timeout should not be set as part of open call.
It should be set as part of Probe if watchdog enabled on
probe, Otherwise timeout should be 0 since watchdog is not enabled.
Bug 200160105
Change-Id: I2bc0f35436dafd01d17e3ea2ec5459fd0d75af5a
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
Reviewed-on: http://git-master/r/927429
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Using Tegra WDT to trigger FIQ when system is in soft lockup.
Bug 1581432
Change-Id: I853a88a3f6e9402c978db18c5a63e903c582040a
Signed-off-by: Renn Wu <rewu@nvidia.com>
Reviewed-on: http://git-master/r/265871
(cherry picked from commit f115f435d471af22ddec5e9d969662f79193f846)
Reviewed-on: http://git-master/r/680353
Reviewed-by: Winnie Hsu <whsu@nvidia.com>
Implement Tegra WDT FIQ debug function.
Default is disabled.
Bug 1581432
Change-Id: Ic81ab4cd3285080016b37191e6e0fab18e330a30
Reviewed-on: http://git-master/r/#/c/271988
Reviewed-on: http://git-master/r/662550
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
Add DT supports for the palmas watchdog.
bug 1486603
Change-Id: I1f22b3f1eccab87c28f3f0726dcda19af6f584d1
Reviewed-on: http://git-master/r/387189
Reviewed-on: http://git-master/r/406970
fix build error when tegra watchdog is enabled
Bug 1485770
Change-Id: Idea7e779b7b06e329751c1a1f0b8185969df020b
Signed-off-by: Josh Kuo <joshk@nvidia.com>
Reviewed-on: http://git-master/r/391678
Correct the logic to check if WDT is enabled.
Fix another coding bug if CONFIG_WATCHDOG_NOWAYOUT
is not defined.
Bug 1384384
Change-Id: Ib6378bb9a080cf8c9fc724a5856c0fc665064ff1
Signed-off-by: Srinivas <ysrinivas@nvidia.com>
Reviewed-on: http://git-master/r/357684
Reviewed-by: Sumeet Gupta <sumeetg@nvidia.com>
Tested-by: Revati Ranjan Prasad <revatip@nvidia.com>
Reviewed-by: Revati Ranjan Prasad <revatip@nvidia.com>
Reviewed-by: Sandeep Trasi <strasi@nvidia.com>
CONFIG_TEGRA_USE_SECURE_KERNEL will be deprecated moving forward.
Since we are using TLK as the secure firmware it makes more sense
to use Trusted Little Kernel driver's config instead.
Bug 1475528
Change-Id: I16e5cf4dbff8ef91524c8ff3c6d28a2589f91435
Reviewed-on: http://git-master/r/377618
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
non-secure mode."
This reverts commit 7f93a0dddf39f372c064f772f9af6903e91aaacf as
the t132ref builds break with the following errors -
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:45: undefined reference to `is_secure_mode'
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:57: undefined reference to `is_secure_mode'
<android>/kernel/drivers/platform/tegra/../../../arch/arm/mach-tegra/reset.c:58: undefined reference to `tegra_generic_smc'
Change-Id: I4e44c2ffba4e1c013213e543b67f2d49a928b764
Reviewed-on: http://git-master/r/365347
- Remove CONFIG_TEGRA_USE_SECURE_KERNEL config option
- Use DBGDSCR.NS bit to dynamically get secure/non-secure mode
- Replace ifdefs with dynamic code.
- Keep CONFIG_TRUSTED_LITTLE_KERNEL to enable secure os
bug 1411345
Change-Id: I75ddfed7a35fcb30e2772bb43057ae022bcf09b3
Signed-off-by: Nitin Sehgal <nsehgal@nvidia.com>
Reviewed-on: http://git-master/r/353155
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
commit dace8bbfccfd9e4fcccfffcfbd82881fda3e756f upstream.
If loaded with isapnp = 0 the driver explodes. This is catching
people out now and then. What should happen in the working case is
a complete mystery and the code appears terminally confused, but we
can at least make the error path work properly.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
Partially-Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=53991
We have already configured the FIQ debugger to give us callstack for
any online CPU.
Bug 1326082
Change-Id: I26d15084bd687f718631005881288c39f9e36081
Reviewed-on: http://git-master/r/338251
Add watchdog timer driver for as3722 device.
The timer can be start/stop and set timing through watchdog subsystem
callbacks.
Bug 1396052
Change-Id: Ib4ce5bdac1bcca37907c5f89820a2719d54ce442
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/333643
This is the 3.10.17 stable release
drivers/usb/host/xhci.c
Change-Id: I6bd3b15ff92a0b94568b9d02e9bb1036becfca20
commit 8612ed0d97abcf1c016d34755b7cf2060de71963 upstream.
Calling the WDIOC_GETSTATUS & WDIOC_GETBOOTSTATUS and twice will cause a
interruptible deadlock.
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
Most of the set up for the debugger is done by the secure
OS, but the kernel setup that needs to be done is done here.
Use the following config options to enable the debugger -
CONFIG_FIQ=y
CONFIG_TEGRA_FIQ_DEBUGGER=y
CONFIG_FIQ_GLUE=y
CONFIG_FIQ_DEBUGGER=y
CONFIG_FIQ_DEBUGGER_CONSOLE=y
CONFIG_TEGRA_WATCHDOG=y
CONFIG_TEGRA_WATCHDOG_ENABLE_ON_PROBE=y
Bug 1326082
Original-author: Hyung Taek Ryoo <hryoo@nvidia.com>
Change-Id: If1a5dd4f158530dea6c0455ead74a8eeaa226163
Reviewed-on: http://git-master/r/#/c/261217
Reviewed-on: http://git-master/r/289165
obtain interrupts through palmas_irq_get_virq instead of
platform_get_irq for MFD palmas drivers.
Change-Id: I66791b6adcb2c7f365d5b90d7b76c6d3ad66c8c6
Signed-off-by: Ajay Nandakumar <anandakumarm@nvidia.com>
Reviewed-on: http://git-master/r/267068
Reviewed-by: Dan Willemsen <dwillemsen@nvidia.com>
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
If device is suspended then do not reset WDT timer from thread.
bug 1257433
Change-Id: I4e5a5faea20365e7387b26404bb7e98ffe25f832
Reviewed-on: http://git-master/r/221389
Tested-by: Greg Heinrich <gheinrich@nvidia.com>
Tested-by: Prashant Malani <pmalani@nvidia.com>
The Maxim77660 system watchdog timer generates interrupt 2 second before
it expire. Within this 2 second, it need to reset the timer. Sometime, on
cpu stress, it is not possible to reset wdt in 2 sec and in this case
it is require to have more time.
Add high priority kthread which run on more faster way and reset wdt in
much advance of expire. The time offset is configurable through platform
data.
Change-Id: I7610bc301889c0e9397868c990594ee7374948f0
Reviewed-on: http://git-master/r/212999
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Add watchdog timer driver for palmas device.
callbacks.
The driver also support wakeup capability and wakeup can be enable/disable
through user level power wakeup sysfs interface.
Change-Id: Icda02290f22ccdc45f2cfa675b8a7dae73f4d313
Reviewed-on: http://git-master/r/203663
(cherry picked from commit d6fc5598f90444260ed17f88d9ecceeb7c252ca7)
Reviewed-on: http://git-master/r/211595
Reviewed-by: Simone Willett <swillett@nvidia.com>
Correctly pass the mask and value when calling max77660_reg_update()
for timeout update.
bug 1255168
Change-Id: I83de0f061db644c79cdee948ffa221e8bad5bcf5
Reviewed-on: http://git-master/r/211671
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Change-Id: I91dd3214092ab5b450e74bc5bf772ee02f6b432e
Signed-off-by: Bo Yan <byan@nvidia.com>
Reviewed-on: http://git-master/r/207770
(cherry picked from commit 17d14202ad24baec56574b52001cc7ba4c625b9c)
Reviewed-on: http://git-master/r/210112
Reviewed-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Kamal Balagopalan <kbalagopalan@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
bug 1239979
Change-Id: I4ca7e4682bf2b27254024f9e8236c7e8868b4e73
Signed-off-by: Xin Xie <xxie@nvidia.com>
Reviewed-on: http://git-master/r/202740
bug 1239765
Change-Id: Ia2c5c83c0489b21d3fb5dcc005a9b7c07fb9b98c
Reviewed-on: http://git-master/r/202662
Bug 122235
Change-Id: Iebc1c97d0c973db9d17749f70099458b94e9079b
Signed-off-by: Pradeep Goudagunta <pgoudagunta@nvidia.com>
Reviewed-on: http://git-master/r/196004
Initialize watchdog time early so that it can handle the watchdog timer
expire effectively.
Bug 1225350
Change-Id: I7338863639bbc3c634a891ff418b3c486410779e
Reviewed-on: http://git-master/r/195510
Set watchdog max77660 IRQ as wakeup capable.
Change-Id: I9948b59283072061d3ab5c074f387ea1ba4e7934
Reviewed-on: http://git-master/r/194718
Implement suspend/resume of MAX77660 system watchdog timer:
- Keep enabling if wakeup enable.
- Disable watchdog timer in suspend and re-enable in resume if
wakeup from watchdog timer is not enabled and timeout is set.
Change-Id: I90ee8c43e11f947ec71370a9095357b229f89d36
Reviewed-on: http://git-master/r/194547
Use the namespaced macro for MAX77660 global config registers.
Accordingly changed the code.
Change-Id: I75ab0fbad978359b22dcdc419dd5830460194732
Reviewed-on: http://git-master/r/194454
Add watchdog timer driver for MAX77660 system watch dog timer.
Change-Id: I2470f90f924d648d12d8303be6524dd5a2401521
Reviewed-on: http://git-master/r/192674
These changes have no effect if CONFIG_GCOV_KERNEL is not set in
defconfig. It is easier to trigger GCOV for kernel if this patch
is in by only setting the before mentioned flag.
Change-Id: I8aade309da2da62c4b3889bd84e4123ba8f182da
Signed-off-by: Juha Tukkinen <jtukkinen@nvidia.com>
Reviewed-on: http://git-master/r/62999
Reviewed-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Tested-by: Rohan Somvanshi <rsomvanshi@nvidia.com>
Rebase-Id: R4c238f707f1db600f188ae83426336753992b7be
include module.h to fix broken compilation
with tegra watchdog enabled
Bug 1179099
Change-Id: Ic03f43ab3f3fef0c190a46271d16b192f04539f7
Reviewed-on: http://git-master/r/165241
- Add compilation flag to treat warning as error
- Handle error of unused variable
- Handle error of uninitialised variable
bug 949219
Change-Id: I07437be5eaa7bf7abe5494c828690b6be3b98178
Signed-off-by: schowdary <schowdary@nvidia.com>
Reviewed-on: http://git-master/r/118039
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Rebase-Id: R5158d12bf942a5189cb5a7cbc838096dda4d4915
Enable FIQ on 2nd watchdog expiry to make use of FIQ debugger. FIQ
debugger can be used to dump call-stack and registers when WDT logic
triggers FIQ on 2nd timeout.
Bug 970018
Change-Id: Ia2e7f8b136499974ff51f2f0c2ef55704dfe37e1
Signed-off-by: Kamal Kannan Balagopalan <kbalagopalan@nvidia.com>
Reviewed-on: http://git-master/r/110953
Reviewed-by: Steve Kuo <stevek@nvidia.com>
Rebase-Id: Rc00872f12af72dec27c36f5c6d83e2f6fd381843
- Make all CPU watchdogs accessible except WDT0
- CPU WDT0 is reserved for suspend/resume WDT recovery
- Fix WDT enable sequence on watchdog driver probe
Bug 857748
Change-Id: Ia2d07856c32230ab8c9195fee151af09bce3ddde
Reviewed-on: http://git-master/r/99780
Rebase-Id: R662dc43398da4ce823cb351bd1bb8365623f4185
Reviewed-on: http://git-master/r/70702
(cherry picked from commit 50992cf718c37882d90e2b781fbe3f01b4997df8)
Reviewed-on: http://git-master/r/77928
(cherry picked from commit a51315ad482758e53a75096be0415ca9b49b9483)
Change-Id: I22389cfc7010937dc60c5b1aa4b59c4992f9906b
Signed-off-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-on: http://git-master/r/80003
Rebase-Id: R2e55efe6f1be3b3bc79a2eadc0e2c5d39b8f4849
Reviewed-on: http://git-master/r/70625
(cherry picked from commit 90add398c43bb111903015bb6a3cd57a8d62262f)
Reviewed-on: http://git-master/r/77926
(cherry picked from commit 4a781c10f2b302f3b467b69060028f9c3b2f9774)
Change-Id: Ia2b4935896a44d1717e20693e26a244c6f556c98
Reviewed-on: http://git-master/r/79999
Rebase-Id: R497e7d83e2e0f685d6f9d18f72b7ab634420b87f
Add KEEPALIVE functionality to Tegra WDT driver for use by user space
applications.
Bug 887733
Reviewed-on: http://git-master/r/77135
Change-Id: I966371bc5db34416de08c8dc2af9069b4bd34c5d
Reviewed-on: http://git-master/r/77750
Rebase-Id: Rad0e04efb1386d078f4359f85c0ba671a3f8c43a
Fix wdt resource definition issue either.
Bug 790458
Original-Change-Id: I7c80d6c243c42a0e632603dfcc255b70995358b2
Reviewed-on: http://git-master/r/20646
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Tested-by: Krishna Reddy <vdumpa@nvidia.com>
Original-Change-Id: I9897fb6614d75508bd0ffd6e866acf27a24a0cb5
Rebase-Id: R165f408464819298bdcc1f0b677c50b46071be90
Use new watch dog controller for CONFIG_ARCH_TEGRA_3x_SOC.
Bug 790458
Original-Change-Id: I43975a2794f44f612a5f16674cd674aeebe4e6be
Reviewed-on: http://git-master/r/19715
Original-Change-Id: Ic8c9907998a2ab1777ea2b00f1acceb6d66c10e5
Rebase-Id: Ra0b9af5a0642fab2d13816f04c0c340ea42a45c8
Opening the Tegra WDT device from user space is causing the kernel
panic. It is found that the device file private data pointer is passing
incorrectly in the orignal code.
bug 786885
Original-Change-Id: I4646b02c5a804c07d05ba01e35034408cc8e3e4e
Reviewed-on: http://git-master/r/23629
Tested-by: Xin Xie <xxie@nvidia.com>
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Rebase-Id: Ra37e36461d02b1482bcb815dc554104cf552544d
To allow the spinlock lockup detection to actually trigger after
60 seconds, the tegra_wdt heartbeat needs to be longer than that.
Bumping it to 120sec, as at the 50% marker the watchdog takes an
interrupt.
Change-Id: I099fd7720d65c0e2050fa91161e30485fe84a1ed
Signed-off-by: JP Abgrall <jpa@google.com>
Rebase-Id: R89dfdbb2a0d1c756a79b5e77205d74a27ab6185b
Fix not re-enabling watchdog resume if it was enabled in probe
Add clearing watchdog interrupt in probe
Remove tegra_wdt_set_timeout
Change-Id: I8fdbb6da3eda64a85a73ed85ab979a5ee0261c37
Signed-off-by: Dmitriy Gruzman <dmitriy.gruzman@motorola.com>
Rebase-Id: R436dfb410144e55c409b03d3ebd09866a08bd276
Add a config option to enable the watchdog driver from probe
Reduce the default timeout to 30 seconds
Read the reset reason and print a messge if the last reboot was
due to watchdog reset
Change-Id: I7500ef236089b06ffcff3d8e7d86a5b9060b59cb
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
Rebase-Id: R120a350e6eee17d286555670d070584624b654cb
add a driver for the hardware watchdog timer embedded in NVIDIA
Tegra SoCs
Change-Id: I45bc829f26f350143d5a07e1f4ddc46d24f3a54c
Signed-off-by: Gary King <gking@nvidia.com>
Rebase-Id: Rf9253734da02097ba5c6fdfa4aa8ed7a3ca307f7
devm_ioremap_resource does sanity checks on the given resource. No need to
duplicate this in the driver.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
A race condition exists when registering the first watchdog device.
Sequence of events:
- watchdog_register_device calls watchdog_dev_register
- watchdog_dev_register creates the watchdog misc device by calling
misc_register.
At that time, the matching character device (/dev/watchdog0) does not yet
exist, and old_wdd is not set either.
- Userspace gets an event and opens /dev/watchdog
- watchdog_open is called and sets wdd = old_wdd, which is still NULL,
and tries to dereference it. This causes the kernel to panic.
Seen with systemd trying to open /dev/watchdog immediately after
it was created.
Reported-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Tested-by: Arkadiusz Miskiewicz <arekm@maven.pl>
Use the newly introduced devm_ioremap_resource() instead of
devm_request_and_ioremap() which provides more consistent error handling.
devm_ioremap_resource() provides its own error messages; so all explicit
error messages can be removed from the failure code paths.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Reviewed-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Gabor Juhos <juhosg@openwrt.org>
