Required to build backports-5.4.
cherry picked from commit fe18957e8e87403a9d4be8e8a62352ef107def99
Add GOST/IETF Streebog hash function (GOST R 34.11-2012, RFC 6986)
generic hash transformation.
Related-to: ELB-2388
Cc: linux-integrity@vger.kernel.org
Signed-off-by: Vitaly Chikunov <vt@altlinux.org>
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
cherry picked from commit 4f0fc1600edbdb3612b931aa5076ca984f7ee8fe
Add OSCCA SM3 secure hash (OSCCA GM/T 0004-2012 SM3)
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
cherry picked from commit 53964b9ee63b7075931b8df85307c449da564b50
This patch adds the implementation of SHA3 algorithm
in software and it's based on original implementation
pushed in patch https://lwn.net/Articles/518415/ with
additional changes to match the padding rules specified
in SHA-3 specification.
Signed-off-by: Raveendra Padasalagi <raveendra.padasalagi@broadcom.com>
cherry picked from commit ee08997fee16f10be23c9748d609dbdf3baab8e4
This patch provides a single place for information about hash algorithms,
such as hash sizes and kernel driver names, which will be used by IMA
and the public key code.
Changelog:
- Fix sparse and checkpatch warnings
- Move hash algo enums to uapi for userspace signing functions.
Signed-off-by: Dmitry Kasatkin <d.kasatkin@samsung.com>
Signed-off-by: Mimi Zohar <zohar@linux.vnet.ibm.com>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
In some cases struct bug_entry can be used before declaring [1].
This patch fixes such situations.
[1] Building the backports-5.4 for toradex_tk1_l4t_r21.7-next
In file included from /home/cryo/work/bp-5.4-clean/backport-include/linux/bug.h:3,
from /home/cryo/work/bp-5.4-clean/backport-include/linux/kernel.h:4,
from include/asm-generic/bug.h:13,
from /home/cryo/work/bp-5.4-clean/backport-include/asm-generic/bug.h:4,
from /home/cryo/work/gitlab/linux-toradex-32/arch/arm/include/asm/bug.h:59,
from /home/cryo/work/bp-5.4-clean/backport-include/asm/bug.h:4,
from /home/cryo/work/gitlab/linux-toradex-32/arch/arm/include/asm/div64.h:63,
from include/linux/math64.h:5,
from /home/cryo/work/bp-5.4-clean/backport-include/linux/math64.h:3,
from include/linux/jiffies.h:4,
from /home/cryo/work/bp-5.4-clean/backport-include/linux/jiffies.h:3,
from /home/cryo/work/bp-5.4-clean/net/mac80211/rx.c:12:
include/linux/bug.h:91:47: warning: ‘struct bug_entry’ declared inside parameter list will not be visible outside of this definition or declaration
91 | static inline int is_warning_bug(const struct bug_entry *bug)
include/linux/bug.h: In function ‘is_warning_bug’:
include/linux/bug.h:93:12: error: dereferencing pointer to incomplete type ‘const struct bug_entry’
93 | return bug->flags & BUGFLAG_WARNING;
[ Upstream commit a6e60d84989fa0e91db7f236eda40453b0e44afa ]
The upcoming GCC 9 release extends the -Wmissing-attributes warnings
(enabled by -Wall) to C and aliases: it warns when particular function
attributes are missing in the aliases but not in their target.
In particular, it triggers for all the init/cleanup_module
aliases in the kernel (defined by the module_init/exit macros),
ending up being very noisy.
These aliases point to the __init/__exit functions of a module,
which are defined as __cold (among other attributes). However,
the aliases themselves do not have the __cold attribute.
Since the compiler behaves differently when compiling a __cold
function as well as when compiling paths leading to calls
to __cold functions, the warning is trying to point out
the possibly-forgotten attribute in the alias.
In order to keep the warning enabled, we decided to silence
this case. Ideally, we would mark the aliases directly
as __init/__exit. However, there are currently around 132 modules
in the kernel which are missing __init/__exit in their init/cleanup
functions (either because they are missing, or for other reasons,
e.g. the functions being called from somewhere else); and
a section mismatch is a hard error.
A conservative alternative was to mark the aliases as __cold only.
However, since we would like to eventually enforce __init/__exit
to be always marked, we chose to use the new __copy function
attribute (introduced by GCC 9 as well to deal with this).
With it, we copy the attributes used by the target functions
into the aliases. This way, functions that were not marked
as __init/__exit won't have their aliases marked either,
and therefore there won't be a section mismatch.
Note that the warning would go away marking either the extern
declaration, the definition, or both. However, we only mark
the definition of the alias, since we do not want callers
(which only see the declaration) to be compiled as if the function
was __cold (and therefore the paths leading to those calls
would be assumed to be unlikely).
Cc: <stable@vger.kernel.org> # 4.14+
Link: https://lore.kernel.org/lkml/20190123173707.GA16603@gmail.com/
Link: https://lore.kernel.org/lkml/20190206175627.GA20399@gmail.com/
Suggested-by: Martin Sebor <msebor@gcc.gnu.org>
Acked-by: Jessica Yu <jeyu@kernel.org>
Signed-off-by: Miguel Ojeda <miguel.ojeda.sandonis@gmail.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
(cherry picked from commit dbc40d3d4afafbce1d64acedc28dfbeb4bf20695)
include/linux/module.h Changed code has moved to a different file
[ Upstream commit c0d9782f5b6d7157635ae2fd782a4b27d55a6013
From the GCC manual:
copy
copy(function)
The copy attribute applies the set of attributes with which function
has been declared to the declaration of the function to which
the attribute is applied. The attribute is designed for libraries
that define aliases or function resolvers that are expected
to specify the same set of attributes as their targets. The copy
attribute can be used with functions, variables, or types. However,
the kind of symbol to which the attribute is applied (either
function or variable) must match the kind of symbol to which
the argument refers. The copy attribute copies only syntactic and
semantic attributes but not attributes that affect a symbol’s
linkage or visibility such as alias, visibility, or weak.
The deprecated attribute is also not copied.
https://gcc.gnu.org/onlinedocs/gcc/Common-Function-Attributes.html
attributes are missing in the aliases but not in their target, e.g.:
void __cold f(void) {}
void __alias("f") g(void);
diagnoses:
warning: 'g' specifies less restrictive attribute than
its target 'f': 'cold' [-Wmissing-attributes]
Using __copy(f) we can copy the __cold attribute from f to g:
void __copy(f) __alias("f") g(void);
This attribute is most useful to deal with situations where an alias
is declared but we don't know the exact attributes the target has.
For instance, in the kernel, the widely used module_init/exit macros
define the init/cleanup_module aliases, but those cannot be marked
always as __init/__exit since some modules do not have their
functions marked as such.
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
(cherry picked from commit c4fa716aa388078b44017d25ebc66fb661cef7c3)
include/linux/compiler.h
Define SND_SOC_DAPM_PRE_POST_PMU to reduce code.
Related to: #48500
u
This fixes breakage to iproute2 build with recent kernel headers
caused by:
commit a263653ed798216c0069922d7b5237ca49436007
Author: Pablo Neira Ayuso <pablo@netfilter.org>
Date: Wed Jun 17 10:28:27 2015 -0500
netfilter: don't pull include/linux/netfilter.h from netns headers
The issue is that definitions in linux/in.h overlap with those
in netinet/in.h. This patch solves this by introducing the same
mechanism as was used to solve the same problem with linux/in6.h
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
(cherry picked from commit 279c6c7fa64f5763e6b9f05e7ab3840092e702e7)
Resolve conflicts between glibc definition of IPV6 socket options
and those defined in Linux headers. Looks like earlier efforts to
solve this did not cover all the definitions.
It resolves warnings during iproute2 build.
Please consider for stable as well.
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
(cherry picked from commit 6d08acd2d32e3e877579315dc3202d7a5f336d98)
Solution:
- Synchronize linux's `include/uapi/linux/in6.h'
with glibc's `inet/netinet/in.h'.
- Synchronize glibc's `inet/netinet/in.h with linux's
`include/uapi/linux/in6.h'.
- Allow including the headers in either other.
- First header included defines the structures and macros.
Details:
The kernel promises not to break the UAPI ABI so I don't
see why we can't just have the two userspace headers
coordinate?
If you include the kernel headers first you get those,
and if you include the glibc headers first you get those,
and the following patch arranges a coordination and
synchronization between the two.
Let's handle `include/uapi/linux/in6.h' from linux,
and `inet/netinet/in.h' from glibc and ensure they compile
in any order and preserve the required ABI.
These two patches pass the following compile tests:
cat >> test1.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test1.c
cat >> test2.c <<EOF
int main (void) {
return 0;
EOF
gcc -c test2.c
One wrinkle is that the kernel has a different name for one of
the members in ipv6_mreq. In the kernel patch we create a macro
to cover the uses of the old name, and while that's not entirely
clean it's one of the best solutions (aside from an anonymous
union which has other issues).
I've reviewed the code and it looks to me like the ABI is
assured and everything matches on both sides.
Notes:
- You want netinet/in.h to include bits/in.h as early as possible,
but it needs in_addr so define in_addr early.
- You want bits/in.h included as early as possible so you can use
the linux specific code to define __USE_KERNEL_DEFS based on
the _UAPI_* macro definition and use those to cull in.h.
- glibc was missing IPPROTO_MH, added here.
Compile tested and inspected.
Reported-by: Thomas Backlund <tmb@mageia.org>
Cc: Thomas Backlund <tmb@mageia.org>
Cc: libc-alpha@sourceware.org
Cc: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Tested-by: Cong Wang <amwang@redhat.com>
Signed-off-by: Carlos O'Donell <carlos@redhat.com>
Signed-off-by: Cong Wang <amwang@redhat.com>
(cherry picked from commit cfd280c91253cc28e4919e349fa7a813b63e71e8)
Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
This reverts commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466.
gcc-7 has an "optimization" pass that completely screws up, and
generates the code expansion for the (impossible) case of calling
ilog2() with a zero constant, even when the code gcc compiles does not
actually have a zero constant.
And we try to generate a compile-time error for anybody doing ilog2() on
a constant where that doesn't make sense (be it zero or negative). So
now gcc7 will fail the build due to our sanity checking, because it
created that constant-zero case that didn't actually exist in the source
code.
There's a whole long discussion on the kernel mailing about how to work
around this gcc bug. The gcc people themselevs have discussed their
"feature" in
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=72785
but it's all water under the bridge, because while it looked at one
point like it would be solved by the time gcc7 was released, that was
not to be.
So now we have to deal with this compiler braindamage.
And the only simple approach seems to be to just delete the code that
tries to warn about bad uses of ilog2().
So now "ilog2()" will just return 0 not just for the value 1, but for
any non-positive value too.
It's not like I can recall anybody having ever actually tried to use
this function on any invalid value, but maybe the sanity check just
meant that such code never made it out in public.
Reported-by: Laura Abbott <labbott@redhat.com>
Cc: John Stultz <john.stultz@linaro.org>,
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
(cherry picked from commit 474c90156c8dcc2fa815e6716cc9394d7930cb9c)
tools/include/linux/log2.h
File does not exist in the 3.1 kernel, change dropped.
This helps with the move to GCC 8.
| include/linux/log2.h:22:1: error: ignoring attribute 'noreturn' because it conflicts with attribute 'const' [-Werror=attributes]
| int ____ilog2_NaN(void);
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
Commit f3804203306e upstream.
array_index_nospec() is proposed as a generic mechanism to mitigate
against Spectre-variant-1 attacks, i.e. an attack that bypasses boundary
checks via speculative execution. The array_index_nospec()
implementation is expected to be safe for current generation CPUs across
multiple architectures (ARM, x86).
Based on an original implementation by Linus Torvalds, tweaked to remove
speculative flows by Alexei Starovoitov, and tweaked again by Linus to
introduce an x86 assembly implementation for the mask generation.
Change-Id: I859161a289215b20bd25ef4006115c0268b30b83
Co-developed-by: Linus Torvalds <torvalds@linux-foundation.org>
Co-developed-by: Alexei Starovoitov <ast@kernel.org>
Suggested-by: Cyril Novikov <cnovikov@lynx.com>
Cc: kernel-hardening@lists.openwall.com
Cc: Russell King <linux@armlinux.org.uk>
Cc: gregkh@linuxfoundation.org
Cc: torvalds@linux-foundation.org
Cc: alan@linux.intel.com
Link: https://lkml.kernel.org/r/151727414229.33451.18411580953862676575.stgit@dwillia2-desk3.amr.corp.intel.com
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1698396
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
When tcp_sendmsg() allocates a fresh and empty skb, it puts it
at the tail of the write queue using tcp_add_write_queue_tail()
Then it attempts to copy user data into this fresh skb.
If the copy fails, we undo the work and remove the fresh skb.
Unfortunately, this undo lacks the change done to tp->highest_sack and we can leave a dangling pointer (to a freed skb)
Later, tcp_xmit_retransmit_queue() can dereference this pointer and
access freed memory. For regular kernels where memory is not unmapped,
this might cause SACK bugs because tcp_highest_sack_seq() is buggy,
returning garbage instead of tp->snd_nxt, but with various debug
features like CONFIG_DEBUG_PAGEALLOC, this can crash the kernel.
This bug was found by Marco Grassi thanks to syzkaller.
Bug 1823317
Bug 1935735
Change-Id: I9bf709b21e5637f338c34d894617f33d84f93ecc
Reported-by: Marco Grassi <marco.gra@gmail.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Reviewed-on: http://git-master/r/1260003
(cherry picked from commit 0c20962647685008dfc6a15fb8a2169ed2abafe6)
Reviewed-on: https://git-master.nvidia.com/r/1690290
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
To support a wider variety of backlight setups, introduce an optional
enable GPIO. Legacy users of the platform data already have a means of
supporting GPIOs by using the .init(), .exit() and .notify() hooks. DT
users however cannot use those, so an alternative method is required.
In order to ease the introduction of the optional enable GPIO, make it
available in the platform data first, so that existing users can be
converted. Once that has happened a second patch will add code to make
use of it in the driver.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 2b9b1620349e325f184c68cddf3b484499c163c0)
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
Both firmware and kernel are using the same set of constants
in a header file, this patch separates them in to a single file.
That way it will be easier to track changes to FW or kernel.
Add ability to switch between 24.1 and 24.0 lvds modes.
Mode description can be found in "Using 24-bpp LVDS Panels with
Intel® Mobile Chipsets for Embedded Applications".
Increased SPI speed for transfers and peripheral speed.
Switch to cleaning IRQ flags on read, instead of separate write.
Switched to zero-copy on SPI reads.
commit 1be7107fbe18eed3e319a6c3e83c78254b693acb upstream.
Stack guard page is a useful feature to reduce a risk of stack smashing
into a different mapping. We have been using a single page gap which
is sufficient to prevent having stack adjacent to a different mapping.
But this seems to be insufficient in the light of the stack usage in
userspace. E.g. glibc uses as large as 64kB alloca() in many commonly
used functions. Others use constructs liks gid_t buffer[NGROUPS_MAX]
which is 256kB or stack strings with MAX_ARG_STRLEN.
This will become especially dangerous for suid binaries and the default
no limit for the stack size limit because those applications can be
tricked to consume a large portion of the stack and a single glibc call
could jump over the guard page. These attacks are not theoretical,
unfortunatelly.
Make those attacks less probable by increasing the stack guard gap
to 1MB (on systems with 4k pages; but make it depend on the page size
because systems with larger base pages might cap stack allocations in
the PAGE_SIZE units) which should cover larger alloca() and VLA stack
allocations. It is obviously not a full fix because the problem is
somehow inherent, but it should reduce attack space a lot.
One could argue that the gap size should be configurable from userspace,
but that can be done later when somebody finds that the new 1MB is wrong
for some special case applications. For now, add a kernel command line
option (stack_guard_gap) to specify the stack gap size (in page units).
Implementation wise, first delete all the old code for stack guard page:
because although we could get away with accounting one extra page in a
stack vma, accounting a larger gap can break userspace - case in point,
a program run with "ulimit -S -v 20000" failed when the 1MB gap was
counted for RLIMIT_AS; similar problems could come with RLIMIT_MLOCK
and strict non-overcommit mode.
Instead of keeping gap inside the stack vma, maintain the stack guard
gap as a gap between vmas: using vm_start_gap() in place of vm_start
(or vm_end_gap() in place of vm_end if VM_GROWSUP) in just those few
places which need to respect the gap - mainly arch_get_unmapped_area(),
and and the vma tree's subtree_gap support for that.
Bug 1946430
Change-Id: I9a66aabc34b687996fb971e01bb0ef30a3d4de7d
Original-patch-by: Oleg Nesterov <oleg@redhat.com>
Original-patch-by: Michal Hocko <mhocko@suse.com>
Tested-by: Helge Deller <deller@gmx.de> # parisc
[wt: backport to 4.11: adjust context]
[wt: backport to 4.9: adjust context ; kernel doc was not in admin-guide]
[wt: backport to 4.4: adjust context ; drop ppc hugetlb_radix changes]
Signed-off-by: Willy Tarreau <w@1wt.eu>
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1509390
Some functionality used by android binary drivers
were missing.
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes
b271e8fa67a6d9c4600274a25636cfe00fdd1b68
Bug 200336148
This reverts commit 2db040946ff8340485b2b33fe5a46f3166fa96f6.
Change-Id: I8a80a7bd1bd8b1a949fba26b683ac1c9bebc0c04
Signed-off-by: Debarshi Dutta <ddutta@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1534941
We have never used the IOCTL FREE_OBJ_CTX. Using it leads to context being
only partially available, and can lead to use-after-free.
Bug 1885775
Change-Id: I9d2b632ab79760f8186d02e0f35861b3a6aae649
Reviewed-on: https://git-master.nvidia.com/r/1506479
This patch includes CAN driver and improvements in SPI communications
for Apalis TK1 k20 based MFD.
Requires firmware version 0.9.
Check a few input params to make sure there is
no potential for a heap overflow in the driver.
(Back ported from Nexus N9 project)
Bug 1757475 (nvidia)
Bug 1832830 (nvidia)
Bug 28193342 (google)
Change-Id: I979fa38c5f453cfad7070f0340ec04adde5bac13
Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com>
Reviewed-on: http://git-master/r/1271369
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Several places in the camera stack can hit integer overflows or cause
bad allocations if userspace passes in a bogus sizeofvalue parameter.
Protect against this by using appropriately-sized integer types, adding
range checks, replacing array-allocation calls with kcalloc(), and
checking for allocations returning ZERO_SIZE_PTR.
For one specific ioctl (PCLLK_IOCTL_UPDATE) sizeofvalue = 0 is fine,
since when that happens the subdrivers won't actually touch the returned
allocation. In fact the existing userspace camera driver makes calls
like these and expects them to succeed! Handle this special case by
adding a __camera_get_params variant that optionally treats zero-sized
inputs as valid.
(back ported from Nexus N9 project)
Bug 1832830
Change-Id: Ie3250d8a4b814de5820fa0190b4cbd1af3ca4b3f
Reported-by: Jianqiang Zhao <zhaojianqiang1@gmail.com>
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Reviewed-on: http://git-master/r/1271367
On Apalis TK1 boards K20 MCU is used
for CAN, GPIO, ADC and touch screen.
This patch includes support for core MFD device, GPIO, ADC
and touch screen.
commit 19be0eaffa3ac7d8eb6784ad9bdbc7d67ed8e619 upstream.
This is an ancient bug that was actually attempted to be fixed once
(badly) by me eleven years ago in commit 4ceb5db9757a ("Fix
get_user_pages() race for write access") but that was then undone due to
problems on s390 by commit f33ea7f404e5 ("fix get_user_pages bug").
In the meantime, the s390 situation has long been fixed, and we can now
fix it by checking the pte_dirty() bit properly (and do it better). The
s390 dirty bit was implemented in abf09bed3cce ("s390/mm: implement
software dirty bits") which made it into v3.9. Earlier kernels will
have to look at the page state itself.
Also, the VM has become more scalable, and what used a purely
theoretical race back then has become easier to trigger.
To fix it, we introduce a new internal FOLL_COW flag to mark the "yes,
we already did a COW" rather than play racy games with FOLL_WRITE that
is very fundamental, and then use the pte dirty flag to validate that
the FOLL_COW flag is still valid.
Reported-and-tested-by: Phil "not Paul" Oester <kernel@linuxace.com>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Willy Tarreau <w@1wt.eu>
Cc: Nick Piggin <npiggin@gmail.com>
Cc: stable@vger.kernel.org
[wt: s/gup.c/memory.c; s/follow_page_pte/follow_page_mask;
s/faultin_page/__get_user_page]
Change-Id: I6fbb1abf656ff7e05ec4c65f07dbbdd694546fb4
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Signed-off-by: Sumit Gupta <sumitg@nvidia.com>
Reviewed-on: http://git-master/r/1241321
commit 95272c29378ee7dc15f43fa2758cb28a5913a06d upstream.
-ftracer can duplicate asm blocks causing compilation to fail in
noclone functions. For example, KVM declares a global variable
in an asm like
asm("2: ... \n
.pushsection data \n
.global vmx_return \n
vmx_return: .long 2b");
and -ftracer causes a double declaration.
Cc: Michal Marek <mmarek@suse.cz>
Cc: kvm@vger.kernel.org
Reported-by: Linda Walsh <lkml@tlinx.org>
(cherry picked from commit 5d814ad8d35e5e23e0c27fb0f0b80c1044ecefad)
commit cb984d101b30eb7478d32df56a0023e4603cba7f upstream.
As gcc major version numbers are going to advance rather rapidly in the
future, there's no real value in separate files for each compiler
version.
Deduplicate some of the macros #defined in each file too.
Neaten comments using normal kernel commenting style.
Cc: Segher Boessenkool <segher@kernel.crashing.org>
Cc: Sasha Levin <levinsasha928@gmail.com>
Cc: Alan Modra <amodra@gmail.com>
[ philm: backport to 3.10-stable ]
Signed-off-by: Philip Müller <philm@manjaro.org>
(cherry picked from commit a4a4f1cd733fe5b345db4e8cc19bb8868d562a8a)
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
Added support to use polling mode instead of interrupts
through a property in dt
Bug 1679083
Change-Id: Ic82ab592822cc96bacda05124d38ddd913e09af9
Reviewed-on: http://git-master/r/840233
(cherry picked from commit cd1c4db5adc8317572106099da37fa434245e699)
Reviewed-on: http://git-master/r/1009988
(cherry picked from commit b29ce03a6b7ebb306ff157640470dd5ab99c6f6b)
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1175213
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Tested-by: Matthew Pedro <mapedro@nvidia.com>
SPI register access for T210 and earlier chips depend
on SPI clock frequency. Provided an option to set SPI
clock at max frequency for register access.
Bug 1675625
Change-Id: Ie52c83cd4602604822462d9f02ddf31ead83aafc
Reviewed-on: http://git-master/r/1009782
(cherry picked from commit a2ccd28f2850538064668568432fee5d70a22e82)
Reviewed-on: http://git-master/r/1174581
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
(cherry picked from commit 71458cfc782eafe4b27656e078d379a34e472adf)
