Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Causes build failures with gcc 8.
Previously, lvds-drive-strength was located in a wrong node and
there was no control of the 5th lane.
The current reset-gpio support triggers an interrupt storm on platforms
using the maxtouch with level based interrupt. The Motorola Droid 4,
which I used for some of the tests is not affected, since it uses a edge
based interrupt.
This change avoids the interrupt storm by enabling the device while its
interrupt is disabled. Afterwards we wait 100ms. This is important for
two reasons: The device is unresponsive for some time (~22ms for
mxt224E) and the CHG (interrupt) line is not working properly for 100ms.
We don't need to wait for any following interrupts, since the following
mxt_initialize() checks for bootloader mode anyways.
This fixes a boot issue on GE PPD (watchdog kills device due to
interrupt storm) and does not cause regression on Motorola Droid 4.
Fixes: f657b00df22e ("Input: atmel_mxt_ts - add support for reset line")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
(cherry picked from commit ca1cd36cef00260db6b35b32d863e0c580c0488d)
Provide support for controlling reset pin. If this is not driven
correctly the device will be held in reset and will not respond.
Acked-by: Rob Herring <robh@kernel.org>
(cherry picked from commit f657b00df22e231da217ca0162a75db452475e8f)
Switch mxt_data and interrupt to resource managed allocation methods,
which cleans up the driver slightly and prepares for adding
reset GPIO support.
(cherry picked from commit 8cc8446b9b62ef954b630ed30e53bd1553e916a6)
When using the 'object' sysfs attribute, T100 is not displayed in
the output.
Signed-off-by: Maxime Roussin-Bélanger <maxime.roussinbelanger@gmail.com>
(cherry picked from commit 089b50d95948f691589cca4d81f1f8761747dbaa)
If a function declares a variable to access a structure element,
use it consistently.
(cherry picked from commit d7ddf15414dd598b9b875664e6b7aebe6c988f5d)
This reverts commit 22a2065b9a3fa6ad458e3100b66c4acaa05f2466.
Before SIOCGMIIREG was only able to access page 0 registers.
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c: In function 'nvhost_channelctl':
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c:894:11: error: 'snprintf' output may be truncated before the last format character [-Werror=format-truncation=]
"%s_%s", dev_name(&pdata->pdev->dev), name);
/build/krm/oe-core_master/build/tmp-glibc/work-shared/apalis-tk1/kernel-source/drivers/video/tegra/host/bus_client.c:893:3: note: 'snprintf' output 2 or more bytes (assuming 33) into a destination of size 32
snprintf(set_name, sizeof(set_name),
In fw version 1.2 K20 CANINTF_TX now indicates TX in progress,
not TX completed.
Parameter fw_ignore disables fw version check.
Parameter fw_reload forces k20 firmware reflash via EzPort.
This adds a driver which simulates a i2c bus with an attached EDID
memory. The memory content is read from the device tree.
This allows to simulate EDID data which may differ from an attached
display.
Hardcoded value was used before. This allows setting
drive strength values in the devicetree.
While the PCIe reset implementation seems to work it currently resets
multiple times due to not differentiating which PCIe port needs
resetting. Improve this by doing specific reset per port only.
Kernel hangs if camera capture errors are not handled to allow for a way
out of the the capture thread.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Merge NVIDIA's latest Linux for Tegra aka L4T R21.7 Linux kernel changes
from git://nv-tegra.nvidia.com/linux-3.10.git commit:
e78bb38b883c42edf81766a1d557aed74458e08f
Conflicts involved missing 24-bit LVDS support and a single whitespace
aka tab difference in drivers/video/tegra/dc/sor.c.
Data can be speculatively loaded from memory and stay in cache even
when bound check fails. This can lead to unintended information
disclosure via side-channel analysis.
To mitigate this problem, insert speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Ifc618c00cee497e6d84cac01a9b73fcecbe8f260
Signed-off-by: David Gilhooley <dgilhooley@nvidia.com>
Signed-off-by: James Huang <jamehuang@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650036
(cherry picked from commit 164f8684deb5b15a53c60a60c7d9b8e3bf5af5be)
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1682714
Reviewed-on: https://git-master.nvidia.com/r/1698611
GVS: Gerrit_Virtual_Submit
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Tested-by: Bibek Basu <bbasu@nvidia.com>
To mitigate this problem insert a speculation barrier.
bug 2039126
CVE-2017-5753
Change-Id: Ib6c4b2f99b85af3119cce3882fe35ab47509c76f
Signed-off-by: Alex Waterman <alexw@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1640500
Reviewed-on: https://git-master.nvidia.com/r/1650050
(cherry picked from commit f293fa670fd2f4fbe170f1e372e9aa237283c67a)
Reviewed-on: https://git-master.nvidia.com/r/1682715
Reviewed-on: https://git-master.nvidia.com/r/1698610
Plugging a Logitech DJ receiver with KASAN activated raises a bunch of
out-of-bound readings.
The fields are allocated up to MAX_USAGE, meaning that potentially, we do
not have enough fields to fit the incoming values.
Add checks and silence KASAN.
Bug 1823317
Bug 1935735
Change-Id: Ib3ba92572acbdd4c9ec265e54a45f92606107700
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Signed-off-by: Gagan Grover <ggrover@nvidia.com>
Signed-off-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/1259928
(cherry picked from commit fbc389a39540e177bfa4d49b9214dfe408ef2d4a)
Reviewed-on: https://git-master.nvidia.com/r/1690285
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Line discipline drivers may mistakenly misuse ldisc-related fields
when initializing. For example, a failure to initialize tty->receive_room
in the N_GIGASET_M101 line discipline was recently found and fixed [1].
Now, the N_X25 line discipline has been discovered accessing the previous
line discipline's already-freed private data [2].
Harden the ldisc interface against misuse by initializing revelant
tty fields before instancing the new line discipline.
[1]
commit fd98e9419d8d622a4de91f76b306af6aa627aa9c
Author: Tilman Schmidt <tilman@imap.cc>
Date: Tue Jul 14 00:37:13 2015 +0200
isdn/gigaset: reset tty->receive_room when attaching ser_gigaset
[2] Report from Sasha Levin <sasha.levin@oracle.com>
[ 634.336761] ==================================================================
[ 634.338226] BUG: KASAN: use-after-free in x25_asy_open_tty+0x13d/0x490 at addr ffff8800a743efd0
[ 634.339558] Read of size 4 by task syzkaller_execu/8981
[ 634.340359] =============================================================================
[ 634.341598] BUG kmalloc-512 (Not tainted): kasan: bad access detected
[ 634.405018] Call Trace:
[ 634.405277] dump_stack (lib/dump_stack.c:52)
[ 634.405775] print_trailer (mm/slub.c:655)
[ 634.406361] object_err (mm/slub.c:662)
[ 634.406824] kasan_report_error (mm/kasan/report.c:138 mm/kasan/report.c:236)
[ 634.409581] __asan_report_load4_noabort (mm/kasan/report.c:279)
[ 634.411355] x25_asy_open_tty (drivers/net/wan/x25_asy.c:559 (discriminator 1))
[ 634.413997] tty_ldisc_open.isra.2 (drivers/tty/tty_ldisc.c:447)
[ 634.414549] tty_set_ldisc (drivers/tty/tty_ldisc.c:567)
[ 634.415057] tty_ioctl (drivers/tty/tty_io.c:2646 drivers/tty/tty_io.c:2879)
[ 634.423524] do_vfs_ioctl (fs/ioctl.c:43 fs/ioctl.c:607)
[ 634.427491] SyS_ioctl (fs/ioctl.c:622 fs/ioctl.c:613)
[ 634.427945] entry_SYSCALL_64_fastpath (arch/x86/entry/entry_64.S:188)
Bug 1823317
Bug 1935735
Change-Id: Ica54faa9334c587594cc19bc9da007340fda672d
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
Reviewed-on: http://git-master/r/1259925
(cherry picked from commit 2b1401855a2bdd31556a93feba50dd0dc0bb70e8)
Reviewed-on: https://git-master.nvidia.com/r/1690300
Tested-by: Amulya Yarlagadda <ayarlagadda@nvidia.com>
If struct xc2028_config is passed without a firmware name,
the following trouble may happen:
[11009.907205] xc2028 5-0061: type set to XCeive xc2028/xc3028 tuner
[11009.907491] ==================================================================
[11009.907750] BUG: KASAN: use-after-free in strcmp+0x96/0xb0 at addr ffff8803bd78ab40
[11009.907992] Read of size 1 by task modprobe/28992
[11009.907994] =============================================================================
[11009.907997] BUG kmalloc-16 (Tainted: G W ): kasan: bad access detected
[11009.907999] -----------------------------------------------------------------------------
[11009.908008] INFO: Allocated in xhci_urb_enqueue+0x214/0x14c0 [xhci_hcd] age=0 cpu=3 pid=28992
[11009.908012] ___slab_alloc+0x581/0x5b0
[11009.908014] __slab_alloc+0x51/0x90
[11009.908017] __kmalloc+0x27b/0x350
[11009.908022] xhci_urb_enqueue+0x214/0x14c0 [xhci_hcd]
[11009.908026] usb_hcd_submit_urb+0x1e8/0x1c60
[11009.908029] usb_submit_urb+0xb0e/0x1200
[11009.908032] usb_serial_generic_write_start+0xb6/0x4c0
[11009.908035] usb_serial_generic_write+0x92/0xc0
[11009.908039] usb_console_write+0x38a/0x560
[11009.908045] call_console_drivers.constprop.14+0x1ee/0x2c0
[11009.908051] console_unlock+0x40d/0x900
[11009.908056] vprintk_emit+0x4b4/0x830
[11009.908061] vprintk_default+0x1f/0x30
[11009.908064] printk+0x99/0xb5
[11009.908067] kasan_report_error+0x10a/0x550
[11009.908070] __asan_report_load1_noabort+0x43/0x50
[11009.908074] INFO: Freed in xc2028_set_config+0x90/0x630 [tuner_xc2028] age=1 cpu=3 pid=28992
[11009.908077] __slab_free+0x2ec/0x460
[11009.908080] kfree+0x266/0x280
[11009.908083] xc2028_set_config+0x90/0x630 [tuner_xc2028]
[11009.908086] xc2028_attach+0x310/0x8a0 [tuner_xc2028]
[11009.908090] em28xx_attach_xc3028.constprop.7+0x1f9/0x30d [em28xx_dvb]
[11009.908094] em28xx_dvb_init.part.3+0x8e4/0x5cf4 [em28xx_dvb]
[11009.908098] em28xx_dvb_init+0x81/0x8a [em28xx_dvb]
[11009.908101] em28xx_register_extension+0xd9/0x190 [em28xx]
[11009.908105] em28xx_dvb_register+0x10/0x1000 [em28xx_dvb]
[11009.908108] do_one_initcall+0x141/0x300
[11009.908111] do_init_module+0x1d0/0x5ad
[11009.908114] load_module+0x6666/0x9ba0
[11009.908117] SyS_finit_module+0x108/0x130
[11009.908120] entry_SYSCALL_64_fastpath+0x16/0x76
[11009.908123] INFO: Slab 0xffffea000ef5e280 objects=25 used=25 fp=0x (null) flags=0x2ffff8000004080
[11009.908126] INFO: Object 0xffff8803bd78ab40 @offset=2880 fp=0x0000000000000001
[11009.908130] Bytes b4 ffff8803bd78ab30: 01 00 00 00 2a 07 00 00 9d 28 00 00 01 00 00 00 ....*....(......
[11009.908133] Object ffff8803bd78ab40: 01 00 00 00 00 00 00 00 b0 1d c3 6a 00 88 ff ff ...........j....
[11009.908137] CPU: 3 PID: 28992 Comm: modprobe Tainted: G B W 4.5.0-rc1+ #43
[11009.908140] Hardware name: /NUC5i7RYB, BIOS RYBDWi35.86A.0350.2015.0812.1722 08/12/2015
[11009.908142] ffff8803bd78a000 ffff8802c273f1b8 ffffffff81932007 ffff8803c6407a80
[11009.908148] ffff8802c273f1e8 ffffffff81556759 ffff8803c6407a80 ffffea000ef5e280
[11009.908153] ffff8803bd78ab40 dffffc0000000000 ffff8802c273f210 ffffffff8155ccb4
[11009.908158] Call Trace:
[11009.908162] [<ffffffff81932007>] dump_stack+0x4b/0x64
[11009.908165] [<ffffffff81556759>] print_trailer+0xf9/0x150
[11009.908168] [<ffffffff8155ccb4>] object_err+0x34/0x40
[11009.908171] [<ffffffff8155f260>] kasan_report_error+0x230/0x550
[11009.908175] [<ffffffff81237d71>] ? trace_hardirqs_off_caller+0x21/0x290
[11009.908179] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908182] [<ffffffff8155f5c3>] __asan_report_load1_noabort+0x43/0x50
[11009.908185] [<ffffffff8155ea00>] ? __asan_register_globals+0x50/0xa0
[11009.908189] [<ffffffff8194cea6>] ? strcmp+0x96/0xb0
[11009.908192] [<ffffffff8194cea6>] strcmp+0x96/0xb0
[11009.908196] [<ffffffffa13ba4ac>] xc2028_set_config+0x15c/0x630 [tuner_xc2028]
[11009.908200] [<ffffffffa13bac90>] xc2028_attach+0x310/0x8a0 [tuner_xc2028]
[11009.908203] [<ffffffff8155ea78>] ? memset+0x28/0x30
[11009.908206] [<ffffffffa13ba980>] ? xc2028_set_config+0x630/0x630 [tuner_xc2028]
[11009.908211] [<ffffffffa157a59a>] em28xx_attach_xc3028.constprop.7+0x1f9/0x30d [em28xx_dvb]
[11009.908215] [<ffffffffa157aa2a>] ? em28xx_dvb_init.part.3+0x37c/0x5cf4 [em28xx_dvb]
[11009.908219] [<ffffffffa157a3a1>] ? hauppauge_hvr930c_init+0x487/0x487 [em28xx_dvb]
[11009.908222] [<ffffffffa01795ac>] ? lgdt330x_attach+0x1cc/0x370 [lgdt330x]
[11009.908226] [<ffffffffa01793e0>] ? i2c_read_demod_bytes.isra.2+0x210/0x210 [lgdt330x]
[11009.908230] [<ffffffff812e87d0>] ? ref_module.part.15+0x10/0x10
[11009.908233] [<ffffffff812e56e0>] ? module_assert_mutex_or_preempt+0x80/0x80
[11009.908238] [<ffffffffa157af92>] em28xx_dvb_init.part.3+0x8e4/0x5cf4 [em28xx_dvb]
[11009.908242] [<ffffffffa157a6ae>] ? em28xx_attach_xc3028.constprop.7+0x30d/0x30d [em28xx_dvb]
[11009.908245] [<ffffffff8195222d>] ? string+0x14d/0x1f0
[11009.908249] [<ffffffff8195381f>] ? symbol_string+0xff/0x1a0
[11009.908253] [<ffffffff81953720>] ? uuid_string+0x6f0/0x6f0
[11009.908257] [<ffffffff811a775e>] ? __kernel_text_address+0x7e/0xa0
[11009.908260] [<ffffffff8104b02f>] ? print_context_stack+0x7f/0xf0
[11009.908264] [<ffffffff812e9846>] ? __module_address+0xb6/0x360
[11009.908268] [<ffffffff8137fdc9>] ? is_ftrace_trampoline+0x99/0xe0
[11009.908271] [<ffffffff811a775e>] ? __kernel_text_address+0x7e/0xa0
[11009.908275] [<ffffffff81240a70>] ? debug_check_no_locks_freed+0x290/0x290
[11009.908278] [<ffffffff8104a24b>] ? dump_trace+0x11b/0x300
[11009.908282] [<ffffffffa13e8143>] ? em28xx_register_extension+0x23/0x190 [em28xx]
[11009.908285] [<ffffffff81237d71>] ? trace_hardirqs_off_caller+0x21/0x290
[11009.908289] [<ffffffff8123ff56>] ? trace_hardirqs_on_caller+0x16/0x590
[11009.908292] [<ffffffff812404dd>] ? trace_hardirqs_on+0xd/0x10
[11009.908296] [<ffffffffa13e8143>] ? em28xx_register_extension+0x23/0x190 [em28xx]
[11009.908299] [<ffffffff822dcbb0>] ? mutex_trylock+0x400/0x400
[11009.908302] [<ffffffff810021a1>] ? do_one_initcall+0x131/0x300
[11009.908306] [<ffffffff81296dc7>] ? call_rcu_sched+0x17/0x20
[11009.908309] [<ffffffff8159e708>] ? put_object+0x48/0x70
[11009.908314] [<ffffffffa1579f11>] em28xx_dvb_init+0x81/0x8a [em28xx_dvb]
[11009.908317] [<ffffffffa13e81f9>] em28xx_register_extension+0xd9/0x190 [em28xx]
[11009.908320] [<ffffffffa0150000>] ? 0xffffffffa0150000
[11009.908324] [<ffffffffa0150010>] em28xx_dvb_register+0x10/0x1000 [em28xx_dvb]
[11009.908327] [<ffffffff810021b1>] do_one_initcall+0x141/0x300
[11009.908330] [<ffffffff81002070>] ? try_to_run_init_process+0x40/0x40
[11009.908333] [<ffffffff8123ff56>] ? trace_hardirqs_on_caller+0x16/0x590
[11009.908337] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908340] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908343] [<ffffffff8155e926>] ? kasan_unpoison_shadow+0x36/0x50
[11009.908346] [<ffffffff8155ea37>] ? __asan_register_globals+0x87/0xa0
[11009.908350] [<ffffffff8144da7b>] do_init_module+0x1d0/0x5ad
[11009.908353] [<ffffffff812f2626>] load_module+0x6666/0x9ba0
[11009.908356] [<ffffffff812e9c90>] ? symbol_put_addr+0x50/0x50
[11009.908361] [<ffffffffa1580037>] ? em28xx_dvb_init.part.3+0x5989/0x5cf4 [em28xx_dvb]
[11009.908366] [<ffffffff812ebfc0>] ? module_frob_arch_sections+0x20/0x20
[11009.908369] [<ffffffff815bc940>] ? open_exec+0x50/0x50
[11009.908374] [<ffffffff811671bb>] ? ns_capable+0x5b/0xd0
[11009.908377] [<ffffffff812f5e58>] SyS_finit_module+0x108/0x130
[11009.908379] [<ffffffff812f5d50>] ? SyS_init_module+0x1f0/0x1f0
[11009.908383] [<ffffffff81004044>] ? lockdep_sys_exit_thunk+0x12/0x14
[11009.908394] [<ffffffff822e6936>] entry_SYSCALL_64_fastpath+0x16/0x76
[11009.908396] Memory state around the buggy address:
[11009.908398] ffff8803bd78aa00: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908401] ffff8803bd78aa80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908403] >ffff8803bd78ab00: fc fc fc fc fc fc fc fc 00 00 fc fc fc fc fc fc
[11009.908405] ^
[11009.908407] ffff8803bd78ab80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908409] ffff8803bd78ac00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[11009.908411] ==================================================================
In order to avoid it, let's set the cached value of the firmware
name to NULL after freeing it. While here, return an error if
the memory allocation fails.
Bug 1823317
Bug 1935735
Change-Id: I1825fc7eb08bd458ed5413fea8b47de539c9b23f
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Reviewed-on: https://git-master.nvidia.com/r/1690296
In sg_common_write(), we free the block request and return -ENODEV if
the device is detached in the middle of the SG_IO ioctl().
Unfortunately, sg_finish_rem_req() also tries to free srp->rq, so we
end up freeing rq->cmd in the already free rq object, and then free
the object itself out from under the current user.
This ends up corrupting random memory via the list_head on the rq
object. The most common crash trace I saw is this:
kernel BUG at block/blk-core.c:1420!
Call Trace:
[<ffffffff81281eab>] blk_put_request+0x5b/0x80
[<ffffffffa0069e5b>] sg_finish_rem_req+0x6b/0x120 [sg]
[<ffffffffa006bcb9>] sg_common_write.isra.14+0x459/0x5a0 [sg]
[<ffffffff8125b328>] ? selinux_file_alloc_security+0x48/0x70
[<ffffffffa006bf95>] sg_new_write.isra.17+0x195/0x2d0 [sg]
[<ffffffffa006cef4>] sg_ioctl+0x644/0xdb0 [sg]
[<ffffffff81170f80>] do_vfs_ioctl+0x90/0x520
[<ffffffff81258967>] ? file_has_perm+0x97/0xb0
[<ffffffff811714a1>] SyS_ioctl+0x91/0xb0
[<ffffffff81602afb>] tracesys+0xdd/0xe2
RIP [<ffffffff81281e04>] __blk_put_request+0x154/0x1a0
The solution is straightforward: just set srp->rq to NULL in the
failure branch so that sg_finish_rem_req() doesn't attempt to re-free
it.
Additionally, since sg_rq_end_io() will never be called on the object
when this happens, we need to free memory backing ->cmd if it isn't
embedded in the object itself.
KASAN was extremely helpful in finding the root cause of this bug.
Bug 1823317
Bug 1935735
Change-Id: I883243dce583cd79e28facaa2cdd81157b293d74
Signed-off-by: Calvin Owens <calvinowens@fb.com>
Acked-by: Douglas Gilbert <dgilbert@interlog.com>
Reviewed-on: http://git-master/r/1259958
(cherry picked from commit b49da4529988ca02bddaed8091a7f5e91105970a)
Reviewed-on: https://git-master.nvidia.com/r/1690295
A malicious application can take advantage of the ION kmalloc heap
to create a specific memory chunk size to exercise a rowhammer
attack on the physical hardware.
The fix is designed to disable ION heap type.
CVE-2016-6728: A-30400942
Bug 1823317
Change-Id: I6b6d891a85da0c175f88cc1a3e48875796db80d4
Reviewed-on: https://git-master.nvidia.com/r/1690291
bug 2039126
Change-Id: Id1908c3058c9ecc0dfb4f2d85440a8d36db45db5
Reviewed-on: https://git-master.nvidia.com/r/1650029
(cherry picked from commit 7a0213eca150614fe88d197a09d461fff6168652)
Reviewed-on: https://git-master.nvidia.com/r/1660781
bug 2039126
CVE-2017-5753
Change-Id: Id85eb9c91932f358dd999b28dd53d7788b37ea04
Reviewed-on: https://git-master.nvidia.com/r/1640356
Reviewed-on: https://git-master.nvidia.com/r/1650014
(cherry picked from commit 25bd9436b11f41e23048c9515deae97900a46669)
Reviewed-on: https://git-master.nvidia.com/r/1660780
Tested-by: Winnie Hsu <whsu@nvidia.com>
Bug 1964290
CVE-2017-5753
Change-Id: I7382dbcc6e9f352fafd457301beafe753925f3c4
Signed-off-by: Hien Goi <hgoi@nvidia.com>
Reviewed-on: https://git-master.nvidia.com/r/1650791
(cherry picked from commit 5cabd53985a30aa818896abdb64564a74c09ab9c)
Reviewed-on: https://git-master.nvidia.com/r/1660772
When a device is shut down, make sure to disable the backlight. If it
stays lit, it gives the impression that the device hasn't turned off.
Furthermore keeping the backlight on may consume power, which is not
what users expect when they shut down a device.
Signed-off-by: Thierry Reding <treding@nvidia.com>
(cherry picked from commit 5f33b896246a2d9bdf01352de11d4dab96ba2fc9)
No need to have a specific OOM message, since there is generic MM out of memory
message in place.
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
(cherry picked from commit ca7a97add4d4a7b0602b3bd1eff5c89da8636713)
I forgot to remove this during earlier cleanup patches and only checked
various builds for errors, not warnings.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
(cherry picked from commit 73d4e2b82b4bb1571b1a7f97012c0db8a0faef42)
Use SIMPLE_DEV_PM_OPS macro will initialize the member "freeze"
and "thaw" of pwm_backlight_pm_ops as below,
.freeze = suspend_fn,
.thaw = resume_fn,
then during the process of making hibernation snapshot, screen
will be blank at the moment of freezing, and then light at the
moment of thawing.
this is not the right user experience for suspending to disk.
so this patch drops freeze and thaw callback, make the LCD is
always lighting before the final shutdown.
Signed-off-by: Huayi Li <huayi.li@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
(cherry picked from commit 1dea1fd09246ada581a99d0669108eea94b7bfee)
Split adjustment of the brightness (by changing the PWM duty cycle) from
the power on sequence. This fixes an issue where the brightness can no
longer be updated once the backlight has been enabled.
Reported-by: Marc Dietrich <marvin24@gmx.de>
(cherry picked from commit e4bfeda96872bfe6015cd360008b77cd3b981b2b)
Currently the driver assumes that the values specified in the
brightness-levels device tree property increase as they are parsed from
left to right. But boards that invert the signal between the PWM output
and the backlight will need to specify decreasing brightness-levels.
This patch removes the assumption that the last element of the array is
the maximum value, and instead searches the array for the maximum value
and uses that in the duty cycle calculation.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
(cherry picked from commit 8f43e18e2769b3b28383903d501b4da29e388aad)
Backlights require a power supply to work properly. This commit adds a
regulator to power up and power down the backlight.
(cherry picked from commit 22ceeee16eb8f0d04de3ef43a5174fb30ec18af9)
Make use of the new enable_gpio field and allow it to be set from DT as
well. Now that all legacy users of platform data have been converted to
initialize this field to an invalid value, it is safe to use the field
from the driver.
(cherry picked from commit 8265b2e4e62632b01f998095d1bbda4d281629fe)
Follow up patches will add support for more complex means of powering
the backlight on and off such as using a regulator. To prevent calls to
the regulator API from becoming unbalanced, keep track of the enabled
state internally.
(cherry picked from commit 97c38437115aa0c3fb2d50c488814b503ba529e0)
In preparation for adding an optional regulator and enable GPIO to the
driver, split the power on and power off sequences into separate
functions to reduce code duplication at the multiple call sites.
(cherry picked from commit 62b744a87c1170b339f993aa3cfb22465974816a)
Add more blank lines to increase readability. While at it, remove a
trailing blank line at the end of the file.
(cherry picked from commit 668e63c6701d486c68b49ffffc0e5b7de1a2e95c)
Use the wrapper function for retrieving the platform data instead of
accessing dev->platform_data directly. This is a cosmetic change to
make the code simpler and enhance the readability.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
(cherry picked from commit c512794cada491e008eeca822af7e4ad5db72a56)
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
This reverts commit 153a5d54d1a10c5a35f6923e0c6423430d2c7c89.
