As we limit the clock to 200 MHz also add tap hole coefficients to
allow for successful UHC-I tuning on SDMMC1.
A couple of pairs of pin group names were swapped in the table. This
caused the wrong register to be programmed. Luckily, this had little
effect, if any, since the swapped pins were likely to be programmed
identically.
(cherry picked from commit 0ffdd4b61b1326b2b8a7c4fdf3c061d807be1a74)
Fix PCIe clock and reset not conforming to specification by moving PCIe
reset handling including the PLX PEX 8605 errata 5 workaround from the
board platform data into the right places timing wise in the PCIe driver
itself.
Also add a kernel command line argument to allow using the Apalis GPIO7
as a regular GPIO rather than for above mentioned PLX PEX 8605
workaround:
pex_perst=0
(cherry picked from tegra-next commit
a2f63805703b43d55d91ae17f10d0049bf0f625e)
This reverts commit ff5bccb61c1f8da1f63451fda88bd1f65dbee5b2.
This makes Antmicro's OV5640 camera module work again as described on
their blog here:
http://antmicro.com/Blog/2015/09/jetson-tk1-cameras/
Further investigation pending.
Connected to CSI CIL-E. Cameras doesn't work simultaneously.
A major part of the driver has been rewritten in order to avoid
writing binary blobs to the chip.
This version also adds support for more video modes.
Input video modes supported:
- 1920x1080 @ 60
- 1280x1024 @ 75
- 1280x720 @ 60
- 1024x768 @ 75
- 800x600 @ 75
- 640x480 @ 75
known issues:
- decoder outputs PAL (720x576), but the image
looks fine only when streamed in 640x576 mode,
- vertical synchronisation glitches,
- setting queue-size in gstreamer greater than 1
results in blinking image,
- every start of streaming requires reloading of
the modules
known issues:
- HDMI input works only in 640x480 mode, 720p only in
test pattern mode, any 4-lane mode doesn't work
- set HDMI transmitter to VGA mode before
starting the stream
known issues:
- works only in 1080p mode,
the modules
drivers/video/tegra/dc/dc.c:116:3: error: 'can_filter' defined but not
used [-Werror=unused-const-variable=]
} can_filter[] = {
drivers/media/platform/tegra/ad5816.c: In function 'ad5816_param_wr':
drivers/media/platform/tegra/ad5816.c:682:6: error: this 'if' clause
does not guard... [-Werror=misleading-indentation]
if (info->s_mode != NVC_SYNC_STEREO)
drivers/media/platform/tegra/dw9718.c:627:6: error: this 'if' clause
drivers/gpu/nvgpu/gk20a/mm_gk20a.c:124:18: error:
'gmmu_page_masks' defined but not used [-Werror=unused-const-variable=]
static const u64 gmmu_page_masks[gmmu_nr_page_sizes] = { ~0xfffLL,
~0x1ffffLL };
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:344:40: error:
'gk20a_runcontrol_whitelist_ranges' defined but not used
static const struct regop_offset_range gk20a_runcontrol_whitelist_ranges[] = {
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:350:18: error:
'gk20a_runcontrol_whitelist_ranges_count' defined but not used
static const u32 gk20a_runcontrol_whitelist_ranges_count =
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:366:40: error:
'gk20a_qctl_whitelist_ranges' defined but not used
static const struct regop_offset_range gk20a_qctl_whitelist_ranges[] = {
drivers/gpu/nvgpu/gk20a/regops_gk20a.c:373:18: error:
'gk20a_qctl_whitelist_ranges_count' defined but not used
static const u32 gk20a_qctl_whitelist_ranges_count =
This patch allows for easy integration of a custom Linux boot logo to
replace the Tux' being shown by default.
Use gimp or the like to create a raw PPM in your desired resolution.
Reduce the number of colours in the image to 224:
user@host:~$ ppmquant 224 Toradex-640x480.ppm > \
Toradex-640x480-224.ppm
ppmquant: making histogram...
ppmquant: 370 colors found
ppmquant: choosing 224 colors...
ppmquant: mapping image to new colors...
Convert it from raw PPM to ASCII format:
user@host:~$ pnmnoraw Toradex-640x480-224.ppm > \
Toradex-640x480-ascii-224.ppm
Copy it into the Linux sources:
cp Toradex-640x480-ascii-224.ppm linux-toradex/drivers/video/logo/\
logo_custom_clut224.ppm
Activate exclusively custom Linux logo in the kernel configuration:
Device Drivers -> Graphics support -> Bootup logo ->
Custom 224-color Linux logo
And re-compile the kernel.
(cherry picked from commit fa2371bff9ac03581881849d8f95678ef3992719)
When setting transfer clock rate out of bounds
old clock rate was used without any notice.
Patch taken from Manoj Gupta's post on NVIDIA's public embedded systems forum:
https://devtalk.nvidia.com/default/topic/822612/jetson-tk1/-issue-lvds-panel-enabled-effect-hdmi-out-image-pull-down-menu-items/post/4673174/#4673174
This fixes the following build time error in case CONFIG_TEGRA_LVDS is enabled:
drivers/video/tegra/dc/sor.h: In function 'tegra_sor_clk_enable':
drivers/video/tegra/dc/sor.h:180:2: error: implicit declaration of function 'clk_prepare_enable' [-Werror=implicit-function-declaration]
clk_prepare_enable(sor->sor_clk);
drivers/video/tegra/dc/sor.h: In function 'tegra_sor_clk_disable':
drivers/video/tegra/dc/sor.h:185:2: error: implicit declaration of function 'clk_disable_unprepare' [-Werror=implicit-function-declaration]
clk_disable_unprepare(sor->sor_clk);
In file included from drivers/video/tegra/dc/dc_priv_defs.h:26:0,
from drivers/video/tegra/dc/dc_priv.h:23,
from drivers/video/tegra/dc/lvds.c:23:
include/linux/clk.h: At top level:
include/linux/clk.h:330:19: error: static declaration of 'clk_prepare_enable' follows non-static declaration
static inline int clk_prepare_enable(struct clk *clk)
In file included from drivers/video/tegra/dc/lvds.h:20:0,
from drivers/video/tegra/dc/lvds.c:22:
drivers/video/tegra/dc/sor.h:180:2: note: previous implicit declaration of 'clk_prepare_enable' was here
include/linux/clk.h:345:20: error: conflicting types for 'clk_disable_unprepare' [-Werror]
static inline void clk_disable_unprepare(struct clk *clk)
include/linux/clk.h:345:20: error: static declaration of 'clk_disable_unprepare' follows non-static declaration
drivers/video/tegra/dc/sor.h:185:2: note: previous implicit declaration of 'clk_disable_unprepare' was here
Final patch taken from Manoj Gupta's post on NVIDIA's public embedded systems forum:
https://devtalk.nvidia.com/default/topic/822612/jetson-tk1/-issue-lvds-panel-enabled-effect-hdmi-out-image-pull-down-menu-items/post/4663817/#4663817
Disable the external loopback and use the internal loopback as per
SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits being set to
0xfffd according to the TRM.
Enable card detect polling as we can't use SD1_CD# aka
SDMMC3_CLK_LB_OUT for now as it features some magic properties even
though the external loopback is disabled and the internal loopback used
as per SDMMC_VENDOR_MISC_CNTRL_0 register's SDMMC_SPARE1 bits being set
to 0xfffd according to the TRM!
Springville/i211 with a blank Flash/iNVM use different PCI IDs. Extend
the driver to load despite i210/i211 data sheets claiming tools only,
not for driver.
Only warn rather than fail on NVM validation failures on Apalis T30.
Revise Ethernet MAC address assignment: should now handle up to two
instances of custom user MACs (2nd one with a 0x100000 offset). This
way customer does not have to worry about NVM on a secondary Ethernet
on the carrier board and still gets a valid official MAC address from
us (e.g. analogous to how we did it on our Protea carrier board).
Use the Toradex OUI as default MAC address if no valid one is
encountered.
Tested on samples of Apalis T30 2GB V1.0B, V1.0C, V1.1A, Apalis T30 1GB
V1.0A, V1.1A and Apalis T30 1GB IT V1.1A both with blank NVMs as well
as iNVMs programmed with Intel's defaults.
Tested on samples of Apalis TK1 2GB V1.0A and V1.0B both with blank
NVMs as well as iNVMs programmed with Intel's defaults.
(cherry picked from commit c4c3c7449bdb15c53bfebb0a29c73b24ea810d23)
Springville/i211 with a blank Flash/iNVM use a different PCI ID (tools
only, not for driver) than properly programmed ones.
While at it also fix ethtool time stamping as well as RX flow hash
indirection functionality.
(cherry picked from commit 2c7123458270c9b3ec9b5ed668f9d55a7f8dbad9)
Integrate latest igb driver version 5.3.5.3
(igb-5.3.5.3.tar.gz from e1000.sf.net).
This reverts commit ca90caa335e3ded32ad6b0a92ad0fa00b67b2322.
We do require eMMC hardware area boot partition access for fw-util aka U-Boot
envrionment access.
As stated by the eMMC 5.0 specification, a chip should not be rejected
only because of the revision stated in the EXT_CSD_REV field of the
EXT_CSD register.
Remove the control on this value, the control of the CSD_STRUCTURE field
should be sufficient to reject future incompatible changes.
Signed-off-by: Romain Izard <romain.izard.pro@gmail.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 03a59437ef6b6ad7fb0165cb9b96c08d6bf057fc)
DIPM is not a POR for Tegra AHCI Sata Controller
Bug 200087528
Change-Id: I5a742170177c9f57426f3756a8cfafefa88af92b
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/1013776
(cherry picked from commit 7ebd3b1058491ee87686e9e731b79ecd914e00d9)
Reviewed-on: http://git-master/r/1031624
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Bug 1729847
Change-Id: Ie455b0469a1d4e35453ca9e36c5e90dfdc6f56a2
Signed-off-by: Bhushan Rupde <brupde@nvidia.com>
Reviewed-on: http://git-master/r/1147432
Reviewed-by: Mohan Nimaje <mnimaje@nvidia.com>
Reviewed-by: Soumen Dey <sdey@nvidia.com>
In case kernel fails to open a channel (e.g. due to inability to
allocate hardware context or turn on the device), the channel open
function releases the resources that were already allocated
successfully.
However, currently the error path additionally calls the channel
release function for putting the channel pointer after the private
data structures have been freed - thereby causing use-after-free
memory usage.
This patch reworks error handling in channel open to release
channel without risking usage of already freed memory.
Bug 1763577
Change-Id: Ic7562e69f2babad653afc7a11e413701494a30b4
Signed-off-by: Arto Merilainen <amerilainen@nvidia.com>
Reviewed-on: http://git-master/r/1148081
Tested-by: Winnie Hsu <whsu@nvidia.com>
In nvhost_ioctl_ctrl_module_regrdwr(), we copy offset
to read/write from user space but we do not have
any check on it
So it is possible for user space to add unaligned
offset and request read/write which would crash the
system
Fix this by explicitly checking alignment of the
offset passed by user space
Bug 1739935
Change-Id: Iea2a07c60500af876b732a0e9d9d08535aa53b5c
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-on: http://git-master/r/1029405
(cherry picked from commit 422baa09a17a6a17f4e572aa5441ca174634de0d)
Reviewed-on: http://git-master/r/1123363
Tested-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Deprecate outdated UPDATE_GPIO function in camera.pcl
driver. This function is not used by any code anymore
and is a security vulnerability since it is trying to
access user mode pointer directly.
Bug 1745102
Change-Id: I4e7e5f9c186f980dcadfe52ec4284102255f19cf
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/1115302
(cherry picked from commit 2e5c355c904a19d71456a04c70f3fb4fc7d918b0)
Reviewed-on: http://git-master/r/1123362
Tested-by: Matthew Pedro <mapedro@nvidia.com>
We need to validate power on/off function size passed
in from user mode in order to avoid integer overflow
or out of memory failures.
Bug 1745100
Change-Id: Idddd848f7dc1e864559ad219f9204325128484e5
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/1114354
(cherry picked from commit 8b3afcc132882f3102083f9a24de7f55476ca59b)
Reviewed-on: http://git-master/r/1150944
We are not checking a variable which is user
controlled. This can lead to reading of the
stack data. Adding a check to ensure it is
less than the max possible value of the variable.
Bug 1763649
Change-Id: I395e882d030199bdd7684837906a9b5d60741650
Signed-off-by: Amey Asgaonkar <aasgaonkar@nvidia.com>
Reviewed-on: http://git-master/r/1150943
Add ref count to prevent invalid vma removal from the h->vmas list
and also allow addition of a different vma which also has same
nvmap_vma_priv as vm_private_data into the h->vmas list. Both cases
are allowed in valid usage of nvmap_vma_open/nvmap_vma_close.
Bug 200164002
Change-Id: Ifc4d281dd91e1d072a9a3ee85e925040bd65a6bc
Signed-off-by: Sri Krishna chowdary <schowdary@nvidia.com>
Signed-off-by: Bryan Wu <pengw@nvidia.com>
Reviewed-on: http://git-master/r/1133708
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
nvmap expects that same VMA is opened and closed to disallow
memory leaks. So, nvmap panics if a previously non-existent vma
is being closed through it.
Hence modify the sequence in vb2_get_vma() to
open the vma_copy before returning it. This way nvmap sees that
the vma_copy exists in its list and will close the vma.
Bug 200164002
Change-Id: I45dfb8ca710375a0e70d9802ebdcc9fd4d0b4600
Reviewed-on: http://git-master/r/931997
(cherry picked from commit bf1d15d8a879a599f9801310cecbbb61ea60e931)
Reviewed-on: http://git-master/r/1133707
Tested-by: Bryan Wu <pengw@nvidia.com>
Reviewed-by: Bryan Wu <pengw@nvidia.com>
- Check whether command buffer data offset is 32-bit
aligned
- Check whether relocation offset is 32-bit aligned
and calculated offset is within command buffer size
- Check whether target offset is 32-bit aligned
and derived address is within target buffer size
Bug 1741516
Change-Id: Ie5370bc1538c8cf9a702904fb88eb850baeb063d
Signed-off-by: Somu Sundaram <somasundaram@nvidia.com>
Reviewed-on: http://git-master/r/1113949
Tested-by: Somu Sundaram <somasundarams@nvidia.com>
Add checks for command buffer offset, relocation
offset in command buffer and target offset for patching
relocation to prevent aritrary kernel write
Bug 1741516
Change-Id: Ia6183ca75f983c0ede23606be9e5d824aa5fa41d
Reviewed-on: http://git-master/r/1111699
Increase NVAVP_MAX_RELOCATION_COUNT to max. possible value
and add check to return error if num_relocs in
nvavp_pushbuffer_submit_ioctl exceeds
Bug 1739930
Change-Id: Ief36cedd692aa53135fc6a0039b19f18609259dd
Signed-off-by: Somasundaram S <somasundaram@nvidia.com>
Reviewed-on: http://git-master/r/1030885
Make sure that the notification object fits within the supplied buffer.
Bug 1739182
Change-Id: Ifb66f848e3758438f37645be6f534f5b60260214
Signed-off-by: Konsta Holtta <kholtta@nvidia.com>
Reviewed-on: http://git-master/r/1026431
(cherry picked from commit 2484c47f123c717030aa00253446e8756e1a0807)
Reviewed-on: http://git-master/r/1030663
Make sure that the notifier object fits within the supplied buffer.
Bug 1739183
Bug 1739932
Change-Id: I713574ce797ffc23cec10b5114f469dbadc68f1e
Reviewed-on: http://git-master/r/1026410
(cherry picked from commit f476b93eb19b962b8760457102448bd533efc54d)
Reviewed-on: http://git-master/r/1029379
Reviewed-by: Terje Bergstrom <tbergstrom@nvidia.com>
Bug 1739183
Change-Id: Ifbf46eddea86bedf0236851ea1c3f73e5f820beb
Reviewed-on: http://git-master/r/1026409
(cherry picked from commit 4086d2137e9b51137aa335fa264d924c73dea5fc)
Reviewed-on: http://git-master/r/1029074
Reviewed-by: Shridhar Rasal <srasal@nvidia.com>
Reviewed-by: Deepak Nibade <dnibade@nvidia.com>
Reviewed-by: Arto Merilainen <amerilainen@nvidia.com>
timeout should not be set as part of open call.
It should be set as part of Probe if watchdog enabled on
probe, Otherwise timeout should be 0 since watchdog is not enabled.
Bug 200160105
Change-Id: I2bc0f35436dafd01d17e3ea2ec5459fd0d75af5a
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: http://git-master/r/927429
Clear error status register during init
Bug 1709814
Change-Id: I348526828015c84027b647bc728355ac9271a5fe
Reviewed-on: http://git-master/r/842868
Bug 1694187
Change-Id: Idb8d95f0a7bc099989cc5b7b0bc97bf5cc896b32
Reviewed-on: http://git-master/r/837972
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Query max vi/isp clk-rate runtime to calcuate max BW.
Remove max-bw defines.
Bug 1538490
Bug 1695435
Change-Id: I86a5c22fa3c7c9582351bbe9a95776aaea6a613d
Signed-off-by: Sudhir Vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/461278
(cherry picked from commit bbcd86c917430ceea1603e03964296ca4e26ac3a)
Reviewed-on: http://git-master/r/825139
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Tested-by: Frank Shi <fshi@nvidia.com>
Use one kthread to start capture a frame and wait for next frame start.
Before waiting, it will move the current buffer to another queue which
will be handled another kthread.
The second kthread (capture_done) will wait for memory output done sync
point event and handle the buffer to videobuffer2 framework as capture
done.
Bug 1686911
Change-Id: Ia092c708ecca3b2e7cbc657a96fd247ea4a00d2f
Reviewed-on: http://git-master/r/819177
Use kthread instead of workqueue, which will create a dedicated kernel
thread for capture.
Remove useless mutex and convert spin_lock_irq() to normal spin_lock().
Bug 1686911
Change-Id: Ib236a7ebbdd0359f2705774a979825f1f9e9d82a
Reviewed-on: http://git-master/r/819176
bytes_per_line should be 64 bytes aligned in Tegra. Add a function to
check that and return the right value for LINE_STRIDE register.
Bug 1694764
Change-Id: I1bb926a416719d19cad509f9a9a7c4fce06b851a
Reviewed-on: http://git-master/r/816975
Avoid to disconnect gadget again after unbinding
bug 200141741
Change-Id: I6fadcb4c5b5262d861a865f24ba2d8666e126923
Signed-off-by: Peter Chiang <pchiang@nvidia.com>
Reviewed-on: http://git-master/r/805175
Reviewed-by: Hui Fu <hfu@nvidia.com>
Reviewed-by: Ashutosh Jha <ajha@nvidia.com>
re-order POWERGATE_ENABLE operations in opposite
order of POWERGATE_DISABLE
Bug 1679372
Change-Id: Ib72a0b80929e2dee2cf88a6d3d0f96d61c02307b
Reviewed-on: http://git-master/r/796459
(cherry picked from commit 7e2668f924a986d4bd7d1d2c383431a5e80d9968)
Reviewed-on: http://git-master/r/801977
