path: root/fs/fs_struct.c
2013-03-01constify path_get/path_put and fs_struct.c stuffAl Viro
2012-11-28kill daemonize()Al Viro
2012-07-14get rid of ->mnt_longtermAl Viro
it's enough to set ->mnt_ns of internal vfsmounts to something distinct from all struct mnt_namespace out there; then we can just use the check for ->mnt_ns != NULL in the fast path of mntput_no_expire() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-20vfs: take path_get_longterm() out of write_seqcount scopeAl Viro
2012-03-20no need to play with fs->seq in exit_fs()Al Viro
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-01-16sanitize vfsmount refcounting changesAl Viro
Instead of splitting refcount between (per-cpu) mnt_count and (SMP-only) mnt_longrefs, make all references contribute to mnt_count again and keep track of how many are longterm ones. Accounting rules for longterm count: * 1 for each fs_struct.root.mnt * 1 for each fs_struct.pwd.mnt * 1 for having non-NULL ->mnt_ns * decrement to 0 happens only under vfsmount lock exclusive That allows nice common case for mntput() - since we can't drop the final reference until after mnt_longterm has reached 0 due to the rules above, mntput() can grab vfsmount lock shared and check mnt_longterm. If it turns out to be non-zero (which is the common case), we know that this is not the final mntput() and can just blindly decrement percpu mnt_count. Otherwise we grab vfsmount lock exclusive and do usual decrement-and-check of percpu mnt_count. For fs_struct.c we have mnt_make_longterm() and mnt_make_shortterm(); namespace.c uses the latter in places where we don't already hold vfsmount lock exclusive and opencodes a few remaining spots where we need to manipulate mnt_longterm. Note that we mostly revert the code outside of fs/namespace.c back to what we used to have; in particular, normal code doesn't need to care about two kinds of references, etc. And we get to keep the optimization Nick's variant had bought us... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: scale mntget/mntputNick Piggin
The problem that this patch aims to fix is vfsmount refcounting scalability. We need to take a reference on the vfsmount for every successful path lookup, which often go to the same mount point. The fundamental difficulty is that a "simple" reference count can never be made scalable, because any time a reference is dropped, we must check whether that was the last reference. To do that requires communication with all other CPUs that may have taken a reference count. We can make refcounts more scalable in a couple of ways, involving keeping distributed counters, and checking for the global-zero condition less frequently. - check the global sum once every interval (this will delay zero detection for some interval, so it's probably a showstopper for vfsmounts). - keep a local count and only taking the global sum when local reaches 0 (this is difficult for vfsmounts, because we can't hold preempt off for the life of a reference, so a counter would need to be per-thread or tied strongly to a particular CPU which requires more locking). - keep a local difference of increments and decrements, which allows us to sum the total difference and hence find the refcount when summing all CPUs. Then, keep a single integer "long" refcount for slow and long lasting references, and only take the global sum of local counters when the long refcount is 0. This last scheme is what I implemented here. Attached mounts and process root and working directory references are "long" references, and everything else is a short reference. This allows scalable vfsmount references during path walking over mounted subtrees and unattached (lazy umounted) mounts with processes still running in them. This results in one fewer atomic op in the fastpath: mntget is now just a per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock and non-atomic decrement in the common case. However code is otherwise bigger and heavier, so single threaded performance is basically a wash. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: fs_struct use seqlockNick Piggin
Use a seqlock in the fs_struct to enable us to take an atomic copy of the complete cwd and root paths. Use this in the RCU lookup path to avoid a thread-shared spinlock in RCU lookup operations. Multi-threaded apps may now perform path lookups with scalability matching multi-process apps. Operations such as stat(2) become very scalable for multi-threaded workload. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-08-18fs: fs_struct rwlock to spinlockNick Piggin
fs: fs_struct rwlock to spinlock struct fs_struct.lock is an rwlock with the read-side used to protect root and pwd members while taking references to them. Taking a reference to a path typically requires just 2 atomic ops, so the critical section is very small. Parallel read-side operations would have cacheline contention on the lock, the dentry, and the vfsmount cachelines, so the rwlock is unlikely to ever give a real parallelism increase. Replace it with a spinlock to avoid one or two atomic operations in typical path lookup fastpath. Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-11vfs: add helpers to get root and pwdMiklos Szeredi
Add three helpers that retrieve a refcounted copy of the root and cwd from the supplied fs_struct. get_fs_root() get_fs_pwd() get_fs_root_and_pwd() Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31New helper - current_umask()Al Viro
current->fs->umask is what most of fs_struct users are doing. Put that into a helper function. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31New locking/refcounting for fs_structAl Viro
* all changes of current->fs are done under task_lock and write_lock of old fs->lock * refcount is not atomic anymore (same protection) * its decrements are done when removing reference from current; at the same time we decide whether to free it. * put_fs_struct() is gone * new field - ->in_exec. Set by check_unsafe_exec() if we are trying to do execve() and only subthreads share fs_struct. Cleared when finishing exec (success and failure alike). Makes CLONE_FS fail with -EAGAIN if set. * check_unsafe_exec() may fail with -EAGAIN if another execve() from subthread is in progress. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-31Take fs_struct handling to new file (fs/fs_struct.c)Al Viro
Pure code move; two new helper functions for nfsd and daemonize (unshare_fs_struct() and daemonize_fs_struct() resp.; for now - the same code as used to be in callers). unshare_fs_struct() exported (for nfsd, as copy_fs_struct()/exit_fs() used to be), copy_fs_struct() and exit_fs() don't need exports anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
