commit a930d8790552658140d7d0d2e316af4f0d76a512 upstream.
If you open a pipe for neither read nor write, the pipe code will not
add any usage counters to the pipe, causing the 'struct pipe_inode_info"
to be potentially released early.
That doesn't normally matter, since you cannot actually use the pipe,
but the pipe release code - particularly fasync handling - still expects
the actual pipe infrastructure to all be there. And rather than adding
NULL pointer checks, let's just disallow this case, the same way we
already do for the named pipe ("fifo") case.
This is ancient going back to pre-2.4 days, and until trinity, nobody
naver noticed.
Reported-by: Dave Jones <davej@redhat.com>
security keys
commit 8aec0f5d4137532de14e6554fd5dd201ff3a3c49 upstream.
Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to
compat_process_vm_rw() shows that the compatibility code requires an
explicit "access_ok()" check before calling
compat_rw_copy_check_uvector(). The same difference seems to appear when
we compare fs/read_write.c:do_readv_writev() to
fs/compat.c:compat_do_readv_writev().
This subtle difference between the compat and non-compat requirements
should probably be debated, as it seems to be error-prone. In fact,
there are two others sites that use this function in the Linux kernel,
and they both seem to get it wrong:
Now shifting our attention to fs/aio.c, we see that aio_setup_iocb()
also ends up calling compat_rw_copy_check_uvector() through
aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to
be missing. Same situation for
security/keys/compat.c:compat_keyctl_instantiate_key_iov().
I propose that we add the access_ok() check directly into
compat_rw_copy_check_uvector(), so callers don't have to worry about it,
and it therefore makes the compat call code similar to its non-compat
counterpart. Place the access_ok() check in the same location where
copy_from_user() can trigger a -EFAULT error in the non-compat code, so
the ABI behaviors are alike on both compat and non-compat.
While we are here, fix compat_do_readv_writev() so it checks for
compat_rw_copy_check_uvector() negative return values.
And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error
handling.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit 4a7d0f6854c4a4ad1dba00a3b128a32d39b9a742 upstream.
I noticed we were getting lots of warnings with xfstest 83 because we have
reservations outstanding. This is because we moved the orphan add outside
of the truncate, but we don't actually cleanup our reservation if something
fails. This fixes the problem and I no longer see warnings. Thanks,
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
commit 925396ecf251432d6d0f703a6cfd0cb9e651d936 upstream.
Dave sent me a panic where we were doing the orphan cleanup and panic'ed
trying to release our reservation from the orphan block rsv. The reason for
this is because our orphan block rsv had been free'd out from underneath us
because the transaction commit found that there were no orphan inodes
according to its count and decided to free it. This is incorrect so make
sure we inc the orphan inodes count so the accounting is all done properly.
This would also cause the warning in the orphan commit code normally if you
had any orphans to cleanup as they would only decrement the orphan count so
you'd get a negative orphan count which could cause problems during runtime.
Thanks,
commit 067785c40e52089993757afa28988c05f3cb2694 upstream.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Signed-off-by: Steve French <sfrench@us.ibm.com>
commit db04dc679bcc780ad6907943afe24a30de974a1b upstream.
Update proc_ns_follow_link to use nd_jump_link instead of just
manually updating nd.path.dentry.
This fixes the BUG_ON(nd->inode != parent->d_inode) reported by Dave
Jones and reproduced trivially with mkdir /proc/self/ns/uts/a.
Sigh it looks like the VFS change to require use of nd_jump_link
happend while proc_ns_follow_link was baking and since the common case
of proc_ns_follow_link continued to work without problems the need for
making this change was overlooked.
commit 7b54c165a0c012edbaeaa73c5c87cb73721eb580 upstream.
It's "normal" - it can happen if the file descriptor you followed was
opened with O_NOFOLLOW.
commit a47970ff7814718fec31b7d966747c6aa1a3545f upstream.
This fixes an oops where a LAYOUTGET is in still in the rpciod queue,
but the requesting processes has been killed. Without this, killing
the process does the final pnfs_put_layout_hdr() and sets NFS_I(inode)->layout
to NULL while the LAYOUTGET rpc task still references it.
Example oops:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000080
IP: [<ffffffffa01bd586>] pnfs_choose_layoutget_stateid+0x37/0xef [nfsv4]
PGD 7365b067 PUD 7365d067 PMD 0
Oops: 0000 [#1] SMP DEBUG_PAGEALLOC
Modules linked in: nfs_layout_nfsv41_files nfsv4 auth_rpcgss nfs lockd sunrpc ipt_MASQUERADE ip6table_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 iptable_nat nf_nat_ipv4 nf_nat iptable_mangle ip6table_filter ip6_tables ppdev e1000 i2c_piix4 i2c_core shpchp parport_pc parport crc32c_intel aesni_intel xts aes_x86_64 lrw gf128mul ablk_helper cryptd mptspi scsi_transport_spi mptscsih mptbase floppy autofs4
CPU 0
Pid: 27, comm: kworker/0:1 Not tainted 3.8.0-dros_cthon2013+ #4 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform
RIP: 0010:[<ffffffffa01bd586>] [<ffffffffa01bd586>] pnfs_choose_layoutget_stateid+0x37/0xef [nfsv4]
RSP: 0018:ffff88007b0c1c88 EFLAGS: 00010246
RAX: ffff88006ed36678 RBX: 0000000000000000 RCX: 0000000ea877e3bc
RDX: ffff88007a729da8 RSI: 0000000000000000 RDI: ffff88007a72b958
RBP: ffff88007b0c1ca8 R08: 0000000000000002 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88007a72b958
R13: ffff88007a729da8 R14: 0000000000000000 R15: ffffffffa011077e
FS: 0000000000000000(0000) GS:ffff88007f600000(0000) knlGS:0000000000000000
CR2: 0000000000000080 CR3: 00000000735f8000 CR4: 00000000001407f0
Process kworker/0:1 (pid: 27, threadinfo ffff88007b0c0000, task ffff88007c2fa0c0)
Stack:
ffff88006fc05388 ffff88007a72b908 ffff88007b240900 ffff88006fc05388
ffff88007b0c1cd8 ffffffffa01a2170 ffff88007b240900 ffff88007b240900
ffff88007b240970 ffffffffa011077e ffff88007b0c1ce8 ffffffffa0110791
Call Trace:
[<ffffffffa01a2170>] nfs4_layoutget_prepare+0x7b/0x92 [nfsv4]
[<ffffffffa011077e>] ? __rpc_atrun+0x15/0x15 [sunrpc]
[<ffffffffa0110791>] rpc_prepare_task+0x13/0x15 [sunrpc]
Reported-by: Tigran Mkrtchyan <tigran.mkrtchyan@desy.de>
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
commit 78f33277f96430ea001c39e952f6b8200b2ab850 upstream.
Pass the directio request on pageio_init to clean up the API.
Percolate pg_dreq from original nfs_pageio_descriptor to the
pnfs_{read,write}_done_resend_to_mds and use it on respective
call to nfs_pageio_init_{read,write} on the newly created
nfs_pageio_descriptor.
Reproduced by command:
mount -o vers=4.1 server:/ /mnt
dd bs=128k count=8 if=/dev/zero of=/mnt/dd.out oflag=direct
BUG: unable to handle kernel NULL pointer dereference at 0000000000000028
IP: [<ffffffffa021a3a8>] atomic_inc+0x4/0x9 [nfs]
PGD 34786067 PUD 34794067 PMD 0
Oops: 0002 [#1] SMP
Modules linked in: nfs_layout_nfsv41_files nfsv4 nfs nfsd lockd nfs_acl auth_rpcgss exportfs sunrpc btrfs zlib_deflate libcrc32c ipv6 autofs4
CPU 1
Pid: 259, comm: kworker/1:2 Not tainted 3.8.0-rc6 #2 Bochs Bochs
RIP: 0010:[<ffffffffa021a3a8>] [<ffffffffa021a3a8>] atomic_inc+0x4/0x9 [nfs]
RSP: 0018:ffff880038f8fa68 EFLAGS: 00010206
RAX: ffffffffa021a6a9 RBX: ffff880038f8fb48 RCX: 00000000000a0000
RDX: ffffffffa021e616 RSI: ffff8800385e9a40 RDI: 0000000000000028
RBP: ffff880038f8fa68 R08: ffffffff81ad6720 R09: ffff8800385e9510
R10: ffffffffa0228450 R11: ffff880038e87418 R12: ffff8800385e9a40
R13: ffff8800385e9a70 R14: ffff880038f8fb38 R15: ffffffffa0148878
FS: 0000000000000000(0000) GS:ffff88003e400000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000028 CR3: 0000000034789000 CR4: 00000000000006e0
Process kworker/1:2 (pid: 259, threadinfo ffff880038f8e000, task ffff880038302480)
Stack:
ffff880038f8fa78 ffffffffa021a6bf ffff880038f8fa88 ffffffffa021bb82
ffff880038f8fae8 ffffffffa021f454 ffff880038f8fae8 ffffffff8109689d
ffff880038f8fab8 ffffffff00000006 0000000000000000 ffff880038f8fb48
Call Trace:
[<ffffffffa021a6bf>] nfs_direct_pgio_init+0x16/0x18 [nfs]
[<ffffffffa021bb82>] nfs_pgheader_init+0x6a/0x6c [nfs]
[<ffffffffa021f454>] nfs_generic_pg_writepages+0x51/0xf8 [nfs]
[<ffffffff8109689d>] ? mark_held_locks+0x71/0x99
[<ffffffffa0148878>] ? rpc_release_resources_task+0x37/0x37 [sunrpc]
[<ffffffffa021bc25>] nfs_pageio_doio+0x1a/0x43 [nfs]
[<ffffffffa021be7c>] nfs_pageio_complete+0x16/0x2c [nfs]
[<ffffffffa02608be>] pnfs_write_done_resend_to_mds+0x95/0xc5 [nfsv4]
[<ffffffffa028e27f>] filelayout_reset_write+0x8c/0x99 [nfs_layout_nfsv41_files]
[<ffffffffa028e5f9>] filelayout_write_done_cb+0x4d/0xc1 [nfs_layout_nfsv41_files]
[<ffffffffa024587a>] nfs4_write_done+0x36/0x49 [nfsv4]
[<ffffffffa021f996>] nfs_writeback_done+0x53/0x1cc [nfs]
[<ffffffffa021fb1d>] nfs_writeback_done_common+0xe/0x10 [nfs]
[<ffffffffa028e03d>] filelayout_write_call_done+0x28/0x2a [nfs_layout_nfsv41_files]
[<ffffffffa01488a1>] rpc_exit_task+0x29/0x87 [sunrpc]
[<ffffffffa014a0c9>] __rpc_execute+0x11d/0x3cc [sunrpc]
[<ffffffff810969dc>] ? trace_hardirqs_on_caller+0x117/0x173
[<ffffffffa014a39f>] rpc_async_schedule+0x27/0x32 [sunrpc]
[<ffffffffa014a378>] ? __rpc_execute+0x3cc/0x3cc [sunrpc]
[<ffffffff8105f8c1>] process_one_work+0x226/0x422
[<ffffffff8105f7f4>] ? process_one_work+0x159/0x422
[<ffffffff81094757>] ? lock_acquired+0x210/0x249
[<ffffffff810600d8>] worker_thread+0x126/0x1c4
[<ffffffff8105ffb2>] ? manage_workers+0x240/0x240
[<ffffffff81064ef8>] kthread+0xb1/0xb9
[<ffffffff81064e47>] ? __kthread_parkme+0x65/0x65
[<ffffffff815206ec>] ret_from_fork+0x7c/0xb0
Code: 00 83 38 02 74 12 48 81 4b 50 00 00 01 00 c7 83 60 07 00 00 01 00 00 00 48 89 df e8 55 fe ff ff 5b 41 5c 5d c3 66 90 55 48 89 e5 <f0> ff 07 5d c3 55 48 89 e5 f0 ff 0f 0f 94 c0 84 c0 0f 95 c0 0f
RIP [<ffffffffa021a3a8>] atomic_inc+0x4/0x9 [nfs]
RSP <ffff880038f8fa68>
Signed-off-by: Benny Halevy <bhalevy@tonian.com>
commit 5a7a613a47a715711b3f2d3322a0eac21d459166 upstream.
Commit 73ca100 broke the code that prevents the client from deleting
a silly renamed dentry. This affected "delete on last close"
semantics as after that commit, nothing prevented removal of
silly-renamed files. As a result, a process holding a file open
could easily get an ESTALE on the file in a directory where some
other process issued 'rm -rf some_dir_containing_the_file' twice.
Before the commit, any attempt at unlinking silly renamed files would
fail inside may_delete() with -EBUSY because of the
DCACHE_NFSFS_RENAMED flag. The following testcase demonstrates
the problem:
tail -f /nfsmnt/dir/file &
rm -rf /nfsmnt/dir
rm -rf /nfsmnt/dir
# second removal does not fail, 'tail' process receives ESTALE
The problem with the above commit is that it unhashes the old and
new dentries from the lookup path, even in the normal case when
a signal is not encountered and it would have been safe to call
d_move. Unfortunately the old dentry has the special
DCACHE_NFSFS_RENAMED flag set on it. Unhashing has the
side-effect that future lookups call d_alloc(), allocating a new
dentry without the special flag for any silly-renamed files. As a
result, subsequent calls to unlink silly renamed files do not fail
but allow the removal to go through. This will result in ESTALE
errors for any other process doing operations on the file.
To fix this, go back to using d_move on success.
For the signal case, it's unclear what we may safely do beyond d_drop.
Reported-by: Dave Wysochanski <dwysocha@redhat.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
commit ce2ac52105aa663056dfc17966ebed1bf93e6e64 upstream.
Kjell Braden reported this oops:
[ 833.211970] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 833.212816] IP: [< (null)>] (null)
[ 833.213280] PGD 1b9b2067 PUD e9f7067 PMD 0
[ 833.213874] Oops: 0010 [#1] SMP
[ 833.214344] CPU 0
[ 833.214458] Modules linked in: des_generic md4 nls_utf8 cifs vboxvideo drm snd_intel8x0 snd_ac97_codec ac97_bus snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event snd_seq bnep rfcomm snd_timer bluetooth snd_seq_device ppdev snd vboxguest parport_pc joydev mac_hid soundcore snd_page_alloc psmouse i2c_piix4 serio_raw lp parport usbhid hid e1000
[ 833.215629]
[ 833.215629] Pid: 1752, comm: mount.cifs Not tainted 3.0.0-rc7-bisectcifs-fec11dd9a0+ #18 innotek GmbH VirtualBox/VirtualBox
[ 833.215629] RIP: 0010:[<0000000000000000>] [< (null)>] (null)
[ 833.215629] RSP: 0018:ffff8800119c9c50 EFLAGS: 00010282
[ 833.215629] RAX: ffffffffa02186c0 RBX: ffff88000c427780 RCX: 0000000000000000
[ 833.215629] RDX: 0000000000000000 RSI: ffff88000c427780 RDI: ffff88000c4362e8
[ 833.215629] RBP: ffff8800119c9c88 R08: ffff88001fc15e30 R09: 00000000d69515c7
[ 833.215629] R10: ffffffffa0201972 R11: ffff88000e8f6a28 R12: ffff88000c4362e8
[ 833.215629] R13: 0000000000000000 R14: 0000000000000000 R15: ffff88001181aaa6
[ 833.215629] FS: 00007f2986171700(0000) GS:ffff88001fc00000(0000) knlGS:0000000000000000
[ 833.215629] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 833.215629] CR2: 0000000000000000 CR3: 000000001b982000 CR4: 00000000000006f0
[ 833.215629] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 833.215629] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 833.215629] Process mount.cifs (pid: 1752, threadinfo ffff8800119c8000, task ffff88001c1c16f0)
[ 833.215629] Stack:
[ 833.215629] ffffffff8116a9b5 ffff8800119c9c88 ffffffff81178075 0000000000000286
[ 833.215629] 0000000000000000 ffff88000c4276c0 ffff8800119c9ce8 ffff8800119c9cc8
[ 833.215629] ffffffff8116b06e ffff88001bc6fc00 ffff88000c4276c0 ffff88000c4276c0
[ 833.215629] Call Trace:
[ 833.215629] [<ffffffff8116a9b5>] ? d_alloc_and_lookup+0x45/0x90
[ 833.215629] [<ffffffff81178075>] ? d_lookup+0x35/0x60
[ 833.215629] [<ffffffff8116b06e>] __lookup_hash.part.14+0x9e/0xc0
[ 833.215629] [<ffffffff8116b1d6>] lookup_one_len+0x146/0x1e0
[ 833.215629] [<ffffffff815e4f7e>] ? _raw_spin_lock+0xe/0x20
[ 833.215629] [<ffffffffa01eef0d>] cifs_do_mount+0x26d/0x500 [cifs]
[ 833.215629] [<ffffffff81163bd3>] mount_fs+0x43/0x1b0
[ 833.215629] [<ffffffff8117d41a>] vfs_kern_mount+0x6a/0xd0
[ 833.215629] [<ffffffff8117e584>] do_kern_mount+0x54/0x110
[ 833.215629] [<ffffffff8117fdc2>] do_mount+0x262/0x840
[ 833.215629] [<ffffffff81108a0e>] ? __get_free_pages+0xe/0x50
[ 833.215629] [<ffffffff8117f9ca>] ? copy_mount_options+0x3a/0x180
[ 833.215629] [<ffffffff8118075d>] sys_mount+0x8d/0xe0
[ 833.215629] [<ffffffff815ece82>] system_call_fastpath+0x16/0x1b
[ 833.215629] Code: Bad RIP value.
[ 833.215629] RIP [< (null)>] (null)
[ 833.215629] RSP <ffff8800119c9c50>
[ 833.238525] ---[ end trace ec00758b8d44f529 ]---
When walking down the path on the server, it's possible to hit a
symlink. The path walking code assumes that the caller will handle that
situation properly, but cifs_get_root() isn't set up for it. This patch
prevents the oops by simply returning an error.
A better solution would be to try and chase the symlinks here, but that's
fairly complicated to handle.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=53221
Reported-and-tested-by: Kjell Braden <afflux@pentabarf.de>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
commit 124fe663f93162d17b7e391705cac122101e93d8 upstream.
Apparently when we do inline extents we allow the data to overlap the last chunk
of the btrfs_file_extent_item, which means that we can possibly have a
btrfs_file_extent_item that isn't actually as large as a btrfs_file_extent_item.
This messes with us when we try to overwrite the extent when logging new extents
since we expect for it to be the right size. To fix this just delete the item
and try to do the insert again which will give us the proper sized
btrfs_file_extent_item. This fixes a panic where map_private_extent_buffer
would blow up because we're trying to write past the end of the leaf. Thanks,
commit bdc20e67e82cfc4901d3a5a0d79104b0e2296d83 upstream.
I noticed while looking into a tree logging bug that we aren't logging inline
extents properly. Since this requires copying and it shouldn't happen too often
just force us to copy everything for the inode into the tree log when we have an
inline extent. With this patch we have valid data after a crash when we write
an inline extent. Thanks,
commit 1cba0cdf5e4dbcd9e5fa5b54d7a028e55e2ca057 upstream.
__btrfs_close_devices() clones btrfs device structs with
memcpy(). Some of the fields in the clone are reinitialized, but it's
missing to init io_lock. In mainline this goes unnoticed, but on RT it
leaves the plist pointing to the original about to be freed lock
struct.
Initialize io_lock after cloning, so no references to the original
struct are left.
Reported-and-tested-by: Mike Galbraith <efault@gmx.de>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
commit 810da240f221d64bf90020f25941b05b378186fe upstream.
We're using macro EXT4_B2C() to convert number of blocks to number of
clusters for bigalloc file systems. However, we should be using
EXT4_NUM_B2C().
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
commit 1e82379b018ceed0f0912327c60d73107dacbcb3 upstream.
When we are converting local data to an extent format as a result of
adding an attribute, the type of data contained in the local fork
determines the behaviour that needs to occur.
xfs_bmap_add_attrfork_local() already handles the directory data
case specially by using S_ISDIR() and calling out to
xfs_dir2_sf_to_block(), but with verifiers we now need to handle
each different type of metadata specially and different metadata
formats require different verifiers (and eventually block header
initialisation).
There is only a single place that we add and attribute fork to
the inode, but that is in the attribute code and it knows nothing
about the specific contents of the data fork. It is only the case of
local data that is the issue here, so adding code to hadnle this
case in the attribute specific code is wrong. Hence we are really
stuck trying to detect the data fork contents in
xfs_bmap_add_attrfork_local() and performing the correct callout
there.
Luckily the current cases can be determined by S_IS* macros, and we
can push the work off to data specific callouts, but each of those
callouts does a lot of work in common with
xfs_bmap_local_to_extents(). The only reason that this fails for
symlinks right now is is that xfs_bmap_local_to_extents() assumes
the data fork contains extent data, and so attaches a a bmap extent
data verifier to the buffer and simply copies the data fork
information straight into it.
To fix this, allow us to pass a "formatting" callback into
xfs_bmap_local_to_extents() which is responsible for setting the
buffer type, initialising it and copying the data fork contents over
to the new buffer. This allows callers to specify how they want to
format the new buffer (which is necessary for the upcoming CRC
enabled metadata blocks) and hence make xfs_bmap_local_to_extents()
useful for any type of data fork content.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 9f244e9cfd70c7c0f82d3c92ce772ab2a92d9f64 upstream.
[Issue]
When pstore is in panic and emergency-restart paths, it may be blocked
in those paths because it simply takes spin_lock.
This is an example scenario which pstore may hang up in a panic path:
- cpuA grabs psinfo->buf_lock
- cpuB panics and calls smp_send_stop
- smp_send_stop sends IRQ to cpuA
- after 1 second, cpuB gives up on cpuA and sends an NMI instead
- cpuA is now in an NMI handler while still holding buf_lock
- cpuB is deadlocked
This case may happen if a firmware has a bug and
cpuA is stuck talking with it more than one second.
Also, this is a similar scenario in an emergency-restart path:
- cpuA grabs psinfo->buf_lock and stucks in a firmware
- cpuB kicks emergency-restart via either sysrq-b or hangcheck timer.
And then, cpuB is deadlocked by taking psinfo->buf_lock again.
[Solution]
This patch avoids the deadlocking issues in both panic and emergency_restart
paths by introducing a function, is_non_blocking_path(), to check if a cpu
can be blocked in current path.
With this patch, pstore is not blocked even if another cpu has
taken a spin_lock, in those paths by changing from spin_lock_irqsave
to spin_trylock_irqsave.
In addition, according to a comment of emergency_restart() in kernel/sys.c,
spin_lock shouldn't be taken in an emergency_restart path to avoid
deadlock. This patch fits the comment below.
<snip>
* emergency_restart - reboot the system
* Without shutting down any hardware or taking any locks
* reboot the system. This is called when we know we are in
* trouble so this is our best effort to reboot. This is
* safe to call in interrupt context.
void emergency_restart(void)
<snip>
Signed-off-by: Seiji Aguchi <seiji.aguchi@hds.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: CAI Qian <caiqian@redhat.com>
commit dfca7cebc2679f3d129f8e680a8f199a7ad16e38 upstream.
drop_nlink() warns if nlink is already zero. This is triggerable by a buggy
userspace filesystem. The cure, I think, is worse than the disease so disable
the warning.
Reported-by: Tero Roponen <tero.roponen@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
commit 2d32b29a1c2830f7c42caa8258c714acd983961f upstream.
When free nfs-client, it must free the ->cl_stateids.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit 304e220f0879198b1f5309ad6f0be862b4009491 upstream.
ext4_has_free_clusters() should tell us whether there is enough free
clusters to allocate, however number of free clusters in the file system
is converted to blocks using EXT4_C2B() which is not only wrong use of
the macro (we should have used EXT4_NUM_B2C) but it's also completely
wrong concept since everything else is in cluster units.
Moreover when calculating number of root clusters we should be using
macro EXT4_NUM_B2C() instead of EXT4_B2C() otherwise the result might be
off by one. However r_blocks_count should always be a multiple of the
cluster ratio so doing a plain bit shift should be enough here. We
avoid using EXT4_B2C() because it's confusing.
As a result of the first problem number of free clusters is much bigger
than it should have been and ext4_has_free_clusters() would return 1 even
if there is really not enough free clusters available.
Fix this by removing the EXT4_C2B() conversion of free clusters and
using bit shift when calculating number of root clusters. This bug
affects number of xfstests tests covering file system ENOSPC situation
handling. With this patch most of the ENOSPC problems with bigalloc file
system disappear, especially the errors caused by delayed allocation not
having enough space when the actual allocation is finally requested.
commit 1231b3a1eb5740192aeebf5344dd6d6da000febf upstream.
Currently when new xattr block is created or released we we would call
dquot_free_block() or dquot_alloc_block() respectively, among the else
decrementing or incrementing the number of blocks assigned to the
inode by one block.
This however does not work for bigalloc file system because we always
allocate/free the whole cluster so we have to count with that in
dquot_free_block() and dquot_alloc_block() as well.
Use the clusters-to-blocks conversion EXT4_C2B() when passing number of
blocks to the dquot_alloc/free functions to fix the problem.
The problem has been revealed by xfstests #117 (and possibly others).
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
commit f1167009711032b0d747ec89a632a626c901a1ad upstream.
In ext4_mb_add_n_trim(), lg_prealloc_lock should be taken when
changing the lg_prealloc_list.
Signed-off-by: Niu Yawei <yawei.niu@intel.com>
commit 72ba74508b2857e71d65fc93f0d6b684492fc740 upstream.
In addition, print the error returned from ext4_enable_quotas()
Reviewed-by: Carlos Maiolino <cmaiolino@redhat.com>
commit 15b49132fc972c63894592f218ea5a9a61b1a18f upstream.
Validate the bh pointer before using it, since
ext4_read_block_bitmap_nowait() might return NULL.
I've seen this in fsfuzz testing.
EXT4-fs error (device loop0): ext4_read_block_bitmap_nowait:385: comm touch: Cannot get buffer for block bitmap - block_group = 0, block_bitmap = 3925999616
IP: [<ffffffff8121de25>] ext4_wait_block_bitmap+0x25/0xe0
Call Trace:
[<ffffffff8121e1e5>] ext4_read_block_bitmap+0x35/0x60
[<ffffffff8125e9c6>] ext4_free_blocks+0x236/0xb80
[<ffffffff811d0d36>] ? __getblk+0x36/0x70
[<ffffffff811d0a5f>] ? __find_get_block+0x8f/0x210
[<ffffffff81191ef3>] ? kmem_cache_free+0x33/0x140
[<ffffffff812678e5>] ext4_xattr_release_block+0x1b5/0x1d0
[<ffffffff812679be>] ext4_xattr_delete_inode+0xbe/0x100
[<ffffffff81222a7c>] ext4_free_inode+0x7c/0x4d0
[<ffffffff812277b8>] ? ext4_mark_inode_dirty+0x88/0x230
[<ffffffff8122993c>] ext4_evict_inode+0x32c/0x490
[<ffffffff811b8cd7>] evict+0xa7/0x1c0
[<ffffffff811b8ed3>] iput_final+0xe3/0x170
[<ffffffff811b8f9e>] iput+0x3e/0x50
[<ffffffff812316fd>] ext4_add_nondir+0x4d/0x90
[<ffffffff81231d0b>] ext4_create+0xeb/0x170
[<ffffffff811aae9c>] vfs_create+0xac/0xd0
[<ffffffff811ac845>] lookup_open+0x185/0x1c0
[<ffffffff8129e3b9>] ? selinux_inode_permission+0xa9/0x170
[<ffffffff811acb54>] do_last+0x2d4/0x7a0
[<ffffffff811af743>] path_openat+0xb3/0x480
[<ffffffff8116a8a1>] ? handle_mm_fault+0x251/0x3b0
[<ffffffff811afc49>] do_filp_open+0x49/0xa0
[<ffffffff811bbaad>] ? __alloc_fd+0xdd/0x150
[<ffffffff8119da28>] do_sys_open+0x108/0x1f0
[<ffffffff8119db51>] sys_open+0x21/0x30
[<ffffffff81618959>] system_call_fastpath+0x16/0x1b
Also fix comment for ext4_read_block_bitmap_nowait()
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
commit 860d21e2c585f7ee8a4ecc06f474fdc33c9474f4 upstream.
The only reason for sb_getblk() failing is if it can't allocate the
buffer_head. So ENOMEM is more appropriate than EIO. In addition,
make sure that the file system is marked as being inconsistent if
sb_getblk() fails.
commit 091e26dfc156aeb3b73bc5c5f277e433ad39331c upstream.
Running AIO is pinning inode in memory using file reference. Once AIO
is completed using aio_complete(), file reference is put and inode can
be freed from memory. So we have to be sure that calling aio_complete()
is the last thing we do with the inode.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
commit 54c807e71d5ac59dee56c685f2b66e27cd54c475 upstream.
CC: Christoph Hellwig <hch@infradead.org>
CC: Jens Axboe <axboe@kernel.dk>
CC: Jeff Moyer <jmoyer@redhat.com>
commit 309a85b6861fedbb48a22d45e0e079d1be993b3a upstream.
ocfs2_block_group_alloc_discontig() disables chain relink by setting
ac->ac_allow_chain_relink = 0 because it grabs clusters from multiple
cluster groups.
It doesn't keep the credits for all chain relink,but
ocfs2_claim_suballoc_bits overrides this in this call trace:
ocfs2_block_group_claim_bits()->ocfs2_claim_clusters()->
__ocfs2_claim_clusters()->ocfs2_claim_suballoc_bits()
ocfs2_claim_suballoc_bits set ac->ac_allow_chain_relink = 1; then call
ocfs2_search_chain() one time and disable it again, and then we run out
of credits.
Fix is to allow relink by default and disable it in
ocfs2_block_group_alloc_discontig.
Without this patch, End-users will run into a crash due to run out of
credits, backtrace like this:
RIP: 0010:[<ffffffffa0808b14>] [<ffffffffa0808b14>]
jbd2_journal_dirty_metadata+0x164/0x170 [jbd2]
RSP: 0018:ffff8801b919b5b8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88022139ddc0 RCX: ffff880159f652d0
RDX: ffff880178aa3000 RSI: ffff880159f652d0 RDI: ffff880087f09bf8
RBP: ffff8801b919b5e8 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000001e00 R11: 00000000000150b0 R12: ffff880159f652d0
R13: ffff8801a0cae908 R14: ffff880087f09bf8 R15: ffff88018d177800
FS: 00007fc9b0b6b6e0(0000) GS:ffff88022fd40000(0000) knlGS:0000000000000000
CR2: 000000000040819c CR3: 0000000184017000 CR4: 00000000000006e0
Process dd (pid: 9945, threadinfo ffff8801b919a000, task ffff880149a264c0)
Call Trace:
ocfs2_journal_dirty+0x2f/0x70 [ocfs2]
ocfs2_relink_block_group+0x111/0x480 [ocfs2]
ocfs2_search_chain+0x455/0x9a0 [ocfs2]
Signed-off-by: Xiaowei.Hu <xiaowei.hu@oracle.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.com>
commit 32918dd9f19e5960af4cdfa41190bb843fb2247b upstream.
We need to re-initialize the security for a new reflinked inode with its
parent dirs if it isn't specified to be preserved for ocfs2_reflink().
However, the code logic is broken at ocfs2_init_security_and_acl()
although ocfs2_init_security_get() succeed. As a result,
ocfs2_acl_init() does not involked and therefore the default ACL of
parent dir was missing on the new inode.
Note this was introduced by 9d8f13ba3 ("security: new
security_inode_init_security API adds function callback")
To reproduce:
set default ACL for the parent dir(ocfs2 in this case):
$ setfacl -m default:user:jeff:rwx ../ocfs2/
$ getfacl ../ocfs2/
# file: ../ocfs2/
# owner: jeff
# group: jeff
user::rwx
group::r-x
other::r-x
default:user::rwx
default:group::r-x
default:mask::rwx
default:other::r-x
$ touch a
$ getfacl a
# file: a
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
Before patching, create reflink file b from a, the user
default ACL entry(user:jeff:rwx)was missing:
$ ./ocfs2_reflink a b
$ getfacl b
# file: b
# owner: jeff
# group: jeff
user::rw-
group::rw-
other::r--
In this case, the end user can also observed an error message at syslog:
(ocfs2_reflink,3229,2):ocfs2_init_security_and_acl:7193 ERROR: status = 0
After applying this patch, create reflink file c from a:
$ ./ocfs2_reflink a c
$ getfacl c
# file: c
# owner: jeff
# group: jeff
user::rw-
user:jeff:rwx #effective:rw-
group::r-x #effective:r--
mask::rw-
other::r--
Test program:
/* Usage: reflink <source> <dest> */
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <errno.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <sys/ioctl.h>
static int
reflink_file(char const *src_name, char const *dst_name,
bool preserve_attrs)
int fd;
#ifndef REFLINK_ATTR_NONE
# define REFLINK_ATTR_NONE 0
#endif
#ifndef REFLINK_ATTR_PRESERVE
# define REFLINK_ATTR_PRESERVE 1
#endif
#ifndef OCFS2_IOC_REFLINK
struct reflink_arguments {
uint64_t old_path;
uint64_t new_path;
uint64_t preserve;
# define OCFS2_IOC_REFLINK _IOW ('o', 4, struct reflink_arguments)
#endif
struct reflink_arguments args = {
.old_path = (unsigned long) src_name,
.new_path = (unsigned long) dst_name,
.preserve = preserve_attrs ? REFLINK_ATTR_PRESERVE :
REFLINK_ATTR_NONE,
fd = open(src_name, O_RDONLY);
if (fd < 0) {
fprintf(stderr, "Failed to open %s: %s\n",
src_name, strerror(errno));
return -1;
if (ioctl(fd, OCFS2_IOC_REFLINK, &args) < 0) {
fprintf(stderr, "Failed to reflink %s to %s: %s\n",
src_name, dst_name, strerror(errno));
return -1;
int
main(int argc, char *argv[])
if (argc != 3) {
fprintf(stdout, "Usage: %s source dest\n", argv[0]);
return 1;
return reflink_file(argv[1], argv[2], 0);
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Reviewed-by: Tao Ma <boyu.mt@taobao.com>
Cc: Mimi Zohar <zohar@linux.vnet.ibm.com>
commit 9b171e0c74ca0549d0610990a862dd895870f04a upstream.
Acked-by: Joel Becker <jlbec@evilplan.org>
commit 8afd500cb52a5d00bab4525dd5a560d199f979b9 upstream.
The last orphan in the dnext list has its dnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the dnext list
and frees it immediately instead ignoring it as a second delete. The
orphan is later freed again by erase_deleted.
This change adds an explicit flag to ubifs_orphan indicating whether
it is pending delete.
Signed-off-by: Adam Thomas <adamthomas1111@gmail.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
commit 2928f0d0c5ebd6c9605c0d98207a44376387c298 upstream.
The last orphan in the cnext list has its cnext set to NULL. Because
of that, ubifs_delete_orphan assumes that it is not on the cnext list
and frees it immediately instead of adding it to the dnext list. The
freed orphan is later modified by write_orph_node.
This can cause various inconsistencies including directory entries
that cannot be removed and this error:
UBIFS error (pid 20685): layout_cnodes: LPT out of space at LEB 14:129009 needing 17, done_ltab 1, done_lsave 1
This is a regression introduced by
"7074e5eb UBIFS: remove invalid reference to list iterator variable".
it is pending commit.
Reviewed-by: Adrian Hunter <adrian.hunter@intel.com>
commit 9b40bc90abd126bcc5da5658059b8e72e285e559 upstream.
It's safe only under namespace_sem or vfsmount_lock; all places
in fs/namespace.c that want mnt->mnt_ns->user_ns actually want to use
current->nsproxy->mnt_ns->user_ns (note the calls of check_mnt() in
there).
commit d2b47cfb26fe06002b8011707baac71a9ae8166f upstream.
This patch allocates a block reservation structure before growing
or shrinking a file. Without this structure, the grow or shink code
can reference the bad pointer.
Signed-off-by: Bob Peterson <rpeterso@redhat.com>
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
commit 085b7a45c63d3da5be155faab9249a5cab224561 upstream.
layoutget's prepare hook can call rpc_exit with status = NFS4_OK (0).
Because of this, nfs4_proc_layoutget can't depend on a 0 status to mean
that the RPC was successfully sent, received and parsed.
To fix this, use the result's len member to see if parsing took place.
This fixes the following OOPS -- calling xdr_init_decode() with a buffer length
0 doesn't set the stream's 'p' member and ends up using uninitialized memory
in filelayout_decode_layout.
BUG: unable to handle kernel paging request at 0000000000008050
IP: [<ffffffff81282e78>] memcpy+0x18/0x120
PGD 0
Oops: 0000 [#1] SMP
last sysfs file: /sys/devices/pci0000:00/0000:00:11.0/0000:02:01.0/irq
CPU 1
Modules linked in: nfs_layout_nfsv41_files nfs lockd fscache auth_rpcgss nfs_acl autofs4 sunrpc ipt_REJECT nf_conntrack_ipv4 nf_defrag_ipv4 iptable_filter ip_tables ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables ipv6 dm_mirror dm_region_hash dm_log dm_mod ppdev parport_pc parport snd_ens1371 snd_rawmidi snd_ac97_codec ac97_bus snd_seq snd_seq_device snd_pcm snd_timer snd soundcore snd_page_alloc e1000 microcode vmware_balloon i2c_piix4 i2c_core sg shpchp ext4 mbcache jbd2 sr_mod cdrom sd_mod crc_t10dif pata_acpi ata_generic ata_piix mptspi mptscsih mptbase scsi_transport_spi [last unloaded: speedstep_lib]
Pid: 1665, comm: flush-0:22 Not tainted 2.6.32-356-test-2 #2 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform
RIP: 0010:[<ffffffff81282e78>] [<ffffffff81282e78>] memcpy+0x18/0x120
RSP: 0018:ffff88003dfab588 EFLAGS: 00010206
RAX: ffff88003dc42000 RBX: ffff88003dfab610 RCX: 0000000000000009
RDX: 000000003f807ff0 RSI: 0000000000008050 RDI: ffff88003dc42000
RBP: ffff88003dfab5b0 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000080 R12: 0000000000000024
R13: ffff88003dc42000 R14: ffff88003f808030 R15: ffff88003dfab6a0
FS: 0000000000000000(0000) GS:ffff880003420000(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000008050 CR3: 000000003bc92000 CR4: 00000000001407e0
Process flush-0:22 (pid: 1665, threadinfo ffff88003dfaa000, task ffff880037f77540)
Stack:
ffffffffa0398ac1 ffff8800397c5940 ffff88003dfab610 ffff88003dfab6a0
<d> ffff88003dfab5d0 ffff88003dfab680 ffffffffa01c150b ffffea0000d82e70
<d> 000000508116713b 0000000000000000 0000000000000000 0000000000000000
Call Trace:
[<ffffffffa0398ac1>] ? xdr_inline_decode+0xb1/0x120 [sunrpc]
[<ffffffffa01c150b>] filelayout_decode_layout+0xeb/0x350 [nfs_layout_nfsv41_files]
[<ffffffffa01c17fc>] filelayout_alloc_lseg+0x8c/0x3c0 [nfs_layout_nfsv41_files]
[<ffffffff8150e6ce>] ? __wait_on_bit+0x7e/0x90
commit fd9a8d7160937f94aad36ac80d7255b4988740ac upstream.
The current code in pnfs_destroy_all_layouts() assumes that removing
the layout from the server->layouts list is sufficient to make it
invisible to other processes. This ignores the fact that most
users access the layout through the nfs_inode->layout...
There is further breakage due to lack of reference counting of the
layouts, meaning that the whole thing Oopses at the drop of a hat.
The code in initiate_bulk_draining() is almost correct, and can be
used as a model for pnfs_destroy_all_layouts(), so move that
code to pnfs.c, and refactor the code to allow us to choose between
a single filesystem bulk recall, and a recall of all layouts.
Also note that initiate_bulk_draining() currently calls iput() while
holding locks. Fix that too.
commit c8da19b9866ea84e9ad1c369393ea95d54ee7845 upstream.
Ensure that if nfs_wait_on_sequence() causes our rpc task to wait for
an NFSv4 state serialisation lock, then we also drop the session slot.
commit 666b3d803a511fbc9bc5e5ea8ce66010cf03ea13 upstream.
Currently, nlmclnt_lock will break out of the for(;;) loop when
the reclaimer wakes up the blocking lock thread by setting
nlm_lck_denied_grace_period. This causes the lock request to fail
with an ENOLCK error.
The intention was always to ensure that we resend the lock request
after the grace period has expired.
Reported-by: Wangyuan Zhang <Wangyuan.Zhang@netapp.com>
commit 5a12cca697aca5dfba42a7d4c3356acc0445a2b0 upstream.
now pnfs client uses block layout, maybe we can remove
blocklayoutdriver first. if we umount later,
it can cause oops in unset_pnfs_layoutdriver.
because nfss->pnfs_curr_ld->clear_layoutdriver is invalid.
reproduce it:
modprobe blocklayoutdriver
mount -t nfs4 -o minorversion=1 pnfsip:/ /mnt/
rmmod blocklayoutdriver
umount /mnt
then you can see following
CPU 0
Pid: 17023, comm: umount.nfs4 Tainted: GF O 3.7.0-rc6-pnfs #1 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform
RIP: 0010:[<ffffffffa04cfe6d>] [<ffffffffa04cfe6d>] unset_pnfs_layoutdriver+0x1d/0x70 [nfsv4]
RSP: 0018:ffff8800022d9e48 EFLAGS: 00010286
RAX: ffffffffa04a1b00 RBX: ffff88000b013800 RCX: 0000000000000001
RDX: ffffffff81ae8ee0 RSI: ffff880001ee94b8 RDI: ffff88000b013800
RBP: ffff8800022d9e58 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff880001ee9400
R13: ffff8800105978c0 R14: 00007fff25846c08 R15: 0000000001bba550
FS: 00007f45ae7f0700(0000) GS:ffff880012c00000(0000) knlGS:0000000000000000
CR2: ffffffffa04a1b38 CR3: 0000000002c0c000 CR4: 00000000000006f0
Process umount.nfs4 (pid: 17023, threadinfo ffff8800022d8000, task ffff880006e48aa0)
Stack:
ffff8800105978c0 ffff88000b013800 ffff8800022d9e78 ffffffffa04cd0ce
ffff8800022d9e78 ffff88000b013800 ffff8800022d9ea8 ffffffffa04755a7
ffff8800022d9ea8 ffff880002f96400 ffff88000b013800 ffff880002f96400
Call Trace:
[<ffffffffa04cd0ce>] nfs4_destroy_server+0x1e/0x30 [nfsv4]
[<ffffffffa04755a7>] nfs_free_server+0xb7/0x150 [nfs]
[<ffffffffa047d4d5>] nfs_kill_super+0x35/0x40 [nfs]
[<ffffffff81178d35>] deactivate_locked_super+0x45/0x70
[<ffffffff8117986a>] deactivate_super+0x4a/0x70
[<ffffffff81193ee2>] mntput_no_expire+0xd2/0x130
[<ffffffff81194d62>] sys_umount+0x72/0xe0
[<ffffffff8154af59>] system_call_fastpath+0x16/0x1b
Code: 06 e1 b8 ea ff ff ff eb 9e 0f 1f 44 00 00 55 48 89 e5 53 48 83 ec 08 66 66 66 66 90 48 8b 87 80 03 00 00 48 89 fb 48 85 c0 74 29 <48> 8b 40 38 48 85 c0 74 02 ff d0 48 8b 03 3e ff 48 04 0f 94 c2
RIP [<ffffffffa04cfe6d>] unset_pnfs_layoutdriver+0x1d/0x70 [nfsv4]
RSP <ffff8800022d9e48>
---[ end trace 29f75aaedda058bf ]---
Signed-off-by: fanchaoting<fanchaoting@cn.fujitsu.com>
commit 3278bb748d2437eb1464765f36429e5d6aa91c38 upstream.
If lockres refresh failed, the super lock will never be released which
will cause some processes on other cluster nodes hung forever.
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
commit 7630b661da330b35dd57b6f5d6d62b386f2dd751 upstream.
We found that bdev->bd_invalidated was left set once revalidate_disk()
is called, which results in page cache flush every time that device is
open.
Specifically, we found this problem in MD block device. Once we resize
a MD device, mdadm --monitor periodically flush all page cache for that
device every 60 or 1000 seconds when it opens the device.
This bug lies since at least 3.2.0 till the latest kernel(3.6.2). Patch
is attached.
The following steps will reproduce the problem.
1. prepair a block device (eg /dev/sdb).
2. create two partitions:
sudo parted /dev/sdb
mklabel gpt
mkpart primary 0% 50%
mkpart primary 50% 100%
3. create a md device.
sudo mdadm -C /dev/md/hoge -l 1 -n 2 -e 1.2 --assume-clean --auto=md --symlink=no /dev/sdb1 /dev/sdb2
4. create file system and mount it
sudo mkfs.ext3 /dev/md/hoge
sudo mkdir /mnt/test
sudo mount /dev/md/hoge /mnt/test
5. try to resize the device
sudo mdadm -G /dev/md/hoge --size=max
6. create a file to fill file cache.
sudo dd if=/dev/urandom of=/mnt/test/data bs=1M count=10
and verify the current status of file by free command.
7. mdadm monitor will open the md device every 1000 seconds and you
will find all file cache on the device are cleared.
The timing can be reduced by the following steps.
a) kill mdadm and restart it with --delay option
/sbin/mdadm --monitor --delay=30 --pid-file /var/run/mdadm/monitor.pid --daemonise --scan --syslog
or open the md device directly.
sudo dd if=/dev/md/hoge of=/dev/null bs=4096 count=1
Signed-off-by: MITSUNARI Shigeo <herumi@nifty.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
commit 676a0675cf9200ac047fb50825f80867b3bb733b upstream.
Running the command:
inotifywait -e unmount /mnt/disk
immediately aborts with a -EINVAL return code. This is however a valid
parameter. This abort occurs only if unmount is the sole event
parameter. If other event parameters are supplied, then the unmount
event wait will work.
The problem was introduced by commit 44b350fc23e ("inotify: Fix mask
checks"). In that commit, it states:
The mask checks in inotify_update_existing_watch() and
inotify_new_watch() are useless because inotify_arg_to_mask()
sets FS_IN_IGNORED and FS_EVENT_ON_CHILD bits anyway.
But instead of removing the useless checks, it did this:
mask = inotify_arg_to_mask(arg);
- if (unlikely(!mask))
+ if (unlikely(!(mask & IN_ALL_EVENTS)))
return -EINVAL;
The problem is that IN_ALL_EVENTS doesn't include IN_UNMOUNT, and other
parts of the code keep IN_UNMOUNT separate from IN_ALL_EVENTS. So the
check should be:
if (unlikely(!(mask & (IN_ALL_EVENTS | IN_UNMOUNT))))
But inotify_arg_to_mask(arg) always sets the IN_UNMOUNT bit in the mask
anyway, so the check is always going to pass and thus should simply be
removed. Also note that inotify_arg_to_mask completely controls what
mask bits get set from arg, there's no way for invalid bits to get
enabled there.
Lets fix it by simply removing the useless broken checks.
Signed-off-by: Jim Somerville <Jim.Somerville@windriver.com>
Cc: Jerome Marchand <jmarchan@redhat.com>
Cc: John McCutchan <john@johnmccutchan.com>
Cc: Robert Love <rlove@rlove.org>
Cc: Eric Paris <eparis@parisplace.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"We've got corner cases for updating i_size that ceph was hitting,
error handling for quotas when we run out of space, a very subtle
snapshot deletion race, a crash while removing devices, and one
deadlock between subvolume creation and the sb_internal code (thanks
lockdep)."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: move d_instantiate outside the transaction during mksubvol
Btrfs: fix EDQUOT handling in btrfs_delalloc_reserve_metadata
Btrfs: fix possible stale data exposure
Btrfs: fix missing i_size update
Btrfs: fix race between snapshot deletion and getting inode
Btrfs: fix missing release of the space/qgroup reservation in start_transaction()
Btrfs: fix wrong sync_writers decrement in btrfs_file_aio_write()
Btrfs: do not merge logged extents if we've removed them from the tree
btrfs: don't try to notify udev about missing devices
Dave Sterba triggered a lockdep complaint about lock ordering
between the sb_internal lock and the cleaner semaphore.
btrfs_lookup_dentry() checks for orphans if we're looking up
the inode for a subvolume, and subvolume creation is triggering
the lookup with a transaction running.
This commit moves the d_instantiate after the transaction closes.
When btrfs_qgroup_reserve returned a failure, we were missing a counter
operation for BTRFS_I(inode)->outstanding_extents++, leading to warning
messages about outstanding extents and space_info->bytes_may_use != 0.
Additionally, the error handling code didn't take into account that we
dropped the inode lock which might require more cleanup.
Luckily, all the cleanup code we need is already there and can be shared
with reserve_metadata_bytes, which is exactly what this patch does.
Reported-by: Lev Vainblat <lev@zadarastorage.com>
Signed-off-by: Jan Schmidt <list.btrfs@jan-o-sch.net>
for-chris into for-linus
We specifically do not update the disk i_size if there are ordered extents
outstanding for any area between the current disk_i_size and our ordered
extent so that we do not expose stale data. The problem is the check we
have only checks if the ordered extent starts at or after the current
disk_i_size, which doesn't take into account an ordered extent that starts
before the current disk_i_size and ends past the disk_i_size. Fix this by
checking if the extent ends past the disk_i_size. Thanks,
If we have an ordered extent before the ordered extent we are currently
completing that is after the current disk_i_size we will put our i_size
update into that ordered extent so that we do not expose stale data. The
problem is that if our disk i_size is updated past the previous ordered
extent we won't update the i_size with the pending i_size update. So check
the pending i_size update and if its above the current disk i_size we need
to go ahead and try to update. Thanks,
While running snapshot testscript created by Mitch and David,
the race between autodefrag and snapshot deletion can lead to
corruption of dead_root list so that we can get crash on
btrfs_clean_old_snapshots().
And besides autodefrag, scrub also does the same thing, ie. read
root first and get inode.
Here is the story(take autodefrag as an example):
(1) when we delete a snapshot or subvolume, it will set its root's
refs to zero and do a iput() on its own inode, and if this inode happens
to be the only active in-meory one in root's inode rbtree, it will add
itself to the global dead_roots list for later cleanup.
(2) after (1), the autodefrag thread may read another inode for defrag
and the inode is just in the deleted snapshot/subvolume, but all of these
are without checking if the root is still valid(refs > 0). So the end up
result is adding the deleted snapshot/subvolume's root to the global
dead_roots list AGAIN.
Fortunately, we already have a srcu lock to avoid the race, ie. subvol_srcu.
So all we need to do is to take the lock to protect 'read root and get inode',
since we synchronize to wait for the rcu grace period before adding something
to the global dead_roots list.
Reported-by: Mitch Harder <mitch.harder@sabayonlinux.org>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
start_transaction()
When we fail to start a transaction, we need to release the reserved free space
and qgroup space, fix it.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Reviewed-by: Jan Schmidt <list.btrfs@jan-o-sch.net>
