path: root/include
2013-06-27net: force a reload of first item in hlist_nulls_for_each_entry_rcuEric Dumazet
[ Upstream commit c87a124a5d5e8cf8e21c4363c3372bcaf53ea190 ] Roman Gushchin discovered that udp4_lib_lookup2() was not reloading first item in the rcu protected list, in case the loop was restarted. This produced soft lockups as in https://lkml.org/lkml/2013/4/16/37 rcu_dereference(X)/ACCESS_ONCE(X) seem to not work as intended if X is ptr->field : In some cases, gcc caches the value or ptr->field in a register. Use a barrier() to disallow such caching, as documented in Documentation/atomic_ops.txt line 114 Thanks a lot to Roman for providing analysis and numerous patches. Diagnosed-by: Roman Gushchin <klamm@yandex-team.ru> Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Boris Zhmurov <zhmurov@yandex-team.ru> Signed-off-by: Roman Gushchin <klamm@yandex-team.ru> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-27net: Block MSG_CMSG_COMPAT in send(m)msg and recv(m)msgAndy Lutomirski
[ Upstream commits 1be374a0518a288147c6a7398792583200a67261 and a7526eb5d06b0084ef12d7b168d008fcf516caab ] MSG_CMSG_COMPAT is (AFAIK) not intended to be part of the API -- it's a hack that steals a bit to indicate to other networking code that a compat entry was used. So don't allow it from a non-compat syscall. This prevents an oops when running this code: int main() { int s; struct sockaddr_in addr; struct msghdr *hdr; char *highpage = mmap((void*)(TASK_SIZE_MAX - 4096), 4096, PROT_READ | PROT_WRITE, MAP_PRIVATE | MAP_ANONYMOUS | MAP_FIXED, -1, 0); if (highpage == MAP_FAILED) err(1, "mmap"); s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP); if (s == -1) err(1, "socket"); addr.sin_family = AF_INET; addr.sin_port = htons(1); addr.sin_addr.s_addr = htonl(INADDR_LOOPBACK); if (connect(s, (struct sockaddr*)&addr, sizeof(addr)) != 0) err(1, "connect"); void *evil = highpage + 4096 - COMPAT_MSGHDR_SIZE; printf("Evil address is %p\n", evil); if (syscall(__NR_sendmmsg, s, evil, 1, MSG_CMSG_COMPAT) < 0) err(1, "sendmmsg"); return 0; } Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-20mm: migration: add migrate_entry_wait_huge()Naoya Horiguchi
commit 30dad30922ccc733cfdbfe232090cf674dc374dc upstream. When we have a page fault for the address which is backed by a hugepage under migration, the kernel can't wait correctly and do busy looping on hugepage fault until the migration finishes. As a result, users who try to kick hugepage migration (via soft offlining, for example) occasionally experience long delay or soft lockup. This is because pte_offset_map_lock() can't get a correct migration entry or a correct page table lock for hugepage. This patch introduces migration_entry_wait_huge() to solve this. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com> Reviewed-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Andi Kleen <andi@firstfloor.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-07wait: fix false timeouts when using wait_event_timeout()Imre Deak
commit 4c663cfc523a88d97a8309b04a089c27dc57fd7e upstream. Many callers of the wait_event_timeout() and wait_event_interruptible_timeout() expect that the return value will be positive if the specified condition becomes true before the timeout elapses. However, at the moment this isn't guaranteed. If the wake-up handler is delayed enough, the time remaining until timeout will be calculated as 0 - and passed back as a return value - even if the condition became true before the timeout has passed. Fix this by returning at least 1 if the condition becomes true. This semantic is in line with what wait_for_condition_timeout() does; see commit bb10ed09 ("sched: fix wait_for_completion_timeout() spurious failure under heavy load"). Daniel said "We have 3 instances of this bug in drm/i915. One case even where we switch between the interruptible and not interruptible wait_event_timeout variants, foolishly presuming they have the same semantics. I very much like this." One such bug is reported at https://bugs.freedesktop.org/show_bug.cgi?id=64133 Signed-off-by: Imre Deak <imre.deak@intel.com> Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Jens Axboe <axboe@kernel.dk> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Dave Jones <davej@redhat.com> Cc: Lukas Czerner <lczerner@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19ipv6: do not clear pinet6 fieldEric Dumazet
[ Upstream commit f77d602124d865c38705df7fa25c03de9c284ad2 ] We have seen multiple NULL dereferences in __inet6_lookup_established() After analysis, I found that inet6_sk() could be NULL while the check for sk_family == AF_INET6 was true. Bug was added in linux-2.6.29 when RCU lookups were introduced in UDP and TCP stacks. Once an IPv6 socket, using SLAB_DESTROY_BY_RCU is inserted in a hash table, we no longer can clear pinet6 field. This patch extends logic used in commit fcbdf09d9652c891 ("net: fix nulls list corruptions in sk_prot_alloc") TCP/UDP/UDPLite IPv6 protocols provide their own .clear_sk() method to make sure we do not clear pinet6 field. At socket clone phase, we do not really care, as cloning the parent (non NULL) pinet6 is not adding a fatal race. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19macvlan: fix passthru mode race between dev removal and rx pathJiri Pirko
[ Upstream commit 233c7df0821c4190e2d3f4be0f2ca0ab40a5ed8c, note that I had to add list_first_or_null_rcu to rculist.h in order to accomodate this fix. ] Currently, if macvlan in passthru mode is created and data are rxed and you remove this device, following panic happens: NULL pointer dereference at 0000000000000198 IP: [<ffffffffa0196058>] macvlan_handle_frame+0x153/0x1f7 [macvlan] I'm using following script to trigger this: <script> while [ 1 ] do ip link add link e1 name macvtap0 type macvtap mode passthru ip link set e1 up ip link set macvtap0 up IFINDEX=`ip link |grep macvtap0 | cut -f 1 -d ':'` cat /dev/tap$IFINDEX >/dev/null & ip link del dev macvtap0 done </script> I run this script while "ping -f" is running on another machine to send packets to e1 rx. Reason of the panic is that list_first_entry() is blindly called in macvlan_handle_frame() even if the list was empty. vlan is set to incorrect pointer which leads to the crash. I'm fixing this by protecting port->vlans list by rcu and by preventing from getting incorrect pointer in case the list is empty. Introduced by: commit eb06acdc85585f2 "macvlan: Introduce 'passthru' mode to takeover the underlying device" Signed-off-by: Jiri Pirko <jiri@resnulli.us> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19if_cablemodem.h: Add parenthesis around ioctl macrosJosh Boyer
[ Upstream commit 4f924b2aa4d3cb30f07e57d6b608838edcbc0d88 ] Protect the SIOCGCM* ioctl macros with parenthesis. Reported-by: Paul Wouters <pwouters@redhat.com> Signed-off-by: Josh Boyer <jwboyer@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-19tcp: force a dst refcount when prequeue packetEric Dumazet
[ Upstream commit 093162553c33e9479283e107b4431378271c735d ] Before escaping RCU protected section and adding packet into prequeue, make sure the dst is refcounted. Reported-by: Mike Galbraith <bitbucket@online.de> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-07ipc: sysv shared memory limited to 8TiBRobin Holt
commit d69f3bad4675ac519d41ca2b11e1c00ca115cecd upstream. Trying to run an application which was trying to put data into half of memory using shmget(), we found that having a shmall value below 8EiB-8TiB would prevent us from using anything more than 8TiB. By setting kernel.shmall greater than 8EiB-8TiB would make the job work. In the newseg() function, ns->shm_tot which, at 8TiB is INT_MAX. ipc/shm.c: 458 static int newseg(struct ipc_namespace *ns, struct ipc_params *params) 459 { ... 465 int numpages = (size + PAGE_SIZE -1) >> PAGE_SHIFT; ... 474 if (ns->shm_tot + numpages > ns->shm_ctlall) 475 return -ENOSPC; [akpm@linux-foundation.org: make ipc/shm.c:newseg()'s numpages size_t, not int] Signed-off-by: Robin Holt <holt@sgi.com> Reported-by: Alex Thorlton <athorlton@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01net: fix incorrect credentials passingLinus Torvalds
[ Upstream commit 83f1b4ba917db5dc5a061a44b3403ddb6e783494 ] Commit 257b5358b32f ("scm: Capture the full credentials of the scm sender") changed the credentials passing code to pass in the effective uid/gid instead of the real uid/gid. Obviously this doesn't matter most of the time (since normally they are the same), but it results in differences for suid binaries when the wrong uid/gid ends up being used. This just undoes that (presumably unintentional) part of the commit. Reported-by: Andy Lutomirski <luto@amacapital.net> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Serge E. Hallyn <serge@hallyn.com> Cc: David S. Miller <davem@davemloft.net> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01netfilter: don't reset nf_trace in nf_reset()Patrick McHardy
[ Upstream commit 124dff01afbdbff251f0385beca84ba1b9adda68 ] Commit 130549fe ("netfilter: reset nf_trace in nf_reset") added code to reset nf_trace in nf_reset(). This is wrong and unnecessary. nf_reset() is used in the following cases: - when passing packets up the the socket layer, at which point we want to release all netfilter references that might keep modules pinned while the packet is queued. nf_trace doesn't matter anymore at this point. - when encapsulating or decapsulating IPsec packets. We want to continue tracing these packets after IPsec processing. - when passing packets through virtual network devices. Only devices on that encapsulate in IPv4/v6 matter since otherwise nf_trace is not used anymore. Its not entirely clear whether those packets should be traced after that, however we've always done that. - when passing packets through virtual network devices that make the packet cross network namespace boundaries. This is the only cases where we clearly want to reset nf_trace and is also what the original patch intended to fix. Add a new function nf_reset_trace() and use it in dev_forward_skb() to fix this properly. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-05-01net: count hw_addr syncs so that unsync works properly.Vlad Yasevich
[ Upstream commit 4543fbefe6e06a9e40d9f2b28d688393a299f079 ] A few drivers use dev_uc_sync/unsync to synchronize the address lists from master down to slave/lower devices. In some cases (bond/team) a single address list is synched down to multiple devices. At the time of unsync, we have a leak in these lower devices, because "synced" is treated as a boolean and the address will not be unsynced for anything after the first device/call. Treat "synced" as a count (same as refcount) and allow all unsync calls to work. Signed-off-by: Vlad Yasevich <vyasevic@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-25vm: add vm_iomap_memory() helper functionLinus Torvalds
commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e upstream. Various drivers end up replicating the code to mmap() their memory buffers into user space, and our core memory remapping function may be very flexible but it is unnecessarily complicated for the common cases to use. Our internal VM uses pfn's ("page frame numbers") which simplifies things for the VM, and allows us to pass physical addresses around in a denser and more efficient format than passing a "phys_addr_t" around, and having to shift it up and down by the page size. But it just means that drivers end up doing that shifting instead at the interface level. It also means that drivers end up mucking around with internal VM things like the vma details (vm_pgoff, vm_start/end) way more than they really need to. So this just exports a function to map a certain physical memory range into user space (using a phys_addr_t based interface that is much more natural for a driver) and hides all the complexity from the driver. Some drivers will still end up tweaking the vm_page_prot details for things like prefetching or cacheability etc, but that's actually relevant to the driver, rather than caring about what the page offset of the mapping is into the particular IO memory region. Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-25KVM: Allow cross page reads and writes from cached translations.Andrew Honig
commit 8f964525a121f2ff2df948dac908dcc65be21b5b upstream. This patch adds support for kvm_gfn_to_hva_cache_init functions for reads and writes that will cross a page. If the range falls within the same memslot, then this will be a fast operation. If the range is split between two memslots, then the slower kvm_read_guest and kvm_write_guest are used. Tested: Test against kvm_clock unit tests. Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12spinlocks and preemption points need to be at least compiler barriersLinus Torvalds
commit 386afc91144b36b42117b0092893f15bc8798a80 upstream. In UP and non-preempt respectively, the spinlocks and preemption disable/enable points are stubbed out entirely, because there is no regular code that can ever hit the kind of concurrency they are meant to protect against. However, while there is no regular code that can cause scheduling, we _do_ end up having some exceptional (literally!) code that can do so, and that we need to make sure does not ever get moved into the critical region by the compiler. In particular, get_user() and put_user() is generally implemented as inline asm statements (even if the inline asm may then make a call instruction to call out-of-line), and can obviously cause a page fault and IO as a result. If that inline asm has been scheduled into the middle of a preemption-safe (or spinlock-protected) code region, we obviously lose. Now, admittedly this is *very* unlikely to actually ever happen, and we've not seen examples of actual bugs related to this. But partly exactly because it's so hard to trigger and the resulting bug is so subtle, we should be extra careful to get this right. So make sure that even when preemption is disabled, and we don't have to generate any actual *code* to explicitly tell the system that we are in a preemption-disabled region, we need to at least tell the compiler not to move things around the critical region. This patch grew out of the same discussion that caused commits 79e5f05edcbf ("ARC: Add implicit compiler barrier to raw_local_irq* functions") and 3e2e0d2c222b ("tile: comment assumption about __insn_mtspr for <asm/irqflags.h>") to come about. Note for stable: use discretion when/if applying this. As mentioned, this bug may never have actually bitten anybody, and gcc may never have done the required code motion for it to possibly ever trigger in practice. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Set max sector to 65535 for Slimtype DVD A DS8A8SH driveShan Hai
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream. The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than 65535, and the blow backtrace is observed on locking up: INFO: task flush-8:32:1130 blocked for more than 120 seconds. "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000 ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000 ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000 ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000 Call Trace: [<ffffffff8168fc2d>] schedule+0x5d/0x70 [<ffffffff8168fccc>] io_schedule+0x8c/0xd0 [<ffffffff81324461>] get_request+0x731/0x7d0 [<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90 [<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40 [<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110 [<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0 [<ffffffff81322176>] generic_make_request+0xc6/0x120 [<ffffffff81322308>] submit_bio+0x138/0x160 [<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120 [<ffffffff811d1f61>] submit_bh+0x1f1/0x220 [<ffffffff811d48b8>] __block_write_full_page+0x228/0x340 [<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d8960>] ? I_BDEV+0x10/0x10 [<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100 [<ffffffff811d4ae5>] block_write_full_page+0x15/0x20 [<ffffffff811d9268>] blkdev_writepage+0x18/0x20 [<ffffffff81142527>] __writepage+0x17/0x40 [<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0 [<ffffffff81142510>] ? set_page_dirty+0x70/0x70 [<ffffffff81143a61>] generic_writepages+0x51/0x80 [<ffffffff81143ab0>] do_writepages+0x20/0x50 [<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0 [<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0 [<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0 [<ffffffff811cad43>] wb_writeback+0x1a3/0x330 [<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50 [<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70 [<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260 [<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240 [<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0 [<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260 [<ffffffff81083550>] kthread+0xc0/0xd0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 [<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0 [<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0 The above trace was triggered by "dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768" It was previously working by accident, since another bug introduced by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused all drives to use maxsect=65535. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12libata: Use integer return value for atapi_command_packet_setShan Hai
commit d8668fcb0b257d9fdcfbe5c172a99b8d85e1cd82 upstream. The function returns type of ATAPI drives so it should return integer value. The commit 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) since v2.6.39 changed the type of return value from int to bool, the change would cause all of the ATAPI class drives to be treated as TYPE_TAPE and the max_sectors of the drives to be set to 65535 because of the commit f8d8e5799b7(libata: increase 128 KB / cmd limit for ATAPI tape drives), for the function would return true for all ATAPI class drives and the TYPE_TAPE is defined as 0x01. Signed-off-by: Shan Hai <shan.hai@windriver.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05thermal: shorten too long mcast group nameMasatake YAMATO
[ Upstream commits 73214f5d9f33b79918b1f7babddd5c8af28dd23d and f1e79e208076ffe7bad97158275f1c572c04f5c7, the latter adds an assertion to genetlink to prevent this from happening again in the future. ] The original name is too long. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05KVM: Ensure all vcpus are consistent with in-kernel irqchip settingsAvi Kivity
commit 3e515705a1f46beb1c942bb8043c16f8ac7b1e9e upstream. If some vcpus are created before KVM_CREATE_IRQCHIP, then irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading to potential NULL pointer dereferences. Fix by: - ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called - ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP This is somewhat long winded because vcpu->arch.apic is created without kvm->lock held. Based on earlier patch by Michael Ellerman. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05NFSv4: Fix an Oops in the NFSv4 getacl codeTrond Myklebust
commit 331818f1c468a24e581aedcbe52af799366a9dfe upstream. Commit bf118a342f10dafe44b14451a1392c3254629a1f (NFSv4: include bitmap in nfsv4 get acl data) introduces the 'acl_scratch' page for the case where we may need to decode multi-page data. However it fails to take into account the fact that the variable may be NULL (for the case where we're not doing multi-page decode), and it also attaches it to the encoding xdr_stream rather than the decoding one. The immediate result is an Oops in nfs4_xdr_enc_getacl due to the call to page_address() with a NULL page pointer. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: Andy Adamson <andros@netapp.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05NFSv4: include bitmap in nfsv4 get acl dataAndy Adamson
commit bf118a342f10dafe44b14451a1392c3254629a1f upstream. The NFSv4 bitmap size is unbounded: a server can return an arbitrary sized bitmap in an FATTR4_WORD0_ACL request. Replace using the nfs4_fattr_bitmap_maxsz as a guess to the maximum bitmask returned by a server with the inclusion of the bitmap (xdr length plus bitmasks) and the acl data xdr length to the (cached) acl page data. This is a general solution to commit e5012d1f "NFSv4.1: update nfs4_fattr_bitmap_maxsz" and fixes hitting a BUG_ON in xdr_shrink_bufhead when getting ACLs. Fix a bug in decode_getacl that returned -EINVAL on ACLs > page when getxattr was called with a NULL buffer, preventing ACL > PAGE_SIZE from being retrieved. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-05signal: Define __ARCH_HAS_SA_RESTORER so we know whether to clear sa_restorerBen Hutchings
Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side struct sigaction declarations'. flush_signal_handlers() needs to know whether sigaction::sa_restorer is defined, not whether SA_RESTORER is defined. Define the __ARCH_HAS_SA_RESTORER macro to indicate this. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28exec: use -ELOOP for max recursion depthKees Cook
commit d740269867021faf4ce38a449353d2b986c34a67 upstream. To avoid an explosion of request_module calls on a chain of abusive scripts, fail maximum recursion with -ELOOP instead of -ENOEXEC. As soon as maximum recursion depth is hit, the error will fail all the way back up the chain, aborting immediately. This also has the side-effect of stopping the user's shell from attempting to reexecute the top-level file as a shell script. As seen in the dash source: if (cmd != path_bshell && errno == ENOEXEC) { *argv-- = cmd; *argv = cmd = path_bshell; goto repeat; } The above logic was designed for running scripts automatically that lacked the "#!" header, not to re-try failed recursion. On a legitimate -ENOEXEC, things continue to behave as the shell expects. Additionally, when tracking recursion, the binfmt handlers should not be involved. The recursion being tracked is the depth of calls through search_binary_handler(), so that function should be exclusively responsible for tracking the depth. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: halfdog <me@halfdog.net> Cc: P J P <ppandit@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28inet: limit length of fragment queue hash table bucket listsHannes Frederic Sowa
[ Upstream commit 5a3da1fe9561828d0ca7eca664b16ec2b9bf0055 ] This patch introduces a constant limit of the fragment queue hash table bucket list lengths. Currently the limit 128 is choosen somewhat arbitrary and just ensures that we can fill up the fragment cache with empty packets up to the default ip_frag_high_thresh limits. It should just protect from list iteration eating considerable amounts of cpu. If we reach the maximum length in one hash bucket a warning is printed. This is implemented on the caller side of inet_frag_find to distinguish between the different users of inet_fragment.c. I dropped the out of memory warning in the ipv4 fragment lookup path, because we already get a warning by the slab allocator. Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-28ipv4: fix definition of FIB_TABLE_HASHSZDenis V. Lunev
[ Upstream commit 5b9e12dbf92b441b37136ea71dac59f05f2673a9 ] a long time ago by the commit commit 93456b6d7753def8760b423ac6b986eb9d5a4a95 Author: Denis V. Lunev <den@openvz.org> Date: Thu Jan 10 03:23:38 2008 -0800 [IPV4]: Unify access to the routing tables. the defenition of FIB_HASH_TABLE size has obtained wrong dependency: it should depend upon CONFIG_IP_MULTIPLE_TABLES (as was in the original code) but it was depended from CONFIG_IP_ROUTE_MULTIPATH This patch returns the situation to the original state. The problem was spotted by Tingwei Liu. Signed-off-by: Denis V. Lunev <den@openvz.org> CC: Tingwei Liu <tingw.liu@gmail.com> CC: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix link failure for non-Intel configsDavid Rientjes
commit 6c4d3bc99b3341067775efd4d9d13cc8e655fd7c upstream. Commit 1d9d8639c063 ("perf,x86: fix kernel crash with PEBS/BTS after suspend/resume") introduces a link failure since perf_restore_debug_store() is only defined for CONFIG_CPU_SUP_INTEL: arch/x86/power/built-in.o: In function `restore_processor_state': (.text+0x45c): undefined reference to `perf_restore_debug_store' Fix it by defining the dummy function appropriately. Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-20perf,x86: fix kernel crash with PEBS/BTS after suspend/resumeStephane Eranian
commit 1d9d8639c063caf6efc2447f5f26aa637f844ff6 upstream. This patch fixes a kernel crash when using precise sampling (PEBS) after a suspend/resume. Turns out the CPU notifier code is not invoked on CPU0 (BP). Therefore, the DS_AREA (used by PEBS) is not restored properly by the kernel and keeps it power-on/resume value of 0 causing any PEBS measurement to crash when running on CPU0. The workaround is to add a hook in the actual resume code to restore the DS Area MSR value. It is invoked for all CPUS. So for all but CPU0, the DS_AREA will be restored twice but this is harmless. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Shuah Khan <shuah.khan@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04unbreak automounter support on 64-bit kernel with 32-bit userspace (v2)Helge Deller
commit 4f4ffc3a5398ef9bdbb32db04756d7d34e356fcf upstream. automount-support is broken on the parisc architecture, because the existing #if list does not include a check for defined(__hppa__). The HPPA (parisc) architecture is similiar to other 64bit Linux targets where we have to define autofs_wqt_t (which is passed back and forth to user space) as int type which has a size of 32bit across 32 and 64bit kernels. During the discussion on the mailing list, H. Peter Anvin suggested to invert the #if list since only specific platforms (specifically those who do not have a 32bit userspace, like IA64 and Alpha) should have autofs_wqt_t as unsigned long type. This suggestion is probably the best way to go, since Arm64 (and maybe others?) seems to have a non-working automounter. So in the long run even for other new upcoming architectures this inverted check seem to be the best solution, since it will not require them to change this #if again (unless they are 64bit only). Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: Ian Kent <raven@themaw.net> Acked-by: Catalin Marinas <catalin.marinas@arm.com> CC: James Bottomley <James.Bottomley@HansenPartnership.com> CC: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04ptrace: introduce signal_wake_up_state() and ptrace_signal_wake_up()Oleg Nesterov
Upstream commit 910ffdb18a6408e14febbb6e4b6840fd2c928c82. Cleanup and preparation for the next change. signal_wake_up(resume => true) is overused. None of ptrace/jctl callers actually want to wakeup a TASK_WAKEKILL task, but they can't specify the necessary mask. Turn signal_wake_up() into signal_wake_up_state(state), reintroduce signal_wake_up() as a trivial helper, and add ptrace_signal_wake_up() which adds __TASK_TRACED. This way ptrace_signal_wake_up() can work "inside" ptrace_request() even if the tracee doesn't have the TASK_WAKEKILL bit set. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Michal Hocko <mhocko@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-04quota: autoload the quota_v2 module for QFMT_VFS_V1 quota formatTheodore Ts'o
commit c3ad83d9efdfe6a86efd44945a781f00c879b7b4 upstream. Otherwise, ext4 file systems with the quota featured enable will get a very confusing "No such process" error message if the quota code is built as a module and the quota_v2 module has not been loaded. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ipv6: use a stronger hash for tcpEric Dumazet
[ Upstream commit 08dcdbf6a7b9d14c2302c5bd0c5390ddf122f664 ] It looks like its possible to open thousands of TCP IPv6 sessions on a server, all landing in a single slot of TCP hash table. Incoming packets have to lookup sockets in a very long list. We should hash all bits from foreign IPv6 addresses, using a salt and hash mix, not a simple XOR. inet6_ehashfn() can also separately use the ports, instead of xoring them. Reported-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Yuchung Cheng <ycheng@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: Yet another band-aid for fixing lockdep messTakashi Iwai
commit e93a9a868792ad71cdd09d75e5a02d8067473c4e upstream. I've still got lockdep warnings even after Alan's patch, and it seems that yet more band aids are required to paper over similar paths for unbind_con_driver() and unregister_con_driver(). After this hack, lockdep warnings are finally gone. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28fb: rework locking to fix lock ordering on takeoverAlan Cox
commit 50e244cc793d511b86adea24972f3a7264cae114 upstream. Adjust the console layer to allow a take over call where the caller already holds the locks. Make the fb layer lock in order. This is partly a band aid, the fb layer is terminally confused about the locking rules it uses for its notifiers it seems. [akpm@linux-foundation.org: remove stray non-ascii char, tidy comment] [akpm@linux-foundation.org: export do_take_over_console()] [airlied: cleanup another non-ascii char] Signed-off-by: Alan Cox <alan@linux.intel.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Jiri Kosina <jkosina@suse.cz> Tested-by: Sedat Dilek <sedat.dilek@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28NLS: improve UTF8 -> UTF16 string conversion routineAlan Stern
commit 0720a06a7518c9d0c0125bd5d1f3b6264c55c3dd upstream. The utf8s_to_utf16s conversion routine needs to be improved. Unlike its utf16s_to_utf8s sibling, it doesn't accept arguments specifying the maximum length of the output buffer or the endianness of its 16-bit output. This patch (as1501) adds the two missing arguments, and adjusts the only two places in the kernel where the function is called. A follow-on patch will add a third caller that does utilize the new capabilities. The two conversion routines are still annoyingly inconsistent in the way they handle invalid byte combinations. But that's a subject for a different patch. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28ALSA: usb: Fix Processing Unit Descriptor parsersPawel Moll
commit b531f81b0d70ffbe8d70500512483227cc532608 upstream. Commit 99fc86450c439039d2ef88d06b222fd51a779176 "ALSA: usb-mixer: parse descriptors with structs" introduced a set of useful parsers for descriptors. Unfortunately the parses for the Processing Unit Descriptor came with a very subtle bug... Functions uac_processing_unit_iProcessing() and uac_processing_unit_specific() were indexing the baSourceID array forgetting the fields before the iProcessing and process-specific descriptors. The problem was observed with Sound Blaster Extigy mixer, where nNrModes in Up/Down-mix Processing Unit Descriptor was accessed at offset 10 of the descriptor (value 0) instead of offset 15 (value 7). In result the resulting control had interesting limit values: Simple mixer control 'Channel Routing Mode Select',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - -1 Mono: -1 [100%] Fixed by starting from the bmControls, which was calculated correctly, instead of baSourceID. Now the mentioned control is fine: Simple mixer control 'Channel Routing Mode Select',0 Capabilities: volume volume-joined penum Playback channels: Mono Capture channels: Mono Limits: 0 - 6 Mono: 0 [0%] Signed-off-by: Pawel Moll <mail@pawelmoll.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-28mm: mmu_notifier: have mmu_notifiers use a global SRCU so they may safely ↵Sagi Grimberg
schedule commit 21a92735f660eaecf69a6f2e777f18463760ec32 upstream. With an RCU based mmu_notifier implementation, any callout to mmu_notifier_invalidate_range_{start,end}() or mmu_notifier_invalidate_page() would not be allowed to call schedule() as that could potentially allow a modification to the mmu_notifier structure while it is currently being used. Since srcu allocs 4 machine words per instance per cpu, we may end up with memory exhaustion if we use srcu per mm. So all mms share a global srcu. Note that during large mmu_notifier activity exit & unregister paths might hang for longer periods, but it is tolerable for current mmu_notifier clients. Signed-off-by: Sagi Grimberg <sagig@mellanox.co.il> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Haggai Eran <haggaie@mellanox.com> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-21printk: fix buffer overflow when calling log_prefix function from ↵Alexandre SIMON
call_console_drivers This patch corrects a buffer overflow in kernels from 3.0 to 3.4 when calling log_prefix() function from call_console_drivers(). This bug existed in previous releases but has been revealed with commit 162a7e7500f9664636e649ba59defe541b7c2c60 (2.6.39 => 3.0) that made changes about how to allocate memory for early printk buffer (use of memblock_alloc). It disappears with commit 7ff9554bb578ba02166071d2d487b7fc7d860d62 (3.4 => 3.5) that does a refactoring of printk buffer management. In log_prefix(), the access to "p[0]", "p[1]", "p[2]" or "simple_strtoul(&p[1], &endp, 10)" may cause a buffer overflow as this function is called from call_console_drivers by passing "&LOG_BUF(cur_index)" where the index must be masked to do not exceed the buffer's boundary. The trick is to prepare in call_console_drivers() a buffer with the necessary data (PRI field of syslog message) to be safely evaluated in log_prefix(). This patch can be applied to stable kernel branches 3.0.y, 3.2.y and 3.4.y. Without this patch, one can freeze a server running this loop from shell : $ export DUMMY=`cat /dev/urandom | tr -dc '12345AZERTYUIOPQSDFGHJKLMWXCVBNazertyuiopqsdfghjklmwxcvbn' | head -c255` $ while true do ; echo $DUMMY > /dev/kmsg ; done The "server freeze" depends on where memblock_alloc does allocate printk buffer : if the buffer overflow is inside another kernel allocation the problem may not be revealed, else the server may hangs up. Signed-off-by: Alexandre SIMON <Alexandre.Simon@univ-lorraine.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-27ahci: Add identifiers for ASM106x devicesAlan Cox
commit 7b4f6ecacb14f384adc1a5a67ad95eb082c02bd1 upstream. They don't always appear as AHCI class devices but instead as IDE class. Based on an initial patch by Hiroaki Nito Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=42804 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Abdallah Chatila <abdallah.chatila@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rtnetlink: Fix problem with buffer allocationGreg Rose
commit 115c9b81928360d769a76c632bae62d15206a94a upstream. Implement a new netlink attribute type IFLA_EXT_MASK. The mask is a 32 bit value that can be used to indicate to the kernel that certain extended ifinfo values are requested by the user application. At this time the only mask value defined is RTEXT_FILTER_VF to indicate that the user wants the ifinfo dump to send information about the VFs belonging to the interface. This patch fixes a bug in which certain applications do not have large enough buffers to accommodate the extra information returned by the kernel with large numbers of SR-IOV virtual functions. Those applications will not send the new netlink attribute with the interface info dump request netlink messages so they will not get unexpectedly large request buffers returned by the kernel. Modifies the rtnl_calcit function to traverse the list of net devices and compute the minimum buffer size that can hold the info dumps of all matching devices based upon the filter passed in via the new netlink attribute filter mask. If no filter mask is sent then the buffer allocation defaults to NLMSG_GOODSIZE. With this change it is possible to add yet to be defined netlink attributes to the dump request which should make it fairly extensible in the future. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Acked-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> [bwh: Backported to 3.0: - Adjust context - Drop the change in do_setlink() that reverts commit f18da1456581 ('net: RTNETLINK adjusting values of min_ifinfo_dump_size'), which was never applied here] Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-17rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream. The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: limit mmu_gather batching to fix soft lockups on !CONFIG_PREEMPTMichal Hocko
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream. Since commit e303297e6c3a ("mm: extended batches for generic mmu_gather") we are batching pages to be freed until either tlb_next_batch cannot allocate a new batch or we are done. This works just fine most of the time but we can get in troubles with non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY) on large machines where too aggressive batching might lead to soft lockups during process exit path (exit_mmap) because there are no scheduling points down the free_pages_and_swap_cache path and so the freeing can take long enough to trigger the soft lockup. The lockup is harmless except when the system is setup to panic on softlockup which is not that unusual. The simplest way to work around this issue is to limit the maximum number of batches in a single mmu_gather. 10k of collected pages should be safe to prevent from soft lockups (we would have 2ms for one) even if they are all freed without an explicit scheduling point. This patch doesn't add any new explicit scheduling points because it relies on zap_pmd_range during page tables zapping which calls cond_resched per PMD. The following lockup has been reported for 3.0 kernel with a huge process (in order of hundreds gigs but I do know any more details). BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053] Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod Supported: Yes CPU 56 Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7 RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10 RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206 RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80 RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206 RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400 R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100) Call Trace: release_pages+0xc5/0x260 free_pages_and_swap_cache+0x9d/0xc0 tlb_flush_mmu+0x5c/0x80 tlb_finish_mmu+0xe/0x50 exit_mmap+0xbd/0x120 mmput+0x49/0x120 exit_mm+0x122/0x160 do_exit+0x17a/0x430 do_group_exit+0x3d/0xb0 get_signal_to_deliver+0x247/0x480 do_signal+0x71/0x1b0 do_notify_resume+0x98/0xb0 int_signal+0x12/0x17 DWARF2 unwinder stuck at int_signal+0x12/0x17 Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Mel Gorman <mgorman@suse.de> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11PCI: Reduce Ricoh 0xe822 SD card reader base clock frequency to 50MHzAndy Lutomirski
commit 812089e01b9f65f90fc8fc670d8cce72a0e01fbb upstream. Otherwise it fails like this on cards like the Transcend 16GB SDHC card: mmc0: new SDHC card at address b368 mmcblk0: mmc0:b368 SDC 15.0 GiB mmcblk0: error -110 sending status command, retrying mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0xb0 Tested on my Lenovo x200 laptop. [bhelgaas: changelog] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Chris Ball <cjb@laptop.org> CC: Manoj Iyer <manoj.iyer@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: implement RFC 5961 4.2Eric Dumazet
[ Upstream commit 0c24604b68fc7810d429d6c3657b6f148270e528 ] Implement the RFC 5691 mitigation against Blind Reset attack using SYN bit. Section 4.2 of RFC 5961 advises to send a Challenge ACK and drop incoming packet, instead of resetting the session. Add a new SNMP counter to count number of challenge acks sent in response to SYN packets. (netstat -s | grep TCPSYNChallenge) Remove obsolete TCPAbortOnSyn, since we no longer abort a TCP session because of a SYN flag. Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11tcp: implement RFC 5961 3.2Eric Dumazet
[ Upstream commit 282f23c6ee343126156dd41218b22ece96d747e3 ] Implement the RFC 5691 mitigation against Blind Reset attack using RST bit. Idea is to validate incoming RST sequence, to match RCV.NXT value, instead of previouly accepted window : (RCV.NXT <= SEG.SEQ < RCV.NXT+RCV.WND) If sequence is in window but not an exact match, send a "challenge ACK", so that the other part can resend an RST with the appropriate sequence. Add a new sysctl, tcp_challenge_ack_limit, to limit number of challenge ACK sent per second. Add a new SNMP counter to count number of challenge acks sent. (netstat -s | grep TCPChallengeACK) Signed-off-by: Eric Dumazet <edumazet@google.com> Cc: Kiran Kumar Kella <kkiran@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11ftrace: Do not function trace inlined functionsSteven Rostedt
commit 45959ee7aa645815a5ce303a0ea1e48a21e67c6a upstream. When gcc inlines a function, it does not mark it with the mcount prologue, which in turn means that inlined functions are not traced by the function tracer. But if CONFIG_OPTIMIZE_INLINING is set, then gcc is allowed not to inline a function that is marked inline. Depending on the options and the compiler, a function may or may not be traced by the function tracer, depending on whether gcc decides to inline a function or not. This has caused several problems in the pass becaues gcc is not always consistent with what it decides to inline between different gcc versions. Some places should not be traced (like paravirt native_* functions) and these are mostly marked as inline. When gcc decides not to inline the function, and if that function should not be traced, then the ftrace function tracer will suddenly break when it use to work fine. This becomes even harder to debug when different versions of gcc will not inline that function, making the same kernel and config work for some gcc versions and not work for others. By making all functions marked inline to not be traced will remove the ambiguity that gcc adds when it comes to tracing functions marked inline. All gcc versions will be consistent with what functions are traced and having volatile working code will be removed. Note, only the inline macro when CONFIG_OPTIMIZE_INLINING is set needs to have notrace added, as the attribute __always_inline will force the function to be inlined and then not traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11mm: Fix PageHead when !CONFIG_PAGEFLAGS_EXTENDEDChristoffer Dall
commit ad4b3fb7ff9940bcdb1e4cd62bd189d10fa636ba upstream. Unfortunately with !CONFIG_PAGEFLAGS_EXTENDED, (!PageHead) is false, and (PageHead) is true, for tail pages. If this is indeed the intended behavior, which I doubt because it breaks cache cleaning on some ARM systems, then the nomenclature is highly problematic. This patch makes sure PageHead is only true for head pages and PageTail is only true for tail pages, and neither is true for non-compound pages. [ This buglet seems ancient - seems to have been introduced back in Apr 2008 in commit 6a1e7f777f61: "pageflags: convert to the use of new macros". And the reason nobody noticed is because the PageHead() tests are almost all about just sanity-checking, and only used on pages that are actual page heads. The fact that the old code returned true for tail pages too was thus not really noticeable. - Linus ] Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu> Acked-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Will Deacon <Will.Deacon@arm.com> Cc: Steve Capper <Steve.Capper@arm.com> Cc: Christoph Lameter <cl@linux.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-11exec: do not leave bprm->interp on stackKees Cook
commit b66c5984017533316fd1951770302649baf1aa33 upstream. If a series of scripts are executed, each triggering module loading via unprintable bytes in the script header, kernel stack contents can leak into the command line. Normally execution of binfmt_script and binfmt_misc happens recursively. However, when modules are enabled, and unprintable bytes exist in the bprm->buf, execution will restart after attempting to load matching binfmt modules. Unfortunately, the logic in binfmt_script and binfmt_misc does not expect to get restarted. They leave bprm->interp pointing to their local stack. This means on restart bprm->interp is left pointing into unused stack memory which can then be copied into the userspace argv areas. After additional study, it seems that both recursion and restart remains the desirable way to handle exec with scripts, misc, and modules. As such, we need to protect the changes to interp. This changes the logic to require allocation for any changes to the bprm->interp. To avoid adding a new kmalloc to every exec, the default value is left as-is. Only when passing through binfmt_script or binfmt_misc does an allocation take place. For a proof of concept, see DoTest.sh from: http://www.halfdog.net/Security/2012/LinuxKernelBinfmtScriptStackDataDisclosure/ Signed-off-by: Kees Cook <keescook@chromium.org> Cc: halfdog <me@halfdog.net> Cc: P J P <ppandit@redhat.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17tmpfs: fix shared mempolicy leakMel Gorman
commit 18a2f371f5edf41810f6469cb9be39931ef9deb9 upstream. This fixes a regression in 3.7-rc, which has since gone into stable. Commit 00442ad04a5e ("mempolicy: fix a memory corruption by refcount imbalance in alloc_pages_vma()") changed get_vma_policy() to raise the refcount on a shmem shared mempolicy; whereas shmem_alloc_page() went on expecting alloc_page_vma() to drop the refcount it had acquired. This deserves a rework: but for now fix the leak in shmem_alloc_page(). Hugh: shmem_swapin() did not need a fix, but surely it's clearer to use the same refcounting there as in shmem_alloc_page(), delete its onstack mempolicy, and the strange mpol_cond_copy() and __mpol_cond_copy() - those were invented to let swapin_readahead() make an unknown number of calls to alloc_pages_vma() with one mempolicy; but since 00442ad04a5e, alloc_pages_vma() has kept refcount in balance, so now no problem. Reported-and-tested-by: Tommi Rantala <tt.rantala@gmail.com> Signed-off-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Hugh Dickins <hughd@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26PCI : ability to relocate assigned pci-resourcesRam Pai
commit 2bbc6942273b5b3097bd265d82227bdd84b351b2 upstream. Currently pci-bridges are allocated enough resources to satisfy their immediate requirements. Any additional resource-requests fail if additional free space, contiguous to the one already allocated, is not available. This behavior is not reasonable since sufficient contiguous resources, that can satisfy the request, are available at a different location. This patch provides the ability to expand and relocate a allocated resource. v2: Changelog: Fixed size calculation in pci_reassign_resource() v3: Changelog : Split this patch. The resource.c changes are already upstream. All the pci driver changes are in here. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Andrew Worsley <amworsley@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-17ALSA: Add a reference counter to card instanceTakashi Iwai
commit a0830dbd4e42b38aefdf3fb61ba5019a1a99ea85 upstream. For more strict protection for wild disconnections, a refcount is introduced to the card instance, and let it up/down when an object is referred via snd_lookup_*() in the open ops. The free-after-last-close check is also changed to check this refcount instead of the empty list, too. Reported-by: Matthieu CASTET <matthieu.castet@parrot.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
