This is upstream as 54583bf4efda79388fc13163e35c016c8bc5de81
Oops...
Signed-off-by: Dave Airlie <airlied@linux.ie>
Already in Linus' tree:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=d58df9cd788e6fb4962e1c8d5ba7b8b95d639a44
The bank switching code assumes that the bank selector is set to 0
when the driver is loaded. This might not be the case. This is exactly
the same bug as was fixed in the w83627ehf driver two months ago:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=0956895aa6f8dc6a33210967252fd7787652537d
In practice, this bug was causing the sensor thermal types to be
improperly reported for my W83627THF the first time I was loading the
w83627hf driver. From the driver history, I'd say that it has been
broken since September 2005 (when we stopped resetting the chip by
default at driver load.)
Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=c09c5184a26158da32801e89d5849d774605f0dd
We need to read the fan clock dividers at initialization time,
otherwise the code in store_fan_min() may use uninitialized values.
That's pretty much the same bug and same fix as for the w83627ehf
driver last month.
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=889af3d5d9586db795a06c619e416b4baee11da8
A stupid bit shifting bug caused the VID value to be always exported
even when the hardware is configured for something different.
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=b965d4b7f614522170af6a7e450be0333792ccd2
Missing parentheses in the definition of FAN_FROM_REG cause a
division by zero for a specific register value.
Acked-by: Hans de Goede <j.w.r.degoede@hhs.nl>
Based on cb50f548c0ee9b2aac39743fc4021a7188825a98 in mainline
[PATCH] V4L: ivtv: fix udma yuv bug
Using udma yuv causes the driver to become locked into that mode. This
prevents use of the mpeg decoder & non-udma yuv output.
This patch clears the operating mode when the device is closed.
Signed-off-by: Ian Armstrong <ian@iarmst.demon.co.uk>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
patch f662fe5a0b144efadbfc00e8040e603ec318746e in mainline.
dm9601: Fix receive MTU
dm9601 didn't take the ethernet header into account when calculating
RX MTU, causing packets bigger than 1486 to fail.
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
This episode illustrates how an overused warning can train people to
ignore that warning, which winds up hiding bugs.
The warning
drivers/net/natsemi.c: In function ‘natsemi_remove1’:
drivers/net/natsemi.c:3222: warning: ignoring return value of
‘device_create_file’, declared with attribute warn_unused_result
is oft-ignored, even though at close inspection one notices this occurs
in the /remove/ function, not normally where creation occurs. A quick
s/create/remove/ and we are fixed, with the warning gone.
Cc: Karsten Keil <kkeil@suse.de>
Fix panic in run_timer_softirq right after "modprobe -r firewire-ohci"
if a FireWire disk was attached and firewire-sbp2 loaded.
Same as commit 8a2d9ed3210464d22fccb9834970629c1c36fa36.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
based on patch 8362cd413e8116306fafbaf414f0419db0595142 in mainline.
domain->header.len is le16 and has just been assigned
cpu_to_le16(arithmetical expression). And all fields of adapter->logmsg
are __le32; not a single 16-bit among them...
That's incremental to the previous one
Signed-off-by: Dan Williams <dcbw@redhat.com>
patch 5707708111ca6c4e9a1160acffdc98a98d95e462 in mainline.
wep->keytype[] is u8
changeset 162f6690a65075b49f242d3c8cdb5caaa959a060 in mainline.
TCP V4 sequence numbers are 32bits, and RFC 793 assumed a 250 KHz clock.
In order to follow network speed increase, we can use a faster clock, but
we should limit this clock so that the delay between two rollovers is
greater than MSL (TCP Maximum Segment Lifetime : 2 minutes)
Choosing a 64 nsec clock should be OK, since the rollovers occur every
274 seconds.
Problem spotted by Denys Fedoryshchenko
[ This bug was introduced by f85958151900f9d30fa5ff941b0ce71eaa45a7de ]
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
changeset ff4abd6cfacf0bb23a077f615d3a5cd17359db1b in mainline.
The ESP scsi driver does not initialize the host controller
instance early enough, so the messages in the log confuse
users.
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
changeset b04e7bdb984e3b7f62fb7f44146a529f88cc7639 from mainline.
device_suspend() calls ACPI suspend functions, which seems to have undesired
side effects on lower idle C-states. It took me some time to realize that
especially the VAIO BIOSes (both Andrews jinxed UP and my elfstruck SMP one)
show this effect. I'm quite sure that other bug reports against suspend/resume
about turning the system into a brick have the same root cause.
After fishing in the dark for quite some time, I realized that removing the ACPI
processor module before suspend (this removes the lower C-state functionality)
made the problem disappear. Interestingly enough the propability of having a
bricked box is influenced by various factors (interrupts, size of the ram image,
...). Even adding a bunch of printks in the wrong places made the problem go
away. The previous periodic tick implementation simply pampered over the
problem, which explains why the dyntick / clockevents changes made this more
prominent.
We avoid complex functionality during the boot process and we have to do the
same during suspend/resume. It is a similar scenario and equaly fragile.
Add suspend / resume functions to the ACPI processor code and disable the lower
idle C-states across suspend/resume. Fall back to the default idle
implementation (halt) instead.
Tested-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Len Brown <lenb@kernel.org>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
In Linus tree already:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=939bc4943d0483961edc45b63a7d27b4ffe547e3
This fixes a bug in the way i2c-algo-bit handles I2C_M_RECV_LEN,
used to implement i2c_smbus_read_block_data(). Previously, in the
absence of PEC (rarely used!) it would NAK the "length" byte:
S addr Rd [A] [length] NA
That prevents the subsequent data bytes from being read:
S addr Rd [A] [length] { A [data] }* NA
The primary fix just reorders two code blocks, so the length used
in the "should I NAK now?" check incorporates the data which it
just read from the slave device.
However, that move also highlighted other fault handling glitches.
This fixes those by abstracting the RX path ack/nak logic, so it
can be used in more than one location.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
commit 45dfd5b5dd20f17fe23dafc5cfe921474d27f849 from upstream
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
Update the libata drive blacklists to the latest in 2.6.23-rc8.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Cc: Jeff Garzik <jeff@garzik.org>
Already upstream.
After resume, driver has reset the chip so the current state
of transmit checksum offload state machine and DMA state machine
will be undefined.
The fix is to set the state so that first Tx will set MSS and offset
values.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Already upstream.
The length check for truncated frames was not correctly handling
the case where VLAN acceleration had already read the tag.
Also, the Yukon EX has some features that use high bit of status
as security tag.
Signed-off-by: Pierre-Yves Ritschard <pyr@spootnik.org>
This is the 2.6.22 version of a regression fix that is already
in 2.6.23. Change the watchdog timer form 10 per second all the time,
to 1 per second and only if interface is up.
commit 2302827c95fe0f441025acd5133e532d2eef322b from upstream
Domain Validation in the SPI transport class is failing on boxes with
damaged cables (and failing to the extent that the box hangs). The
problem is that the first test it does is a cable integrity test for
wide transfers and if this fails, it turns the wide bit off. The
problem is that the next set of tests it does turns wide back on
again, with the result that it runs through the entirety of DV with a
known bad setting and then hangs the system.
The attached patch fixes the problem by physically nailing the wide
setting to what it deduces it should be for the whole of Domain
Validation.
port of 3f7086978fc0193eff24a77d8b57ac4debc088fa from mainline.
A crash upon booting that is caused by bcm43xx has been reported [1] and
found to be due to a work queue being reinitialized while work on that
queue is still pending. This fix modifies the shutdown of work queues and
prevents periodic work from being requeued during shutdown. With this patch,
no more crashes on reboot were observed by the original reporter. I do not
get that particular failure on my system; however, when running a large
number of ifdown/ifup sequences, my system would kernel panic with the
'caps lock' light blinking at roughly a 1 Hz rate. In addition, there were
infrequent failures in the firmware that resulted in 'IRQ READY TIMEOUT'
errors. With this patch, no more of the first type of failure occur, and
incidence of the second type is greatly reduced.
[1] http://bugzilla.kernel.org/show_bug.cgi?id=8937
Acked-by: Michael Buesch <mb@bu3sch.de>
commit ba685fb2abd71162bea6895a99449c1071b01402 in mainline.
As noticed by Chuck Ebbert, commit c5e3ae8823693b260ce1f217adca8add1bc0b3de
introduced a copy-paste typo, as realtek phy is 0x732 and not 0x1c1. Obvious
fix below suggested by Ayaz Abdulla.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
Initialization of ohci1394 was broken according to one reporter if the
driver was statically linked, i.e. not built as loadable module. Dmesg:
PCI: Device 0000:02:07.0 not available because of resource collisions
ohci1394: Failed to enable OHCI hardware.
This was reported for a Toshiba Satellite 5100-503. The cause is commit
8df4083c5291b3647e0381d3c69ab2196f5dd3b7 in Linux 2.6.19-rc1 which only
served purposes of early remote debugging via FireWire. This
functionality is better provided by the currently out-of-tree driver
ohci1394_earlyinit. Reversal of the commit was OK'd by Andi Kleen.
Same as pre-2.6.23 commit be7963b7e7f08a149e247c0bf29a4abd174e0929.
regression)
Minor regression since 2.6.22-rc1: If the experimental firewire-ohci
driver instead of ohci1394 was loaded, iBook G3 and older PowerBooks
refused to suspend.
Same as commit 5511142870046a7bed947d51ec9b320856ee120a plus format
string touch-ups from 8a8cea2734808522f02941ea16125810ee42c9c7,
"firewire: missing newline in printk". Original patch description:
Fixes (papers over) "Sleep problems with kernels >= 2.6.21 on powerpc",
http://lkml.org/lkml/2007/8/25/155. The issue is that the FireWire
controller's pci_dev.current_state of iBook G3 and presumably older
PowerBooks is still in PCI_UNKNOWN instead of PCI_D0 when the firewire
driver's .suspend method is called.
Like it was suggested earlier in http://lkml.org/lkml/2006/10/24/13, we
do not fail .suspend anymore if pci_set_power_state failed.
commit 3558c9b3232b5f0fd9f32043a191eca20fca64c6 in mainline.
sparc32:
drivers/block/DAC960.c: In function 'DAC960_V1_EnableMemoryMailboxInterface':
drivers/block/DAC960.c:1168: error: 'DMA_32BIT_MASK' undeclared (first use in this function)
drivers/block/DAC960.c:1168: error: (Each undeclared identifier is reported only
Cc: <dac@conglom-o.org>
Cc: Alessandro Polverini <alex@nibbles.it>
Cc: Matthew Wilcox <matthew@wil.cx>
commit 868047fcbb85dbb44ddd98c336fef83236a2c06a in mainline.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=8942
Use PCI_DMA_* constants instead of own private definitions Fall back to
32-bit DMA mask if a 64-bit one fails
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Acked-by: Jeff Garzik <jeff@garzik.org>
Tested-by: Lars <polynomial-c@gmx.de>
Commit 85237f202d46d55c1bffe0c5b1aa3ddc0f1dce4d introduced the
following warning:
drivers/media/video/pwc/pwc-if.c: In function "pwc_video_close":
drivers/media/video/pwc/pwc-if.c:1211: warning: "i" may be used uninitialized in this function
This is true, and can cause a broken debug message to be logged.
Here's a fix.
Fix is already in Linus' tree for 2.6.23:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=7b9fbc3e30f785412a26819aa4daf0b6c27f6c53
Fix an off-by-one error in the I/O region declaration of two
hardware monitoring drivers (lm78 and w83781d.) We were requesting
one extra port at the end of the region.
This is a regression in 2.6.22 and could prevent other drivers from
loading properly.
Already applied to Linus' tree for 2.6.23:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=15bde2f1a8e819213f54314505a5a0509673109b
(cherry picked from commit 48200baeab95fd39a7f4c4f3536c7142a64ac335)
[PATCH] V4L: cx88: Avoid a NULL pointer dereference during mpeg_open()
Bug: With a hardware encoder board installed as cx88[1] and a
non-encoder boards installed as cx88[0], an OOPS is generated
during cx8802_get_device() called from mpeg_open().
Signed-off-by: Steven Toth <stoth@hauppauge.com>
changeset 48440e893d700fb8f0de95fa7d748b711d290365 from mainline.
Initialise s_flags in get_sb_mtd_aux() from the flags parameter.
Cc: Jason Lunz <lunz@falooley.org>
[SCSI] 3w-9xxx: Fix dma mask setting
Extracted from commit 0e78d158b67fba3977f577f293c323359d80dd0e
The attached patch updates the 3ware 9000 driver:
- Fix dma mask setting to fallback to 32-bit if 64-bit fails.
Signed-off-by: Adam Radford <linuxraid@amcc.com>
commit 9f3119b70cf189530f1b46a006a052e171a1622f in mainline.
ACPI 1.0 used an RSDT with 32-bit physical addresses.
ACPI 2.0 adds an XSDT with 32-bit physical addresses.
An ACPI 2.0 aware OS is supposed to use the XSDT
(when present) instead of the RSDT.
However, several systems have failed because the XSDT
contains NULL entries -- while it is missing pointers
to needed tables, such as SSDTs.
When we find an XSDT with NULL entries, discard it
and use the ACPI 1.0 RSDT instead.
http://bugzilla.kernel.org/show_bug.cgi?id=8630
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Cc: Vincet Fortier <Vincent.Fortier1@EC.GC.CA>
Signed-off-by: Len Brown <len.brown@intel.com>
commit e5dd01154c1e9ca2400f4682602d1a4fa54c25dd in mainline.
This patch fixes the order of list_add_tail() arguments in
usb_store_new_id() so the list can have more than one single element.
Signed-off-by: Nathael Pajani <nathael.pajani@cpe.fr>
commit bec494775600b1cd7c144d31a09e1f46df9c6324 in mainline.
We want drivers/mtd/{mtdcore, mtdsuper, mtdpart}.c to be built and linked
into the same mtd.ko module. Fix the Makefile to ensure this, and remove
duplicate MODULE_ declarations in mtdpart.c, as mtdcore.c already has them.
Signed-off-by: Satyam Sharma <satyam@infradead.org>
cherry picked from commit 6175e487e314385e37f06448847e4c46c20edb44
b2c2-flexcop: fix Airstar HD5000 tuning regression
Git changeset 6bdcc6e6dbab8daffd05e5026486f34ba41a6c72 dropped the
stand-alone lgh06xf module, whose functionality was absorbed into the
dvb-pll module. However, there was a minor difference between the code
in lgh06xf and dvb-pll, which caused a regression in b2c2-flexcop
devices using the LG-H06xF NIM.
dvb-pll will probe for the presence of an i2c pll chip by performing a
single byte read, the lgh06xf driver did not do this. Unfortunately, the
code in flexcop-i2c.c does not currently support 1 byte or 0 byte reads
as a probe. Such probes with the current code will always fail.
In order to work around this problem, and restore proper functionality
of the Airstar HD5000 device, this hack was created to make the probe
appear to succeed. The single byte read in dvb_pll_attach is the only
place where such a probe would ever occur, so this change is safe, and
will not affect any other devices.
Of course, if one knew how to actually perform the read operation, it
would be better to go that route. In the meantime, however, we must
apply this workaround, in order to prevent the regression that causes
tuning to fail on the Airstar HD5000 ATSC device.
Thanks to Jarod Wilson, who had originally reported this regression, and
to Geoffrey Hausheer, whose original workaround patch led us to find the
actual cause of the problem.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
Cc: Geoffrey Hausheer <inli3epy93n@phracturedblue.com>
Acked-by: Jarod Wilson <jwilson@redhat.com>
cherry picked from commit c3624f99a8c06cfe75e0b06f23a7f7cea9d2d5ff
ivtv: fix VIDIOC_S_FBUF support: new OSD values were never actually set.
The values set with VIDIOC_S_FBUF were not actually used until the next
VIDIOC_S_FMT. Fixed.
This fixes a regression for userspace programs that were relying on these events.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Andreas Jellinghaus <aj@ciphirelabs.com>
the pwc driver has a disconnect method that waits for user space to
close the device. This opens up an opportunity for a DoS attack,
blocking the USB subsystem and making khubd's task busy wait in
kernel space. This patch shifts freeing resources to close if an opened
device is disconnected.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
This patch (as964) was suggested by Steffen Koepf. It makes
usb_get_descriptor() retry on all errors other than ETIMEDOUT, instead
of only on EPIPE. This helps with some devices.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
RX790 can't do MSI like its predecessors. Disable MSI on RX790.
Signed-off-by: Tejun Heo <htejun@gmail.com>
RD580 can't do MSI like its predecessors. Disable MSI on RD580.
Signed-off-by: Tejun Heo <teheo@suse.de>
RS690 can't do MSI like its predecessors. Disable MSI on RS690.
Cc: Henry Su <henry.su@amd.com>
Adrian Bunk wrote:
> Alois Nešpor wrote
>> PCI: Bus #0b (-#0e) is hidden behind transparent bridge #0a (-#0b) (try 'pci=assign-busses')
>> Please report the result to linux-kernel to fix this permanently"
>> dmesg:
>> "Yenta: Raising subordinate bus# of parent bus (#0a) from #0b to #0e"
>> without pci=assign-busses and nothing with pci=assign-busses.
> Bernhard?
Ok, lets kill the message. As Alois Nešpor also saw, that's fixed up by Yenta,
so PCI does not have to warn about it. PCI could still warn about it if
is_cardbus is 0 in that instance of pci_scan_bridge(), but so far I have
not seen a report where this would have been the case so I think we can
spare the kernel of that check (removes ~300 lines of asm) unless debugging
is done.
History: The whole check was added in the days before we had the fixup
for this in Yenta and pci=assign-busses was the only way to get CardBus
cards detected on many (not all) of the machines which give this warning.
In theory, there could be cases when this warning would be triggered and
it's not cardbus, then the warning should still apply, but I think this
should only be the case when working on a completely broken PCI setup,
but one may have already enabled the debug code in drivers/pci and the
patched check would then trigger.
I do not sign this off yet because it's completely untested so far, but
everyone is free to test it (with the #ifdef DEBUG replaced by #if 1 and
pr_debug( changed to printk(.
We may also dump the whole check (remove everything within the #ifdef from
the source) if that's perferred.
On Alois Nešpor's machine this would then (only when debugging) this message:
"PCI: Bus #0b (-#0e) is partially hidden behind transparent bridge #0a (-#0b)"
"partially" should be in the message on his machine because #0b of #0b-#0e
is reachable behind #0a-#0b, but not #0c-#0e.
But that differentiation is now moot anyway because the fixup in Yenta takes
care of it as far as I could see so far, which means that unless somebody
is debugging a totally broken PCI setup, this message is not needed anymore,
not even for debugging PCI.
Ok, here the patch with the following changes:
* Refined to say that the bus is only partially hidden when the parent
bus numbers are not totally way off (outside of) the child bus range
* remove the reference to pci=assign-busses and the plea to report it
We could add a pure source code-only comment to keep a reference to
pci=assign-busses the in case when this is triggered by someone who
is debugging the cause of this message and looking the way to solve it.
This patch addresses the issue with "osize too small" errors in mppe
encryption. The patch fixes the issue with wrong output buffer size
being passed to ppp decompression routine.
As pointed out by Suresh Mahalingam, the issue addressed by
ppp-fix-osize-too-small-errors-when-decoding patch is not fully resolved yet.
The size of allocated output buffer is correct, however it size passed to
ppp->rcomp->decompress in ppp_generic.c if wrong. The patch fixes that.
Signed-off-by: Konstantin Sharlaimov <konstantin.sharlaimov@gmail.com>
There are special PHY settings available on Yukon EC-U chip that
should not get cleared. This should solve mysterious errors on some
motherboards (like Gigabyte DS-3).
[NET]: Share correct feature code between bridging and bonding
http://bugzilla.kernel.org/show_bug.cgi?id=8797 shows that the
bonding driver may produce bogus combinations of the checksum
flags and SG/TSO.
For example, if you bond devices with NETIF_F_HW_CSUM and
NETIF_F_IP_CSUM you'll end up with a bonding device that
has neither flag set. If both have TSO then this produces
an illegal combination.
The bridge device on the other hand has the correct code to
deal with this.
In fact, the same code can be used for both. So this patch
moves that logic into net/core/dev.c and uses it for both
bonding and bridging.
In the process I've made small adjustments such as only
setting GSO_ROBUST if at least one constituent device
supports it.
The SATA controller device ID is different according to
the onchip SATA type set in the system BIOS:
Device Device ID
SATA in IDE mode 0x4390
SATA in AHCI mode 0x4391
SATA in non-raid5 driver 0x4392
SATA in raid5 driver 0x4393
Although the device ID is different, they use the same AHCI driver
.The attached file is the patch for adding these device
IDs for ATI SB700.
Signed-off-by: su henry <henry.su.ati@gmail.com>
If the forcedeth driver receives too much work in an interrupt, it
assumes it has a broken hardware with stuck IRQ. It works around the
problem by disabling interrupts on the nic but makes a printk while
holding device spinlog - which isn't smart thing to do if you have
netconsole on the same nic.
This patch moves the printk's out of the spinlock protected area.
Without this patch the machine hangs hard. With this patch everything
still works even when there is significant increase on CPU usage while
using the nic.
Signed-off-by: Timo Jantunen <jeti@iki.fi>
Theory : though needless, it should not have hurt.
Practice: it does not play nice with DEBUG_SHIRQ + LOCKDEP + UP
(see https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=3D242572).
The patch makes sense in itself but I should dig why it has an effect
on #242572 (assuming that NAPI do not change in a near future).
Patch in mainline as 313b0305b5a1e7e0fb39383befbf79558ce68a9c.
Backported to 2.6.22-stable by Thomas M=FCller.
Signed-off-by: Thomas M=FCller <thomas@mathtm.de>
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
