path: root/drivers
2018-03-28apalis-tk1: handle backlight in the device treeApalis-TK1_LXDE-Image_2.8b2.97-20180331toradex_tk1_l4t_r21.6Dominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-28pwm-backlight: Disable backlight on shutdownThierry Reding
When a device is shut down, make sure to disable the backlight. If it stays lit, it gives the impression that the device hasn't turned off. Furthermore keeping the backlight on may consume power, which is not what users expect when they shut down a device. Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 5f33b896246a2d9bdf01352de11d4dab96ba2fc9)
2018-03-28backlight: pwm_bl: Remove error message upon devm_kzalloc() failureFabio Estevam
No need to have a specific OOM message, since there is generic MM out of memory message in place. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> (cherry picked from commit ca7a97add4d4a7b0602b3bd1eff5c89da8636713)
2018-03-28pwm-backlight: Remove unused variableThierry Reding
I forgot to remove this during earlier cleanup patches and only checked various builds for errors, not warnings. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> (cherry picked from commit 73d4e2b82b4bb1571b1a7f97012c0db8a0faef42)
2018-03-28pwm_backlight: avoid short blank screen while doing hibernationHuayi Li
Use SIMPLE_DEV_PM_OPS macro will initialize the member "freeze" and "thaw" of pwm_backlight_pm_ops as below, .freeze = suspend_fn, .thaw = resume_fn, then during the process of making hibernation snapshot, screen will be blank at the moment of freezing, and then light at the moment of thawing. this is not the right user experience for suspending to disk. so this patch drops freeze and thaw callback, make the LCD is always lighting before the final shutdown. Signed-off-by: Huayi Li <huayi.li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Thierry Reding <thierry.reding@gmail.com> (cherry picked from commit 1dea1fd09246ada581a99d0669108eea94b7bfee)
2018-03-28pwm-backlight: Fix brightness adjustmentThierry Reding
Split adjustment of the brightness (by changing the PWM duty cycle) from the power on sequence. This fixes an issue where the brightness can no longer be updated once the backlight has been enabled. Reported-by: Marc Dietrich <marvin24@gmx.de> Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit e4bfeda96872bfe6015cd360008b77cd3b981b2b)
2018-03-28pwm-backlight: Allow for non-increasing brightness levelsMike Dunn
Currently the driver assumes that the values specified in the brightness-levels device tree property increase as they are parsed from left to right. But boards that invert the signal between the PWM output and the backlight will need to specify decreasing brightness-levels. This patch removes the assumption that the last element of the array is the maximum value, and instead searches the array for the maximum value and uses that in the duty cycle calculation. Signed-off-by: Mike Dunn <mikedunn@newsguy.com> Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 8f43e18e2769b3b28383903d501b4da29e388aad)
2018-03-28pwm-backlight: Add power supply supportThierry Reding
Backlights require a power supply to work properly. This commit adds a regulator to power up and power down the backlight. Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 22ceeee16eb8f0d04de3ef43a5174fb30ec18af9)
2018-03-28pwm-backlight: Use new enable_gpio fieldThierry Reding
Make use of the new enable_gpio field and allow it to be set from DT as well. Now that all legacy users of platform data have been converted to initialize this field to an invalid value, it is safe to use the field from the driver. Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 8265b2e4e62632b01f998095d1bbda4d281629fe)
2018-03-28pwm-backlight: Track enable stateThierry Reding
Follow up patches will add support for more complex means of powering the backlight on and off such as using a regulator. To prevent calls to the regulator API from becoming unbalanced, keep track of the enabled state internally. Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 97c38437115aa0c3fb2d50c488814b503ba529e0)
2018-03-28pwm-backlight: Refactor backlight power on/offThierry Reding
In preparation for adding an optional regulator and enable GPIO to the driver, split the power on and power off sequences into separate functions to reduce code duplication at the multiple call sites. Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 62b744a87c1170b339f993aa3cfb22465974816a)
2018-03-28pwm-backlight: Improve readabilityThierry Reding
Add more blank lines to increase readability. While at it, remove a trailing blank line at the end of the file. Signed-off-by: Thierry Reding <treding@nvidia.com> (cherry picked from commit 668e63c6701d486c68b49ffffc0e5b7de1a2e95c)
2018-03-28backlight: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> (cherry picked from commit c512794cada491e008eeca822af7e4ad5db72a56)
2018-03-28Revert "video: backlight: pwm_bl: add pwm_gpio"Dominik Sliwa
This reverts commit 95730406a0e3bbd7f862718782924a3c367845a1.
2018-03-28Revert "video: backlight: EDP client for backlight"Dominik Sliwa
This reverts commit 74df06fb565b7250bc86d79727b66bb02259d54c.
2018-03-28Revert "EDP: remove old system EDP framework (pwm backlight driver)"Dominik Sliwa
This reverts commit 08a13bacb43f206239ae0f1ccbe37325993e2b1b.
2018-03-28Revert "backlight: pwm: Converting benign message to info"Dominik Sliwa
This reverts commit 153a5d54d1a10c5a35f6923e0c6423430d2c7c89.
2018-03-28input: atmel_mxt_ts: support reset gpio lineDominik Sliwa
2018-03-28input: touchscreen: atmel_mxt_ts: backport from kernel 4.9Dominik Sliwa
2018-03-28apalis-tk1:lvds: add option to select 24-bit lvds modeDominik Sliwa
Add ability to switch between 24.1 and 24.0 lvds modes. Mode description can be found in "Using 24-bpp LVDS Panels with IntelĀ® Mobile Chipsets for Embedded Applications". Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-28apalis-tk1: move display configuration to device-treeDominik Sliwa
2018-03-28can: mfd: apalis-tk1: v1.1 frequency adjustments and various fixesDominik Sliwa
2018-03-28mfd: apalis-tk1-k20: single transaction register readDominik Sliwa
This change also modifies SPI clock for ezPort mode. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-28can: mfd: apalis-tk1-k20:increased clock speed, zero copyDominik Sliwa
Increased SPI speed for transfers and peripheral speed. Switch to cleaning IRQ flags on read, instead of separate write. Switched to zero-copy on SPI reads. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-22apalis-tk1: fix wake on lan functionalityApalis-TK1_LXDE-Image_2.8b1.64-20171229Dominik Sliwa
GPIO used for WOL is briefly used in i210 reset procedure. This patch makes sure it's freed and can be used for a wakeup source. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-29tegra: align graphics drivers with android binariesApalis-TK1_LXDE-Image_2.7b5-20171201Dominik Sliwa
Some functionality used by android binary drivers were missing. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-11-29mfd: apalis-tk1: 0.11 fw supportDominik Sliwa
2017-11-29mmc: Allow forward compatibility for eMMCRomain Izard
As stated by the eMMC 5.0 specification, a chip should not be rejected only because of the revision stated in the EXT_CSD_REV field of the EXT_CSD register. Remove the control on this value, the control of the CSD_STRUCTURE field should be sufficient to reject future incompatible changes. Signed-off-by: Romain Izard <romain.izard.pro@gmail.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> (cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
2017-11-29Merge tag 'tegra-l4t-r21.6' into toradex_tk1_l4t_r21.6Marcel Ziswiler
Merge NVIDIA's latest Linux for Tegra aka L4T R21.6 Linux kernel changes from git://nv-tegra.nvidia.com/linux-3.10.git commit: b271e8fa67a6d9c4600274a25636cfe00fdd1b68 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29Revert "spi-tegra114: Warning when clock rate switch fails"Marcel Ziswiler
This reverts commit 8fdf8dc5afdb02625084356ebd7c0d1c7494a00e. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29Revert "mmc: Allow forward compatibility for eMMC"Marcel Ziswiler
This reverts commit 0293e897d740cc7991c82567aab5dee0e66294fd. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-29media: ov5640: major driver cleanuptoradex_tk1_l4t_r21.5Peter Gielda
Signed-off-by: Peter Gielda <pgielda@antmicro.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-06mfd: apalis-tk1-k20: clean-up and fix support for 0.10 k20 fwApalis-TK1_LXDE-Image_2.7b4-20171007Dominik Sliwa
2017-10-05mfd: apalis-tk1-k20: support for 0.10 k20 fwDominik Sliwa
2017-10-03pinctrl: tegra: clean-upMarcel Ziswiler
Cosmetic clean-up to bring it more in-line with mainline driver in order to be able to easily assess whether it is all kosher. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20dp.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | drivers/video/tegra/dc/dp.c:1178:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses] | cr_done ? : ({ret = -EINVAL; goto fail; }); | ^ | drivers/video/tegra/dc/dp.c:1186:12: error: the omitted middle operand in ?: will always be 'true', suggest explicit middle operand [-Werror=parentheses] | lt_done ? : ({ret = -EINVAL; goto fail; }); | ^ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20dsi.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | drivers/video/tegra/dc/dsi.c:766:34: error: '*' in boolean context, suggest '&&' instead [-Werror=int-in-bool-context] | drivers/video/tegra/dc/dsi.c:757:1: | (platform_t_phy_ps) ? ( \ | ~~~~~~~~~~~~~~~~~~~ | kernel-source/drivers/video/tegra/dc/dsi.c:766:34: | dsi->info.phy_timing.t_tlpx_ns * 1000, | drivers/video/tegra/dc/dsi.c:757:2: note: in definition of macro 'SELECT_T_PHY' | (platform_t_phy_ps) ? ( \ | ^~~~~~~~~~~~~~~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20tegra_udc.c: fix compilation with gcc 7Max Krummenacher
With gcc 7 the following compile time error occurs: | .../drivers/usb/gadget/tegra_udc.c:2565:17: error: 'out' directive writing 3 bytes into a region of size between 2 and 11 [-Werror=format-overflow=] | sprintf(name, "ep%dout", i); | ^~~~~~~~~ | .../drivers/usb/gadget/tegra_udc.c:2565:3: note: 'sprintf' output between 7 and 16 bytes into a destination of size 14 | sprintf(name, "ep%dout", i); | ^~~~~~~~~~~~~~~~~~~~~~~~~~~ The last end point will never be greater than 32 but the compiler can not find this out from the code. Work around this by passing a format specifier to interpreat i as a signed char. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20mfd: apalis-tk1: fix NULL pointer dereferenceDominik Sliwa
2017-09-20spi: tegra: fix warning when using controller-dataDominik Sliwa
Tegra spi driver was using devm_kzalloc before dev was bound. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-09-20apalis-tk1: fix pcie reset for reliable gigabit ethernet operationMarcel Ziswiler
It turns out that the current PCIe reset implementation is not quite working reliably due to some Intel i210 errata. Fix this by making sure the i210's +V3.3_ETH rail is properly disabled during its reset sequence. Also further improve on the bringing up the PCIe switch as found on the Apalis Evaluation board. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-09-20rtc: ds1307: support m41t0 variantBhuvanchandra DV
The m41t0 variant is very similar to the already supported m41t00 variant, with the notable exception of the oscillator fail bit. The data sheet notes: If the oscillator fail (OF) bit is internally set to a '1,' this indicates that the oscillator has either stopped, or was stopped for some period of time and can be used to judge the validity of the clock and date data. The bit will get cleared with a regular write of the system time, so no changes are needed to clear it. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> (backported from commit 8566f70c8a90f3914b06e934852596ba94aaa381)
2017-07-26gpu: nvgpu: Remove IOCTL FREE_OBJ_CTXDebarshi Dutta
We have never used the IOCTL FREE_OBJ_CTX. Using it leads to context being only partially available, and can lead to use-after-free. Bug 1885775 Change-Id: I9d2b632ab79760f8186d02e0f35861b3a6aae649 Signed-off-by: Debarshi Dutta <ddutta@nvidia.com> Reviewed-on: https://git-master.nvidia.com/r/1506479 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-07-26video: tegra: nvmap: fix nvmap create handle vulnerabilityKrishna Reddy
Handle the race condition between malicious fd close and copy_to_user error, which can create use after free condition. This is fixed by deferring the fd install, which eliminates the race that leads to use after free condition. Fixing Google Bug 32160775. Bug 1835857 Change-Id: I337807e4360661beced8f9e1155c47b66607b8df Signed-off-by: Krishna Reddy <vdumpa@nvidia.com> Reviewed-on: http://git-master/r/1248391 Reviewed-on: https://git-master.nvidia.com/r/1512958 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com>
2017-06-30apalis-tk1-k20: can and spi improvementsDominik Sliwa
This patch includes CAN driver and improvements in SPI communications for Apalis TK1 k20 based MFD. Requires firmware version 0.9. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30video: tegra: sor: set drive current for lane4WayneWWW
Drive current for LANE4 was not set if configured as 24bpp LVDS out. Fix it by programming proper drive current register if using 24bpp out. https://devtalk.nvidia.com/default/topic/1003030 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-29video: tegra: dsi: Set max limit for reading panelPavan Kunapuli
In the debugfs support for reading panel registers, max payload needs to be limited to the buff array size to avoid stack corruption. Bug 1873360 Change-Id: Ibee7bd81027d2669297942c09b905f1dd3bb09ee Signed-off-by: Pavan Kunapuli <pkunapuli@nvidia.com> Signed-off-by: sakets <sakets@nvidia.com> Reviewed-on: https://git-master/r/1507653 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com>
2017-06-21video: tegra: nvmap: fix information leak in pin/unpinSri Krishna chowdary
When the NVMAP_IOC_PIN_MULT_32 and NVMAP_IOC_UNPIN_MULT_32 are called it is possible that the op.addr is not initialized. This can cause write to some random address thus causing corruption. This patch fixes Google Bug 31668540 bug 1832092 Change-Id: I4d12d1a6c777131ba1fa2a753ea640861f8e82a6 Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com> Reviewed-on: http://git-master/r/1314406 (cherry picked from commit da0c43534bb61e2e0849e297d389517d5e4ed168) Reviewed-on: http://git-master/r/1504673 GVS: Gerrit_Virtual_Submit Reviewed-by: Bibek Basu <bbasu@nvidia.com> Tested-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-06-20media: tegra: nvavp: Fix UAF issue.Jitendra Kumar
Use locking to protect generated fd, so that it can't be freed before channel open completes. Also add null value checks in release call. CVE-2016-8449 (A-31798848) Bug 1830023 Bug 1849492 Change-Id: Ie6e2b29c7132fdfdff6b0bfa75440bd43afffd5f Signed-off-by: Gagan Grover <ggrover@nvidia.com> Reviewed-on: http://git-master/r/1285817 (cherry picked from commit 2ff0fdedfd65f269359d6540df4662e958681aa7) Reviewed-on: http://git-master/r/1299505 (cherry picked from commit ea1af2ce5a746bda36205357c9e0adaf527026bb) Reviewed-on: http://git-master/r/1489467 (cherry picked from commit 89559abb25f82dc333eafa26391be0a50d6e9e0a) Reviewed-on: http://git-master/r/1504674 Reviewed-by: Automatic_Commit_Validation_User GVS: Gerrit_Virtual_Submit Tested-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Bibek Basu <bbasu@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
2017-06-16gpu: nvgpu: Fix pgsz_idx used in gk20a_vm_alloc_space()Alex Waterman
Use the correct page size index for pgsz_idx in gk20a_vm_alloc_space(). Previously the page size itself was used, not the page size index. Bug 1837624 Change-Id: I652f5af5321c1c49dc8eb170d3f92f00c23d2b6f Signed-off-by: Alex Waterman <alexw@nvidia.com> (cherry picked from commit fd13e0e1c4e397335c24497a0f92c85934d6185f) Reviewed-on: http://git-master/r/1503371 Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com> Reviewed-by: Winnie Hsu <whsu@nvidia.com>
