Some functionality used by android binary drivers
were missing.
This patch permits changing of the current CSC coefficients. It cannot be used
with interlaced mode.
Adds fields to skip window CSC programming if nothing has changed.
Bug 1522546
Change-Id: If8fc6a5d634e4b300ef0de6a5913188fe1f1efb0
Signed-off-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-on: http://git-master/r/422885
(cherry picked from commit 4aa22cd32362f0d91ef030bc0942c303714141cf)
Reviewed-on: http://git-master/r/425986
GVS: Gerrit_Virtual_Submit
Reviewed-by: Michael Frydrych <mfrydrych@nvidia.com>
Tested-by: Michael Frydrych <mfrydrych@nvidia.com>
Bug 200004122
Bug 1511804
This merge takes AOSP commits from android-3.10 branch
Change-Id: I07ec2468114db0366d63777142c9572bbfadbc45
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
Change-Id: I42e087cddc29f6b93749791606e80dbd3e6f59ce
Signed-off-by: Greg Hackmann <ghackmann@google.com>
Quirks specify common behaviors that vary slightly among devices, and
which ADF must account for.
The buffer padding quirk captures the way different devices fetch the
last scanline in a buffer: some devices fetch an entire line (including
padding to the pitch) while others only fetch up to the visible width.
ADF's buffer size validation now takes this quirk into account.
Change-Id: I828b13316e27621d8a9efd9d5fffa6ce12a525ff
Changes "long int" to uint in order to ensure
AARCH32/AARCH64 compatibility.
Bug 1466413
Change-Id: I0c17ff7e8710a62b1c93aade08f7999be66a2c3e
Signed-off-by: Anton Kondratenko <akondratenko@nvidia.com>
Reviewed-on: http://git-master/r/390364
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Thomas Cherry <tcherry@nvidia.com>
A device's fb_info is shared between clients. fb_release() is called
when each client is released, not just the last one. Since the fbdev
helper needs to release its dma-buf when the last client goes away, it
must keep its own reference count.
fbmem and fbcon hold different locks while calling fb_release(), so
explicit locking is needed.
Change-Id: I42cd659f7633adba7c11f407d4b594bd43305d6a
Add compat ioctls and clean up data structures where it would be
simplier to break the old 64-bit APIs for a new one that works.
Some user space binaries will have to be rebuilt after this patch, but
those binaries were almost certainly already broken as the driver wasn't
doing the right thing.
adds 32-bit compat version of:
TEGRA_DC_EXT_CONTROL_GET_OUTPUT_EDID
TEGRA_DC_EXT_FLIP2
TEGRA_DC_EXT_SET_PROPOSED_BW
TEGRA_DC_EXT_SET_LUT
TEGRA_DC_EXT_GET_FEATURES
updates struct tegra_dc_ext_flip_windowattr to be the same size in both
environments. This allows these ioctls to work:
TEGRA_DC_EXT_FLIP
TEGRA_DC_EXT_FLIP3
Bug 1466416
Change-Id: I17b8ba1b1fc5ace659b7db99dd252c03e96273e8
Reviewed-on: http://git-master/r/378129
This reverts commit 0ca988fecb9b58567f2019d9dc0530200e3f764f.
Bug 1466416
Change-Id: I8393151c04a032834d7658d2f4181c0fedccb13a
Reviewed-on: http://git-master/r/378128
Provide a compat version of FBIO_TEGRA_GET_MODEDB.
Bug 1466416
Change-Id: Id976d9e5059d4bb81a25e1412941ecfcc38b4657
Reviewed-on: http://git-master/r/373105
Support for compat ioctls of DC where userspace is 32bit
and kernel is 64bit.
Bug 1349118
Change-Id: Ie48d426eaddda4126b9088794585a4f5765facbc
Signed-off-by: Peng Du <pdu@nvidia.com>
Reviewed-on: http://git-master/r/274472
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Reviewed-by: Bo Yan <byan@nvidia.com>
Change-Id: I0c919e55654e0c224a5f8a5df80d9f49e92dbb37
Modify flip to allow fence file descriptors instead of syncpoint information
Bug 1356564.
Change-Id: I84fad52524cddb037e3ddc4512d3cd85ba394cee
Signed-off-by: Rakesh Iyer <riyer@nvidia.com>
Reviewed-on: http://git-master/r/336299
Reviewed-by: Lauri Peltonen <lpeltonen@nvidia.com>
Tested-by: Jon Mayo <jmayo@nvidia.com>
Add asynchronous bandwidth negotiation support for display.
Bug 1197598.
Change-Id: I16c1ba1dcbe790cec0f6b907c5d4071dc3840629
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/299599
Tested-by: Xue Dong <xdong@nvidia.com>
Reviewed-by: Chao Xu <cxu@nvidia.com>
Change-Id: Id9f8b2184927a77b244ce0b33d619d6e44a0f17a
Many custom formats look a lot like the standard ones, but with
different subsampling, bpp, etc. Expose and document
adf_buffer_validate()'s main body, so drivers can reuse its logic when
validating these formats.
Change-Id: I1d06981c9e5aab26f3ab2956c08c679f2c823bcc
Bug 1352981
Change-Id: Ie103fd01a751744f9d879dbf91972021eb73e483
Signed-off-by: Tuomas Kulve <tkulve@nvidia.com>
Reviewed-on: http://git-master/r/298883
Reviewed-by: Peng Du <pdu@nvidia.com>
Informational flags don't affect ADF directly but may be useful to
clients. Currently used to indicate primary and external displays.
Change-Id: I343c7f0148da0869244c8e818350e9855525df85
Change-Id: I2b82bb625f805e8edb27799743b290dda5befb97
Change-Id: If2aa783b9ece60160f465bf697508fc58682e1bc
Simple buffers are linear RGB buffers analogous to KMS's dumb buffers.
Simple buffers can be allocated and posted to a display interface
without any driver-private data.
Internally, ADF drivers provide the driver-private data needed (if any)
to post a simple buffer to the display.
Change-Id: Ib0b737622eaf343111310f6623f99d69cf3807d2
Provides a dma-buf exporter for memblocks, mainly useful for ADF devices
to wrap their bootloader logos
Change-Id: I936a9b5df099ab6084d433fcaf50f3bc29f93289
Change-Id: I693257e269a99012cd0dbb57576ac222869cf4c7
Add TEGRA_DC_EXT_CURSOR_FORMAT_FLAGS_RGBA_PREMULT_ALPHA flag for
tegra_dc_ext_cursor_image::flags to select premultiplied alpha.
For consistency, rename
TEGRA_DC_EXT_CURSOR_FLAGS_2BIT_LEGACY
TEGRA_DC_EXT_CURSOR_FLAGS_RGBA_NORMAL
to
TEGRA_DC_EXT_CURSOR_FORMAT_FLAGS_2BIT_LEGACY
TEGRA_DC_EXT_CURSOR_FORMAT_FLAGS_RGBA_NON_PREMULT_ALPHA
(but retain the old names as aliases, for source-level backwards
compatibility).
Add new caps bits to be reported in tegra_dc_ext_control_capabilities::caps
TEGRA_DC_EXT_CAPABILITIES_CURSOR_TWO_COLOR
TEGRA_DC_EXT_CAPABILITIES_CURSOR_RGBA_NON_PREMULT_ALPHA
TEGRA_DC_EXT_CAPABILITIES_CURSOR_RGBA_PREMULT_ALPHA
Note that before this change the default RGBA cursor behavior on T114 was
non-premultipled alpha, while on T124 it was premultipled alpha. Now,
the default RGBA cursor behavior is consistently non-premultipled alpha.
Existing T124 RGBA cursor users will need to use the new PREMULT_ALPHA
flag.
Update the cursor image format documentation in tegra_dc_ext.h
Bug 1354320
Change-Id: I82b04c97dea1830ce2659c966ae2a1b59fa06028
Signed-off-by: Andy Ritger <aritger@nvidia.com>
Reviewed-on: http://git-master/r/271749
Expose new planar and semi-planar color formats.
These formats have already been added to dc.h.
Bug 1311740
Change-Id: I26be6148acbacaadf8525e24e7d30bcd93eaf7b4
Signed-off-by: Antoine Chauveau <achauveau@nvidia.com>
Reviewed-on: http://git-master/r/243704
Tested-by: Bhanu Murthy V <bmurthyv@nvidia.com>
Change-Id: I49617eedb7f5dd65fb032f9c9972612a75d01523
Signed-off-by: Chao Xu <cxu@nvidia.com>
Reviewed-on: http://git-master/r/242519
Bug 1232181
Change-Id: I0277727f0b4d8ac63778f4c536c9b23e7dc3825d
Signed-off-by: Xue Dong <xdong@nvidia.com>
Change-Id: Id93f3c905e1976b979e0f931c75701a54fdcf254
Reviewed-on: http://git-master/r/236005
Reviewed-by: Kevin Huang (Eng-SW) <kevinh@nvidia.com>
Bug 1172562
arch/arm/mach-tegra/include/mach/dc.h
drivers/video/tegra/dc/mode.c
Change-Id: I9e33ae73c60e0d98c5009a2a72c243d598bf084f
Reviewed-on: http://git-master/r/200502
Change-Id: I2cc33844d07f34b5391c927293015294b45ae125
Reviewed-on: http://git-master/r/110199
Reviewed-by: Mark Stadler <mastadler@nvidia.com>
reserve upper bits of pixformat to indicate byte swizzle option.
reorder and increase field sizes of tegra_dc structure.
Change-Id: Ibd84dafcc478f6c8f51669f2db52270d5723961c
Reviewed-on: http://git-master/r/232768
(cherry picked from commit 1c6286c8c3d8fc2148281c59f38949824844db4e)
Reviewed-on: http://git-master/r/231899
Export nvhdcp state to user land to check hdcp
link is verified before doing anything else.
Reviewed-on: http://git-master/r/188466
(cherry picked from commit 4305e7007e73e361fc351d94eb76ce52ff074ed5)
Change-Id: I2d40ce69d0726e6d7817462519a47e68a800c21d
Signed-off-by: James Zhao <jamesz@nvidia.com>
Reviewed-on: http://git-master/r/200908
Report event TEGRA_DC_EXT_EVENT_BANDWIDTH through tegra_dc_ctrl device
when there is not enough bandwidth.
Bug 1169265
Change-Id: Ia95b1ecc7eb16db6f3a709e7c9efc59ab2490ead
Reviewed-on: http://git-master/r/207766
Added two interfaces for cmu read. In kernel, the initial cmu values
derive from either default cmu table (identical mapping) or the board
file. TEGRA_DC_EXT_GET_CMU returns the cached cmu values which are the
same as hw values. TEGRA_DC_EXT_GET_CUSTOM_CMU returns the cmu custom
values if they are set in board file; otherwise return error.
Notice for TEGRA_DC_EXT_GET_CMU, in the case cmu is off by default, we
don't write cmu registers. So it returns zeros unless it is enabled.
Bug 1221681
Change-Id: Ie976700b9d1f073e84d83fbdb2f25ecb5d7149db
Reviewed-on: http://git-master/r/202202
Reviewed-by: Harshada Kale <hkale@nvidia.com>
Tested-by: Harshada Kale <hkale@nvidia.com>
Support advanced display cursor for t11x and t14x.
For t14x, window H is set to window mode by default in the sense that
cursor is not necessary for most phones. It can be switched to cursor
mode as below.
echo 0 > /sys/class/graphics/fb0/device/win_h
To switch cursor between normal and legacy mode, user can set flag of
tegra_dc_ext_cursor through the ioctl TEGRA_DC_EXT_SET_CURSOR.
Change-Id: If5ef50401b8a2b2fd22500636d07506983aee0b5
Reviewed-on: http://git-master/r/194210
Reviewed-by: Mrutyunjay Sawant <msawant@nvidia.com>
Tested-by: Mrutyunjay Sawant <msawant@nvidia.com>
Move tegra_camera from platform_driver to
part of nvhost vi driver. Split tegra_camera.c file into
multiple files incluidng camera.c, camera_power.c,
camera_emc.c and camera_clk.c according to functionality.
tegra_camera is registered/unregistered in nvhost vi driver.
Bug 1189789
Reviewed-on: http://git-master/r/174508
(cherry picked from commit e503a08b809844b53b7737e504e9f376f4a8a1eb)
Change-Id: Ia8e189e809e18e16b780d3ff064bc96db84ade85
Signed-off-by: Jihoon Bang <jbang@nvidia.com>
Reviewed-on: http://git-master/r/194805
Reviewed-by: Mandar Padmawar <mpadmawar@nvidia.com>
Tested-by: Mandar Padmawar <mpadmawar@nvidia.com>
add new ioctl that supports flip of an arbitrary number of windows.
Change-Id: I6368129092921c665db5a8063f714d9f8fc14e63
Reviewed-on: http://git-master/r/193929
Reviewed-by: Tuomas Kulve <tkulve@nvidia.com>
Bug 1169109
Change-Id: I98ee2794724299113c7aab3a60703f2927c9ea8d
Reviewed-on: http://git-master/r/162990
Reviewed-by: Simone Willett <swillett@nvidia.com>
Add a new ioctl to enable cursor clipping.
Modify set_cursor_image_hw() to preserve cursor
clipping status.
Change-Id: I4af4c342fc008203c4d8148609587618e333c71f
Signed-off-by: Prashant Malani <pmalani@nvidia.com>
Reviewed-on: http://git-master/r/131270
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R44f6792eaf1ae5abdebac1786ff4051c349f1d32
SCAN_COLUMN is a new feature for display. Add support to it for
90 & 270 degree rotation.
Bug 964993
Bug 911213
Change-Id: Iff9818d901a4ae09dffb833bf2cf4a888f1ecec5
Reviewed-on: http://git-master/r/130313
Rebase-Id: R631c88af2834303d46a21b87dfaba2ffb7eb5843
Bug 992947
Change-Id: I0d1ecc9f8f042956cbe631779260a38573936616
Reviewed-on: http://git-master/r/105776
Rebase-Id: Raaf16738c516385dbbd9474a427e05f3b675a82d
Adds a global alpha parameter to each window. It provides a default
alpha value for pixel formats that do not include alpha.
Change-Id: I5465864877a727b4daed0eb32fb8219e2ccb663e
Reviewed-on: http://git-master/r/101806
Rebase-Id: Rbca65e11501f8721a596b4906aaa767791868cda
This change adds a flag to flip windows in cursor mode. Cursor mode
will cause flips to be skipped over if there are newer flip requests
waiting in the workqueue.
Add CURSOR_MODE to caps bitfield.
bug 942762
Change-Id: Ib52a0a5565f961cdd9650e4204cd65b86f96fee1
Signed-off-by: Adam Cheney <acheney@nvidia.com>
Reviewed-on: http://git-master/r/90418
Reviewed-by: Robert Morell <rmorell@nvidia.com>
Rebase-Id: R179068b5bad6d40e1599b8b3597fb1659a61f8f9
Defines a new ioctl for querying a bitfield of DC capabilities.
The first defined caps bit is for "cursor mode" flipping support.
bug 942631
Change-Id: Iea8a0dfe4e400e0dad4bb9f23509c3ac0ca532ba
Reviewed-on: http://git-master/r/87066
Tested-by: Adam Cheney <acheney@nvidia.com>
Rebase-Id: R9cf72d8428495698fc5caebe4a0f8378a061c0c7
This adds flags for horizontal and vertical surface mirroring,
and updates the ioctl handling code to set the appropriate core
dc mirroring flags when the dc_ext mirroring flags are passed.
Bug 905578
Change-Id: Idbe0c95cb0807aa9e26ccfdc42cf4ef0dc9eb38f
Reviewed-on: http://git-master/r/64110
Reviewed-by: Markus Holtmanns <mholtmanns@nvidia.com>
Rebase-Id: R5795faa3988df9f87e669f40aab9b0281111a4b0
This adds a new flags field to the dc_ext flip ioctl, adds a flag for
tiled surfaces, and updates the ioctl handling code to set the
appropriate core dc tiling flag when the dc_ext tiled flag is passed.
Bug 831397
Change-Id: I36cbf4a59173885a98209e559f77404bddcf54cd
Reviewed-on: http://git-master/r/64109
Rebase-Id: Rf741be9e6945b6b92699e26fb1745fafef4d8fe4
Add support to set a global gamma correction table via fbdev cmap
API. The 3 Tegra DC windows have their own local gamma tables, which
can either override or alter the global table.
Bug 868060
Change-Id: I0be1c5e4afa8fd8c010b772c7808c883c0848ab4
Reviewed-on: http://git-master/r/60201
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Rebase-Id: R7e613b1c8ac469242172bd81db9dfba25176e0c3
- enable gamma look-up hardware only when needed to save power
- add flags field to ioctl TEGRA_DC_EXT_SET_LUT for forward compatibility
Bug 868060
Change-Id: I690f8b8856e0b1acd6215907ca8bd78ecaf30b17
Reviewed-on: http://git-master/r/57736
Reviewed-by: David Schalig <dschalig@nvidia.com>
Tested-by: David Schalig <dschalig@nvidia.com>
Rebase-Id: Rf6081a9372ba7d6e53a66b9b58a50a62ad409d9a
Adds ioctl TEGRA_DC_EXT_SET_LUT to dc_ext driver for setting
a DC window's color palette.
Bug 868060
Change-Id: I57ffcf3a3f91e76efd1c7f1f972b73c2edbaed82
Reviewed-on: http://git-master/r/56392
Rebase-Id: R712c71151d0c3e3d274279f334bedf312e26e75d
This change implements the TEGRA_DC_EXT_CONTROL_GET_OUTPUT_EDID ioctl in
the dc_ext interface.
It first adds a way for the tegra dc EDID module to export EDID data
safely, without the risk of reading an incomplete or corrupted EDID in
the presence of hotplug, by moving the actual data to a substructure
with a lifetime maintained by a kref. Then, that support is plumbed
through the hdmi block (which is currently the only way to get at the
EDID) and out to userspace.
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Bug 817119
Original-Change-Id: I78cd170e15322011b428cb71ffad2c0c3ea058ac
Reviewed-on: http://git-master/r/49127
Rebase-Id: Rafafc0a6fbacda5494b12162ad99a8c70ceeb2e0
Currently, dc_ext only takes a single nvmap memory ID per overlay, even
in the YUV case (the U and V planes are expected to be differentiated
using an offset from the beginning of the nvmap allocation).
This is problematic for some software flows, such as certain video
interlacing algorithms that will vary the luma plane while keeping the
chrome plane constant.
This change allows dc_ext clients to specify a different nvmap
allocation for each of the Y, U, and V planes. If a YUV surface is
used and no U or V plane allocation is specified, the old behavior is
preserved: the U and V offsets are assumed to be within the same
allocation as Y.
Note: this changes the behavior of the offset parameter: the old code
added offset to offset_u and offset_v when using it. The new code
treats all three offsets as relative to the beginning of the allocation.
It also fixes a bug in the code where offset was applied twice to the Y
plane. I believe this is safe because the presence of this bug means
that no existing clients are using offset != 0 (or if they are, they're
already broken).
Bug 850882
Original-Change-Id: I230e03db25baaae73a3bdc0d45a2aec162b87fa4
Reviewed-on: http://git-master/r/41471
Rebase-Id: Ra6dd17a50de7150edf104d2a6c9b3b9949919022
