path: root/include
2014-12-16move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-04uapi: fix to export linux/vm_sockets.hMasahiro Yamada
A typo "header=y" was introduced by commit 7071cf7fc435 ("uapi: add missing network related headers to kbuild"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-28Merge tag 'staging-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging/IIO driver fixes from Greg KH: "Here are some staging and IIO driver fixes for 3.18-rc7 that resolve a number of reported issues, and a new device id for a staging wireless driver. All of these have been in linux-next" * tag 'staging-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: r8188eu: Add new device ID for DLink GO-USB-N150 staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd iio: accel: bmc150: set low default thresholds iio: accel: bmc150: Fix iio_event_spec direction iio: accel: bmc150: Send x, y and z motion separately iio: accel: bmc150: Error handling when mode set fails iio: gyro: bmg160: Fix iio_event_spec direction iio: gyro: bmg160: Send x, y and z motion separately iio: gyro: bmg160: Don't let interrupt mode to be open drain iio: gyro: bmg160: Error handling when mode set fails iio: adc: men_z188_adc: Add terminating entry for men_z188_ids iio: accel: kxcjk-1013: Fix kxcjk10013_set_range iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit mask
2014-11-28Merge tag 'sound-3.18-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "No excitement, here are only minor fixes: an endian fix for the new DSD format we added in 3.18, a fix for HP mute LED, and a fix for Native Instrument quirk" * tag 'sound-3.18-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: pcm: Add big-endian DSD sample formats and fix XMOS DSD sample format ALSA: hda - One more HP machine needs to change mute led quirk ALSA: usb-audio: Use snd_usb_ctl_msg() for Native Instruments quirk
2014-11-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Several small fixes here: 1) Don't crash in tg3 driver when the number of tx queues has been configured to be different from the number of rx queues. From Thadeu Lima de Souza Cascardo. 2) VLAN filter not disabled properly in promisc mode in ixgbe driver, from Vlad Yasevich. 3) Fix OOPS on dellink op in VTI tunnel driver, from Xin Long. 4) IPV6 GRE driver WCCP code checks skb->protocol for ETH_P_IP instead of ETH_P_IPV6, whoops. From Yuri Chislov. 5) Socket matching in ping driver is buggy when packet AF does not match socket's AF. Fix from Jane Zhou. 6) Fix checksum calculation errors in VXLAN due to where the udp_tunnel6_xmit_skb() helper gets it's saddr/daddr from. From Alexander Duyck. 7) Fix 5G detection problem in rtlwifi driver, from Larry Finger. 8) Fix NULL deref in tcp_v{4,6}_send_reset, from Eric Dumazet. 9) Various missing netlink attribute verifications in bridging code, from Thomas Graf. 10) tcp_recvmsg() unconditionally calls ipv4 ip_recv_error even for ipv6 sockets, whoops. Fix from Willem de Bruijn" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (29 commits) net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socks bridge: Sanitize IFLA_EXT_MASK for AF_BRIDGE:RTM_GETLINK bridge: Add missing policy entry for IFLA_BRPORT_FAST_LEAVE net: Check for presence of IFLA_AF_SPEC net: Validate IFLA_BRIDGE_MODE attribute length bridge: Validate IFLA_BRIDGE_FLAGS attribute length stmmac: platform: fix default values of the filter bins setting net/mlx4_core: Limit count field to 24 bits in qp_alloc_res net: dsa: bcm_sf2: reset switch prior to initialization net: dsa: bcm_sf2: fix unmapping registers in case of errors tg3: fix ring init when there are more TX than RX channels tcp: fix possible NULL dereference in tcp_vX_send_reset() rtlwifi: Change order in device startup rtlwifi: rtl8821ae: Fix 5G detection problem Revert "netfilter: conntrack: fix race in __nf_conntrack_confirm against get_next_corpse" vxlan: Fix boolean flip in VXLAN_F_UDP_ZERO_CSUM6_[TX|RX] ip6_udp_tunnel: Fix checksum calculation net-timestamp: Fix a documentation typo net/ping: handle protocol mismatching scenario af_packet: fix sparse warning ...
2014-11-26net-timestamp: make tcp_recvmsg call ipv6_recv_error for AF_INET6 socksWillem de Bruijn
TCP timestamping introduced MSG_ERRQUEUE handling for TCP sockets. If the socket is of family AF_INET6, call ipv6_recv_error instead of ip_recv_error. This change is more complex than a single branch due to the loadable ipv6 module. It reuses a pre-existing indirect function call from ping. The ping code is safe to call, because it is part of the core ipv6 module and always present when AF_INET6 sockets are active. Fixes: 4ed2d765 (net-timestamp: TCP timestamping) Signed-off-by: Willem de Bruijn <willemb@google.com> ---- It may also be worthwhile to add WARN_ON_ONCE(sk->family == AF_INET6) to ip_recv_error. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-26Merge tag 'iio-fixes-for-3.18c' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/jic23/iio into staging-linus Jonathan writes: Third set of IIO fixes for the 3.18 cycle. Most of these are fairly standard little fixes, a bmc150 and bmg160 patch is to make an ABI change to indicated a specific axis in an event rather than the generic option in the original drivers. As both of these drivers are new in this cycle it would be ideal to push this minor change through even though it isn't strictly a fix. A couple of other 'fixes' change defaults for some settings on these new drivers to more intuitive calues. Looks like some useful feedback has been coming in for this driver since it was applied. * IIO_EVENT_CODE_EXTRACT_DIR bit mask was wrong and has been for a while 0xCF clearly doesn't give a contiguous bitmask. * kxcjk-1013 range setting was failing to mask out the previous value in the register and hence was 'enable only'. * men_z188 device id table wasn't null terminated. * bmg160 and bmc150 both failed to correctly handling an error in mode setting. * bmg160 and bmc150 both had a bug in setting the event direction in the event spec (leads to an attribute name being incorrect) * bmg160 defaulted to an open drain output for the interrupt - as a default this obviously only works with some interrupt chips - hence change the default to push-pull (note this is a new driver so we aren't going to cause any regressions with this change). * bmc150 had an unintuitive default for the rate of change (motion detector) so change it to 0 (new driver so change of default won't cause any regressions).
2014-11-26kvm: fix kvm_is_mmio_pfn() and rename to kvm_is_reserved_pfn()Ard Biesheuvel
This reverts commit 85c8555ff0 ("KVM: check for !is_zero_pfn() in kvm_is_mmio_pfn()") and renames the function to kvm_is_reserved_pfn. The problem being addressed by the patch above was that some ARM code based the memory mapping attributes of a pfn on the return value of kvm_is_mmio_pfn(), whose name indeed suggests that such pfns should be mapped as device memory. However, kvm_is_mmio_pfn() doesn't do quite what it says on the tin, and the existing non-ARM users were already using it in a way which suggests that its name should probably have been 'kvm_is_reserved_pfn' from the beginning, e.g., whether or not to call get_page/put_page on it etc. This means that returning false for the zero page is a mistake and the patch above should be reverted. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-11-25Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Ben Herrenschmidt: "This series fix a nasty issue with radeon adapters on powerpc servers, it's all CC'ed stable and has the relevant maintainers ack's/reviews. Basically, some (radeon) adapters have issues with MSI addresses above 1T (only support 40-bits). We had powerpc specific quirk but it only listed a specific revision of an adapter that we shipped with our machines and didn't properly handle the audio function which some distros enable nowadays. So we made the quirk generic and fixed both the graphic and audio drivers properly to use it. Without that, ppc64 server machines will crash at boot with a radeon adapter. Note: This has been brewing for a while, it just needed a last respin which got delayed due to us moving ozlabs to a new location in town and other such things taking priority" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/pci: Remove unused force_32bit_msi quirk powerpc/pseries: Honor the generic "no_64bit_msi" flag powerpc/powernv: Honor the generic "no_64bit_msi" flag sound/radeon: Move 64-bit MSI quirk from arch to driver gpu/radeon: Set flag to indicate broken 64-bit MSI PCI/MSI: Add device flag indicating that 64-bit MSIs don't work ALSA: hda - Limit 40bit DMA for AMD HDMI controllers
2014-11-25Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
https://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "The fixes for the clock framework are all regressions in drivers, plus a single fix in one of the basic clock templates. No fixes to the core this time around. As with most clock driver fixes these run the gamut from fixing a build warning to fixing wrecked memory timings, with a little USB tossed in for fun" * tag 'clk-fixes-for-linus' of https://git.linaro.org/people/mike.turquette/linux: clk: pxa: fix pxa27x CCCR bit usage clk-divider: Fix READ_ONLY when divider > 1 clk: qcom: Fix duplicate rbcpr clock name clk: at91: usb: fix at91sam9x5 recalc, round and set rate clk: at91: usb: fix at91rm9200 round and set rate
2014-11-24PCI/MSI: Add device flag indicating that 64-bit MSIs don't workBenjamin Herrenschmidt
This can be set by quirks/drivers to be used by the architecture code that assigns the MSI addresses. We additionally add verification in the core MSI code that the values assigned by the architecture do satisfy the limitation in order to fail gracefully if they don't (ie. the arch hasn't been updated to deal with that quirk yet). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: <stable@vger.kernel.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2014-11-23Merge branch 'for-3.18-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu fix from Tejun Heo: "This contains one patch to fix a race condition which can lead to percpu_ref using a percpu pointer which is corrupted with a set DEAD bit. The bug was introduced while separating out the ATOMIC mode flag from the DEAD flag. The fix is pretty straight forward. I just committed the patch to the percpu tree but am sending out the pull request early as I'll be on vacation for a week. The patch should be fairly safe and while the latency will be higher I'll be checking emails" * 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu-ref: fix DEAD flag contamination of percpu pointer
2014-11-23percpu-ref: fix DEAD flag contamination of percpu pointerTejun Heo
While decoupling ATOMIC and DEAD flags, f47ad4578461 ("percpu_ref: decouple switching to percpu mode and reinit") updated __ref_is_percpu() so that it only tests ATOMIC flag to determine whether the ref is in percpu mode or not; however, while DEAD implies ATOMIC, the two flags are set separately during percpu_ref_kill() and if __ref_is_percpu() races percpu_ref_kill(), it may see DEAD w/o ATOMIC. Because __ref_is_percpu() returns @ref->percpu_count_ptr value verbatim as the percpu pointer after testing ATOMIC, the pointer may now be contaminated with the DEAD flag. This can be fixed by clearing the flag bits before returning the pointer which was the fix proposed by Shaohua; however, as DEAD implies ATOMIC, we can just test for both flags at once and avoid the explicit masking. Update __ref_is_percpu() so that it tests that both ATOMIC and DEAD are clear before returning @ref->percpu_count_ptr as the percpu pointer. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-Reviewed-by: Shaohua Li <shli@kernel.org> Link: http://lkml.kernel.org/r/995deb699f5b873c45d667df4add3b06f73c2c25.1416638887.git.shli@kernel.org Fixes: f47ad4578461 ("percpu_ref: decouple switching to percpu mode and reinit")
2014-11-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix BUG when decrypting empty packets in mac80211, from Ronald Wahl. 2) nf_nat_range is not fully initialized and this is copied back to userspace, from Daniel Borkmann. 3) Fix read past end of b uffer in netfilter ipset, also from Dan Carpenter. 4) Signed integer overflow in ipv4 address mask creation helper inet_make_mask(), from Vincent BENAYOUN. 5) VXLAN, be2net, mlx4_en, and qlcnic need ->ndo_gso_check() methods to properly describe the device's capabilities, from Joe Stringer. 6) Fix memory leaks and checksum miscalculations in openvswitch, from Pravin B SHelar and Jesse Gross. 7) FIB rules passes back ambiguous error code for unreachable routes, making behavior confusing for userspace. Fix from Panu Matilainen. 8) ieee802154fake_probe() doesn't release resources properly on error, from Alexey Khoroshilov. 9) Fix skb_over_panic in add_grhead(), from Daniel Borkmann. 10) Fix access of stale slave pointers in bonding code, from Nikolay Aleksandrov. 11) Fix stack info leak in PPP pptp code, from Mathias Krause. 12) Cure locking bug in IPX stack, from Jiri Bohac. 13) Revert SKB fclone memory freeing optimization that is racey and can allow accesses to freed up memory, from Eric Dumazet. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (71 commits) tcp: Restore RFC5961-compliant behavior for SYN packets net: Revert "net: avoid one atomic operation in skb_clone()" virtio-net: validate features during probe cxgb4 : Fix DCB priority groups being returned in wrong order ipx: fix locking regression in ipx_sendmsg and ipx_recvmsg openvswitch: Don't validate IPv6 label masks. pptp: fix stack info leak in pptp_getname() brcmfmac: don't include linux/unaligned/access_ok.h cxgb4i : Don't block unload/cxgb4 unload when remote closes TCP connection ipv6: delete protocol and unregister rtnetlink when cleanup net/mlx4_en: Add VXLAN ndo calls to the PF net device ops too bonding: fix curr_active_slave/carrier with loadbalance arp monitoring mac80211: minstrel_ht: fix a crash in rate sorting vxlan: Inline vxlan_gso_check(). can: m_can: update to support CAN FD features can: m_can: fix incorrect error messages can: m_can: add missing delay after setting CCCR_INIT bit can: m_can: fix not set can_dlc for remote frame can: m_can: fix possible sleep in napi poll can: m_can: add missing message RAM initialization ...
2014-11-21Merge tag 'sound-3.18-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "This batch ended up as a relatively high volume due to pending ASoC fixes. But most of fixes there are trivial and/or device- specific fixes and quirks, so safe to apply. The only (ASoC) core fixes are the DPCM race fix and the machine-driver matching fix for componentization" * tag 'sound-3.18-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda - fix the mic mute led problem for Latitude E5550 ALSA: hda - move DELL_WMI_MIC_MUTE_LED to the tail in the quirk chain ASoC: wm_adsp: Avoid attempt to free buffers that might still be in use ALSA: usb-audio: Set the Control Selector to SU_SELECTOR_CONTROL for UAC2 ALSA: usb-audio: Add ctrl message delay quirk for Marantz/Denon devices ASoC: sgtl5000: Fix SMALL_POP bit definition ASoC: cs42l51: re-hook of_match_table pointer ASoC: rt5670: change dapm routes of PLL connection ASoC: rt5670: correct the incorrect default values ASoC: samsung: Add MODULE_DEVICE_TABLE for Snow ASoC: max98090: Correct pclk divisor settings ASoC: dpcm: Fix race between FE/BE updates and trigger ASoC: Fix snd_soc_find_dai() matching component by name ASoC: rsnd: remove unsupported PAUSE flag ASoC: fsi: remove unsupported PAUSE flag ASoC: rt5645: Mark RT5645_TDM_CTRL_3 as readable ASoC: rockchip-i2s: fix infinite loop in rockchip_snd_rxctrl ASoC: es8328-i2c: Fix i2c_device_id name field in es8328_id ASoC: fsl_asrc: Add reg_defaults for regmap to fix kernel dump
2014-11-21Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes: two NUMA fixes, two cputime fixes and an RCU/lockdep fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Fix clock_nanosleep()/clock_gettime() inconsistency sched/cputime: Fix cpu_timer_sample_group() double accounting sched/numa: Avoid selecting oneself as swap target sched/numa: Fix out of bounds read in sched_init_numa() sched: Remove lockdep check in sched_move_task()
2014-11-21Merge branch 'core-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core fix from Ingo Molnar: "Fix GENMASK macro shift overflow" Nobody seems to currently use GENMASK() to fill every single last bit (which is what overflows) in-tree, and gcc would warn about it, so we have that going for us. But apparently there are pending changes that want this. * 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: bitops: Fix shift overflow in GENMASK macros
2014-11-21ALSA: pcm: Add big-endian DSD sample formats and fix XMOS DSD sample formatJussi Laako
This patch fixes XMOS DSD sample format to DSD_U32_BE and also adds DSD_U16_BE and DSD_U32_BE sample formats. Signed-off-by: Jussi Laako <jussi@sonarnerd.net> Acked-by: Jurgen Kramer <gtmkramer@xs4all.nl> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-11-19Merge tag 'linux-can-fixes-for-3.18-20141118' of ↵David S. Miller
git://gitorious.org/linux-can/linux-can Marc Kleine-Budde says: ==================== pull-request: can 2014-11-18 this is a pull request of 17 patches for net/master for the v3.18 release cycle. The last patch of this pull request ("can: m_can: update to support CAN FD features") adds, as the description says, a new feature to the m_can driver. As the m_can driver has been added in v3.18 there is no risk of causing a regression. Give me a note if this is not okay and I'll create a new pull request without it. There is a patch for the CAN infrastructure by Thomas Körper which fixes calling kfree_skb() from interrupt context. Roman Fietze fixes a typo also in the infrastructure. A patch by Dong Aisheng adds a generic helper function to tell if a skb is normal CAN or CAN-FD frame. Alexey Khoroshilov of the Linux Driver Verification project fixes a memory leak in the esd_usb2 driver. Two patches by Sudip Mukherjee remove unused variables and fixe the signess of a variable. Three patches by me add the missing .ndo_change_mtu callback to the xilinx_can, rcar_can and gs_usb driver. The remaining patches improve the m_can driver: David Cohen adds the missing CONFIG_HAS_IOMEM dependency. Dong Aisheng provides 6 bugfix patches (most important: missing RAM init, sleep in NAPI poll, dlc in RTR). While the last of his patches adds CAN FD support to the driver. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18vxlan: Inline vxlan_gso_check().Joe Stringer
Suggested-by: Or Gerlitz <ogerlitz@mellanox.com> Signed-off-by: Joe Stringer <joestringer@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-18can: dev: add can_is_canfd_skb() APIDong Aisheng
The CAN device drivers can use can_is_canfd_skb() to check if the frame to send is on CAN FD mode or normal CAN mode. Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Dong Aisheng <b29396@freescale.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-11-17clk-divider: Fix READ_ONLY when divider > 1James Hogan
Commit 79c6ab509558 (clk: divider: add CLK_DIVIDER_READ_ONLY flag) in v3.16 introduced the CLK_DIVIDER_READ_ONLY flag which caused the recalc_rate() and round_rate() clock callbacks to be omitted. However using this flag has the unfortunate side effect of causing the clock recalculation code when a clock rate change is attempted to always treat it as a pass-through clock, i.e. with a fixed divide of 1, which may not be the case. Child clock rates are then recalculated using the wrong parent rate. Therefore instead of dropping the recalc_rate() and round_rate() callbacks, alter clk_divider_bestdiv() to always report the current divider as the best divider so that it is never altered. For me the read only clock was the system clock, which divided the PLL rate by 2, from which both the UART and the SPI clocks were divided. Initial setting of the UART rate set it correctly, but when the SPI clock was set, the other child clocks were miscalculated. The UART clock was recalculated using the PLL rate as the parent rate, resulting in a UART new_rate of double what it should be, and a UART which spewed forth garbage when the rate changes were propagated. Signed-off-by: James Hogan <james.hogan@imgtec.com> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Tomasz Figa <t.figa@samsung.com> Cc: Max Schwarz <max.schwarz@online.de> Cc: <stable@vger.kernel.org> # v3.16+ Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17clk: qcom: Fix duplicate rbcpr clock nameGeorgi Djakov
There is a duplication in a clock name for apq8084 platform that causes the following warning: "RBCPR_CLK_SRC" redefined Resolve this by adding a MMSS_ prefix to this clock and making its name coherent with msm8974 platform. Fixes: 2b46cd23a5a2 ("clk: qcom: Add APQ8084 Multimedia Clock Controller (MMCC) support") Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-17Merge remote-tracking branches 'asoc/fix/adsp', 'asoc/fix/cs41l51', ↵Mark Brown
'asoc/fix/dpcm', 'asoc/fix/es8328', 'asoc/fix/fsl-asrc', 'asoc/fix/max98090', 'asoc/fix/rcar', 'asoc/fix/rockchip' and 'asoc/fix/rt5645' into asoc-linus
2014-11-16Merge tag 'armsoc-for-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another small set of fixes: - some DT compatible typo fixes - irq setup fix dealing with irq storms on orion - i2c quirk generalization for mvebu - a handful of smaller fixes for OMAP - a couple of added file patterns for OMAP entries in MAINTAINERS" * tag 'armsoc-for-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: at91/dt: Fix sama5d3x typos pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name ARM: orion: Fix for certain sequence of request_irq can cause irq storm ARM: mvebu: armada xp: Generalize use of i2c quirk
2014-11-16Merge tag 'omap-fixes-against-v3.18-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v3.18-rc4" from Tony Lindgren: Few omap fixes for hangs and wrong pinctrl defines, and update MAINTAINERS file to avoid missing PMIC and SoC related patches: - Fix random hangs on am437x because of incorrect default value for the DDR regulator - Fix wrong partition name for NAND on am335x-evm - Fix wrong pinctrl defines for dra7xx - Update maintainers entries for PMICs and SoCs * tag 'omap-fixes-against-v3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/pablo/nfDavid S. Miller
Pablo Neira Ayuso says: ==================== Netfilter/IPVS fixes for net The following patchset contains Netfilter updates for your net tree, they are: 1) Fix missing initialization of the range structure (allocated in the stack) in nft_masq_{ipv4, ipv6}_eval, from Daniel Borkmann. 2) Make sure the data we receive from userspace contains the req_version structure, otherwise return an error incomplete on truncated input. From Dan Carpenter. 3) Fix handling og skb->sk which may cause incorrect handling of connections from a local process. Via Simon Horman, patch from Calvin Owens. 4) Fix wrong netns in nft_compat when setting target and match params structure. 5) Relax chain type validation in nft_compat that was recently included, this broke the matches that need to be run from the route chain type. Now iptables-test.py automated regression tests report success again and we avoid the only possible problematic case, which is the use of nat targets out of nat chain type. 6) Use match->table to validate the tablename, instead of the match->name. Again patch for nft_compat. 7) Restore the synchronous release of objects from the commit and abort path in nf_tables. This is causing two major problems: splats when using nft_compat, given that matches and targets may sleep and call_rcu is invoked from softirq context. Moreover Patrick reported possible event notification reordering when rules refer to anonymous sets. 8) Fix race condition in between packets that are being confirmed by conntrack and the ctnetlink flush operation. This happens since the removal of the central spinlock. Thanks to Jesper D. Brouer to looking into this. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-16sched/cputime: Fix cpu_timer_sample_group() double accountingPeter Zijlstra
While looking over the cpu-timer code I found that we appear to add the delta for the calling task twice, through: cpu_timer_sample_group() thread_group_cputimer() thread_group_cputime() times->sum_exec_runtime += task_sched_runtime(); *sample = cputime.sum_exec_runtime + task_delta_exec(); Which would make the sample run ahead, making the sleep short. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Stanislaw Gruszka <sgruszka@redhat.com> Cc: Christoph Lameter <cl@linux.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rik van Riel <riel@redhat.com> Cc: Tejun Heo <tj@kernel.org> Link: http://lkml.kernel.org/r/20141112113737.GI10476@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-16bitops: Fix shift overflow in GENMASK macrosMaxime COQUELIN
On some 32 bits architectures, including x86, GENMASK(31, 0) returns 0 instead of the expected ~0UL. This is the same on some 64 bits architectures with GENMASK_ULL(63, 0). This is due to an overflow in the shift operand, 1 << 32 for GENMASK, 1 << 64 for GENMASK_ULL. Reported-by: Eric Paire <eric.paire@st.com> Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: <stable@vger.kernel.org> # v3.13+ Cc: linux@rasmusvillemoes.dk Cc: gong.chen@linux.intel.com Cc: John Sullivan <jsrhbz@kanargh.force9.co.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Theodore Ts'o <tytso@mit.edu> Fixes: 10ef6b0dffe4 ("bitops: Introduce a more generic BITMASK macro") Link: http://lkml.kernel.org/r/1415267659-10563-1-git-send-email-maxime.coquelin@st.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-15Merge tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull power supply updates from Sebastian Reichel: "Power supply and reset changes for the v3.18-rc: - misc. charger-manager fixes - year 2038 fix in ab8500_fg - fix error handling of bq2415x_charger" * tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6: power: charger-manager: Fix accessing invalidated power supply after charger unbind power: charger-manager: Fix accessing invalidated power supply after fuel gauge unbind power: charger-manager: Avoid recursive thermal get_temp call power_supply: Add no_thermal property to prevent recursive get_temp calls power: bq2415x_charger: Fix memory leak on DTS parsing error power: bq2415x_charger: Properly handle ENODEV from power_supply_get_by_phandle power: ab8500_fg.c: use 64-bit time types
2014-11-15Merge tag 'nfs-for-3.18-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client bugfixes from Trond Myklebust: "Highlights include: - stable patches to fix NFSv4.x delegation reclaim error paths - fix a bug whereby we were advertising NFSv4.1 but using NFSv4.2 features - fix a use-after-free problem with pNFS block layouts - fix a memory leak in the pNFS files O_DIRECT code - replace an intrusive and Oops-prone performance fix in the NFSv4 atomic open code with a safer one-line version and revert the two original patches" * tag 'nfs-for-3.18-3' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: sunrpc: fix sleeping under rcu_read_lock in gss_stringify_acceptor NFS: Don't try to reclaim delegation open state if recovery failed NFSv4: Ensure that we call FREE_STATEID when NFSv4.x stateids are revoked NFSv4: Fix races between nfs_remove_bad_delegation() and delegation return NFSv4.1: nfs41_clear_delegation_stateid shouldn't trust NFS_DELEGATED_STATE NFSv4: Ensure that we remove NFSv4.0 delegations when state has expired NFS: SEEK is an NFS v4.2 feature nfs: Fix use of uninitialized variable in nfs_getattr() nfs: Remove bogus assignment nfs: remove spurious WARN_ON_ONCE in write path pnfs/blocklayout: serialize GETDEVICEINFO calls nfs: fix pnfs direct write memory leak Revert "NFS: nfs4_do_open should add negative results to the dcache." Revert "NFS: remove BUG possibility in nfs4_open_and_get_state" NFSv4: Ensure nfs_atomic_open set the dentry verifier on ENOENT
2014-11-15iio: Fix IIO_EVENT_CODE_EXTRACT_DIR bit maskCristina Ciocan
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask in order to retrieve it, that is 0x7F, not 0xCF as it is now. Fixes: ade7ef7ba (staging:iio: Differential channel handling) Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com> Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2014-11-14net: Add vxlan_gso_check() helperJoe Stringer
Most NICs that report NETIF_F_GSO_UDP_TUNNEL support VXLAN, and not other UDP-based encapsulation protocols where the format and size of the header differs. This patch implements a generic ndo_gso_check() for VXLAN which will only advertise GSO support when the skb looks like it contains VXLAN (or no UDP tunnelling at all). Implementation shamelessly stolen from Tom Herbert: http://thread.gmane.org/gmane.linux.network/332428/focus=333111 Signed-off-by: Joe Stringer <joestringer@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-14inetdevice: fixed signed integer overflowVincent BENAYOUN
There could be a signed overflow in the following code. The expression, (32-logmask) is comprised between 0 and 31 included. It may be equal to 31. In such a case the left shift will produce a signed integer overflow. According to the C99 Standard, this is an undefined behavior. A simple fix is to replace the signed int 1 with the unsigned int 1U. Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-14Merge tag 'pm+acpi-3.18-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: "These are three regression fixes, two recent (generic power domains, suspend-to-idle) and one older (cpufreq), an ACPI blacklist entry for one more machine having problems with Windows 8 compatibility, a minor cpufreq driver fix (cpufreq-dt) and a fixup for new callback definitions (generic power domains). Specifics: - Fix a crash in the suspend-to-idle code path introduced by a recent commit that forgot to check a pointer against NULL before dereferencing it (Dmitry Eremin-Solenikov). - Fix a boot crash on Exynos5 introduced by a recent commit making that platform use generic Device Tree bindings for power domains which exposed a weakness in the generic power domains framework leading to that crash (Ulf Hansson). - Fix a crash during system resume on systems where cpufreq depends on Operation Performance Points (OPP) for functionality, but CONFIG_OPP is not set. This leads the cpufreq driver registration to fail, but the resume code attempts to restore the pre-suspend cpufreq configuration (which does not exist) nevertheless and crashes. From Geert Uytterhoeven. - Add a new ACPI blacklist entry for Dell Vostro 3546 that has problems if it is reported as Windows 8 compatible to the BIOS (Adam Lee). - Fix swapped arguments in an error message in the cpufreq-dt driver (Abhilash Kesavan). - Fix up the prototypes of new callbacks in struct generic_pm_domain to make them more useful. Users of those callbacks will be added in 3.19 and it's better for them to be based on the correct struct definition in mainline from the start. From Ulf Hansson and Kevin Hilman" * tag 'pm+acpi-3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PM / Domains: Fix initial default state of the need_restore flag PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set PM / Domains: Change prototype for the attach and detach callbacks cpufreq: Avoid crash in resume on SMP without OPP cpufreq: cpufreq-dt: Fix arguments in clock failure error message ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
2014-11-14Merge branches 'pm-domains', 'pm-sleep' and 'pm-cpufreq'Rafael J. Wysocki
* pm-domains: PM / Domains: Fix initial default state of the need_restore flag PM / Domains: Change prototype for the attach and detach callbacks * pm-sleep: PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set * pm-cpufreq: cpufreq: Avoid crash in resume on SMP without OPP cpufreq: cpufreq-dt: Fix arguments in clock failure error message
2014-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) sunhme driver lacks DMA mapping error checks, based upon a report by Meelis Roos. 2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee. 3) DMA memory allocation sizes are wrong in systemport ethernet driver, fix from Florian Fainelli. 4) Fix use after free in mac80211 defragmentation code, from Johannes Berg. 5) Some networking uapi headers missing from Kbuild file, from Stephen Hemminger. 6) TUN driver gets csum_start offset wrong when VLAN accel is enabled, and macvtap has a similar bug, from Herbert Xu. 7) Adjust several tunneling drivers to set dev->iflink after registry, because registry sets that to -1 overwriting whatever we did. From Steffen Klassert. 8) Geneve forgets to set inner tunneling type, causing GSO segmentation to fail on some NICs. From Jesse Gross. 9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and Giuseppe CAVALLARO. 10) Fix spurious timeouts with NewReno on low traffic connections, from Marcelo Leitner. 11) Fix descriptor updates in enic driver, from Govindarajulu Varadarajan. 12) PPP calls bpf_prog_create() with locks held, which isn't kosher. Fix from Takashi Iwai. 13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel Borkmann. 14) psock_fanout selftest accesses past the end of the mmap ring, fix from Shuah Khan. 15) Fix PTP timestamping for VLAN packets, from Richard Cochran. 16) netlink_unbind() calls in netlink pass wrong initial argument, from Hiroaki SHIMODA. 17) vxlan socket reuse accidently reuses a socket when the address family is different, so we have to explicitly check this, from Marcelo Lietner. 18) Fix missing include in nft_reject_bridge.c breaking the build on ppc and other architectures, from Guenter Roeck. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits) vxlan: Do not reuse sockets for a different address family smsc911x: power-up phydev before doing a software reset. lib: rhashtable - Remove weird non-ASCII characters from comments net/smsc911x: Fix delays in the PHY enable/disable routines net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode netlink: Properly unbind in error conditions. net: ptp: fix time stamp matching logic for VLAN packets. cxgb4 : dcb open-lldp interop fixes selftests/net: psock_fanout seg faults in sock_fanout_read_ring() net: bcmgenet: apply MII configuration in bcmgenet_open() net: bcmgenet: connect and disconnect from the PHY state machine net: qualcomm: Fix dependency ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx net: phy: Correctly handle MII ioctl which changes autonegotiation. ipv6: fix IPV6_PKTINFO with v4 mapped net: sctp: fix memory leak in auth key management net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet net: ppp: Don't call bpf_prog_create() in ppp_lock net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set cxgb4 : Fix bug in DCB app deletion ...
2014-11-13mem-hotplug: reset node managed pages when hot-adding a new pgdatTang Chen
In free_area_init_core(), zone->managed_pages is set to an approximate value for lowmem, and will be adjusted when the bootmem allocator frees pages into the buddy system. But free_area_init_core() is also called by hotadd_new_pgdat() when hot-adding memory. As a result, zone->managed_pages of the newly added node's pgdat is set to an approximate value in the very beginning. Even if the memory on that node has node been onlined, /sys/device/system/node/nodeXXX/meminfo has wrong value: hot-add node2 (memory not onlined) cat /sys/device/system/node/node2/meminfo Node 2 MemTotal: 33554432 kB Node 2 MemFree: 0 kB Node 2 MemUsed: 33554432 kB Node 2 Active: 0 kB This patch fixes this problem by reset node managed pages to 0 after hot-adding a new node. 1. Move reset_managed_pages_done from reset_node_managed_pages() to reset_all_zones_managed_pages() 2. Make reset_node_managed_pages() non-static 3. Call reset_node_managed_pages() in hotadd_new_pgdat() after pgdat is initialized Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com> Signed-off-by: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: <stable@vger.kernel.org> [3.16+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-13mm/page_alloc: fix incorrect isolation behavior by rechecking migratetypeJoonsoo Kim
Before describing bugs itself, I first explain definition of freepage. 1. pages on buddy list are counted as freepage. 2. pages on isolate migratetype buddy list are *not* counted as freepage. 3. pages on cma buddy list are counted as CMA freepage, too. Now, I describe problems and related patch. Patch 1: There is race conditions on getting pageblock migratetype that it results in misplacement of freepages on buddy list, incorrect freepage count and un-availability of freepage. Patch 2: Freepages on pcp list could have stale cached information to determine migratetype of buddy list to go. This causes misplacement of freepages on buddy list and incorrect freepage count. Patch 4: Merging between freepages on different migratetype of pageblocks will cause freepages accouting problem. This patch fixes it. Without patchset [3], above problem doesn't happens on my CMA allocation test, because CMA reserved pages aren't used at all. So there is no chance for above race. With patchset [3], I did simple CMA allocation test and get below result: - Virtual machine, 4 cpus, 1024 MB memory, 256 MB CMA reservation - run kernel build (make -j16) on background - 30 times CMA allocation(8MB * 30 = 240MB) attempts in 5 sec interval - Result: more than 5000 freepage count are missed With patchset [3] and this patchset, I found that no freepage count are missed so that I conclude that problems are solved. On my simple memory offlining test, these problems also occur on that environment, too. This patch (of 4): There are two paths to reach core free function of buddy allocator, __free_one_page(), one is free_one_page()->__free_one_page() and the other is free_hot_cold_page()->free_pcppages_bulk()->__free_one_page(). Each paths has race condition causing serious problems. At first, this patch is focused on first type of freepath. And then, following patch will solve the problem in second type of freepath. In the first type of freepath, we got migratetype of freeing page without holding the zone lock, so it could be racy. There are two cases of this race. 1. pages are added to isolate buddy list after restoring orignal migratetype CPU1 CPU2 get migratetype => return MIGRATE_ISOLATE call free_one_page() with MIGRATE_ISOLATE grab the zone lock unisolate pageblock release the zone lock grab the zone lock call __free_one_page() with MIGRATE_ISOLATE freepage go into isolate buddy list, although pageblock is already unisolated This may cause two problems. One is that we can't use this page anymore until next isolation attempt of this pageblock, because freepage is on isolate buddy list. The other is that freepage accouting could be wrong due to merging between different buddy list. Freepages on isolate buddy list aren't counted as freepage, but ones on normal buddy list are counted as freepage. If merge happens, buddy freepage on normal buddy list is inevitably moved to isolate buddy list without any consideration of freepage accouting so it could be incorrect. 2. pages are added to normal buddy list while pageblock is isolated. It is similar with above case. This also may cause two problems. One is that we can't keep these freepages from being allocated. Although this pageblock is isolated, freepage would be added to normal buddy list so that it could be allocated without any restriction. And the other problem is same as case 1, that it, incorrect freepage accouting. This race condition would be prevented by checking migratetype again with holding the zone lock. Because it is somewhat heavy operation and it isn't needed in common case, we want to avoid rechecking as much as possible. So this patch introduce new variable, nr_isolate_pageblock in struct zone to check if there is isolated pageblock. With this, we can avoid to re-check migratetype in common case and do it only if there is isolated pageblock or migratetype is MIGRATE_ISOLATE. This solve above mentioned problems. Changes from v3: Add one more check in free_one_page() that checks whether migratetype is MIGRATE_ISOLATE or not. Without this, abovementioned case 1 could happens. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Minchan Kim <minchan@kernel.org> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Vlastimil Babka <vbabka@suse.cz> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Cc: Mel Gorman <mgorman@suse.de> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Heesub Shin <heesub.shin@samsung.com> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com> Cc: Ritesh Harjani <ritesh.list@gmail.com> Cc: Gioh Kim <gioh.kim@lge.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-12Merge tag 'trace-fixes-v3.18-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing fix from Steven Rostedt: "Rabin Vincent found a way that tracing could cause an infinite loop in the kernel. The splice logic wants a full page from the ring buffer but the ring_buffer_wait() returns when there's any data in the ring buffer. The splice code would then continue the loop waiting for a full page. But if a full page never happens, the splice code will never sleep and just continue to loop. There's another case that Rabin fixed that could loop if there's no memory and kmalloc() constantly returns NULL" * tag 'trace-fixes-v3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Do not risk busy looping in buffer splice tracing: Do not busy wait in buffer splice
2014-11-12Merge tag 'mfd-fixes-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD fixes from Lee Jones: - register offset fix for stmpe - eradicate build warning when !PM in rtsx_pcr - fix device ID collision when multiple boards are connected in viperboard - use correct Regmap handle - fixing unhanded IRQs in max77693 - unmask MUIC IRQs in max77693 - clear VBUS & CHG bits so board doesn't reboot instead of poweroff in twl4030 * tag 'mfd-fixes-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: mfd: twl4030-power: Fix poweroff with PM configuration enabled mfd: max77693: Fix always masked MUIC interrupts mfd: max77693: Use proper regmap for handling MUIC interrupts mfd: viperboard: Fix platform-device id collision mfd: rtsx: Fix build warnings for !PM mfd: stmpe: Fix STMPE24xx GPMR LSB
2014-11-12nfs: fix pnfs direct write memory leakPeng Tao
For pNFS direct writes, layout driver may dynamically allocate ds_cinfo.buckets. So we need to take care to free them when freeing dreq. Ideally this needs to be done inside layout driver where ds_cinfo.buckets are allocated. But buckets are attached to dreq and reused across LD IO iterations. So I feel it's OK to free them in the generic layer. Cc: stable@vger.kernel.org [v3.4+] Signed-off-by: Peng Tao <tao.peng@primarydata.com> Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
2014-11-12netfilter: nf_tables: restore synchronous object release from commit/abortPablo Neira Ayuso
The existing xtables matches and targets, when used from nft_compat, may sleep from the destroy path, ie. when removing rules. Since the objects are released via call_rcu from softirq context, this results in lockdep splats and possible lockups that may be hard to reproduce. Patrick also indicated that delayed object release via call_rcu can cause us problems in the ordering of event notifications when anonymous sets are in place. So, this patch restores the synchronous object release from the commit and abort paths. This includes a call to synchronize_rcu() to make sure that no packets are walking on the objects that are going to be released. This is slowier though, but it's simple and it resolves the aforementioned problems. This is a partial revert of c7c32e7 ("netfilter: nf_tables: defer all object release via rcu") that was introduced in 3.16 to speed up interaction with userspace. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2014-11-11PM / Domains: Fix initial default state of the need_restore flagUlf Hansson
The initial state of the device's need_restore flag should'nt depend on the current state of the PM domain. For example it should be perfectly valid to attach an inactive device to a powered PM domain. The pm_genpd_dev_need_restore() API allow us to update the need_restore flag to somewhat cope with such scenarios. Typically that should have been done from drivers/buses ->probe() since it's those that put the requirements on the value of the need_restore flag. Until recently, the Exynos SOCs were the only user of the pm_genpd_dev_need_restore() API, though invoking it from a centralized location while adding devices to their PM domains. Due to that Exynos now have swithed to the generic OF-based PM domain look-up, it's no longer possible to invoke the API from a centralized location. The reason is because devices are now added to their PM domains during the probe sequence. Commit "ARM: exynos: Move to generic PM domain DT bindings" did the switch for Exynos to the generic OF-based PM domain look-up, but it also removed the call to pm_genpd_dev_need_restore(). This caused a regression for some of the Exynos drivers. To handle things more properly in the generic PM domain, let's change the default initial value of the need_restore flag to reflect that the state is unknown. As soon as some of the runtime PM callbacks gets invoked, update the initial value accordingly. Moreover, since the generic PM domain is verifying that all devices are both runtime PM enabled and suspended, using pm_runtime_suspended() while pm_genpd_poweroff() is invoked from the scheduled work, we can be sure of that the PM domain won't be powering off while having active devices. Do note that, the generic PM domain can still only know about active devices which has been activated through invoking its runtime PM resume callback. In other words, buses/drivers using pm_runtime_set_active() during ->probe() will still suffer from a race condition, potentially probing a device without having its PM domain being powered. That issue will have to be solved using a different approach. This a log from the boot regression for Exynos5, which is being fixed in this patch. ------------[ cut here ]------------ WARNING: CPU: 0 PID: 308 at ../drivers/clk/clk.c:851 clk_disable+0x24/0x30() Modules linked in: CPU: 0 PID: 308 Comm: kworker/0:1 Not tainted 3.18.0-rc3-00569-gbd9449f-dirty #10 Workqueue: pm pm_runtime_work [<c0013c64>] (unwind_backtrace) from [<c0010dec>] (show_stack+0x10/0x14) [<c0010dec>] (show_stack) from [<c03ee4cc>] (dump_stack+0x70/0xbc) [<c03ee4cc>] (dump_stack) from [<c0020d34>] (warn_slowpath_common+0x64/0x88) [<c0020d34>] (warn_slowpath_common) from [<c0020d74>] (warn_slowpath_null+0x1c/0x24) [<c0020d74>] (warn_slowpath_null) from [<c03107b0>] (clk_disable+0x24/0x30) [<c03107b0>] (clk_disable) from [<c02cc834>] (gsc_runtime_suspend+0x128/0x160) [<c02cc834>] (gsc_runtime_suspend) from [<c0249024>] (pm_generic_runtime_suspend+0x2c/0x38) [<c0249024>] (pm_generic_runtime_suspend) from [<c024f44c>] (pm_genpd_default_save_state+0x2c/0x8c) [<c024f44c>] (pm_genpd_default_save_state) from [<c024ff2c>] (pm_genpd_poweroff+0x224/0x3ec) [<c024ff2c>] (pm_genpd_poweroff) from [<c02501b4>] (pm_genpd_runtime_suspend+0x9c/0xcc) [<c02501b4>] (pm_genpd_runtime_suspend) from [<c024a4f8>] (__rpm_callback+0x2c/0x60) [<c024a4f8>] (__rpm_callback) from [<c024a54c>] (rpm_callback+0x20/0x74) [<c024a54c>] (rpm_callback) from [<c024a930>] (rpm_suspend+0xd4/0x43c) [<c024a930>] (rpm_suspend) from [<c024bbcc>] (pm_runtime_work+0x80/0x90) [<c024bbcc>] (pm_runtime_work) from [<c0032a9c>] (process_one_work+0x12c/0x314) [<c0032a9c>] (process_one_work) from [<c0032cf4>] (worker_thread+0x3c/0x4b0) [<c0032cf4>] (worker_thread) from [<c003747c>] (kthread+0xcc/0xe8) [<c003747c>] (kthread) from [<c000e738>] (ret_from_fork+0x14/0x3c) ---[ end trace 40cd58bcd6988f12 ]--- Fixes: a4a8c2c4962bb655 (ARM: exynos: Move to generic PM domain DT bindings) Reported-and-tested0by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-10pinctrl: dra: dt-bindings: Fix output pull up/downRoger Quadros
For PIN_OUTPUT_PULLUP and PIN_OUTPUT_PULLDOWN we must not set the PULL_DIS bit which disables the PULLs. PULL_ENA is a 0 and using it in an OR operation is a NOP, so don't use it in the PIN_OUTPUT_PULLUP/DOWN macros. Fixes: 23d9cec07c58 ("pinctrl: dra: dt-bindings: Fix pull enable/disable") Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-10tracing: Do not busy wait in buffer spliceRabin Vincent
On a !PREEMPT kernel, attempting to use trace-cmd results in a soft lockup: # trace-cmd record -e raw_syscalls:* -F false NMI watchdog: BUG: soft lockup - CPU#0 stuck for 22s! [trace-cmd:61] ... Call Trace: [<ffffffff8105b580>] ? __wake_up_common+0x90/0x90 [<ffffffff81092e25>] wait_on_pipe+0x35/0x40 [<ffffffff810936e3>] tracing_buffers_splice_read+0x2e3/0x3c0 [<ffffffff81093300>] ? tracing_stats_read+0x2a0/0x2a0 [<ffffffff812d10ab>] ? _raw_spin_unlock+0x2b/0x40 [<ffffffff810dc87b>] ? do_read_fault+0x21b/0x290 [<ffffffff810de56a>] ? handle_mm_fault+0x2ba/0xbd0 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff810951e2>] ? trace_buffer_lock_reserve+0x22/0x60 [<ffffffff81095c80>] ? trace_event_buffer_lock_reserve+0x40/0x80 [<ffffffff8112415d>] do_splice_to+0x6d/0x90 [<ffffffff81126971>] SyS_splice+0x7c1/0x800 [<ffffffff812d1edd>] tracesys_phase2+0xd3/0xd8 The problem is this: tracing_buffers_splice_read() calls ring_buffer_wait() to wait for data in the ring buffers. The buffers are not empty so ring_buffer_wait() returns immediately. But tracing_buffers_splice_read() calls ring_buffer_read_page() with full=1, meaning it only wants to read a full page. When the full page is not available, tracing_buffers_splice_read() tries to wait again with ring_buffer_wait(), which again returns immediately, and so on. Fix this by adding a "full" argument to ring_buffer_wait() which will make ring_buffer_wait() wait until the writer has left the reader's page, i.e. until full-page reads will succeed. Link: http://lkml.kernel.org/r/1415645194-25379-1-git-send-email-rabin@rab.in Cc: stable@vger.kernel.org # 3.16+ Fixes: b1169cc69ba9 ("tracing: Remove mock up poll wait function") Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-10udptunnel: Add SKB_GSO_UDP_TUNNEL during gro_complete.Jesse Gross
When doing GRO processing for UDP tunnels, we never add SKB_GSO_UDP_TUNNEL to gso_type - only the type of the inner protocol is added (such as SKB_GSO_TCPV4). The result is that if the packet is later resegmented we will do GSO but not treat it as a tunnel. This results in UDP fragmentation of the outer header instead of (i.e.) TCP segmentation of the inner header as was originally on the wire. Signed-off-by: Jesse Gross <jesse@nicira.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-10mfd: max77693: Fix always masked MUIC interruptsKrzysztof Kozlowski
All interrupts coming from MUIC were ignored because interrupt source register was masked. The Maxim 77693 has a "interrupt source" - a separate register and interrupts which give information about PMIC block triggering the individual interrupt (charger, topsys, MUIC, flash LED). By default bootloader could initialize this register to "mask all" value. In such case (observed on Trats2 board) MUIC interrupts won't be generated regardless of their mask status. Regmap irq chip was unmasking individual MUIC interrupts but the source was masked Before introducing regmap irq chip this interrupt source was unmasked, read and acked. Reading and acking is not necessary but unmasking is. Fixes: 342d669c1ee4 ("mfd: max77693: Handle IRQs using regmap") Cc: <stable@vger.kernel.org> Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-09Merge tag 'armsoc-for-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "Another quiet week: - a fix to silence edma probe error on non-supported platforms from Arnd - a fix to enable the PL clock for Parallella, to make mainline usable with the SDK. - a somewhat verbose fix for the PLL clock tree on VF610 - enabling of SD/MMC on one of the VF610-based boards (for testing) - a fix for i.MX where CONFIG_SPI used to be implicitly enabled and now needs to be added to the defconfig instead - another maintainer added for bcm2835: Lee Jones" * tag 'armsoc-for-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: dts: zynq: Enable PL clocks for Parallella dma: edma: move device registration to platform code ARM: dts: vf610: add SD node to cosmic dts MAINTAINERS: update bcm2835 entry ARM: imx: Fix the removal of CONFIG_SPI option ARM: imx: clk-vf610: define PLL's clock tree
2014-11-09Merge branch 'devicetree/merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux Pull devicetree bugfix from Grant Likely: "One buffer overflow bug that shouldn't be left around" * 'devicetree/merge' of git://git.kernel.org/pub/scm/linux/kernel/git/glikely/linux: of: Fix overflow bug in string property parsing functions
