path: root/fs/autofs4
2013-05-06autofs - remove autofs dentry mount checkDavid Jeffery
When checking if an autofs mount point is busy it isn't sufficient to only check if it's a mount point. For example, if the mount of an offset mountpoint in a tree is denied for this host by its export and the dentry becomes a process working directory the check incorrectly returns the mount as not in use at expire. This can happen since the default when mounting within a tree is nostrict, which means ingnore mount fails on mounts within the tree and continue. The nostrict option is meant to allow mounting in this case. Signed-off-by: David Jeffery <djeffery@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-06autofs - fix sparse warning for autofs4_d_manage()Claudiu Ghioc
Fixed the sparse warning: fs/autofs4/root.c:411:5: warning: symbol 'autofs4_d_manage' was not declared. Should it be static?" [ Clearly it should be static as the function is declared static at the top of root.c. - imk ] Signed-off-by: Claudiu Ghioc <claudiu.ghioc@gmail.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-03-01autofs4 - autofs4_catatonic_mode(): remove redundant null check on kfree()Tim Gardner
smatch analysis: fs/autofs4/waitq.c:46 autofs4_catatonic_mode() info: redundant null check on wq->name.name calling kfree() Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Ian Kent <raven@themaw.net> Cc: autofs@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-01autofs - Fix sparse warning: context imbalance in autofs4_d_automount() ↵Peter Huewe
different lock contexts for basic block Sparse complains: fs/autofs4/root.c:409:9: sparse: context imbalance in 'autofs4_d_automount' - different lock contexts for basic block This was introduced by commit f55fb0c24386 ("autofs4 - dont clear DCACHE_NEED_AUTOMOUNT on rootless mount") The function autofs4_d_automount can be left with the (&sbi->fs_lock) held if sbi->version <= 4 and simple_empty(dentry) == false so the warning seems valid. --> Add an spin_unlock in this case before we jump to done Unfortunately compile tested only. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-26fs: change return values from -EACCES to -EPERMZhao Hongjiang
According to SUSv3: [EACCES] Permission denied. An attempt was made to access a file in a way forbidden by its file access permissions. [EPERM] Operation not permitted. An attempt was made to perform an operation limited to processes with appropriate privileges or to the owner of a file or other resource. So -EPERM should be returned if capability checks fails. Strictly speaking this is an API change since the error code user sees is altered. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "While small this set of changes is very significant with respect to containers in general and user namespaces in particular. The user space interface is now complete. This set of changes adds support for unprivileged users to create user namespaces and as a user namespace root to create other namespaces. The tyranny of supporting suid root preventing unprivileged users from using cool new kernel features is broken. This set of changes completes the work on setns, adding support for the pid, user, mount namespaces. This set of changes includes a bunch of basic pid namespace cleanups/simplifications. Of particular significance is the rework of the pid namespace cleanup so it no longer requires sending out tendrils into all kinds of unexpected cleanup paths for operation. At least one case of broken error handling is fixed by this cleanup. The files under /proc/<pid>/ns/ have been converted from regular files to magic symlinks which prevents incorrect caching by the VFS, ensuring the files always refer to the namespace the process is currently using and ensuring that the ptrace_mayaccess permission checks are always applied. The files under /proc/<pid>/ns/ have been given stable inode numbers so it is now possible to see if different processes share the same namespaces. Through the David Miller's net tree are changes to relax many of the permission checks in the networking stack to allowing the user namespace root to usefully use the networking stack. Similar changes for the mount namespace and the pid namespace are coming through my tree. Two small changes to add user namespace support were commited here adn in David Miller's -net tree so that I could complete the work on the /proc/<pid>/ns/ files in this tree. Work remains to make it safe to build user namespaces and 9p, afs, ceph, cifs, coda, gfs2, ncpfs, nfs, nfsd, ocfs2, and xfs so the Kconfig guard remains in place preventing that user namespaces from being built when any of those filesystems are enabled. Future design work remains to allow root users outside of the initial user namespace to mount more than just /proc and /sys." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (38 commits) proc: Usable inode numbers for the namespace file descriptors. proc: Fix the namespace inode permission checks. proc: Generalize proc inode allocation userns: Allow unprivilged mounts of proc and sysfs userns: For /proc/self/{uid,gid}_map derive the lower userns from the struct file procfs: Print task uids and gids in the userns that opened the proc file userns: Implement unshare of the user namespace userns: Implent proc namespace operations userns: Kill task_user_ns userns: Make create_new_namespaces take a user_ns parameter userns: Allow unprivileged use of setns. userns: Allow unprivileged users to create new namespaces userns: Allow setting a userns mapping to your current uid. userns: Allow chown and setgid preservation userns: Allow unprivileged users to create user namespaces. userns: Ignore suid and sgid on binaries if the uid or gid can not be mapped userns: fix return value on mntns_install() failure vfs: Allow unprivileged manipulation of the mount namespace. vfs: Only support slave subtrees across different user namespaces vfs: Add a user namespace reference from struct mnt_namespace ...
2012-12-13autofs4 - use simple_empty() for empty directory checkIan Kent
For direct (and offset) mounts, if an automounted mount is manually umounted the trigger mount dentry can appear non-empty causing it to not trigger mounts. This can also happen if there is a file handle leak in a user space automounting application. This happens because, when a ioctl control file handle is opened on the mount, a cursor dentry is created which causes list_empty() to see the dentry as non-empty. Since there is a case where listing the directory of these dentrys is needed, the use of dcache_dir_*() functions for .open() and .release() is needed. Consequently simple_empty() must be used instead of list_empty() when checking for an empty directory. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-13autofs4 - dont clear DCACHE_NEED_AUTOMOUNT on rootless mountIan Kent
The DCACHE_NEED_AUTOMOUNT flag is cleared on mount and set on expire for autofs rootless multi-mount dentrys to prevent unnecessary calls to ->d_automount(). Since DCACHE_MANAGE_TRANSIT is always set on autofs dentrys ->d_managed() is always called so the check can be done in ->d_manage() without the need to change the flag. This still avoids unnecessary calls to ->d_automount(), adds negligible overhead and eliminates a seriously ugly check in the expire code. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-14userns: Support autofs4 interacing with multiple user namespacesEric W. Biederman
Use kuid_t and kgid_t in struct autofs_info and struct autofs_wait_queue. When creating directories and symlinks default the uid and gid of the mount requester to the global root uid and gid. autofs4_wait will update these fields when a mount is requested. When generating autofsv5 packets report the uid and gid of the mount requestor in user namespace of the process that opened the pipe, reporting unmapped uids and gids as overflowuid and overflowgid. In autofs_dev_ioctl_requester return the uid and gid of the last mount requester converted into the calling processes user namespace. When the uid or gid don't map return overflowuid and overflowgid as appropriate, allowing failure to find a mount requester to be distinguished from failure to map a mount requester. The uid and gid mount options specifying the user and group of the root autofs inode are converted into kuid and kgid as they are parsed defaulting to the current uid and current gid of the process that mounts autofs. Mounting of autofs for the present remains confined to processes in the initial user namespace. Cc: Ian Kent <raven@themaw.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-10-11autofs4 - fix reset pending flag on mount failIan Kent
In autofs4_d_automount(), if a mount fail occurs the AUTOFS_INF_PENDING mount pending flag is not cleared. One effect of this is when using the "browse" option, directory entry attributes show up with all "?"s due to the incorrect callback and subsequent failure return (when in fact no callback should be made). Signed-off-by: Ian Kent <ikent@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-26make get_file() return its argumentAl Viro
simplifies a bunch of callers... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26autofs4: don't open-code fd_install()Al Viro
The only difference between autofs_dev_ioctl_fd_install() and fd_install() is __set_close_on_exec() done by the latter. Just use get_unused_fd_flags(O_CLOEXEC) to allocate the descriptor and be done with that... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-17autofs4 - fix expire checkIan Kent
In some cases when an autofs indirect mount is contained in a file system that is marked as shared (such as when systemd does the equivalent of "mount --make-rshared /" early in the boot), mounts stop expiring. When this happens the first expiry check on a mountpoint dentry in autofs_expire_indirect() sees a mountpoint dentry with a higher than minimal reference count. Consequently the dentry is condidered busy and the actual expiry check is never done. This particular check was originally meant as an optimisation to detect a path walk in progress but with the addition of rcu-walk it can be ineffective anyway. Removing the test allows automounts to expire again since the actual expire check doesn't rely on the dentry reference count. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-16autofs4 - fix get_next_positive_subdir()Ian Kent
Following a report of a crash during an automount expire I found that the locking in fs/autofs4/expire.c:get_next_positive_subdir() was wrong. Not only is the locking wrong but the function is more complex than it needs to be. The function is meant to calculate (and dget) the next entry in the list of directories contained in the root of an autofs mount point (an autofs indirect mount to be precise). The main problem was that the d_lock of the owner of the list was not being taken when walking the list, which lead to list corruption under load. The only other lock that needs to be taken is against the next dentry candidate so it can be checked for usability. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-23switch dentry_open() to struct path, make it grab references itselfAl Viro
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-28Merge tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linuxLinus Torvalds
Pull writeback tree from Wu Fengguang: "Mainly from Jan Kara to avoid iput() in the flusher threads." * tag 'writeback' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Avoid iput() from flusher thread vfs: Rename end_writeback() to clear_inode() vfs: Move waiting for inode writeback from end_writeback() to evict_inode() writeback: Refactor writeback_single_inode() writeback: Remove wb->list_lock from writeback_single_inode() writeback: Separate inode requeueing after writeback writeback: Move I_DIRTY_PAGES handling writeback: Move requeueing when I_SYNC set to writeback_sb_inodes() writeback: Move clearing of I_SYNC into inode_sync_complete() writeback: initialize global_dirty_limit fs: remove 8 bytes of padding from struct writeback_control on 64 bit builds mm: page-writeback.c: local functions should not be exposed globally
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-04-29autofs: make the autofsv5 packet file descriptor use a packetized pipeLinus Torvalds
The autofs packet size has had a very unfortunate size problem on x86: because the alignment of 'u64' differs in 32-bit and 64-bit modes, and because the packet data was not 8-byte aligned, the size of the autofsv5 packet structure differed between 32-bit and 64-bit modes despite looking otherwise identical (300 vs 304 bytes respectively). We first fixed that up by making the 64-bit compat mode know about this problem in commit a32744d4abae ("autofs: work around unhappy compat problem on x86-64"), and that made a 32-bit 'systemd' work happily on a 64-bit kernel because everything then worked the same way as on a 32-bit kernel. But it turned out that 'automount' had actually known and worked around this problem in user space, so fixing the kernel to do the proper 32-bit compatibility handling actually *broke* 32-bit automount on a 64-bit kernel, because it knew that the packet sizes were wrong and expected those incorrect sizes. As a result, we ended up reverting that compatibility mode fix, and thus breaking systemd again, in commit fcbf94b9dedd. With both automount and systemd doing a single read() system call, and verifying that they get *exactly* the size they expect but using different sizes, it seemed that fixing one of them inevitably seemed to break the other. At one point, a patch I seriously considered applying from Michael Tokarev did a "strcmp()" to see if it was automount that was doing the operation. Ugly, ugly. However, a prettier solution exists now thanks to the packetized pipe mode. By marking the communication pipe as being packetized (by simply setting the O_DIRECT flag), we can always just write the bigger packet size, and if user-space does a smaller read, it will just get that partial end result and the extra alignment padding will simply be thrown away. This makes both automount and systemd happy, since they now get the size they asked for, and the kernel side of autofs simply no longer needs to care - it could pad out the packet arbitrarily. Of course, if there is some *other* user of autofs (please, please, please tell me it ain't so - and we haven't heard of any) that tries to read the packets with multiple writes, that other user will now be broken - the whole point of the packetized mode is that one system call gets exactly one packet, and you cannot read a packet in pieces. Tested-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: David Miller <davem@davemloft.net> Cc: Ian Kent <raven@themaw.net> Cc: Thomas Meyer <thomas@m3y3r.de> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-28Revert "autofs: work around unhappy compat problem on x86-64"Linus Torvalds
This reverts commit a32744d4abae24572eff7269bc17895c41bd0085. While that commit was technically the right thing to do, and made the x86-64 compat mode work identically to native 32-bit mode (and thus fixing the problem with a 32-bit systemd install on a 64-bit kernel), it turns out that the automount binaries had workarounds for this compat problem. Now, the workarounds are disgusting: doing an "uname()" to find out the architecture of the kernel, and then comparing it for the 64-bit cases and fixing up the size of the read() in automount for those. And they were confused: it's not actually a generic 64-bit issue at all, it's very much tied to just x86-64, which has different alignment for an 'u64' in 64-bit mode than in 32-bit mode. But the end result is that fixing the compat layer actually breaks the case of a 32-bit automount on a x86-64 kernel. There are various approaches to fix this (including just doing a "strcmp()" on current->comm and comparing it to "automount"), but I think that I will do the one that teaches pipes about a special "packet mode", which will allow user space to not have to care too deeply about the padding at the end of the autofs packet. That change will make the compat workaround unnecessary, so let's revert it first, and get automount working again in compat mode. The packetized pipes will then fix autofs for systemd. Reported-and-requested-by: Michael Tokarev <mjt@tls.msk.ru> Cc: Ian Kent <raven@themaw.net> Cc: stable@kernel.org # for 3.3 Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-03-20autofs: set things up *before* registering fs typeAl Viro
it's not a serious race, but we really want misc device before anybody gets to mount this sucker. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-02-25autofs: work around unhappy compat problem on x86-64Ian Kent
When the autofs protocol version 5 packet type was added in commit 5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it obvously tried quite hard to be word-size agnostic, and uses explicitly sized fields that are all correctly aligned. However, with the final "char name[NAME_MAX+1]" array at the end, the actual size of the structure ends up being not very well defined: because the struct isn't marked 'packed', doing a "sizeof()" on it will align the size of the struct up to the biggest alignment of the members it has. And despite all the members being the same, the alignment of them is different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round number (256), the name[] array starts out a 4-byte aligned. End result: the "packed" size of the structure is 300 bytes: 4-byte, but not 8-byte aligned. As a result, despite all the fields being in the same place on all architectures, sizeof() will round up that size to 304 bytes on architectures that have 8-byte alignment for u64. Note that this is *not* a problem for 32-bit compat mode on POWER, since there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit and 64-bit alignment is different for 64-bit entities, and as a result the structure that has exactly the same layout has different sizes. So on x86-64, but no other architecture, we will just subtract 4 from the size of the structure when running in a compat task. That way we will write the properly sized packet that user mode expects. Not pretty. Sadly, this very subtle, and unnecessary, size difference has been encoded in user space that wants to read packets of *exactly* the right size, and will refuse to touch anything else. Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-19Wrap accesses to the fd_sets in struct fdtableDavid Howells
Wrap accesses to the fd_sets in struct fdtable (for recording open files and close-on-exec flags) so that we can move away from using fd_sets since we abuse the fd_set structs by not allocating the full-sized structure under normal circumstances and by non-core code looking at the internals of the fd_sets. The first abuse means that use of FD_ZERO() on these fd_sets is not permitted, since that cannot be told about their abnormal lengths. This introduces six wrapper functions for setting, clearing and testing close-on-exec flags and fd-is-open flags: void __set_close_on_exec(int fd, struct fdtable *fdt); void __clear_close_on_exec(int fd, struct fdtable *fdt); bool close_on_exec(int fd, const struct fdtable *fdt); void __set_open_fd(int fd, struct fdtable *fdt); void __clear_open_fd(int fd, struct fdtable *fdt); bool fd_is_open(int fd, const struct fdtable *fdt); Note that I've prepended '__' to the names of the set/clear functions because they require the caller to hold a lock to use them. Note also that I haven't added wrappers for looking behind the scenes at the the array. Possibly that should exist too. Signed-off-by: David Howells <dhowells@redhat.com> Link: http://lkml.kernel.org/r/20120216174942.23314.1364.stgit@warthog.procyon.org.uk Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk>
2012-02-13autofs4 - fix lockdep splat in autofsSteven Rostedt
When recursing down the locks when traversing a tree/list in get_next_positive_dentry() or get_next_positive_subdir() a lock can change from being nested to being a parent which breaks lockdep. This patch tells lockdep about what we did. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-13autofs4 - fix deal with autofs4_write racesIan Kent
I don't know how I missed this obvious mistake when I reviewed Als' patches, sorry. [ Quoting Al: Grr... Note to self: do git status *and* git stash show -p before git push. Nothing like "WTF? I'd fixed that braino" feeling ;-/ Al sent the same patch - it got broken in commit d668dc56631d: "autofs4: deal with autofs4_write/autofs4_write races". ] Reported-and-tested-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-11autofs4: deal with autofs4_write/autofs4_write racesAl Viro
Just serialize the actual writing of packets into pipe on a new mutex, independent from everything else in the locking hierarchy. As soon as something has started feeding a piece of packet into the pipe to daemon, we *want* everything else about to try the same to wait until we are done. Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-11autofs4: catatonic_mode vs. notify_daemon raceAl Viro
we need to hold ->wq_mutex while we are forming the packet to send, lest we have autofs4_catatonic_mode() setting wq->name.name to NULL just as autofs4_notify_daemon() decides to memcpy() from it... We do have check for catatonic mode immediately after that (under ->wq_mutex, as it ought to be) and packet won't be actually sent, but it'll be too late for us if we oops on that memcpy() from NULL... Fix is obvious - just extend the area covered by ->wq_mutex over that switch and check whether it's catatonic *before* doing anything else. Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-11autofs4: autofs4_wait() vs. autofs4_catatonic_mode() raceAl Viro
We need to recheck ->catatonic after autofs4_wait() got ->wq_mutex for good, or we might end up with wq inserted into queue after autofs4_catatonic_mode() had done its thing. It will stick there forever, since there won't be anything to clear its ->name.name. A bit of a complication: validate_request() drops and regains ->wq_mutex. It actually ends up the most convenient place to stick the check into... Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2012-01-06vfs: prefer ->dentry->d_sb to ->mnt->mnt_sbAl Viro
2012-01-03autofs4: propagate umode_tAl Viro
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-08-08autofs4: fix debug printk warning uncovered by cleanupLinus Torvalds
The previous comit made the autofs4 debug printouts check types against the printout format, and uncovered this bug: fs/autofs4/waitq.c:106:2: warning: format ‘%08lx’ expects type ‘long unsigned int’, but argument 4 has type ‘autofs_wqt_t’ which is due to the insane type for wait_queue_token. That thing should be some fixed well-defined size (preferably just 'unsigned int' or 'u32') but for unexplained reasons it is randomly either 'unsigned long' or 'unsigned int' depending on the architecture. For now, cast it to 'unsigned long' for printing, the way we do elsewhere. Somebody else can try to explain the typedef mess. (There's a reason we don't support excessive use of typedefs in the kernel: it's usually just a good way of confusing yourself). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-08autofs4: clean up uaotfs use of debug/info/warning printoutsLinus Torvalds
Use 'pr_debug()' for DPRINTK, which will do the proper type checking on the arguments (without generating code) even when DEBUG isn't #defined. Also, use the standard __VA_ARGS__ for the macros, and stop the pointless abuse of 'do { xyz } while (0)' when the macro is already a perfectly well-formed single statement. Reported-by: David Howells <dhowells@redhat.com> Suggested-by: Joe Perches <joe@perches.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-30autofs4: bogus dentry_unhash() added in ->unlink()Al Viro
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4: Do not potentially dereference NULL pointer returned by fget() in ↵Jesper Juhl
autofs_dev_ioctl_setpipefd() In fs/autofs4/dev-ioctl.c::autofs_dev_ioctl_setpipefd() we call fget(), which may return NULL, but we do not explicitly test for that NULL return so we may end up dereferencing a NULL pointer - bad. When I originally submitted this patch I had chosen EBUSY as the return value to use if this happens. Ian Kent was kind enough to explain why that would most likely be wrong and why EBADF should most likely be used instead. This version of the patch uses EBADF. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - remove autofs4_lockIan Kent
The autofs4_lock introduced by the rcu-walk changes has unnecessarily broad scope. The locking is better handled by the per-autofs super block lookup_lock. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix d_manage() return on rcu-walkIan Kent
The daemon never needs to block and, in the rcu-walk case an error return isn't used, so always return zero. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix autofs4_expire_indirect() traversalIan Kent
The vfs-scale changes changed the traversal used in autofs4_expire_indirect() from a list to a depth first tree traversal which isn't right. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix dentry leak in autofs4_expire_direct()Ian Kent
There is a missing dput() when returning from autofs4_expire_direct() when we see that the dentry is already a pending mount. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - reinstate last used update on accessIan Kent
When direct (and offset) mounts were introduced the the last used timeout could no longer be updated in ->d_revalidate(). This is because covered direct mounts would be followed over without calling the autofs file system. As a result the definition of the busyness check for all entries was changed to be "actually busy" being an open file or working directory within the automount. But now we have a call back in the follow so the last used update on any access can be re-instated. This requires DCACHE_MANAGE_TRANSIT to always be set. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-18lose 'mounting_here' argument in ->d_manage()Al Viro
it's always false... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-18autofs4: clean ->d_release() and autofs4_free_ino() upAl Viro
The latter is called only when both ino and dentry are about to be freed, so cleaning ->d_fsdata and ->dentry is pointless. Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
