pipe_iov_copy_{from,to}_user() may be tried twice with the same iovec,
the first time atomically and the second time not. The second attempt
needs to continue from the iovec position, pipe buffer offset and
remaining length where the first attempt failed, but currently the
pipe buffer offset and remaining length are reset. This will corrupt
the piped data (possibly also leading to an information leak between
processes) and may also corrupt kernel memory.
This was fixed upstream by commits f0d1bec9d58d ("new helper:
copy_page_from_iter()") and 637b58c2887e ("switch pipe_read() to
copy_page_to_iter()"), but those aren't suitable for stable. This fix
for older kernel versions was made by Seth Jennings for RHEL and I
have extracted it from their update.
CVE-2015-1805
Bug 1744232
References: https://bugzilla.redhat.com/show_bug.cgi?id=1202855
(cherry picked from commit 14f81062f365fa9e3839bb2a16862217b71a553c)
Change-Id: Ia5f97a4cfdaa2eb0e2a4974c2f04bc9a75934bd4
Reviewed-on: http://git-master/r/1111957
(cherry picked from commit e5bc77c0676277fd0b58ee469bd5638019a65d95)
Reviewed-on: http://git-master/r/1112337
GVS: Gerrit_Virtual_Submit
Tested-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
commit b0d8d2292160bb63de1972361ebed100c64b5b37 upstream.
The pipe code was trying (and failing) to be very careful about freeing
the pipe info only after the last access, with a pattern like:
spin_lock(&inode->i_lock);
if (!--pipe->files) {
inode->i_pipe = NULL;
kill = 1;
spin_unlock(&inode->i_lock);
__pipe_unlock(pipe);
if (kill)
free_pipe_info(pipe);
where the final freeing is done last.
HOWEVER. The above is actually broken, because while the freeing is
done at the end, if we have two racing processes releasing the pipe
inode info, the one that *doesn't* free it will decrement the ->files
count, and unlock the inode i_lock, but then still use the
"pipe_inode_info" afterwards when it does the "__pipe_unlock(pipe)".
This is *very* hard to trigger in practice, since the race window is
very small, and adding debug options seems to just hide it by slowing
things down.
Simon originally reported this way back in July as an Oops in
kmem_cache_allocate due to a single bit corruption (due to the final
"spin_unlock(pipe->mutex.wait_lock)" incrementing a field in a different
allocation that had re-used the free'd pipe-info), it's taken this long
to figure out.
Since the 'pipe->files' accesses aren't even protected by the pipe lock
(we very much use the inode lock for that), the simple solution is to
just drop the pipe lock early. And since there were two users of this
pattern, create a helper function for it.
Introduced commit ba5bb147330a ("pipe: take allocation and freeing of
pipe_inode_info out of ->i_mutex").
Reported-by: Simon Kirby <sim@hostway.ca>
Reported-by: Ian Applegate <ia@cloudflare.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Faster kernel compiles by way of fewer unnecessary includes.
[akpm@linux-foundation.org: fix fallout]
[akpm@linux-foundation.org: fix build]
Signed-off-by: Kent Overstreet <koverstreet@google.com>
Cc: Zach Brown <zab@redhat.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Asai Thambi S P <asamymuthupa@micron.com>
Cc: Selvan Mani <smani@micron.com>
Cc: Sam Bradshaw <sbradshaw@micron.com>
Cc: Jeff Moyer <jmoyer@redhat.com>
Cc: Benjamin LaHaise <bcrl@kvack.org>
Reviewed-by: "Theodore Ts'o" <tytso@mit.edu>
and rename __free_pipe_info() to free_pipe_info()
not used anymore
it's used only as a flag to distinguish normal pipes/FIFOs from the
internal per-task one used by file-to-file splice. And pipe->files
would work just as well for that purpose...
fs/pipe.c file_operations methods *know* that pipe is not an internal one;
no need to check pipe->inode for those callers.
simplify get_pipe_info(), while we are at it
now it can be done - put mutex into pipe_inode_info, use it instead
of ->i_mutex
* new field - pipe->files; number of struct file over that pipe (all
sharing the same inode, of course); protected by inode->i_lock.
* pipe_release() decrements pipe->files, clears inode->i_pipe when
if the counter has reached 0 (all under ->i_lock) and, in that case,
frees pipe after having done pipe_unlock()
* fifo_open() starts with grabbing ->i_lock, and either bumps pipe->files
if ->i_pipe was non-NULL or allocates a new pipe (dropping and regaining
->i_lock) and rechecks ->i_pipe; if it's still NULL, inserts new pipe
there, otherwise bumps ->i_pipe->files and frees the one we'd allocated.
At that point we know that ->i_pipe is non-NULL and won't go away, so
we can do pipe_lock() on it and proceed as we used to. If we end up
failing, decrement pipe->files and if it reaches 0 clear ->i_pipe and
free the sucker after pipe_unlock().
* use the fact that file_inode(file)->i_pipe doesn't change
while the file is opened - no locks needed to access that.
* switch to pipe_lock/pipe_unlock where it's easy to do
If you open a pipe for neither read nor write, the pipe code will not
add any usage counters to the pipe, causing the 'struct pipe_inode_info"
to be potentially released early.
That doesn't normally matter, since you cannot actually use the pipe,
but the pipe release code - particularly fasync handling - still expects
the actual pipe infrastructure to all be there. And rather than adding
NULL pointer checks, let's just disallow this case, the same way we
already do for the named pipe ("fifo") case.
This is ancient going back to pre-2.4 days, and until trinity, nobody
naver noticed.
Reported-by: Dave Jones <davej@redhat.com>
Allocating a file structure in function get_empty_filp() might fail because
of several reasons:
- not enough memory for file structures
- operation is not allowed
- user is over its limit
Currently the function returns NULL in all cases and we loose the exact
reason of the error. All callers of get_empty_filp() assume that the function
can fail with ENFILE only.
Return error through pointer. Change all callers to preserve this error code.
[AV: cleaned up a bit, carved the get_empty_filp() part out into a separate commit
(things remaining here deal with alloc_file()), removed pipe(2) behaviour change]
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
don't mess with sys_close() if copy_to_user() fails; just postpone
fd_install() until we know it hasn't.
Pull second vfs pile from Al Viro:
"The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the
deadlock reproduced by xfstests 068), symlink and hardlink restriction
patches, plus assorted cleanups and fixes.
Note that another fsfreeze deadlock (emergency thaw one) is *not*
dealt with - the series by Fernando conflicts a lot with Jan's, breaks
userland ABI (FIFREEZE semantics gets changed) and trades the deadlock
for massive vfsmount leak; this is going to be handled next cycle.
There probably will be another pull request, but that stuff won't be
in it."
Fix up trivial conflicts due to unrelated changes next to each other in
drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c}
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits)
delousing target_core_file a bit
Documentation: Correct s_umount state for freeze_fs/unfreeze_fs
fs: Remove old freezing mechanism
ext2: Implement freezing
btrfs: Convert to new freezing mechanism
nilfs2: Convert to new freezing mechanism
ntfs: Convert to new freezing mechanism
fuse: Convert to new freezing mechanism
gfs2: Convert to new freezing mechanism
ocfs2: Convert to new freezing mechanism
xfs: Convert to new freezing code
ext4: Convert to new freezing mechanism
fs: Protect write paths by sb_start_write - sb_end_write
fs: Skip atime update on frozen filesystem
fs: Add freezing handling to mnt_want_write() / mnt_drop_write()
fs: Improve filesystem freezing handling
switch the protection of percpu_counter list to spinlock
nfsd: Push mnt_want_write() outside of i_mutex
btrfs: Push mnt_want_write() outside of i_mutex
fat: Push mnt_want_write() outside of i_mutex
Signed-off-by: Cong Wang <amwang@redhat.com>
Btrfs has to make sure we have space to allocate new blocks in order to modify
the inode, so updating time can fail. We've gotten around this by having our
own file_update_time but this is kind of a pain, and Christoph has indicated he
would like to make xfs do something different with atime updates. So introduce
->update_time, where we will deal with i_version an a/m/c time updates and
indicate which changes need to be made. The normal version just does what it
has always done, updates the time and marks the inode dirty, and then
filesystems can choose to do something different.
I've gone through all of the users of file_update_time and made them check for
errors with the exception of the fault code since it's complicated and I wasn't
quite sure what to do there, also Jan is going to be pushing the file time
updates into page_mkwrite for those who have it so that should satisfy btrfs and
make it not a big deal to check the file_update_time() return code in the
generic fault path. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
As described in commit 07d106d0a ("vfs: fix up ENOIOCTLCMD error
handling"), drivers should return -ENOIOCTLCMD if they receive an ioctl
command which they don't understand. Doing so will result in -ENOTTY
being returned to userspace, which matches the behaviour of the compat
layer if it fails to translate an ioctl command.
This patch fixes the pipe ioctl to return -ENOIOCTLCMD instead of
-EINVAL when passed an unknown ioctl command.
The actual internal pipe implementation is already really about
individual packets (called "pipe buffers"), and this simply exposes that
as a special packetized mode.
When we are in the packetized mode (marked by O_DIRECT as suggested by
Alan Cox), a write() on a pipe will not merge the new data with previous
writes, so each write will get a pipe buffer of its own. The pipe
buffer is then marked with the PIPE_BUF_FLAG_PACKET flag, which in turn
will tell the reader side to break the read at that boundary (and throw
away any partial packet contents that do not fit in the read buffer).
End result: as long as you do writes less than PIPE_BUF in size (so that
the pipe doesn't have to split them up), you can now treat the pipe as a
packet interface, where each read() system call will read one packet at
a time. You can just use a sufficiently big read buffer (PIPE_BUF is
sufficient, since bigger than that doesn't guarantee atomicity anyway),
and the return value of the read() will naturally give you the size of
the packet.
NOTE! We do not support zero-sized packets, and zero-sized reads and
writes to a pipe continue to be no-ops. Also note that big packets will
currently be split at write time, but that the size at which that
happens is not really specified (except that it's bigger than PIPE_BUF).
Currently that limit is the system page size, but we might want to
explicitly support bigger packets some day.
The main user for this is going to be the autofs packet interface,
allowing us to stop having to care so deeply about exact packet sizes
(which have had bugs with 32/64-bit compatibility modes). But user
space can create packetized pipes with "pipe2(fd, O_DIRECT)", which will
fail with an EINVAL on kernels that do not support this interface.
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Ian Kent <raven@themaw.net>
Cc: Thomas Meyer <thomas@m3y3r.de>
Cc: stable@kernel.org # needed for systemd/autofs interaction fix
- Move open-coded filesystem magic numbers into magic.h
- Rearrange magic.h so that the filesystem-related constants are grouped
together.
Signed-off-by: Muthukumar R <muthur@gmail.com>
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
When a user with the CAP_SYS_RESOURCE cap tries to F_SETPIPE_SZ a pipe
with size bigger than kmalloc() can alloc it spits out an ugly warning:
WARNING: at mm/page_alloc.c:2095 __alloc_pages_nodemask+0x5d3/0x7a0()
Pid: 733, comm: a.out Not tainted 3.2.0-rc1+ #4
Call Trace:
warn_slowpath_common+0x75/0xb0
warn_slowpath_null+0x15/0x20
__get_free_pages+0x12/0x50
__kmalloc+0x12b/0x150
pipe_set_size+0x75/0x120
pipe_fcntl+0xf8/0x140
do_fcntl+0x2d4/0x410
sys_fcntl+0x66/0xa0
system_call_fastpath+0x16/0x1b
---[ end trace 432f702e6db7b5ee ]---
Instead, make kcalloc() handle the overflow case and fail quietly.
[akpm@linux-foundation.org: switch to sizeof(*bufs) for 80-column niceness]
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
... so no exitcalls there. Not much would work if pipe(2) would stop
working, after all...
Currently a statfs on a pipe's /proc/<pid>/fd/ link returns -ENOSYS. Wire
pipfs up so that the statfs succeeds.
This is required by checkpoint-restart in the userspace to make it
possible to distinguish pipes from fifos.
When we dump information about task's open files we use the /proc/pid/fd
directoy's symlinks and the fact that opening any of them gives us exactly
the same dentry->inode pair as the original process has. Now if a task
we're dumping has opened pipe and fifo we need to detect this and act
accordingly. Knowing that an fd with type S_ISFIFO resides on a pipefs is
the most precise way.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Reviewed-by: Tejun Heo <tj@kernel.org>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Workloads using pipes and sockets hit inode_sb_list_lock contention.
superblock s_inodes list is needed for quota, dirty, pagecache and
fsnotify management. pipe/anon/socket fs are clearly not candidates for
these.
For a number of file systems that don't have a mount point (e.g. sockfs
and pipefs), they are not marked as long term. Therefore in
mntput_no_expire, all locks in vfs_mount lock are taken instead of just
local cpu's lock to aggregate reference counts when we release
reference to file objects. In fact, only local lock need to have been
taken to update ref counts as these file systems are in no danger of
going away until we are ready to unregister them.
The attached patch marks file systems using kern_mount without
mount point as long term. The contentions of vfs_mount lock
is now eliminated. Before un-registering such file system,
kern_unmount should be called to remove the long term flag and
make the mount point ready to be freed.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
Commit e462c448fdc8 ("pipe: use event aware wakeups") optimized the pipe
event wakeup calls to avoid wakeups if the events do not match the
requested set.
However, the optimization was buggy, in that it didn't actually use the
correct sets for the events: when we make room for more data to be
written, the pipe poll() routine will return both the POLLOUT _and_
POLLWRNORM bits. Similarly for read.
And most critically, when a pipe is released, that will potentially
result in POLLHUP|POLLERR (depending on whether it was the last reader
or writer), not just the regular POLLIN|POLLOUT.
This bug showed itself as a hung gnome-screensaver-dialog process, stuck
forever (or at least until it was poked by a signal or by being traced)
in a poll() system call.
Cc: Davide Libenzi <davidel@xmailserver.org>
Instead of splitting refcount between (per-cpu) mnt_count
and (SMP-only) mnt_longrefs, make all references contribute
to mnt_count again and keep track of how many are longterm
ones.
Accounting rules for longterm count:
* 1 for each fs_struct.root.mnt
* 1 for each fs_struct.pwd.mnt
* 1 for having non-NULL ->mnt_ns
* decrement to 0 happens only under vfsmount lock exclusive
That allows nice common case for mntput() - since we can't drop the
final reference until after mnt_longterm has reached 0 due to the rules
above, mntput() can grab vfsmount lock shared and check mnt_longterm.
If it turns out to be non-zero (which is the common case), we know
that this is not the final mntput() and can just blindly decrement
percpu mnt_count. Otherwise we grab vfsmount lock exclusive and
do usual decrement-and-check of percpu mnt_count.
For fs_struct.c we have mnt_make_longterm() and mnt_make_shortterm();
namespace.c uses the latter in places where we don't already hold
vfsmount lock exclusive and opencodes a few remaining spots where
we need to manipulate mnt_longterm.
Note that we mostly revert the code outside of fs/namespace.c back
to what we used to have; in particular, normal code doesn't need
to care about two kinds of references, etc. And we get to keep
the optimization Nick's variant had bought us...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (41 commits)
fs: add documentation on fallocate hole punching
Gfs2: fail if we try to use hole punch
Btrfs: fail if we try to use hole punch
Ext4: fail if we try to use hole punch
Ocfs2: handle hole punching via fallocate properly
XFS: handle hole punching via fallocate properly
fs: add hole punching to fallocate
vfs: pass struct file to do_truncate on O_TRUNC opens (try #2)
fix signedness mess in rw_verify_area() on 64bit architectures
fs: fix kernel-doc for dcache::prepend_path
fs: fix kernel-doc for dcache::d_validate
sanitize ecryptfs ->mount()
switch afs
move internal-only parts of ncpfs headers to fs/ncpfs
switch ncpfs
switch 9p
pass default dentry_operations to mount_pseudo()
switch hostfs
switch affs
switch configfs
Send the events the wakeup refers to, so that epoll, and even the new poll
code in fs/select.c can avoid wakeups if the events do not match the
requested set.
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
The problem that this patch aims to fix is vfsmount refcounting scalability.
We need to take a reference on the vfsmount for every successful path lookup,
which often go to the same mount point.
The fundamental difficulty is that a "simple" reference count can never be made
scalable, because any time a reference is dropped, we must check whether that
was the last reference. To do that requires communication with all other CPUs
that may have taken a reference count.
We can make refcounts more scalable in a couple of ways, involving keeping
distributed counters, and checking for the global-zero condition less
frequently.
- check the global sum once every interval (this will delay zero detection
for some interval, so it's probably a showstopper for vfsmounts).
- keep a local count and only taking the global sum when local reaches 0 (this
is difficult for vfsmounts, because we can't hold preempt off for the life of
a reference, so a counter would need to be per-thread or tied strongly to a
particular CPU which requires more locking).
- keep a local difference of increments and decrements, which allows us to sum
the total difference and hence find the refcount when summing all CPUs. Then,
keep a single integer "long" refcount for slow and long lasting references,
and only take the global sum of local counters when the long refcount is 0.
This last scheme is what I implemented here. Attached mounts and process root
and working directory references are "long" references, and everything else is
a short reference.
This allows scalable vfsmount references during path walking over mounted
subtrees and unattached (lazy umounted) mounts with processes still running
in them.
This results in one fewer atomic op in the fastpath: mntget is now just a
per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock
and non-atomic decrement in the common case. However code is otherwise bigger
and heavier, so single threaded performance is basically a wash.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Regardless of how much we possibly try to scale dcache, there is likely
always going to be some fundamental contention when adding or removing children
under the same parent. Pseudo filesystems do not seem need to have connected
dentries because by definition they are disconnected.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Pseudo filesystems that don't put inode on RCU list or reachable by
rcu-walk dentries do not need to RCU free their inodes.
This avoids some include-file hell, and the function isn't really
important enough to be inlined anyway.
Reported-by: Ingo Molnar <mingo@elte.hu>
And in particular, use it in 'pipe_fcntl()'.
The other pipe functions do not need to use the 'careful' version, since
they are only ever called for things that are already known to be pipes.
The normal read/write/ioctl functions are called through the file
operations structures, so if a file isn't a pipe, they'd never get
called. But pipe_fcntl() is special, and called directly from the
generic fcntl code, and needs to use the same careful function that the
splice code is using.
Cc: Jens Axboe <jaxboe@fusionio.com>
Cc: Dave Jones <davej@redhat.com>
Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
The arguments were transposed, we want to assign the error code to
'ret', which is being returned.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
As it stands this check compares the number of pages to the page size.
This makes no sense and makes the fcntl fail in almost any sane case.
Fix it by checking if nr_pages is not zero (it can become zero only if
arg is too big and round_pipe_size() overflows).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
pipe_set_size() needs to copy pipe bufs from the old circular buffer
to the new.
The current code gets this wrong in multiple ways, resulting in oops.
Test program is available here:
http://www.kernel.org/pub/linux/kernel/people/mszeredi/piperesize/
This changes the interface to be based on bytes instead. The API
matches that of F_SETPIPE_SZ in that it rounds up the passed in
size so that the resulting page array is a power-of-2 in size.
The proc file is renamed to /proc/sys/fs/pipe-max-size to
reflect this change.
Change it to CAP_SYS_RESOURCE, as that more accurately models what
we want to control.
Suggested-by: Michael Kerrisk <mtk.manpages@googlemail.com>
We don't need to pages to guarantee the POSIX requirement
that upto a page size write must be atomic to an empty
pipe.
