates how much memory the kernel is using. This
patch recalculates file-max after deferred memory initialisation. Note
that using memory hotplug infrastructure would not have avoided this
problem as the value is not recalculated after memory hot-add.
4.1: files_stat.max_files = 6582781
4.2-rc2: files_stat.max_files = 8192
4.2-rc2 patched: files_stat.max_files = 6562467
Small differences with the patch applied and 4.1 but not enough to matter.
Reported-by: Dave Hansen <dave.hansen@intel.com>
Cc: Nicolai Stange <nicstange@gmail.com>
Cc: Alex Ng <alexng@microsoft.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
This commit prevents Kconfig from asking the user about RCU_NOCB_CPU
unless the user really wants to be asked.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Adds a new single-purpose PIDs subsystem to limit the number of
tasks that can be forked inside a cgroup. Essentially this is an
implementation of RLIMIT_NPROC that applies to a cgroup rather than a
process tree.
However, it should be noted that organisational operations (adding and
removing tasks from a PIDs hierarchy) will *not* be prevented. Rather,
the number of tasks in the hierarchy cannot exceed the limit through
forking. This is due to the fact that, in the unified hierarchy, attach
cannot fail (and it is not possible for a task to overcome its PIDs
cgroup policy limit by attaching to a child cgroup -- even if migrating
mid-fork it must be able to fork in the parent first).
PIDs are fundamentally a global resource, and it is possible to reach
PID exhaustion inside a cgroup without hitting any reasonable kmemcg
policy. Once you've hit PID exhaustion, you're only in a marginally
better state than OOM. This subsystem allows PID exhaustion inside a
cgroup to be prevented.
Signed-off-by: Aleksa Sarai <cyphar@cyphar.com>
The RCU_USER_QS Kconfig parameter is now just a synonym for NO_HZ_FULL,
so this commit eliminates RCU_USER_QS, replacing all uses with NO_HZ_FULL.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Pull scheduler fixes from Ingo Molnar:
"Debug info and other statistics fixes and related enhancements"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/numa: Fix numa balancing stats in /proc/pid/sched
sched/numa: Show numa_group ID in /proc/sched_debug task listings
sched/debug: Move print_cfs_rq() declaration to kernel/sched/sched.h
sched/stat: Expose /proc/pid/schedstat if CONFIG_SCHED_INFO=y
sched/stat: Simplify the sched_info accounting dependency
Pull max log buf size increase from Ingo Molnar:
"Ran into this limit recently, so increase it by an order of magnitude"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
printk: Increase maximum CONFIG_LOG_BUF_SHIFT from 21 to 25
Both CONFIG_SCHEDSTATS=y and CONFIG_TASK_DELAY_ACCT=y track task
sched_info, which results in ugly #if clauses.
Simplify the code by introducing a synthethic CONFIG_SCHED_INFO
switch, selected by both.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: Balbir Singh <bsingharora@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: a.p.zijlstra@chello.nl
Cc: ricklind@us.ibm.com
Link: http://lkml.kernel.org/r/8d19eef800811a94b0f91bcbeb27430a884d7433.1435255405.git.naveen.n.rao@linux.vnet.ibm.com
Merge third patchbomb from Andrew Morton:
- the rest of MM
- scripts/gdb updates
- ipc/ updates
- lib/ updates
- MAINTAINERS updates
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (67 commits)
genalloc: rename of_get_named_gen_pool() to of_gen_pool_get()
genalloc: rename dev_get_gen_pool() to gen_pool_get()
x86: opt into HAVE_COPY_THREAD_TLS, for both 32-bit and 64-bit
MAINTAINERS: add zpool
MAINTAINERS: BCACHE: Kent Overstreet has changed email address
MAINTAINERS: move Jens Osterkamp to CREDITS
MAINTAINERS: remove unused nbd.h pattern
MAINTAINERS: update brcm gpio filename pattern
MAINTAINERS: update brcm dts pattern
MAINTAINERS: update sound soc intel patterns
MAINTAINERS: remove website for paride
MAINTAINERS: update Emulex ocrdma email addresses
bcache: use kvfree() in various places
libcxgbi: use kvfree() in cxgbi_free_big_mem()
target: use kvfree() in session alloc and free
IB/ehca: use kvfree() in ipz_queue_{cd}tor()
drm/nouveau/gem: use kvfree() in u_free()
drm: use kvfree() in drm_free_large()
cxgb4: use kvfree() in t4_free_mem()
cxgb3: use kvfree() in cxgb_free_mem()
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull module updates from Rusty Russell:
"Main excitement here is Peter Zijlstra's lockless rbtree optimization
to speed module address lookup. He found some abusers of the module
lock doing that too.
A little bit of parameter work here too; including Dan Streetman's
breaking up the big param mutex so writing a parameter can load
another module (yeah, really). Unfortunately that broke the usual
suspects, !CONFIG_MODULES and !CONFIG_SYSFS, so those fixes were
appended too"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (26 commits)
modules: only use mod->param_lock if CONFIG_MODULES
param: fix module param locks when !CONFIG_SYSFS.
rcu: merge fix for Convert ACCESS_ONCE() to READ_ONCE() and WRITE_ONCE()
module: add per-module param_lock
module: make perm const
params: suppress unused variable error, warn once just in case code changes.
modules: clarify CONFIG_MODULE_COMPRESS help, suggest 'N'.
kernel/module.c: avoid ifdefs for sig_enforce declaration
kernel/workqueue.c: remove ifdefs over wq_power_efficient
kernel/params.c: export param_ops_bool_enable_only
kernel/params.c: generalize bool_enable_only
kernel/module.c: use generic module param operaters for sig_enforce
kernel/params: constify struct kernel_param_ops uses
sysfs: tightened sysfs permission checks
module: Rework module_addr_{min,max}
module: Use __module_address() for module_address_lookup()
module: Make the mod_tree stuff conditional on PERF_EVENTS || TRACING
module: Optimize __module_address() using a latched RB-tree
rbtree: Implement generic latch_tree
seqlock: Introduce raw_read_seqcount_latch()
So I tried to some kernel debugging that produced a ton of kernel messages
on a big box, and wanted to save them all: but CONFIG_LOG_BUF_SHIFT maxes
out at 21 (2 MB).
Increase it to 25 (32 MB).
This does not affect any existing config or defaults.
Waiman Long reported that 24TB machines hit OOM during basic setup when
struct page initialisation was deferred. One approach is to initialise
memory on demand but it interferes with page allocator paths. This patch
creates dedicated threads to initialise memory before basic setup. It
then blocks on a rw_semaphore until completion as a wait_queue and counter
is overkill. This may be slower to boot but it's simplier overall and
also gets rid of a section mangling which existed so kswapd could do the
initialisation.
[akpm@linux-foundation.org: include rwsem.h, use DECLARE_RWSEM, fix comment, remove unneeded cast]
Cc: Waiman Long <waiman.long@hp.com
Cc: Nathan Zimmer <nzimmer@sgi.com>
Cc: Scott Norton <scott.norton@hp.com>
Tested-by: Daniel J Blueman <daniel@numascale.com>
- threadgroup_lock got reorganized so that its users can pick the
actual locking mechanism to use. Its only user - cgroups - is
updated to use a percpu_rwsem instead of per-process rwsem.
This makes things a bit lighter on hot paths and allows cgroups to
perform and fail multi-task (a process) migrations atomically.
Multi-task migrations are used in several places including the
unified hierarchy.
- Delegation rule and documentation added to unified hierarchy. This
will likely be the last interface update from the cgroup core side
for unified hierarchy before lifting the devel mask.
- Some groundwork for the pids controller which is scheduled to be
merged in the coming devel cycle.
* 'for-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup:
cgroup: add delegation section to unified hierarchy documentation
cgroup: require write perm on common ancestor when moving processes on the default hierarchy
cgroup: separate out cgroup_procs_write_permission() from __cgroup_procs_write()
kernfs: make kernfs_get_inode() public
MAINTAINERS: add a cgroup core co-maintainer
cgroup: fix uninitialised iterator in for_each_subsys_which
cgroup: replace explicit ss_mask checking with for_each_subsys_which
cgroup: use bitmask to filter for_each_subsys
cgroup: add seq_file forward declaration for struct cftype
cgroup: simplify threadgroup locking
sched, cgroup: replace signal_struct->group_rwsem with a global percpu_rwsem
sched, cgroup: reorganize threadgroup locking
cgroup: switch to unsigned long for bitmasks
cgroup: reorganize include/linux/cgroup.h
cgroup: separate out include/linux/cgroup-defs.h
cgroup: fix some comment typos
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the driver core / firmware changes for 4.2-rc1.
A number of small changes all over the place in the driver core, and
in the firmware subsystem. Nothing really major, full details in the
shortlog. Some of it is a bit of churn, given that the platform
driver probing changes was found to not work well, so they were
reverted.
All of these have been in linux-next for a while with no reported
issues"
* tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits)
Revert "base/platform: Only insert MEM and IO resources"
Revert "base/platform: Continue on insert_resource() error"
Revert "of/platform: Use platform_device interface"
Revert "base/platform: Remove code duplication"
firmware: add missing kfree for work on async call
fs: sysfs: don't pass count == 0 to bin file readers
base:dd - Fix for typo in comment to function driver_deferred_probe_trigger().
firmware: use const for remaining firmware names
firmware: fix possible use after free on name on asynchronous request
firmware: check for file truncation on direct firmware loading
firmware: fix __getname() missing failure check
drivers: of/base: move of_init to driver_init
drivers/base: cacheinfo: fix annoying typo when DT nodes are absent
sysfs: disambiguate between "error code" and "failure" in comments
driver-core: fix build for !CONFIG_MODULES
driver-core: make __device_attach() static
Merge second patchbomb from Andrew Morton:
- most of the rest of MM
- lots of misc things
- procfs updates
- printk feature work
- updates to get_maintainer, MAINTAINERS, checkpatch
- lib/ updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits)
exit,stats: /* obey this comment */
coredump: add __printf attribute to cn_*printf functions
coredump: use from_kuid/kgid when formatting corename
fs/reiserfs: remove unneeded cast
NILFS2: support NFSv2 export
fs/befs/btree.c: remove unneeded initializations
fs/minix: remove unneeded cast
init/do_mounts.c: add create_dev() failure log
kasan: remove duplicate definition of the macro KASAN_FREE_PAGE
fs/efs: femove unneeded cast
checkpatch: emit "NOTE: <types>" message only once after multiple files
checkpatch: emit an error when there's a diff in a changelog
checkpatch: validate MODULE_LICENSE content
checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY
checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr()
checkpatch: fix processing of MEMSET issues
checkpatch: suggest using ether_addr_equal*()
checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files
checkpatch: remove local from codespell path
checkpatch: add --showfile to allow input via pipe to show filenames
If create_dev() function fails to create the root mount device
(/dev/root), then it goes to panic as root device not found but there is
no printk in this case. So I have added the log in case it fails to
create the root device. It will help in debugging.
[akpm@linux-foundation.org: simplify printk(), use pr_emerg(), display errno]
Signed-off-by: Vishnu Pratap Singh <vishnu.ps@samsung.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Dan Ehrenberg <dehrenberg@chromium.org>
Cc: Miklos Szeredi <mszeredi@suse.cz>
