commit c88547a8119e3b581318ab65e9b72f27f23e641d upstream.
Commit f5ea1100 ("xfs: add CRCs to dir2/da node blocks") introduced
in 3.10 incorrectly converted the btree hash index array pointer in
xfs_da3_fixhashpath(). It resulted in the the current hash always
being compared against the first entry in the btree rather than the
current block index into the btree block's hash entry array. As a
result, it was comparing the wrong hashes, and so could misorder the
entries in the btree.
For most cases, this doesn't cause any problems as it requires hash
collisions to expose the ordering problem. However, when there are
hash collisions within a directory there is a very good probability
that the entries will be ordered incorrectly and that actually
matters when duplicate hashes are placed into or removed from the
btree block hash entry array.
This bug results in an on-disk directory corruption and that results
in directory verifier functions throwing corruption warnings into
the logs. While no data or directory entries are lost, access to
them may be compromised, and attempts to remove entries from a
directory that has suffered from this corruption may result in a
filesystem shutdown. xfs_repair will fix the directory hash
ordering without data loss occuring.
[dchinner: wrote useful a commit message]
Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Signed-off-by: Mark Tinguely <tinguely@sgi.com>
Reviewed-by: Ben Myers <bpm@sgi.com>
Signed-off-by: Dave Chinner <david@fromorbit.com>
commit 31978b5cc66b8ba8a7e8eef60b12395d41b7b890 upstream.
If we allocate less than sizeof(struct attrlist) then we end up
corrupting memory or doing a ZERO_PTR_SIZE dereference.
This can only be triggered with CAP_SYS_ADMIN.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit f94c44573e7c22860e2c3dfe349c45f72ba35ad3 upstream.
This loop in xfs_growfs_data_private() is incorrect for V4
superblocks filesystems:
for (bucket = 0; bucket < XFS_AGFL_SIZE(mp); bucket++)
agfl->agfl_bno[bucket] = cpu_to_be32(NULLAGBLOCK);
For V4 filesystems, we don't have a agfl header structure, and so
XFS_AGFL_SIZE() returns an entire sector's worth of entries, which
we then index from an offset into the sector. Hence: buffer overrun.
This problem was introduced in 3.10 by commit 77c95bba ("xfs: add
CRC checks to the AGFL") which changed the AGFL structure but failed
to update the growfs code to handle the different structures.
Fix it by using the correct offset into the buffer for both V4 and
V5 filesystems.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Jie Liu <jeff.liu@oracle.com>
commit 8c567a7fab6e086a0284eee2db82348521e7120c upstream.
Check for CAP_SYS_ADMIN since the caller can truncate preallocated
blocks from files they do not own nor have write access to. A more
fine grained access check was considered: require the caller to
specify their own uid/gid and to use inode_permission to check for
write, but this would not catch the case of an inode not reachable
via path traversal from the callers mount namespace.
Add check for read-only filesystem to free eofblocks ioctl.
Reviewed-by: Brian Foster <bfoster@redhat.com>
Reviewed-by: Gao feng <gaofeng@cn.fujitsu.com>
Signed-off-by: Dwight Engen <dwight.engen@oracle.com>
Cc: Kees Cook <keescook@google.com>
commit 997def25e4b9cee3b01609e18a52f926bca8bd2b upstream.
Commit f5ea1100 cleans up the disk to host conversions for
node directory entries, but because a variable is reused in
xfs_node_toosmall() the next node is not correctly found.
If the original node is small enough (<= 3/8 of the node size),
this change may incorrectly cause a node collapse when it should
not. That will cause an assert in xfstest generic/319:
Assertion failed: first <= last && last < BBTOB(bp->b_length),
file: /root/newest/xfs/fs/xfs/xfs_trans_buf.c, line: 569
Keep the original node header to get the correct forward node.
(When a node is considered for a merge with a sibling, it overwrites the
sibling pointers of the original incore nodehdr with the sibling's
pointers. This leads to loop considering the original node as a merge
candidate with itself in the second pass, and so it incorrectly
determines a merge should occur.)
[v3: added Dave Chinner's (slightly modified) suggestion to the commit header,
cleaned up whitespace. -bpm]
Unfortunately, we cannot guarantee that items logged multiple times
and replayed by log recovery do not take objects back in time. When
they are taken back in time, the go into an intermediate state which
is corrupt, and hence verification that occurs on this intermediate
state causes log recovery to abort with a corruption shutdown.
Instead of causing a shutdown and unmountable filesystem, don't
verify post-recovery items before they are written to disk. This is
less than optimal, but there is no way to detect this issue for
non-CRC filesystems If log recovery successfully completes, this
will be undone and the object will be consistent by subsequent
transactions that are replayed, so in most cases we don't need to
take drastic action.
For CRC enabled filesystems, leave the verifiers in place - we need
to call them to recalculate the CRCs on the objects anyway. This
recovery problem can be solved for such filesystems - we have a LSN
stamped in all metadata at writeback time that we can to determine
whether the item should be replayed or not. This is a separate piece
of work, so is not addressed by this patch.
(cherry picked from commit 9222a9cf86c0d64ffbedf567412b55da18763aa3)
For CRC enabled filesystems, the BMBT is rooted in an inode, so it
passes through a different code path on root splits than the
freespace and inode btrees. This is much less traversed by xfstests
than the other trees. When testing on a 1k block size filesystem,
I've been seeing ASSERT failures in generic/234 like:
XFS: Assertion failed: cur->bc_btnum != XFS_BTNUM_BMAP || cur->bc_private.b.allocated == 0, file: fs/xfs/xfs_btree.c, line: 317
which are generally preceded by a lblock check failure. I noticed
this in the bmbt stats:
$ pminfo -f xfs.btree.block_map
xfs.btree.block_map.lookup
value 39135
xfs.btree.block_map.compare
value 268432
xfs.btree.block_map.insrec
value 15786
xfs.btree.block_map.delrec
value 13884
xfs.btree.block_map.newroot
value 2
xfs.btree.block_map.killroot
value 0
Very little coverage of root splits and merges. Indeed, on a 4k
filesystem, block_map.newroot and block_map.killroot are both zero.
i.e. the code is not exercised at all, and it's the only generic
btree infrastructure operation that is not exercised by a default run
of xfstests.
Turns out that on a 1k filesystem, generic/234 accounts for one of
those two root splits, and that is somewhat of a smoking gun. In
fact, it's the same problem we saw in the directory/attr code where
headers are memcpy()d from one block to another without updating the
self describing metadata.
Simple fix - when copying the header out of the root block, make
sure the block number is updated correctly.
(cherry picked from commit ade1335afef556df6538eb02e8c0dc91fbd9cc37)
Michael L. Semon has been testing CRC patches on a 32 bit system and
been seeing assert failures in the directory code from xfs/080.
Thanks to Michael's heroic efforts with printk debugging, we found
that the problem was that the last free space being left in the
directory structure was too small to fit a unused tag structure and
it was being corrupted and attempting to log a region out of bounds.
Hence the assert failure looked something like:
#5 calling xfs_dir2_data_log_unused() 36 32
#1 4092 4095 4096
#2 8182 8183 4096
XFS: Assertion failed: first <= last && last < BBTOB(bp->b_length), file: fs/xfs/xfs_trans_buf.c, line: 568
Where #1 showed the first region of the dup being logged (i.e. the
last 4 bytes of a directory buffer) and #2 shows the corrupt values
being calculated from the length of the dup entry which overflowed
the size of the buffer.
It turns out that the problem was not in the logging code, nor in
the freespace handling code. It is an initial condition bug that
only shows up on 32 bit systems. When a new buffer is initialised,
where's the freespace that is set up:
[ 172.316249] calling xfs_dir2_leaf_addname() from xfs_dir_createname()
[ 172.316346] #9 calling xfs_dir2_data_log_unused()
[ 172.316351] #1 calling xfs_trans_log_buf() 60 63 4096
[ 172.316353] #2 calling xfs_trans_log_buf() 4094 4095 4096
Note the offset of the first region being logged? It's 60 bytes into
the buffer. Once I saw that, I pretty much knew that the bug was
going to be caused by this.
Essentially, all direct entries are rounded to 8 bytes in length,
and all entries start with an 8 byte alignment. This means that we
can decode inplace as variables are naturally aligned. With the
directory data supposedly starting on a 8 byte boundary, and all
entries padded to 8 bytes, the minimum freespace in a directory
block is supposed to be 8 bytes, which is large enough to fit a
unused data entry structure (6 bytes in size). The fact we only have
4 bytes of free space indicates a directory data block alignment
problem.
And what do you know - there's an implicit hole in the directory
data block header for the CRC format, which means the header is 60
byte on 32 bit intel systems and 64 bytes on 64 bit systems. Needs
padding. And while looking at the structures, I found the same
problem in the attr leaf header. Fix them both.
Note that this only affects 32 bit systems with CRCs enabled.
Everything else is just fine. Note that CRC enabled filesystems created
before this fix on such systems will not be readable with this fix
applied.
Reported-by: Michael L. Semon <mlsemon35@gmail.com>
Debugged-by: Michael L. Semon <mlsemon35@gmail.com>
(cherry picked from commit 8a1fd2950e1fe267e11fc8c85dcaa6b023b51b60)
We write the superblock every 30s or so which results in the
verifier being called. Right now that results in this output
every 30s:
XFS (vda): Version 5 superblock detected. This kernel has EXPERIMENTAL support enabled!
Use of these features in this kernel is at your own risk!
And spamming the logs.
We don't need to check for whether we support v5 superblocks or
whether there are feature bits we don't support set as these are
only relevant when we first mount the filesytem. i.e. on superblock
read. Hence for the write verification we can just skip all the
checks (and hence verbose output) altogether.
(cherry picked from commit 34510185abeaa5be9b178a41c0a03d30aec3db7e)
The limit of 25 ACL entries is arbitrary, but baked into the on-disk
format. For version 5 superblocks, increase it to the maximum nuber
of ACLs that can fit into a single xattr.
Reviewed-by: Mark Tinguely <tinuguely@sgi.com>
(cherry picked from commit 5c87d4bc1a86bd6e6754ac3d6e111d776ddcfe57)
attr2 format is always enabled for v5 superblock filesystems, so the
mount options to enable or disable it need to be cause mount errors.
(cherry picked from commit d3eaace84e40bf946129e516dcbd617173c1cf14)
The inode unlinked list manipulations operate directly on the inode
buffer, and so bypass the inode CRC calculation mechanisms. Hence an
inode on the unlinked list has an invalid CRC. Fix this by
recalculating the CRC whenever we modify an unlinked list pointer in
an inode, ncluding during log recovery. This is trivial to do and
results in unlinked list operations always leaving a consistent
inode in the buffer.
Reviewed-by: Mark Tinguely <tinguely@sgi.com>
(cherry picked from commit 0a32c26e720a8b38971d0685976f4a7d63f9e2ef)
There are several constraints that inode allocation and unlink
logging impose on log recovery. These all stem from the fact that
inode alloc/unlink are logged in buffers, but all other inode
changes are logged in inode items. Hence there are ordering
constraints that recovery must follow to ensure the correct result
occurs.
As it turns out, this ordering has been working mostly by chance
than good management. The existing code moves all buffers except
cancelled buffers to the head of the list, and everything else to
the tail of the list. The problem with this is that is interleaves
inode items with the buffer cancellation items, and hence whether
the inode item in an cancelled buffer gets replayed is essentially
left to chance.
Further, this ordering causes problems for log recovery when inode
CRCs are enabled. It typically replays the inode unlink buffer long before
it replays the inode core changes, and so the CRC recorded in an
unlink buffer is going to be invalid and hence any attempt to
validate the inode in the buffer is going to fail. Hence we really
need to enforce the ordering that the inode alloc/unlink code has
expected log recovery to have since inode chunk de-allocation was
introduced back in 2003...
(cherry picked from commit a775ad778073d55744ed6709ccede36310638911)
When invalidating an attribute leaf block block, there might be
remote attributes that it points to. With the recent rework of the
remote attribute format, we have to make sure we calculate the
length of the attribute correctly. We aren't doing that in
xfs_attr3_leaf_inactive(), so fix it.
(cherry picked from commit 59913f14dfe8eb772ff93eb442947451b4416329)
Calculating dquot CRCs when the backing buffer is written back just
doesn't work reliably. There are several places which manipulate
dquots directly in the buffers, and they don't calculate CRCs
appropriately, nor do they always set the buffer up to calculate
CRCs appropriately.
Firstly, if we log a dquot buffer (e.g. during allocation) it gets
logged without valid CRC, and so on recovery we end up with a dquot
that is not valid.
Secondly, if we recover/repair a dquot, we don't have a verifier
attached to the buffer and hence CRCs are not calculated on the way
down to disk.
Thirdly, calculating the CRC after we've changed the contents means
that if we re-read the dquot from the buffer, we cannot verify the
contents of the dquot are valid, as the CRC is invalid.
So, to avoid all the dquot CRC errors that are being detected by the
read verifier, change to using the same model as for inodes. That
is, dquot CRCs are calculated and written to the backing buffer at
the time the dquot is flushed to the backing buffer. If we modify
the dquot directly in the backing buffer, calculate the CRC
immediately after the modification is complete. Hence the dquot in
the on-disk buffer should always have a valid CRC.
(cherry picked from commit 6fcdc59de28817d1fbf1bd58cc01f4f3fac858fb)
Note: this changes the on-disk remote attribute format. I assert
that this is OK to do as CRCs are marked experimental and the first
kernel it is included in has not yet reached release yet. Further,
the userspace utilities are still evolving and so anyone using this
stuff right now is a developer or tester using volatile filesystems
for testing this feature. Hence changing the format right now to
save longer term pain is the right thing to do.
The fundamental change is to move from a header per extent in the
attribute to a header per filesytem block in the attribute. This
means there are more header blocks and the parsing of the attribute
data is slightly more complex, but it has the advantage that we
always know the size of the attribute on disk based on the length of
the data it contains.
This is where the header-per-extent method has problems. We don't
know the size of the attribute on disk without first knowing how
many extents are used to hold it. And we can't tell from a
mapping lookup, either, because remote attributes can be allocated
contiguously with other attribute blocks and so there is no obvious
way of determining the actual size of the atribute on disk short of
walking and mapping buffers.
The problem with this approach is that if we map a buffer
incorrectly (e.g. we make the last buffer for the attribute data too
long), we then get buffer cache lookup failure when we map it
correctly. i.e. we get a size mismatch on lookup. This is not
necessarily fatal, but it's a cache coherency problem that can lead
to returning the wrong data to userspace or writing the wrong data
to disk. And debug kernels will assert fail if this occurs.
I found lots of niggly little problems trying to fix this issue on a
4k block size filesystem, finally getting it to pass with lots of
fixes. The thing is, 1024 byte filesystems still failed, and it was
getting really complex handling all the corner cases that were
showing up. And there were clearly more that I hadn't found yet.
It is complex, fragile code, and if we don't fix it now, it will be
complex, fragile code forever more.
Hence the simple fix is to add a header to each filesystem block.
This gives us the same relationship between the attribute data
length and the number of blocks on disk as we have without CRCs -
it's a linear mapping and doesn't require us to guess anything. It
is simple to implement, too - the remote block count calculated at
lookup time can be used by the remote attribute set/get/remove code
without modification for both CRC and non-CRC filesystems. The world
becomes sane again.
Because the copy-in and copy-out now need to iterate over each
filesystem block, I moved them into helper functions so we separate
the block mapping and buffer manupulations from the attribute data
and CRC header manipulations. The code becomes much clearer as a
result, and it is a lot easier to understand and debug. It also
appears to be much more robust - once it worked on 4k block size
filesystems, it has worked without failure on 1k block size
filesystems, too.
(cherry picked from commit ad1858d77771172e08016890f0eb2faedec3ecee)
xfs_attr3_leaf_compact() uses a temporary buffer for compacting the
the entries in a leaf. It copies the the original buffer into the
temporary buffer, then zeros the original buffer completely. It then
copies the entries back into the original buffer. However, the
original buffer has not been correctly initialised, and so the
movement of the entries goes horribly wrong.
Make sure the zeroed destination buffer is fully initialised, and
once we've set up the destination incore header appropriately, write
is back to the buffer before starting to move entries around.
While debugging this, the _d/_s prefixes weren't sufficient to
remind me what buffer was what, so rename then all _src/_dst.
(cherry picked from commit d4c712bcf26a25c2b67c90e44e0b74c7993b5334)
xfs_attr3_leaf_unbalance() uses a temporary buffer for recombining
the entries in two leaves when the destination leaf requires
compaction. The temporary buffer ends up being copied back over the
original destination buffer, so the header in the temporary buffer
needs to contain all the information that is in the destination
buffer.
To make sure the temporary buffer is fully initialised, once we've
set up the temporary incore header appropriately, write is back to
the temporary buffer before starting to move entries around.
(cherry picked from commit 8517de2a81da830f5d90da66b4799f4040c76dc9)
If we don't map the buffers correctly (same as for get/set
operations) then the incore buffer lookup will fail. If a block
number matches but a length is wrong, then debug kernels will ASSERT
fail in _xfs_buf_find() due to the length mismatch. Ensure that we
map the buffers correctly by basing the length of the buffer on the
attribute data length rather than the remote block count.
(cherry picked from commit 6863ef8449f1908c19f43db572e4474f24a1e9da)
When an attribute data does not fill then entire remote block, we
zero the remaining part of the buffer. This, however, needs to take
into account that the buffer has a header, and so the offset where
zeroing starts and the length of zeroing need to take this into
account. Otherwise we end up with zeros over the end of the
attribute value when CRCs are enabled.
While there, make sure we only ask to map an extent that covers the
remaining range of the attribute, rather than asking every time for
the full length of remote data. If the remote attribute blocks are
contiguous with other parts of the attribute tree, it will map those
blocks as well and we can potentially zero them incorrectly. We can
also get buffer size mistmatches when trying to read or remove the
remote attribute, and this can lead to not finding the correct
buffer when looking it up in cache.
(cherry picked from commit 4af3644c9a53eb2f1ecf69cc53576561b64be4c6)
Reading a maximally size remote attribute fails when CRCs are
enabled with this verification error:
XFS (vdb): remote attribute header does not match required off/len/owner)
There are two reasons for this, the first being that the
length of the buffer being read is determined from the
args->rmtblkcnt which doesn't take into account CRC headers. Hence
the mapped length ends up being too short and so we need to
calculate it directly from the value length.
The second is that the byte count of valid data within a buffer is
capped by the length of the data and so doesn't take into account
that the buffer might be longer due to headers. Hence we need to
calculate the data space in the buffer first before calculating the
actual byte count of data.
(cherry picked from commit 913e96bc292e1bb248854686c79d6545ef3ee720)
When CRCs are enabled, there may be multiple allocations made if the
headers cause a length overflow. This, however, does not mean that
the number of headers required increases, as the second and
subsequent extents may be contiguous with the previous extent. Hence
when we map the extents to write the attribute data, we may end up
with less extents than allocations made. Hence the assertion that we
consume the number of headers we calculated in the allocation loop
is incorrect and needs to be removed.
(cherry picked from commit 90253cf142469a40f89f989904abf0a1e500e1a6)
When the directory freespace index grows to a second block (2017
4k data blocks in the directory), the initialisation of the second
new block header goes wrong. The write verifier fires a corruption
error indicating that the block number in the header is zero. This
was being tripped by xfs/110.
The problem is that the initialisation of the new block is done just
fine in xfs_dir3_free_get_buf(), but the caller then users a dirv2
structure to zero on-disk header fields that xfs_dir3_free_get_buf()
has already zeroed. These lined up with the block number in the dir
v3 header format.
While looking at this, I noticed that the struct xfs_dir3_free_hdr()
had 4 bytes of padding in it that wasn't defined as padding or being
zeroed by the initialisation. Add a pad field declaration and fully
zero the on disk and in-core headers in xfs_dir3_free_get_buf() so
that this is never an issue in the future. Note that this doesn't
change the on-disk layout, just makes the 32 bits of padding in the
layout explicit.
(cherry picked from commit 5ae6e6a401957698f2bd8c9f4a86d86d02199fea)
Currently, swapping extents from one inode to another is a simple
act of switching data and attribute forks from one inode to another.
This, unfortunately in no longer so simple with CRC enabled
filesystems as there is owner information embedded into the BMBT
blocks that are swapped between inodes. Hence swapping the forks
between inodes results in the inodes having mapping blocks that
point to the wrong owner and hence are considered corrupt.
To fix this we need an extent tree block or record based swap
algorithm so that the BMBT block owner information can be updated
atomically in the swap transaction. This is a significant piece of
new work, so for the moment simply don't allow swap extent
operations to succeed on CRC enabled filesystems.
(cherry picked from commit 02f75405a75eadfb072609f6bf839e027de6a29a)
Currently userspace has no way of determining that a filesystem is
CRC enabled. Add a flag to the XFS_IOC_FSGEOMETRY ioctl output to
indicate that the filesystem has v5 superblock support enabled.
This will allow xfs_info to correctly report the state of the
filesystem.
Reviewed-by: Eric Sandeen <sandeen@redhat.com>
(cherry picked from commit 74137fff067961c9aca1e14d073805c3de8549bd)
When CRCs are enabled, the number of blocks needed to hold a remote
symlink on a 1k block size filesystem may be 2 instead of 1. The
transaction reservation for the allocated blocks was not taking this
into account and only allocating one block. Hence when trying to
read or invalidate such symlinks, we are mapping a hole where there
should be a block and things go bad at that point.
Fix the reservation to use the correct block count, clean up the
block count calculation similar to the remote attribute calculation,
and add a debug guard to detect when we don't write the entire
symlink to disk.
(cherry picked from commit 321a95839e65db3759a07a3655184b0283af90fe)
A long time ago in a galaxy far away....
.. the was a commit made to fix some ilinux specific "fragmented
buffer" log recovery problem:
http://oss.sgi.com/cgi-bin/gitweb.cgi?p=archive/xfs-import.git;a=commitdiff;h=b29c0bece51da72fb3ff3b61391a391ea54e1603
That problem occurred when a contiguous dirty region of a buffer was
split across across two pages of an unmapped buffer. It's been a
long time since that has been done in XFS, and the changes to log
the entire inode buffers for CRC enabled filesystems has
re-introduced that corner case.
And, of course, it turns out that the above commit didn't actually
fix anything - it just ensured that log recovery is guaranteed to
fail when this situation occurs. And now for the gory details.
xfstest xfs/085 is failing with this assert:
XFS (vdb): bad number of regions (0) in inode log format
XFS: Assertion failed: 0, file: fs/xfs/xfs_log_recover.c, line: 1583
Largely undocumented factoid #1: Log recovery depends on all log
buffer format items starting with this format:
struct foo_log_format {
__uint16_t type;
__uint16_t size;
As recoery uses the size field and assumptions about 32 bit
alignment in decoding format items. So don't pay much attention to
the fact log recovery thinks that it decoding an inode log format
item - it just uses them to determine what the size of the item is.
But why would it see a log format item with a zero size? Well,
luckily enough xfs_logprint uses the same code and gives the same
error, so with a bit of gdb magic, it turns out that it isn't a log
format that is being decoded. What logprint tells us is this:
Oper (130): tid: a0375e1a len: 28 clientid: TRANS flags: none
BUF: #regs: 2 start blkno: 144 (0x90) len: 16 bmap size: 2 flags: 0x4000
Oper (131): tid: a0375e1a len: 4096 clientid: TRANS flags: none
BUF DATA
Oper (132): tid: a0375e1a len: 4096 clientid: TRANS flags: none
xfs_logprint: unknown log operation type (4e49)
* ERROR: data block=2 *
That we've got a buffer format item (oper 130) that has two regions;
the format item itself and one dirty region. The subsequent region
after the buffer format item and it's data is them what we are
tripping over, and the first bytes of it at an inode magic number.
Not a log opheader like there is supposed to be.
That means there's a problem with the buffer format item. It's dirty
data region is 4096 bytes, and it contains - you guessed it -
initialised inodes. But inode buffers are 8k, not 4k, and we log
them in their entirety. So something is wrong here. The buffer
format item contains:
(gdb) p /x *(struct xfs_buf_log_format *)in_f
$22 = {blf_type = 0x123c, blf_size = 0x2, blf_flags = 0x4000,
blf_len = 0x10, blf_blkno = 0x90, blf_map_size = 0x2,
blf_data_map = {0xffffffff, 0xffffffff, .... }}
Two regions, and a signle dirty contiguous region of 64 bits. 64 *
128 = 8k, so this should be followed by a single 8k region of data.
And the blf_flags tell us that the type of buffer is a
XFS_BLFT_DINO_BUF. It contains inodes. And because it doesn't have
the XFS_BLF_INODE_BUF flag set, that means it's an inode allocation
buffer. So, it should be followed by 8k of inode data.
But we know that the next region has a header of:
(gdb) p /x *ohead
$25 = {oh_tid = 0x1a5e37a0, oh_len = 0x100000, oh_clientid = 0x69,
oh_flags = 0x0, oh_res2 = 0x0}
and so be32_to_cpu(oh_len) = 0x1000 = 4096 bytes. It's simply not
long enough to hold all the logged data. There must be another
region. There is - there's a following opheader for another 4k of
data that contains the other half of the inode cluster data - the
one we assert fail on because it's not a log format header.
So why is the second part of the data not being accounted to the
correct buffer log format structure? It took a little more work with
gdb to work out that the buffer log format structure was both
expecting it to be there but hadn't accounted for it. It was at that
point I went to the kernel code, as clearly this wasn't a bug in
xfs_logprint and the kernel was writing bad stuff to the log.
First port of call was the buffer item formatting code, and the
discontiguous memory/contiguous dirty region handling code
immediately stood out. I've wondered for a long time why the code
had this comment in it:
vecp->i_addr = xfs_buf_offset(bp, buffer_offset);
vecp->i_len = nbits * XFS_BLF_CHUNK;
vecp->i_type = XLOG_REG_TYPE_BCHUNK;
* You would think we need to bump the nvecs here too, but we do not
* this number is used by recovery, and it gets confused by the boundary
* split here
* nvecs++;
vecp++;
And it didn't account for the extra vector pointer. The case being
handled here is that a contiguous dirty region lies across a
boundary that cannot be memcpy()d across, and so has to be split
into two separate operations for xlog_write() to perform.
What this code assumes is that what is written to the log is two
consecutive blocks of data that are accounted in the buf log format
item as the same contiguous dirty region and so will get decoded as
such by the log recovery code.
The thing is, xlog_write() knows nothing about this, and so just
does it's normal thing of adding an opheader for each vector. That
means the 8k region gets written to the log as two separate regions
of 4k each, but because nvecs has not been incremented, the buf log
format item accounts for only one of them.
Hence when we come to log recovery, we process the first 4k region
and then expect to come across a new item that starts with a log
format structure of some kind that tells us whenteh next data is
going to be. Instead, we hit raw buffer data and things go bad real
quick.
So, the commit from 2002 that commented out nvecs++ is just plain
wrong. It breaks log recovery completely, and it would seem the only
reason this hasn't been since then is that we don't log large
contigous regions of multi-page unmapped buffers very often. Never
would be a closer estimate, at least until the CRC code came along....
So, lets fix that by restoring the nvecs accounting for the extra
region when we hit this case.....
.... and there's the problemin log recovery it is apparently working
around:
XFS: Assertion failed: i == item->ri_total, file: fs/xfs/xfs_log_recover.c, line: 2135
Yup, xlog_recover_do_reg_buffer() doesn't handle contigous dirty
regions being broken up into multiple regions by the log formatting
code. That's an easy fix, though - if the number of contiguous dirty
bits exceeds the length of the region being copied out of the log,
only account for the number of dirty bits that region covers, and
then loop again and copy more from the next region. It's a 2 line
fix.
Now xfstests xfs/085 passes, we have one less piece of mystery
code, and one more important piece of knowledge about how to
structure new log format items..
(cherry picked from commit 709da6a61aaf12181a8eea8443919ae5fc1b731d)
XFS has failed to kill suid/sgid bits correctly when truncating
files of non-zero size since commit c4ed4243 ("xfs: split
xfs_setattr") introduced in the 3.1 kernel. Fix it.
Fix it.
cc: stable kernel <stable@vger.kernel.org>
(cherry picked from commit 56c19e89b38618390addfc743d822f99519055c6)
Lockdep reports:
[ INFO: possible recursive locking detected ]
3.9.0+ #3 Not tainted
setquota/28368 is trying to acquire lock:
(sb_internal){++++.?}, at: [<c11e8846>] xfs_trans_alloc+0x26/0x50
but task is already holding lock:
from xfs_qm_scall_setqlim()->xfs_dqread() when a dquot needs to be
allocated.
xfs_qm_scall_setqlim() is starting a transaction and then not
passing it into xfs_qm_dqet() and so it starts it's own transaction
when allocating the dquot. Splat!
Fix this by not allocating the dquot in xfs_qm_scall_setqlim()
inside the setqlim transaction. This requires getting the dquot
first (and allocating it if necessary) then dropping and relocking
the dquot before joining it to the setqlim transaction.
(cherry picked from commit f648167f3ac79018c210112508c732ea9bf67c7b)
When reading a remote attribute, to correctly calculate the length
of the data buffer for CRC enable filesystems, we need to know the
length of the attribute data. We get this information when we look
up the attribute, but we don't store it in the args structure along
with the other remote attr information we get from the lookup. Add
this information to the args structure so we can use it
appropriately.
(cherry picked from commit e461fcb194172b3f709e0b478d2ac1bdac7ab9a3)
xfstests generic/117 fails with:
XFS: Assertion failed: leaf->hdr.info.magic == cpu_to_be16(XFS_ATTR_LEAF_MAGIC)
indicating a function that does not handle the attr3 format
correctly. Fix it.
(cherry picked from commit b38958d715316031fe9ea0cc6c22043072a55f49)
(cherry picked from commit 72916fb8cbcf0c2928f56cdc2fbe8c7bf5517758)
There are several places where we use KM_SLEEP allocation contexts
and use the fact that they are called from transaction context to
add KM_NOFS where appropriate. Unfortunately, there are several
places where the code makes this assumption but can be called from
outside transaction context but with filesystem locks held. These
places need explicit KM_NOFS annotations to avoid lockdep
complaining about reclaim contexts.
(cherry picked from commit ac14876cf9255175bf3bdad645bf8aa2b8fb2d7c)
Checking the EFI for whether it is being released from recovery
after we've already released the known active reference is a mistake
worthy of a brown paper bag. Fix the (now) obvious use after free
that it can cause.
Reported-by: Dave Jones <davej@redhat.com>
(cherry picked from commit 52c24ad39ff02d7bd73c92eb0c926fb44984a41d)
The offset passed into xfs_free_file_space() needs to be rounded
down to a certain size, but the rounding mask is built by a 32 bit
variable. Hence the mask will always mask off the upper 32 bits of
the offset and lead to incorrect writeback and invalidation ranges.
This is not actually exposed as a bug because we writeback and
invalidate from the rounded offset to the end of the file, and hence
the offset we are actually punching a hole out of will always be
covered by the code. This needs fixing, however, if we ever want to
use exact ranges for writeback/invalidation here...
(cherry picked from commit 28ca489c63e9aceed8801d2f82d731b3c9aa50f5)
FSX on 512 byte block size filesystems has been failing for some
time with corrupted data. The fault dates back to the change in
the writeback data integrity algorithm that uses a mark-and-sweep
approach to avoid data writeback livelocks.
Unfortunately, a side effect of this mark-and-sweep approach is that
each page will only be written once for a data integrity sync, and
there is a condition in writeback in XFS where a page may require
two writeback attempts to be fully written. As a result of the high
level change, we now only get a partial page writeback during the
integrity sync because the first pass through writeback clears the
mark left on the page index to tell writeback that the page needs
writeback....
The cause is writing a partial page in the clustering code. This can
happen when a mapping boundary falls in the middle of a page - we
end up writing back the first part of the page that the mapping
covers, but then never revisit the page to have the remainder mapped
and written.
The fix is simple - if the mapping boundary falls inside a page,
then simple abort clustering without touching the page. This means
that the next ->writepage entry that write_cache_pages() will make
is the page we aborted on, and xfs_vm_writepage() will map all
sections of the page correctly. This behaviour is also optimal for
non-data integrity writes, as it results in contiguous sequential
writeback of the file rather than missing small holes and having to
write them a "random" writes in a future pass.
With this fix, all the fsx tests in xfstests now pass on a 512 byte
block size filesystem on a 4k page machine.
(cherry picked from commit 49b137cbbcc836ef231866c137d24f42c42bb483)
Pull xfs update (#2) from Ben Myers:
- add CONFIG_XFS_WARN, a step between zero debugging and
CONFIG_XFS_DEBUG.
- fix attrmulti and attrlist to fall back to vmalloc when kmalloc
fails.
* tag 'for-linus-v3.10-rc1-2' of git://oss.sgi.com/xfs/xfs:
xfs: fallback to vmalloc for large buffers in xfs_compat_attrlist_by_handle
xfs: fallback to vmalloc for large buffers in xfs_attrlist_by_handle
xfs: introduce CONFIG_XFS_WARN
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
Shamelessly copied from dchinner's:
ad650f5b xfs: fallback to vmalloc for large buffers in xfs_attrmulti_attr_get
xfsdump uses a large buffer for extended attributes, which has a
kmalloc'd shadow buffer in the kernel. This can fail after the
system has been running for some time as it is a high order
allocation. Add a fallback to vmalloc so that it doesn't require
contiguous memory and so won't randomly fail while xfsdump is
running.
This was done for xfs_attrlist_by_handle but
xfs_compat_attrlist_by_handle (the 32-bit version) needs the same
attention.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
xfsdump uses for a large buffer for extended attributes, which has a
running.
Running a CONFIG_XFS_DEBUG kernel in production environments is not
the best idea as it introduces significant overhead, can change
the behaviour of algorithms (such as allocation) to improve test
coverage, and (most importantly) panic the machine on non-fatal
errors.
There are many cases where all we want to do is run a
kernel with more bounds checking enabled, such as is provided by the
ASSERT() statements throughout the code, but without all the
potential overhead and drawbacks.
This patch converts all the ASSERT statements to evaluate as
WARN_ON(1) statements and hence if they fail dump a warning and a
stack trace to the log. This has minimal overhead and does not
change any algorithms, and will allow us to find strange "out of
bounds" problems more easily on production machines.
There are a few places where assert statements contain debug only
code. These are converted to be debug-or-warn only code so that we
still get all the assert checks in the code.
Pull xfs update from Ben Myers:
"For 3.10-rc1 we have a number of bug fixes and cleanups and a
currently experimental feature from David Chinner, CRCs protection for
metadata. CRCs are enabled by using mkfs.xfs to create a filesystem
with the feature bits set.
- numerous fixes for speculative preallocation
- don't verify buffers on IO errors
- rename of random32 to prandom32
- refactoring/rearrangement in xfs_bmap.c
- removal of unused m_inode_shrink in struct xfs_mount
- fix error handling of xfs_bufs and readahead
- quota driven preallocation throttling
- fix WARN_ON in xfs_vm_releasepage
- add ratelimited printk for different alert levels
- fix spurious forced shutdowns due to freed Extent Free Intents
- remove some obsolete XLOG_CIL_HARD_SPACE_LIMIT() macros
- remove some obsoleted comments
- (experimental) CRC support for metadata"
* tag 'for-linus-v3.10-rc1' of git://oss.sgi.com/xfs/xfs: (46 commits)
xfs: fix da node magic number mismatches
xfs: Remote attr validation fixes and optimisations
xfs: Teach dquot recovery about CONFIG_XFS_QUOTA
xfs: add metadata CRC documentation
xfs: implement extended feature masks
xfs: add CRC checks to the superblock
xfs: buffer type overruns blf_flags field
xfs: add buffer types to directory and attribute buffers
xfs: add CRC protection to remote attributes
xfs: split remote attribute code out
xfs: add CRCs to attr leaf blocks
xfs: shortform directory offsets change for dir3 format
xfs: add CRC checking to dir2 leaf blocks
xfs: add CRC checking to dir2 data blocks
xfs: add CRC checking to dir2 free blocks
xfs: add CRC checks to block format directory blocks
xfs: add CRC checks to remote symlinks
xfs: split out symlink code into it's own file.
xfs: add version 3 inode format with CRCs
- optimise the calcuation for the number of blocks in a remote
xattr.
- check attribute length against MAX_XATTR_SIZE, not MAXPATHLEN
- whitespace fixes
Fix a build error when CONFIG_XFS_QUOTA=n:
fs/built-in.o: In function `xlog_recovery_validate_buf_type':
/home/dave/src/build/x86-64/xfsdev/fs/xfs/xfs_log_recover.c:1948: undefined
reference to `xfs_dquot_buf_ops'
The version 5 superblock has extended feature masks for compatible,
incompatible and read-only compatible feature sets. Implement the
masking and mount-time checking for these feature masks.
With the addition of CRCs, there is such a wide and varied change to
the on disk format that it makes sense to bump the superblock
version number rather than try to use feature bits for all the new
functionality.
This commit introduces all the new superblock fields needed for all
the new functionality: feature masks similar to ext4, separate
project quota inodes, a LSN field for recovery and the CRC field.
This commit does not bump the superblock version number, however.
That will be done as a separate commit at the end of the series
after all the new functionality is present so we switch it all on in
one commit. This means that we can slowly introduce the changes
without them being active and hence maintain bisectability of the
tree.
This patch is based on a patch originally written by myself back
from SGI days, which was subsequently modified by Christoph Hellwig.
There is relatively little of that patch remaining, but the history
of the patch still should be acknowledged here.
The buffer type passed to log recvoery in the buffer log item
overruns the blf_flags field. I had assumed that flags field was a
32 bit value, and it turns out it is a unisgned short. Therefore
having 19 flags doesn't really work.
Convert the buffer type field to numeric value, and use the top 5
bits of the flags field for it. We currently have 17 types of
buffers, so using 5 bits gives us plenty of room for expansion in
future....
Add buffer types to the buffer log items so that log recovery can
validate the buffers and calculate CRCs correctly after the buffers
are recovered.
There are two ways of doing this - the first is to add a CRC to the
remote attribute entry in the attribute block. The second is to
treat them similar to the remote symlink, where each fragment has
it's own header and identifies fragment location in the attribute.
The problem with the CRC in the remote attr entry is that we cannot
identify the owner of the metadata from the metadata blocks
themselves, or where the blocks fit into the remote attribute. The
down side to this approach is that we never know when the attribute
has been read from disk or not and so we have to verify it every
time it is read, and we must calculate it during the create
transaction and log it. We do not log CRCs for any other metadata,
and so this creates a unique set of coherency problems that, in
general, are best avoided.
Adding an identifying header to each allocated block allows us to
identify each fragment and where in the attribute it is located. It
enables us to rebuild the remote attribute from just the raw blocks
containing the attribute. It also provides us to do per-block CRCs
verification at IO time rather than during the transaction context
that creates it or every time it is read into a user buffer. Hence
it avoids all the problems that an external, logged CRC has, and
provides all the benefits of self identifying metadata.
The only complexity is that we have to add a header per fragment,
and we don't know how many fragments will be needed prior to
allocations. If we take the symlink example, the header is 56 bytes
and hence for a 4k block size filesystem, in the worst case 16
headers requires 1 extra block for the 64k attribute data. For 512
byte filesystems the worst case is an extra block for every 9
fragments (i.e. 16 extra blocks in the worse case). This will be
very rare and so it's not really a major concern.
Because allocation is done in two steps - the first finds a hole
large enough in the attribute file, the second does the allocation -
we only need to find a hole big enough for a worst case allocation.
We only need to allocate enough extra blocks for number of headers
required by the fragments, and we can calculate that as we go....
Hence it really only makes sense to use the same model as for
symlinks - it doesn't add that much complexity, does not require an
attribute tree format change, and does not require logging
calculated CRC values.
