path: root/fs/ecryptfs
2013-11-13ecryptfs: Fix memory leakage in keystore.cGeyslan G. Bem
commit 3edc8376c06133e3386265a824869cad03a4efd4 upstream. In 'decrypt_pki_encrypted_session_key' function: Initializes 'payload' pointer and releases it on exit. Signed-off-by: Geyslan G. Bem <geyslan@gmail.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-04eCryptfs: Check return of filemap_write_and_wait during fsyncTyler Hicks
Error out of ecryptfs_fsync() if filemap_write_and_wait() fails. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: Paul Taysom <taysom@chromium.org> Cc: Olof Johansson <olofj@chromium.org> Cc: stable@vger.kernel.org # v3.6+
2013-05-24ecryptfs: fixed msync to flush dataPaul Taysom
When msync is called on a memory mapped file, that data is not flushed to the disk. In Linux, msync calls fsync for the file. For ecryptfs, fsync just calls the lower level file system's fsync. Changed the ecryptfs fsync code to call filemap_write_and_wait before calling the lower level fsync. Addresses the problem described in http://crbug.com/239536 Signed-off-by: Paul Taysom <taysom@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: stable@vger.kernel.org # v3.6+
2013-05-10Merge tag 'ecryptfs-3.10-rc1-ablkcipher' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull eCryptfs update from Tyler Hicks: "Improve performance when AES-NI (and most likely other crypto accelerators) is available by moving to the ablkcipher crypto API. The improvement is more apparent on faster storage devices. There's no noticeable change when hardware crypto is not available" * tag 'ecryptfs-3.10-rc1-ablkcipher' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: Use the ablkcipher crypto API
2013-05-09eCryptfs: Use the ablkcipher crypto APITyler Hicks
Make the switch from the blkcipher kernel crypto interface to the ablkcipher interface. encrypt_scatterlist() and decrypt_scatterlist() now use the ablkcipher interface but, from the eCryptfs standpoint, still treat the crypto operation as a synchronous operation. They submit the async request and then wait until the operation is finished before they return. Most of the changes are contained inside those two functions. Despite waiting for the completion of the crypto operation, the ablkcipher interface provides performance increases in most cases when used on AES-NI capable hardware. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Acked-by: Colin King <colin.king@canonical.com> Reviewed-by: Zeev Zilberman <zeev@annapurnaLabs.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Cc: Tim Chen <tim.c.chen@intel.com> Cc: Ying Huang <ying.huang@intel.com> Cc: Thieu Le <thieule@google.com> Cc: Li Wang <dragonylffly@163.com> Cc: Jarkko Sakkinen <jarkko.sakkinen@iki.fi>
2013-05-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs fixes from Al Viro: "Regression fix from Geert + yet another open-coded kernel_read()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ecryptfs: don't open-code kernel_read() xtensa simdisk: Fix proc_create_data() conversion fallout
2013-05-09ecryptfs: don't open-code kernel_read()Al Viro
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-09ecryptfs: close rmmod raceAl Viro
2013-03-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull namespace bugfixes from Eric Biederman: "This is three simple fixes against 3.9-rc1. I have tested each of these fixes and verified they work correctly. The userns oops in key_change_session_keyring and the BUG_ON triggered by proc_ns_follow_link were found by Dave Jones. I am including the enhancement for mount to only trigger requests of filesystem modules here instead of delaying this for the 3.10 merge window because it is both trivial and the kind of change that tends to bit-rot if left untouched for two months." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: proc: Use nd_jump_link in proc_ns_follow_link fs: Limit sys_mount to only request filesystem modules (Part 2). fs: Limit sys_mount to only request filesystem modules. userns: Stop oopsing in key_change_session_keyring
2013-03-07Merge tag 'ecryptfs-3.9-rc2-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: "Minor code cleanups and new Kconfig option to disable /dev/ecryptfs The code cleanups fix up W=1 compiler warnings and some unnecessary checks. The new Kconfig option, defaulting to N, allows the rarely used eCryptfs kernel to userspace communication channel to be compiled out. This may be the first step in it being eventually removed." Hmm. I'm not sure whether these should be called "fixes", and it probably should have gone in the merge window. But I'll let it slide. * tag 'ecryptfs-3.9-rc2-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: allow userspace messaging to be disabled eCryptfs: Fix redundant error check on ecryptfs_find_daemon_by_euid() ecryptfs: ecryptfs_msg_ctx_alloc_to_free(): remove kfree() redundant null check eCryptfs: decrypt_pki_encrypted_session_key(): remove kfree() redundant null check eCryptfs: remove unneeded checks in virt_to_scatterlist() eCryptfs: Fix -Wmissing-prototypes warnings eCryptfs: Fix -Wunused-but-set-variable warnings eCryptfs: initialize payload_len in keystore.c
2013-03-03eCryptfs: allow userspace messaging to be disabledKees Cook
When the userspace messaging (for the less common case of userspace key wrap/unwrap via ecryptfsd) is not needed, allow eCryptfs to build with it removed. This saves on kernel code size and reduces potential attack surface by removing the /dev/ecryptfs node. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-27eCryptfs: Fix redundant error check on ecryptfs_find_daemon_by_euid()Tyler Hicks
It is sufficient to check the return code of ecryptfs_find_daemon_by_euid(). If it returns 0, it always sets the daemon pointer to point to a valid ecryptfs_daemon. Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Kees Cook <keescook@chromium.org>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-26export kernel_write(), convert open-coded instancesAl Viro
2013-02-26switch vfs_getattr() to struct pathAl Viro
2013-02-22new helper: file_inode(file)Al Viro
2013-02-12ecryptfs: ecryptfs_msg_ctx_alloc_to_free(): remove kfree() redundant null checkTim Gardner
smatch analysis: fs/ecryptfs/messaging.c:101 ecryptfs_msg_ctx_alloc_to_free() info: redundant null check on msg_ctx->msg calling kfree() Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Cc: ecryptfs@vger.kernel.org Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-02-12eCryptfs: decrypt_pki_encrypted_session_key(): remove kfree() redundant null ↵Tim Gardner
check smatch analysis: fs/ecryptfs/keystore.c:1206 decrypt_pki_encrypted_session_key() info: redundant null check on msg calling kfree() Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Cc: ecryptfs@vger.kernel.org Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-01-28eCryptfs: remove unneeded checks in virt_to_scatterlist()Dan Carpenter
This is always called with a valid "sg" pointer. My static checker complains because the call to sg_init_table() dereferences "sg" before we reach the checks. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-01-17eCryptfs: Fix -Wmissing-prototypes warningsTyler Hicks
Mark two inode operation fuctions as static. Fixes warnings when building with W=1. Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-01-17eCryptfs: Fix -Wunused-but-set-variable warningsTyler Hicks
These two variables are no longer used and can be removed. Fixes warnings when building with W=1. Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-01-17eCryptfs: initialize payload_len in keystore.cSimon Que
This is meant to remove a compiler warning. It should not make any functional change. payload_len should be initialized when it is passed to write_tag_64_packet() as a pointer. If that call fails, this function should return early, and payload_len won't be used. Signed-off-by: Simon Que <sque@chromium.org> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2013-01-11fs/ecryptfs: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Tyler Hicks <tyhicks@canonical.com> CC: Dustin Kirkland <dustin.kirkland@gazzang.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Tyler Hicks <tyhicks@canonical.com>
2012-12-18fs/ecryptfs/crypto.c: make ecryptfs_encode_for_filename() staticCong Ding
the function ecryptfs_encode_for_filename() is only used in this file Signed-off-by: Cong Ding <dinggnu@gmail.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-12-18eCryptfs: fix to use list_for_each_entry_safe() when delete itemsWei Yongjun
Since we will be removing items off the list using list_del() we need to use a safer version of the list_for_each_entry() macro aptly named list_for_each_entry_safe(). We should use the safe macro if the loop involves deletions of items. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> [tyhicks: Fixed compiler err - missing list_for_each_entry_safe() param] Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-11-07eCryptfs: Avoid unnecessary disk read and data decryption during writingLi Wang
ecryptfs_write_begin grabs a page from page cache for writing. If the page contains invalid data, or data older than the counterpart on the disk, eCryptfs will read out the corresponing data from the disk into the page, decrypt them, then perform writing. However, for this page, if the length of the data to be written into is equal to page size, that means the whole page of data will be overwritten, in which case, it does not matter whatever the data were before, it is beneficial to perform writing directly rather than bothering to read and decrypt first. With this optimization, according to our test on a machine with Intel Core 2 Duo processor, iozone 'write' operation on an existing file with write size being multiple of page size will enjoy a steady 3x speedup. Signed-off-by: Li Wang <wangli@kylinos.com.cn> Signed-off-by: Yunchuan Wen <wenyunchuan@kylinos.com.cn> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert ecryptfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-14eCryptfs: Copy up attributes of the lower target inode after renameTyler Hicks
After calling into the lower filesystem to do a rename, the lower target inode's attributes were not copied up to the eCryptfs target inode. This resulted in the eCryptfs target inode staying around, rather than being evicted, because i_nlink was not updated for the eCryptfs inode. This also meant that eCryptfs didn't do the final iput() on the lower target inode so it stayed around, as well. This would result in a failure to free up space occupied by the target file in the rename() operation. Both target inodes would eventually be evicted when the eCryptfs filesystem was unmounted. This patch calls fsstack_copy_attr_all() after the lower filesystem does its ->rename() so that important inode attributes, such as i_nlink, are updated at the eCryptfs layer. ecryptfs_evict_inode() is now called and eCryptfs can drop its final reference on the lower inode. http://launchpad.net/bugs/561129 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Tested-by: Colin Ian King <colin.king@canonical.com> Cc: <stable@vger.kernel.org> [2.6.39+]
2012-09-14eCryptfs: Call lower ->flush() from ecryptfs_flush()Tyler Hicks
Since eCryptfs only calls fput() on the lower file in ecryptfs_release(), eCryptfs should call the lower filesystem's ->flush() from ecryptfs_flush(). If the lower filesystem implements ->flush(), then eCryptfs should try to flush out any dirty pages prior to calling the lower ->flush(). If the lower filesystem does not implement ->flush(), then eCryptfs has no need to do anything in ecryptfs_flush() since dirty pages are now written out to the lower filesystem in ecryptfs_release(). Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-09-14eCryptfs: Write out all dirty pages just before releasing the lower fileTyler Hicks
Fixes a regression caused by: 821f749 eCryptfs: Revert to a writethrough cache model That patch reverted some code (specifically, 32001d6f) that was necessary to properly handle open() -> mmap() -> close() -> dirty pages -> munmap(), because the lower file could be closed before the dirty pages are written out. Rather than reapplying 32001d6f, this approach is a better way of ensuring that the lower file is still open in order to handle writing out the dirty pages. It is called from ecryptfs_release(), while we have a lock on the lower file pointer, just before the lower file gets the final fput() and we overwrite the pointer. https://launchpad.net/bugs/1047261 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Reported-by: Artemy Tregubenko <me@arty.name> Tested-by: Artemy Tregubenko <me@arty.name> Tested-by: Colin Ian King <colin.king@canonical.com>
2012-08-02Merge tag 'ecryptfs-3.6-rc1-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs Pull ecryptfs fixes from Tyler Hicks: - Fixes a bug when the lower filesystem mount options include 'acl', but the eCryptfs mount options do not - Cleanups in the messaging code - Better handling of empty files in the lower filesystem to improve usability. Failed file creations are now cleaned up and empty lower files are converted into eCryptfs during open(). - The write-through cache changes are being reverted due to bugs that are not easy to fix. Stability outweighs the performance enhancements here. - Improvement to the mount code to catch unsupported ciphers specified in the mount options * tag 'ecryptfs-3.6-rc1-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tyhicks/ecryptfs: eCryptfs: check for eCryptfs cipher support at mount eCryptfs: Revert to a writethrough cache model eCryptfs: Initialize empty lower files when opening them eCryptfs: Unlink lower inode when ecryptfs_create() fails eCryptfs: Make all miscdev functions use daemon ptr in file private_data eCryptfs: Remove unused messaging declarations and function eCryptfs: Copy up POSIX ACL and read-only flags from lower mount
2012-07-29ecryptfs_lookup_interpose(): allocate dentry_info firstAl Viro
less work on failure that way Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-29sanitize ecryptfs_lookup()Al Viro
* ->lookup() never gets hit with . or .. * dentry it gets is unhashed, so unless we had gone and hashed it ourselves, there's no need to d_drop() the sucker. * wrong name printed in one of the printks (NULL, in fact) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-23ecryptfs: don't reinvent the wheels, please - use struct completionAl Viro
... and keep the sodding requests on stack - they are small enough. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23don't expose I_NEW inodes via dentry->d_inodeAl Viro
d_instantiate(dentry, inode); unlock_new_inode(inode); is a bad idea; do it the other way round... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata * to vfs_create()Al Viro
all we want is a boolean flag, same as the method gets now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-13eCryptfs: check for eCryptfs cipher support at mountTim Sally
The issue occurs when eCryptfs is mounted with a cipher supported by the crypto subsystem but not by eCryptfs. The mount succeeds and an error does not occur until a write. This change checks for eCryptfs cipher support at mount time. Resolves Launchpad issue #338914, reported by Tyler Hicks in 03/2009. https://bugs.launchpad.net/ecryptfs/+bug/338914 Signed-off-by: Tim Sally <tsally@atomicpeace.com> Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
2012-07-13eCryptfs: Revert to a writethrough cache modelTyler Hicks
A change was made about a year ago to get eCryptfs to better utilize its page cache during writes. The idea was to do the page encryption operations during page writeback, rather than doing them when initially writing into the page cache, to reduce the number of page encryption operations during sequential writes. This meant that the encrypted page would only be written to the lower filesystem during page writeback, which was a change from how eCryptfs had previously wrote to the lower filesystem in ecryptfs_write_end(). The change caused a few eCryptfs-internal bugs that were shook out. Unfortunately, more grave side effects have been identified that will force changes outside of eCryptfs. Because the lower filesystem isn't consulted until page writeback, eCryptfs has no way to pass lower write errors (ENOSPC, mainly) back to userspace. Additionaly, it was reported that quotas could be bypassed because of the way eCryptfs may sometimes open the lower filesystem using a privileged kthread. It would be nice to resolve the latest issues, but it is best if the eCryptfs commits be reverted to the old behavior in the meantime. This reverts: 32001d6f "eCryptfs: Flush file in vma close" 5be79de2 "eCryptfs: Flush dirty pages in setattr" 57db4e8d "ecryptfs: modify write path to encrypt page in writepage" Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Tested-by: Colin King <colin.king@canonical.com> Cc: Colin King <colin.king@canonical.com> Cc: Thieu Le <thieule@google.com>
2012-07-08eCryptfs: Initialize empty lower files when opening themTyler Hicks
Historically, eCryptfs has only initialized lower files in the ecryptfs_create() path. Lower file initialization is the act of writing the cryptographic metadata from the inode's crypt_stat to the header of the file. The ecryptfs_open() path already expects that metadata to be in the header of the file. A number of users have reported empty lower files in beneath their eCryptfs mounts. Most of the causes for those empty files being left around have been addressed, but the presence of empty files causes problems due to the lack of proper cryptographic metadata. To transparently solve this problem, this patch initializes empty lower files in the ecryptfs_open() error path. If the metadata is unreadable due to the lower inode size being 0, plaintext passthrough support is not in use, and the metadata is stored in the header of the file (as opposed to the user.ecryptfs extended attribute), the lower file will be initialized. The number of nested conditionals in ecryptfs_open() was getting out of hand, so a helper function was created. To avoid the same nested conditional problem, the conditional logic was reversed inside of the helper function. https://launchpad.net/bugs/911507 Signed-off-by: Tyler Hicks <tyhicks@canonical.com> Cc: John Johansen <john.johansen@canonical.com> Cc: Colin Ian King <colin.king@canonical.com>
