commit f51e1eb63d9c28cec188337ee656a13be6980cfd upstream.
Toralf Förster reported that the cpufreq ondemand governor behaves erratically
(doesn't scale well) after a suspend/resume cycle. The problem was that the
cpufreq subsystem's idea of the cpu frequencies differed from the actual
frequencies set in the hardware after a suspend/resume cycle. Toralf bisected
the problem to commit a66b2e5 (cpufreq: Preserve sysfs files across
suspend/resume).
Among other (harmless) things, that commit skipped the call to
cpufreq_update_policy() in the resume path. But cpufreq_update_policy() plays
an important role during resume, because it is responsible for checking if
the BIOS changed the cpu frequencies behind our back and resynchronize the
cpufreq subsystem's knowledge of the cpu frequencies, and update them
accordingly.
So, restore the call to cpufreq_update_policy() in the resume path to fix
the cpufreq regression.
Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit 2ee3e26c673e75c05ef8b914f54fadee3d7b9c88 upstream.
Commit 39c60a0948cc '[SCSI] sd: fix array cache flushing bug causing
performance problems' added temp as a pointer to "temporary " and used
sizeof(temp) - 1 as its length. But sizeof(temp) is the size of the
pointer, not the size of the string constant. Change temp to a static
array so that sizeof() does what was intended.
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
PCI 9835 Multi-I/O Controller"
commit 828c6a102b1f2b8583fadc0e779c46b31d448f0b upstream.
This reverts commit 8d2f8cd424ca0b99001f3ff4f5db87c4e525f366.
As reported by Stefan, this device already works with the parport_serial
driver, so the 8250_pci driver should not also try to grab it as well.
Reported-by: Stefan Seyfried <stefan.seyfried@googlemail.com>
Cc: Wang YanQing <udknight@gmail.com>
commit 64e377dcd7d75c241d614458e9619d3445de44ef upstream.
Commit 19ffd68f816878aed456d5e87697f43bd9e3bd2b
('pty: Remove redundant itty reset') introduced a regression
whereby the other pty's linkage is not cleared on teardown.
This triggers a false positive diagnostic in testing.
Properly reset the itty linkage.
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit ffc8b30866879ed9ba62bd0a86fecdbd51cd3d19 upstream.
Disk names may contain arbitrary strings, so they must not be
interpreted as format strings. It seems that only md allows arbitrary
strings to be used for disk names, but this could allow for a local
memory corruption from uid 0 into ring 0.
CVE-2013-2851
commit 3594f4c0d7bc51e3a7e6d73c44e368ae079e42f3 upstream.
The exposed interface for cm_notify_event() could result in the event msg
string being parsed as a format string. Make sure it is only used as a
literal string.
Cc: Anton Vorontsov <cbou@mail.ru>
Signed-off-by: Anton Vorontsov <anton@enomsg.org>
commit 542db01579fbb7ea7d1f7bb9ddcef1559df660b2 upstream.
In drivers/cdrom/cdrom.c mmc_ioctl_cdrom_read_data() allocates a memory
area with kmalloc in line 2885.
2885 cgc->buffer = kmalloc(blocksize, GFP_KERNEL);
2886 if (cgc->buffer == NULL)
2887 return -ENOMEM;
In line 2908 we can find the copy_to_user function:
2908 if (!ret && copy_to_user(arg, cgc->buffer, blocksize))
The cgc->buffer is never cleaned and initialized before this function.
If ret = 0 with the previous basic block, it's possible to display some
memory bytes in kernel space from userspace.
When we read a block from the disk it normally fills the ->buffer but if
the drive is malfunctioning there is a chance that it would only be
partially filled. The result is an leak information to userspace.
Cc: Jonathan Salwan <jonathan.salwan@gmail.com>
Cc: Luis Henriques <luis.henriques@canonical.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of seven bug fixes. Several fcoe fixes for locking
problems, initiator issues and a VLAN API change, all of which could
eventually lead to data corruption, one fix for a qla2xxx locking
problem which could lead to multiple completions of the same request
(and subsequent data corruption) and a use after free in the ipr
driver. Plus one minor MAINTAINERS file update"
(only six bugfixes in this pull, since I had already pulled the fcoe API
fix directly from Robert Love)
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
[SCSI] ipr: Avoid target_destroy accessing memory after it was freed
[SCSI] qla2xxx: Fix for locking issue between driver ISR and mailbox routines
MAINTAINERS: Fix fcoe mailing list
libfc: extend ex_lock to protect all of fc_seq_send
libfc: Correct check for initiator role
libfcoe: Fix Conflicting FCFs issue in the fabric
Pull drm/qxl fix from Dave Airlie:
"Bad me forgot an access check, possible security issue, but since this
is the first kernel with it, should be fine to just put it in now"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/qxl: add missing access check for execbuffer ioctl
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph fix from Sage Weil:
"This is a recently spotted regression in the snapshot behavior...
It turns out several tests weren't being run in the nightlies so this
took a while to spot"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: send snapshot context with writes
Reported-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Sending the right snapshot context with each write is required for
snapshots to work. Due to the ordering of calls, the snapshot context
is never set for any requests. This causes writes to the current
version of the image to be reflected in all snapshots, which are
supposed to be read-only.
This happens because rbd_osd_req_format_write() sets the snapshot
context based on obj_request->img_request. At this point, however,
obj_request->img_request has not been set yet, to the snapshot context
is set to NULL. Fix this by moving rbd_img_obj_request_add(), which
sets obj_request->img_request, before the osd request formatting
calls.
This resolves:
http://tracker.ceph.com/issues/5465
Reported-by: Karol Jurak <karol.jurak@gmail.com>
Signed-off-by: Josh Durgin <josh.durgin@inktank.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Reviewed-by: Alex Elder <elder@linaro.org>
This patch fixes a critical bug that was introduced in 3.9
related to VLAN tagging FCoE frames.
3.10 fixes
Pull networking fixes from David Miller:
1) Found via trinity:
If you connect up an ipv6 socket to an ipv4 mapped address then an
ipv6 one, sendmsg() can croak because ip6_sk_dst_check() assumes the
route cached in the socket is an ipv6 one. In this case there is an
ipv4 route attached, so it gets stomped on.
Reported by Dave Jones and Hannes Frederic Sowa, fixed by Eric
Dumazet.
2) AF_KEY notifications leak some kernel memory to userspace, fix from
Mathias Krause.
3) DLCI calls __dev_get_by_name() without proper locking, and dlci_del
doesn't validate that the device being deleted is actually a DLCI
one. Fixes from Li Zefan.
4) Length check on bluetooth l2cap information responses is wrong, each
response type has a different lenth, so we should make sure it's in
a given range rather than enforce one single valid length. From
Jaganath Kanakkassery.
5) Receive FIFO overflow is really easy to trigger in stress scenerios
in the sh_eth driver, but the event isn't being handled properly at
all. Specifically, the mask of error interrupts doesn't include the
event so we never clear it, resulting in the driver becomming wedged
processing an interrupt that never gets cleared.
Fix from Sergei Shtylyov.
6) qlcnic sleeps while holding a spinlock, use mdelay() instead of
msleep(). From Shahed Shaikh.
7) Missing curly braces causes SIP netfilter NAT module to always drop
packets. Fix from Balazs Peter Odor.
8) ipt_ULOG in netfilter passes the wrong value to timer setup, causing
the timer to dereference crap when it fires. Fix from Gao Feng.
9) Missing RCU protection around txq->axq_acq traversal in
ath_txq_schedule(). Fix from Felix Fietkau.
10) Idle state transition test in ath9k_htc_config() is reversed, fix
from Sujith Manoharan.
11) IPV6 forwarding handles unicast Router Alert packets incorrectly.
It tests the wrong option state. Previously opt->ra being non-zero
indicated a router alert marking in the SKB, but now it's indicated
by a bit in opt->flags. Fix from YOSHIFUJI Hideaki.
12) SKB leak in GRE tunnel GSO handling, from Eric Dumazet.
13) get_user_pages_fast() error handling in TUN and MACVTAP use the same
local variable for the base index and the loop iterator for page
traversal, oops! Fix from Michael S Tsirkin.
14) ipv6_get_lladdr() can fail, and we must therefore check it's return
value in inet6_set_iftoken(). For from Hannes Frederic Sowa.
15) If you change an interface name and meanwhile can sneak in something
that looks up the name (like SO_BINDTODEVICE or SIOCGIFNAME) we can
deadlock with CONFIG_PREEMPT=n. Fix this by providing a helper
function that properly uses raw_seqcount_begin(). From Nicolas
Schichan.
16) Chain noise calibration test is inverted in iwlwifi, fix from
Nikolay Martynov.
17) Properly set TX iwlwifi descriptor flags for back requests. Fix
from Emmanuel Grumbach.
18) We can't assume skb_transport_header() is set in xt_TCPOPTSTRAP
module, fix from Pablo Neira Ayuso.
19) Some crummy APs don't provide the proper High Throughput info in
association response frames. Add a workaround by assume we'll use
whatever is in the beacon/probe. Fix from Johannes Berg.
20) mac80211 call to rate_idx_match_mask() swaps two arguments (mask and
channel width). Fix from Simon Wunderlich.
21) xt_TCPMSS (like xt_TCPOPTSTRAP) must not try to handle fragmented
frames. Fix from Phil Oester.
22) Fix rate control regression causing iwlwifi/iwlegacy chips to use
1Mbit/s on pre-11n networks. From Moshe Benji and Stanslaw Gruszka.
23) Disable brcmsmac power-save functions, they cause regressions. From
Arend van Spriel.
24) Enforce a sane minimum MTU in l2cap_build_cmd() otherwise we can
easily crash. Fix from Anderson Lizardo.
25) If a learning packet arrives during vxlan_stop() we crash, easily
fixed by checking netif_running(). From Stephen Hemminger.
26) Static vxlan FDB entries should not be migrated, also from Stephen.
27) skb_clone() failures not handled in vxlan_xmit(), oops. Also from
Stephen.
28) Add minimal driver for AR816x/AR817x ethernet chips, from Johannes
Berg.
29) Fix regression in userspace VLAN acceleration control, added by the
802.1ad support changes. Fix from Fernando Luis Vazquez Cao.
30) Interval selection for MLD queries in the bridging code was
reversed. Fix from Linus Lüssing.
31) ipv6's ndisc_send_redirect() erroneously writes to the packet we
received not the packet we are building to send out. Fix from
Matthias Schiffer.
32) Don't free netdev before unregistering it, in usb_8dev can driver.
From Marc Kleine-Budde.
33) Fix nl80211 attribute buffer races, from Johannes Berg.
34) Although netlink_diag.h is under uapi/ it isn't present in Kbuild.
35) Wrong address and family passed to MD5 key lookups in TCP, from
Aydin Arik.
36) phy_type attribute created by SFC driver should not be writable.
From Ben Hutchings.
37) Receive/Transmit queue allocations in pxa168_eth and mv643xx_eth
should use kzalloc(). Otherwise if setup fails half-way, we'll
dereference garbage when trying to teardown the rings. From Lubomir
Rintel.
38) Fix double-allocation of dst (resulting in unfreeable net device) in
ipv6's init_loopback(). From Gao Feng.
39) Fix fragmentation handling SKB leak in netfilter conntrack, we were
freeing the wrong skb pointer. From Phil Oester.
40) Don't report "-1" (SPEED_UNKNOWN) in bond_miimon_commit(), from
Nikolay Aleksandrov.
41) davinci_cpdma doesn't check for DMA mapping errors, letting the
device scribble to random addresses. From Sebastian Siewior.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (69 commits)
dlci: validate the net device in dlci_del()
dlci: acquire rtnl_lock before calling __dev_get_by_name()
af_key: fix info leaks in notify messages
ipv6: ip6_sk_dst_check() must not assume ipv6 dst
net: fix kernel deadlock with interface rename and netdev name retrieval.
net/tg3: Avoid delay during MMIO access
ipv6: check return value of ipv6_get_lladdr
macvtap: fix recovery from gup errors
tun: fix recovery from gup errors
gre: fix a possible skb leak
ipv6: Process unicast packet with Router Alert by checking flag in skb.
ath9k_htc: Handle IDLE state transition properly
ath9k: fix an RCU issue in calling ieee80211_get_tx_rates
netfilter: ipt_ULOG: fix incorrect setting of ulog timer
netfilter: ctnetlink: send event when conntrack label was modified
netfilter: nf_nat_sip: fix mangling
qlcnic: Do not sleep while holding spinlock
drivers: net: cpsw: fix compilation error with cpsw driver
tcp: doc : fix the syncookies default value
sh_eth: fix misreporting of transmit abort
Pull i915 drm fixes from Dave Airlie:
"These should be the last two fixes for i915, one is for a fence leak
killing X on some older GPUs, and one is a late regression partial
revert for an swiotlb/xen/i915 interaction, Konrad has promised to
figure out the proper answer, and this patch is the best thing to do
at this stage to avoid regressing"
drm/i915: make compact dma scatter lists creation work with SWIOTLB backend.
drm/i915: Restore fences after resume and GPU resets
We triggered an oops while running trinity with 3.4 kernel:
BUG: unable to handle kernel paging request at 0000000100000d07
IP: [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci]
PGD 640c0d067 PUD 0
Oops: 0000 [#1] PREEMPT SMP
CPU 3
Pid: 7302, comm: trinity-child3 Not tainted 3.4.24.09+ 40 Huawei Technologies Co., Ltd. Tecal RH2285 /BC11BTSA
RIP: 0010:[<ffffffffa0109738>] [<ffffffffa0109738>] dlci_ioctl+0xd8/0x2d4 [dlci]
Call Trace:
[<ffffffff8137c5c3>] sock_ioctl+0x153/0x280
[<ffffffff81195494>] do_vfs_ioctl+0xa4/0x5e0
[<ffffffff8118354a>] ? fget_light+0x3ea/0x490
[<ffffffff81195a1f>] sys_ioctl+0x4f/0x80
[<ffffffff81478b69>] system_call_fastpath+0x16/0x1b
It's because the net device is not a dlci device.
Reported-by: Li Jinyue <lijinyue@huawei.com>
Signed-off-by: Li Zefan <lizefan@huawei.com>
Cc: stable@vger.kernel.org
Otherwise the net device returned can be freed at anytime.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator fix from Mark Brown:
"Fix module loading for tps6586x.
A simple one liner fix to make module loading work for distros
(product specific kernels tend to have things built in)"
* tag 'regulator-v3.10-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator:
mfd: tps6586x: correct device name of the regulator cell
Pull GPIO regression fix from Grant Likely:
"It took a while to work out the correct solution to this regression.
It is sorted now. This branch was constructed and tested by Tony.
I've verified that it builds and signed the tag"
* tag 'gpio-for-linus' of git://git.secretlab.ca/git/linux:
gpio/omap: don't use linear domain mapping for OMAP1
Pull late power management and ACPI fixes from Rafael Wysocki:
"Sorry about the timing of this, but ACPI-based docking stations with
PCI devices on them and ATA bays would be hardly usable with 3.10
without it. We've been working on these fixes for the last couple of
weeks and everyone involved appears to be reasonably comfortable with
them now.
The PM part is one fix for a cpufreq regression introduced recently
- Fix for an ACPI dock regression introduced by the recent rework of
the ACPI-based PCI hotplug code (acpiphp) that caused it to be
initialized before the ACPI dock driver, which is incorrect (ACPI
dock has to be initialized before acpiphp so that acpiphp can
register PCI devices on docking stations with it for PCI hotplug on
re-dock to work). From Jiang Liu.
- Fix for PCI resources allocation in the ACPI-based PCI hotplug code
(acpiphp) that makes it use the same PCI resources assignment rules
during runtime hotplug that are used during boot (the BIOS' choices
are now respected in both cases). This prevents PCI resource
allocation failures during hotplug from happening in some cases.
From Jiang Liu.
- Fix for ordering and synchronization issues during hot-removal of
PCI devices on docking stations. It makes the ACPI dock code carry
out the PCI devices removal synchronously during undock instead of
spawning a separate asynchronous work item to remove each of them
without even bothering to wait for all those work items to
complete. The hot-addition part is changed analogously.
- Fix for a regression (introduced a few releases ago) that removed
the code to register a hotplug notificaion handler for for ATA
ports/devices inadvertently which prevented ATA bays hotplug from
working. The missing code is added back with some improvements.
From Aaron Lu.
- Fix for a recent cpufreq regression causing a NULL pointer
dereference to trigger in od_set_powersave_bias() in some
situations from Jacob Shin"
* tag 'pm+acpi-3.10-late' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
cpufreq: fix NULL pointer deference at od_set_powersave_bias()
libata-acpi: add back ACPI based hotplug functionality
ACPI / dock / PCI: Synchronous handling of dock events for PCI devices
PCI / ACPI: Use boot-time resource allocation rules during hotplug
ACPI / dock: Initialize ACPI dock subsystem upfront
git://git.kernel.org/pub/scm/linux/kernel/git/rwlove/fcoe
Pull FCoE fix from Robert W Love:
"This patch fixes a critical bug that was introduced in 3.9 related to
VLAN tagging FCoE frames"
* tag 'critical_fix_for_3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/rwlove/fcoe:
fcoe: Use correct API to set vlan tag for FCoE Ethertype skbs
"This fixes another problem with using v2 images on 3.10 due to the
order in which fields are read from the image header.
Hopefully this is the last one"
rbd: fetch object order before using it
Commit ede4d7a5 ("gpio/omap: convert gpio irq domain to linear mapping")
converted the OMAP GPIO driver to use a linear mapping for the GPIO IRQ
domain instead of using a legacy mapping. Not using a legacy mapping has
a number of benefits but it requires the platform to support SPARSE_IRQ
which currently is not supported on OMAP1.
So this change caused a regression on OMAP1 platforms [1].
Since this issue is not present on all OMAP2+ platforms, there is no need to
revert the driver to use legacy domain mapping for all the platforms.
[1]: http://www.mail-archive.com/linux-omap@vger.kernel.org/msg89005.html
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
When the EEH error is the result of a fenced host bridge, MMIO accesses
can be very slow (milliseconds) to timeout and return all 1's,
thus causing the driver various timeout loops to take way too long and
trigger soft-lockup warnings (in addition to taking minutes to recover).
It might be worthwhile to check if for any of these cases, ffffffff is
a valid possible value, and if not, bail early since that means the HW
is either gone or isolated. In the meantime, checking that the PCI channel
is offline would be workaround of the problem.
Cc: <stable@vger.kernel.org> # v3.0+
Signed-off-by: Gavin Shan <shangw@linux.vnet.ibm.com>
get user pages might fail partially in macvtap zero copy
mode. To recover we need to put all pages that we got,
but code used a wrong index resulting in double-free
errors.
Reported-by: Brad Hubbard <bhubbard@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Acked-by: Jason Wang <jasowang@redhat.com>
get user pages might fail partially in tun zero copy
errors.
* pm-fixes:
When initializing the default powersave_bias value, we need to first
make sure that this policy is running the ondemand governor.
Reported-and-tested-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Jacob Shin <jacob.shin@amd.com>
rbd_dev_v2_header_onetime() fetches striping information, and
checks whether the image can be read by compariing the stripe unit
to the object size. It determines the object size by shifting
the object order, which is 0 at this point since it has not been
read yet. Move the call to get the image size and object order
before rbd_dev_v2_header_onetime() so it is set before use.
fcoe_xmit was coded such that it would skip the vlan net device/layer
and instead set some vlan flags and transmit on the real net device.
The real net device has code that would add the vlan tag for fcoe skbs.
This avoids some extra processing for data frames and provides a small
performance improvement.
Since fcoe_xmit was not using the vlan net device, __vlan_put_tag
within the real net device's xmit routine was ultimately being
called to set the vlan tag.
With the below change the behavior of __vlan_put_tag changed slightly,
it now sets the skb->protocol = vlan_proto. vlan_proto was not a field
being set by fcoe_xmit, so the skb->protocol is now not being set to
ETH_P_8021Q, as it should be.
This patch converts fcoe_xmit to use the vlan_put_tag routine which
will tag the skb and fcoe will continue to transmit fcoe skbs on the
real net device.
For reference, the below change was the one that altered the
__vlan_put_tag behavior.
commit 86a9bad3ab6b6f858fd4443b48738cabbb6d094c
Author: Patrick McHardy <kaber@trash.net>
Date: Fri Apr 19 02:04:30 2013 +0000
net: vlan: add protocol argument to packet tagging functions
Add a protocol argument to the VLAN packet tagging functions. In case of HW
tagging, we need that protocol available in the ndo_start_xmit functions,
so it is stored in a new field in the skb. The new field fits into a hole
(on 64 bit) and doesn't increase the sks's size.
Signed-off-by: Robert Love <robert.w.love@intel.com>
Acked-by: John Fastabend <john.r.fastabend@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi
Pull spi updates from Mark Brown:
"A few last minute SPI updates: fix a missized allocation and use
atomic allocations in atomic context in the PXA driver, and fix the
checking of return codes in the S3C64xx driver which caused spurious
errors under heavy load."
* tag 'spi-v3.10-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi:
spi/pxa2xx: fix memory corruption due to wrong size used in devm_kzalloc()
spi/pxa2xx: use GFP_ATOMIC in sg table allocation
spi: s3c64xx: Fix pm_runtime_get_sync() return value check
Git commit 90797e6d1ec0dfde6ba62a48b9ee3803887d6ed4
("drm/i915: create compact dma scatter lists for gem objects") makes
certain assumptions about the under laying DMA API that are not always
correct.
On a ThinkPad X230 with an Intel HD 4000 with Xen during the bootup
I see:
[drm:intel_pipe_set_base] *ERROR* pin & fence failed
[drm:intel_crtc_set_config] *ERROR* failed to set mode on [CRTC:3], err = -28
Bit of debugging traced it down to dma_map_sg failing (in
i915_gem_gtt_prepare_object) as some of the SG entries were huge (3MB).
That unfortunately are sizes that the SWIOTLB is incapable of handling -
the maximum it can handle is a an entry of 512KB of virtual contiguous
memory for its bounce buffer. (See IO_TLB_SEGSIZE).
Previous to the above mention git commit the SG entries were of 4KB, and
the code introduced by above git commit squashed the CPU contiguous PFNs
in one big virtual address provided to DMA API.
This patch is a simple semi-revert - were we emulate the old behavior
if we detect that SWIOTLB is online. If it is not online then we continue
on with the new compact scatter gather mechanism.
An alternative solution would be for the the '.get_pages' and the
i915_gem_gtt_prepare_object to retry with smaller max gap of the
amount of PFNs that can be combined together - but with this issue
discovered during rc7 that might be too risky.
Reported-and-Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
CC: Chris Wilson <chris@chris-wilson.co.uk>
CC: Imre Deak <imre.deak@intel.com>
CC: Daniel Vetter <daniel.vetter@ffwll.ch>
CC: David Airlie <airlied@linux.ie>
CC: <dri-devel@lists.freedesktop.org>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
One remaining regression fix for i915. I've left it in -fixes for more
than a week since it's in tricky code, and it took us a few kernel
releases to notice the regression at all. The fence leak is especially
annoying on gen2/3 and will kill userspace there quickly. For extra
paranoia we've added a WARN in -next to catch this, things seem to be
solid now.
* tag 'drm-intel-fixes-2013-06-24' of git://people.freedesktop.org/~danvet/drm-intel:
Commit 30dcf76acc69 "libata: migrate ACPI code over to new bindings"
mistakenly dropped the code to register hotplug notificaion handler
for ATA port/devices, causing regression for people using ATA bay,
as kernel bug #59871 shows.
Fix this by adding back the hotplug notification handler registration
code. Since this code has to be run once and notification needs to
be installed on every ATA port/devices handle no matter if there is
actual device attached, we can't do this in binding time for ATA
device ACPI handle, as the binding only occurs when a SCSI device is
created, i.e. there is device attached. So introduce the
ata_acpi_hotplug_init() function to loop scan all ATA ACPI handles
and if it is available, install the notificaion handler for it during
ATA init time.
With the ATA ACPI handle binding to SCSI device tree, it is possible
now that when the SCSI hotplug work removes the SCSI device, the ACPI
unbind function will find that the corresponding ACPI device has
already been deleted by dock driver, causing a scaring message like:
[ 128.263966] scsi 4:0:0:0: Oops, 'acpi_handle' corrupt
Fix this by waiting for SCSI hotplug task finish in our notificaion
handler, so that the removal of ACPI device done in ACPI unbind
function triggered by the removal of SCSI device is run earlier when
ACPI device is still available.
[rjw: Rebased]
References: https://bugzilla.kernel.org/show_bug.cgi?id=59871
Reported-bisected-and-tested-by: Dirk Griesbach <spamthis@freenet.de>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Tejun Heo <tj@kernel.org>
Cc: 3.6+ <stable@vger.kernel.org>
Make sure that a chip reset is done when IDLE is turned
off - this fixes authentication timeouts.
Reported-by: Ignacy Gawedzki <i@lri.fr>
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
ath_txq_schedule is called outside of the drv_tx call, so it needs RCU
protection.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Change the device name of the regulator function to the one chosen for
MODULE_ALIAS. This fixes kernel auto-module loading for the regulator function.
Signed-off-by: Marc Dietrich <marvin24@gmx.de>
Signed-off-by: Mark Brown <broonie@linaro.org>
The interactions between the ACPI dock driver and the ACPI-based PCI
hotplug (acpiphp) are currently problematic because of ordering
issues during hot-remove operations.
First of all, the current ACPI glue code expects that physical
devices will always be deleted before deleting the companion ACPI
device objects. Otherwise, acpi_unbind_one() will fail with a
warning message printed to the kernel log, for example:
[ 185.026073] usb usb5: Oops, 'acpi_handle' corrupt
[ 185.035150] pci 0000:1b:00.0: Oops, 'acpi_handle' corrupt
[ 185.035515] pci 0000:18:02.0: Oops, 'acpi_handle' corrupt
[ 180.013656] port1: Oops, 'acpi_handle' corrupt
This means, in particular, that struct pci_dev objects have to
be deleted before the struct acpi_device objects they are "glued"
with.
Now, the following happens the during the undocking of an ACPI-based
dock station:
1) hotplug_dock_devices() invokes registered hotplug callbacks to
destroy physical devices associated with the ACPI device objects
depending on the dock station. It calls dd->ops->handler() for
each of those device objects.
2) For PCI devices dd->ops->handler() points to
handle_hotplug_event_func() that queues up a separate work item
to execute _handle_hotplug_event_func() for the given device and
returns immediately. That work item will be executed later.
3) hotplug_dock_devices() calls dock_remove_acpi_device() for each
device depending on the dock station. This runs acpi_bus_trim()
for each of them, which causes the underlying ACPI device object
to be destroyed, but the work items queued up by
handle_hotplug_event_func() haven't been started yet.
4) _handle_hotplug_event_func() queued up in step 2) are executed
and cause the above failure to happen, because the PCI devices
they handle do not have the companion ACPI device objects any
more (those objects have been deleted in step 3).
The possible breakage doesn't end here, though, because
hotplug_dock_devices() may return before at least some of the
_handle_hotplug_event_func() work items spawned by it have a
chance to complete and then undock() will cause _DCK to be
evaluated and that will cause the devices handled by the
_handle_hotplug_event_func() to go away possibly while they are
being accessed.
This means that dd->ops->handler() for PCI devices should not point
to handle_hotplug_event_func(). Instead, it should point to a
function that will do the work of _handle_hotplug_event_func()
synchronously. For this reason, introduce such a function,
hotplug_event_func(), and modity acpiphp_dock_ops to point to
it as the handler.
Unfortunately, however, this is not sufficient, because if the dock
code were not changed further, hotplug_event_func() would now
deadlock with hotplug_dock_devices() that called it, since it would
run unregister_hotplug_dock_device() which in turn would attempt to
acquire the dock station's hp_lock mutex already acquired by
hotplug_dock_devices().
To resolve that deadlock use the observation that
unregister_hotplug_dock_device() won't need to acquire hp_lock
if PCI bridges the devices on the dock station depend on are
prevented from being removed prematurely while the first loop in
hotplug_dock_devices() is in progress.
To make that possible, introduce a mechanism by which the callers of
register_hotplug_dock_device() can provide "init" and "release"
routines that will be executed, respectively, during the addition
and removal of the physical device object associated with the
given ACPI device handle. Make acpiphp use two new functions,
acpiphp_dock_init() and acpiphp_dock_release(), that call
get_bridge() and put_bridge(), respectively, on the acpiphp bridge
holding the given device, for this purpose.
In addition to that, remove the dock station's list of
"hotplug devices" and make the dock code always walk the whole list
of "dependent devices" instead in such a way that the loops in
hotplug_dock_devices() and dock_event() (replacing the loops over
"hotplug devices") will take references to the list entries that
register_hotplug_dock_device() has been called for. That prevents
the "release" routines associated with those entries from being
called while the given entry is being processed and for PCI
devices this means that their bridges won't be removed (by a
concurrent thread) while hotplug_event_func() handling them is
being executed.
This change is based on two earlier patches from Jiang Liu.
References: https://bugzilla.kernel.org/show_bug.cgi?id=59501
Reported-and-tested-by: Alexander E. Patrakov <patrakov@gmail.com>
Tracked-down-by: Jiang Liu <jiang.liu@huawei.com>
Tested-by: Illya Klymov <xanf@xanf.me>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: 3.9+ <stable@vger.kernel.org>
This patch reverts commit a4791254b6625b06aa33e36304f6e8a1a4a1fdea
("qlcnic: change mdelay to msleep") which overwrote a commit
68b3f28c11bf896be32ad2a2e151aaa5f4a7c98e
("qlcnic: Fix scheduling while atomic bug")
Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com>
Signed-off-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com>
drivers/net/ethernet/ti/cpsw.c: In function 'cpsw_suspend':
drivers/net/ethernet/ti/cpsw.c:1979:26: error: 'priv' undeclared (first use in this function)
drivers/net/ethernet/ti/cpsw.c:1979:26: note: each undeclared identifier is reported only once for each function it appears in
make[4]: *** [drivers/net/ethernet/ti/cpsw.o] Error 1
The compilation error was introduced by the following commit
6d3d76f (drivers: net: cpsw: fix cpsw clock gating issue across suspend/resume)
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Due to obviously missing braces, EESR.TABT (transmit abort) interrupt may be
reported even if it hasn't happened, just when EESR.TWB (transmit descriptor
write-back) interrupt happens. Luckily (?), EESR.TWB is disabled by the driver
via the TRIMD register and all the interrupt masks, so that transmit abort is
never actually logged...
Put the braces where they should be and fix the incoherent comment, while at it.
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
EESR.RFE (receive FIFO overflow) interrupt is enabled by the driver on all SoCs
and sh_eth_error() handles it but it's not present in any initializer/assignment
of the 'eesr_err_check' field of 'struct sh_eth_cpu_data'. This leads to that
interrupt not being handled and cleared, and finally to disabling IRQ and the
driver being non-functional.
Modify DEFAULT_EESR_ERR_CHECK macro and all explicit initializers of the above
mentioned field to contain the EESR.RFE bit. Remove useless backslashes from the
initializers, while at it.
Found in the Windows INF files while investigating the
Novatel/Verizon USB-1000 device. The USB-1000 is verified as
a Gobi1K device and works with QMI after loading appropriate
firmware.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Bjørn Mork <bjorn@mork.no>
Since the DMA mapping may fail the caller should check the return value.
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
When we have BOND_LINK_UP the speed is reported unconditionally with %u
format although it can be SPEED_UNKNOWN (-1). After this patch it returns
0 in that case in an attempt to keep the existing scripts happy.
One line is intenionally left 81 chars because it gets ugly if broken.
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
Acked-by: Veaceslav Falico <vfalico@redhat.com>
Old hypervisors don't mask out timestamp capability for slave. Till slave
support will be added, need to disable capability by slave.
Signed-off-by: Amir Vadai <amirv@mellanox.com>
