Renaming regulator enums from TPS65090_ID_* to
TPS65090_REGULATOR_* for better readability.
Change-Id: I402de2069045b97000686e8010897c4a0821a48d
Reviewed-on: http://git-master/r/120835
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
This change assists automating system wide
touch driver performance.
Bug 928954
Change-Id: Iea21dfea1c31748ce5835652cecc0856c4f4028d
Signed-off-by: Vikas Jain <vjain@nvidia.com>
Reviewed-on: http://git-master/r/118984
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Reviewed-by: David Jung <djung@nvidia.com>
To make AE transition smoother, the group hold enable/disable actions
should be added before and after set gain/frame length/coarse time.
bug 1025995
Change-Id: I578b33167e50f59d0d9a88a0e16fac0c5425b6b6
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-on: http://git-master/r/119835
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Abhinav Sinha <absinha@nvidia.com>
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
TPS80031 supports the three external regulator named
as REGEN1, REGEN2 and SYSEN.
Supports these regulator through regulator driver.
Change-Id: I6c22aab13499a66ab8b4c68e8a5833553222decd
Reviewed-on: http://git-master/r/119977
Converting tps80031 regulator driver to be register as mfd
sub device of the tps65910 and register all its regulators from
single probe calls.
Add separate platform data for the regulator to be supply from
board as part of tps80031 platform data.
Change-Id: Ie65b25f3058202070f7f917e64a4a660dd941210
Reviewed-on: http://git-master/r/119976
As HSIC phy parameters are not customizable, removing them
from platform_data structure.
bug 1024260
Change-Id: I00fcc0559be43ad336b5b03a7a47443dfaa80d06
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Reviewed-on: http://git-master/r/119298
GVS: Gerrit_Virtual_Submit
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
The platform data of tps80031 have the regualtor_init_data as
non-pointer type. Converting this as pointer type for aligning
to regulator driver policy and easy support for DT.
Change-Id: I07f574953b09e0ed9ec3735d0ee7999ca35bee61
Reviewed-on: http://git-master/r/119974
Reviewed-by: Simone Willett <swillett@nvidia.com>
This reverts commit 70e40e9cf025c73fde46d1a5577547dc37182a64
Change-Id: Iaf390c0d3ea16686f619f321bceea572ee7434fc
Reviewed-on: http://git-master/r/119802
Align the driver with mainline.
This is vbased on commit
3c33be06f9aa0949ad24e67dfcae1f2a3006f4e1
mfd: Add support for TPS65090
TPS65090 is a Texas Instrument PMIC. It contains 3 Step-Down converters, 2
always on LDO's and 7 current limited load switches.
Change-Id: I26545520f2cc72100a927cb60b38693153a4afce
Reviewed-on: http://git-master/r/119320
This reverts commit 5bc340e408aa3f009651735c71f3c97676fbe79f
Change-Id: I70e40e9cf025c73fde46d1a5577547dc37182a64
Reviewed-on: http://git-master/r/119800
Renaming the regulator name from TPS80031_ID_* to
TPS80031_REGULATOR_* for better readability.
Change-Id: I6176cb213d23e44061549fd1e81306756a324523
Align driver with mainline.
This is based on mainline change
452534e50780697a7e1d3cf87cdfdd2b5a0d3c6b
regulator: Add TPS65090 regulator driver
TPS65090 PMIC from TI consists of 3 step down converters,
2 always on LDOs and 7 current limited load switches. The
output voltages are ON/OFF controllable and are meant to
supply power to the components on target board.
Change-Id: I2aeacc948e2aa15aedd73c704787eef8ace9d336
Reviewed-on: http://git-master/r/119321
Modified the mmc_poweroff to resume before sending the poweroff
notification command. In sleep mode only AWAKE and RESET commands are
allowed, so before sending the poweroff notification command resume from
sleep mode and then send the notification command.
PowerOff Notify is tested on a Synopsis Designware Host Controller
(eMMC 4.5). The suspend to RAM and resume works fine.
Change-Id: Ib4642a29e423aee6041a92cc72a388d677674ae3
Signed-off-by: Girish K S <girish.shivananjappa@linaro.org>
Tested-by: Girish K S <girish.shivananjappa@linaro.org>
Reviewed-by: Saugata Das <saugata.das@linaro.org>
Signed-off-by: Chris Ball <cjb@laptop.org>
Bug 1007644
Bug 936069
Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Change-Id: I2e3d421c82eb765cb640876691ffe4818d7e146b
Reviewed-on: http://git-master/r/118918
Reviewed-by: Min-wuk Lee <mlee@nvidia.com>
Reviewed-by: Naveen Kumar Arepalli <naveenk@nvidia.com>
Host may now use MMC_CAP2_NO_SLEEP_CMD to disable the use
of eMMC sleep/awake command.
This option can be used when your platform has a buggy
kernel crash dump software, which is supposed to store
the dump on the eMMC, but is not able to wake up the eMMC
from sleep state.
In particular, failures have been seen with u-boot; even if
it is fixed there, platforms will be slow to update their
bootloader binaries.
Change-Id: I403f4b2a231dde087095a660189dc2f4e79edfd5
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Reviewed-by: Hanumath Prasad <hanumath.prasad@stericsson.com>
Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Acked-by: Subhash Jadavani <subhashj@codeaurora.org>
Bug 1007644
Bug 936069
Change-Id: I8b2834e154e338a97bd6d82f177809d47d318ff0
Reviewed-on: http://git-master/r/118914
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
adding support for using a throughput hint given by the tegra-gfx misc
device in the 3d scaling code. If throughput hint usage is enabled and
the latest throughput hint is recent enough (less than 1 second old),
the throughput hint is used to control 3d frequency scaling. Otherwise
the existing idle time percentage estimate is used.
Bug 991589
Change-Id: I68893e5ce7ef922b95ce5f5b3664eb8e1fdd4027
Signed-off-by: Ilan Aelion <iaelion@nvidia.com>
Reviewed-on: http://git-master/r/116866
Reviewed-by: Lokesh Pathak <lpathak@nvidia.com>
Tested-by: Lokesh Pathak <lpathak@nvidia.com>
Creates a miscdev at /dev/tegra-throughput which gl will use to set a
target frame rate. In addition it receives notifications from dc on
flip events. On each notification the percentage ratio of the actual
frame time to the target frame time is calculated. In subsequent
changes this ratio will be reported to other modules as a throughput
hint.
Bug 991589
Change-Id: Ieaa2b2755b63d2d071de31e3ef819d4c3b51a956
Reviewed-on: http://git-master/r/116865
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
1) Enable bsea/vcp clocks for Audio support by ioctl
2) Send kernel event NVE276_OS_INTERRUPT_APP_NOTIFY
to user space
3) Suspend Resume support
bug 964514
Change-Id: I72fb790baa093b4bcd99a128c886dc049fa0fbb6
Signed-off-by: Vandana Salve <vsalve@nvidia.com>
Reviewed-on: http://git-master/r/108493
cherry picked from commit 4432c5fa5e9072ff019d994f3bc8239bd34ddad1
Reviewed-on: http://git-master/r/114589
Unlike SDSC and SDHC, for SDXC cards CMD20 needs to be
issued to meet the class performance for speed class
recording. Adding mmc_speed_class_control() which should
be used by an AV recording app/utility before starting
recording on an SDXC card.
Bug 969360
Reviewed-on: http://git-master/r/39394
Reviewed-on: http://git-master/r/115685
(cherry picked from commit 04b8d1287a95e1882d956cdf7997015350408a3c)
Change-Id: Id567effb476ee580de3d49b70201ebae5a13360a
Reviewed-on: http://git-master/r/118038
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Added generic busy/free notifiers that the driver can invoke to let the
governor know that it cannot process further core online/offline
requests (invoked in our case whenever we switch to the LP cluster).
Change-Id: I5e3f7f28f38806a7f87050e8d0c8d2f2cf7521aa
Signed-off-by: Sai Charan Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-on: http://git-master/r/114807
This driver supports voltage regulator driver for TI TPS51632
voltage regulator chip. The TPS52632 is 3-2-1 Phase D-Cap+ Step
Down Driverless Controller with Serial VID control and DVFS.
This device has only one voltage output.
bug 978821
Change-Id: I73f3fd696bab5267e76e788fb4b5bf8d9f10b5b5
Reviewed-on: http://git-master/r/117381
Adds the IrDA transceiver handling support to tegra_hsuart driver based on
the platform data.
Bug 999895
Change-Id: Ia475639d97c540d014c7128ef392fa394a5b26ad
Signed-off-by: Ramalingam C <ramalingamc@nvidia.com>
Reviewed-on: http://git-master/r/114927
From a regulator point of view those PMICs differentiate in their SM2 voltage tables. While the older tps658621a and tps658621d as utilised on Harmony resp. Ventana have a range from 3000 to 4550 mV the tps658623 goes from 1700 to 2475 mV and the tps658643 just from 1025 to 1800 mV. Using its VERSIONCRC register the type of PMIC is queried and the right ranges applied.
This fix comes from:
https://gerrit.chromium.org/gerrit/#change,5744
https://gerrit.chromium.org/gerrit/#change,5745
So that it can work with the related wpa_supplicant tool.
BUG=895591
Change-Id: Ie81f6d6052bd45dab13c936f9f0c5f4eb277496a
Original-Signed-off-by: Wei Ni <wni@nvidia.com>
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
Reviewed-on: http://git-master/r/111333
Support for get/set capabilities added. Focuser code has a way to
calibrate itself that results in determination of optimal working
range. This along with actual range from device ROM are returned
to the caller. Focuser has the macro at lower end and infinity at
farther end of the range, which are reversed to the user level to
keep the inf/macro positions to be consistent. Focuser range
translation is taken out.
Bug 1004816
Change-Id: I1a086ff10e99940f9ad861397bf7e71e9996c68a
Signed-off-by: Naren Bhat <nbhat@nvidia.com>
Reviewed-on: http://git-master/r/110443
Reviewed-by: Charlie Huang <chahuang@nvidia.com>
Reviewed-by: Patrick Shehane <pshehane@nvidia.com>
Tested-by: Charlie Huang <chahuang@nvidia.com>
The callback in otg driver is not a standard way of controlling
USB VBUS. Remove the callback and use regulator to control.
Bug 997805
Change-Id: I6d7fd01f9346e037515901ac6fe6d349a140d13e
Signed-off-by: Chander Zhang <chazhang@nvidia.com>
Reviewed-on: http://git-master/r/112896
Reviewed-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Change-Id: I215c5de8e98d139a93113978e1e27adb5a6b252c
Reviewed-on: http://git-master/r/111283
Palmas is a PMIC from Texas Instruments and this is the MFD part of the
driver for this chip. The PMIC has SMPS and LDO regulators, a general
purpose ADC, GPIO, USB OTG mode detection, watchdog and RTC features.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
(cherry picked from commit 2945fbc2fcd83df03165342c1bc3ab83d0fe9c04)
Change-Id: I0bdebbef55d91d2293806355dced43b4c2decad8
Reviewed-on: http://git-master/r/111485
Tested-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
In some chips the IRQ status registers are not contiguous in the register
map but spaced at even spaces. This is an easy case to handle with minor
changes. It is assume for this purpose that the stride for status is
equal to the stride for mask/ack registers as well.
(cherry picked from commit 022f926a2401c80ed36ebb48a1bffbac08f34d98)
Change-Id: I68a59c8fd8a67062dac0eceaefcc85ed597f4a29
Reviewed-on: http://git-master/r/111484
- Gpio freeing function does disabling job.
- If backlight pin is an sfio, we have to claim the gpio. So that we can use
the gpio api's to configure it as sfio.
bug 984440
bug 858120
Change-Id: I583bf4a486d2d9a6d9b78ee459b1962379eafd3b
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/109564
Sometimes the system allow to run in less than requested
minimum voltage and if this tolerance allow the regulator
to set voltage in lower side range than this saves the power.
For the example, if client request vmin = 975mV for regulator
voltage then it sets the voltage to 987.5mv as the nearest to this
desired value. The next lower side for the voltage is 974.8mv.
So if system runs on tolerance of 1mv and if it request for
975mv then driver can look for minimum voltage as 975 - tolerance(1)
= 974mv and possible configure 974.8mv rather than 987.5mV and so
it can save the power equivalent to 12.5mV higher voltage.
Support the configuration of tolerance value.
Change-Id: Ic8312bb397c2615a3ee0f84072ec394e513525ea
Reviewed-on: http://git-master/r/110523
Compute the time-average number of running tasks per run-queue for a
trailing window of a fixed time period. The detla add/sub to the
average value is weighted by the amount of time per nr_running value
relative to the total measurement period.
Change-Id: I076e24ff4ed65bed3b8dd8d2b279a503318071ff
Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com>
(cherry picked from commit 3a12d7499cee352e8a46eaf700259ba3c733f0e3)
Reviewed-on: http://git-master/r/111635
Reviewed-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Tested-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Reviewed-by: Peter Boonstoppel <pboonstoppel@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Force serialization of 2D jobs by inserting a host wait for previous
maximum at the beginning of the job.
Bug 1002293
Change-Id: I667ad4565cc32186ea7ccf16845c68d1b1bbdf78
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/111475
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-by: Daniel Parker <dparker@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-by: Francis Hart <fhart@nvidia.com>
Added driver which estimates temperature based on
a linear formula from other temperature sensors.
bug 1007726
Change-Id: Ic0d3ba7f0d369d4321f55b03e6326ff4efbb512e
Signed-off-by: Joshua Primero <jprimero@nvidia.com>
Reviewed-on: http://git-master/r/105988
Added function that exposes nct1008's internal and external
temperature measurements.
bug 1007726
Change-Id: Iffaca95f5e4267e09a0c3ebb2fbfb909a3bed89d
Reviewed-on: http://git-master/r/101377
- add public APIs for power & sync-point management
- all these APIs end with string _ext
- all these APIs can be found in linux/nvhost.h
- all these APIs take nvhost_device as first argument
- all these APIs are based on the fact that host1x hardware
driver is parent of all the host1x client driver
- this allows clients of host1x which are outside host1x
driver code to just include nvhost.h & use host1x driver
interfaces
- this also hides the implementation details of power &
sync-point inside host1x driver code
- move sync point ids for dc and nvavp to nvhost.h
Bug 961009
Change-Id: I1a9ca074df87656c4d4bd246853e039a7850d56a
Signed-off-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
Reviewed-on: http://git-master/r/109219
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Migrate Colibri USB OTG support.
Restore the AP/modem handshaking functions and clean up the null
phy driver.
Bug 996035
Signed-off-by: Steve Lin <stlin@nvidia.com>
Reviewed-on: http://git-master/r/109044
(cherry picked from commit ff27e8a48a53fe70949d95915f62dd2e03c73df7)
Change-Id: I12a2401a7fcc540a657ab15378d440ef85561001
Reviewed-on: http://git-master/r/110145
Tested-by: Steve Lin <stlin@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
Change-Id: I86e68c57846fe14de7620edf4c241ad7d9e46df2
Signed-off-by: Krishna Reddy <vdumpa@nvidia.com>
Reviewed-on: http://git-master/r/106491
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Satya Popuri <spopuri@nvidia.com>
this commit exposes following power management parameter through
sysfs:
- clockgate_delay: delay after which module is clock gated after
it goes idle. this read/write attribute & unit is ms.
- powergate_delay: delay after which module is power gated after
it is clock gated. this is read/write attribute & unit is ms.
- refcount: current reference count on the module. this is
read-only attribute.
path is: /sys/devices/host1x/<device-name>/acm/ where
<device-name> = name of device node like gr2d or gr3d etc
Bug 845598
Change-Id: I6011eb90ee85b5fc576320272e657ce31f9e264d
Reviewed-on: http://git-master/r/108827
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random
pointer memory access in nl80211_send_station.
Instead of checking if the pointer is null, use sinfo->filled, like
the rest of the fields.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Remove version from nvhost_device name, and use a new field,
version, to distinguish between IP versions. This restores the
sysfs API for 3D clock scaling back to its original path.
Change-Id: I444ef728b7cab9e5ea3a08f3c7be0f1661209686
Reviewed-on: http://git-master/r/108501
Move the device structures to the driver source code files. Register
all nvhost_device's in one loop which is called from board file.
host1x driver code is moved to live under host1x, too. This causes
a need to add host to include path of tegradc and nvavp.
Bug 982965
Change-Id: If99cf9d1ef6bc24663ee8294c19370429ed04ca7
Reviewed-on: http://git-master/r/104076
The range parameters & slew rate from the blocks-camera are being passed
down to ODM and then to kernel. Generic structure added for sharing
the data between ODM and kernel instead of specific structure.
Bug 954874
Change-Id: I84656e36a5a2721c007de78aa5c20f5dfeb00361
Reviewed-on: http://git-master/r/102077
- Adding flag to treat warning as error.
- Handling warnings of unused variable, structures and functions,
wrong return type, wrong type comparision.
Bug 949219
Change-Id: I9d02387ce1073c4e46f69d01669285aa3754f1d9
Reviewed-on: http://git-master/r/104968
Adding CMD56 implementation.
Doing the following for manfid 0x90 and FW revisions 0x73 and
0x7b (both are non-standard custom FW):
1. Adding change to issue BKOPS_START whenever 20 seconds have gone
by without any slow write operations.
2. Adding change to issue CMD56 to refresh (custom feature) 1 block
whenever 60 seconds have gone by without any slow write operations.
Corresponding changes are already there in embedded branches:
http://git-master/r/#change,93247
http://git-master/r/#change,97555
Bug 847037.
Bug 874256.
Bug 963737.
Change-Id: Ie36b52620a75320abfedc36d1408647b36eddb46
Signed-off-by: Vishal Singh <vissingh@nvidia.com>
Reviewed-on: http://git-master/r/102259
Reviewed-by: Luis Dib <ldib@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Changed USB1_UTMIP_XCVR_CFG0_0 register value with values
provided by sys-eng
* Implemented algo as described on Bug 974236
* Added variable 'usb_calib_mask' in 'usb platform data' to
make distinction on how many bits to mask in usb_calib_0 fuse
Bug 978870
Bug 972436
Change-Id: I71f27b0cf5ffe33a9896238b01c52650ca632352
Signed-off-by: Rakesh Bodla <rbodla@nvidia.com>
Reviewed-on: http://git-master/r/103308
Add builtin_host variable to tegra USB platform data structure
bug 947300
Change-Id: I0c5efd245a63c4331959f18faf316f1632e1801e
Reviewed-on: http://git-master/r/106982
Change-Id: Ie391d6d11fad7b76b0bf5daff67ac46663651dc0
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Reviewed-on: http://git-master/r/105265
