path: root/fs/libfs.c
2012-12-20vfs: drop vmtruncateMarco Stornelli
Removed vmtruncate Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-05vfs: fix kerneldoc for generic_fh_to_parent()Yanchuan Nian
Wrong function name in the kerneldoc description of generic_fh_to_parent(). Signed-off-by: Yanchuan Nian <ycnian@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-10vfs: make it possible to access the dentry hash/len as one 64-bit entryLinus Torvalds
This allows comparing hash and len in one operation on 64-bit architectures. Right now only __d_lookup_rcu() takes advantage of this, since that is the case we care most about. The use of anonymous struct/unions hides the alternate 64-bit approach from most users, the exception being a few cases where we initialize a 'struct qstr' with a static initializer. This makes the problematic cases use a new QSTR_INIT() helper function for that (but initializing just the name pointer with a "{ .name = xyzzy }" initializer remains valid, as does just copying another qstr structure). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-09dentry leak in simple_fill_super() failure exitAl Viro
d_genocide() does _not_ evict dentries; it just removes extra ref pinning each of those. Normally it's followed by shrinking the tree (it's done just before generic_shutdown_super() by kill_litter_super()), but in case of simple_fill_super() nothing of that kind will follow. Just do shrink_dcache_parent() manually. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-05libfs: add simple_open()Stephen Boyd
debugfs and a few other drivers use an open-coded version of simple_open() to pass a pointer from the file to the read/write file ops. Add support for this simple case to libfs so that we can remove the many duplicate copies of this simple function. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-20make simple_pin_fs() pass MS_KERNMOUNT - it's a kernel-internal oneAl Viro
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-03fs: move code out of buffer.cAl Viro
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export kill_bdev as well, so brd doesn't have to open code it. Reduce buffer_head.h requirement accordingly. Removed a rather large comment from invalidate_bdev, as it looked a bit obsolete to bother moving. The small comment replacing it says enough. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02vfs: fix dentry leak in simple_fill_super()Konstantin Khlebnikov
put dentry if inode allocation failed, d_genocide() cannot release it Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-07-22fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.Al Viro
On ramfs and other simple_rename() users IN_DELETE_SELF is not generated for victim of overwriting rename() if it's is a directory. Works on most of the local filesystems and really trivial to fix... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20Make ->d_sb assign-once and always non-NULLAl Viro
New helper (non-exported, fs/internal.h-only): __d_alloc(sb, name). Allocates dentry, sets its ->d_sb to given superblock and sets ->d_op accordingly. Old d_alloc(NULL, name) callers are converted to that (all of them know what superblock they want). d_alloc() itself is left only for parent != NULl case; uses __d_alloc(), inserts result into the list of parent's children. Note that now ->d_sb is assign-once and never NULL *and* ->d_parent is never NULL either. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-19fs/libfs.c: fix simple_attr_write() on 32bit machinesAkinobu Mita
Assume that /sys/kernel/debug/dummy64 is debugfs file created by debugfs_create_x64(). # cd /sys/kernel/debug # echo 0x1234567812345678 > dummy64 # cat dummy64 0x0000000012345678 # echo 0x80000000 > dummy64 # cat dummy64 0xffffffff80000000 A value larger than INT_MAX cannot be written to the debugfs file created by debugfs_create_u64 or debugfs_create_x64 on 32bit machine. Because simple_attr_write() uses simple_strtol() for the conversion. To fix this, use simple_strtoll() instead. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12pass default dentry_operations to mount_pseudo()Al Viro
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale subdirsNick Piggin
Protect d_subdirs and d_child with d_lock, except in filesystems that aren't using dcache_lock for these anyway (eg. using i_mutex). Note: if we change the locking rule in future so that ->d_child protection is provided only with ->d_parent->d_lock, it may allow us to reduce some locking. But it would be an exception to an otherwise regular locking scheme, so we'd have to see some good results. Probably not worthwhile. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale d_unhashedNick Piggin
Protect d_unhashed(dentry) condition with d_lock. This means keeping DCACHE_UNHASHED bit in synch with hash manipulations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_pseudo() usersAl Viro
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: add sync_inode_metadataChristoph Hellwig
Add a new helper to write out the inode using the writeback code, that is including the correct dirty bit and list manipulation. A few of filesystems already opencode this, and a lot of others should be using it instead of using write_inode_now which also writes out the data. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-10libfs: Fix shift bug in generic_check_addressable()Joel Becker
generic_check_addressable() erroneously shifts pages down by a block factor when it should be shifting up. To prevent overflow, we shift blocks down to pages. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-10ext3/ext4: Factor out disk addressability checkPatrick J. LoPresti
As part of adding support for OCFS2 to mount huge volumes, we need to check that the sector_t and page cache of the system are capable of addressing the entire volume. An identical check already appears in ext3 and ext4. This patch moves the addressability check into its own function in fs/libfs.c and modifies ext3 and ext4 to invoke it. [Edited to -EINVAL instead of BUG_ON() for bad blocksize_bits -- Joel] Signed-off-by: Patrick LoPresti <lopresti@gmail.com> Cc: linux-ext4@vger.kernel.org Acked-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-08-09check ATTR_SIZE contraints in inode_change_okChristoph Hellwig
Make sure we check the truncate constraints early on in ->setattr by adding those checks to inode_change_ok. Also clean up and document inode_change_ok to make this obvious. As a fallout we don't have to call inode_newsize_ok from simple_setsize and simplify it down to a truncate_setsize which doesn't return an error. This simplifies a lot of setattr implementations and means we use truncate_setsize almost everywhere. Get rid of fat_setsize now that it's trivial and mark ext2_setsize static to make the calling convention obvious. Keep the inode_newsize_ok in vmtruncate for now as all callers need an audit for its removal anyway. Note: setattr code in ecryptfs doesn't call inode_change_ok at all and needs a deeper audit, but that is left for later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09default to simple_setattrChristoph Hellwig
With the new truncate sequence every filesystem that wants to support file size changes on disk needs to implement its own ->setattr. So instead of calling inode_setattr which supports size changes call into a simple method that doesn't support this. simple_setattr is almost what we want except that it does not mark the inode dirty after changes. Given that marking the inode dirty is a no-op for the simple in-memory filesystems that use simple_setattr currently just add the mark_inode_dirty call. Also add a WARN_ON for the presence of a truncate method to simple_setattr to catch new instances of it during the transition period. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09rename generic_setattrChristoph Hellwig
Despite its name it's now a generic implementation of ->setattr, but rather a helper to copy attributes from a struct iattr to the inode. Rename it to setattr_copy to reflect this fact. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-04wrong type for 'magic' argument in simple_fill_super()Roberto Sassu
It's used to superblock ->s_magic, which is unsigned long. Signed-off-by: Roberto Sassu <roberto.sassu@polito.it> Reviewed-by: Mimi Zohar <zohar@us.ibm.com> Signed-off-by: Eric Paris <eparis@redhat.com> CC: stable@kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-10FS / libfs: Implement simple_write_to_bufferJiri Slaby
It will be used in suspend code and serves as an easy wrap around copy_from_user. Similar to simple_read_from_buffer, it takes care of transfers with proper lengths depending on available and count parameters and advances ppos appropriately. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03libfs: Unexport and kill simple_prepare_writeBoaz Harrosh
Remove the EXPORT_UNUSED_SYMBOL of simple_prepare_write Collapse simple_prepare_write into it's only caller, though making it simpler and clearer to understand. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-03libfs: Open code simple_commit_write into only userBoaz Harrosh
* simple_commit_write was only called by simple_write_end. Open coding it makes it tiny bit less heavy on the arithmetic and much more readable. * While at it use zero_user() for clearing a partial page. * While at it add a docbook comment for simple_write_end. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16libfs: move EXPORT_SYMBOL for d_alloc_nameH Hartley Sweeten
The EXPORT_SYMBOL for d_alloc_name is in fs/libfs.c but the function is in fs/dcache.c. Move the EXPORT_SYMBOL to the line immediately after the closing function brace line in fs/dcache.c as mentioned in Documentation/CodingStyle. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24libfs: return error code on failed attr setWu Fengguang
Currently all simple_attr.set handlers return 0 on success and negative codes on error. Fix simple_attr_write() to return these error codes. Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-09-24libfs: make simple_read_from_buffer conventionalSteven Rostedt
Impact: have simple_read_from_buffer conform to standards It was brought to my attention by Andrew Morton, Theodore Tso, and H. Peter Anvin that a read from userspace should only return -EFAULT if nothing was actually read. Looking at the simple_read_from_buffer I noticed that this function does not conform to that rule. This patch fixes that function. [akpm@linux-foundation.org: simplification suggested by hpa] [hpa@zytor.com: fix count==0 handling] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-08-18vfs: make get_sb_pseudo set s_maxbytes to value that can be cast to signedJeff Layton
get_sb_pseudo sets s_maxbytes to ~0ULL which becomes negative when cast to a signed value. Fix it to use MAX_LFS_FILESIZE which casts properly to a positive signed value. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Steve French <smfrench@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Robert Love <rlove@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11New helper - simple_fsync()Al Viro
writes associated buffers, then does sync_inode() to write the inode itself (and to make it clean). Depends on ->write_inode() honouring the second argument. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09Convert obvious places to deactivate_locked_super()Al Viro
2009-04-03kmemtrace, fs: uninline simple_transaction_set()Ingo Molnar
Impact: cleanup We want to remove percpu.h from rcupdate.h (for upcoming kmemtrace changes), but this is not possible currently without breaking the build because fs.h has an implicit include file depedency: it uses PAGE_SIZE but does not include asm/page.h which defines it. This problem gets masked in practice because most fs.h using sites use rcupreempt.h (and other headers) which includes percpu.h which brings in asm/page.h indirectly. We cannot add asm/page.h to asm/fs.h because page.h is not an exported header. Move simple_transaction_set() to the other simple-transaction file helpers in fs/libfs.c. This removes the include file hell and also reduces kernel size a bit. Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1237898630.25315.83.camel@penberg-laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-27vfs: simple_set_mnt() should return voidSukadev Bhattiprolu
simple_set_mnt() is defined as returning 'int' but always returns 0. Callers assume simple_set_mnt() never fails and don't properly cleanup if it were to _ever_ fail. For instance, get_sb_single() and get_sb_nodev() should: up_write(sb->s_unmount); deactivate_super(sb); if simple_set_mnt() fails. Since simple_set_mnt() never fails, would be cleaner if it did not return anything. [akpm@linux-foundation.org: fix build] Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-27constify dentry_operations: restAl Viro
